WU failing
Forcinghavok
WU failing
Post by Forcinghavok »
I started this one day and the whole computer crashed and gave me a blue screen. Then I run the same WU the next day and the WU is failing? Two part question?
1.) Why did the whole computer crash first?
2.) Why did the work unit crash or fail?
*********************** Log Started 2019-12-11T21:40:40Z ***********************
21:40:40:************************* Folding@home Client *************************
21:40:40:        Website: https://foldingathome.org/
21:40:40:      Copyright: (c) 2009-2018 foldingathome.org
21:40:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:40:40:           Args:
21:40:40:         Config: C:\Users\erikb\AppData\Roaming\FAHClient\config.xml
21:40:40:******************************** Build ********************************
21:40:40:        Version: 7.5.1
21:40:40:           Date: May 11 2018
21:40:40:           Time: 13:06:32
21:40:40:     Repository: Git
21:40:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:40:40:         Branch: master
21:40:40:       Compiler: Visual C++ 2008
21:40:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:40:40:       Platform: win32 10
21:40:40:           Bits: 32
21:40:40:           Mode: Release
21:40:40:******************************* System ********************************
21:40:40:            CPU: AMD FX(tm)-8350 Eight-Core Processor
21:40:40:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
21:40:40:           CPUs: 8
21:40:40:         Memory: 15.90GiB
21:40:40:    Free Memory: 13.55GiB
21:40:40:        Threads: WINDOWS_THREADS
21:40:40:     OS Version: 6.2
21:40:40:    Has Battery: false
21:40:40:     On Battery: false
21:40:40:     UTC Offset: -5
21:40:40:            PID: 1316
21:40:40:            CWD: C:\Users\erikb\AppData\Roaming\FAHClient
21:40:40:             OS: Windows 10 Home
21:40:40:        OS Arch: AMD64
21:40:40:           GPUs: 1
21:40:40:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
21:40:40:                 470/480/570/580]
21:40:40:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:40:40:                 specified module could not be found.
21:40:40:
21:40:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2906.10
21:40:40:  Win32 Service: false
21:40:40:***********************************************************************
21:40:41:<config>
21:40:41:  <!-- Folding Core -->
21:40:41:  <checkpoint v='3'/>
21:40:41:
21:40:41:  <!-- Network -->
21:40:41:  <proxy v=':8080'/>
21:40:41:
21:40:41:  <!-- Slot Control -->
21:40:41:  <pause-on-battery v='false'/>
21:40:41:  <power v='full'/>
21:40:41:
21:40:41:  <!-- User Information -->
21:40:41:  <team v='2092'/>
21:40:41:  <user v='forcinghavok'/>
21:40:41:
21:40:41:  <!-- Folding Slots -->
21:40:41:  <slot id='0' type='CPU'>
21:40:41:    <cpus v='4'/>
21:40:41:    <idle v='true'/>
21:40:41:    <paused v='true'/>
21:40:41:  </slot>
21:40:41:  <slot id='1' type='GPU'>
21:40:41:  </slot>
21:40:41:</config>
21:40:41:Trying to access database...
