Why do I constantly lose my % progress?
danielk
Post by danielk »
Hello.
I am new to folding@home. I just installed the software today and have been folding for 2-3 hours now. However I've noticed that at a certain point I had completed 10% of my job and then suddenly the % counter went down to zero, I lost my progress and the counter started going up from zero. I set the checkpoint frequency to 8 minutes, so that I don't lose any progress in case of the Internet connection stopping or something.
This situation happened a couple of times. Is this normal or I am experiencing some kind of a bug? Thank you.
Re: Why do I constantly lose my % progress?
Post your log per the instructions below.
Perhaps your system had an error; perhaps not.
Did you do the default install or did you try to do things differently? Were you logged on as the same user that's currently running FAH?
danielk
Post by danielk »
bruce wrote:Post your log per the instructions below.
Hello, Bruce.
I did the default install. However I think I first started the app and after that I chose a username, received a passkey and entered them on the web interface. Here's a screenshot of my app: Image
It's been running for 5-6 hours now and I haven't received any points so far as I can see in the FAH web page. It % counter keeps increasing and reseting itself back to zero, than starts gaining again.
As for the log, I'm not sure what exactly you're asking me to do, so I'll just copy the whole log info. Here it is:
*********************** Log Started 2019-10-27T11:24:42Z ***********************
11:24:42:************************* Folding@home Client *************************
11:24:42:        Website: https://foldingathome.org/
11:24:42:      Copyright: (c) 2009-2018 foldingathome.org
11:24:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:24:42:           Args: --open-web-control
11:24:42:         Config: <none>
11:24:42:******************************** Build ********************************
11:24:42:        Version: 7.5.1
11:24:42:           Date: May 11 2018
11:24:42:           Time: 13:06:32
11:24:42:     Repository: Git
11:24:42:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:24:42:         Branch: master
11:24:42:       Compiler: Visual C++ 2008
11:24:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:24:42:       Platform: win32 10
11:24:42:           Bits: 32
11:24:42:           Mode: Release
11:24:42:******************************* System ********************************
11:24:42:            CPU: Intel(R) Pentium(R) CPU N3540 @ 2.16GHz
11:24:42:         CPU ID: GenuineIntel Family 6 Model 55 Stepping 8
11:24:42:           CPUs: 4
11:24:42:         Memory: 3.89GiB
11:24:42:    Free Memory: 734.06MiB
11:24:42:        Threads: WINDOWS_THREADS
11:24:42:     OS Version: 6.1
11:24:42:    Has Battery: false
11:24:42:     On Battery: false
11:24:42:     UTC Offset: 2
11:24:42:            PID: 5164
11:24:42:            CWD: C:\Users\Dido\AppData\Roaming\FAHClient
11:24:42:             OS: Windows 7 Ultimate
11:24:42:        OS Arch: AMD64
11:24:42:           GPUs: 0
11:24:42:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
11:24:42:                 specified module could not be found.
11:24:42:
11:24:42:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
11:24:42:  Win32 Service: false
11:24:42:***********************************************************************
11:24:42:<config>
11:24:42:  <!-- Folding Slots -->
11:24:42:</config>
11:24:42:Connecting to assign1.foldingathome.org:8080
11:25:04:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to connect to assign1.foldingathome.org:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:25:04:Connecting to assign2.foldingathome.org:80
11:25:25:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to connect to assign2.foldingathome.org:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:25:25:Trying to access database...
11:25:26:Successfully acquired database lock
11:25:26:Enabled folding slot 00: PAUSED cpu:3 (not configured)
11:25:34:8:127.0.0.1:New Web connection
11:26:27:Saving configuration to config.xml
11:26:27:<config>
11:26:27:  <!-- Folding Slots -->
11:26:27:  <slot id='0' type='CPU'/>
11:26:27:</config>
11:26:27:Set client configured
11:26:27:WU00:FS00:Connecting to 65.254.110.245:8080
11:26:28:WU00:FS00:Connecting to 65.254.110.245:8080
11:26:28:WU00:FS00:Assigned to work server 128.252.203.9
11:26:28:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
11:26:28:WU00:FS00:Connecting to 128.252.203.9:8080
11:26:29:WU00:FS00:Downloading 8.14MiB
11:26:34:WU00:FS00:Download complete
