Am slowly coming back after my old hard drive died hard almost two weeks ago, after working nearly 24/7 for 6 1/2 years.
Anyway, restarted folding on this and another laptop trying to catch back up. Have had a few possibly related issues since coming back. The laptop although an I-7 is slower than this old desktop, generating about 5K points per day. This one is at least twice that if not more, even with restore running. Yesterday, This desktop finished Project: 14190 (Run 30, Clone 73, Gen 5) October 17th at 06:43:47:WU01:FS00:Final credit estimate, 23231.00 points. Coding from the existent log file is below. So far I have not received the 23231 points.
Also on Oct 17th around 0055Z, I changed my Passkey (while Project 14190 was running). Would this have done something to me not getting credit for the job that was being done via my old Passkey? Do not remember exactly when I changed it, but it would have been in 0100-0300Z timeframe. Also during this time, I had to temporarily suspend folding, as the IDrive client was not working properly and was troubleshooting it with their tech support. After this job finished around 17/0643Z, I did not allow anymore folding (wanted the backup to proceed at a hopefully faster pace). Since it has not really made a difference, I turned the folding client back on around 17/2226Z or 526 PM CDT.
If there is anyway I can get credit for the 20K points, I would greatly appreciate it!!
Robby of Team Pande Lab
*********************** Log Started 2019-10-15T21:13:52Z ***********************
21:13:52:************************* Folding@home Client *************************
21:13:52: Website: https://foldingathome.org/
21:13:52: Copyright: (c) 2009-2018 foldingathome.org
21:13:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:13:52: Args:
21:13:52: Config: C:\Users\bobb1\AppData\Roaming\FAHClient\config.xml
21:13:52:******************************** Build ********************************
21:13:52: Version: 7.5.1
21:13:52: Date: May 11 2018
21:13:52: Time: 13:06:32
21:13:52: Repository: Git
21:13:52: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:13:52: Branch: master
21:13:52: Compiler: Visual C++ 2008
21:13:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:13:52: Platform: win32 10
21:13:52: Bits: 32
21:13:52: Mode: Release
21:13:52:******************************* System ********************************
21:13:52: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
21:13:52: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:13:52: CPUs: 8
21:13:52: Memory: 15.89GiB
21:13:52: Free Memory: 14.27GiB
21:13:52: Threads: WINDOWS_THREADS
21:13:52: OS Version: 6.2
21:13:52: Has Battery: true
21:13:52: On Battery: false
21:13:52: UTC Offset: -5
21:13:52: PID: 4896
21:13:52: CWD: C:\Windows\system32
21:13:52: OS: Windows 10 Home
21:13:52: OS Arch: AMD64
21:13:52: GPUs: 0
21:13:52: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:13:52: specified module could not be found.
21:13:52:
21:13:52:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
21:13:52: Win32 Service: true
21:13:52:***********************************************************************
21:13:52:<config>
21:13:52: <!-- Folding Slot Configuration -->
21:13:52: <cause v='ALZHEIMERS'/>
21:13:52:
21:13:52: <!-- Network -->
21:13:52: <proxy v=':8080'/>
21:13:52:
21:13:52: <!-- Slot Control -->
21:13:52: <power v='medium'/>
21:13:52:
21:13:52: <!-- User Information -->
21:13:52: <passkey v='********************************'/>
21:13:52: <team v='1'/>
21:13:52: <user v='Robby'/>
21:13:52:
21:13:52: <!-- Work Unit Control -->
21:13:52: <next-unit-percentage v='100'/>
21:13:52:
21:13:52: <!-- Folding Slots -->
21:13:52: <slot id='0' type='CPU'>
21:13:52: <paused v='true'/>
21:13:52: </slot>
21:13:52:</config>
21:13:52:Trying to access database...
21:13:52:Successfully acquired database lock
21:13:52:Enabled folding slot 00: PAUSED cpu:7 (by user)
21:13:52:ERROR:Exception: Failed to register systray icon: Unspecified error
21:22:11:FS00:Unpaused
21:22:11:WU00:FS00:Starting
21:22:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4896 -checkpoint 15 -np 7 -service
21:22:11:WU00:FS00:Started FahCore on PID 10868
21:22:12:WU00:FS00:Core PID:988
21:22:12:WU00:FS00:FahCore 0xa7 started
21:22:13:WU00:FS00:0xa7:*********************** Log Started 2019-10-15T21:22:12Z ***********************
21:22:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:22:13:WU00:FS00:0xa7: Type: 0xa7
21:22:13:WU00:FS00:0xa7: Core: Gromacs
21:22:13:WU00:FS00:0xa7: Website: https://foldingathome.org/
21:22:13:WU00:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
21:22:13:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:22:13:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 10868 -checkpoint 15 -np
21:22:13:WU00:FS00:0xa7: 7 -service
21:22:13:WU00:FS00:0xa7: Config: <none>
21:22:13:WU00:FS00:0xa7:************************************ Build *************************************
21:22:13:WU00:FS00:0xa7: Version: 0.0.17
21:22:13:WU00:FS00:0xa7: Date: Apr 27 2018
21:22:13:WU00:FS00:0xa7: Time: 16:19:36
21:22:13:WU00:FS00:0xa7: Repository: Git
21:22:13:WU00:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
