Project: 13794 (Run 13, Clone 15, Gen 4)
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
The FAH client appears to be having trouble completing this run of Project 13794. It is stopped at 99 percent completion. In the log files, there appeared that some error occurred before normal completion. I am attaching them, and a screen shot of the client. The screen shot was captured over an hour ago, since then there has been no change with Project 13794. Newer Project 14188 is now up to 22.5 percent complete.
Sorry my "signature" needs to be updated, am now in the Pande Team. Do not see a way to save a draft (only Preview and Submit); will work on that later...
Thanks,
Robby
05:15:24:WU00:FS00:0xa7:Completed 2325000 out of 2500000 steps (93%)
05:26:02:WU00:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
05:36:56:WU00:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
******************************* Date: 2019-09-18 *******************************
05:47:34:WU00:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
05:58:12:WU00:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
06:08:44:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
06:19:13:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
06:19:14:WU01:FS00:Connecting to 65.254.110.245:8080
06:19:14:WU01:FS00:Assigned to work server 155.247.166.219
06:19:14:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 155.247.166.219
06:19:14:WU01:FS00:Connecting to 155.247.166.219:8080
06:19:14:WU01:FS00:Downloading 6.65MiB
06:19:20:WU01:FS00:Download 77.09%
06:19:21:WU01:FS00:Download complete
06:19:21:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14188 run:2 clone:326 gen:4 core:0xa7 unit:0x000000070002894b5d77e6718c74297f
06:19:44:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:19:44:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
06:19:44:WU01:FS00:Starting
06:19:44:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4144 -checkpoint 15 -np 3 -service
06:19:44:WU01:FS00:Started FahCore on PID 22848
06:19:47:WU01:FS00:Core PID:648
06:19:47:WU01:FS00:FahCore 0xa7 started
06:19:48:WU01:FS00:0xa7:*********************** Log Started 2019-09-18T06:19:47Z ***********************
06:19:48:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:19:48:WU01:FS00:0xa7:       Type: 0xa7
06:19:48:WU01:FS00:0xa7:       Core: Gromacs
06:19:48:WU01:FS00:0xa7:    Website: https://foldingathome.org/
06:19:48:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
06:19:48:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:19:48:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 22848 -checkpoint 15 -np
06:19:48:WU01:FS00:0xa7:             3 -service
06:19:48:WU01:FS00:0xa7:     Config: <none>
06:19:48:WU01:FS00:0xa7:************************************ Build *************************************
06:19:48:WU01:FS00:0xa7:    Version: 0.0.17
06:19:48:WU01:FS00:0xa7:       Date: Apr 25 2018
06:19:48:WU01:FS00:0xa7:       Time: 11:02:26
06:19:48:WU01:FS00:0xa7: Repository: Git
06:19:48:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
06:19:48:WU01:FS00:0xa7:     Branch: master
06:19:48:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
06:19:48:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:19:48:WU01:FS00:0xa7:   Platform: win32 10
06:19:48:WU01:FS00:0xa7:       Bits: 32
06:19:48:WU01:FS00:0xa7:       Mode: Release
06:19:48:WU01:FS00:0xa7:       SIMD: sse2
06:19:48:WU01:FS00:0xa7:************************************ System ************************************
06:19:48:WU01:FS00:0xa7:        CPU: Unknown
06:19:48:WU01:FS00:0xa7:     CPU ID:
06:19:48:WU01:FS00:0xa7:       CPUs: 8
06:19:48:WU01:FS00:0xa7:     Memory: 15.89GiB
06:19:48:WU01:FS00:0xa7:Free Memory: 11.03GiB
06:19:48:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
06:19:48:WU01:FS00:0xa7: OS Version: 6.2
06:19:48:WU01:FS00:0xa7:Has Battery: true
06:19:48:WU01:FS00:0xa7: On Battery: false
06:19:48:WU01:FS00:0xa7: UTC Offset: -5
06:19:48:WU01:FS00:0xa7:        PID: 648
06:19:48:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
06:19:48:WU01:FS00:0xa7:         OS: Windows 10 Home
06:19:48:WU01:FS00:0xa7:    OS Arch: AMD64
06:19:48:WU01:FS00:0xa7:********************************************************************************
06:19:48:WU01:FS00:0xa7:Project: 14188 (Run 2, Clone 326, Gen 4)
06:19:48:WU01:FS00:0xa7:Unit: 0x000000070002894b5d77e6718c74297f
06:19:48:WU01:FS00:0xa7:Reading tar file core.xml
06:19:48:WU01:FS00:0xa7:Reading tar file frame4.tpr
06:19:48:WU01:FS00:0xa7:Digital signatures verified
06:19:48:WU01:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpt 15 -nt 3
06:19:48:WU01:FS00:0xa7:Steps: first=5000000 total=1250000
06:19:51:WU01:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
06:41:55:WU01:FS00:0xa7:Completed 12500 out of 1250000 steps (1%)
07:03:54:WU01:FS00:0xa7:Completed 25000 out of 1250000 steps (2%)
07:25:58:WU01:FS00:0xa7:Completed 37500 out of 1250000 steps (3%)
07:47:57:WU01:FS00:0xa7:Completed 50000 out of 1250000 steps (4%)
08:09:56:WU01:FS00:0xa7:Completed 62500 out of 1250000 steps (5%)
08:31:58:WU01:FS00:0xa7:Completed 75000 out of 1250000 steps (6%)
08:54:01:WU01:FS00:0xa7:Completed 87500 out of 1250000 steps (7%)
09:16:02:WU01:FS00:0xa7:Completed 100000 out of 1250000 steps (8%)
09:38:05:WU01:FS00:0xa7:Completed 112500 out of 1250000 steps (9%)
10:00:07:WU01:FS00:0xa7:Completed 125000 out of 1250000 steps (10%)
10:22:07:WU01:FS00:0xa7:Completed 137500 out of 1250000 steps (11%)
10:44:09:WU01:FS00:0xa7:Completed 150000 out of 1250000 steps (12%)
11:06:13:WU01:FS00:0xa7:Completed 162500 out of 1250000 steps (13%)
11:28:13:WU01:FS00:0xa7:Completed 175000 out of 1250000 steps (14%)
11:50:17:WU01:FS00:0xa7:Completed 187500 out of 1250000 steps (15%)
12:12:22:WU01:FS00:0xa7:Completed 200000 out of 1250000 steps (16%)
12:34:26:WU01:FS00:0xa7:Completed 212500 out of 1250000 steps (17%)
12:56:30:WU01:FS00:0xa7:Completed 225000 out of 1250000 steps (18%)
13:18:08:72:127.0.0.1:New Web connection
13:19:12:WU01:FS00:0xa7:Completed 237500 out of 1250000 steps (19%)
13:42:02:WU01:FS00:0xa7:Completed 250000 out of 1250000 steps (20%)
14:05:02:WU01:FS00:0xa7:Completed 262500 out of 1250000 steps (21%)
14:28:12:WU01:FS00:0xa7:Completed 275000 out of 1250000 steps (22%)
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 13794 (Run 13, Clone 15, Gen 4)
As best as I can tell from the log, your Project 13794 WU reached 99% and that caused the download of the next WU. Shortly after the WU crashed for some reason, and with 2 WU's in the queue the slot started the new WU instead of completing the previous one. So the older one is sitting in the queue waiting to restart from its last checkpoint before the crash.