11:26:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13831 run:639 clone:2 gen:20 core:0xa7 unit:0x0000001580fccb095d693ab67c3429ee
11:26:35:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_a7.fah
11:26:35:WU00:FS00:Connecting to cores.foldingathome.org:80
11:26:35:WU00:FS00:FahCore a7: Downloading 6.64MiB
11:26:40:WU00:FS00:FahCore a7: Download complete
11:26:40:WU00:FS00:Valid core signature
11:26:40:WU00:FS00:Unpacked 18.40MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe
11:26:40:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/libfftw3f-3.dll
11:26:40:WU00:FS00:Starting
11:26:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 15 -np 3
11:26:40:WU00:FS00:Started FahCore on PID 7876
11:26:41:WU00:FS00:Core PID:6512
11:26:41:WU00:FS00:FahCore 0xa7 started
11:26:42:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T11:26:42Z ***********************
11:26:42:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:26:42:WU00:FS00:0xa7:       Type: 0xa7
11:26:42:WU00:FS00:0xa7:       Core: Gromacs
11:26:42:WU00:FS00:0xa7:    Website: https://foldingathome.org/
11:26:42:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
11:26:42:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:26:42:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7876 -checkpoint 15 -np 3
11:26:42:WU00:FS00:0xa7:     Config: <none>
11:26:42:WU00:FS00:0xa7:************************************ Build *************************************
11:26:42:WU00:FS00:0xa7:    Version: 0.0.17
11:26:42:WU00:FS00:0xa7:       Date: Apr 27 2018
11:26:42:WU00:FS00:0xa7:       Time: 16:19:35
11:26:42:WU00:FS00:0xa7: Repository: Git
11:26:42:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
11:26:42:WU00:FS00:0xa7:     Branch: master
11:26:42:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:26:42:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:26:42:WU00:FS00:0xa7:   Platform: win32 10
11:26:42:WU00:FS00:0xa7:       Bits: 64
11:26:42:WU00:FS00:0xa7:       Mode: Release
11:26:42:WU00:FS00:0xa7:       SIMD: sse2
11:26:42:WU00:FS00:0xa7:************************************ System ************************************
11:26:42:WU00:FS00:0xa7:        CPU: Unknown
11:26:42:WU00:FS00:0xa7:     CPU ID:
11:26:42:WU00:FS00:0xa7:       CPUs: 4
11:26:42:WU00:FS00:0xa7:     Memory: 3.89GiB
11:26:42:WU00:FS00:0xa7:Free Memory: 678.38MiB
11:26:42:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:26:42:WU00:FS00:0xa7: OS Version: 6.1
11:26:42:WU00:FS00:0xa7:Has Battery: false
11:26:42:WU00:FS00:0xa7: On Battery: false
11:26:42:WU00:FS00:0xa7: UTC Offset: 2
11:26:42:WU00:FS00:0xa7:        PID: 6512
11:26:42:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
11:26:42:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
11:26:42:WU00:FS00:0xa7:    OS Arch: AMD64
11:26:42:WU00:FS00:0xa7:********************************************************************************
11:26:42:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
11:26:42:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
11:26:42:WU00:FS00:0xa7:Reading tar file core.xml
11:26:42:WU00:FS00:0xa7:Reading tar file frame20.tpr
11:26:42:WU00:FS00:0xa7:Digital signatures verified
11:26:42:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 3
11:28:06:WU00:FS00:0xa7:Steps: first=2500000 total=125000
11:29:42:Connecting to assign1.foldingathome.org:8080
11:29:42:Updated GPUs.txt
11:31:46:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
11:32:33:Saving configuration to config.xml
11:32:33:<config>
11:32:33:  <!-- User Information -->
11:32:33:  <passkey v='********************************'/>
11:32:33:  <user v='danielkostov'/>
11:32:33:
11:32:33:  <!-- Folding Slots -->
11:32:33:  <slot id='0' type='CPU'/>
11:32:33:</config>
11:34:36:FS00:Shutting core down
11:34:36:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6512
11:34:36:WU00:FS00:0xa7:Exiting, please wait. . .
11:34:46:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:34:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:34:47:WU00:FS00:Starting
11:34:47:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
11:34:47:WARNING:WU00:FS00:AS lowered CPUs from 4 to 3
11:34:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 15 -np 3
11:34:47:WU00:FS00:Started FahCore on PID 7836
11:34:47:WU00:FS00:Core PID:8068
11:34:47:WU00:FS00:FahCore 0xa7 started
11:34:48:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T11:34:47Z ***********************
11:34:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:34:48:WU00:FS00:0xa7:       Type: 0xa7
11:34:48:WU00:FS00:0xa7:       Core: Gromacs
11:34:48:WU00:FS00:0xa7:    Website: https://foldingathome.org/
11:34:48:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