21:22:13:WU00:FS00:0xa7: Branch: master
21:22:13:WU00:FS00:0xa7: Compiler: Visual C++ 2008
21:22:13:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:22:13:WU00:FS00:0xa7: Platform: win32 10
21:22:13:WU00:FS00:0xa7: Bits: 64
21:22:13:WU00:FS00:0xa7: Mode: Release
21:22:13:WU00:FS00:0xa7: SIMD: avx_256
21:22:13:WU00:FS00:0xa7:************************************ System ************************************
21:22:13:WU00:FS00:0xa7: CPU: Unknown
21:22:13:WU00:FS00:0xa7: CPU ID:
21:22:13:WU00:FS00:0xa7: CPUs: 8
21:22:13:WU00:FS00:0xa7: Memory: 15.89GiB
21:22:13:WU00:FS00:0xa7:Free Memory: 13.05GiB
21:22:13:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:22:13:WU00:FS00:0xa7: OS Version: 6.2
21:22:13:WU00:FS00:0xa7:Has Battery: true
21:22:13:WU00:FS00:0xa7: On Battery: false
21:22:13:WU00:FS00:0xa7: UTC Offset: -5
21:22:13:WU00:FS00:0xa7: PID: 988
21:22:13:WU00:FS00:0xa7: CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
21:22:13:WU00:FS00:0xa7: OS: Windows 10 Home
21:22:13:WU00:FS00:0xa7: OS Arch: AMD64
21:22:13:WU00:FS00:0xa7:********************************************************************************
21:22:13:WU00:FS00:0xa7:Project: 14190 (Run 30, Clone 73, Gen 5)
21:22:13:WU00:FS00:0xa7:Unit: 0x000000060002894b5d5d2c822f6f5263
21:22:13:WU00:FS00:0xa7:Digital signatures verified
21:22:13:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
21:22:13:WU00:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 6
21:22:14:WU00:FS00:0xa7:Steps: first=6250000 total=1250000
21:22:15:WU00:FS00:0xa7:Completed 134421 out of 1250000 steps (10%)
21:23:01:Saving configuration to config.xml
21:23:01:<config>
21:23:01: <!-- Folding Slot Configuration -->
21:23:01: <cause v='ALZHEIMERS'/>
21:23:01:
21:23:01: <!-- Network -->
21:23:01: <proxy v=':8080'/>
21:23:01:
21:23:01: <!-- Slot Control -->
21:23:01: <power v='medium'/>
21:23:01:
21:23:01: <!-- User Information -->
21:23:01: <passkey v='********************************'/>
21:23:01: <team v='1'/>
21:23:01: <user v='Robby'/>
21:23:01:
21:23:01: <!-- Work Unit Control -->
21:23:01: <next-unit-percentage v='100'/>
21:23:01:
21:23:01: <!-- Folding Slots -->
21:23:01: <slot id='0' type='CPU'/>
21:23:01:</config>
21:25:04:WU00:FS00:0xa7:Completed 137500 out of 1250000 steps (11%)
21:36:20:WU00:FS00:0xa7:Completed 150000 out of 1250000 steps (12%)
21:48:57:WU00:FS00:0xa7:Completed 162500 out of 1250000 steps (13%)
22:01:44:WU00:FS00:0xa7:Completed 175000 out of 1250000 steps (14%)
22:15:06:WU00:FS00:0xa7:Completed 187500 out of 1250000 steps (15%)
22:28:20:WU00:FS00:0xa7:Completed 200000 out of 1250000 steps (16%)
22:41:21:WU00:FS00:0xa7:Completed 212500 out of 1250000 steps (17%)
22:54:23:WU00:FS00:0xa7:Completed 225000 out of 1250000 steps (18%)
23:07:29:WU00:FS00:0xa7:Completed 237500 out of 1250000 steps (19%)
23:21:04:WU00:FS00:0xa7:Completed 250000 out of 1250000 steps (20%)
23:34:12:WU00:FS00:0xa7:Completed 262500 out of 1250000 steps (21%)
23:47:20:WU00:FS00:0xa7:Completed 275000 out of 1250000 steps (22%)
00:00:37:WU00:FS00:0xa7:Completed 287500 out of 1250000 steps (23%)
00:13:34:WU00:FS00:0xa7:Completed 300000 out of 1250000 steps (24%)
00:26:56:WU00:FS00:0xa7:Completed 312500 out of 1250000 steps (25%)
00:40:53:WU00:FS00:0xa7:Completed 325000 out of 1250000 steps (26%)
00:44:35:FS00:Paused
00:44:35:FS00:Shutting core down
00:44:35:WARNING:FS00:FahCore not accepting gentle shutdown, killing
00:44:35:WARNING:FS00:Killing WU00
00:44:35:WU00:FS00:FahCore terminated
00:45:20:Saving configuration to config.xml
00:45:20:<config>
00:45:20: <!-- Folding Slot Configuration -->
00:45:20: <cause v='ALZHEIMERS'/>
00:45:20:
00:45:20: <!-- Network -->
00:45:20: <proxy v=':8080'/>
00:45:20:
00:45:20: <!-- Slot Control -->
00:45:20: <power v='medium'/>
00:45:20:
00:45:20: <!-- User Information -->
00:45:20: <passkey v='********************************'/>
00:45:20: <team v='1'/>
00:45:20: <user v='Robby'/>
00:45:20:
00:45:20: <!-- Work Unit Control -->
00:45:20: <next-unit-percentage v='100'/>
00:45:20:
00:45:20: <!-- Folding Slots -->
00:45:20: <slot id='0' type='CPU'>
00:45:20: <paused v='true'/>
00:45:20: </slot>
00:45:20:</config>
02:28:02:FS00:Unpaused
02:28:02:WU00:FS00:Starting
02:28:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4896 -checkpoint 15 -np 7 -service
02:28:06:WU00:FS00:Started FahCore on PID 13004
02:28:14:WU00:FS00:Core PID:4388
02:28:14:WU00:FS00:FahCore 0xa7 started
02:28:20:WU00:FS00:0xa7:*********************** Log Started 2019-10-16T02:28:19Z ***********************
02:28:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:28:20:WU00:FS00:0xa7: Type: 0xa7
02:28:20:WU00:FS00:0xa7: Core: Gromacs
02:28:20:WU00:FS00:0xa7: Website: https://foldingathome.org/
02:28:20:WU00:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
02:28:20:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:28:20:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 13004 -checkpoint 15 -np
02:28:20:WU00:FS00:0xa7: 7 -service
02:28:20:WU00:FS00:0xa7: Config: <none>
02:28:20:WU00:FS00:0xa7:************************************ Build *************************************
02:28:20:WU00:FS00:0xa7: Version: 0.0.17
