Bad work units, bad luck or bad Me?
iBozz
Hardware configuration: iMac (Retina 5K, 27-inch, 2017), 3.8 GHz Quad-Core Intel Core i5, 64 GB 2400 MHz DDR4, 2TB HD running under macOS Catalina v10.15.7 (19G2021)
Post by iBozz »
I have three iMacs Folding, two of which are running under Snow Leopard, the most recent OS they will support, and do nothing other than Fold. Accordingly, I rarely look at them but have looked today and both are stuck on 0.00% progress and have been for several days.
I have rebooted both of them to see if that "frees" the units.
Snoozy Susie (don't ask!) has a log thus:
*********************** Log Started 2019-11-11T14:59:32Z ***********************
14:59:32:************************* Folding@home Client *************************
14:59:32:    Website: http://folding.stanford.edu/
14:59:32:  Copyright: (c) 2009-2014 Stanford University
14:59:32:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:59:32:       Args:
14:59:32:     Config: /Library/Application Support/FAHClient/config.xml
14:59:32:******************************** Build ********************************
14:59:32:    Version: 7.4.4
14:59:32:       Date: Mar 4 2014
14:59:32:       Time: 20:27:54
14:59:32:    SVN Rev: 4130
14:59:32:     Branch: fah/trunk/client
14:59:32:   Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
14:59:32:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
14:59:32:             -fno-unsafe-math-optimizations -msse3 -arch x86_64
14:59:32:             -mmacosx-version-min=10.6
14:59:32:   Platform: darwin 10.8.0
14:59:32:       Bits: 64
14:59:32:       Mode: Release
14:59:32:******************************* System ********************************
14:59:32:        CPU: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz
14:59:32:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 10
14:59:32:       CPUs: 2
14:59:32:     Memory: 3.00GiB
14:59:32:Free Memory: 2.83GiB
14:59:32:    Threads: POSIX_THREADS
14:59:32: OS Version: 10.6
14:59:32:Has Battery: false
14:59:32: On Battery: false
14:59:32: UTC Offset: 0
14:59:32:        PID: 55
14:59:32:        CWD: /Library/Application Support/FAHClient
14:59:32:         OS: Darwin 10.8.0 i386
14:59:32:    OS Arch: AMD64
14:59:32:       GPUs: 1
14:59:32:      GPU 0: UNSUPPORTED: [Radeon HD 2400 XT]
14:59:32:       CUDA: Not detected
14:59:32:***********************************************************************
14:59:32:<config>
14:59:32:  <!-- Client Control -->
14:59:32:  <client-threads v='6'/>
14:59:32:  <cycle-rate v='4'/>
14:59:32:  <cycles v='-1'/>
14:59:32:  <data-directory v='.'/>
14:59:32:  <disable-sleep-when-active v='true'/>
14:59:32:  <exec-directory v='/usr/bin'/>
14:59:32:  <exit-when-done v='false'/>
14:59:32:  <fold-anon v='false'/>
14:59:32:  <open-web-control v='false'/>
14:59:32:
14:59:32:  <!-- Configuration -->
14:59:32:  <config-rotate v='true'/>
14:59:32:  <config-rotate-dir v='configs'/>
14:59:32:  <config-rotate-max v='16'/>
14:59:32:
14:59:32:  <!-- Debugging -->
14:59:32:  <assignment-servers>
14:59:32:    assign3.stanford.edu:8080 assign4.stanford.edu:80
14:59:32:  </assignment-servers>
14:59:32:  <auth-as v='true'/>
14:59:32:  <capture-directory v='capture'/>
14:59:32:  <capture-on-error v='false'/>
14:59:32:  <capture-packets v='false'/>
14:59:32:  <capture-requests v='false'/>
14:59:32:  <capture-responses v='false'/>
14:59:32:  <capture-sockets v='false'/>
14:59:32:  <core-exec v='FahCore_$type'/>
14:59:32:  <core-wrapper-exec v='FAHCoreWrapper'/>
14:59:32:  <debug-sockets v='false'/>
14:59:32:  <exception-locations v='true'/>
14:59:32:  <gpu-assignment-servers>
14:59:32:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
14:59:32:  </gpu-assignment-servers>
14:59:32:  <stack-traces v='false'/>
14:59:32:
14:59:32:  <!-- Error Handling -->
14:59:32:  <max-slot-errors v='10'/>
14:59:32:  <max-unit-errors v='5'/>
14:59:32:
14:59:32:  <!-- Folding Core -->
14:59:32:  <checkpoint v='30'/>
14:59:32:  <core-dir v='cores'/>
14:59:32:  <core-priority v='idle'/>
14:59:32:  <cpu-affinity v='false'/>
14:59:32:  <cpu-usage v='100'/>
14:59:32:  <gpu-usage v='100'/>
14:59:32:  <no-assembly v='false'/>
14:59:32:
14:59:32:  <!-- Folding Slot Configuration -->
14:59:32:  <cause v='ANY'/>
14:59:32:  <client-subtype v='MACOSX'/>
14:59:32:  <client-type v='normal'/>
14:59:32:  <cpu-species v='X86_PENTIUM_II'/>
14:59:32:  <cpu-type v='AMD64'/>
14:59:32:  <cpus v='-1'/>
14:59:32:  <gpu v='false'/>
14:59:32:  <max-packet-size v='normal'/>
14:59:32:  <os-species v='UNKNOWN'/>
14:59:32:  <os-type v='MACOSX'/>
14:59:32:  <project-key v='0'/>
14:59:32:  <smp v='true'/>
14:59:32:
14:59:32:  <!-- HTTP Server -->
14:59:32:  <allow v='127.0.0.1'/>
14:59:32:  <connection-timeout v='60'/>
14:59:32:  <deny v='0/0'/>
14:59:32:  <http-addresses v='0:7396'/>
14:59:32:  <https-addresses v=''/>
14:59:32:  <max-connect-time v='900'/>
14:59:32:  <max-connections v='800'/>
14:59:32:  <max-request-length v='52428800'/>
14:59:32:  <min-connect-time v='300'/>
14:59:32:  <threads v='2'/>
14:59:32:
14:59:32:  <!-- Logging -->
14:59:32:  <log v='log.txt'/>
14:59:32:  <log-color v='true'/>
14:59:32:  <log-crlf v='false'/>
14:59:32:  <log-date v='false'/>
14:59:32:  <log-date-periodically v='21600'/>
14:59:32:  <log-debug v='true'/>
14:59:32:  <log-domain v='false'/>
14:59:32:  <log-header v='true'/>
14:59:32:  <log-level v='true'/>
14:59:32:  <log-no-info-header v='true'/>
14:59:32:  <log-redirect v='false'/>
14:59:32:  <log-rotate v='true'/>
14:59:32:  <log-rotate-dir v='logs'/>
14:59:32:  <log-rotate-max v='16'/>
14:59:32:  <log-short-level v='false'/>
14:59:32:  <log-simple-domains v='true'/>
14:59:32:  <log-thread-id v='false'/>
14:59:32:  <log-thread-prefix v='true'/>
14:59:32:  <log-time v='true'/>
14:59:32:  <log-to-screen v='true'/>
14:59:32:  <log-truncate v='false'/>
14:59:32:  <verbosity v='5'/>
14:59:32:
14:59:32:  <!-- Network -->
14:59:32:  <proxy v=':8080'/>
14:59:32:  <proxy-enable v='false'/>
14:59:32:  <proxy-pass v=''/>
14:59:32:  <proxy-user v=''/>
14:59:32:
14:59:32:  <!-- Process Control -->
14:59:32:  <child v='false'/>
14:59:32:  <daemon v='false'/>
14:59:32:  <fork v='false'/>
14:59:32:  <pid v='false'/>
14:59:32:  <pid-file v='Folding@home Client.pid'/>
14:59:32:  <respawn v='false'/>
14:59:32:  <service v='false'/>
14:59:32:
14:59:32:  <!-- Remote Command Server -->
14:59:32:  <command-address v='0.0.0.0'/>
14:59:32:  <command-allow-no-pass v='127.0.0.1'/>
14:59:32:  <command-deny-no-pass v='0/0'/>
14:59:32:  <command-enable v='true'/>
14:59:32:  <command-port v='36330'/>
14:59:32:
14:59:32:  <!-- Slot Control -->
14:59:32:  <idle v='false'/>
14:59:32:  <max-shutdown-wait v='60'/>
14:59:32:  <pause-on-battery v='true'/>
14:59:32:  <pause-on-start v='false'/>
14:59:32:  <paused v='false'/>
14:59:32:  <power v='full'/>
14:59:32:
14:59:32:  <!-- User Information -->
14:59:32:  <machine-id v='0'/>
14:59:32:  <passkey v='********************************'/>
14:59:32:  <team v='37761'/>
14:59:32:  <user v='iBozz'/>
14:59:32:
14:59:32:  <!-- Web Server -->
14:59:32:  <web-allow v='127.0.0.1'/>
14:59:32:  <web-deny v='0/0'/>
14:59:32:  <web-enable v='true'/>
14:59:32:
14:59:32:  <!-- Web Server Sessions -->
14:59:32:  <session-cookie v='sid'/>
14:59:32:  <session-lifetime v='86400'/>
14:59:32:  <session-timeout v='3600'/>
14:59:32:
14:59:32:  <!-- Work Unit Control -->
14:59:32:  <dump-after-deadline v='true'/>
14:59:32:  <max-queue v='16'/>
14:59:32:  <max-units v='0'/>
14:59:32:  <next-unit-percentage v='99'/>
14:59:32:  <stall-detection-enabled v='false'/>
14:59:32:  <stall-percent v='5'/>
14:59:32:  <stall-timeout v='1800'/>
14:59:32:
14:59:32:  <!-- Folding Slots -->
14:59:32:  <slot id='0' type='CPU'/>
14:59:32:</config>
14:59:32:Trying to access database...