I am not sure how to get the client to return to the nearly complete WU without first finishing the one it is currently processing. Safest might be to set the processing to Finish, you might have to use Finish a second time after the currently processing WU is done.
You did not provide the beginning of the log file, which version of the folding client are you running? The stalled error could be an issue with an older version, the detection code had some problems in earlier versions that are thought to have been corrected.
P.S. Updating your signature in your profile will apply to all posts you have made in the past as well.
Whenever there are two WUs enqueued on a single slot, and something interrupts the the active WU, there's the potential for the problem Joe_H has described. I know of no method to manually alter the sequence in which the WUs will be processed.
Personally, I have configured my system for "next-unit-percentage" = "100" which essentially avoid the potential issue. With my internet connection, the processing gap between one WU and the next one is so small that I don't consider downloading the new WU important. [In the days of dial-up-modems, it was.]
Robby_Firefox
A follow up...
Seems this morning around 19/0807Z, this client Version 7.5.1 (after processing Project 14188 to 70 percent) paused that job, and reloaded Project 13794. Backed it to 97 percent, then finished it in less than 25 minutes at 19/0831Z. Earned 4927 points (would it have been more if it completed on time earlier?). The current job 14188 is back to processing, estimated it will finish in another 6 hours or around 1915Z. The "top" of the log had scrolled off of the page, as this PC has been running continuously over the past few week. This PC is coming back from a major failure (think registry), had to do a install. I have an older copy from a previous log that started from the top - from a week or so ago..
Thanks bruce and Joe_H for your advice. Now am curious from bruce, how does one set the parameters: "next-unit-percentage" = "100"? I suppose it is in the expert settings? See the jobs are in the multi-megabyte size range, a preload in those pre-wideband days was needed.
Lastly, cannot properly set my signature? It shows up at least on my end and from another computer as:
[img]https://folding.extremeoverclocking.com/sigs/sigimage.php?u=832104[/img]
Without putting the code/code in, the image actually shows up. It was prompting "It was not possible to determine the dimensions of the image." Am I allowed to include something like width="468" height="60" along with an href to get over this error? Tried it with and without the URL without much success.
Am posting it right below my name and it works as it should (or used to from Control Panel and Preferences).
Thanks,
Robby
12:34:55:WU00:FS00:FahCore 0xa7 started
12:34:55:WU00:FS00:0xa7:*********************** Log Started 2019-09-17T12:34:55Z ***********************
12:34:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:34:55:WU00:FS00:0xa7:       Type: 0xa7
12:34:55:WU00:FS00:0xa7:       Core: Gromacs
12:34:55:WU00:FS00:0xa7:    Website: https://foldingathome.org/
12:34:55:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:34:55:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:34:55:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3252 -checkpoint 15 -np 3
12:34:55:WU00:FS00:0xa7:             -service
12:34:55:WU00:FS00:0xa7:     Config: <none>
12:34:55:WU00:FS00:0xa7:************************************ Build *************************************
12:34:55:WU00:FS00:0xa7:    Version: 0.0.17
12:34:55:WU00:FS00:0xa7:       Date: Apr 25 2018
12:34:55:WU00:FS00:0xa7:       Time: 11:02:26
12:34:55:WU00:FS00:0xa7: Repository: Git
12:34:55:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
12:34:55:WU00:FS00:0xa7:     Branch: master
12:34:55:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:34:55:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:34:55:WU00:FS00:0xa7:   Platform: win32 10
12:34:55:WU00:FS00:0xa7:       Bits: 32
12:34:55:WU00:FS00:0xa7:       Mode: Release
12:34:55:WU00:FS00:0xa7:       SIMD: sse2
12:34:55:WU00:FS00:0xa7:************************************ System ************************************
12:34:55:WU00:FS00:0xa7:        CPU: Unknown
12:34:55:WU00:FS00:0xa7:     CPU ID:
12:34:55:WU00:FS00:0xa7:       CPUs: 8
12:34:55:WU00:FS00:0xa7:     Memory: 15.89GiB
12:34:55:WU00:FS00:0xa7:Free Memory: 11.53GiB
12:34:55:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:34:55:WU00:FS00:0xa7: OS Version: 6.2
12:34:55:WU00:FS00:0xa7:Has Battery: true
12:34:55:WU00:FS00:0xa7: On Battery: false
12:34:55:WU00:FS00:0xa7: UTC Offset: -5
12:34:55:WU00:FS00:0xa7:        PID: 10336
12:34:55:WU00:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
12:34:55:WU00:FS00:0xa7:         OS: Windows 10 Home
12:34:55:WU00:FS00:0xa7:    OS Arch: AMD64
12:34:55:WU00:FS00:0xa7:********************************************************************************
12:34:55:WU00:FS00:0xa7:Project: 13794 (Run 13, Clone 15, Gen 4)
12:34:55:WU00:FS00:0xa7:Unit: 0x000000070002894c5d5d93e4a87483a3