02:28:20:WU00:FS00:0xa7: Date: Apr 27 2018
02:28:20:WU00:FS00:0xa7: Time: 16:19:36
02:28:20:WU00:FS00:0xa7: Repository: Git
02:28:20:WU00:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
02:28:20:WU00:FS00:0xa7: Branch: master
02:28:20:WU00:FS00:0xa7: Compiler: Visual C++ 2008
02:28:20:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:28:20:WU00:FS00:0xa7: Platform: win32 10
02:28:20:WU00:FS00:0xa7: Bits: 64
02:28:20:WU00:FS00:0xa7: Mode: Release
02:28:20:WU00:FS00:0xa7: SIMD: avx_256
02:28:20:WU00:FS00:0xa7:************************************ System ************************************
02:28:20:WU00:FS00:0xa7: CPU: Unknown
02:28:20:WU00:FS00:0xa7: CPU ID:
02:28:20:WU00:FS00:0xa7: CPUs: 8
02:28:20:WU00:FS00:0xa7: Memory: 15.89GiB
02:28:20:WU00:FS00:0xa7:Free Memory: 11.86GiB
02:28:20:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
02:28:20:WU00:FS00:0xa7: OS Version: 6.2
02:28:20:WU00:FS00:0xa7:Has Battery: true
02:28:20:WU00:FS00:0xa7: On Battery: false
02:28:20:WU00:FS00:0xa7: UTC Offset: -5
02:28:20:WU00:FS00:0xa7: PID: 4388
02:28:20:WU00:FS00:0xa7: CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
02:28:20:WU00:FS00:0xa7: OS: Windows 10 Home
02:28:20:WU00:FS00:0xa7: OS Arch: AMD64
02:28:20:WU00:FS00:0xa7:********************************************************************************
02:28:21:WU00:FS00:0xa7:Project: 14190 (Run 30, Clone 73, Gen 5)
02:28:21:WU00:FS00:0xa7:Unit: 0x000000060002894b5d5d2c822f6f5263
02:28:21:WU00:FS00:0xa7:Digital signatures verified
02:28:22:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
02:28:22:WU00:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 6
02:28:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:28:55:WU00:FS00:0xa7:Steps: first=6250000 total=1250000
02:29:02:Saving configuration to config.xml
02:29:02:<config>
02:29:02: <!-- Folding Slot Configuration -->
02:29:02: <cause v='ALZHEIMERS'/>
02:29:02:
02:29:02: <!-- Network -->
02:29:02: <proxy v=':8080'/>
02:29:02:
02:29:02: <!-- Slot Control -->
02:29:02: <power v='medium'/>
02:29:02:
02:29:02: <!-- User Information -->
02:29:02: <passkey v='********************************'/>
02:29:02: <team v='1'/>
02:29:02: <user v='Robby'/>
02:29:02:
02:29:02: <!-- Work Unit Control -->
02:29:02: <next-unit-percentage v='100'/>
02:29:02:
02:29:02: <!-- Folding Slots -->
02:29:02: <slot id='0' type='CPU'/>
02:29:02:</config>
02:29:12:WU00:FS00:0xa7:Completed 321701 out of 1250000 steps (25%)
02:34:15:WU00:FS00:0xa7:Completed 325000 out of 1250000 steps (26%)
02:51:49:WU00:FS00:0xa7:Completed 337500 out of 1250000 steps (27%)
03:10:30:WU00:FS00:0xa7:Completed 350000 out of 1250000 steps (28%)
******************************* Date: 2019-10-16 *******************************
03:29:20:WU00:FS00:0xa7:Completed 362500 out of 1250000 steps (29%)
03:44:34:WU00:FS00:0xa7:Completed 375000 out of 1250000 steps (30%)
11:21:31:WU01:FS00:0xa7:Completed 50000 out of 1250000 steps (4%)
11:27:03:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
11:32:50:WU01:FS00:0xa7:Completed 62500 out of 1250000 steps (5%)
11:43:38:WU01:FS00:0xa7:Completed 75000 out of 1250000 steps (6%)
11:54:30:WU01:FS00:0xa7:Completed 87500 out of 1250000 steps (7%)
12:05:47:WU01:FS00:0xa7:Completed 100000 out of 1250000 steps (8%)
12:17:29:WU01:FS00:0xa7:Completed 112500 out of 1250000 steps (9%)
12:28:35:WU01:FS00:0xa7:Completed 125000 out of 1250000 steps (10%)
12:40:00:WU01:FS00:0xa7:Completed 137500 out of 1250000 steps (11%)
12:51:04:WU01:FS00:0xa7:Completed 150000 out of 1250000 steps (12%)
13:02:26:WU01:FS00:0xa7:Completed 162500 out of 1250000 steps (13%)
13:14:07:WU01:FS00:0xa7:Completed 175000 out of 1250000 steps (14%)
13:26:13:WU01:FS00:0xa7:Completed 187500 out of 1250000 steps (15%)
13:37:28:WU01:FS00:0xa7:Completed 200000 out of 1250000 steps (16%)
13:49:17:WU01:FS00:0xa7:Completed 212500 out of 1250000 steps (17%)
14:00:13:WU01:FS00:0xa7:Completed 225000 out of 1250000 steps (18%)
14:11:37:WU01:FS00:0xa7:Completed 237500 out of 1250000 steps (19%)
14:22:31:WU01:FS00:0xa7:Completed 250000 out of 1250000 steps (20%)
14:33:24:WU01:FS00:0xa7:Completed 262500 out of 1250000 steps (21%)
14:44:18:WU01:FS00:0xa7:Completed 275000 out of 1250000 steps (22%)
14:55:18:WU01:FS00:0xa7:Completed 287500 out of 1250000 steps (23%)
15:06:19:WU01:FS00:0xa7:Completed 300000 out of 1250000 steps (24%)
15:17:28:WU01:FS00:0xa7:Completed 312500 out of 1250000 steps (25%)
15:28:40:WU01:FS00:0xa7:Completed 325000 out of 1250000 steps (26%)
15:39:45:WU01:FS00:0xa7:Completed 337500 out of 1250000 steps (27%)
15:50:49:WU01:FS00:0xa7:Completed 350000 out of 1250000 steps (28%)
16:01:57:WU01:FS00:0xa7:Completed 362500 out of 1250000 steps (29%)
16:13:31:WU01:FS00:0xa7:Completed 375000 out of 1250000 steps (30%)
16:24:34:WU01:FS00:0xa7:Completed 387500 out of 1250000 steps (31%)
16:35:32:WU01:FS00:0xa7:Completed 400000 out of 1250000 steps (32%)
16:46:32:WU01:FS00:0xa7:Completed 412500 out of 1250000 steps (33%)
16:57:32:WU01:FS00:0xa7:Completed 425000 out of 1250000 steps (34%)
17:08:33:WU01:FS00:0xa7:Completed 437500 out of 1250000 steps (35%)
17:19:34:WU01:FS00:0xa7:Completed 450000 out of 1250000 steps (36%)
