Sig images
Penfold
Sig images
Post by Penfold »
While I'm still awake, I have a small niggle I'd like to have sorted out, please. Up until today I had the sig image in my signature - name, points total, points per day etc. For some treason* I managed to delete it in all the trauma of the frozen WU. I used this to try to recover it
[URL=https://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781][IMG]https://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781[/IMG][/URL]
However I then get this message: It was not possible to determine the dimensions of the image.
Can anyone suggest what I might be doing wrong here? It worked before.
Edit: * treason? Surely not …
Ubuntu 18.04.4
F@H v 7.5.1
bollix47
Re: Sig images
Post by bollix47 »
Try the following:
[img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781[/img]
Using my EOC id in the above results in:
https://folding.extremeoverclocking.com/?nav=IMAGES
Penfold
Re: Sig images
Post by Penfold »
Bollix, I tried, by copying and pasting, your suggestion and got the same error message.
Can you see what I might have done wrong here?
[URL=http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781][img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781[/img][/URL]
I note that I had had 'https' rather than the 'http' you suggest. Does that matter. I tried both, btw.
Ubuntu 18.04.4
F@H v 7.5.1
bollix47
Re: Sig images
Post by bollix47 »
No, https vs http makes no difference in this case.
As you can see below both the format I suggested & the one you're using work:
Using the above without the code tags results in the following:
[url=http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781][img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781[/img][/url]
The only difference I see is an extra line under the box using your method.
Do you have "Disable BBCode" checked? If so, remove it. You can see that Option below any posting/edit window and in User Control Panel > Profile > Edit signature
Penfold
Re: Sig images
Post by Penfold »
The BBCode box is unchecked.
I copied and pasted the second CODE:SELECT ALL version from your post. I'll go back over it again with my fine toothed brain.
Ubuntu 18.04.4
F@H v 7.5.1
Penfold
Re: Sig images
Post by Penfold »
Now I can't even get 'Ubuntu 18.4.3' nor 'F@H v 7.5.1' to appear in my sig. That is, I don't have a sig anymore.
BBCode is shown to be On, and the 'Disable BBCode' checkbox is unchecked.
EDIT: 'Ubuntu 18.4.3' nor 'F@H v 7.5.1' appear on my first post but not on the rest. In desperation I logged out and then back in. Tried
[URL=https://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781][img]http://folding.extremeoverclocking.com/sigs/sigimage.php?u=611781[/img][/URL]
again, but no go.
Ubuntu 18.04.4
F@H v 7.5.1
Penfold
Re: Sig images
Post by Penfold »
Total absence of sig now. Can anyone suggest a way to overcome this, please?
Ubuntu 18.04.4
F@H v 7.5.1
bollix47
Re: Sig images
Post by bollix47 »
Signatures are only shown once on a page and your signature is in a post near the top of the page.
Penfold
Re: Sig images
Post by Penfold »
bollix47 wrote:Signatures are only shown once on a page and your signature is in a post near the top of the page.
OK thanks - didn't realise that.
Can this thread be transferred to 'Issues with this forum' in the Stats & Server Issues section? I should maybe have started it there.
Ubuntu 18.04.4
F@H v 7.5.1
Re: Sig images
I have been looking into this, and think I have identified the forum setting that is causing this problem. I will do some further checking and will return to this topic when I know more.
Penfold
Re: Sig images
Post by Penfold »
OK, Joe. Thanks.
(Whenever this sort of thing pops up I always feel that I've blundered somehow.)
Ubuntu 18.04.4
F@H v 7.5.1
rusty
Re: Sig images
Post by rusty »
Sorry to bring this topic back from the dead, but I am encountering the same issue described here by @Penfold.
Again, specifically, including the following in my signature:
[img]https://folding.extremeoverclocking.com/sigs/sigimage.php?u=854248[/img]
results in phpBB throwing the following error:
I can apparently use this image successfully in a post body, no problem:
...just not in my signature :(
From his Oct 10th post, it sounded like @Joe_H was closing in on a potential solution for this issue. Is there a known fix for this?
Thanks!
Re: Sig images
I thought I was on to a solution ... then that turned out not to be it. Still looking , but spending more time learning the internals of the forum software to get ready for updating the forum to a current version.
rusty
Re: Sig images
Post by rusty »
Thanks, Joe! No worries, was just hoping there might be a simple fix from my side. Strange how it only affects some users and not others. Bizarre. Good luck on the upgrade.
Re: Sig images
It appears to be connected with when the sig image was added. I added mine years ago, people adding recently are getting an error message. I get the same message when I try to fix it for someone, my guess is that some obscure forum setting got changed at some point and that is keeping them from working the same.
