Project: 14089 (Run 154, Clone 0, Gen 0)
Frisa
Post by Frisa »
Seems a new ADV project, which havent been announced in Announcements forum
got following error
09:43:46:WU01:FS00:Connecting to 65.254.110.245:8080
09:43:47:WU01:FS00:Assigned to work server 155.247.166.219
09:43:47:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 155.247.166.219
09:43:47:WU01:FS00:Connecting to 155.247.166.219:8080
09:43:48:WU01:FS00:Downloading 1.48MiB
09:43:54:WU01:FS00:Download 25.35%
09:44:00:WU01:FS00:Download 42.26%
09:44:06:WU01:FS00:Download 59.16%
09:44:12:WU01:FS00:Download 100.00%
09:44:12:WU01:FS00:Download complete
09:44:12:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14089 run:154 clone:0 gen:0 core:0xa7 unit:0x000000040002894b5d92487e0b90d42c
09:45:17:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
09:45:20:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
09:45:20:WU00:FS00:0xa7:Saving result file frame3.trr
09:45:20:WU00:FS00:0xa7:Saving result file frame3.xtc
09:45:20:WU00:FS00:0xa7:Saving result file md.log
09:45:20:WU00:FS00:0xa7:Saving result file science.log
09:45:20:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:45:20:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:45:20:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13830 run:205 clone:1 gen:3 core:0xa7 unit:0x0000000380fccb095d693e20eb37fa86
09:45:20:WU00:FS00:Uploading 11.24MiB to 128.252.203.9
09:45:20:WU00:FS00:Connecting to 128.252.203.9:8080
09:45:20:WU01:FS00:Starting
09:45:20:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 503 -checkpoint 15 -np 8
09:45:20:WU01:FS00:Started FahCore on PID 2691
09:45:20:WU01:FS00:Core PID:2695
09:45:20:WU01:FS00:FahCore 0xa7 started
09:45:21:WU01:FS00:0xa7:*********************** Log Started 2019-10-02T09:45:20Z ***********************
09:45:21:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:45:21:WU01:FS00:0xa7:       Type: 0xa7
09:45:21:WU01:FS00:0xa7:       Core: Gromacs
09:45:21:WU01:FS00:0xa7:    Website: https://foldingathome.org/
09:45:21:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:45:21:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:45:21:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2691 -checkpoint 15 -np 8
09:45:21:WU01:FS00:0xa7:     Config: <none>
09:45:21:WU01:FS00:0xa7:************************************ Build *************************************
09:45:21:WU01:FS00:0xa7:    Version: 0.0.17
09:45:21:WU01:FS00:0xa7:       Date: Apr 27 2018
09:45:21:WU01:FS00:0xa7:       Time: 19:09:21
09:45:21:WU01:FS00:0xa7: Repository: Git
09:45:21:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
09:45:21:WU01:FS00:0xa7:     Branch: master
09:45:21:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
09:45:21:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
09:45:21:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
09:45:21:WU01:FS00:0xa7:       Bits: 64
09:45:21:WU01:FS00:0xa7:       Mode: Release
09:45:21:WU01:FS00:0xa7:       SIMD: avx_256
09:45:21:WU01:FS00:0xa7:************************************ System ************************************
09:45:21:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
09:45:21:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
09:45:21:WU01:FS00:0xa7:       CPUs: 8
09:45:21:WU01:FS00:0xa7:     Memory: 3.77GiB
09:45:21:WU01:FS00:0xa7:Free Memory: 3.08GiB
09:45:21:WU01:FS00:0xa7:    Threads: POSIX_THREADS
09:45:21:WU01:FS00:0xa7: OS Version: 4.19
09:45:21:WU01:FS00:0xa7:Has Battery: false
09:45:21:WU01:FS00:0xa7: On Battery: false
09:45:21:WU01:FS00:0xa7: UTC Offset: 8
09:45:21:WU01:FS00:0xa7:        PID: 2695
09:45:21:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
09:45:21:WU01:FS00:0xa7:         OS: Linux 4.19.0-6-amd64 x86_64
09:45:21:WU01:FS00:0xa7:    OS Arch: AMD64
09:45:21:WU01:FS00:0xa7:********************************************************************************
09:45:21:WU01:FS00:0xa7:Project: 14089 (Run 154, Clone 0, Gen 0)