17:30:36:WU01:FS00:0xa7:Completed 462500 out of 1250000 steps (37%)
17:41:44:WU01:FS00:0xa7:Completed 475000 out of 1250000 steps (38%)
17:52:50:WU01:FS00:0xa7:Completed 487500 out of 1250000 steps (39%)
18:03:51:WU01:FS00:0xa7:Completed 500000 out of 1250000 steps (40%)
18:14:54:WU01:FS00:0xa7:Completed 512500 out of 1250000 steps (41%)
18:25:59:WU01:FS00:0xa7:Completed 525000 out of 1250000 steps (42%)
18:37:06:WU01:FS00:0xa7:Completed 537500 out of 1250000 steps (43%)
18:48:10:WU01:FS00:0xa7:Completed 550000 out of 1250000 steps (44%)
18:59:15:WU01:FS00:0xa7:Completed 562500 out of 1250000 steps (45%)
19:10:20:WU01:FS00:0xa7:Completed 575000 out of 1250000 steps (46%)
19:21:24:WU01:FS00:0xa7:Completed 587500 out of 1250000 steps (47%)
19:32:31:WU01:FS00:0xa7:Completed 600000 out of 1250000 steps (48%)
19:43:50:WU01:FS00:0xa7:Completed 612500 out of 1250000 steps (49%)
19:55:10:WU01:FS00:0xa7:Completed 625000 out of 1250000 steps (50%)
20:06:41:WU01:FS00:0xa7:Completed 637500 out of 1250000 steps (51%)
20:18:02:WU01:FS00:0xa7:Completed 650000 out of 1250000 steps (52%)
20:29:28:WU01:FS00:0xa7:Completed 662500 out of 1250000 steps (53%)
20:41:02:WU01:FS00:0xa7:Completed 675000 out of 1250000 steps (54%)
20:52:27:WU01:FS00:0xa7:Completed 687500 out of 1250000 steps (55%)
21:03:54:WU01:FS00:0xa7:Completed 700000 out of 1250000 steps (56%)
21:15:15:WU01:FS00:0xa7:Completed 712500 out of 1250000 steps (57%)
21:26:37:WU01:FS00:0xa7:Completed 725000 out of 1250000 steps (58%)
21:38:16:WU01:FS00:0xa7:Completed 737500 out of 1250000 steps (59%)
21:49:52:WU01:FS00:0xa7:Completed 750000 out of 1250000 steps (60%)
22:01:33:WU01:FS00:0xa7:Completed 762500 out of 1250000 steps (61%)
22:13:17:WU01:FS00:0xa7:Completed 775000 out of 1250000 steps (62%)
22:25:14:WU01:FS00:0xa7:Completed 787500 out of 1250000 steps (63%)
22:36:42:WU01:FS00:0xa7:Completed 800000 out of 1250000 steps (64%)
22:47:52:WU01:FS00:0xa7:Completed 812500 out of 1250000 steps (65%)
22:58:59:WU01:FS00:0xa7:Completed 825000 out of 1250000 steps (66%)
23:10:20:WU01:FS00:0xa7:Completed 837500 out of 1250000 steps (67%)
23:21:21:WU01:FS00:0xa7:Completed 850000 out of 1250000 steps (68%)
23:32:55:WU01:FS00:0xa7:Completed 862500 out of 1250000 steps (69%)
23:43:57:WU01:FS00:0xa7:Completed 875000 out of 1250000 steps (70%)
23:55:21:WU01:FS00:0xa7:Completed 887500 out of 1250000 steps (71%)
00:06:28:WU01:FS00:0xa7:Completed 900000 out of 1250000 steps (72%)
00:10:37:Saving configuration to config.xml
00:10:37:<config>
00:10:37: <!-- Folding Slot Configuration -->
00:10:37: <cause v='ALZHEIMERS'/>
00:10:37:
00:10:37: <!-- Network -->
00:10:37: <proxy v=':8080'/>
00:10:37:
00:10:37: <!-- Slot Control -->
00:10:37: <power v='medium'/>
00:10:37:
00:10:37: <!-- User Information -->
00:10:37: <passkey v='********************************'/>
00:10:37: <team v='1'/>
00:10:37: <user v='Robby'/>
00:10:37:
00:10:37: <!-- Work Unit Control -->
00:10:37: <next-unit-percentage v='100'/>
00:10:37:
00:10:37: <!-- Folding Slots -->
00:10:37: <slot id='0' type='CPU'/>
00:10:37:</config>
00:10:40:Saving configuration to config.xml
00:10:40:<config>
00:10:40: <!-- Folding Slot Configuration -->
00:10:40: <cause v='ALZHEIMERS'/>
00:10:40:
00:10:40: <!-- Network -->
00:10:40: <proxy v=':8080'/>
00:10:40:
00:10:40: <!-- Slot Control -->
00:10:40: <power v='medium'/>
00:10:40:
00:10:40: <!-- User Information -->
00:10:40: <passkey v='********************************'/>
00:10:40: <team v='1'/>
00:10:40: <user v='Robby'/>
00:10:40:
00:10:40: <!-- Work Unit Control -->
00:10:40: <next-unit-percentage v='100'/>
00:10:40:
00:10:40: <!-- Folding Slots -->
00:10:40: <slot id='0' type='CPU'/>
00:10:40:</config>
00:18:26:WU01:FS00:0xa7:Completed 912500 out of 1250000 steps (73%)
00:29:22:WU01:FS00:0xa7:Completed 925000 out of 1250000 steps (74%)
00:40:16:WU01:FS00:0xa7:Completed 937500 out of 1250000 steps (75%)
00:51:10:WU01:FS00:0xa7:Completed 950000 out of 1250000 steps (76%)
01:02:00:WU01:FS00:0xa7:Completed 962500 out of 1250000 steps (77%)
01:13:01:WU01:FS00:0xa7:Completed 975000 out of 1250000 steps (78%)
01:24:02:WU01:FS00:0xa7:Completed 987500 out of 1250000 steps (79%)
01:35:07:WU01:FS00:0xa7:Completed 1000000 out of 1250000 steps (80%)
01:43:53:FS00:Paused
01:43:53:FS00:Shutting core down
01:43:53:WARNING:FS00:FahCore not accepting gentle shutdown, killing
01:43:53:WARNING:FS00:Killing WU01
01:43:53:WU01:FS00:FahCore terminated
01:44:00:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:44:12:Saving configuration to config.xml
01:44:12:<config>
01:44:12: <!-- Folding Slot Configuration -->
01:44:12: <cause v='ALZHEIMERS'/>
01:44:12:
01:44:12: <!-- Network -->
01:44:12: <proxy v=':8080'/>
01:44:12:
01:44:12: <!-- Slot Control -->
01:44:12: <power v='medium'/>
01:44:12:
01:44:12: <!-- User Information -->
01:44:12: <passkey v='********************************'/>
01:44:12: <team v='1'/>
01:44:12: <user v='Robby'/>
01:44:12:
01:44:12: <!-- Work Unit Control -->
01:44:12: <next-unit-percentage v='100'/>
01:44:12:
01:44:12: <!-- Folding Slots -->
01:44:12: <slot id='0' type='CPU'>
01:44:12: <paused v='true'/>
01:44:12: </slot>
01:44:12:</config>
02:39:25:FS00:Unpaused
02:39:25:WU01:FS00:Starting