21:40:41:Successfully acquired database lock
21:40:41:Enabled folding slot 00: PAUSED cpu:4 (by user)
21:40:41:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (by user)
21:42:19:FS00:Unpaused
21:42:19:FS01:Unpaused
21:42:19:WU02:FS01:Starting
21:42:19:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:42:20:WU02:FS01:Started FahCore on PID 7036
21:42:20:WU02:FS01:Core PID:7196
21:42:20:WU02:FS01:FahCore 0x21 started
21:42:20:WU01:FS00:Starting
21:42:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
21:42:20:WU01:FS00:Started FahCore on PID 5240
21:42:20:WU01:FS00:Core PID:1988
21:42:20:WU01:FS00:FahCore 0xa7 started
21:42:21:WU02:FS01:0x21:*********************** Log Started 2019-12-11T21:42:20Z ***********************
21:42:21:WU02:FS01:0x21:Project: 14185 (Run 16, Clone 81, Gen 28)
21:42:21:WU02:FS01:0x21:Unit: 0x0000004d0002894c5d38965c6ce67471
21:42:21:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:42:21:WU02:FS01:0x21:Machine: 1
21:42:21:WU02:FS01:0x21:Digital signatures verified
21:42:21:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:42:21:WU02:FS01:0x21:Version 0.0.20
21:42:21:WU02:FS01:0x21:  Found a checkpoint file
21:42:21:WU01:FS00:0xa7:*********************** Log Started 2019-12-11T21:42:21Z ***********************
21:42:21:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:42:21:WU01:FS00:0xa7:       Type: 0xa7
21:42:21:WU01:FS00:0xa7:       Core: Gromacs
21:42:21:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 5240 -checkpoint 3 -np 4
21:42:21:WU01:FS00:0xa7:************************************ CBang *************************************
21:42:21:WU01:FS00:0xa7:       Date: Oct 26 2019
21:42:21:WU01:FS00:0xa7:       Time: 01:38:25
21:42:21:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:42:21:WU01:FS00:0xa7:     Branch: master
21:42:21:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:42:21:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:42:21:WU01:FS00:0xa7:   Platform: win32 10
21:42:21:WU01:FS00:0xa7:       Bits: 64
21:42:21:WU01:FS00:0xa7:       Mode: Release
21:42:21:WU01:FS00:0xa7:************************************ System ************************************
21:42:21:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
21:42:21:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
21:42:21:WU01:FS00:0xa7:       CPUs: 8
21:42:21:WU01:FS00:0xa7:     Memory: 15.90GiB
21:42:21:WU01:FS00:0xa7:Free Memory: 13.58GiB
21:42:21:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:42:21:WU01:FS00:0xa7: OS Version: 6.2
21:42:21:WU01:FS00:0xa7:Has Battery: false
21:42:21:WU01:FS00:0xa7: On Battery: false
21:42:21:WU01:FS00:0xa7: UTC Offset: -5
21:42:21:WU01:FS00:0xa7:        PID: 1988
21:42:21:WU01:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
21:42:21:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:42:21:WU01:FS00:0xa7:    Version: 0.0.18
21:42:21:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:42:21:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:42:21:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:42:21:WU01:FS00:0xa7:       Time: 01:52:30
21:42:21:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:42:21:WU01:FS00:0xa7:************************************ Build *************************************
21:42:21:WU01:FS00:0xa7:       SIMD: avx_256
21:42:21:WU01:FS00:0xa7:********************************************************************************
21:42:21:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 512, Gen 18)
21:42:21:WU01:FS00:0xa7:Unit: 0x000000180002894b5d77e4e3207977f7
21:42:21:WU01:FS00:0xa7:Digital signatures verified
21:42:21:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpi state.cpt -cpt 3 -nt 4
21:42:22:WU01:FS00:0xa7:ERROR:Guru Meditation #533b948fb6ab0694.359f25ac17666ad5 (3052920.6105840) '01/01/frame18.trr'
21:42:22:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:42:22:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:42:22:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:42:22:WU01:FS00:0xa7:Saving result file frame18.trr
21:42:25:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:42:25:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:42:26:WU01:FS00:Starting
21:42:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
