Device ID: 1002 6981 - 103C 854C
*********************** Log Started 2019-10-22T19:55:02Z ***********************
19:55:02:************************* Folding@home Client *************************
19:55:02: Website: https://foldingathome.org/
19:55:02: Copyright: (c) 2009-2018 foldingathome.org
19:55:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:02: Args:
19:55:02: Config: C:\Users\David\AppData\Roaming\FAHClient\config.xml
19:55:02:******************************** Build ********************************
19:55:02: Version: 7.5.1
19:55:02: Date: May 11 2018
19:55:02: Time: 13:06:32
19:55:02: Repository: Git
19:55:02: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:55:02: Branch: master
19:55:02: Compiler: Visual C++ 2008
19:55:02: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:55:02: Platform: win32 10
19:55:02: Bits: 32
19:55:02: Mode: Release
19:55:02:******************************* System ********************************
19:55:02: CPU: Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz
19:55:02: CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
19:55:02: CPUs: 8
19:55:02: Memory: 15.81GiB
19:55:02: Free Memory: 13.89GiB
19:55:02: Threads: WINDOWS_THREADS
19:55:02: OS Version: 6.2
19:55:02: Has Battery: true
19:55:02: On Battery: false
19:55:02: UTC Offset: 13
19:55:02: PID: 7660
19:55:02: CWD: C:\WINDOWS\system32
19:55:02: OS: Windows 10 Enterprise
19:55:02: OS Arch: AMD64
19:55:02: GPUs: 0
19:55:02: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:55:02: specified module could not be found.
19:55:02:
19:55:02:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
19:55:02:OpenCL Device 2: Platform:1 Device:0 Bus:60 Slot:0 Compute:1.2 Driver:2841.5
19:55:02: Win32 Service: true
19:55:02:***********************************************************************
19:55:02:<config>
19:55:02: <!-- Client Control -->
19:55:02: <open-web-control v='true'/>
19:55:02:
19:55:02: <!-- HTTP Server -->
19:55:02: <allow v='127.0.0.1 10.1.1.0/24'/>
19:55:02:
19:55:02: <!-- Network -->
19:55:02: <proxy v=':8080'/>
19:55:02:
19:55:02: <!-- Remote Command Server -->
19:55:02: <command-allow-no-pass v='127.0.0.1 10.1.1.0/24'/>
19:55:02: <password v='********'/>
19:55:02:
19:55:02: <!-- Slot Control -->
19:55:02: <power v='medium'/>
19:55:02:
19:55:02: <!-- User Information -->
19:55:02: <passkey v='********************************'/>
19:55:02: <team v='233223'/>
19:55:02: <user v='dfirons_ALL_12Lhow3NvwYsZL4QFST2TqKdRoDf5v7FQH'/>
19:55:02:
19:55:02: <!-- Work Unit Control -->
19:55:02: <next-unit-percentage v='100'/>
19:55:02:
19:55:02: <!-- Folding Slots -->
19:55:02: <slot id='0' type='CPU'/>
19:55:02:</config>
19:55:02:Trying to access database...