14:59:32:Started thread 1 on PID 55
14:59:36:Successfully acquired database lock
14:59:36:Enabled folding slot 00: READY cpu:2
14:59:36:Started thread 4 on PID 55
14:59:36:Started thread 5 on PID 55
14:59:36:Started thread 6 on PID 55
14:59:36:Started thread 7 on PID 55
14:59:36:Started thread 8 on PID 55
14:59:36:Started thread 9 on PID 55
14:59:36:WU01:FS00:Starting
14:59:36:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
14:59:36:WU01:FS00:Started FahCore on PID 130
14:59:36:Started thread 10 on PID 55
14:59:37:WU01:FS00:Core PID:135
14:59:37:WU01:FS00:FahCore 0xa7 started
14:59:38:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:59:38:WU01:FS00:Starting
14:59:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
14:59:38:WU01:FS00:Started FahCore on PID 140
14:59:38:Started thread 11 on PID 55
14:59:38:WU01:FS00:Core PID:141
14:59:38:WU01:FS00:FahCore 0xa7 started
14:59:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:59:46:Started thread 12 on PID 55
15:00:38:WU01:FS00:Starting
15:00:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
15:00:38:WU01:FS00:Started FahCore on PID 467
15:00:38:Started thread 13 on PID 55
15:00:38:WU01:FS00:Core PID:470
15:00:38:WU01:FS00:FahCore 0xa7 started
15:00:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:01:38:WU01:FS00:Starting
15:01:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
15:01:38:WU01:FS00:Started FahCore on PID 473
15:01:38:Started thread 14 on PID 55
15:01:38:WU01:FS00:Core PID:476
15:01:38:WU01:FS00:FahCore 0xa7 started
15:01:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:02:38:WU01:FS00:Starting
15:02:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
15:02:38:WU01:FS00:Started FahCore on PID 478
15:02:38:Started thread 15 on PID 55
15:02:38:WU01:FS00:Core PID:481
15:02:38:WU01:FS00:FahCore 0xa7 started
15:02:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:03:38:WU01:FS00:Starting
15:03:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
15:03:38:WU01:FS00:Started FahCore on PID 484
15:03:38:Started thread 16 on PID 55
15:03:38:WU01:FS00:Core PID:487
15:03:38:WU01:FS00:FahCore 0xa7 started
15:03:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:04:38:WU01:FS00:Starting
15:04:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 2
15:04:38:WU01:FS00:Started FahCore on PID 491
15:04:38:Started thread 17 on PID 55
15:04:38:WU01:FS00:Core PID:494
15:04:38:WU01:FS00:FahCore 0xa7 started
15:04:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:05:38:WU01:FS00:Starting
15:05:38:WARNING:WU01:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
15:05:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:05:38:WU01:FS00:Started FahCore on PID 510
15:05:38:Started thread 18 on PID 55
15:05:38:WU01:FS00:Core PID:513
15:05:38:WU01:FS00:FahCore 0xa7 started
15:05:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:05:42:Saving configuration to config.xml
15:05:42:<config>
15:05:42:  <!-- Folding Core -->
15:05:42:  <checkpoint v='30'/>
15:05:42:
15:05:42:  <!-- Logging -->
15:05:42:  <verbosity v='5'/>
15:05:42:
15:05:42:  <!-- Network -->
15:05:42:  <proxy v=':8080'/>
15:05:42:
15:05:42:  <!-- User Information -->
15:05:42:  <passkey v='********************************'/>
15:05:42:  <team v='37761'/>
15:05:42:  <user v='iBozz'/>
15:05:42:
15:05:42:  <!-- Folding Slots -->
15:05:42:  <slot id='0' type='CPU'/>
15:05:42:</config>
15:06:38:WU01:FS00:Starting
15:06:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:06:38:WU01:FS00:Started FahCore on PID 521
15:06:38:Started thread 19 on PID 55
15:06:38:WU01:FS00:Core PID:524
15:06:38:WU01:FS00:FahCore 0xa7 started
15:06:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:07:11:Caught signal SIGPIPE(13) on PID 55
15:07:38:WU01:FS00:Starting
15:07:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:07:38:WU01:FS00:Started FahCore on PID 530
15:07:38:Started thread 20 on PID 55
15:07:38:WU01:FS00:Core PID:533
15:07:38:WU01:FS00:FahCore 0xa7 started
15:07:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:08:38:WU01:FS00:Starting
15:08:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:08:38:WU01:FS00:Started FahCore on PID 543
15:08:38:Started thread 21 on PID 55
15:08:38:WU01:FS00:Core PID:546
15:08:38:WU01:FS00:FahCore 0xa7 started
15:08:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:09:38:WU01:FS00:Starting
15:09:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:09:38:WU01:FS00:Started FahCore on PID 708
15:09:38:Started thread 22 on PID 55
15:09:38:WU01:FS00:Core PID:711
15:09:38:WU01:FS00:FahCore 0xa7 started
15:09:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:10:38:WU01:FS00:Starting
15:10:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:10:38:WU01:FS00:Started FahCore on PID 714
15:10:38:Started thread 23 on PID 55
15:10:38:WU01:FS00:Core PID:717
15:10:38:WU01:FS00:FahCore 0xa7 started
15:10:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:11:38:WU01:FS00:Starting
