No WUs available / Could not get an assignment
parkut
Post by parkut »
I supervise several Ubuntu Linux 18.04.03 LTS machines, most are CPU only, a very few are GPU machines
For some time now, I have been observing difficulty in receiving work units. I can reach the assignment
servers and get the FAH logo on my web browser. Rebooting the machine does not seem to help.
Some times it resolves itself, other times, it can be days on end. I have not seen any mention of
server issues in this forum. Sometimes identical machines sitting next to each other, one will get
work, the other sits idle.
I can see the client retrying to get work. The GPU machines will get work assigned to the GPU but
not the CPU.
Any advice on what am I might be missing?
13:03:26:WU01:FS00:0xa7:*********************** Log Started 2019-10-11T13:03:26Z ***********************
13:03:26:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:03:26:WU01:FS00:0xa7:       Type: 0xa7
13:03:26:WU01:FS00:0xa7:       Core: Gromacs
13:03:26:WU01:FS00:0xa7:    Website: https://foldingathome.org/
13:03:26:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
13:03:26:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:03:26:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2836 -checkpoint 15 -np 8
13:03:26:WU01:FS00:0xa7:     Config: <none>
13:03:26:WU01:FS00:0xa7:************************************ Build *************************************
13:03:26:WU01:FS00:0xa7:    Version: 0.0.17
13:03:26:WU01:FS00:0xa7:       Date: Apr 27 2018
13:03:26:WU01:FS00:0xa7:       Time: 19:09:21
13:03:26:WU01:FS00:0xa7: Repository: Git
13:03:26:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
13:03:26:WU01:FS00:0xa7:     Branch: master
13:03:26:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
13:03:26:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
13:03:26:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
13:03:26:WU01:FS00:0xa7:       Bits: 64
13:03:26:WU01:FS00:0xa7:       Mode: Release
13:03:26:WU01:FS00:0xa7:       SIMD: avx_256
13:03:26:WU01:FS00:0xa7:************************************ System ************************************
13:03:26:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
13:03:26:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:03:26:WU01:FS00:0xa7:       CPUs: 8
13:03:26:WU01:FS00:0xa7:     Memory: 7.77GiB
13:03:26:WU01:FS00:0xa7:Free Memory: 6.91GiB
13:03:26:WU01:FS00:0xa7:    Threads: POSIX_THREADS
13:03:26:WU01:FS00:0xa7: OS Version: 4.15
13:03:26:WU01:FS00:0xa7:Has Battery: false
13:03:26:WU01:FS00:0xa7: On Battery: false
13:03:26:WU01:FS00:0xa7: UTC Offset: -4
13:03:26:WU01:FS00:0xa7:        PID: 2840
13:03:26:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
13:03:26:WU01:FS00:0xa7:         OS: Linux 4.15.0-65-generic x86_64
13:03:26:WU01:FS00:0xa7:    OS Arch: AMD64
13:03:26:WU01:FS00:0xa7:********************************************************************************
20:32:37:WU01:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
20:37:14:WU01:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
20:41:50:WU01:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
20:41:51:WU00:FS00:Connecting to 65.254.110.245:8080
20:41:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:41:51:WU00:FS00:Connecting to 18.218.241.186:80
20:41:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:41:52:ERROR:WU00:FS00:Exception: Could not get an assignment
20:41:52:WU00:FS00:Connecting to 65.254.110.245:8080
20:41:52:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:41:52:WU00:FS00:Connecting to 18.218.241.186:80
20:42:52:WU00:FS00:Connecting to 65.254.110.245:8080
20:42:52:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:42:52:WU00:FS00:Connecting to 18.218.241.186:80
20:42:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:42:52:ERROR:WU00:FS00:Exception: Could not get an assignment
20:44:29:WU00:FS00:Connecting to 65.254.110.245:8080
20:44:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:44:29:WU00:FS00:Connecting to 18.218.241.186:80
20:44:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:44:30:ERROR:WU00:FS00:Exception: Could not get an assignment
20:46:27:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
20:46:28:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
20:46:28:WU01:FS00:0xa7:Saving result file frame75.trr
20:46:28:WU01:FS00:0xa7:Saving result file md.log
20:46:28:WU01:FS00:0xa7:Saving result file science.log
20:46:28:WU01:FS00:0xa7:Saving result file traj_comp.xtc
20:46:28:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:46:28:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:46:28:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14181 run:22 clone:3 gen:75 core:0xa7 unit:0x000000560002894c5d3706438abd6ae2
20:46:28:WU01:FS00:Uploading 5.19MiB to 155.247.166.220
20:46:28:WU01:FS00:Connecting to 155.247.166.220:8080
20:46:34:WU01:FS00:Upload 63.89%
20:46:38:WU01:FS00:Upload complete
20:46:38:WU01:FS00:Server responded WORK_ACK (400)
20:46:38:WU01:FS00:Final credit estimate, 12919.00 points
20:46:38:WU01:FS00:Cleaning up
20:47:07:WU00:FS00:Connecting to 65.254.110.245:8080
20:47:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:07:WU00:FS00:Connecting to 18.218.241.186:80
20:47:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:47:07:ERROR:WU00:FS00:Exception: Could not get an assignment
20:51:21:WU00:FS00:Connecting to 65.254.110.245:8080
20:51:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:51:21:WU00:FS00:Connecting to 18.218.241.186:80
20:51:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:51:21:ERROR:WU00:FS00:Exception: Could not get an assignment
20:58:12:WU00:FS00:Connecting to 65.254.110.245:8080
20:58:13:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:58:13:WU00:FS00:Connecting to 18.218.241.186:80
20:58:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:58:13:ERROR:WU00:FS00:Exception: Could not get an assignment
21:09:18:WU00:FS00:Connecting to 65.254.110.245:8080
21:09:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:09:18:WU00:FS00:Connecting to 18.218.241.186:80
21:09:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:09:18:ERROR:WU00:FS00:Exception: Could not get an assignment
21:27:15:WU00:FS00:Connecting to 65.254.110.245:8080
21:27:15:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:27:15:WU00:FS00:Connecting to 18.218.241.186:80
21:27:15:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:27:15:ERROR:WU00:FS00:Exception: Could not get an assignment
21:56:17:WU00:FS00:Connecting to 65.254.110.245:8080
21:56:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:56:17:WU00:FS00:Connecting to 18.218.241.186:80
21:56:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:56:17:ERROR:WU00:FS00:Exception: Could not get an assignment
22:43:16:WU00:FS00:Connecting to 65.254.110.245:8080
22:43:16:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:43:16:WU00:FS00:Connecting to 18.218.241.186:80
22:43:16:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:43:16:ERROR:WU00:FS00:Exception: Could not get an assignment
23:59:17:WU00:FS00:Connecting to 65.254.110.245:8080
23:59:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:59:17:WU00:FS00:Connecting to 18.218.241.186:80
23:59:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:59:17:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2019-10-12 *******************************
02:02:16:WU00:FS00:Connecting to 65.254.110.245:8080
02:02:16:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:02:16:WU00:FS00:Connecting to 18.218.241.186:80
02:02:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:02:17:ERROR:WU00:FS00:Exception: Could not get an assignment
05:21:17:WU00:FS00:Connecting to 65.254.110.245:8080
05:21:17:WU00:FS00:Assigned to work server 155.247.166.220
05:21:17:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 155.247.166.220
05:21:17:WU00:FS00:Connecting to 155.247.166.220:8080
05:21:17:ERROR:WU00:FS00:Exception: Server did not assign work unit
10:43:17:WU00:FS00:Connecting to 65.254.110.245:8080
10:43:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:43:17:WU00:FS00:Connecting to 18.218.241.186:80
10:43:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:43:17:ERROR:WU00:FS00:Exception: Could not get an assignment
16:43:17:WU00:FS00:Connecting to 65.254.110.245:8080
16:43:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:43:17:WU00:FS00:Connecting to 18.218.241.186:80
16:43:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:43:18:ERROR:WU00:FS00:Exception: Could not get an assignment
22:43:17:WU00:FS00:Connecting to 65.254.110.245:8080
22:43:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:43:17:WU00:FS00:Connecting to 18.218.241.186:80
22:43:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:43:17:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2019-10-13 *******************************
04:43:17:WU00:FS00:Connecting to 65.254.110.245:8080
04:43:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:43:17:WU00:FS00:Connecting to 18.218.241.186:80
04:43:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:43:18:ERROR:WU00:FS00:Exception: Could not get an assignment
10:43:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:43:18:ERROR:WU00:FS00:Exception: Could not get an assignment
16:43:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:43:18:WU00:FS00:Connecting to 18.218.241.186:80
22:43:18:WU00:FS00:Connecting to 65.254.110.245:8080
22:43:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:43:18:WU00:FS00:Connecting to 18.218.241.186:80
22:43:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:43:18:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2019-10-14 *******************************
04:43:18:WU00:FS00:Connecting to 65.254.110.245:8080
04:43:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:43:18:WU00:FS00:Connecting to 18.218.241.186:80
10:43:18:WU00:FS00:Connecting to 65.254.110.245:8080
10:43:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:43:18:WU00:FS00:Connecting to 18.218.241.186:80
Re: No WUs available / Could not get an assignment
Please post the beginning section of your log that shows the system info and folding configuration. That would help in figuring out what CPU WU's your system is requesting beyond that it is for 8 threads.