21:42:26:WU01:FS00:Started FahCore on PID 2944
21:42:26:WU01:FS00:Core PID:4872
21:42:26:WU01:FS00:FahCore 0xa7 started
21:42:26:WU01:FS00:0xa7:*********************** Log Started 2019-12-11T21:42:26Z ***********************
21:42:26:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:42:26:WU01:FS00:0xa7:       Type: 0xa7
21:42:26:WU01:FS00:0xa7:       Core: Gromacs
21:42:26:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2944 -checkpoint 3 -np 4
21:42:26:WU01:FS00:0xa7:************************************ CBang *************************************
21:42:26:WU01:FS00:0xa7:       Date: Oct 26 2019
21:42:26:WU01:FS00:0xa7:       Time: 01:38:25
21:42:26:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:42:26:WU01:FS00:0xa7:     Branch: master
21:42:26:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:42:26:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:42:26:WU01:FS00:0xa7:   Platform: win32 10
21:42:26:WU01:FS00:0xa7:       Bits: 64
21:42:26:WU01:FS00:0xa7:       Mode: Release
21:42:26:WU01:FS00:0xa7:************************************ System ************************************
21:42:26:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
21:42:26:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
21:42:26:WU01:FS00:0xa7:       CPUs: 8
21:42:26:WU01:FS00:0xa7:     Memory: 15.90GiB
21:42:26:WU01:FS00:0xa7:Free Memory: 13.45GiB
21:42:26:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:42:26:WU01:FS00:0xa7: OS Version: 6.2
21:42:26:WU01:FS00:0xa7:Has Battery: false
21:42:26:WU01:FS00:0xa7: On Battery: false
21:42:26:WU01:FS00:0xa7: UTC Offset: -5
21:42:26:WU01:FS00:0xa7:        PID: 4872
21:42:26:WU01:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
21:42:26:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:42:26:WU01:FS00:0xa7:    Version: 0.0.18
21:42:26:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:42:26:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:42:26:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:42:26:WU01:FS00:0xa7:       Time: 01:52:30
21:42:26:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:42:26:WU01:FS00:0xa7:************************************ Build *************************************
21:42:26:WU01:FS00:0xa7:       SIMD: avx_256
21:42:26:WU01:FS00:0xa7:********************************************************************************
21:42:26:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 512, Gen 18)
21:42:26:WU01:FS00:0xa7:Unit: 0x000000180002894b5d77e4e3207977f7
21:42:26:WU01:FS00:0xa7:Digital signatures verified
21:42:26:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpi state.cpt -cpt 3 -nt 4
21:42:26:WU01:FS00:0xa7:ERROR:Guru Meditation #533b948fb6ab0694.359f25ac17666ad5 (3052920.6105840) '01/01/frame18.trr'
21:42:26:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:42:26:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:42:26:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:42:26:WU01:FS00:0xa7:Saving result file frame18.trr
21:42:27:WU02:FS01:0x21:Completed 500000 out of 12500000 steps (4%)
21:42:27:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:42:30:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:42:30:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:42:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:42:43:Removing old file 'configs/config-20191202-012353.xml'
21:42:43:Saving configuration to config.xml
21:42:43:<config>
21:42:43:  <!-- Folding Core -->
21:42:43:  <checkpoint v='3'/>
21:42:43:
21:42:43:  <!-- Network -->
21:42:43:  <proxy v=':8080'/>
21:42:43:
21:42:43:  <!-- Slot Control -->
21:42:43:  <pause-on-battery v='false'/>
21:42:43:  <power v='full'/>
21:42:43:
21:42:43:  <!-- User Information -->
21:42:43:  <team v='2092'/>
21:42:43:  <user v='forcinghavok'/>
21:42:43:
21:42:43:  <!-- Folding Slots -->
21:42:43:  <slot id='0' type='CPU'>
21:42:43:    <cpus v='4'/>
21:42:43:  </slot>
21:42:43:  <slot id='1' type='GPU'/>
21:42:43:</config>
21:43:26:WU01:FS00:Starting
21:43:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
21:43:26:WU01:FS00:Started FahCore on PID 7468
21:43:26:WU01:FS00:Core PID:6320
21:43:26:WU01:FS00:FahCore 0xa7 started
21:43:26:WU01:FS00:0xa7:*********************** Log Started 2019-12-11T21:43:26Z ***********************