15:11:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:11:38:WU01:FS00:Started FahCore on PID 721
15:11:38:Started thread 24 on PID 55
15:11:39:WU01:FS00:Core PID:724
15:11:39:WU01:FS00:FahCore 0xa7 started
15:11:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:12:38:WU01:FS00:Starting
15:12:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:12:38:WU01:FS00:Started FahCore on PID 730
15:12:38:Started thread 25 on PID 55
15:12:39:WU01:FS00:Core PID:733
15:12:39:WU01:FS00:FahCore 0xa7 started
15:12:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:13:38:WU01:FS00:Starting
15:13:38:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:13:38:WU01:FS00:Started FahCore on PID 736
15:13:38:Started thread 26 on PID 55
15:13:39:WU01:FS00:Core PID:739
15:13:39:WU01:FS00:FahCore 0xa7 started
15:13:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:14:38:WU01:FS00:Starting
15:14:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:14:39:WU01:FS00:Started FahCore on PID 742
15:14:39:Started thread 27 on PID 55
15:14:39:WU01:FS00:Core PID:745
15:14:39:WU01:FS00:FahCore 0xa7 started
15:14:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:15:39:WU01:FS00:Starting
15:15:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:15:39:WU01:FS00:Started FahCore on PID 750
15:15:39:Started thread 28 on PID 55
15:15:39:WU01:FS00:Core PID:753
15:15:39:WU01:FS00:FahCore 0xa7 started
15:15:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:16:39:WU01:FS00:Starting
15:16:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:16:39:WU01:FS00:Started FahCore on PID 756
15:16:39:Started thread 29 on PID 55
15:16:39:WU01:FS00:Core PID:759
15:16:39:WU01:FS00:FahCore 0xa7 started
15:16:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:17:39:WU01:FS00:Starting
15:17:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:17:39:WU01:FS00:Started FahCore on PID 762
15:17:39:Started thread 30 on PID 55
15:17:39:WU01:FS00:Core PID:765
15:17:39:WU01:FS00:FahCore 0xa7 started
15:17:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:18:39:WU01:FS00:Starting
15:18:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:18:39:WU01:FS00:Started FahCore on PID 771
15:18:39:Started thread 31 on PID 55
15:18:39:WU01:FS00:Core PID:774
15:18:39:WU01:FS00:FahCore 0xa7 started
15:18:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:19:34:Started thread 32 on PID 55
15:19:39:WU01:FS00:Starting
15:19:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 55 -checkpoint 30 -np 1
15:19:39:WU01:FS00:Started FahCore on PID 785
15:19:39:Started thread 33 on PID 55
15:19:39:WU01:FS00:Core PID:788
15:19:39:WU01:FS00:FahCore 0xa7 started
15:19:39:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Her Ladyship has a log thus (I said don't ask :) )
*********************** Log Started 2019-11-11T15:22:49Z ***********************
15:22:49:************************* Folding@home Client *************************
15:22:49:    Website: http://folding.stanford.edu/
15:22:49:  Copyright: (c) 2009-2014 Stanford University
15:22:49:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:22:49:       Args:
15:22:49:     Config: /Library/Application Support/FAHClient/config.xml
15:22:49:******************************** Build ********************************
15:22:49:    Version: 7.4.4
15:22:49:       Date: Mar 4 2014
15:22:49:       Time: 20:27:54
15:22:49:    SVN Rev: 4130
15:22:49:     Branch: fah/trunk/client
15:22:49:   Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
15:22:49:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
15:22:49:             -fno-unsafe-math-optimizations -msse3 -arch x86_64
15:22:49:             -mmacosx-version-min=10.6
15:22:49:   Platform: darwin 10.8.0
15:22:49:       Bits: 64
15:22:49:       Mode: Release
15:22:49:******************************* System ********************************
15:22:49:        CPU: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz
15:22:49:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 10
15:22:49:       CPUs: 2
15:22:49:     Memory: 1.00GiB
15:22:49:Free Memory: 875.57MiB
15:22:49:    Threads: POSIX_THREADS
15:22:49: OS Version: 10.6
15:22:49:Has Battery: false
15:22:49: On Battery: false
15:22:49: UTC Offset: 0
15:22:49:        PID: 46
15:22:49:        CWD: /Library/Application Support/FAHClient
15:22:49:         OS: Darwin 10.8.0 i386
15:22:49:    OS Arch: AMD64
15:22:49:       GPUs: 1
15:22:49:      GPU 0: UNSUPPORTED: [Radeon HD 2400 XT]
15:22:49:       CUDA: Not detected
15:22:49:***********************************************************************
15:22:49:<config>
15:22:49:  <!-- Network -->
15:22:49:  <proxy v=':8080'/>
15:22:49:
15:22:49:  <!-- Slot Control -->
15:22:49:  <power v='full'/>
15:22:49:
15:22:49:  <!-- User Information -->
15:22:49:  <passkey v='********************************'/>
15:22:49:  <team v='37761'/>
15:22:49:  <user v='iBozz'/>
15:22:49:
15:22:49:  <!-- Folding Slots -->
15:22:49:  <slot id='0' type='CPU'/>
15:22:49:</config>
15:22:49:Trying to access database...