Include that segment of the logs from one or more of the machines that are getting assignments as well as the same segment from the one (?) that's not getting assignments. Be sure verbosity is set to the default value.
parkut
Post by parkut »
Two Dell Inspiron 530 (identical) machines-
Intel Quad Core Q6600 currently running Project: 13794 (Run 26, Clone 64, Gen 27)
*********************** Log Started 2019-09-27T19:04:44Z ***********************
19:04:44:************************* Folding@home Client *************************
19:04:44:    Website: https://foldingathome.org/
19:04:44:  Copyright: (c) 2009-2018 foldingathome.org
19:04:44:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:04:44:       Args: --child --lifeline 961 /etc/fahclient/config.xml --run-as fahclient
19:04:44:             --pid-file=/var/run/fahclient.pid --daemon
19:04:44:     Config: /etc/fahclient/config.xml
19:04:44:******************************** Build ********************************
19:04:44:    Version: 7.5.1
19:04:44:       Date: May 11 2018
19:04:44:       Time: 19:59:04
19:04:44: Repository: Git
19:04:44:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:04:44:     Branch: master
19:04:44:   Compiler: GNU 6.3.0 20170516
19:04:44:    Options: -std=gnu++98 -O3 -funroll-loops
19:04:44:   Platform: linux2 4.14.0-3-amd64
19:04:44:       Bits: 64
19:04:44:       Mode: Release
19:04:44:******************************* System ********************************
19:04:44:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
19:04:44:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
19:04:44:       CPUs: 4
19:04:44:     Memory: 2.92GiB
19:04:44:Free Memory: 2.53GiB
19:04:44:    Threads: POSIX_THREADS
19:04:44: OS Version: 4.15
19:04:44:Has Battery: false
19:04:44: On Battery: false
19:04:44: UTC Offset: -4
19:04:44:        PID: 963
19:04:44:        CWD: /var/lib/fahclient
19:04:44:         OS: Linux 4.15.0-64-generic x86_64
19:04:44:    OS Arch: AMD64
19:04:44:       GPUs: 0
19:04:44:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
19:04:44:             libcuda.so: cannot open shared object file: No such file or
19:04:44:             directory
19:04:44:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
19:04:44:             libOpenCL.so: cannot open shared object file: No such file or
19:04:44:             directory
19:04:44:***********************************************************************
19:04:44:<config>
19:04:44:  <!-- HTTP Server -->
19:04:44:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255'/>
19:04:44:
19:04:44:  <!-- Network -->
19:04:44:  <proxy v='192.168.1.142:3128'/>
19:04:44:
19:04:44:  <!-- Remote Command Server -->
19:04:44:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255'/>
19:04:44:
19:04:44:  <!-- Slot Control -->
19:04:44:  <power v='full'/>
19:04:44:
19:04:44:  <!-- User Information -->
19:04:44:  <passkey v='********************************'/>
19:04:44:  <team v='4'/>
19:04:44:  <user v='TH_Foldinator'/>
19:04:44:
19:04:44:  <!-- Folding Slots -->
19:04:44:  <slot id='0' type='CPU'>
19:04:44:    <client-type v='advanced'/>
19:04:44:  </slot>
19:04:44:</config>
2nd identical Intel Quad Core Q6600 that has not been assigned a work unit
*********************** Log Started 2019-09-27T19:01:59Z ***********************
19:01:59:************************* Folding@home Client *************************
19:01:59:    Website: https://foldingathome.org/
19:01:59:  Copyright: (c) 2009-2018 foldingathome.org
19:01:59:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:01:59:       Args: --child --lifeline 908 /etc/fahclient/config.xml --run-as fahclient
19:01:59:             --pid-file=/var/run/fahclient.pid --daemon
19:01:59:     Config: /etc/fahclient/config.xml
19:01:59:******************************** Build ********************************
19:01:59:    Version: 7.5.1
19:01:59:       Date: May 11 2018
19:01:59:       Time: 19:59:04
19:01:59: Repository: Git
19:01:59:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:01:59:     Branch: master
19:01:59:   Compiler: GNU 6.3.0 20170516
19:01:59:    Options: -std=gnu++98 -O3 -funroll-loops
19:01:59:   Platform: linux2 4.14.0-3-amd64
19:01:59:       Bits: 64
19:01:59:       Mode: Release
19:01:59:******************************* System ********************************
19:01:59:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
19:01:59:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
19:01:59:       CPUs: 4
19:01:59:     Memory: 3.17GiB
19:01:59:Free Memory: 2.76GiB
19:01:59:    Threads: POSIX_THREADS
19:01:59: OS Version: 4.15
19:01:59:Has Battery: false
19:01:59: On Battery: false
19:01:59: UTC Offset: -4
19:01:59:        PID: 910
19:01:59:        CWD: /var/lib/fahclient
19:01:59:         OS: Linux 4.15.0-64-generic x86_64
19:01:59:    OS Arch: AMD64
19:01:59:       GPUs: 0
19:01:59:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
19:01:59:             libcuda.so: cannot open shared object file: No such file or
19:01:59:             directory
19:01:59:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
19:01:59:             libOpenCL.so: cannot open shared object file: No such file or
19:01:59:             directory
19:01:59:***********************************************************************
19:01:59:<config>
19:01:59:  <!-- HTTP Server -->
19:01:59:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255'/>
19:01:59:
19:01:59:  <!-- Network -->
19:01:59:  <proxy v='192.168.1.142:3128'/>
19:01:59:
19:01:59:  <!-- Remote Command Server -->
19:01:59:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255'/>
19:01:59:
19:01:59:  <!-- Slot Control -->
19:01:59:  <power v='full'/>
19:01:59:
19:01:59:  <!-- User Information -->
19:01:59:  <passkey v='********************************'/>
19:01:59:  <team v='4'/>
19:01:59:  <user v='TH_Foldinator'/>
19:01:59:
19:01:59:  <!-- Folding Slots -->
19:01:59:  <slot id='0' type='CPU'>
19:01:59:    <client-type v='advanced'/>
19:01:59:  </slot>
19:01:59:</config>
parkut
Post by parkut »
Two intel I7-2600 machines, rebooted at same time. One received work, one has not.