12:34:55:WU00:FS00:0xa7:Reading tar file core.xml
12:34:55:WU00:FS00:0xa7:Reading tar file frame4.tpr
12:34:55:WU00:FS00:0xa7:Digital signatures verified
12:34:55:WU00:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpt 15 -nt 3
12:34:55:WU00:FS00:0xa7:Steps: first=10000000 total=2500000
12:34:56:WU01:FS00:Server responded WORK_ACK (400)
12:34:56:WU01:FS00:Final credit estimate, 3664.00 points
12:34:56:WU01:FS00:Cleaning up
12:34:56:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
12:45:27:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
12:55:59:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
13:06:28:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
13:17:01:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
13:27:35:WU00:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
13:38:08:WU00:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
13:48:38:WU00:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
13:59:08:WU00:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
14:09:35:WU00:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
14:20:03:WU00:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
14:30:31:WU00:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
14:40:57:WU00:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
14:51:23:WU00:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
15:01:46:WU00:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
15:12:14:WU00:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
15:22:43:WU00:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
15:33:12:WU00:FS00:0xa7:Completed 425000 out of 2500000 steps (17%)
15:43:41:WU00:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
15:54:10:WU00:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
16:04:39:WU00:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
16:15:05:WU00:FS00:0xa7:Completed 525000 out of 2500000 steps (21%)
16:25:30:WU00:FS00:0xa7:Completed 550000 out of 2500000 steps (22%)
16:35:57:WU00:FS00:0xa7:Completed 575000 out of 2500000 steps (23%)
16:46:24:WU00:FS00:0xa7:Completed 600000 out of 2500000 steps (24%)
16:56:53:WU00:FS00:0xa7:Completed 625000 out of 2500000 steps (25%)
17:07:21:WU00:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
17:17:54:WU00:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
17:28:29:WU00:FS00:0xa7:Completed 700000 out of 2500000 steps (28%)
******************************* Date: 2019-09-17 *******************************
17:39:04:WU00:FS00:0xa7:Completed 725000 out of 2500000 steps (29%)
17:49:36:WU00:FS00:0xa7:Completed 750000 out of 2500000 steps (30%)
18:00:05:WU00:FS00:0xa7:Completed 775000 out of 2500000 steps (31%)
18:10:37:WU00:FS00:0xa7:Completed 800000 out of 2500000 steps (32%)
18:21:08:WU00:FS00:0xa7:Completed 825000 out of 2500000 steps (33%)
18:31:39:WU00:FS00:0xa7:Completed 850000 out of 2500000 steps (34%)
18:42:16:WU00:FS00:0xa7:Completed 875000 out of 2500000 steps (35%)
18:52:50:WU00:FS00:0xa7:Completed 900000 out of 2500000 steps (36%)
19:03:19:WU00:FS00:0xa7:Completed 925000 out of 2500000 steps (37%)
19:13:50:WU00:FS00:0xa7:Completed 950000 out of 2500000 steps (38%)
19:24:21:WU00:FS00:0xa7:Completed 975000 out of 2500000 steps (39%)
19:34:50:WU00:FS00:0xa7:Completed 1000000 out of 2500000 steps (40%)
19:45:20:WU00:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
19:55:48:WU00:FS00:0xa7:Completed 1050000 out of 2500000 steps (42%)
20:06:18:WU00:FS00:0xa7:Completed 1075000 out of 2500000 steps (43%)
20:16:47:WU00:FS00:0xa7:Completed 1100000 out of 2500000 steps (44%)
20:27:15:WU00:FS00:0xa7:Completed 1125000 out of 2500000 steps (45%)
20:37:45:WU00:FS00:0xa7:Completed 1150000 out of 2500000 steps (46%)
20:48:14:WU00:FS00:0xa7:Completed 1175000 out of 2500000 steps (47%)
20:58:46:WU00:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
21:09:16:WU00:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
21:19:45:WU00:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
21:30:14:WU00:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
21:40:42:WU00:FS00:0xa7:Completed 1300000 out of 2500000 steps (52%)
21:51:11:WU00:FS00:0xa7:Completed 1325000 out of 2500000 steps (53%)
22:01:40:WU00:FS00:0xa7:Completed 1350000 out of 2500000 steps (54%)
22:12:08:WU00:FS00:0xa7:Completed 1375000 out of 2500000 steps (55%)
22:22:38:WU00:FS00:0xa7:Completed 1400000 out of 2500000 steps (56%)
22:33:07:WU00:FS00:0xa7:Completed 1425000 out of 2500000 steps (57%)
22:43:38:WU00:FS00:0xa7:Completed 1450000 out of 2500000 steps (58%)
22:54:10:WU00:FS00:0xa7:Completed 1475000 out of 2500000 steps (59%)
23:04:39:WU00:FS00:0xa7:Completed 1500000 out of 2500000 steps (60%)
23:15:08:WU00:FS00:0xa7:Completed 1525000 out of 2500000 steps (61%)
23:25:40:WU00:FS00:0xa7:Completed 1550000 out of 2500000 steps (62%)
23:36:15:WU00:FS00:0xa7:Completed 1575000 out of 2500000 steps (63%)
23:46:49:WU00:FS00:0xa7:Completed 1600000 out of 2500000 steps (64%)
23:57:22:WU00:FS00:0xa7:Completed 1625000 out of 2500000 steps (65%)
00:07:54:WU00:FS00:0xa7:Completed 1650000 out of 2500000 steps (66%)