15:22:53:Successfully acquired database lock
15:22:53:Enabled folding slot 00: READY cpu:2
15:22:54:WU01:FS00:Starting
15:22:54:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:22:54:WU01:FS00:Started FahCore on PID 154
15:23:01:WU01:FS00:Core PID:239
15:23:01:WU01:FS00:FahCore 0xa7 started
15:23:03:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:23:03:WU01:FS00:Starting
15:23:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:23:03:WU01:FS00:Started FahCore on PID 252
15:23:03:WU01:FS00:Core PID:253
15:23:03:WU01:FS00:FahCore 0xa7 started
15:23:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:24:03:WU01:FS00:Starting
15:24:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:24:03:WU01:FS00:Started FahCore on PID 773
15:24:03:WU01:FS00:Core PID:776
15:24:03:WU01:FS00:FahCore 0xa7 started
15:24:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:25:03:WU01:FS00:Starting
15:25:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:25:03:WU01:FS00:Started FahCore on PID 1045
15:25:04:WU01:FS00:Core PID:1048
15:25:04:WU01:FS00:FahCore 0xa7 started
15:25:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:26:03:WU01:FS00:Starting
15:26:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:26:03:WU01:FS00:Started FahCore on PID 1292
15:26:04:WU01:FS00:Core PID:1295
15:26:04:WU01:FS00:FahCore 0xa7 started
15:26:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:27:03:WU01:FS00:Starting
15:27:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:27:03:WU01:FS00:Started FahCore on PID 1540
15:27:03:WU01:FS00:Core PID:1543
15:27:03:WU01:FS00:FahCore 0xa7 started
15:27:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:28:03:WU01:FS00:Starting
15:28:03:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:28:03:WU01:FS00:Started FahCore on PID 1809
15:28:04:WU01:FS00:Core PID:1812
15:28:04:WU01:FS00:FahCore 0xa7 started
15:28:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:29:04:WU01:FS00:Starting
15:29:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:29:04:WU01:FS00:Started FahCore on PID 1908
15:29:04:WU01:FS00:Core PID:1911
15:29:04:WU01:FS00:FahCore 0xa7 started
15:29:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:30:04:WU01:FS00:Starting
15:30:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:30:04:WU01:FS00:Started FahCore on PID 1937
15:30:04:WU01:FS00:Core PID:1940
15:30:04:WU01:FS00:FahCore 0xa7 started
15:30:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:31:04:WU01:FS00:Starting
15:31:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:31:04:WU01:FS00:Started FahCore on PID 1974
15:31:04:WU01:FS00:Core PID:1977
15:31:04:WU01:FS00:FahCore 0xa7 started
15:31:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:32:04:WU01:FS00:Starting
15:32:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:32:04:WU01:FS00:Started FahCore on PID 2014
15:32:04:WU01:FS00:Core PID:2017
15:32:04:WU01:FS00:FahCore 0xa7 started
15:32:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:33:04:WU01:FS00:Starting
15:33:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:33:04:WU01:FS00:Started FahCore on PID 2112
15:33:04:WU01:FS00:Core PID:2115
15:33:04:WU01:FS00:FahCore 0xa7 started
15:33:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:34:04:WU01:FS00:Starting
15:34:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:34:04:WU01:FS00:Started FahCore on PID 2176
15:34:04:WU01:FS00:Core PID:2179
15:34:04:WU01:FS00:FahCore 0xa7 started
15:34:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:35:04:WU01:FS00:Starting
15:35:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:35:04:WU01:FS00:Started FahCore on PID 2183
15:35:04:WU01:FS00:Core PID:2186
15:35:04:WU01:FS00:FahCore 0xa7 started
15:35:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:36:04:WU01:FS00:Starting
15:36:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:36:04:WU01:FS00:Started FahCore on PID 2189
15:36:04:WU01:FS00:Core PID:2192
15:36:04:WU01:FS00:FahCore 0xa7 started
15:36:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:37:04:WU01:FS00:Starting
15:37:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:37:04:WU01:FS00:Started FahCore on PID 2195
15:37:04:WU01:FS00:Core PID:2198
15:37:04:WU01:FS00:FahCore 0xa7 started
15:37:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:38:04:WU01:FS00:Starting
15:38:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:38:04:WU01:FS00:Started FahCore on PID 2203
15:38:05:WU01:FS00:Core PID:2206
15:38:05:WU01:FS00:FahCore 0xa7 started
15:38:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:39:04:WU01:FS00:Starting
15:39:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:39:04:WU01:FS00:Started FahCore on PID 2209
15:39:05:WU01:FS00:Core PID:2212
15:39:05:WU01:FS00:FahCore 0xa7 started
15:39:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:40:04:WU01:FS00:Starting
15:40:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:40:04:WU01:FS00:Started FahCore on PID 2215