02:39:25:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4896 -checkpoint 15 -np 7 -service
02:39:26:WU01:FS00:Started FahCore on PID 13328
02:39:26:WU01:FS00:Core PID:10304
02:39:26:WU01:FS00:FahCore 0xa7 started
02:39:27:WU01:FS00:0xa7:*********************** Log Started 2019-10-17T02:39:27Z ***********************
02:39:27:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:39:27:WU01:FS00:0xa7: Type: 0xa7
02:39:27:WU01:FS00:0xa7: Core: Gromacs
02:39:27:WU01:FS00:0xa7: Website: https://foldingathome.org/
02:39:27:WU01:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
02:39:27:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:39:27:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 13328 -checkpoint 15 -np
02:39:27:WU01:FS00:0xa7: 7 -service
02:39:27:WU01:FS00:0xa7: Config: <none>
02:39:27:WU01:FS00:0xa7:************************************ Build *************************************
02:39:27:WU01:FS00:0xa7: Version: 0.0.17
02:39:27:WU01:FS00:0xa7: Date: Apr 27 2018
02:39:27:WU01:FS00:0xa7: Time: 16:19:36
02:39:27:WU01:FS00:0xa7: Repository: Git
02:39:27:WU01:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
02:39:27:WU01:FS00:0xa7: Branch: master
02:39:27:WU01:FS00:0xa7: Compiler: Visual C++ 2008
02:39:27:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:39:27:WU01:FS00:0xa7: Platform: win32 10
02:39:27:WU01:FS00:0xa7: Bits: 64
02:39:27:WU01:FS00:0xa7: Mode: Release
02:39:27:WU01:FS00:0xa7: SIMD: avx_256
02:39:27:WU01:FS00:0xa7:************************************ System ************************************
02:39:27:WU01:FS00:0xa7: CPU: Unknown
02:39:27:WU01:FS00:0xa7: CPU ID:
02:39:27:WU01:FS00:0xa7: CPUs: 8
02:39:27:WU01:FS00:0xa7: Memory: 15.89GiB
02:39:27:WU01:FS00:0xa7:Free Memory: 10.42GiB
02:39:27:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
02:39:27:WU01:FS00:0xa7: OS Version: 6.2
02:39:27:WU01:FS00:0xa7:Has Battery: true
02:39:27:WU01:FS00:0xa7: On Battery: false
02:39:27:WU01:FS00:0xa7: UTC Offset: -5
02:39:27:WU01:FS00:0xa7: PID: 10304
02:39:27:WU01:FS00:0xa7: CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
02:39:27:WU01:FS00:0xa7: OS: Windows 10 Home
02:39:27:WU01:FS00:0xa7: OS Arch: AMD64
02:39:27:WU01:FS00:0xa7:********************************************************************************
02:39:27:WU01:FS00:0xa7:Project: 14188 (Run 6, Clone 962, Gen 0)
02:39:27:WU01:FS00:0xa7:Unit: 0x000000000002894b5d77e4b3b74cbff4
02:39:27:WU01:FS00:0xa7:Digital signatures verified
02:39:27:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
02:39:27:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 6
02:39:28:WU01:FS00:0xa7:Steps: first=0 total=1250000
02:39:30:WU01:FS00:0xa7:Completed 997961 out of 1250000 steps (79%)
02:39:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:40:07:Saving configuration to config.xml
02:40:07:<config>
02:40:07: <!-- Folding Slot Configuration -->
02:40:07: <cause v='ALZHEIMERS'/>
02:40:07:
02:40:07: <!-- Network -->
02:40:07: <proxy v=':8080'/>
02:40:07:
02:40:07: <!-- Slot Control -->
02:40:07: <power v='medium'/>
02:40:07:
02:40:07: <!-- User Information -->
02:40:07: <passkey v='********************************'/>
02:40:07: <team v='1'/>
02:40:07: <user v='Robby'/>
02:40:07:
02:40:07: <!-- Work Unit Control -->
02:40:07: <next-unit-percentage v='100'/>
02:40:07:
02:40:07: <!-- Folding Slots -->
02:40:07: <slot id='0' type='CPU'/>
02:40:07:</config>
02:40:53:FS00:Finishing
02:41:44:WU01:FS00:0xa7:Completed 1000000 out of 1250000 steps (80%)
02:55:16:WU01:FS00:0xa7:Completed 1012500 out of 1250000 steps (81%)
03:07:19:WU01:FS00:0xa7:Completed 1025000 out of 1250000 steps (82%)
03:18:55:WU01:FS00:0xa7:Completed 1037500 out of 1250000 steps (83%)
03:30:32:WU01:FS00:0xa7:Completed 1050000 out of 1250000 steps (84%)
03:42:20:WU01:FS00:0xa7:Completed 1062500 out of 1250000 steps (85%)
******************************* Date: 2019-10-17 *******************************
03:55:26:WU01:FS00:0xa7:Completed 1075000 out of 1250000 steps (86%)
04:07:01:WU01:FS00:0xa7:Completed 1087500 out of 1250000 steps (87%)
04:18:39:WU01:FS00:0xa7:Completed 1100000 out of 1250000 steps (88%)
04:30:16:WU01:FS00:0xa7:Completed 1112500 out of 1250000 steps (89%)
04:41:55:WU01:FS00:0xa7:Completed 1125000 out of 1250000 steps (90%)
04:55:26:WU01:FS00:0xa7:Completed 1137500 out of 1250000 steps (91%)
05:08:21:WU01:FS00:0xa7:Completed 1150000 out of 1250000 steps (92%)
05:20:35:WU01:FS00:0xa7:Completed 1162500 out of 1250000 steps (93%)
05:32:41:WU01:FS00:0xa7:Completed 1175000 out of 1250000 steps (94%)
05:44:21:WU01:FS00:0xa7:Completed 1187500 out of 1250000 steps (95%)
05:56:00:WU01:FS00:0xa7:Completed 1200000 out of 1250000 steps (96%)
06:07:55:WU01:FS00:0xa7:Completed 1212500 out of 1250000 steps (97%)
06:19:31:WU01:FS00:0xa7:Completed 1225000 out of 1250000 steps (98%)
06:31:20:WU01:FS00:0xa7:Completed 1237500 out of 1250000 steps (99%)
06:43:37:WU01:FS00:0xa7:Completed 1250000 out of 1250000 steps (100%)
06:43:41:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
06:43:41:WU01:FS00:0xa7:Saving result file frame0.trr
06:43:42:WU01:FS00:0xa7:Saving result file md.log
06:43:42:WU01:FS00:0xa7:Saving result file science.log