One assigned work: Project: 14181 (Run 3, Clone 17, Gen 70)
(edit: host name f5b1)
*********************** Log Started 2019-10-14T22:17:18Z ***********************
22:17:18:************************* Folding@home Client *************************
22:17:18:    Website: https://foldingathome.org/
22:17:18:  Copyright: (c) 2009-2018 foldingathome.org
22:17:18:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:17:18:       Args: --child --lifeline 1073 /etc/fahclient/config.xml --run-as
22:17:18:             fahclient --pid-file=/var/run/fahclient.pid --daemon
22:17:18:     Config: /etc/fahclient/config.xml
22:17:18:******************************** Build ********************************
22:17:18:    Version: 7.5.1
22:17:18:       Date: May 11 2018
22:17:18:       Time: 19:59:04
22:17:18: Repository: Git
22:17:18:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:17:18:     Branch: master
22:17:18:   Compiler: GNU 6.3.0 20170516
22:17:18:    Options: -std=gnu++98 -O3 -funroll-loops
22:17:18:   Platform: linux2 4.14.0-3-amd64
22:17:18:       Bits: 64
22:17:18:       Mode: Release
22:17:18:******************************* System ********************************
22:17:18:        CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
22:17:18:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:17:18:       CPUs: 8
22:17:18:     Memory: 7.76GiB
22:17:18:Free Memory: 7.20GiB
22:17:18:    Threads: POSIX_THREADS
22:17:18: OS Version: 4.15
22:17:18:Has Battery: false
22:17:18: On Battery: false
22:17:18: UTC Offset: -4
22:17:18:        PID: 1075
22:17:18:        CWD: /var/lib/fahclient
22:17:18:         OS: Linux 4.15.0-65-generic x86_64
22:17:18:    OS Arch: AMD64
22:17:18:       GPUs: 1
22:17:18:      GPU 0: Bus:4 Slot:1 Func:0 AMD:0 [Rage XL]
22:17:18:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
22:17:18:             libcuda.so: cannot open shared object file: No such file or
22:17:18:             directory
22:17:18:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
22:17:18:             libOpenCL.so: cannot open shared object file: No such file or
22:17:18:             directory
22:17:18:***********************************************************************
22:17:18:<config>
22:17:18:  <!-- HTTP Server -->
22:17:18:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255'/>
22:17:18:
22:17:18:  <!-- Network -->
22:17:18:  <proxy v='192.168.1.142:3128'/>
22:17:18:
22:17:18:  <!-- Remote Command Server -->
22:17:18:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255'/>
22:17:18:
22:17:18:  <!-- Slot Control -->
22:17:18:  <power v='full'/>
22:17:18:
22:17:18:  <!-- User Information -->
22:17:18:  <passkey v='********************************'/>
22:17:18:  <team v='4'/>
22:17:18:  <user v='TH_Foldinator'/>
22:17:18:
22:17:18:  <!-- Folding Slots -->
22:17:18:  <slot id='0' type='CPU'/>
22:17:18:</config>
22:17:18:Switching to user fahclient
22:17:18:Trying to access database...
22:17:18:Successfully acquired database lock
22:17:18:Enabled folding slot 00: READY cpu:8
22:17:19:WU00:FS00:Connecting to 65.254.110.245:8080
22:17:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:17:20:WU00:FS00:Connecting to 18.218.241.186:80
22:17:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:17:21:ERROR:WU00:FS00:Exception: Could not get an assignment
22:17:21:WU00:FS00:Connecting to 65.254.110.245:8080
22:17:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:17:22:WU00:FS00:Connecting to 18.218.241.186:80
22:17:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:17:22:ERROR:WU00:FS00:Exception: Could not get an assignment
22:18:21:WU00:FS00:Connecting to 65.254.110.245:8080
22:18:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:18:22:WU00:FS00:Connecting to 18.218.241.186:80
22:18:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:18:22:ERROR:WU00:FS00:Exception: Could not get an assignment
22:19:59:WU00:FS00:Connecting to 65.254.110.245:8080
22:19:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:19:59:WU00:FS00:Connecting to 18.218.241.186:80
22:19:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:19:59:ERROR:WU00:FS00:Exception: Could not get an assignment
22:22:36:WU00:FS00:Connecting to 65.254.110.245:8080
22:22:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:22:36:WU00:FS00:Connecting to 18.218.241.186:80
22:22:36:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:22:36:ERROR:WU00:FS00:Exception: Could not get an assignment
22:26:50:WU00:FS00:Connecting to 65.254.110.245:8080
22:26:50:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:26:50:WU00:FS00:Connecting to 18.218.241.186:80
22:26:51:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:26:51:ERROR:WU00:FS00:Exception: Could not get an assignment
22:33:42:WU00:FS00:Connecting to 65.254.110.245:8080
22:33:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:33:42:WU00:FS00:Connecting to 18.218.241.186:80
22:33:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:33:42:ERROR:WU00:FS00:Exception: Could not get an assignment
22:44:47:WU00:FS00:Connecting to 65.254.110.245:8080
22:44:47:WU00:FS00:Assigned to work server 155.247.166.220
22:44:47:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 155.247.166.220
22:44:47:WU00:FS00:Connecting to 155.247.166.220:8080
22:44:48:WU00:FS00:Downloading 1.53MiB
22:44:48:WU00:FS00:Download complete
22:44:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14181 run:3 clone:17 gen:70 core:0xa7 unit:0x0000005b0002894c5ce58161f2b148c1
22:44:48:WU00:FS00:Starting
22:44:48:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1075 -checkpoint 15 -np 8
22:44:48:WU00:FS00:Started FahCore on PID 3195
22:44:48:WU00:FS00:Core PID:3199
22:44:48:WU00:FS00:FahCore 0xa7 started
22:44:49:WU00:FS00:0xa7:*********************** Log Started 2019-10-14T22:44:49Z ***********************
22:44:49:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:44:49:WU00:FS00:0xa7:       Type: 0xa7
22:44:49:WU00:FS00:0xa7:       Core: Gromacs
22:44:49:WU00:FS00:0xa7:    Website: https://foldingathome.org/
22:44:49:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
22:44:49:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:44:49:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3195 -checkpoint 15 -np 8
22:44:49:WU00:FS00:0xa7:     Config: <none>
22:44:49:WU00:FS00:0xa7:************************************ Build *************************************
22:44:49:WU00:FS00:0xa7:    Version: 0.0.17
22:44:49:WU00:FS00:0xa7:       Date: Apr 27 2018
22:44:49:WU00:FS00:0xa7:       Time: 19:09:21
22:44:49:WU00:FS00:0xa7: Repository: Git
22:44:49:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
22:44:49:WU00:FS00:0xa7:     Branch: master
22:44:49:WU00:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
22:44:49:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
22:44:49:WU00:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
22:44:49:WU00:FS00:0xa7:       Bits: 64
22:44:49:WU00:FS00:0xa7:       Mode: Release
22:44:49:WU00:FS00:0xa7:       SIMD: avx_256
22:44:49:WU00:FS00:0xa7:************************************ System ************************************
22:44:49:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
22:44:49:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:44:49:WU00:FS00:0xa7:       CPUs: 8
22:44:49:WU00:FS00:0xa7:     Memory: 7.76GiB
22:44:49:WU00:FS00:0xa7:Free Memory: 6.93GiB
22:44:49:WU00:FS00:0xa7:    Threads: POSIX_THREADS
22:44:49:WU00:FS00:0xa7: OS Version: 4.15
22:44:49:WU00:FS00:0xa7:Has Battery: false
22:44:49:WU00:FS00:0xa7: On Battery: false
22:44:49:WU00:FS00:0xa7: UTC Offset: -4
22:44:49:WU00:FS00:0xa7:        PID: 3199
22:44:49:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
22:44:49:WU00:FS00:0xa7:         OS: Linux 4.15.0-65-generic x86_64