11:34:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:34:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7836 -checkpoint 15 -np 3
11:34:48:WU00:FS00:0xa7:     Config: <none>
11:34:48:WU00:FS00:0xa7:************************************ Build *************************************
11:34:48:WU00:FS00:0xa7:    Version: 0.0.17
11:34:48:WU00:FS00:0xa7:       Date: Apr 27 2018
11:34:48:WU00:FS00:0xa7:       Time: 16:19:35
11:34:48:WU00:FS00:0xa7: Repository: Git
11:34:48:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
11:34:48:WU00:FS00:0xa7:     Branch: master
11:34:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:34:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:34:48:WU00:FS00:0xa7:   Platform: win32 10
11:34:48:WU00:FS00:0xa7:       Bits: 64
11:34:48:WU00:FS00:0xa7:       Mode: Release
11:34:48:WU00:FS00:0xa7:       SIMD: sse2
11:34:48:WU00:FS00:0xa7:************************************ System ************************************
11:34:48:WU00:FS00:0xa7:        CPU: Unknown
11:34:48:WU00:FS00:0xa7:     CPU ID:
11:34:48:WU00:FS00:0xa7:       CPUs: 4
11:34:48:WU00:FS00:0xa7:     Memory: 3.89GiB
11:34:48:WU00:FS00:0xa7:Free Memory: 800.47MiB
11:34:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:34:48:WU00:FS00:0xa7: OS Version: 6.1
11:34:48:WU00:FS00:0xa7:Has Battery: false
11:34:48:WU00:FS00:0xa7: On Battery: false
11:34:48:WU00:FS00:0xa7: UTC Offset: 2
11:34:48:WU00:FS00:0xa7:        PID: 8068
11:34:48:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
11:34:48:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
11:34:48:WU00:FS00:0xa7:    OS Arch: AMD64
11:34:48:WU00:FS00:0xa7:********************************************************************************
11:34:48:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
11:34:48:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
11:34:48:WU00:FS00:0xa7:Digital signatures verified
11:34:48:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 15 -nt 3
11:34:56:WU00:FS00:0xa7:Steps: first=2500000 total=125000
11:35:18:WU00:FS00:0xa7:Completed 112 out of 125000 steps (0%)
11:35:36:Saving configuration to config.xml
11:35:36:<config>
11:35:36:  <!-- Slot Control -->
11:35:36:  <power v='FULL'/>
11:35:36:
11:35:36:  <!-- User Information -->
11:35:36:  <passkey v='********************************'/>
11:35:36:  <user v='danielkostov'/>
11:35:36:
11:35:36:  <!-- Folding Slots -->
11:35:36:  <slot id='0' type='CPU'/>
11:35:36:</config>
11:57:53:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
12:10:06:FS00:Shutting core down
12:10:07:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 8068
12:10:07:WU00:FS00:0xa7:Exiting, please wait. . .
12:10:10:Saving configuration to config.xml
12:10:10:<config>
12:10:10:  <!-- Slot Control -->
12:10:10:  <power v='MEDIUM'/>
12:10:10:
12:10:10:  <!-- User Information -->
12:10:10:  <passkey v='********************************'/>
12:10:10:  <user v='danielkostov'/>
12:10:10:
12:10:10:  <!-- Folding Slots -->
12:10:10:  <slot id='0' type='CPU'/>
12:10:10:</config>
12:11:07:WARNING:FS00:Killing WU00
12:11:07:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:11:07:WU00:FS00:Starting
12:11:07:WARNING:WU00:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
12:11:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 15 -np 3
12:11:07:WU00:FS00:Started FahCore on PID 2672
12:11:07:WU00:FS00:Core PID:5424
12:11:07:WU00:FS00:FahCore 0xa7 started
12:11:09:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T12:11:09Z ***********************
12:11:09:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:11:09:WU00:FS00:0xa7:       Type: 0xa7
12:11:09:WU00:FS00:0xa7:       Core: Gromacs
12:11:09:WU00:FS00:0xa7:    Website: https://foldingathome.org/
12:11:09:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:11:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:11:09:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2672 -checkpoint 15 -np 3
12:11:09:WU00:FS00:0xa7:     Config: <none>
12:11:09:WU00:FS00:0xa7:************************************ Build *************************************
12:11:09:WU00:FS00:0xa7:    Version: 0.0.17
12:11:09:WU00:FS00:0xa7:       Date: Apr 27 2018
12:11:09:WU00:FS00:0xa7:       Time: 16:19:35
12:11:09:WU00:FS00:0xa7: Repository: Git
12:11:09:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
12:11:09:WU00:FS00:0xa7:     Branch: master
12:11:09:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:11:09:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:11:09:WU00:FS00:0xa7:   Platform: win32 10
12:11:09:WU00:FS00:0xa7:       Bits: 64
12:11:09:WU00:FS00:0xa7:       Mode: Release
12:11:09:WU00:FS00:0xa7:       SIMD: sse2