06:43:42:WU01:FS00:0xa7:Saving result file traj_comp.xtc
06:43:42:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
06:43:43:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:43:43:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14188 run:6 clone:962 gen:0 core:0xa7 unit:0x000000000002894b5d77e4b3b74cbff4
06:43:43:WU01:FS00:Uploading 15.67MiB to 155.247.166.219
06:43:43:WU01:FS00:Connecting to 155.247.166.219:8080
06:43:47:WU01:FS00:Upload complete
06:43:47:WU01:FS00:Server responded WORK_ACK (400)
[b][color=#BF0000]06:43:47:WU01:FS00:Final credit estimate, 23231.00 points[/color][/b]
06:43:48:WU01:FS00:Cleaning up
22:26:00:WU00:FS00:Connecting to 65.254.110.245:8080
22:26:00:WU00:FS00:Assigned to work server 155.247.166.219
22:26:00:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.166.219
22:26:00:WU00:FS00:Connecting to 155.247.166.219:8080
22:26:01:ERROR:WU00:FS00:Exception: Server did not assign work unit
22:26:01:WU00:FS00:Connecting to 65.254.110.245:8080
22:26:01:WU00:FS00:Assigned to work server 128.252.203.10
22:26:01:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.10
22:26:01:WU00:FS00:Connecting to 128.252.203.10:8080
22:26:02:WU00:FS00:Downloading 1.24MiB
22:26:02:WU00:FS00:Download complete
22:26:02:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14245 run:0 clone:63 gen:20 core:0xa7 unit:0x0000001a80fccb0a5d6fe0b5e8e32e79
22:26:03:WU00:FS00:Starting
22:26:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4896 -checkpoint 15 -np 3 -service
22:26:04:WU00:FS00:Started FahCore on PID 4976
22:26:04:WU00:FS00:Core PID:9016
22:26:04:WU00:FS00:FahCore 0xa7 started
22:26:05:WU00:FS00:0xa7:*********************** Log Started 2019-10-17T22:26:05Z ***********************
22:26:05:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:26:05:WU00:FS00:0xa7: Type: 0xa7
22:26:05:WU00:FS00:0xa7: Core: Gromacs
22:26:05:WU00:FS00:0xa7: Website: https://foldingathome.org/
22:26:05:WU00:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
22:26:05:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:26:05:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 4976 -checkpoint 15 -np 3
22:26:05:WU00:FS00:0xa7: -service
22:26:05:WU00:FS00:0xa7: Config: <none>
22:26:05:WU00:FS00:0xa7:************************************ Build *************************************
22:26:05:WU00:FS00:0xa7: Version: 0.0.17
22:26:05:WU00:FS00:0xa7: Date: Apr 27 2018
22:26:05:WU00:FS00:0xa7: Time: 16:19:36
22:26:05:WU00:FS00:0xa7: Repository: Git
22:26:05:WU00:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
22:26:05:WU00:FS00:0xa7: Branch: master
22:26:05:WU00:FS00:0xa7: Compiler: Visual C++ 2008
22:26:05:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:26:05:WU00:FS00:0xa7: Platform: win32 10
22:26:05:WU00:FS00:0xa7: Bits: 64
22:26:05:WU00:FS00:0xa7: Mode: Release
22:26:05:WU00:FS00:0xa7: SIMD: avx_256
22:26:05:WU00:FS00:0xa7:************************************ System ************************************
22:26:05:WU00:FS00:0xa7: CPU: Unknown
22:26:05:WU00:FS00:0xa7: CPU ID:
22:26:05:WU00:FS00:0xa7: CPUs: 8
22:26:05:WU00:FS00:0xa7: Memory: 15.89GiB
22:26:05:WU00:FS00:0xa7:Free Memory: 10.69GiB
22:26:05:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
22:26:05:WU00:FS00:0xa7: OS Version: 6.2
22:26:05:WU00:FS00:0xa7:Has Battery: true
22:26:05:WU00:FS00:0xa7: On Battery: false
22:26:05:WU00:FS00:0xa7: UTC Offset: -5
22:26:05:WU00:FS00:0xa7: PID: 9016
22:26:05:WU00:FS00:0xa7: CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
22:26:05:WU00:FS00:0xa7: OS: Windows 10 Home
22:26:05:WU00:FS00:0xa7: OS Arch: AMD64
22:26:05:WU00:FS00:0xa7:********************************************************************************
22:26:05:WU00:FS00:0xa7:Project: 14245 (Run 0, Clone 63, Gen 20)
22:26:05:WU00:FS00:0xa7:Unit: 0x0000001a80fccb0a5d6fe0b5e8e32e79
22:26:05:WU00:FS00:0xa7:Reading tar file core.xml
22:26:05:WU00:FS00:0xa7:Reading tar file frame20.tpr
22:26:05:WU00:FS00:0xa7:Digital signatures verified
22:26:05:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 3
22:26:05:WU00:FS00:0xa7:Steps: first=5000000 total=250000
22:26:06:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
22:26:34:Saving configuration to config.xml
22:26:34:<config>
22:26:34: <!-- Folding Slot Configuration -->
22:26:34: <cause v='ALZHEIMERS'/>
22:26:34:
22:26:34: <!-- Network -->
22:26:34: <proxy v=':8080'/>
22:26:34:
22:26:34: <!-- User Information -->
22:26:34: <passkey v='********************************'/>
22:26:34: <team v='1'/>
22:26:34: <user v='Robby'/>
22:26:34:
22:26:34: <!-- Work Unit Control -->
22:26:34: <next-unit-percentage v='100'/>
22:26:34:
22:26:34: <!-- Folding Slots -->
22:26:34: <slot id='0' type='CPU'/>
22:26:34:</config>
22:27:10:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
22:28:14:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
22:29:20:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
22:30:30:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
22:31:40:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
22:32:51:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
22:34:01:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
