*********************** Log Started 2019-11-10T10:42:09Z ***********************
10:42:09:************************* Folding@home Client *************************
10:42:09: Website: https://foldingathome.org/
10:42:09: Copyright: (c) 2009-2018 foldingathome.org
10:42:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:42:09: Args: --open-web-control
10:42:09: Config: <none>
10:42:09:******************************** Build ********************************
10:42:09: Version: 7.5.1
10:42:09: Date: May 11 2018
10:42:09: Time: 13:06:32
10:42:09: Repository: Git
10:42:09: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:42:09: Branch: master
10:42:09: Compiler: Visual C++ 2008
10:42:09: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:42:09: Platform: win32 10
10:42:09: Bits: 32
10:42:09: Mode: Release
10:42:09:******************************* System ********************************
10:42:09: CPU: AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G
10:42:09: CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
10:42:09: CPUs: 4
10:42:09: Memory: 14.92GiB
10:42:09: Free Memory: 9.98GiB
10:42:09: Threads: WINDOWS_THREADS
10:42:09: OS Version: 6.2
10:42:09: Has Battery: false
10:42:09: On Battery: false
10:42:09: UTC Offset: 0
10:42:09: PID: 9908
10:42:09: CWD: C:\Users\pawci\AppData\Roaming\FAHClient
10:42:09: OS: Windows 10 Home
10:42:09: OS Arch: AMD64
10:42:09: GPUs: 1
10:42:09: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 xxxx [Radeon R7]
10:42:09: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Nie
10:42:09: można odnaleźć określonego modułu.
10:42:09:
10:42:09:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:2841.5
10:42:09: Win32 Service: false
10:42:09:***********************************************************************
10:42:10:<config>
10:42:10: <!-- Folding Slots -->
10:42:10:</config>
10:42:10:Connecting to assign1.foldingathome.org:8080
10:42:10:Updated GPUs.txt
10:42:10:Read GPUs.txt
10:42:10:Trying to access database...
10:42:10:Successfully acquired database lock
10:42:10:Enabled folding slot 00: PAUSED cpu:2 (not configured)
10:42:10:Enabled folding slot 01: PAUSED gpu:0:Kaveri [Radeon R7] (not configured)
10:42:22:7:127.0.0.1:New Web connection
10:42:24:20:127.0.0.1:New Web connection
10:43:11:Saving configuration to config.xml
10:43:11:<config>
10:43:11: <!-- Folding Slots -->
10:43:11: <slot id='0' type='CPU'/>
10:43:11: <slot id='1' type='GPU'/>
10:43:11:</config>
10:43:11:Set client configured
10:43:11:WU00:FS00:Connecting to 65.254.110.245:8080
10:43:11:WU01:FS01:Connecting to 65.254.110.245:8080
10:43:12:WU00:FS00:Connecting to 65.254.110.245:8080
10:43:12:WU01:FS01:Connecting to 65.254.110.245:8080
10:43:12:WU00:FS00:Assigned to work server 155.247.166.220
10:43:12:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.220
10:43:12:WU00:FS00:Connecting to 155.247.166.220:8080
10:43:12:WU01:FS01:Assigned to work server 155.247.166.220
10:43:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Kaveri [Radeon R7] from 155.247.166.220
10:43:12:WU01:FS01:Connecting to 155.247.166.220:8080
10:43:13:WU00:FS00:Downloading 1.84MiB
10:43:13:WU01:FS01:Downloading 15.87MiB
10:43:15:WU00:FS00:Download complete
10:43:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13794 run:0 clone:378 gen:17 core:0xa7 unit:0x000000130002894c5dae0b85e5e3b2a0
10:43:15:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
10:43:15:WU00:FS00:Connecting to cores.foldingathome.org:80
10:43:16:WU00:FS00:FahCore a7: Downloading 6.71MiB
10:43:19:WU01:FS01:Download 24.82%