12:11:09:WU00:FS00:0xa7:************************************ System ************************************
12:11:09:WU00:FS00:0xa7:        CPU: Unknown
12:11:09:WU00:FS00:0xa7:     CPU ID:
12:11:09:WU00:FS00:0xa7:       CPUs: 4
12:11:09:WU00:FS00:0xa7:     Memory: 3.89GiB
12:11:09:WU00:FS00:0xa7:Free Memory: 1021.56MiB
12:11:09:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:11:09:WU00:FS00:0xa7: OS Version: 6.1
12:11:09:WU00:FS00:0xa7:Has Battery: false
12:11:09:WU00:FS00:0xa7: On Battery: false
12:11:09:WU00:FS00:0xa7: UTC Offset: 2
12:11:09:WU00:FS00:0xa7:        PID: 5424
12:11:09:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
12:11:09:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
12:11:09:WU00:FS00:0xa7:    OS Arch: AMD64
12:11:09:WU00:FS00:0xa7:********************************************************************************
12:11:09:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
12:11:09:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
12:11:09:WU00:FS00:0xa7:Digital signatures verified
12:11:09:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 15 -nt 3
12:11:18:WU00:FS00:0xa7:Steps: first=2500000 total=125000
12:11:56:72:127.0.0.1:New Web connection
12:14:22:WU00:FS00:0xa7:Completed 1651 out of 125000 steps (1%)
12:16:30:Saving configuration to config.xml
12:16:30:<config>
12:16:30:  <!-- Folding Core -->
12:16:30:  <checkpoint v='10'/>
12:16:30:  <core-priority v='low'/>
12:16:30:
12:16:30:  <!-- Network -->
12:16:30:  <proxy v=':8080'/>
12:16:30:
12:16:30:  <!-- Slot Control -->
12:16:30:  <power v='MEDIUM'/>
12:16:30:
12:16:30:  <!-- User Information -->
12:16:30:  <passkey v='********************************'/>
12:16:30:  <user v='danielkostov'/>
12:16:30:
12:16:30:  <!-- Folding Slots -->
12:16:30:  <slot id='0' type='CPU'/>
12:16:30:</config>
12:17:17:Saving configuration to config.xml
12:17:17:<config>
12:17:17:  <!-- Folding Core -->
12:17:17:  <checkpoint v='10'/>
12:17:17:  <core-priority v='low'/>
12:17:17:
12:17:17:  <!-- Network -->
12:17:17:  <proxy v=':8080'/>
12:17:17:
12:17:17:  <!-- Slot Control -->
12:17:17:  <power v='MEDIUM'/>
12:17:17:
12:17:17:  <!-- User Information -->
12:17:17:  <passkey v='********************************'/>
12:17:17:  <user v='danielkostov'/>
12:17:17:
12:17:17:  <!-- Folding Slots -->
12:17:17:  <slot id='0' type='CPU'/>
12:17:17:</config>
12:33:19:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
12:48:01:Saving configuration to config.xml
12:48:01:<config>
12:48:01:  <!-- Folding Core -->
12:48:01:  <checkpoint v='8'/>
12:48:01:  <core-priority v='low'/>
12:48:01:
12:48:01:  <!-- Network -->
12:48:01:  <proxy v=':8080'/>
12:48:01:
12:48:01:  <!-- Slot Control -->
12:48:01:  <power v='MEDIUM'/>
12:48:01:
12:48:01:  <!-- User Information -->
12:48:01:  <passkey v='********************************'/>
12:48:01:  <user v='danielkostov'/>
12:48:01:
12:48:01:  <!-- Folding Slots -->
12:48:01:  <slot id='0' type='CPU'/>
12:48:01:</config>
12:48:48:Saving configuration to config.xml
12:48:48:<config>
12:48:48:  <!-- Folding Core -->
12:48:48:  <checkpoint v='8'/>
12:48:48:  <core-priority v='low'/>
12:48:48:
12:48:48:  <!-- Network -->
12:48:48:  <proxy v=':8080'/>
12:48:48:
12:48:48:  <!-- Slot Control -->
12:48:48:  <power v='MEDIUM'/>
12:48:48:
12:48:48:  <!-- User Information -->
12:48:48:  <passkey v='********************************'/>
12:48:48:  <user v='danielkostov'/>
12:48:48:
12:48:48:  <!-- Folding Slots -->
12:48:48:  <slot id='0' type='CPU'/>
12:48:48:</config>
12:52:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
12:58:34:FS00:Shutting core down
12:58:36:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5424
12:58:37:WU00:FS00:0xa7:Exiting, please wait. . .
12:58:58:Saving configuration to config.xml
12:58:58:<config>
12:58:58:  <!-- Folding Core -->
12:58:58:  <checkpoint v='8'/>
12:58:58:  <core-priority v='low'/>
12:58:58:
12:58:58:  <!-- Network -->
12:58:58:  <proxy v=':8080'/>
12:58:58:
12:58:58:  <!-- Slot Control -->
12:58:58:  <power v='light'/>
12:58:58:
12:58:58:  <!-- User Information -->
12:58:58:  <passkey v='********************************'/>
12:58:58:  <user v='danielkostov'/>
12:58:58:
12:58:58:  <!-- Folding Slots -->
12:58:58:  <slot id='0' type='CPU'/>
12:58:58:</config>
12:59:36:WARNING:FS00:Killing WU00
12:59:36:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:59:37:WU00:FS00:Starting
12:59:37:WARNING:WU00:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
12:59:37:ERROR:WU00:FS00:Failed to start core: Failed to rename './work/00/logfile_01.txt' to './work/00/logfile_01-20191027-125937.txt': The process cannot access the file because it is being used by another process.