22:44:49:WU00:FS00:0xa7:    OS Arch: AMD64
22:44:49:WU00:FS00:0xa7:********************************************************************************
22:44:49:WU00:FS00:0xa7:Project: 14181 (Run 3, Clone 17, Gen 70)
22:44:49:WU00:FS00:0xa7:Unit: 0x0000005b0002894c5ce58161f2b148c1
22:44:49:WU00:FS00:0xa7:Reading tar file core.xml
22:44:49:WU00:FS00:0xa7:Reading tar file frame70.tpr
22:44:49:WU00:FS00:0xa7:Digital signatures verified
22:44:49:WU00:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -cpt 15 -nt 8
22:44:49:WU00:FS00:0xa7:Steps: first=175000000 total=2500000
22:44:51:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
22:49:24:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
22:53:58:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
22:58:31:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
23:03:05:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
23:07:39:WU00:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
23:12:12:WU00:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
no work - (edit: reference host name f3b5)
*********************** Log Started 2019-10-14T22:16:34Z ***********************
22:16:34:************************* Folding@home Client *************************
22:16:34:    Website: https://foldingathome.org/
22:16:34:  Copyright: (c) 2009-2018 foldingathome.org
22:16:34:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:16:34:       Args: --child --lifeline 1141 /etc/fahclient/config.xml --run-as
22:16:34:             fahclient --pid-file=/var/run/fahclient.pid --daemon
22:16:34:     Config: /etc/fahclient/config.xml
22:16:34:******************************** Build ********************************
22:16:34:    Version: 7.5.1
22:16:34:       Date: May 11 2018
22:16:34:       Time: 19:59:04
22:16:34: Repository: Git
22:16:34:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:16:34:     Branch: master
22:16:34:   Compiler: GNU 6.3.0 20170516
22:16:34:    Options: -std=gnu++98 -O3 -funroll-loops
22:16:34:   Platform: linux2 4.14.0-3-amd64
22:16:34:       Bits: 64
22:16:34:       Mode: Release
22:16:34:******************************* System ********************************
22:16:34:        CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
22:16:34:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:16:34:       CPUs: 8
22:16:34:     Memory: 7.77GiB
22:16:34:Free Memory: 7.20GiB
22:16:34:    Threads: POSIX_THREADS
22:16:34: OS Version: 4.15
22:16:34:Has Battery: false
22:16:34: On Battery: false
22:16:34: UTC Offset: -4
22:16:34:        PID: 1143
22:16:34:        CWD: /var/lib/fahclient
22:16:34:         OS: Linux 4.15.0-65-generic x86_64
22:16:34:    OS Arch: AMD64
22:16:34:       GPUs: 0
22:16:34:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
22:16:34:             libcuda.so: cannot open shared object file: No such file or
22:16:34:             directory
22:16:34:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
22:16:34:             libOpenCL.so: cannot open shared object file: No such file or
22:16:34:             directory
22:16:34:***********************************************************************
22:16:34:<config>
22:16:34:  <!-- Client Control -->
22:16:34:  <fold-anon v='true'/>
22:16:34:
22:16:34:  <!-- Folding Slot Configuration -->
22:16:34:  <gpu v='false'/>
22:16:34:
22:16:34:  <!-- HTTP Server -->
22:16:34:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255'/>
22:16:34:
22:16:34:  <!-- Network -->
22:16:34:  <proxy v=':8080'/>
22:16:34:
22:16:34:  <!-- Remote Command Server -->
22:16:34:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255'/>
22:16:34:
22:16:34:  <!-- Slot Control -->
22:16:34:  <power v='full'/>
22:16:34:
22:16:34:  <!-- User Information -->
22:16:34:  <passkey v='********************************'/>
22:16:34:  <team v='4'/>
22:16:34:  <user v='TH_Foldinator'/>
22:16:34:
22:16:34:  <!-- Folding Slots -->
22:16:34:  <slot id='0' type='CPU'/>
22:16:34:</config>
22:16:34:Switching to user fahclient
22:16:34:Trying to access database...
22:16:34:Successfully acquired database lock
22:16:34:Enabled folding slot 00: READY cpu:8
22:16:35:WU00:FS00:Connecting to 65.254.110.245:8080
22:16:35:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:16:35:WU00:FS00:Connecting to 18.218.241.186:80
22:16:36:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:16:36:ERROR:WU00:FS00:Exception: Could not get an assignment
22:16:36:WU00:FS00:Connecting to 65.254.110.245:8080
22:16:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:16:37:WU00:FS00:Connecting to 18.218.241.186:80
22:16:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:16:37:ERROR:WU00:FS00:Exception: Could not get an assignment
22:17:36:WU00:FS00:Connecting to 65.254.110.245:8080
22:17:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:17:37:WU00:FS00:Connecting to 18.218.241.186:80
22:17:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:17:37:ERROR:WU00:FS00:Exception: Could not get an assignment
22:19:14:WU00:FS00:Connecting to 65.254.110.245:8080
22:19:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:19:14:WU00:FS00:Connecting to 18.218.241.186:80
22:19:14:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:19:14:ERROR:WU00:FS00:Exception: Could not get an assignment
22:21:51:WU00:FS00:Connecting to 65.254.110.245:8080
22:21:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:21:51:WU00:FS00:Connecting to 18.218.241.186:80
22:21:51:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:21:51:ERROR:WU00:FS00:Exception: Could not get an assignment
22:26:05:WU00:FS00:Connecting to 65.254.110.245:8080
22:26:05:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:26:05:WU00:FS00:Connecting to 18.218.241.186:80
22:26:06:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:26:06:ERROR:WU00:FS00:Exception: Could not get an assignment
22:32:57:WU00:FS00:Connecting to 65.254.110.245:8080
22:32:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:32:57:WU00:FS00:Connecting to 18.218.241.186:80
22:32:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:32:57:ERROR:WU00:FS00:Exception: Could not get an assignment
22:44:02:WU00:FS00:Connecting to 65.254.110.245:8080
22:44:02:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:44:02:WU00:FS00:Connecting to 18.218.241.186:80
22:44:03:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:44:03:ERROR:WU00:FS00:Exception: Could not get an assignment
23:01:59:WU00:FS00:Connecting to 65.254.110.245:8080
23:01:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:01:59:WU00:FS00:Connecting to 18.218.241.186:80
23:01:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:01:59:ERROR:WU00:FS00:Exception: Could not get an assignment
_r2w_ben
Post by _r2w_ben »
That is very odd. You mention that they're identical. Were they cloned from the same disk image? Was FAH already installed in that image? My wild guess is somehow the assignment server thinks the one machine is impersonating the other and refusing to assign work. If there is a unique identifier per machine, I would expect it to be in work/client.db. Try stopping FAHclient on the machine without work and rename client.db and client.db-journal. Then see what happens when you restart FAHclient.
parkut
Post by parkut »
The machines are not clones- each were bare metal installations running well over a year, the no work issue only developed in the last couple of months
What was the PRCG of the last WU completed before it went idle?
I suspect that the machines that are not being assigned have a history of dumping a lot of failed WUs -- sometimes because of something like a less that stable overclock. If that is, in fact, what happened, it's your own fault for not monitoring the system(s) and taking corrective action.