00:18:24:WU00:FS00:0xa7:Completed 1675000 out of 2500000 steps (67%)
00:28:53:WU00:FS00:0xa7:Completed 1700000 out of 2500000 steps (68%)
00:39:22:WU00:FS00:0xa7:Completed 1725000 out of 2500000 steps (69%)
00:49:51:WU00:FS00:0xa7:Completed 1750000 out of 2500000 steps (70%)
01:00:22:WU00:FS00:0xa7:Completed 1775000 out of 2500000 steps (71%)
01:10:51:WU00:FS00:0xa7:Completed 1800000 out of 2500000 steps (72%)
01:22:10:WU00:FS00:0xa7:Completed 1825000 out of 2500000 steps (73%)
01:37:27:WU00:FS00:0xa7:Completed 1850000 out of 2500000 steps (74%)
01:52:28:WU00:FS00:0xa7:Completed 1875000 out of 2500000 steps (75%)
02:07:30:WU00:FS00:0xa7:Completed 1900000 out of 2500000 steps (76%)
02:22:37:WU00:FS00:0xa7:Completed 1925000 out of 2500000 steps (77%)
02:35:35:WU00:FS00:0xa7:Completed 1950000 out of 2500000 steps (78%)
02:46:03:WU00:FS00:0xa7:Completed 1975000 out of 2500000 steps (79%)
02:56:32:WU00:FS00:0xa7:Completed 2000000 out of 2500000 steps (80%)
03:07:02:WU00:FS00:0xa7:Completed 2025000 out of 2500000 steps (81%)
03:16:46:44:127.0.0.1:New Web connection
03:17:39:WU00:FS00:0xa7:Completed 2050000 out of 2500000 steps (82%)
03:28:31:WU00:FS00:0xa7:Completed 2075000 out of 2500000 steps (83%)
03:39:16:WU00:FS00:0xa7:Completed 2100000 out of 2500000 steps (84%)
03:49:55:WU00:FS00:0xa7:Completed 2125000 out of 2500000 steps (85%)
04:00:38:WU00:FS00:0xa7:Completed 2150000 out of 2500000 steps (86%)
04:11:19:WU00:FS00:0xa7:Completed 2175000 out of 2500000 steps (87%)
04:22:07:WU00:FS00:0xa7:Completed 2200000 out of 2500000 steps (88%)
04:32:53:WU00:FS00:0xa7:Completed 2225000 out of 2500000 steps (89%)
04:43:37:WU00:FS00:0xa7:Completed 2250000 out of 2500000 steps (90%)
04:54:21:WU00:FS00:0xa7:Completed 2275000 out of 2500000 steps (91%)
05:04:57:WU00:FS00:0xa7:Completed 2300000 out of 2500000 steps (92%)
14:51:00:WU01:FS00:0xa7:Completed 287500 out of 1250000 steps (23%)
15:13:36:WU01:FS00:0xa7:Completed 300000 out of 1250000 steps (24%)
15:35:38:WU01:FS00:0xa7:Completed 312500 out of 1250000 steps (25%)
15:57:43:WU01:FS00:0xa7:Completed 325000 out of 1250000 steps (26%)
16:19:45:WU01:FS00:0xa7:Completed 337500 out of 1250000 steps (27%)
16:41:46:WU01:FS00:0xa7:Completed 350000 out of 1250000 steps (28%)
17:04:26:WU01:FS00:0xa7:Completed 362500 out of 1250000 steps (29%)
17:26:51:WU01:FS00:0xa7:Completed 375000 out of 1250000 steps (30%)
17:49:11:WU01:FS00:0xa7:Completed 387500 out of 1250000 steps (31%)
18:11:59:WU01:FS00:0xa7:Completed 400000 out of 1250000 steps (32%)
18:35:12:WU01:FS00:0xa7:Completed 412500 out of 1250000 steps (33%)
18:58:34:WU01:FS00:0xa7:Completed 425000 out of 1250000 steps (34%)
19:21:39:WU01:FS00:0xa7:Completed 437500 out of 1250000 steps (35%)
19:44:35:WU01:FS00:0xa7:Completed 450000 out of 1250000 steps (36%)
20:08:04:WU01:FS00:0xa7:Completed 462500 out of 1250000 steps (37%)
20:31:13:WU01:FS00:0xa7:Completed 475000 out of 1250000 steps (38%)
20:53:23:WU01:FS00:0xa7:Completed 487500 out of 1250000 steps (39%)
21:14:41:WU01:FS00:0xa7:Completed 500000 out of 1250000 steps (40%)
21:35:53:WU01:FS00:0xa7:Completed 512500 out of 1250000 steps (41%)
21:57:00:WU01:FS00:0xa7:Completed 525000 out of 1250000 steps (42%)
22:18:03:WU01:FS00:0xa7:Completed 537500 out of 1250000 steps (43%)
22:39:11:WU01:FS00:0xa7:Completed 550000 out of 1250000 steps (44%)
23:00:17:WU01:FS00:0xa7:Completed 562500 out of 1250000 steps (45%)
23:21:34:WU01:FS00:0xa7:Completed 575000 out of 1250000 steps (46%)
23:42:51:WU01:FS00:0xa7:Completed 587500 out of 1250000 steps (47%)
00:04:03:WU01:FS00:0xa7:Completed 600000 out of 1250000 steps (48%)
******************************* Date: 2019-09-19 *******************************
00:25:18:WU01:FS00:0xa7:Completed 612500 out of 1250000 steps (49%)
00:46:34:WU01:FS00:0xa7:Completed 625000 out of 1250000 steps (50%)
01:07:47:WU01:FS00:0xa7:Completed 637500 out of 1250000 steps (51%)
01:28:51:WU01:FS00:0xa7:Completed 650000 out of 1250000 steps (52%)
01:49:56:WU01:FS00:0xa7:Completed 662500 out of 1250000 steps (53%)
02:13:39:WU01:FS00:0xa7:Completed 675000 out of 1250000 steps (54%)
02:40:36:WU01:FS00:0xa7:Completed 687500 out of 1250000 steps (55%)
03:02:11:WU01:FS00:0xa7:Completed 700000 out of 1250000 steps (56%)
03:23:44:WU01:FS00:0xa7:Completed 712500 out of 1250000 steps (57%)
03:46:01:WU01:FS00:0xa7:Completed 725000 out of 1250000 steps (58%)
04:08:58:WU01:FS00:0xa7:Completed 737500 out of 1250000 steps (59%)
04:31:47:WU01:FS00:0xa7:Completed 750000 out of 1250000 steps (60%)
04:53:43:WU01:FS00:0xa7:Completed 762500 out of 1250000 steps (61%)
05:15:00:WU01:FS00:0xa7:Completed 775000 out of 1250000 steps (62%)
05:36:18:WU01:FS00:0xa7:Completed 787500 out of 1250000 steps (63%)
05:57:35:WU01:FS00:0xa7:Completed 800000 out of 1250000 steps (64%)
06:18:51:WU01:FS00:0xa7:Completed 812500 out of 1250000 steps (65%)
06:40:04:WU01:FS00:0xa7:Completed 825000 out of 1250000 steps (66%)
07:01:19:WU01:FS00:0xa7:Completed 837500 out of 1250000 steps (67%)
07:22:39:WU01:FS00:0xa7:Completed 850000 out of 1250000 steps (68%)
07:44:03:WU01:FS00:0xa7:Completed 862500 out of 1250000 steps (69%)