09:45:21:WU01:FS00:0xa7:Unit: 0x000000040002894b5d92487e0b90d42c
09:45:21:WU01:FS00:0xa7:Reading tar file core.xml
09:45:21:WU01:FS00:0xa7:Reading tar file frame0.tpr
09:45:21:WU01:FS00:0xa7:Digital signatures verified
09:45:21:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
09:45:21:WU01:FS00:0xa7:Steps: first=0 total=1250000
09:45:21:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
09:45:21:WU01:FS00:0xa7:ERROR:
09:45:21:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
09:45:21:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20161122-4846b12ba-unknown
09:45:21:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/mdlib/pme.c, line: 754
09:45:21:WU01:FS00:0xa7:ERROR:Fatal error:
09:45:21:WU01:FS00:0xa7:ERROR:5 particles communicated to PME rank 4 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
09:45:21:WU01:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
09:45:21:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
09:45:21:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
09:45:26:WU00:FS00:Upload 70.04%
09:45:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:45:27:WU01:FS00:Starting
09:45:27:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 503 -checkpoint 15 -np 8
09:45:27:WU01:FS00:Started FahCore on PID 2706
09:45:27:WU01:FS00:Core PID:2710
09:45:27:WU01:FS00:FahCore 0xa7 started
09:45:27:WU01:FS00:0xa7:*********************** Log Started 2019-10-02T09:45:27Z ***********************
09:45:27:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:45:27:WU01:FS00:0xa7:       Type: 0xa7
09:45:27:WU01:FS00:0xa7:       Core: Gromacs
09:45:27:WU01:FS00:0xa7:    Website: https://foldingathome.org/
09:45:27:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:45:27:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:45:27:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2706 -checkpoint 15 -np 8
09:45:27:WU01:FS00:0xa7:     Config: <none>
09:45:27:WU01:FS00:0xa7:************************************ Build *************************************
09:45:27:WU01:FS00:0xa7:    Version: 0.0.17
09:45:27:WU01:FS00:0xa7:       Date: Apr 27 2018
09:45:27:WU01:FS00:0xa7:       Time: 19:09:21
09:45:27:WU01:FS00:0xa7: Repository: Git
09:45:27:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
09:45:27:WU01:FS00:0xa7:     Branch: master
09:45:27:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
09:45:27:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
09:45:27:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
09:45:27:WU01:FS00:0xa7:       Bits: 64
09:45:27:WU01:FS00:0xa7:       Mode: Release
09:45:27:WU01:FS00:0xa7:       SIMD: avx_256
09:45:27:WU01:FS00:0xa7:************************************ System ************************************
09:45:27:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
09:45:27:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
09:45:27:WU01:FS00:0xa7:       CPUs: 8
09:45:27:WU01:FS00:0xa7:     Memory: 3.77GiB
09:45:27:WU01:FS00:0xa7:Free Memory: 3.07GiB
09:45:27:WU01:FS00:0xa7:    Threads: POSIX_THREADS
09:45:27:WU01:FS00:0xa7: OS Version: 4.19
09:45:27:WU01:FS00:0xa7:Has Battery: false
09:45:27:WU01:FS00:0xa7: On Battery: false
09:45:27:WU01:FS00:0xa7: UTC Offset: 8
09:45:27:WU01:FS00:0xa7:        PID: 2710
09:45:27:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
09:45:27:WU01:FS00:0xa7:         OS: Linux 4.19.0-6-amd64 x86_64
09:45:27:WU01:FS00:0xa7:    OS Arch: AMD64
09:45:27:WU01:FS00:0xa7:********************************************************************************
09:45:27:WU01:FS00:0xa7:Project: 14089 (Run 154, Clone 0, Gen 0)
09:45:27:WU01:FS00:0xa7:Unit: 0x000000040002894b5d92487e0b90d42c
09:45:27:WU01:FS00:0xa7:Digital signatures verified
09:45:27:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
09:45:27:WU01:FS00:0xa7:Steps: first=0 total=1250000
09:45:28:WU00:FS00:Upload complete
09:45:28:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