13:01:00:Saving configuration to config.xml
13:01:00:<config>
13:01:00:  <!-- Folding Core -->
13:01:00:  <checkpoint v='8'/>
13:01:00:  <core-priority v='low'/>
13:01:00:
13:01:00:  <!-- Network -->
13:01:00:  <proxy v=':8080'/>
13:01:00:
13:01:00:  <!-- User Information -->
13:01:00:  <passkey v='********************************'/>
13:01:00:  <user v='danielkostov'/>
13:01:00:
13:01:00:  <!-- Folding Slots -->
13:01:00:  <slot id='0' type='CPU'/>
13:01:00:</config>
13:01:14:WU00:FS00:Starting
13:01:14:WARNING:WU00:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
13:01:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 8 -np 3
13:01:14:WU00:FS00:Started FahCore on PID 8112
13:01:15:WU00:FS00:Core PID:5796
13:01:15:WU00:FS00:FahCore 0xa7 started
13:01:20:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T13:01:19Z ***********************
13:01:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:01:20:WU00:FS00:0xa7:       Type: 0xa7
13:01:20:WU00:FS00:0xa7:       Core: Gromacs
13:01:20:WU00:FS00:0xa7:    Website: https://foldingathome.org/
13:01:20:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
13:01:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:01:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8112 -checkpoint 8 -np 3
13:01:20:WU00:FS00:0xa7:     Config: <none>
13:01:20:WU00:FS00:0xa7:************************************ Build *************************************
13:01:20:WU00:FS00:0xa7:    Version: 0.0.17
13:01:20:WU00:FS00:0xa7:       Date: Apr 27 2018
13:01:20:WU00:FS00:0xa7:       Time: 16:19:35
13:01:20:WU00:FS00:0xa7: Repository: Git
13:01:20:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
13:01:20:WU00:FS00:0xa7:     Branch: master
13:01:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:01:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:01:20:WU00:FS00:0xa7:   Platform: win32 10
13:01:20:WU00:FS00:0xa7:       Bits: 64
13:01:20:WU00:FS00:0xa7:       Mode: Release
13:01:20:WU00:FS00:0xa7:       SIMD: sse2
13:01:20:WU00:FS00:0xa7:************************************ System ************************************
13:01:20:WU00:FS00:0xa7:        CPU: Unknown
13:01:20:WU00:FS00:0xa7:     CPU ID:
13:01:20:WU00:FS00:0xa7:       CPUs: 4
13:01:20:WU00:FS00:0xa7:     Memory: 3.89GiB
13:01:20:WU00:FS00:0xa7:Free Memory: 1.82GiB
13:01:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:01:20:WU00:FS00:0xa7: OS Version: 6.1
13:01:20:WU00:FS00:0xa7:Has Battery: false
13:01:20:WU00:FS00:0xa7: On Battery: false
13:01:20:WU00:FS00:0xa7: UTC Offset: 2
13:01:20:WU00:FS00:0xa7:        PID: 5796
13:01:20:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
13:01:20:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
13:01:20:WU00:FS00:0xa7:    OS Arch: AMD64
13:01:20:WU00:FS00:0xa7:********************************************************************************
13:01:20:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
13:01:20:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
13:01:20:WU00:FS00:0xa7:Digital signatures verified
13:01:20:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 8 -nt 3
13:01:23:WU00:FS00:0xa7:Steps: first=2500000 total=125000
13:06:22:WU00:FS00:0xa7:Completed 3551 out of 125000 steps (2%)
13:21:47:FS00:Shutting core down
13:21:51:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5796
13:21:51:WU00:FS00:0xa7:Exiting, please wait. . .
13:22:21:Saving configuration to config.xml
13:22:21:<config>
13:22:21:  <!-- Folding Core -->
13:22:21:  <checkpoint v='8'/>
13:22:21:  <core-priority v='low'/>
13:22:21:
13:22:21:  <!-- Network -->
13:22:21:  <proxy v=':8080'/>
13:22:21:
13:22:21:  <!-- Slot Control -->
13:22:21:  <power v='full'/>
13:22:21:
13:22:21:  <!-- User Information -->
13:22:21:  <passkey v='********************************'/>
13:22:21:  <user v='danielkostov'/>
13:22:21:
13:22:21:  <!-- Folding Slots -->
13:22:21:  <slot id='0' type='CPU'/>
13:22:21:</config>
13:22:48:WARNING:FS00:Killing WU00
13:22:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:22:48:WU00:FS00:Starting
13:22:48:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
13:22:48:WARNING:WU00:FS00:AS lowered CPUs from 4 to 3
13:22:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 8 -np 3
13:22:48:WU00:FS00:Started FahCore on PID 5604
13:22:49:WU00:FS00:Core PID:5320
13:22:49:WU00:FS00:FahCore 0xa7 started
13:22:51:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T13:22:51Z ***********************
13:22:51:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:22:51:WU00:FS00:0xa7:       Type: 0xa7
13:22:51:WU00:FS00:0xa7:       Core: Gromacs
13:22:51:WU00:FS00:0xa7:    Website: https://foldingathome.org/
13:22:51:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
13:22:51:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:22:51:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5604 -checkpoint 8 -np 3
13:22:51:WU00:FS00:0xa7:     Config: <none>
13:22:51:WU00:FS00:0xa7:************************************ Build *************************************
13:22:51:WU00:FS00:0xa7:    Version: 0.0.17
13:22:51:WU00:FS00:0xa7:       Date: Apr 27 2018
13:22:51:WU00:FS00:0xa7:       Time: 16:19:35
13:22:51:WU00:FS00:0xa7: Repository: Git
13:22:51:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
13:22:51:WU00:FS00:0xa7:     Branch: master