22:35:13:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
22:36:25:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
22:37:28:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
22:38:32:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
22:39:37:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
22:40:41:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
22:41:44:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
22:42:49:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
22:43:50:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
22:44:51:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
22:45:51:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
22:46:50:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
22:47:52:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
22:48:57:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
22:49:59:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
22:51:01:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
22:52:02:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
22:53:05:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
22:54:06:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
22:55:10:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
22:56:14:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
22:57:18:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
22:58:21:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
22:59:25:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
23:00:28:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
23:01:32:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
23:02:36:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
23:03:36:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
23:04:39:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
23:05:40:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
23:06:41:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
23:07:42:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
23:08:43:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
23:09:45:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
23:10:46:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
23:11:47:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
23:12:46:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
23:13:46:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
23:14:46:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
23:15:45:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
23:16:46:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
23:17:46:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
23:18:48:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
23:19:48:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
23:20:50:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
23:21:52:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
23:22:54:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
23:23:56:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
23:25:03:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
23:26:09:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
23:27:16:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
23:28:22:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
23:29:26:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
23:30:29:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
23:31:32:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
23:32:34:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
23:33:34:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
23:34:37:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
23:35:42:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
23:36:46:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
23:37:47:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
23:38:48:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
23:39:48:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
23:40:50:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
23:41:53:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
23:42:58:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
23:43:59:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
23:45:00:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
23:46:01:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
23:47:04:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
23:48:07:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
23:49:09:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
23:50:13:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
23:51:20:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
23:52:22:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
23:53:23:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
23:54:29:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
23:55:34:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
23:56:39:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
23:57:42:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
23:58:47:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
23:59:52:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