When the number of failed WUs becomes excessive, the machine eventually gets blacklisted -- as it's really bad for science.
parkut
Post by parkut »
Of the four selected machines posted above, today, only one of the Q6600's has work.
the i7-2600 above that had work, completed it, returned it for credit, and now has no work (edit: host name f5b1)
Hi TH_Foldinator (team 4), Your WU (P14181 R3 C17 G70) was added to the stats database on Tue, 15 Oct 2019 15:30:01 GMT for 13073.2 points of credit.
06:12:32:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
06:17:06:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
06:17:07:WU01:FS00:Connecting to 65.254.110.245:8080
06:17:07:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:17:07:WU01:FS00:Connecting to 18.218.241.186:80
06:17:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:17:08:ERROR:WU01:FS00:Exception: Could not get an assignment
06:17:08:WU01:FS00:Connecting to 65.254.110.245:8080
06:17:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:17:08:WU01:FS00:Connecting to 18.218.241.186:80
06:18:08:WU01:FS00:Connecting to 65.254.110.245:8080
06:18:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:18:08:WU01:FS00:Connecting to 18.218.241.186:80
06:18:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:18:08:ERROR:WU01:FS00:Exception: Could not get an assignment
06:19:45:WU01:FS00:Connecting to 65.254.110.245:8080
06:19:45:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:19:45:WU01:FS00:Connecting to 18.218.241.186:80
06:19:46:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:19:46:ERROR:WU01:FS00:Exception: Could not get an assignment
06:21:40:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
06:21:41:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
06:21:41:WU00:FS00:0xa7:Saving result file frame70.trr
06:21:41:WU00:FS00:0xa7:Saving result file md.log
06:21:41:WU00:FS00:0xa7:Saving result file science.log
06:21:41:WU00:FS00:0xa7:Saving result file traj_comp.xtc
06:21:41:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
06:21:41:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:21:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14181 run:3 clone:17 gen:70 core:0xa7 unit:0x0000005b0002894c5ce58161f2b148c1
06:21:41:WU00:FS00:Uploading 5.18MiB to 155.247.166.220
06:21:41:WU00:FS00:Connecting to 155.247.166.220:8080
06:21:47:WU00:FS00:Upload 69.98%
06:21:51:WU00:FS00:Upload complete
06:21:51:WU00:FS00:Server responded WORK_ACK (400)
06:21:51:WU00:FS00:Final credit estimate, 13072.00 points
06:21:51:WU00:FS00:Cleaning up
06:22:23:WU01:FS00:Connecting to 65.254.110.245:8080
06:22:23:WU01:FS00:Assigned to work server 155.247.166.220
06:22:23:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 155.247.166.220
06:22:23:WU01:FS00:Connecting to 155.247.166.220:8080
06:22:23:ERROR:WU01:FS00:Exception: Server did not assign work unit
06:26:37:WU01:FS00:Connecting to 65.254.110.245:8080
06:26:37:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:26:37:WU01:FS00:Connecting to 18.218.241.186:80
06:26:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:26:37:ERROR:WU01:FS00:Exception: Could not get an assignment
06:33:28:WU01:FS00:Connecting to 65.254.110.245:8080
06:33:28:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:33:28:WU01:FS00:Connecting to 18.218.241.186:80
06:33:29:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:33:29:ERROR:WU01:FS00:Exception: Could not get an assignment
06:44:34:WU01:FS00:Connecting to 65.254.110.245:8080
06:44:34:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:44:34:WU01:FS00:Connecting to 18.218.241.186:80
06:44:34:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:44:34:ERROR:WU01:FS00:Exception: Could not get an assignment
07:02:30:WU01:FS00:Connecting to 65.254.110.245:8080
07:02:31:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:02:31:WU01:FS00:Connecting to 18.218.241.186:80
07:02:31:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:02:31:ERROR:WU01:FS00:Exception: Could not get an assignment
07:31:33:WU01:FS00:Connecting to 65.254.110.245:8080
07:31:33:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:31:33:WU01:FS00:Connecting to 18.218.241.186:80
07:31:33:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:31:33:ERROR:WU01:FS00:Exception: Could not get an assignment
08:18:32:WU01:FS00:Connecting to 65.254.110.245:8080
08:18:32:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:18:32:WU01:FS00:Connecting to 18.218.241.186:80
08:18:32:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:18:32:ERROR:WU01:FS00:Exception: Could not get an assignment
09:34:32:WU01:FS00:Connecting to 65.254.110.245:8080
09:34:33:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:34:33:WU01:FS00:Connecting to 18.218.241.186:80
09:34:33:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:34:33:ERROR:WU01:FS00:Exception: Could not get an assignment
******************************* Date: 2019-10-15 *******************************
11:37:32:WU01:FS00:Connecting to 65.254.110.245:8080
11:37:32:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:37:32:WU01:FS00:Connecting to 18.218.241.186:80
11:37:32:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:37:32:ERROR:WU01:FS00:Exception: Could not get an assignment
parkut
Post by parkut »
the i7-2600 posted earlier that did not have work, still doesn't have any work. (edit: reference host name f3b5)
the last work unit received was completed without any error, and received credit.
log-20191014-160113.txt:20:46:28:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14181 run:22 clone:3 gen:75 core:0xa7 unit:0x000000560002894c5d3706438abd6ae2
Hi TH_Foldinator (team 4), Your WU (P14181 R22 C3 G75) was added to the stats database on Sat, 12 Oct 2019 06:00:02 GMT for 12919.5 points of credit.
the work unit received and completed without any errors immediately prior to that, also received credit
log-20191014-160113.txt:13:03:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:3 clone:68 gen:6 core:0xa7 unit:0x0000000a0002894c5d5d93a21c766f17
Hi TH_Foldinator (team 4), Your WU (P13794 R3 C68 G6) was added to the stats database on Fri, 11 Oct 2019 22:15:02 GMT for 11582 points of credit.