19:55:02:Successfully acquired database lock
19:55:02:Enabled folding slot 00: READY cpu:7
19:55:02:ERROR:Exception: Failed to register systray icon: Unspecified error
19:55:02:WU01:FS00:Starting
19:55:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 7660 -checkpoint 15 -np 7 -service
19:55:02:WU01:FS00:Started FahCore on PID 12004
19:55:04:WU01:FS00:Core PID:13020
19:55:04:WU01:FS00:FahCore 0xa7 started
19:55:05:WU01:FS00:0xa7:*********************** Log Started 2019-10-22T19:55:04Z ***********************
19:55:05:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:55:05:WU01:FS00:0xa7: Type: 0xa7
19:55:05:WU01:FS00:0xa7: Core: Gromacs
19:55:05:WU01:FS00:0xa7: Website: https://foldingathome.org/
19:55:05:WU01:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
19:55:05:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:05:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 12004 -checkpoint 15 -np
19:55:05:WU01:FS00:0xa7: 7 -service
19:55:05:WU01:FS00:0xa7: Config: <none>
19:55:05:WU01:FS00:0xa7:************************************ Build *************************************
19:55:05:WU01:FS00:0xa7: Version: 0.0.17
19:55:05:WU01:FS00:0xa7: Date: Apr 27 2018
19:55:05:WU01:FS00:0xa7: Time: 16:19:36
19:55:05:WU01:FS00:0xa7: Repository: Git
19:55:05:WU01:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
19:55:05:WU01:FS00:0xa7: Branch: master
19:55:05:WU01:FS00:0xa7: Compiler: Visual C++ 2008
19:55:05:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:55:05:WU01:FS00:0xa7: Platform: win32 10
19:55:05:WU01:FS00:0xa7: Bits: 64
19:55:05:WU01:FS00:0xa7: Mode: Release
19:55:05:WU01:FS00:0xa7: SIMD: avx_256
19:55:05:WU01:FS00:0xa7:************************************ System ************************************
19:55:05:WU01:FS00:0xa7: CPU: Unknown
19:55:05:WU01:FS00:0xa7: CPU ID:
19:55:05:WU01:FS00:0xa7: CPUs: 8
19:55:05:WU01:FS00:0xa7: Memory: 15.81GiB
19:55:05:WU01:FS00:0xa7:Free Memory: 13.12GiB
19:55:05:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
19:55:05:WU01:FS00:0xa7: OS Version: 6.2
19:55:05:WU01:FS00:0xa7:Has Battery: true
19:55:05:WU01:FS00:0xa7: On Battery: false
19:55:05:WU01:FS00:0xa7: UTC Offset: 13
19:55:05:WU01:FS00:0xa7: PID: 13020
19:55:05:WU01:FS00:0xa7: CWD: C:\Users\David\AppData\Roaming\FAHClient\work
19:55:05:WU01:FS00:0xa7: OS: Windows 10 Pro
19:55:05:WU01:FS00:0xa7: OS Arch: AMD64
19:55:05:WU01:FS00:0xa7:********************************************************************************
19:55:05:WU01:FS00:0xa7:Project: 13794 (Run 6, Clone 322, Gen 0)
19:55:05:WU01:FS00:0xa7:Unit: 0x000000010002894c5dae0b4728079543
19:55:05:WU01:FS00:0xa7:Digital signatures verified
19:55:05:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
19:55:05:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 6
19:55:05:WU01:FS00:0xa7:Steps: first=0 total=2500000
19:55:06:WU01:FS00:0xa7:Completed 1451032 out of 2500000 steps (58%)
01:02:43:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
01:02:44:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
01:02:44:WU01:FS00:0xa7:Saving result file ener.edr
01:02:44:WU01:FS00:0xa7:Saving result file frame0.trr
01:02:44:WU00:FS00:Connecting to 65.254.110.245:8080
01:02:44:WU01:FS00:0xa7:Saving result file md.log
01:02:44:WU01:FS00:0xa7:Saving result file pullf.xvg
01:02:44:WU01:FS00:0xa7:Saving result file pullx.xvg
01:02:44:WU01:FS00:0xa7:Saving result file science.log
01:02:44:WU01:FS00:0xa7:Saving result file traj_comp.xtc
01:02:44:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:02:44:WU00:FS00:Assigned to work server 155.247.166.219
01:02:44:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 155.247.166.219
01:02:44:WU00:FS00:Connecting to 155.247.166.219:8080
01:02:45:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:02:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:6 clone:322 gen:0 core:0xa7 unit:0x000000010002894c5dae0b4728079543
01:02:45:WU00:FS00:Downloading 6.65MiB
01:02:45:WU01:FS00:Uploading 27.56MiB to 155.247.166.220
01:02:45:WU01:FS00:Connecting to 155.247.166.220:8080
01:02:50:WU00:FS00:Download complete
01:02:51:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14190 run:38 clone:7 gen:11 core:0xa7 unit:0x0000000e0002894b5d5d2bc076337618
01:02:51:WU00:FS00:Starting
01:02:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 7660 -checkpoint 15 -np 7 -service
01:02:51:WU00:FS00:Started FahCore on PID 16316
01:02:51:WU00:FS00:Core PID:13636
01:02:51:WU00:FS00:FahCore 0xa7 started
01:02:51:WU00:FS00:0xa7:*********************** Log Started 2019-10-23T01:02:51Z ***********************
Thanks
David