21:43:26:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:43:26:WU01:FS00:0xa7:       Type: 0xa7
21:43:26:WU01:FS00:0xa7:       Core: Gromacs
21:43:26:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 7468 -checkpoint 3 -np 4
21:43:26:WU01:FS00:0xa7:************************************ CBang *************************************
21:43:26:WU01:FS00:0xa7:       Date: Oct 26 2019
21:43:26:WU01:FS00:0xa7:       Time: 01:38:25
21:43:26:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:43:26:WU01:FS00:0xa7:     Branch: master
21:43:26:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:43:26:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:43:26:WU01:FS00:0xa7:   Platform: win32 10
21:43:26:WU01:FS00:0xa7:       Bits: 64
21:43:26:WU01:FS00:0xa7:       Mode: Release
21:43:26:WU01:FS00:0xa7:************************************ System ************************************
21:43:26:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
21:43:26:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
21:43:26:WU01:FS00:0xa7:       CPUs: 8
21:43:26:WU01:FS00:0xa7:     Memory: 15.90GiB
21:43:26:WU01:FS00:0xa7:Free Memory: 13.31GiB
21:43:26:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:43:26:WU01:FS00:0xa7: OS Version: 6.2
21:43:26:WU01:FS00:0xa7:Has Battery: false
21:43:26:WU01:FS00:0xa7: On Battery: false
21:43:26:WU01:FS00:0xa7: UTC Offset: -5
21:43:26:WU01:FS00:0xa7:        PID: 6320
21:43:26:WU01:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
21:43:26:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:43:26:WU01:FS00:0xa7:    Version: 0.0.18
21:43:26:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:43:26:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:43:26:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:43:26:WU01:FS00:0xa7:       Time: 01:52:30
21:43:26:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:43:26:WU01:FS00:0xa7:************************************ Build *************************************
21:43:26:WU01:FS00:0xa7:       SIMD: avx_256
21:43:26:WU01:FS00:0xa7:********************************************************************************
21:43:26:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 512, Gen 18)
21:43:26:WU01:FS00:0xa7:Unit: 0x000000180002894b5d77e4e3207977f7
21:43:26:WU01:FS00:0xa7:Digital signatures verified
21:43:26:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpi state.cpt -cpt 3 -nt 4
21:43:26:WU01:FS00:0xa7:ERROR:Guru Meditation #533b948fb6ab0694.359f25ac17666ad5 (3052920.6105840) '01/01/frame18.trr'
21:43:26:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:43:26:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:43:26:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:43:26:WU01:FS00:0xa7:Saving result file frame18.trr
21:43:30:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:43:30:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:44:19:WU02:FS01:0x21:Completed 625000 out of 12500000 steps (5%)
21:44:26:WU01:FS00:Starting
21:44:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
21:44:26:WU01:FS00:Started FahCore on PID 3664
21:44:26:WU01:FS00:Core PID:588
21:44:26:WU01:FS00:FahCore 0xa7 started
21:44:26:WU01:FS00:0xa7:*********************** Log Started 2019-12-11T21:44:26Z ***********************
21:44:26:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:44:26:WU01:FS00:0xa7:       Type: 0xa7
21:44:26:WU01:FS00:0xa7:       Core: Gromacs
21:44:26:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3664 -checkpoint 3 -np 4
21:44:26:WU01:FS00:0xa7:************************************ CBang *************************************
21:44:26:WU01:FS00:0xa7:       Date: Oct 26 2019
21:44:26:WU01:FS00:0xa7:       Time: 01:38:25
21:44:26:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:44:26:WU01:FS00:0xa7:     Branch: master
21:44:26:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:44:26:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:44:26:WU01:FS00:0xa7:   Platform: win32 10
21:44:26:WU01:FS00:0xa7:       Bits: 64
21:44:26:WU01:FS00:0xa7:       Mode: Release
21:44:26:WU01:FS00:0xa7:************************************ System ************************************
