Linux Mint 32 Bit Version
Planorez
Post by Planorez »
I don't find a Linux Mint 32 bit client in the present downloads. What is the latest version I can get and where can I get it?
Thanks
Planorez
Re: Linux Mint 32 Bit Version
FAH only supports 64-bit versions of Linux.
Upgrade.
Planorez
Post by Planorez »
I know only 64 bit versions of Linux Mint clients are currently available. I am trying to make use of Intel Core2 duo laptops that are 32 bit. Where can archive versions on Linux Mint 32 bit clients be found?
I am not sure I understand? Why would you want a version that did not work anymore?
The 32 bit linux version never supported Core_a7, Just Core_a4. There are no Core_a4 Work Units being deployed, I personally doubt any more use for Core_a4 will be found.
AMD and Nvidia have dropped support for 32 bit drivers, so you can't run GPU projects.
All Core 2 CPUs are 64 bit. I just do not understand. https://en.wikipedia.org/wiki/Intel_Core_2