00:00:56:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
00:02:00:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
00:03:02:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
00:04:05:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
00:05:08:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
00:06:11:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
00:07:14:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
00:08:18:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
00:09:23:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
00:10:28:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
00:11:31:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
00:11:33:WU01:FS00:Connecting to 65.254.110.245:8080
00:11:34:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
00:11:34:WU00:FS00:0xa7:Saving result file frame20.trr
00:11:34:WU00:FS00:0xa7:Saving result file frame20.xtc
00:11:34:WU00:FS00:0xa7:Saving result file md.log
00:11:34:WU00:FS00:0xa7:Saving result file science.log
00:11:34:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
00:11:34:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:11:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14245 run:0 clone:63 gen:20 core:0xa7 unit:0x0000001a80fccb0a5d6fe0b5e8e32e79
00:11:34:WU00:FS00:Uploading 1.53MiB to 128.252.203.10
00:11:34:WU00:FS00:Connecting to 128.252.203.10:8080
00:11:34:WU01:FS00:Assigned to work server 155.247.166.219
00:11:34:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.166.219
00:11:34:WU01:FS00:Connecting to 155.247.166.219:8080
00:11:35:WU00:FS00:Upload complete
00:11:35:ERROR:WU01:FS00:Exception: Server did not assign work unit
00:11:36:WU01:FS00:Connecting to 65.254.110.245:8080
00:11:36:WU00:FS00:Server responded WORK_ACK (400)
00:11:36:WU00:FS00:Final credit estimate, 1404.00 points
00:11:36:WU00:FS00:Cleaning up
00:11:37:WU01:FS00:Assigned to work server 155.247.166.219
00:11:37:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.166.219
00:11:37:WU01:FS00:Connecting to 155.247.166.219:8080
00:11:38:WU01:FS00:Downloading 1.83MiB
00:11:39:WU01:FS00:Download complete
00:11:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14183 run:0 clone:110 gen:7 core:0xa7 unit:0x000000090002894b5cf93620086210a1
00:11:40:WU01:FS00:Starting
00:11:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4896 -checkpoint 15 -np 3 -service
00:11:40:WU01:FS00:Started FahCore on PID 2728
00:11:41:WU01:FS00:Core PID:2452
00:11:41:WU01:FS00:FahCore 0xa7 started
00:11:42:WU01:FS00:0xa7:*********************** Log Started 2019-10-18T00:11:41Z ***********************
00:11:42:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:11:42:WU01:FS00:0xa7: Type: 0xa7
00:11:42:WU01:FS00:0xa7: Core: Gromacs
00:11:42:WU01:FS00:0xa7: Website: https://foldingathome.org/
00:11:42:WU01:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
00:11:42:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:11:42:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 2728 -checkpoint 15 -np 3
00:11:42:WU01:FS00:0xa7: -service
00:11:42:WU01:FS00:0xa7: Config: <none>
00:11:42:WU01:FS00:0xa7:************************************ Build *************************************
00:11:42:WU01:FS00:0xa7: Version: 0.0.17
00:11:42:WU01:FS00:0xa7: Date: Apr 27 2018
00:11:42:WU01:FS00:0xa7: Time: 16:19:36
00:11:42:WU01:FS00:0xa7: Repository: Git
00:11:42:WU01:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:11:42:WU01:FS00:0xa7: Branch: master
00:11:42:WU01:FS00:0xa7: Compiler: Visual C++ 2008
00:11:42:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:11:42:WU01:FS00:0xa7: Platform: win32 10
00:11:42:WU01:FS00:0xa7: Bits: 64
00:11:42:WU01:FS00:0xa7: Mode: Release
00:11:42:WU01:FS00:0xa7: SIMD: avx_256
00:11:42:WU01:FS00:0xa7:************************************ System ************************************
00:11:42:WU01:FS00:0xa7: CPU: Unknown
00:11:42:WU01:FS00:0xa7: CPU ID:
00:11:42:WU01:FS00:0xa7: CPUs: 8
00:11:42:WU01:FS00:0xa7: Memory: 15.89GiB
00:11:42:WU01:FS00:0xa7:Free Memory: 10.73GiB
00:11:42:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
00:11:42:WU01:FS00:0xa7: OS Version: 6.2
00:11:42:WU01:FS00:0xa7:Has Battery: true
00:11:42:WU01:FS00:0xa7: On Battery: false
00:11:42:WU01:FS00:0xa7: UTC Offset: -5
00:11:42:WU01:FS00:0xa7: PID: 2452
00:11:42:WU01:FS00:0xa7: CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
00:11:42:WU01:FS00:0xa7: OS: Windows 10 Home
00:11:42:WU01:FS00:0xa7: OS Arch: AMD64
00:11:42:WU01:FS00:0xa7:********************************************************************************
00:11:42:WU01:FS00:0xa7:Project: 14183 (Run 0, Clone 110, Gen 7)
00:11:42:WU01:FS00:0xa7:Unit: 0x000000090002894b5cf93620086210a1
00:11:42:WU01:FS00:0xa7:Reading tar file core.xml
00:11:42:WU01:FS00:0xa7:Reading tar file frame7.tpr
00:11:42:WU01:FS00:0xa7:Digital signatures verified
00:11:42:WU01:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpt 15 -nt 3
00:11:42:WU01:FS00:0xa7:Steps: first=17500000 total=2500000
00:11:43:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
00:21:11:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
00:30:41:WU01:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