Sending history for several weeks prior to the last two completed work units posted below, if useful
log-20190921-133204.txt:06:22:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:12 clone:185 gen:2 core:0xa7 unit:0x000000040002894c5d5f33ed568aae89
log-20190921-133204.txt:14:17:03:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:4 clone:68 gen:7 core:0xa7 unit:0x000000080002894c5d5d93add725e44b
log-20190921-133204.txt:22:10:30:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:19 clone:64 gen:7 core:0xa7 unit:0x0000000b0002894c5d5d940fc08c8796
log-20190921-133204.txt:06:04:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:21 clone:53 gen:10 core:0xa7 unit:0x0000000b0002894c5d5d9406ef999658
log-20190921-133204.txt:13:59:59:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:5 clone:95 gen:7 core:0xa7 unit:0x000000090002894c5d5d93b334b7415f
log-20190921-133204.txt:21:53:01:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:17 clone:128 gen:6 core:0xa7 unit:0x000000090002894c5d5f340931ebcb26
log-20190921-133204.txt:05:47:04:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:24 clone:172 gen:6 core:0xa7 unit:0x000000070002894c5d5f3423df94fa82
log-20190921-133204.txt:13:45:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:11 clone:43 gen:21 core:0xa7 unit:0x0000001b0002894c5d5d93d99228ae6a
log-20190921-133204.txt:21:41:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:7 clone:105 gen:12 core:0xa7 unit:0x0000000f0002894c5d5f33b9f06638eb
log-20190921-133204.txt:05:35:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:26 clone:110 gen:7 core:0xa7 unit:0x0000000b0002894c5d5f341cef0c7474
log-20190921-133204.txt:13:30:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:1 clone:176 gen:7 core:0xa7 unit:0x0000000d0002894c5d5f3397b1478562
log-20190921-133204.txt:21:25:28:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:25 clone:25 gen:15 core:0xa7 unit:0x000000140002894c5d5d93f189e5a6fe
log-20190921-133204.txt:06:04:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:5 clone:29 gen:7 core:0xa7 unit:0x0000000b0002894c5d5d93afc350a007
log-20190921-133204.txt:13:58:44:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:24 clone:147 gen:9 core:0xa7 unit:0x0000000a0002894c5d5f3424c24e898e
log-20190921-133204.txt:21:53:37:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:16 clone:115 gen:8 core:0xa7 unit:0x0000000d0002894c5d5f3402a5f2c5db
log-20190921-133204.txt:05:47:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:9 clone:112 gen:6 core:0xa7 unit:0x000000080002894c5d5f33c90856324a
log-20190921-133204.txt:13:43:34:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:22 clone:108 gen:10 core:0xa7 unit:0x0000000f0002894c5d5f342f5d6627d3
log-20190921-133204.txt:21:38:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:17 clone:97 gen:8 core:0xa7 unit:0x0000000e0002894c5d5d941899628f20
log-20190921-133204.txt:05:32:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:2 clone:138 gen:3 core:0xa7 unit:0x000000070002894c5d5f339b55ff8dfe
log-20190921-133204.txt:13:28:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:6 clone:175 gen:16 core:0xa7 unit:0x000000120002894c5d5f33bb4abe809f
log-20190921-133204.txt:21:22:22:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:8 clone:173 gen:6 core:0xa7 unit:0x0000000a0002894c5d5f33b1f0bf80f4
log-20190921-133204.txt:05:15:35:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:3 clone:50 gen:5 core:0xa7 unit:0x000000060002894c5d5d93a1dad65632
log-20190921-133204.txt:13:10:19:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:16 clone:46 gen:12 core:0xa7 unit:0x0000000f0002894c5d5d941f73f9d968
log-20190921-133204.txt:21:06:13:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:14 clone:100 gen:16 core:0xa7 unit:0x000000180002894c5d5f33f498408135
log-20190921-133204.txt:05:02:05:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:20 clone:27 gen:15 core:0xa7 unit:0x000000120002894c5d5d940b3350adcb
log-20190921-133204.txt:12:57:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:20 clone:112 gen:19 core:0xa7 unit:0x000000190002894c5d5f3439e48530ad
log-20190927-223950.txt:20:54:38:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:19 clone:24 gen:14 core:0xa7 unit:0x000000130002894c5d5d9411012eaef4
log-20190927-223950.txt:04:49:52:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:22 clone:191 gen:16 core:0xa7 unit:0x000000150002894c5d5f342b81a30f1b
log-20190927-223950.txt:12:43:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:7 clone:14 gen:16 core:0xa7 unit:0x000000150002894c5d5d93bf274de5b3
log-20190927-223950.txt:20:41:17:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:18 clone:191 gen:41 core:0xa7 unit:0x000000350002894c5d5f34149cff8cec
log-20190927-223950.txt:04:37:01:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:4 clone:166 gen:6 core:0xa7 unit:0x000000070002894c5d5f33ac25637271
log-20190927-223950.txt:12:33:59:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:8 clone:122 gen:12 core:0xa7 unit:0x000000110002894c5d5f33b4ced87a64
log-20190927-223950.txt:20:32:29:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:10 clone:15 gen:20 core:0xa7 unit:0x000000170002894c5d5d93d1edeab7d4
log-20190927-223950.txt:04:27:42:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:25 clone:118 gen:10 core:0xa7 unit:0x0000000b0002894c5d5f3421851a525e
log-20190927-223950.txt:12:25:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:9 clone:134 gen:35 core:0xa7 unit:0x0000002a0002894c5d5f33cb969475fc
log-20190927-223950.txt:20:24:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:25 clone:150 gen:18 core:0xa7 unit:0x000000150002894c5d5f341f8aaae551
log-20190927-223950.txt:04:20:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:15 clone:161 gen:18 core:0xa7 unit:0x000000140002894c5d5f33fe500684d9
log-20190927-223950.txt:12:18:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:11 clone:99 gen:16 core:0xa7 unit:0x000000150002894c5d5d93ddaa92f0d0
log-20190927-223950.txt:20:04:59:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14181 run:23 clone:12 gen:62 core:0xa7 unit:0x000000540002894c5d370645e6b2c3d2
log-20191003-133713.txt:00:02:39:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:22 clone:53 gen:25 core:0xa7 unit:0x0000001c0002894c5d5d93fd36881ab6
log-20191003-133713.txt:08:00:02:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:6 clone:112 gen:26 core:0xa7 unit:0x0000001e0002894c5d5f33bea80610a9
log-20191003-133713.txt:15:58:03:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:22 clone:69 gen:22 core:0xa7 unit:0x000000190002894c5d5d93fd7bc09778
log-20191003-133713.txt:23:54:26:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:6 clone:112 gen:28 core:0xa7 unit:0x000000200002894c5d5f33bea80610a9
log-20191003-133713.txt:07:49:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:26 clone:194 gen:12 core:0xa7 unit:0x000000130002894c5d5f3418a14ade9d
log-20191003-133713.txt:15:43:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:15 clone:10 gen:4 core:0xa7 unit:0x000000070002894c5d5d9424ecbec62b
log-20191003-133713.txt:08:13:28:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:21 clone:67 gen:20 core:0xa7 unit:0x000000190002894c5d5d9405cc71a098
log-20191003-133713.txt:16:19:20:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:23 clone:50 gen:18 core:0xa7 unit:0x000000160002894c5d5d93f9972785e2
log-20191003-133713.txt:00:19:23:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:9 clone:69 gen:41 core:0xa7 unit:0x000000300002894c5d5d93ced622ae88
log-20191003-133713.txt:08:14:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:10 clone:188 gen:17 core:0xa7 unit:0x000000130002894c5d5f33dfc837c53c
log-20191003-133713.txt:16:11:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:3 clone:2 gen:17 core:0xa7 unit:0x000000120002894c5d5d939ff4fa090a
log-20191003-133713.txt:00:08:01:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:2 clone:141 gen:9 core:0xa7 unit:0x000000120002894c5d5f339bc710669a
log-20191003-133713.txt:08:18:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:22 clone:175 gen:15 core:0xa7 unit:0x000000120002894c5d5f342ce9e9dad7
log-20191003-133713.txt:16:16:55:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:10 clone:159 gen:15 core:0xa7 unit:0x000000130002894c5d5f33dd13f0ee95
log-20191003-133713.txt:00:13:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:6 clone:21 gen:6 core:0xa7 unit:0x0000000a0002894c5d5d93b52015cc22
log-20191003-133713.txt:08:20:03:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:2 clone:146 gen:16 core:0xa7 unit:0x000000130002894c5d5f339c18074f07
log-20191011-124827.txt:16:20:35:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:18 clone:152 gen:3 core:0xa7 unit:0x000000060002894c5d5f3411080526bd