10:43:20:WU00:FS00:FahCore a7: Download complete
10:43:20:WU00:FS00:Valid core signature
10:43:20:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
10:43:20:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
10:43:20:WU00:FS00:Starting
10:43:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:43:20:WU00:FS00:Started FahCore on PID 1480
10:43:21:WU00:FS00:Core PID:12308
10:43:21:WU00:FS00:FahCore 0xa7 started
10:43:21:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
10:43:21:WARNING:WU00:FS00:Fatal error, dumping
10:43:21:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:13794 run:0 clone:378 gen:17 core:0xa7 unit:0x000000130002894c5dae0b85e5e3b2a0
10:43:21:WU00:FS00:Connecting to 155.247.166.220:8080
10:43:22:WU02:FS00:Connecting to 65.254.110.245:8080
10:43:22:WU00:FS00:Server responded WORK_ACK (400)
10:43:22:WU00:FS00:Cleaning up
10:43:22:WU02:FS00:Assigned to work server 128.252.203.9
10:43:22:WU02:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
10:43:22:WU02:FS00:Connecting to 128.252.203.9:8080
10:43:23:WU02:FS00:Downloading 8.14MiB
10:43:25:WU01:FS01:Download 79.57%
10:43:27:WU01:FS01:Download complete
10:43:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:1 clone:348 gen:97 core:0x21 unit:0x0000008f0002894c5d3b5451a98a4190
10:43:27:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah
10:43:27:WU01:FS01:Connecting to cores.foldingathome.org:80
10:43:27:WU01:FS01:FahCore 21: Downloading 3.48MiB
10:43:29:WU02:FS00:Download 92.93%
10:43:29:WU02:FS00:Download complete
10:43:29:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13827 run:621 clone:1 gen:79 core:0xa7 unit:0x0000005d80fccb095c9f83b5a0e98d3e
10:43:29:WU02:FS00:Starting
10:43:29:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:43:29:WU02:FS00:Started FahCore on PID 11748
10:43:29:WU02:FS00:Core PID:10884
10:43:29:WU02:FS00:FahCore 0xa7 started
10:43:30:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:43:30:WU02:FS00:Starting
10:43:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:43:30:WU02:FS00:Started FahCore on PID 1836
10:43:30:WU02:FS00:Core PID:8544
10:43:30:WU02:FS00:FahCore 0xa7 started
10:43:31:WU01:FS01:FahCore 21: Download complete
10:43:31:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:43:31:WU01:FS01:Valid core signature
10:43:31:WU01:FS01:Unpacked 11.81MiB to cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe
10:43:31:WU01:FS01:Starting
10:43:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:43:31:WU01:FS01:Started FahCore on PID 13608
10:43:31:WU01:FS01:Core PID:7512
10:43:31:WU01:FS01:FahCore 0x21 started
10:43:32:WU01:FS01:0x21:*********************** Log Started 2019-11-10T10:43:31Z ***********************
10:43:32:WU01:FS01:0x21:Project: 14180 (Run 1, Clone 348, Gen 97)
10:43:32:WU01:FS01:0x21:Unit: 0x0000008f0002894c5d3b5451a98a4190
10:43:32:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
10:43:32:WU01:FS01:0x21:Machine: 1
10:43:32:WU01:FS01:0x21:Reading tar file core.xml
10:43:32:WU01:FS01:0x21:Reading tar file integrator.xml
10:43:32:WU01:FS01:0x21:Reading tar file state.xml
10:43:32:WU01:FS01:0x21:Reading tar file system.xml
10:43:32:WU01:FS01:0x21:Digital signatures verified
10:43:32:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
10:43:32:WU01:FS01:0x21:Version 0.0.20
10:43:45:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
10:43:45:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:44:12:Saving configuration to config.xml
10:44:12:<config>
10:44:12: <!-- User Information -->
10:44:12: <passkey v='********************************'/>