21:44:26:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
21:44:26:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
21:44:26:WU01:FS00:0xa7:       CPUs: 8
21:44:26:WU01:FS00:0xa7:     Memory: 15.90GiB
21:44:26:WU01:FS00:0xa7:Free Memory: 13.29GiB
21:44:26:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:44:26:WU01:FS00:0xa7: OS Version: 6.2
21:44:26:WU01:FS00:0xa7:Has Battery: false
21:44:26:WU01:FS00:0xa7: On Battery: false
21:44:26:WU01:FS00:0xa7: UTC Offset: -5
21:44:26:WU01:FS00:0xa7:        PID: 588
21:44:26:WU01:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
21:44:26:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:44:26:WU01:FS00:0xa7:    Version: 0.0.18
21:44:27:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:44:27:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:44:27:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:44:27:WU01:FS00:0xa7:       Date: Oct 26 2019
21:44:27:WU01:FS00:0xa7:       Time: 01:52:30
21:44:27:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:44:27:WU01:FS00:0xa7:     Branch: master
21:44:27:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:44:27:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:44:27:WU01:FS00:0xa7:   Platform: win32 10
21:44:27:WU01:FS00:0xa7:       Bits: 64
21:44:27:WU01:FS00:0xa7:       Mode: Release
21:44:27:WU01:FS00:0xa7:************************************ Build *************************************
21:44:27:WU01:FS00:0xa7:       SIMD: avx_256
21:44:27:WU01:FS00:0xa7:********************************************************************************
21:44:27:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 512, Gen 18)
21:44:27:WU01:FS00:0xa7:Unit: 0x000000180002894b5d77e4e3207977f7
21:44:27:WU01:FS00:0xa7:Digital signatures verified
21:44:27:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpi state.cpt -cpt 3 -nt 4
21:44:27:WU01:FS00:0xa7:ERROR:Guru Meditation #533b948fb6ab0694.359f25ac17666ad5 (3052920.6105840) '01/01/frame18.trr'
21:44:27:WU01:FS00:0xa7:WARNING:Unexpected exit() call
21:44:27:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
21:44:27:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
21:44:27:WU01:FS00:0xa7:Saving result file frame18.trr
21:44:30:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:44:30:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:44:47:FS00:Paused
21:45:46:Removing old file 'configs/config-20191205-005859.xml'
21:45:46:Saving configuration to config.xml
21:45:46:<config>
21:45:46:  <!-- Folding Core -->
21:45:46:  <checkpoint v='3'/>
21:45:46:
21:45:46:  <!-- Network -->
21:45:46:  <proxy v=':8080'/>
21:45:46:
21:45:46:  <!-- Slot Control -->
21:45:46:  <pause-on-battery v='false'/>
21:45:46:  <power v='full'/>
21:45:46:
21:45:46:  <!-- User Information -->
21:45:46:  <team v='2092'/>
21:45:46:  <user v='forcinghavok'/>
21:45:46:
21:45:46:  <!-- Folding Slots -->
21:45:46:  <slot id='0' type='CPU'>
21:45:46:    <cpus v='4'/>
21:45:46:    <paused v='true'/>
21:45:46:  </slot>
21:45:46:  <slot id='1' type='GPU'/>
21:45:46:</config>
21:46:12:WU02:FS01:0x21:Completed 750000 out of 12500000 steps (6%)
21:48:06:WU02:FS01:0x21:Completed 875000 out of 12500000 steps (7%)
21:50:00:WU02:FS01:0x21:Completed 1000000 out of 12500000 steps (8%)
21:51:53:WU02:FS01:0x21:Completed 1125000 out of 12500000 steps (9%)
21:53:47:WU02:FS01:0x21:Completed 1250000 out of 12500000 steps (10%)
21:55:42:WU02:FS01:0x21:Completed 1375000 out of 12500000 steps (11%)
21:57:35:WU02:FS01:0x21:Completed 1500000 out of 12500000 steps (12%)
21:59:30:WU02:FS01:0x21:Completed 1625000 out of 12500000 steps (13%)
22:01:23:WU02:FS01:0x21:Completed 1750000 out of 12500000 steps (14%)
22:03:17:WU02:FS01:0x21:Completed 1875000 out of 12500000 steps (15%)
22:05:11:WU02:FS01:0x21:Completed 2000000 out of 12500000 steps (16%)
22:07:05:WU02:FS01:0x21:Completed 2125000 out of 12500000 steps (17%)
22:08:58:WU02:FS01:0x21:Completed 2250000 out of 12500000 steps (18%)
22:10:51:WU02:FS01:0x21:Completed 2375000 out of 12500000 steps (19%)
22:12:44:WU02:FS01:0x21:Completed 2500000 out of 12500000 steps (20%)
22:14:38:WU02:FS01:0x21:Completed 2625000 out of 12500000 steps (21%)
22:16:31:WU02:FS01:0x21:Completed 2750000 out of 12500000 steps (22%)