15:40:05:WU01:FS00:Core PID:2218
15:40:05:WU01:FS00:FahCore 0xa7 started
15:40:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:41:04:WU01:FS00:Starting
15:41:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:41:04:WU01:FS00:Started FahCore on PID 2223
15:41:04:WU01:FS00:Core PID:2226
15:41:04:WU01:FS00:FahCore 0xa7 started
15:41:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:42:04:WU01:FS00:Starting
15:42:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:42:04:WU01:FS00:Started FahCore on PID 2228
15:42:04:WU01:FS00:Core PID:2231
15:42:04:WU01:FS00:FahCore 0xa7 started
15:42:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:43:04:WU01:FS00:Starting
15:43:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:43:04:WU01:FS00:Started FahCore on PID 2234
15:43:04:WU01:FS00:Core PID:2237
15:43:04:WU01:FS00:FahCore 0xa7 started
15:43:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:44:04:WU01:FS00:Starting
15:44:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:44:04:WU01:FS00:Started FahCore on PID 2239
15:44:04:WU01:FS00:Core PID:2242
15:44:04:WU01:FS00:FahCore 0xa7 started
15:44:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:45:04:WU01:FS00:Starting
15:45:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:45:04:WU01:FS00:Started FahCore on PID 2245
15:45:04:WU01:FS00:Core PID:2248
15:45:04:WU01:FS00:FahCore 0xa7 started
15:45:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:46:04:WU01:FS00:Starting
15:46:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 704 -lifeline 46 -checkpoint 15 -np 2
15:46:04:WU01:FS00:Started FahCore on PID 2263
15:46:04:WU01:FS00:Core PID:2266
15:46:04:WU01:FS00:FahCore 0xa7 started
15:46:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
I'm not a techie geek so apart from the logs telling me that things aren't working, is it thee or me?
And what can I do about it to get both machines back Folding again? I'm hoping that the problem lies with the specific units and I do hope that they can carry on Folding - it's all that they do and it would be a shame if they had to retire.
Thanks in advance.
iMac (Retina 5K, 27-inch, 2017), 3.8 GHz Quad-Core Intel Core i5, 64 GB 2400 MHz DDR4, 2TB HD, macOS Catalina v10.15.7
Re: Bad work units, bad luck or bad Me?
A new version of the A7 folding core was recently put out to fix a serious problem with it on Windows. There was limited testing on OS X, I personally just tested on Sierra. The first test core was missing a library, a new one was put out with it that works on my systems. So it could be a problem with the core.
First, pause folding. Then go to the Library folder on the Mac's drive. Open the Application Support folder, and then open the FAHClient folder that is there. Drag the cores folder to the Trash, you will be prompted for an Admin password to complete moving the folder.
Resume folding. If the WU still crashes after downloading a new folding core, pause it again.
In this case the output of a software crash log will be useful. Open the Console app that is in the Utilites folder of Applications. On the left hand side go to /Library/Logs, click on the arrow to the left to expand the list. Then click on Diagnostic Reports folder there, a long list will show up in the Console window. Scroll down until you see files named beginning with FAHCore_a7. The rest of the name is a timestamp. Double click on the most recent one, and could you copy the output and post it here.
iBozz
Post by iBozz »
I did have a unit, some while back, which also stuck at 0.00%, but a simple reboot seemed to fix that.
Right, I followed step 1 on both machines but to no avail.
Here are the Crash Logs (I hope that they are what you want, from my position of total ignorance I expected a bit more information!).
Snoozy Susie:
Process:         FahCore_a7 [2739]
Path:            /Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7
Identifier:      FahCore_a7
Version:         ??? (???)
Code Type:       X86-64 (Native)
Parent Process:  FAHCoreWrapper [2736]
Date/Time:       2019-11-11 19:13:57.835 +0000
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  0
Dyld Error Message:
  Library not loaded: /usr/lib/libc++.1.dylib
  Referenced from: /Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7
  Reason: image not found
Binary Images:
    0x7fff5fc00000 -     0x7fff5fc3be0f  dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
Her Ladyship:
Process:         FahCore_a7 [3837]
Version:         ??? (???)
Parent Process:  FAHCoreWrapper [3834]
Date/Time:       2019-11-11 19:30:07.418 +0000
Report Version:  6
Crashed Thread:  0
Dyld Error Message:
Binary Images:
iBozz
Post by iBozz »
I should add that I have done nothing to either machine, either for F@H or any other application, so this problem is, I surmise, self-inflicted by or within F@H - and that's an observation, not a criticism!