10:44:12: <user v='PawelS'/>
10:44:12:
10:44:12: <!-- Folding Slots -->
10:44:12: <slot id='0' type='CPU'/>
10:44:12: <slot id='1' type='GPU'/>
10:44:12:</config>
10:44:30:WU02:FS00:Starting
10:44:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:44:30:WU02:FS00:Started FahCore on PID 7012
10:44:30:WU02:FS00:Core PID:924
10:44:30:WU02:FS00:FahCore 0xa7 started
10:44:31:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:45:30:WU02:FS00:Starting
10:45:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:45:30:WU02:FS00:Started FahCore on PID 3300
10:45:31:WU02:FS00:Core PID:3184
10:45:31:WU02:FS00:FahCore 0xa7 started
10:45:31:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:46:31:WU02:FS00:Starting
10:46:31:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:46:31:WU02:FS00:Started FahCore on PID 7740
10:46:31:WU02:FS00:Core PID:5308
10:46:31:WU02:FS00:FahCore 0xa7 started
10:46:32:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:46:32:WARNING:WU02:FS00:Too many errors, failing
10:46:32:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:13827 run:621 clone:1 gen:79 core:0xa7 unit:0x0000005d80fccb095c9f83b5a0e98d3e
10:46:32:WU02:FS00:Connecting to 128.252.203.9:8080
10:46:32:WU00:FS00:Connecting to 65.254.110.245:8080
10:46:32:WU02:FS00:Server responded WORK_ACK (400)
10:46:32:WU02:FS00:Cleaning up
10:46:33:WU00:FS00:Assigned to work server 155.247.166.219
10:46:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.219
10:46:33:WU00:FS00:Connecting to 155.247.166.219:8080
10:46:33:WU00:FS00:Downloading 1.22MiB
10:46:36:WU00:FS00:Download complete
10:46:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14091 run:0 clone:7 gen:36 core:0xa7 unit:0x0000002a0002894b5dacdada9eb453e3
10:46:36:WU00:FS00:Starting
10:46:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:46:36:WU00:FS00:Started FahCore on PID 6724
10:46:36:WU00:FS00:Core PID:8080
10:46:36:WU00:FS00:FahCore 0xa7 started
10:46:37:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
10:46:37:WARNING:WU00:FS00:Fatal error, dumping
10:46:37:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:14091 run:0 clone:7 gen:36 core:0xa7 unit:0x0000002a0002894b5dacdada9eb453e3
10:46:37:WU00:FS00:Connecting to 155.247.166.219:8080
10:46:37:WU02:FS00:Connecting to 65.254.110.245:8080
10:46:37:WU00:FS00:Server responded WORK_ACK (400)
10:46:37:WU00:FS00:Cleaning up
10:46:37:WU02:FS00:Assigned to work server 128.252.203.9
10:46:37:WU02:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
10:46:37:WU02:FS00:Connecting to 128.252.203.9:8080
10:46:38:WU02:FS00:Downloading 8.14MiB
10:46:43:WU02:FS00:Download complete
10:46:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13830 run:798 clone:1 gen:37 core:0xa7 unit:0x0000002c80fccb095d693c7f873fb25d
10:46:43:WU02:FS00:Starting
10:46:43:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:46:43:WU02:FS00:Started FahCore on PID 7380
10:46:43:WU02:FS00:Core PID:8796
10:46:43:WU02:FS00:FahCore 0xa7 started
10:46:44:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:46:44:WU02:FS00:Starting
10:46:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:46:44:WU02:FS00:Started FahCore on PID 1268
10:46:44:WU02:FS00:Core PID:9072
10:46:44:WU02:FS00:FahCore 0xa7 started
10:46:46:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:47:44:WU02:FS00:Starting
10:47:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:47:44:WU02:FS00:Started FahCore on PID 9404
10:47:44:WU02:FS00:Core PID:11420
10:47:44:WU02:FS00:FahCore 0xa7 started