log-20191011-124827.txt:00:43:43:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14181 run:14 clone:11 gen:43 core:0xa7 unit:0x0000003e0002894c5ce58167f0d372ff
log-20191011-124827.txt:09:18:14:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:4 clone:22 gen:7 core:0xa7 unit:0x0000000c0002894c5d5d93a6a5dd580f
log-20191011-124827.txt:17:24:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:2 clone:12 gen:46 core:0xa7 unit:0x000000360002894c5d5d9398263f906e
log-20191011-124827.txt:01:28:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:11 clone:127 gen:8 core:0xa7 unit:0x0000000b0002894c5d5f33e380db5a36
log-20191011-124827.txt:09:23:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:23 clone:147 gen:18 core:0xa7 unit:0x000000170002894c5d5f3429e969eb1a
log-20191011-124827.txt:17:17:38:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:16 clone:123 gen:17 core:0xa7 unit:0x000000180002894c5d5f34027b1ea14e
log-20191011-124827.txt:01:13:20:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:19 clone:41 gen:8 core:0xa7 unit:0x0000000d0002894c5d5d9410449af4eb
log-20191011-124827.txt:09:08:50:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:26 clone:108 gen:16 core:0xa7 unit:0x000000120002894c5d5f341d0add954c
log-20191011-124827.txt:17:06:04:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:26 clone:18 gen:3 core:0xa7 unit:0x000000030002894c5d5d93ec61e22352
log-20191011-124827.txt:01:02:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:12 clone:34 gen:4 core:0xa7 unit:0x000000060002894c5d5d93e0dd35d561
log-20191011-124827.txt:08:58:46:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:0 clone:2 gen:9 core:0xa7 unit:0x0000000f0002894c5d5d938ca10c31ae
log-20191011-124827.txt:16:53:46:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:3 clone:18 gen:33 core:0xa7 unit:0x000000270002894c5d5d939f14dd0ba3
log-20191011-124827.txt:02:21:03:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:16 clone:9 gen:11 core:0xa7 unit:0x0000000c0002894c5d5d942100565928
log-20191011-124827.txt:10:15:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:2 clone:26 gen:22 core:0xa7 unit:0x0000001c0002894c5d5d939928e622e3
log-20191011-124827.txt:18:11:25:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:18 clone:149 gen:14 core:0xa7 unit:0x000000140002894c5d5f34119f7494b3
log-20191011-124827.txt:02:05:42:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:9 clone:106 gen:18 core:0xa7 unit:0x000000160002894c5d5f33c9353c37d8
log-20191011-124827.txt:10:24:49:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:6 clone:191 gen:18 core:0xa7 unit:0x0000001a0002894c5d5f33ba81146cdc
log-20191011-124827.txt:18:21:17:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:16 clone:12 gen:18 core:0xa7 unit:0x0000001b0002894c5d5d942059666280
log-20191011-124827.txt:02:16:29:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13794 run:12 clone:161 gen:21 core:0xa7 unit:0x0000001b0002894c5d5f33ebc47a369e
log-20191011-124827.txt:10:11:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:23 clone:136 gen:26 core:0xa7 unit:0x000000210002894c5d5f342957b8c6cd
log-20191011-124827.txt:01:53:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14181 run:9 clone:16 gen:45 core:0xa7 unit:0x0000003f0002894c5ce5816a6bb8a780
parkut
Post by parkut »
Reference hostname f4b1
Dell Inspiron Q6600, no work since last returned on October 14 @ 17:48
Project: 13794 (Run 24, Clone 39, Gen 19)
Hi TH_Foldinator (team 4), Your WU (P13794 R24 C39 G19) was added to the stats database on Tue, 15 Oct 2019 03:00:02 GMT for 7098.88 points of credit.
system has been rebooted several times since last return, with no change in ability to receive new work.
*********************** Log Started 2019-10-16T00:30:41Z ***********************
00:30:41:************************* Folding@home Client *************************
00:30:41:    Website: https://foldingathome.org/
00:30:41:  Copyright: (c) 2009-2018 foldingathome.org
00:30:41:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:30:41:       Args: --child --lifeline 891 /etc/fahclient/config.xml --run-as fahclient
00:30:41:             --pid-file=/var/run/fahclient.pid --daemon
00:30:41:     Config: /etc/fahclient/config.xml
00:30:41:******************************** Build ********************************
00:30:41:    Version: 7.5.1
00:30:41:       Date: May 11 2018
00:30:41:       Time: 19:59:04
00:30:41: Repository: Git
00:30:41:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:30:41:     Branch: master
00:30:41:   Compiler: GNU 6.3.0 20170516
00:30:41:    Options: -std=gnu++98 -O3 -funroll-loops
00:30:41:   Platform: linux2 4.14.0-3-amd64
00:30:41:       Bits: 64
00:30:41:       Mode: Release
00:30:41:******************************* System ********************************
00:30:41:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
00:30:41:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
00:30:41:       CPUs: 4
00:30:41:     Memory: 3.17GiB
00:30:41:Free Memory: 2.78GiB
00:30:41:    Threads: POSIX_THREADS
00:30:41: OS Version: 4.15
00:30:41:Has Battery: false
00:30:41: On Battery: false
00:30:41: UTC Offset: -4
00:30:41:        PID: 893
00:30:41:        CWD: /var/lib/fahclient
00:30:41:         OS: Linux 4.15.0-65-generic x86_64
00:30:41:    OS Arch: AMD64
00:30:41:       GPUs: 0
00:30:41:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
00:30:41:             libcuda.so: cannot open shared object file: No such file or
00:30:41:             directory
00:30:41:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
00:30:41:             libOpenCL.so: cannot open shared object file: No such file or
00:30:41:             directory
00:30:41:***********************************************************************
00:30:41:<config>
00:30:41:  <!-- HTTP Server -->
00:30:41:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255,192.168.0.1-192.168.0.255'/>
00:30:41:
00:30:41:  <!-- Network -->
00:30:41:  <proxy v='192.168.1.142:3128'/>
00:30:41:
00:30:41:  <!-- Remote Command Server -->
00:30:41:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255,192.168.0.1-192.168.0.255'/>
00:30:41:
00:30:41:  <!-- Slot Control -->
00:30:41:  <power v='full'/>
00:30:41:
00:30:41:  <!-- User Information -->
00:30:41:  <passkey v='********************************'/>
00:30:41:  <team v='4'/>
00:30:41:  <user v='TH_Foldinator'/>
00:30:41:
00:30:41:  <!-- Folding Slots -->
00:30:41:  <slot id='0' type='CPU'>
00:30:41:    <client-type v='advanced'/>
00:30:41:  </slot>
00:30:41:</config>
00:30:41:Switching to user fahclient
00:30:41:Trying to access database...
00:30:42:Successfully acquired database lock
00:30:42:Enabled folding slot 00: READY cpu:4
00:30:42:WU00:FS00:Connecting to 65.254.110.245:8080
00:30:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:30:43:WU00:FS00:Connecting to 18.218.241.186:80
00:30:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:30:43:ERROR:WU00:FS00:Exception: Could not get an assignment
00:30:43:WU00:FS00:Connecting to 65.254.110.245:8080
00:30:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:30:44:WU00:FS00:Connecting to 18.218.241.186:80
00:30:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:30:44:ERROR:WU00:FS00:Exception: Could not get an assignment
00:31:44:WU00:FS00:Connecting to 65.254.110.245:8080
00:31:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:31:44:WU00:FS00:Connecting to 18.218.241.186:80
00:31:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:31:44:ERROR:WU00:FS00:Exception: Could not get an assignment
00:33:21:WU00:FS00:Connecting to 65.254.110.245:8080
00:33:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:33:21:WU00:FS00:Connecting to 18.218.241.186:80
00:33:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:33:21:ERROR:WU00:FS00:Exception: Could not get an assignment
00:35:58:WU00:FS00:Connecting to 65.254.110.245:8080
00:35:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:35:58:WU00:FS00:Connecting to 18.218.241.186:80
00:35:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:35:58:ERROR:WU00:FS00:Exception: Could not get an assignment
00:40:12:WU00:FS00:Connecting to 65.254.110.245:8080
00:40:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:40:12:WU00:FS00:Connecting to 18.218.241.186:80
00:40:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:40:13:ERROR:WU00:FS00:Exception: Could not get an assignment
00:47:04:WU00:FS00:Connecting to 65.254.110.245:8080
00:47:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
00:47:04:WU00:FS00:Connecting to 18.218.241.186:80
00:47:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
00:47:04:ERROR:WU00:FS00:Exception: Could not get an assignment
parkut
Post by parkut »
This machine has work currently, and is sitting next to the Q6600-f4b1 immediately above this post that is unable to get work.