Yes, it looks like a problem with the new core that was distributed. A different library is being reported as missing from the one I saw when testing on Sierra.
I will pass this info on to the developer.
iBozz
Post by iBozz »
Many thanks. if any other information is needed then let me know and I'll try to supply it.
If you would be good enough to report back when fixed i would be most grateful.
Thanks again.
TomJohnson
Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD.
Post by TomJohnson »
Put me down for a Ditto with iBozz - running OS V10.6.8 also on my Mac Pro 5,1.
My log file - PS - I followed Joe_H's procedures posted below.
PPS- My other 7 Macs running later OS Versions are running the WUs properly and do not do not have this same problem.
*********************** Log Started 2019-11-19T22:52:17Z ***********************
22:52:17:************************* Folding@home Client *************************
22:52:17:    Website: https://foldingathome.org/
22:52:17:  Copyright: (c) 2009-2018 foldingathome.org
22:52:17:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:52:17:       Args:
22:52:17:     Config: /Library/Application Support/FAHClient/config.xml
22:52:17:******************************** Build ********************************
22:52:17:    Version: 7.5.1
22:52:17:       Date: May 11 2018
22:52:17:       Time: 12:57:01
22:52:17: Repository: Git
22:52:17:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:52:17:     Branch: master
22:52:17:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
22:52:17:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
22:52:17:             -Wno-unused-local-typedefs
22:52:17:   Platform: darwin 15.6.0
22:52:17:       Bits: 64
22:52:17:       Mode: Release
22:52:17:******************************* System ********************************
22:52:17:        CPU: Intel(R) Xeon(R) CPU X5675 @ 3.07GHz
22:52:17:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
22:52:17:       CPUs: 24
22:52:17:     Memory: 52.00GiB
22:52:17:Free Memory: 49.94GiB
22:52:17:    Threads: POSIX_THREADS
22:52:17: OS Version: 10.6
22:52:17:Has Battery: false
22:52:17: On Battery: false
22:52:17: UTC Offset: -8
22:52:17:        PID: 80
22:52:17:        CWD: /Library/Application Support/FAHClient
22:52:17:         OS: Darwin 10.8.0 x86_64
22:52:17:    OS Arch: AMD64
22:52:17:       GPUs: 1
22:52:17:      GPU 0: Bus:5 Slot:0 Func:0 AMD:4 Juniper [Radeon HD 5700 Series]
22:52:17:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
22:52:17:             dlopen(libcuda.dylib, 1): image not found
22:52:17:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
22:52:17:             dlopen(libOpenCL.dylib, 1): image not found
22:52:17:***********************************************************************
22:52:17:<config>
22:52:17:  <!-- Folding Core -->
22:52:17:  <checkpoint v='30'/>
22:52:17:
22:52:17:  <!-- Folding Slot Configuration -->
22:52:17:  <client-type v='advanced'/>
22:52:17:
22:52:17:  <!-- Network -->
22:52:17:  <proxy v=':8080'/>
22:52:17:
22:52:17:  <!-- Process Control -->
22:52:17:  <child v='true'/>
22:52:17:  <respawn v='true'/>
22:52:17:
22:52:17:  <!-- Slot Control -->
22:52:17:  <pause-on-battery v='false'/>
22:52:17:  <power v='full'/>
22:52:17:
22:52:17:  <!-- User Information -->
22:52:17:  <passkey v='********************************'/>
22:52:17:  <team v='1971'/>
22:52:17:  <user v='Tom_Johnson'/>
22:52:17:
22:52:17:  <!-- Folding Slots -->
22:52:17:  <slot id='0' type='CPU'/>
22:52:17:</config>
22:52:17:Trying to access database...