10:47:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:48:45:WU02:FS00:Starting
10:48:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:48:45:WU02:FS00:Started FahCore on PID 1472
10:48:45:WU02:FS00:Core PID:13380
10:48:45:WU02:FS00:FahCore 0xa7 started
10:48:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:49:45:WU02:FS00:Starting
10:49:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:49:45:WU02:FS00:Started FahCore on PID 3928
10:49:45:WU02:FS00:Core PID:3232
10:49:45:WU02:FS00:FahCore 0xa7 started
10:49:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:49:45:WARNING:WU02:FS00:Too many errors, failing
10:49:45:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:13830 run:798 clone:1 gen:37 core:0xa7 unit:0x0000002c80fccb095d693c7f873fb25d
10:49:46:WU02:FS00:Connecting to 128.252.203.9:8080
10:49:46:WU00:FS00:Connecting to 65.254.110.245:8080
10:49:46:WU02:FS00:Server responded WORK_ACK (400)
10:49:46:WU02:FS00:Cleaning up
10:49:47:WU00:FS00:Assigned to work server 155.247.166.219
10:49:47:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.219
10:49:47:WU00:FS00:Connecting to 155.247.166.219:8080
10:49:47:WU00:FS00:Downloading 1.22MiB
10:49:53:WU00:FS00:Download 61.44%
10:49:54:WU00:FS00:Download complete
10:49:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14091 run:1 clone:12 gen:32 core:0xa7 unit:0x000000240002894b5dacdad5efc8f251
10:49:54:WU00:FS00:Starting
10:49:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:49:54:WU00:FS00:Started FahCore on PID 12812
10:49:54:WU00:FS00:Core PID:3108
10:49:54:WU00:FS00:FahCore 0xa7 started
10:49:55:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
10:49:55:WARNING:WU00:FS00:Fatal error, dumping
10:49:55:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:14091 run:1 clone:12 gen:32 core:0xa7 unit:0x000000240002894b5dacdad5efc8f251
10:49:55:WU00:FS00:Connecting to 155.247.166.219:8080
10:49:55:WU02:FS00:Connecting to 65.254.110.245:8080
10:49:56:WU00:FS00:Server responded WORK_ACK (400)
10:49:56:WU00:FS00:Cleaning up
10:49:56:WU02:FS00:Assigned to work server 155.247.166.220
10:49:56:WU02:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.220
10:49:56:WU02:FS00:Connecting to 155.247.166.220:8080
10:49:58:WU02:FS00:Downloading 1.53MiB
10:50:04:WU02:FS00:Download 16.32%
10:50:11:WU02:FS00:Download 61.19%
10:50:17:WU02:FS00:Download 73.42%
10:50:19:WU02:FS00:Download complete
10:50:19:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14181 run:20 clone:13 gen:48 core:0xa7 unit:0x000000410002894c5d3706404697d177
10:50:19:WU02:FS00:Starting
10:50:19:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:50:19:WU02:FS00:Started FahCore on PID 9380
10:50:19:WU02:FS00:Core PID:11004
10:50:19:WU02:FS00:FahCore 0xa7 started
10:50:20:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:50:21:WU02:FS00:Starting
10:50:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:50:21:WU02:FS00:Started FahCore on PID 10488
10:50:21:WU02:FS00:Core PID:10528
10:50:21:WU02:FS00:FahCore 0xa7 started
10:50:22:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:51:21:WU02:FS00:Starting
10:51:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:51:21:WU02:FS00:Started FahCore on PID 5352
10:51:21:WU02:FS00:Core PID:11708
10:51:21:WU02:FS00:FahCore 0xa7 started
10:51:22:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:52:21:WU02:FS00:Starting
10:52:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:52:21:WU02:FS00:Started FahCore on PID 1608
10:52:21:WU02:FS00:Core PID:4236
10:52:21:WU02:FS00:FahCore 0xa7 started