08:05:24:WU01:FS00:0xa7:Completed 875000 out of 1250000 steps (70%)
08:07:41:WU00:FS00:Starting
08:07:41:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4144 -checkpoint 15 -np 3 -service
08:07:41:WU00:FS00:Started FahCore on PID 23928
08:07:43:WU00:FS00:Core PID:13728
08:07:43:WU00:FS00:FahCore 0xa7 started
08:07:43:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
08:07:43:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
08:07:43:WU00:FS00:0xa7:*********************** Log Started 2019-09-19T08:07:43Z ***********************
08:07:43:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:07:43:WU00:FS00:0xa7:       Type: 0xa7
08:07:43:WU00:FS00:0xa7:       Core: Gromacs
08:07:43:WU00:FS00:0xa7:    Website: https://foldingathome.org/
08:07:43:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
08:07:43:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:07:43:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 23928 -checkpoint 15 -np
08:07:43:WU00:FS00:0xa7:             3 -service
08:07:43:WU00:FS00:0xa7:     Config: <none>
08:07:43:WU00:FS00:0xa7:************************************ Build *************************************
08:07:43:WU00:FS00:0xa7:    Version: 0.0.17
08:07:43:WU00:FS00:0xa7:       Date: Apr 25 2018
08:07:43:WU00:FS00:0xa7:       Time: 11:02:26
08:07:43:WU00:FS00:0xa7: Repository: Git
08:07:43:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
08:07:43:WU00:FS00:0xa7:     Branch: master
08:07:43:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
08:07:43:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:07:43:WU00:FS00:0xa7:   Platform: win32 10
08:07:43:WU00:FS00:0xa7:       Bits: 32
08:07:43:WU00:FS00:0xa7:       Mode: Release
08:07:43:WU00:FS00:0xa7:       SIMD: sse2
08:07:43:WU00:FS00:0xa7:************************************ System ************************************
08:07:43:WU00:FS00:0xa7:        CPU: Unknown
08:07:43:WU00:FS00:0xa7:     CPU ID:
08:07:43:WU00:FS00:0xa7:       CPUs: 8
08:07:43:WU00:FS00:0xa7:     Memory: 15.89GiB
08:07:43:WU00:FS00:0xa7:Free Memory: 11.60GiB
08:07:43:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
08:07:43:WU00:FS00:0xa7: OS Version: 6.2
08:07:43:WU00:FS00:0xa7:Has Battery: true
08:07:43:WU00:FS00:0xa7: On Battery: false
08:07:43:WU00:FS00:0xa7: UTC Offset: -5
08:07:43:WU00:FS00:0xa7:        PID: 13728
08:07:43:WU00:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
08:07:43:WU00:FS00:0xa7:         OS: Windows 10 Home
08:07:43:WU00:FS00:0xa7:    OS Arch: AMD64
08:07:43:WU00:FS00:0xa7:********************************************************************************
08:07:43:WU00:FS00:0xa7:Project: 13794 (Run 13, Clone 15, Gen 4)
08:07:43:WU00:FS00:0xa7:Unit: 0x000000070002894c5d5d93e4a87483a3
08:07:43:WU00:FS00:0xa7:Digital signatures verified
08:07:43:WU00:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpi state.cpt -cpt 15 -nt 3
08:07:44:WU00:FS00:0xa7:Steps: first=10000000 total=2500000
08:07:46:WU00:FS00:0xa7:Completed 2441001 out of 2500000 steps (97%)
08:11:31:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
08:21:43:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
08:31:55:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
08:31:56:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:31:56:WU00:FS00:0xa7:Saving result file ener.edr
08:31:56:WU00:FS00:0xa7:Saving result file frame4.trr
08:31:56:WU00:FS00:0xa7:Saving result file md.log
08:31:56:WU00:FS00:0xa7:Saving result file pullf.xvg
08:31:56:WU00:FS00:0xa7:Saving result file pullx.xvg
08:31:56:WU00:FS00:0xa7:Saving result file science.log
08:31:56:WU00:FS00:0xa7:Saving result file traj_comp.xtc
08:31:56:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:31:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:31:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13794 run:13 clone:15 gen:4 core:0xa7 unit:0x000000070002894c5d5d93e4a87483a3
08:31:57:WU00:FS00:Uploading 27.16MiB to 155.247.166.220
08:31:57:WU01:FS00:Starting
08:31:57:WU00:FS00:Connecting to 155.247.166.220:8080
08:31:57:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4144 -checkpoint 15 -np 3 -service
08:31:57:WU01:FS00:Started FahCore on PID 10924
08:31:57:WU01:FS00:Core PID:1348
08:31:57:WU01:FS00:FahCore 0xa7 started
08:31:57:WU01:FS00:0xa7:*********************** Log Started 2019-09-19T08:31:57Z ***********************
08:31:57:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:31:57:WU01:FS00:0xa7:       Type: 0xa7
08:31:57:WU01:FS00:0xa7:       Core: Gromacs
08:31:57:WU01:FS00:0xa7:    Website: https://foldingathome.org/
08:31:57:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
08:31:57:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:57:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 10924 -checkpoint 15 -np
08:31:58:WU01:FS00:0xa7:             3 -service
08:31:58:WU01:FS00:0xa7:     Config: <none>
08:31:58:WU01:FS00:0xa7:************************************ Build *************************************
08:31:58:WU01:FS00:0xa7:    Version: 0.0.17
08:31:58:WU01:FS00:0xa7:       Date: Apr 25 2018
08:31:58:WU01:FS00:0xa7:       Time: 11:02:26