13:22:51:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:22:51:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:22:51:WU00:FS00:0xa7:   Platform: win32 10
13:22:51:WU00:FS00:0xa7:       Bits: 64
13:22:51:WU00:FS00:0xa7:       Mode: Release
13:22:51:WU00:FS00:0xa7:       SIMD: sse2
13:22:51:WU00:FS00:0xa7:************************************ System ************************************
13:22:51:WU00:FS00:0xa7:        CPU: Unknown
13:22:51:WU00:FS00:0xa7:     CPU ID:
13:22:51:WU00:FS00:0xa7:       CPUs: 4
13:22:51:WU00:FS00:0xa7:     Memory: 3.89GiB
13:22:51:WU00:FS00:0xa7:Free Memory: 1.72GiB
13:22:51:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:22:51:WU00:FS00:0xa7: OS Version: 6.1
13:22:51:WU00:FS00:0xa7:Has Battery: false
13:22:51:WU00:FS00:0xa7: On Battery: false
13:22:51:WU00:FS00:0xa7: UTC Offset: 2
13:22:51:WU00:FS00:0xa7:        PID: 5320
13:22:51:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
13:22:51:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
13:22:51:WU00:FS00:0xa7:    OS Arch: AMD64
13:22:51:WU00:FS00:0xa7:********************************************************************************
13:22:51:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
13:22:51:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
13:22:51:WU00:FS00:0xa7:Digital signatures verified
13:22:51:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 8 -nt 3
13:22:54:WU00:FS00:0xa7:Steps: first=2500000 total=125000
13:28:36:WU00:FS00:0xa7:Completed 3691 out of 125000 steps (2%)
13:42:16:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
13:49:49:FS00:Shutting core down
13:49:50:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5320
13:49:50:WU00:FS00:0xa7:Exiting, please wait. . .
13:50:09:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
13:50:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:50:10:WU00:FS00:Starting
13:50:10:WARNING:WU00:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
13:50:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 8 -np 3
13:50:10:WU00:FS00:Started FahCore on PID 6200
13:50:10:WU00:FS00:Core PID:5204
13:50:10:WU00:FS00:FahCore 0xa7 started
13:50:11:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T13:50:10Z ***********************
13:50:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:50:11:WU00:FS00:0xa7:       Type: 0xa7
13:50:11:WU00:FS00:0xa7:       Core: Gromacs
13:50:11:WU00:FS00:0xa7:    Website: https://foldingathome.org/
13:50:11:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
13:50:11:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:50:11:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6200 -checkpoint 8 -np 3
13:50:11:WU00:FS00:0xa7:     Config: <none>
13:50:11:WU00:FS00:0xa7:************************************ Build *************************************
13:50:11:WU00:FS00:0xa7:    Version: 0.0.17
13:50:11:WU00:FS00:0xa7:       Date: Apr 27 2018
13:50:11:WU00:FS00:0xa7:       Time: 16:19:35
13:50:11:WU00:FS00:0xa7: Repository: Git
13:50:11:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
13:50:11:WU00:FS00:0xa7:     Branch: master
13:50:11:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:50:11:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:50:11:WU00:FS00:0xa7:   Platform: win32 10
13:50:11:WU00:FS00:0xa7:       Bits: 64
13:50:11:WU00:FS00:0xa7:       Mode: Release
13:50:11:WU00:FS00:0xa7:       SIMD: sse2
13:50:11:WU00:FS00:0xa7:************************************ System ************************************
13:50:11:WU00:FS00:0xa7:        CPU: Unknown
13:50:11:WU00:FS00:0xa7:     CPU ID:
13:50:11:WU00:FS00:0xa7:       CPUs: 4
13:50:11:WU00:FS00:0xa7:     Memory: 3.89GiB
13:50:11:WU00:FS00:0xa7:Free Memory: 1.82GiB
13:50:11:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:50:11:WU00:FS00:0xa7: OS Version: 6.1
13:50:11:WU00:FS00:0xa7:Has Battery: false
13:50:11:WU00:FS00:0xa7: On Battery: false
13:50:11:WU00:FS00:0xa7: UTC Offset: 2
13:50:11:WU00:FS00:0xa7:        PID: 5204
13:50:11:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
13:50:11:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
13:50:11:WU00:FS00:0xa7:    OS Arch: AMD64
13:50:11:WU00:FS00:0xa7:********************************************************************************
13:50:11:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
13:50:11:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
13:50:11:WU00:FS00:0xa7:Digital signatures verified
13:50:11:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 8 -nt 3
13:50:18:WU00:FS00:0xa7:Steps: first=2500000 total=125000
13:50:49:Saving configuration to config.xml
13:50:49:<config>
13:50:49:  <!-- Folding Core -->
13:50:49:  <checkpoint v='8'/>
13:50:49:  <core-priority v='low'/>
13:50:49:
13:50:49:  <!-- Network -->
13:50:49:  <proxy v=':8080'/>
13:50:49:
13:50:49:  <!-- User Information -->
13:50:49:  <passkey v='********************************'/>
13:50:49:  <user v='danielkostov'/>
13:50:49:
13:50:49:  <!-- Folding Slots -->
13:50:49:  <slot id='0' type='CPU'/>
13:50:49:</config>
13:52:32:WU00:FS00:0xa7:Completed 3802 out of 125000 steps (3%)
14:22:19:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
14:33:39:FS00:Shutting core down
14:33:40:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5204
14:33:40:WU00:FS00:0xa7:Exiting, please wait. . .