22:52:17:Successfully acquired database lock
22:52:17:Enabled folding slot 00: READY cpu:24
22:52:17:WARNING:WU00:Missing data files, dumping
22:52:18:ERROR:Failed to register for display power changes
22:52:18:WU00:FS00:Cleaning up
22:52:18:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: nodename nor servname provided, or not known
22:52:18:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: nodename nor servname provided, or not known
22:52:18:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
22:52:18:ERROR:WU00:FS00:Exception: Could not get an assignment
22:53:18:WU00:FS00:Connecting to 65.254.110.245:8080
22:53:19:WU00:FS00:Assigned to work server 155.247.166.219
22:53:19:WU00:FS00:Requesting new work unit for slot 00: READY cpu:24 from 155.247.166.219
22:53:19:WU00:FS00:Connecting to 155.247.166.219:8080
22:53:20:WU00:FS00:Downloading 1.22MiB
22:53:26:WU00:FS00:Download 25.60%
22:53:30:WU00:FS00:Download complete
22:53:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14091 run:1 clone:27 gen:17 core:0xa7 unit:0x000000160002894b5dacdad58b190598
22:53:33:WU00:FS00:Starting
22:53:33:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:53:33:WU00:FS00:Started FahCore on PID 347
22:53:52:WU00:FS00:Core PID:356
22:53:52:WU00:FS00:FahCore 0xa7 started
22:53:55:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:53:58:WU00:FS00:Starting
22:53:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:53:58:WU00:FS00:Started FahCore on PID 368
22:53:58:WU00:FS00:Core PID:369
22:53:58:WU00:FS00:FahCore 0xa7 started
22:54:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:54:58:WU00:FS00:Starting
22:54:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:54:58:WU00:FS00:Started FahCore on PID 508
22:54:58:WU00:FS00:Core PID:511
22:54:58:WU00:FS00:FahCore 0xa7 started
22:54:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:55:58:WU00:FS00:Starting
22:55:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:55:58:WU00:FS00:Started FahCore on PID 526
22:55:58:WU00:FS00:Core PID:529
22:55:58:WU00:FS00:FahCore 0xa7 started
22:55:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:56:58:WU00:FS00:Starting
22:56:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:56:58:WU00:FS00:Started FahCore on PID 544
22:56:58:WU00:FS00:Core PID:547
22:56:58:WU00:FS00:FahCore 0xa7 started
22:56:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:57:58:WU00:FS00:Starting
22:57:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:57:58:WU00:FS00:Started FahCore on PID 580
22:57:58:WU00:FS00:Core PID:583
22:57:58:WU00:FS00:FahCore 0xa7 started
22:57:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:58:58:WU00:FS00:Starting
22:58:58:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 80 -checkpoint 30 -np 24
22:58:58:WU00:FS00:Started FahCore on PID 603
22:58:58:WU00:FS00:Core PID:606
22:58:58:WU00:FS00:FahCore 0xa7 started
22:58:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
The software developer said he would look into this, not sure how long it will take.
From my own testing the revised A7 core works on El Capitan and Sierra, and I assume higher versions of the OS. That leaves the question as to which s the lowest version of the OS that still will work?
TomJohnson
Here is a list of the CPUs and OS configuration for us three users showing that 10.6.8 does not work and 10.8.5 and above does work for Folding -
IMAC PRO 1,1 / 10.14.6 / TJ F@H WORKS ON THESE OS /CPU COMBINATIONS
IMAC 18,2 / 10.14.6 / TJ
MBP 13,3 / 10.13.6 / TJ
MBA 5,2 / 10.13.6 / TJ & IBOZZ ON 2009 IMAC ?
MP ? / 10.12.6 / JH
IMAC ? / 10.11.6 / JH
MBP ? / 10.11.6 / JH
MBP 8,3 / 10.10.5 / TJ
MM 7,1 / 10.10.5 / TJ
IMAC 10.1 / 10.9.5 / TJ
MP 3,1 / 10.8.5 / TJ______________________
MP 5,1 / 10.6.8 / TJ F@H (64 bit) DOES NOT WORK
If pertinent please fill in missing Computer ID Numbers.
iBozz
Post by iBozz »
Joe_H wrote:The software developer said he would look into this, not sure how long it will take.
I appreciate that support for older systems cannot go on for ever, but it would be a shame if Snow Leopard were no longer supported - a fair number of my own Mac User Group still run it and I would assume that the proportion is fairly representative.
If support has indeed gone then my own two dedicated F@H iMacs will be consigned to the scrapheap and I'll be down to Folding on just one! :(
TomJohnson
Has any 10.6.8 User had success uninstalling F@H 7.5.1_x86_64 then reinstalling 7.4.16_x86_64 and getting it to work properly ?
I tried but received a log entry stating "23:19:30:Trying to access database... [91m23:19:30:ERROR:Exception: Database version is 16 but this program only supports 14[0m"
I then uninstalled 7.4.16_86_64 then reinstalled 7.4.4_x86_64 and then received log entry stating "23:55:53:Trying to access database... [91m23:55:53:ERROR:Exception: Database version is 16 but this program only supports 13[0m"
F@H still not working :(
The problem is not in the client, FAHClient, but in the folding core that the client downloads to process the WU. It will have a name of FAHCore_A7.
As for the error message, the older client uses a slightly older database, the installer for the current version converts an older one at install time. The only way to go back is a complete uninstall including removing data files. But there is no point in doing that, the problem isn't with the client install.
TomJohnson
Joe_H , Thanks for the clarification. I did Trash all of the old configs, work/client.db and core & added myself for a permitted user for the app but it is still a no go after restarting & shutting down the Mac Pro 5,1. :(
All of the data files are stored in a folder in the system Library folder. The path is:
There are some parts of the client that are not installed there or in Applications, but the Uninstaller provided should remove those. The Uninstaller currently does not remove files in /Library/Application Support/FAHClient.
TomJohnson
I use Easy Find to track down all of the app's spider connections so that I can Trash any remnants left over from an uninstall. :)