22:18:24:WU02:FS01:0x21:Completed 2875000 out of 12500000 steps (23%)
22:20:17:WU02:FS01:0x21:Completed 3000000 out of 12500000 steps (24%)
22:22:11:WU02:FS01:0x21:Completed 3125000 out of 12500000 steps (25%)
22:24:05:WU02:FS01:0x21:Completed 3250000 out of 12500000 steps (26%)
22:25:59:WU02:FS01:0x21:Completed 3375000 out of 12500000 steps (27%)
22:27:53:WU02:FS01:0x21:Completed 3500000 out of 12500000 steps (28%)
22:29:47:WU02:FS01:0x21:Completed 3625000 out of 12500000 steps (29%)
22:31:40:WU02:FS01:0x21:Completed 3750000 out of 12500000 steps (30%)
22:33:33:WU02:FS01:0x21:Completed 3875000 out of 12500000 steps (31%)
22:35:27:WU02:FS01:0x21:Completed 4000000 out of 12500000 steps (32%)
22:36:15:FS00:Unpaused
22:36:15:WU01:FS00:Starting
22:36:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
22:36:16:WU01:FS00:Started FahCore on PID 8608
22:36:16:WU01:FS00:Core PID:8108
22:36:16:WU01:FS00:FahCore 0xa7 started
22:36:16:WU01:FS00:0xa7:*********************** Log Started 2019-12-11T22:36:16Z ***********************
22:36:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:36:16:WU01:FS00:0xa7:       Type: 0xa7
22:36:16:WU01:FS00:0xa7:       Core: Gromacs
22:36:16:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8608 -checkpoint 3 -np 4
22:36:16:WU01:FS00:0xa7:************************************ CBang *************************************
22:36:16:WU01:FS00:0xa7:       Date: Oct 26 2019
22:36:16:WU01:FS00:0xa7:       Time: 01:38:25
22:36:16:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:36:16:WU01:FS00:0xa7:     Branch: master
22:36:16:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:36:16:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:36:16:WU01:FS00:0xa7:   Platform: win32 10
22:36:16:WU01:FS00:0xa7:       Bits: 64
22:36:16:WU01:FS00:0xa7:       Mode: Release
22:36:16:WU01:FS00:0xa7:************************************ System ************************************
22:36:16:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:36:16:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:36:16:WU01:FS00:0xa7:       CPUs: 8
22:36:16:WU01:FS00:0xa7:     Memory: 15.90GiB
22:36:16:WU01:FS00:0xa7:Free Memory: 13.28GiB
22:36:16:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:36:16:WU01:FS00:0xa7: OS Version: 6.2
22:36:16:WU01:FS00:0xa7:Has Battery: false
22:36:16:WU01:FS00:0xa7: On Battery: false
22:36:16:WU01:FS00:0xa7: UTC Offset: -5
22:36:16:WU01:FS00:0xa7:        PID: 8108
22:36:16:WU01:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
22:36:16:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:36:16:WU01:FS00:0xa7:    Version: 0.0.18
22:36:16:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:36:16:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:36:16:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:36:16:WU01:FS00:0xa7:       Time: 01:52:30
22:36:16:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:36:16:WU01:FS00:0xa7:************************************ Build *************************************
22:36:16:WU01:FS00:0xa7:       SIMD: avx_256
22:36:16:WU01:FS00:0xa7:********************************************************************************
22:36:16:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 512, Gen 18)
22:36:16:WU01:FS00:0xa7:Unit: 0x000000180002894b5d77e4e3207977f7
22:36:16:WU01:FS00:0xa7:Digital signatures verified
22:36:16:WU01:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpi state.cpt -cpt 3 -nt 4
22:36:16:WU01:FS00:0xa7:ERROR:Guru Meditation #533b948fb6ab0694.359f25ac17666ad5 (3052920.6105840) '01/01/frame18.trr'
22:36:16:WU01:FS00:0xa7:WARNING:Unexpected exit() call
22:36:16:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
22:36:16:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
22:36:16:WU01:FS00:0xa7:Saving result file frame18.trr
22:36:21:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
22:36:21:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
22:36:21:WARNING:WU01:FS00:Too many errors, failing
22:36:21:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14188 run:6 clone:512 gen:18 core:0xa7 unit:0x000000180002894b5d77e4e3207977f7
22:36:21:WU01:FS00:Connecting to 155.247.166.219:8080
22:36:21:WU00:FS00:Connecting to 65.254.110.245:8080
22:36:22:WU01:FS00:Server responded WORK_ACK (400)