10:52:22:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:53:21:WU02:FS00:Starting
10:53:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:53:21:WU02:FS00:Started FahCore on PID 11500
10:53:21:WU02:FS00:Core PID:11712
10:53:21:WU02:FS00:FahCore 0xa7 started
10:53:22:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:53:22:WARNING:WU02:FS00:Too many errors, failing
10:53:22:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14181 run:20 clone:13 gen:48 core:0xa7 unit:0x000000410002894c5d3706404697d177
10:53:22:WU02:FS00:Connecting to 155.247.166.220:8080
10:53:22:WU00:FS00:Connecting to 65.254.110.245:8080
10:53:23:WU02:FS00:Server responded WORK_ACK (400)
10:53:23:WU02:FS00:Cleaning up
10:53:23:WU00:FS00:Assigned to work server 128.252.203.9
10:53:23:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
10:53:23:WU00:FS00:Connecting to 128.252.203.9:8080
10:53:24:WU00:FS00:Downloading 8.14MiB
10:53:28:WU00:FS00:Download complete
10:53:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13829 run:353 clone:0 gen:40 core:0xa7 unit:0x0000003080fccb095d66d41614f21fd0
10:53:28:WU00:FS00:Starting
10:53:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:53:28:WU00:FS00:Started FahCore on PID 14320
10:53:28:WU00:FS00:Core PID:9324
10:53:28:WU00:FS00:FahCore 0xa7 started
10:53:28:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
10:53:29:WARNING:WU00:FS00:Fatal error, dumping
10:53:29:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:13829 run:353 clone:0 gen:40 core:0xa7 unit:0x0000003080fccb095d66d41614f21fd0
10:53:29:WU00:FS00:Connecting to 128.252.203.9:8080
10:53:29:WU02:FS00:Connecting to 65.254.110.245:8080
10:53:29:WU00:FS00:Server responded WORK_ACK (400)
10:53:29:WU00:FS00:Cleaning up
10:53:30:WU02:FS00:Assigned to work server 155.247.166.220
10:53:30:WU02:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.220
10:53:30:WU02:FS00:Connecting to 155.247.166.220:8080
10:53:30:WU02:FS00:Downloading 1.84MiB
10:53:36:WU02:FS00:Download 33.95%
10:53:42:WU02:FS00:Download 91.67%
10:53:43:WU02:FS00:Download complete
10:53:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13794 run:15 clone:481 gen:14 core:0xa7 unit:0x0000000e0002894c5dae0ae2d564f3ba
10:53:43:WU02:FS00:Starting
10:53:43:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:53:43:WU02:FS00:Started FahCore on PID 14064
10:53:43:WU02:FS00:Core PID:4152
10:53:43:WU02:FS00:FahCore 0xa7 started
10:53:44:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:53:44:WU02:FS00:Starting
10:53:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:53:44:WU02:FS00:Started FahCore on PID 6520
10:53:44:WU02:FS00:Core PID:10512
10:53:44:WU02:FS00:FahCore 0xa7 started
10:53:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:54:44:WU02:FS00:Starting
10:54:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:54:44:WU02:FS00:Started FahCore on PID 9072
10:54:44:WU02:FS00:Core PID:13148
10:54:44:WU02:FS00:FahCore 0xa7 started
10:54:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:55:44:WU02:FS00:Starting
10:55:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:55:44:WU02:FS00:Started FahCore on PID 5536
10:55:44:WU02:FS00:Core PID:8684
10:55:44:WU02:FS00:FahCore 0xa7 started
10:55:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:56:44:WU02:FS00:Starting
10:56:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:56:44:WU02:FS00:Started FahCore on PID 10988
10:56:45:WU02:FS00:Core PID:10548
10:56:45:WU02:FS00:FahCore 0xa7 started
10:56:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:56:45:WARNING:WU02:FS00:Too many errors, failing