14:33:55:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:33:55:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:33:56:WU00:FS00:Starting
14:33:56:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
14:33:56:WARNING:WU00:FS00:AS lowered CPUs from 4 to 3
14:33:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dido\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 5164 -checkpoint 8 -np 3
14:33:56:WU00:FS00:Started FahCore on PID 6996
14:33:56:WU00:FS00:Core PID:6540
14:33:56:WU00:FS00:FahCore 0xa7 started
14:33:57:WU00:FS00:0xa7:*********************** Log Started 2019-10-27T14:33:57Z ***********************
14:33:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:33:57:WU00:FS00:0xa7:       Type: 0xa7
14:33:57:WU00:FS00:0xa7:       Core: Gromacs
14:33:57:WU00:FS00:0xa7:    Website: https://foldingathome.org/
14:33:57:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
14:33:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:33:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6996 -checkpoint 8 -np 3
14:33:57:WU00:FS00:0xa7:     Config: <none>
14:33:57:WU00:FS00:0xa7:************************************ Build *************************************
14:33:57:WU00:FS00:0xa7:    Version: 0.0.17
14:33:57:WU00:FS00:0xa7:       Date: Apr 27 2018
14:33:57:WU00:FS00:0xa7:       Time: 16:19:35
14:33:57:WU00:FS00:0xa7: Repository: Git
14:33:57:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
14:33:57:WU00:FS00:0xa7:     Branch: master
14:33:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:33:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:33:57:WU00:FS00:0xa7:   Platform: win32 10
14:33:57:WU00:FS00:0xa7:       Bits: 64
14:33:57:WU00:FS00:0xa7:       Mode: Release
14:33:57:WU00:FS00:0xa7:       SIMD: sse2
14:33:57:WU00:FS00:0xa7:************************************ System ************************************
14:33:57:WU00:FS00:0xa7:        CPU: Unknown
14:33:57:WU00:FS00:0xa7:     CPU ID:
14:33:57:WU00:FS00:0xa7:       CPUs: 4
14:33:57:WU00:FS00:0xa7:     Memory: 3.89GiB
14:33:57:WU00:FS00:0xa7:Free Memory: 1.75GiB
14:33:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:33:57:WU00:FS00:0xa7: OS Version: 6.1
14:33:57:WU00:FS00:0xa7:Has Battery: false
14:33:57:WU00:FS00:0xa7: On Battery: false
14:33:57:WU00:FS00:0xa7: UTC Offset: 2
14:33:57:WU00:FS00:0xa7:        PID: 6540
14:33:57:WU00:FS00:0xa7:        CWD: C:\Users\Dido\AppData\Roaming\FAHClient\work
14:33:57:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
14:33:57:WU00:FS00:0xa7:    OS Arch: AMD64
14:33:57:WU00:FS00:0xa7:********************************************************************************
14:33:57:WU00:FS00:0xa7:Project: 13831 (Run 639, Clone 2, Gen 20)
14:33:57:WU00:FS00:0xa7:Unit: 0x0000001580fccb095d693ab67c3429ee
14:33:57:WU00:FS00:0xa7:Digital signatures verified
14:33:57:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpi state.cpt -cpt 8 -nt 3
14:34:08:WU00:FS00:0xa7:Steps: first=2500000 total=125000
14:34:32:Saving configuration to config.xml
14:34:32:<config>
14:34:32:  <!-- Folding Core -->
14:34:32:  <checkpoint v='8'/>
14:34:32:  <core-priority v='low'/>
14:34:32:
14:34:32:  <!-- Network -->
14:34:32:  <proxy v=':8080'/>
14:34:32:
14:34:32:  <!-- Slot Control -->
14:34:32:  <power v='full'/>
14:34:32:
14:34:32:  <!-- User Information -->
14:34:32:  <passkey v='********************************'/>
14:34:32:  <user v='danielkostov'/>
14:34:32:
14:34:32:  <!-- Folding Slots -->
14:34:32:  <slot id='0' type='CPU'/>
14:34:32:</config>
14:35:50:WU00:FS00:0xa7:Completed 5512 out of 125000 steps (4%)
14:51:51:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
Mod note: added Code tags to log
First, you do not receive points until you complete and return a WU.
Your various configuration changes mostly have also included a pause and restart of processing the WU. In one case you had not completed enough to have a checkpoint, the WU started back at 0. In all cases the WU restarts at the progress recorded in the last checkpoint if it exists and is not corrupted.
One note, the WU you have was downloaded with a CPU setting of 3. Even if you set your system to use all 4 threads available, it will never run with more than 3.
There is a bug in the current A7 core that results in the upload size for the results growing very large if there are frequent restarts. See the following topics - viewtopic.php?f=18&t=31876, viewtopic.php?f=18&t=31944, and a topic on a beta test of a new version of the core - viewtopic.php?f=24&t=31960.
danielk
Post by danielk »
Joe_H wrote:First, you do not receive points until you complete and return a WU.
Thank you for the detailed explanations, Joe.
I had a look at the threads you mentioned.