09:45:28:WU01:FS00:0xa7:ERROR:
09:45:28:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
09:45:28:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20161122-4846b12ba-unknown
09:45:28:WU01:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/mdlib/pme.c, line: 754
09:45:28:WU01:FS00:0xa7:ERROR:Fatal error:
09:45:28:WU01:FS00:0xa7:ERROR:5 particles communicated to PME rank 4 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
09:45:28:WU01:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
09:45:28:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
09:45:28:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
09:45:28:WU00:FS00:Server responded WORK_ACK (400)
09:45:28:WU00:FS00:Final credit estimate, 6297.00 points
09:45:28:WU00:FS00:Cleaning up
09:45:33:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Mod edit: changed Quote tags to Code for log file
Frisa
Re: Project: 14089 (Run 154, Clone 0, Gen 0)
Post by Frisa »
error from another Run
12:47:56:WU01:FS00:FahCore 0xa7 started
12:47:56:WU01:FS00:0xa7:*********************** Log Started 2019-10-02T12:47:56Z ***********************
12:47:56:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:47:56:WU01:FS00:0xa7:       Type: 0xa7
12:47:56:WU01:FS00:0xa7:       Core: Gromacs
12:47:56:WU01:FS00:0xa7:    Website: https://foldingathome.org/
12:47:56:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:47:56:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:47:56:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3284 -checkpoint 15 -np 8
12:47:56:WU01:FS00:0xa7:     Config: <none>
12:47:56:WU01:FS00:0xa7:************************************ Build *************************************
12:47:56:WU01:FS00:0xa7:    Version: 0.0.17
12:47:56:WU01:FS00:0xa7:       Date: Apr 27 2018
12:47:56:WU01:FS00:0xa7:       Time: 19:09:21
12:47:56:WU01:FS00:0xa7: Repository: Git
12:47:56:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
12:47:56:WU01:FS00:0xa7:     Branch: master
12:47:56:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
12:47:56:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
12:47:56:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
12:47:56:WU01:FS00:0xa7:       Bits: 64
12:47:56:WU01:FS00:0xa7:       Mode: Release
12:47:56:WU01:FS00:0xa7:       SIMD: avx_256
12:47:56:WU01:FS00:0xa7:************************************ System ************************************
12:47:56:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
12:47:56:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:47:56:WU01:FS00:0xa7:       CPUs: 8
12:47:56:WU01:FS00:0xa7:     Memory: 3.77GiB
12:47:56:WU01:FS00:0xa7:Free Memory: 3.12GiB
12:47:56:WU01:FS00:0xa7:    Threads: POSIX_THREADS
12:47:56:WU01:FS00:0xa7: OS Version: 4.19
12:47:56:WU01:FS00:0xa7:Has Battery: false
12:47:56:WU01:FS00:0xa7: On Battery: false
12:47:56:WU01:FS00:0xa7: UTC Offset: 8
12:47:56:WU01:FS00:0xa7:        PID: 3288
12:47:56:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
12:47:56:WU01:FS00:0xa7:         OS: Linux 4.19.0-6-amd64 x86_64
12:47:56:WU01:FS00:0xa7:    OS Arch: AMD64
12:47:56:WU01:FS00:0xa7:********************************************************************************
12:47:56:WU01:FS00:0xa7:Project: 14088 (Run 36, Clone 1, Gen 0)
12:47:56:WU01:FS00:0xa7:Unit: 0x000000000002894b5d92494acb3ea0e4
12:47:56:WU01:FS00:0xa7:Reading tar file core.xml
12:47:56:WU01:FS00:0xa7:Reading tar file frame0.tpr
12:47:56:WU01:FS00:0xa7:Digital signatures verified
12:47:56:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
12:47:56:WU01:FS00:0xa7:Steps: first=0 total=1250000
12:47:56:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
12:47:57:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Mode edit: same
The first WU has multiple errors reported with no successful completions, it should stop being assigned automatically. The second is too early to say.
Project owner has been notified and project should not be assigning anymore.