Reference hostname f4b2
Dell inspiron Q6600, currently assigned work (Project: 13794 Run 9, Clone 164, Gen 7) 96% complete
Immediately prior work unit completed with no problems
Hi TH_Foldinator (team 4), Your WU (P13794 R26 C64 G27) was added to the stats database on Tue, 15 Oct 2019 13:45:02 GMT for 7109.78 points of credit.
*********************** Log Started 2019-10-16T00:28:50Z ***********************
00:28:50:************************* Folding@home Client *************************
00:28:50:    Website: https://foldingathome.org/
00:28:50:  Copyright: (c) 2009-2018 foldingathome.org
00:28:50:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:28:50:       Args: --child --lifeline 1014 /etc/fahclient/config.xml --run-as
00:28:50:             fahclient --pid-file=/var/run/fahclient.pid --daemon
00:28:50:     Config: /etc/fahclient/config.xml
00:28:50:******************************** Build ********************************
00:28:50:    Version: 7.5.1
00:28:50:       Date: May 11 2018
00:28:50:       Time: 19:59:04
00:28:50: Repository: Git
00:28:50:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:28:50:     Branch: master
00:28:50:   Compiler: GNU 6.3.0 20170516
00:28:50:    Options: -std=gnu++98 -O3 -funroll-loops
00:28:50:   Platform: linux2 4.14.0-3-amd64
00:28:50:       Bits: 64
00:28:50:       Mode: Release
00:28:50:******************************* System ********************************
00:28:50:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
00:28:50:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
00:28:50:       CPUs: 4
00:28:50:     Memory: 2.92GiB
00:28:50:Free Memory: 2.53GiB
00:28:50:    Threads: POSIX_THREADS
00:28:50: OS Version: 4.15
00:28:50:Has Battery: false
00:28:50: On Battery: false
00:28:50: UTC Offset: -4
00:28:50:        PID: 1016
00:28:50:        CWD: /var/lib/fahclient
00:28:50:         OS: Linux 4.15.0-65-generic x86_64
00:28:50:    OS Arch: AMD64
00:28:50:       GPUs: 0
00:28:50:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
00:28:50:             libcuda.so: cannot open shared object file: No such file or
00:28:50:             directory
00:28:50:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
00:28:50:             libOpenCL.so: cannot open shared object file: No such file or
00:28:50:             directory
00:28:50:***********************************************************************
00:28:50:<config>
00:28:50:  <!-- HTTP Server -->
00:28:50:  <allow v='127.0.0.1,192.168.1.1-192.168.1.255,192.168.0.1-192.168.0.255'/>
00:28:50:
00:28:50:  <!-- Network -->
00:28:50:  <proxy v='192.168.1.142:3128'/>
00:28:50:
00:28:50:  <!-- Remote Command Server -->
00:28:50:  <command-allow-no-pass v='127.0.0.1,192.168.1.1-192.168.1.255,192.168.0.1-192.168.0.255'/>
00:28:50:
00:28:50:  <!-- Slot Control -->
00:28:50:  <power v='full'/>
00:28:50:
00:28:50:  <!-- User Information -->
00:28:50:  <passkey v='********************************'/>
00:28:50:  <team v='4'/>
00:28:50:  <user v='TH_Foldinator'/>
00:28:50:
00:28:50:  <!-- Folding Slots -->
00:28:50:  <slot id='0' type='CPU'>
00:28:50:    <client-type v='advanced'/>
00:28:50:  </slot>
00:28:50:</config>
00:28:50:Switching to user fahclient
00:28:50:Trying to access database...
00:28:51:Successfully acquired database lock
00:28:51:Enabled folding slot 00: READY cpu:4
00:28:51:WU00:FS00:Starting
00:28:51:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1016 -checkpoint 15 -np 4
00:28:51:WU00:FS00:Started FahCore on PID 1028
00:28:51:WU00:FS00:Core PID:1035
00:28:51:WU00:FS00:FahCore 0xa7 started
00:28:52:WU00:FS00:0xa7:*********************** Log Started 2019-10-16T00:28:51Z ***********************
00:28:52:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:28:52:WU00:FS00:0xa7:       Type: 0xa7
00:28:52:WU00:FS00:0xa7:       Core: Gromacs
00:28:52:WU00:FS00:0xa7:    Website: https://foldingathome.org/
00:28:52:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:28:52:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:28:52:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1028 -checkpoint 15 -np 4
00:28:52:WU00:FS00:0xa7:     Config: <none>
00:28:52:WU00:FS00:0xa7:************************************ Build *************************************
00:28:52:WU00:FS00:0xa7:    Version: 0.0.17
00:28:52:WU00:FS00:0xa7:       Date: Apr 27 2018
00:28:52:WU00:FS00:0xa7:       Time: 19:09:25
00:28:52:WU00:FS00:0xa7: Repository: Git
00:28:52:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:28:52:WU00:FS00:0xa7:     Branch: master
00:28:52:WU00:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
00:28:52:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
00:28:52:WU00:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
00:28:52:WU00:FS00:0xa7:       Bits: 64
00:28:52:WU00:FS00:0xa7:       Mode: Release
00:28:52:WU00:FS00:0xa7:       SIMD: sse2
00:28:52:WU00:FS00:0xa7:************************************ System ************************************
00:28:52:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
00:28:52:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
00:28:52:WU00:FS00:0xa7:       CPUs: 4
00:28:52:WU00:FS00:0xa7:     Memory: 2.92GiB
00:28:52:WU00:FS00:0xa7:Free Memory: 2.52GiB
00:28:52:WU00:FS00:0xa7:    Threads: POSIX_THREADS
00:28:52:WU00:FS00:0xa7: OS Version: 4.15
00:28:52:WU00:FS00:0xa7:Has Battery: false
00:28:52:WU00:FS00:0xa7: On Battery: false
00:28:52:WU00:FS00:0xa7: UTC Offset: -4
00:28:52:WU00:FS00:0xa7:        PID: 1035
00:28:52:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
00:28:52:WU00:FS00:0xa7:         OS: Linux 4.15.0-65-generic x86_64
00:28:52:WU00:FS00:0xa7:    OS Arch: AMD64
00:28:52:WU00:FS00:0xa7:********************************************************************************
00:28:52:WU00:FS00:0xa7:Project: 13794 (Run 9, Clone 164, Gen 7)
00:28:52:WU00:FS00:0xa7:Unit: 0x0000000a0002894c5d5f33cf2adb2f95
00:28:52:WU00:FS00:0xa7:Digital signatures verified
00:28:52:WU00:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpi state.cpt -cpt 15 -nt 4
00:28:55:WU00:FS00:0xa7:Steps: first=17500000 total=2500000
00:28:56:WU00:FS00:0xa7:Completed 2337782 out of 2500000 steps (93%)
00:35:19:WU00:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
00:48:18:WU00:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
01:01:16:WU00:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
_r2w_ben
Post by _r2w_ben »
Does removing client-type advanced from the slot configuration make any difference?
parkut
Post by parkut »
@Bruce, I am not seeing any evidence of DUMPED wu's, connectivity issues, or other problems, except for not being able to get work assignments.
For what it's worth, I monitor 17 different systems in five different locations across four states. They all seem to have CPU work assignment issues.
parkut
Post by parkut »
@r2w_ben, It does not seem to make any difference, I have some set as client-type advanced, and some with no client type setting