My progress now reached 99.99% and it has been stuck on this figure for the last 15-20 minutes. Is this normal, or is it the bug which is mentioned in those threads? I did paused the process like 3-4 times. I checked the logged, the last entry is from 3 hours ago, when I had problems with my Internet connection. It doesn't say anything about trying to upload data or failing to do so. What do you advise? Should I just wait?
I'm sorry if my questions sound dumb, I'm fairly new to all this, I hope you understand. :)
Joe_H wrote:One note, the WU you have was downloaded with a CPU setting of 3. Even if you set your system to use all 4 threads available, it will never run with more than 3.
Just to clarify, if you have your client configured for 4 when the next WU downloads, that WU will run at any value between 1 and 4.
You have effectively changed the number of CPUs several times by moving the power slider, but ultimately you can't increase the value to 4 for this WU. Just let it finish at 3. You have also adjusted the checkpoint interval several times but each time you've made a change, the progress reverts to whatever checkpoint has been saved -- which has probably been the initial setting (if no checkpoint has been saved) so that's why things are getting set back to zero. Stopping making changes for a while will allow permanent progress to be stored in a new checkpoint.
danielk wrote:My progress now reached 99.99% and it has been stuck on this figure for the last 15-20 minutes. Is this normal, or is it the bug which is mentioned in those threads? I did paused the process like 3-4 times. I checked the logged, the last entry is from 3 hours ago, when I had problems with my Internet connection. It doesn't say anything about trying to upload data or failing to do so. What do you advise? Should I just wait?
No, your questions don't sound dumb. You're fairly new, as you say, but also very observant -- asking questions about things many folks wouldn't have noticed.
Probably the answer is "just wait" but you'll need to append another segment of your log showing what happened more recently. The progress up to 99% wasn't covered in your earlier post. (Start about about the point that the earlier log ended.
If it is still stuck at 99%, it probably makes sense to pause and resume and see what happens. It might back up to an earlier checkpoint ... or might not.
danielk
Post by danielk »
What I observe now is the % counter reaching 99.9% several times already and than starting back from zero eventhough I have set the frequency checkpoint to 8 minutes and haven't touched it since then. This was taken a few hours ago: Image
This screenshot is from a few minutes ago: Image
This is what puzzles me. It seems like the whole job is fragmented into many 99.9%'s and reaching this figure gets done only one fragment. Than it starts doing the next one from zero to 99.9%.
When it reverted back to zero, I checked the log and saw:
19:02:41:WU00:FS00:0xa7:Completed 12271 out of 125000 steps (9%)
19:26:11:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
20:37:19:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
So basically these 99.9% is actually 1 percent done of the whole job, am I right on this one?
My guess from the information you have provided is that either the core process crashed in some way and restarted at the beginning, or that the process of writing out a checkpoint was interrupted and caused it to be corrupted. The same thing would happen, processing may start over at the beginning. You did not show enough of the log to tell.
One thing, there is a saying that a picture is worth a thousand words. It is often wrong, and this is one case where the screen captures of the appearance of FAHClient are not much help in troubleshooting. Please just post the log section that covers from just before to a bit after the progress reverting to zero. In this case the two pictures are from over 3 hours apart, a lot could have happened in that interval. The log usually does capture that information.
Your concept of "fragments" seems to suggest that the percent complete in the screenshot isn't meaningful. On the other hand, I see a screenshot saying the WU is 11.85% complete while the log has recently reported "Completed 13750 out of 125000 steps (11%)" which is completely consistent. I tend to believe that the log is correct. What's interesting is that it took 23m30 tos get from 9% to 10% and it took 1h11m08s to get from 10% to 11%. Ordinarily those two intervals should similar in duration. since the computation rate SHOULD be the same and the processing load SHOULD be about the same.
I have to ask: Is your OS configured to save power by sleeping when nobody is at the keyboard? FAH requires that the CPU be set to whatever setting tells it NOT to sleep but to continue processing. The other possibility is that you've chosen to have FAH process "on idle" which means it never goes into computing mode as long as somebody is at the keyboard.
danielk
Post by danielk »
Hey, guys!
I've have finally gotten my way around this nice program. :)) I've learned to work with it without having so many crashes and bugs. Thank you for the assistance.
It is all going normal regarding the % counter nowadays, it is steady and works fine. I'm on my third job right now.
I'd like to ask one thing. I decided to try how my other computer would compute, but it is an old and slow one. I accepted a job, but it is really not worth the time and electricity. Can I cancel the job without this affecting my bonus? I'm determined to complete 10 tasks before deadline, but do they have to be consecutive for this matter? Please, help me get around this situation.
@bruce The only time I don't fold is when my laptop is turned off. Otherwise I fold all the time. Folding does get slower when I use the laptop for surfing the web and gets faster when I'm not on the keyboard.
As i understand it, you must maintain a 80% completion rate to get the bonus.
One failure to complete should not be an issue.
Another choice is to set the WU to 'Finish', where it completes but does not start another,
danielk
Post by danielk »
JimboPalmer wrote:As i understand it, you must maintain a 80% completion rate to get the bonus.
Thank you, Jimbo!