08:31:58:WU01:FS00:0xa7: Repository: Git
08:31:58:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
08:31:58:WU01:FS00:0xa7:     Branch: master
08:31:58:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:31:58:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:31:58:WU01:FS00:0xa7:   Platform: win32 10
08:31:58:WU01:FS00:0xa7:       Bits: 32
08:31:58:WU01:FS00:0xa7:       Mode: Release
08:31:58:WU01:FS00:0xa7:       SIMD: sse2
08:31:58:WU01:FS00:0xa7:************************************ System ************************************
08:31:58:WU01:FS00:0xa7:        CPU: Unknown
08:31:58:WU01:FS00:0xa7:     CPU ID:
08:31:58:WU01:FS00:0xa7:       CPUs: 8
08:31:58:WU01:FS00:0xa7:     Memory: 15.89GiB
08:31:58:WU01:FS00:0xa7:Free Memory: 11.75GiB
08:31:58:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:31:58:WU01:FS00:0xa7: OS Version: 6.2
08:31:58:WU01:FS00:0xa7:Has Battery: true
08:31:58:WU01:FS00:0xa7: On Battery: false
08:31:58:WU01:FS00:0xa7: UTC Offset: -5
08:31:58:WU01:FS00:0xa7:        PID: 1348
08:31:58:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
08:31:58:WU01:FS00:0xa7:         OS: Windows 10 Home
08:31:58:WU01:FS00:0xa7:    OS Arch: AMD64
08:31:58:WU01:FS00:0xa7:********************************************************************************
08:31:58:WU01:FS00:0xa7:Project: 14188 (Run 2, Clone 326, Gen 4)
08:31:58:WU01:FS00:0xa7:Unit: 0x000000070002894b5d77e6718c74297f
08:31:58:WU01:FS00:0xa7:Digital signatures verified
08:31:58:WU01:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -cpi state.cpt -cpt 15 -nt 3
08:31:58:WU01:FS00:0xa7:Steps: first=5000000 total=1250000
08:31:59:WU00:FS00:Upload complete
08:32:00:WU01:FS00:0xa7:Completed 874681 out of 1250000 steps (69%)
08:32:03:WU00:FS00:Server responded WORK_ACK (400)
08:32:03:WU00:FS00:Final credit estimate, 4927.00 points
08:32:03:WU00:FS00:Cleaning up
08:32:33:WU01:FS00:0xa7:Completed 875000 out of 1250000 steps (70%)
08:54:12:WU01:FS00:0xa7:Completed 887500 out of 1250000 steps (71%)
09:15:53:WU01:FS00:0xa7:Completed 900000 out of 1250000 steps (72%)
09:37:34:WU01:FS00:0xa7:Completed 912500 out of 1250000 steps (73%)
09:59:16:WU01:FS00:0xa7:Completed 925000 out of 1250000 steps (74%)
10:20:58:WU01:FS00:0xa7:Completed 937500 out of 1250000 steps (75%)
10:42:36:WU01:FS00:0xa7:Completed 950000 out of 1250000 steps (76%)
11:04:21:WU01:FS00:0xa7:Completed 962500 out of 1250000 steps (77%)
11:26:01:WU01:FS00:0xa7:Completed 975000 out of 1250000 steps (78%)
11:47:44:WU01:FS00:0xa7:Completed 987500 out of 1250000 steps (79%)
12:09:23:WU01:FS00:0xa7:Completed 1000000 out of 1250000 steps (80%)
12:30:59:WU01:FS00:0xa7:Completed 1012500 out of 1250000 steps (81%)
12:52:33:WU01:FS00:0xa7:Completed 1025000 out of 1250000 steps (82%)
13:05:19:104:127.0.0.1:New Web connection
*********************** Log Started 2019-09-10T00:50:04Z ***********************
00:50:04:************************* Folding@home Client *************************
00:50:04:        Website: https://foldingathome.org/
00:50:04:      Copyright: (c) 2009-2018 foldingathome.org
00:50:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:50:04:           Args:
00:50:04:         Config: C:\Users\bobb1\AppData\Roaming\FAHClient\config.xml
00:50:04:******************************** Build ********************************
00:50:04:        Version: 7.5.1
00:50:04:           Date: May 11 2018
00:50:04:           Time: 13:06:32
00:50:04:     Repository: Git
00:50:04:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:50:04:         Branch: master
00:50:04:       Compiler: Visual C++ 2008
00:50:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:50:04:       Platform: win32 10
00:50:04:           Bits: 32
00:50:04:           Mode: Release
00:50:04:******************************* System ********************************
00:50:04:            CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:50:04:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:50:04:           CPUs: 8
00:50:04:         Memory: 15.89GiB
00:50:04:    Free Memory: 14.31GiB
00:50:04:        Threads: WINDOWS_THREADS
00:50:04:     OS Version: 6.2
00:50:04:    Has Battery: true
00:50:04:     On Battery: false
00:50:04:     UTC Offset: -5
00:50:04:            PID: 4472
00:50:04:            CWD: C:\Windows\system32
00:50:04:             OS: Windows 10 Home
00:50:04:        OS Arch: AMD64
00:50:04:           GPUs: 0
00:50:04:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
00:50:04:                 specified module could not be found.
00:50:04:
00:50:04:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
00:50:04:  Win32 Service: true
00:50:04:***********************************************************************
00:50:04:<config>
00:50:04:  <!-- Folding Slot Configuration -->
00:50:04:  <cause v='ALZHEIMERS'/>
00:50:04:
00:50:04:  <!-- User Information -->
00:50:04:  <passkey v='********************************'/>
00:50:04:  <team v='1'/>
00:50:04:  <user v='Robby'/>
00:50:04:
00:50:04:  <!-- Folding Slots -->
00:50:04:  <slot id='0' type='CPU'/>
00:50:04:</config>
00:50:04:Trying to access database...
