Yesterday I tried to install fahclient on Ubuntu 16.04. It failed with the following error:
Setting up fahclient:amd64 (7.5.1) ...
update-rc.d: error: no runlevel symlinks to modify, aborting!
dpkg: error processing package fahclient:amd64 (--install):
subprocess installed post-installation script returned error exit status 1The problem was AFAIK caused by the following snippet in the postinst script:
if [ -x insserv ]; then
insserv -r FAHClient
else
update-rc.d FAHClient disable
fi
update-rc.d FAHClient disableOne solution would be to modify the line so:
update-rc.d FAHClient disable || true