10:56:45:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:13794 run:15 clone:481 gen:14 core:0xa7 unit:0x0000000e0002894c5dae0ae2d564f3ba
10:56:45:WU02:FS00:Connecting to 155.247.166.220:8080
10:56:46:WU02:FS00:Server responded WORK_ACK (400)
10:56:46:WU02:FS00:Cleaning up
10:56:46:WU00:FS00:Connecting to 65.254.110.245:8080
10:56:46:WU00:FS00:Assigned to work server 155.247.166.219
10:56:46:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.166.219
10:56:46:WU00:FS00:Connecting to 155.247.166.219:8080
10:56:47:WU00:FS00:Downloading 1.72MiB
10:56:49:WU00:FS00:Download complete
10:56:49:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14182 run:7 clone:92 gen:28 core:0xa7 unit:0x000000220002894b5cf684be5deb324a
10:56:49:WU00:FS00:Starting
10:56:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:56:49:WU00:FS00:Started FahCore on PID 13388
10:56:49:WU00:FS00:Core PID:7528
10:56:49:WU00:FS00:FahCore 0xa7 started
10:56:50:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
10:56:50:WARNING:WU00:FS00:Fatal error, dumping
10:56:50:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:14182 run:7 clone:92 gen:28 core:0xa7 unit:0x000000220002894b5cf684be5deb324a
10:56:50:WU00:FS00:Connecting to 155.247.166.219:8080
10:56:50:WU02:FS00:Connecting to 65.254.110.245:8080
10:56:50:WU00:FS00:Server responded WORK_ACK (400)
10:56:50:WU00:FS00:Cleaning up
10:56:51:WU02:FS00:Assigned to work server 128.252.203.9
10:56:51:WU02:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
10:56:51:WU02:FS00:Connecting to 128.252.203.9:8080
10:56:51:WU02:FS00:Downloading 8.14MiB
10:56:57:WU02:FS00:Download 82.94%
10:56:57:WU02:FS00:Download complete
10:56:58:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13827 run:35 clone:1 gen:64 core:0xa7 unit:0x0000004e80fccb095c9f84985e525021
10:56:58:WU02:FS00:Starting
10:56:58:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:56:58:WU02:FS00:Started FahCore on PID 9400
10:56:58:WU02:FS00:Core PID:3164
10:56:58:WU02:FS00:FahCore 0xa7 started
10:56:58:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:56:59:WU02:FS00:Starting
10:56:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:56:59:WU02:FS00:Started FahCore on PID 12728
10:56:59:WU02:FS00:Core PID:13620
10:56:59:WU02:FS00:FahCore 0xa7 started
10:56:59:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:57:59:WU02:FS00:Starting
10:57:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:57:59:WU02:FS00:Started FahCore on PID 3572
10:57:59:WU02:FS00:Core PID:540
10:57:59:WU02:FS00:FahCore 0xa7 started
10:58:00:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:58:59:WU02:FS00:Starting
10:58:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:58:59:WU02:FS00:Started FahCore on PID 9148
10:58:59:WU02:FS00:Core PID:6624
10:58:59:WU02:FS00:FahCore 0xa7 started
10:59:00:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:59:59:WU02:FS00:Starting
10:59:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pawci\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 9908 -checkpoint 15 -np 2
10:59:59:WU02:FS00:Started FahCore on PID 8108
10:59:59:WU02:FS00:Core PID:11908
10:59:59:WU02:FS00:FahCore 0xa7 started
11:00:00:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:00:00:WARNING:WU02:FS00:Too many errors, failing
11:00:00:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:13827 run:35 clone:1 gen:64 core:0xa7 unit:0x0000004e80fccb095c9f84985e525021
11:00:00:WU02:FS00:Connecting to 128.252.203.9:8080
11:00:00:WU02:FS00:Server responded WORK_ACK (400)
11:00:00:WU02:FS00:Cleaning up