00:50:04:Successfully acquired database lock
00:50:04:Enabled folding slot 00: READY cpu:3
00:50:05:ERROR:Exception: Failed to register systray icon: Unspecified error
00:50:05:WU01:FS00:Starting
00:50:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4472 -checkpoint 15 -np 3 -service
00:50:06:WU01:FS00:Started FahCore on PID 5900
00:50:06:WU01:FS00:Core PID:6028
00:50:06:WU01:FS00:FahCore 0xa7 started
00:50:10:WU01:FS00:0xa7:*********************** Log Started 2019-09-10T00:50:09Z ***********************
00:50:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:50:10:WU01:FS00:0xa7:       Type: 0xa7
00:50:10:WU01:FS00:0xa7:       Core: Gromacs
00:50:10:WU01:FS00:0xa7:    Website: https://foldingathome.org/
00:50:10:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:50:10:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:50:10:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 5900 -checkpoint 15 -np 3
00:50:10:WU01:FS00:0xa7:             -service
00:50:10:WU01:FS00:0xa7:     Config: <none>
00:50:10:WU01:FS00:0xa7:************************************ Build *************************************
00:50:10:WU01:FS00:0xa7:    Version: 0.0.17
00:50:10:WU01:FS00:0xa7:       Date: Apr 25 2018
00:50:10:WU01:FS00:0xa7:       Time: 11:02:26
00:50:10:WU01:FS00:0xa7: Repository: Git
00:50:10:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
00:50:10:WU01:FS00:0xa7:     Branch: master
00:50:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:50:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:50:10:WU01:FS00:0xa7:   Platform: win32 10
00:50:10:WU01:FS00:0xa7:       Bits: 32
00:50:10:WU01:FS00:0xa7:       Mode: Release
00:50:10:WU01:FS00:0xa7:       SIMD: sse2
00:50:10:WU01:FS00:0xa7:************************************ System ************************************
00:50:10:WU01:FS00:0xa7:        CPU: Unknown
00:50:10:WU01:FS00:0xa7:     CPU ID:
00:50:10:WU01:FS00:0xa7:       CPUs: 8
00:50:10:WU01:FS00:0xa7:     Memory: 15.89GiB
00:50:10:WU01:FS00:0xa7:Free Memory: 14.20GiB
00:50:10:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:50:10:WU01:FS00:0xa7: OS Version: 6.2
00:50:10:WU01:FS00:0xa7:Has Battery: true
00:50:10:WU01:FS00:0xa7: On Battery: false
00:50:10:WU01:FS00:0xa7: UTC Offset: -5
00:50:10:WU01:FS00:0xa7:        PID: 6028
00:50:10:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
00:50:10:WU01:FS00:0xa7:         OS: Windows 10 Home
00:50:10:WU01:FS00:0xa7:    OS Arch: AMD64
00:50:10:WU01:FS00:0xa7:********************************************************************************
00:50:10:WU01:FS00:0xa7:Project: 14104 (Run 0, Clone 59, Gen 19)
00:50:10:WU01:FS00:0xa7:Unit: 0x000000170002894b5d5d9741a67ec63d
00:50:10:WU01:FS00:0xa7:Digital signatures verified
00:50:13:WU01:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 15 -nt 3
00:50:19:WU01:FS00:0xa7:Steps: first=23750000 total=1250000
00:50:23:WU01:FS00:0xa7:Completed 1057782 out of 1250000 steps (84%)
00:52:47:WU01:FS00:0xa7:Completed 1062500 out of 1250000 steps (85%)
00:59:19:WU01:FS00:0xa7:Completed 1075000 out of 1250000 steps (86%)
01:05:26:WU01:FS00:0xa7:Completed 1087500 out of 1250000 steps (87%)
01:11:20:WU01:FS00:0xa7:Completed 1100000 out of 1250000 steps (88%)
01:16:59:WU01:FS00:0xa7:Completed 1112500 out of 1250000 steps (89%)
01:22:45:WU01:FS00:0xa7:Completed 1125000 out of 1250000 steps (90%)
01:28:00:WU01:FS00:0xa7:Completed 1137500 out of 1250000 steps (91%)
01:33:24:WU01:FS00:0xa7:Completed 1150000 out of 1250000 steps (92%)
01:38:50:WU01:FS00:0xa7:Completed 1162500 out of 1250000 steps (93%)
01:43:58:WU01:FS00:0xa7:Completed 1175000 out of 1250000 steps (94%)
01:49:08:WU01:FS00:0xa7:Completed 1187500 out of 1250000 steps (95%)
01:54:17:WU01:FS00:0xa7:Completed 1200000 out of 1250000 steps (96%)
01:59:23:WU01:FS00:0xa7:Completed 1212500 out of 1250000 steps (97%)
02:04:32:WU01:FS00:0xa7:Completed 1225000 out of 1250000 steps (98%)
02:09:40:WU01:FS00:0xa7:Completed 1237500 out of 1250000 steps (99%)
02:09:41:WU00:FS00:Connecting to 65.254.110.245:8080
02:09:41:WU00:FS00:Assigned to work server 155.247.166.220
02:09:41:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 155.247.166.220
02:09:41:WU00:FS00:Connecting to 155.247.166.220:8080
02:09:41:WU00:FS00:Downloading 1.50KiB
02:09:41:WU00:FS00:Download complete
02:09:41:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8696 run:0 clone:522 gen:41 core:0xa4 unit:0x000000310002894c5d66819713082715
02:14:47:WU01:FS00:0xa7:Completed 1250000 out of 1250000 steps (100%)
02:14:48:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
02:14:48:WU01:FS00:0xa7:Saving result file frame19.trr
02:14:49:WU01:FS00:0xa7:Saving result file md.log
02:14:49:WU01:FS00:0xa7:Saving result file science.log
02:14:49:WU01:FS00:0xa7:Saving result file traj_comp.xtc
02:14:49:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:14:50:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:14:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14104 run:0 clone:59 gen:19 core:0xa7 unit:0x000000170002894b5d5d9741a67ec63d
02:14:50:WU01:FS00:Uploading 9.55MiB to 155.247.166.219
02:14:50:WU00:FS00:Starting
02:14:50:WU01:FS00:Connecting to 155.247.166.219:8080
02:14:50:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 4472 -checkpoint 15 -np 3 -service
02:14:50:WU00:FS00:Started FahCore on PID 11900
02:14:52:WU00:FS00:Core PID:6656
02:14:52:WU00:FS00:FahCore 0xa4 started
02:14:52:WU00:FS00:0xa4:
02:14:52:WU00:FS00:0xa4:*------------------------------*
02:14:52:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:14:52:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:14:52:WU00:FS00:0xa4:Preparing to commence simulation
02:14:52:WU00:FS00:0xa4:- Looking at optimizations...