22:36:22:WU01:FS00:Cleaning up
22:36:23:WU00:FS00:Assigned to work server 155.247.166.219
22:36:23:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.166.219
22:36:23:WU00:FS00:Connecting to 155.247.166.219:8080
22:36:24:WU00:FS00:Downloading 1.83MiB
22:36:25:WU00:FS00:Download complete
22:36:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14183 run:0 clone:437 gen:31 core:0xa7 unit:0x000000240002894b5dae0839376d000d
22:36:26:WU00:FS00:Starting
22:36:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 1316 -checkpoint 3 -np 4
22:36:26:WU00:FS00:Started FahCore on PID 4860
22:36:26:WU00:FS00:Core PID:9444
22:36:26:WU00:FS00:FahCore 0xa7 started
22:36:27:WU00:FS00:0xa7:*********************** Log Started 2019-12-11T22:36:26Z ***********************
22:36:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:36:27:WU00:FS00:0xa7:       Type: 0xa7
22:36:27:WU00:FS00:0xa7:       Core: Gromacs
22:36:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4860 -checkpoint 3 -np 4
22:36:27:WU00:FS00:0xa7:************************************ CBang *************************************
22:36:27:WU00:FS00:0xa7:       Date: Oct 26 2019
22:36:27:WU00:FS00:0xa7:       Time: 01:38:25
22:36:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:36:27:WU00:FS00:0xa7:     Branch: master
22:36:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:36:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:36:27:WU00:FS00:0xa7:   Platform: win32 10
22:36:27:WU00:FS00:0xa7:       Bits: 64
22:36:27:WU00:FS00:0xa7:       Mode: Release
22:36:27:WU00:FS00:0xa7:************************************ System ************************************
22:36:27:WU00:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:36:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:36:27:WU00:FS00:0xa7:       CPUs: 8
22:36:27:WU00:FS00:0xa7:     Memory: 15.90GiB
22:36:27:WU00:FS00:0xa7:Free Memory: 13.30GiB
22:36:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:36:27:WU00:FS00:0xa7: OS Version: 6.2
22:36:27:WU00:FS00:0xa7:Has Battery: false
22:36:27:WU00:FS00:0xa7: On Battery: false
22:36:27:WU00:FS00:0xa7: UTC Offset: -5
22:36:27:WU00:FS00:0xa7:        PID: 9444
22:36:27:WU00:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
22:36:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:36:27:WU00:FS00:0xa7:    Version: 0.0.18
22:36:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:36:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:36:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:36:27:WU00:FS00:0xa7:       Time: 01:52:30
22:36:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:36:27:WU00:FS00:0xa7:************************************ Build *************************************
22:36:27:WU00:FS00:0xa7:       SIMD: avx_256
22:36:27:WU00:FS00:0xa7:********************************************************************************
22:36:27:WU00:FS00:0xa7:Project: 14183 (Run 0, Clone 437, Gen 31)
22:36:27:WU00:FS00:0xa7:Unit: 0x000000240002894b5dae0839376d000d
22:36:27:WU00:FS00:0xa7:Reading tar file core.xml
22:36:27:WU00:FS00:0xa7:Reading tar file frame31.tpr
22:36:27:WU00:FS00:0xa7:Digital signatures verified
22:36:27:WU00:FS00:0xa7:Calling: mdrun -s frame31.tpr -o frame31.trr -cpt 3 -nt 4
22:36:27:WU00:FS00:0xa7:Steps: first=77500000 total=2500000
22:36:28:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
22:36:36:Removing old file 'configs/config-20191205-020704.xml'
22:36:36:Saving configuration to config.xml
22:36:36:<config>
22:36:36:  <!-- Folding Core -->
22:36:36:  <checkpoint v='3'/>
22:36:36:
22:36:36:  <!-- Network -->
22:36:36:  <proxy v=':8080'/>
22:36:36:
22:36:36:  <!-- Slot Control -->
22:36:36:  <pause-on-battery v='false'/>
22:36:36:  <power v='full'/>
22:36:36:
22:36:36:  <!-- User Information -->
22:36:36:  <team v='2092'/>
22:36:36:  <user v='forcinghavok'/>
22:36:36:
22:36:36:  <!-- Folding Slots -->
22:36:36:  <slot id='0' type='CPU'>
22:36:36:    <cpus v='4'/>
22:36:36:  </slot>
22:36:36:  <slot id='1' type='GPU'/>
22:36:36:</config>
Re: WU failing
I think that 0xc0000409 is a stack overflow, which pretty much indicates a serious error somewhere without much helpful information. Are the critical components of your system overheating?