02:14:52:WU00:FS00:0xa4:- Created dyn
02:14:52:WU00:FS00:0xa4:- Files status OK
02:14:52:WU00:FS00:0xa4:Failed: Unrecognized scheme 1024
02:14:52:WU00:FS00:0xa4:Error: Could not open work file
02:14:52:WU00:FS00:0xa4:Folding@home Core Shutdown: FILE_IO_ERROR
02:14:52:WU01:FS00:Upload complete
02:14:52:WARNING:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
02:14:52:WARNING:WU00:FS00:Fatal error, dumping
02:14:52:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:8696 run:0 clone:522 gen:41 core:0xa4 unit:0x000000310002894c5d66819713082715
02:14:52:WU00:FS00:Connecting to 155.247.166.220:8080
02:14:53:WU02:FS00:Connecting to 65.254.110.245:8080
02:14:53:WU01:FS00:Server responded WORK_ACK (400)
02:14:53:WU01:FS00:Final credit estimate, 5271.00 points
02:14:53:WU01:FS00:Cleaning up
02:14:53:WU00:FS00:Server responded WORK_ACK (400)
02:14:54:WU00:FS00:Cleaning up
02:14:54:WU02:FS00:Assigned to work server 155.247.166.220
02:14:54:WU02:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.166.220
02:14:54:WU02:FS00:Connecting to 155.247.166.220:8080
02:14:55:WU02:FS00:Downloading 1.84MiB
02:14:56:WU02:FS00:Download complete
02:14:56:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13794 run:2 clone:90 gen:29 core:0xa7 unit:0x0000001e0002894c5d5d939d56854273
02:14:57:WU02:FS00:Starting
02:14:57:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4472 -checkpoint 15 -np 3 -service
02:14:57:WU02:FS00:Started FahCore on PID 10864
02:14:57:WU02:FS00:Core PID:12452
02:14:57:WU02:FS00:FahCore 0xa7 started
02:14:58:WU02:FS00:0xa7:*********************** Log Started 2019-09-10T02:14:57Z ***********************
02:14:58:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:14:58:WU02:FS00:0xa7:       Type: 0xa7
02:14:58:WU02:FS00:0xa7:       Core: Gromacs
02:14:58:WU02:FS00:0xa7:    Website: https://foldingathome.org/
02:14:58:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
02:14:58:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:14:58:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 10864 -checkpoint 15 -np
02:14:58:WU02:FS00:0xa7:             3 -service
02:14:58:WU02:FS00:0xa7:     Config: <none>
02:14:58:WU02:FS00:0xa7:************************************ Build *************************************
02:14:58:WU02:FS00:0xa7:    Version: 0.0.17
02:14:58:WU02:FS00:0xa7:       Date: Apr 25 2018
02:14:58:WU02:FS00:0xa7:       Time: 11:02:26
02:14:58:WU02:FS00:0xa7: Repository: Git
02:14:58:WU02:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
02:14:58:WU02:FS00:0xa7:     Branch: master
02:14:58:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
02:14:58:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:14:58:WU02:FS00:0xa7:   Platform: win32 10
02:14:58:WU02:FS00:0xa7:       Bits: 32
02:14:58:WU02:FS00:0xa7:       Mode: Release
02:14:58:WU02:FS00:0xa7:       SIMD: sse2
02:14:58:WU02:FS00:0xa7:************************************ System ************************************
02:14:58:WU02:FS00:0xa7:        CPU: Unknown
02:14:58:WU02:FS00:0xa7:     CPU ID:
02:14:58:WU02:FS00:0xa7:       CPUs: 8
02:14:58:WU02:FS00:0xa7:     Memory: 15.89GiB
02:14:58:WU02:FS00:0xa7:Free Memory: 14.04GiB
02:14:58:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
02:14:58:WU02:FS00:0xa7: OS Version: 6.2
02:14:58:WU02:FS00:0xa7:Has Battery: true
02:14:58:WU02:FS00:0xa7: On Battery: false
02:14:58:WU02:FS00:0xa7: UTC Offset: -5
02:14:58:WU02:FS00:0xa7:        PID: 12452
02:14:58:WU02:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
02:14:58:WU02:FS00:0xa7:         OS: Windows 10 Home
02:14:58:WU02:FS00:0xa7:    OS Arch: AMD64
02:14:58:WU02:FS00:0xa7:********************************************************************************
02:14:58:WU02:FS00:0xa7:Project: 13794 (Run 2, Clone 90, Gen 29)
02:14:58:WU02:FS00:0xa7:Unit: 0x0000001e0002894c5d5d939d56854273
02:14:58:WU02:FS00:0xa7:Reading tar file core.xml
02:14:58:WU02:FS00:0xa7:Reading tar file frame29.tpr
02:14:58:WU02:FS00:0xa7:Digital signatures verified
02:14:58:WU02:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpt 15 -nt 3
02:14:58:WU02:FS00:0xa7:Steps: first=72500000 total=2500000
02:14:59:WU02:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
02:23:11:WU02:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
02:31:26:WU02:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
02:39:36:WU02:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
To get to the top of the log either click Refresh which reloads the log into FAHControl from the beginning, or navigate to the log file using the directions in the topic linked to in Bruce's signature and use a text editor.
Robby_Firefox wrote:how does one set the parameters: "next-unit-percentage" = "100"? I suppose it is in the expert settings?
This parameter can either be added to the slot options, and will only be in effect for that slot, or added to the expert settings and apply to all folding slots. Since you have folding set up as a service, you can only do CPU folding and have a single slot, it does not matter which.
As for your signature, you have entered it incorrectly for use in a sig. Please see the directions on the EOC site - https://folding.extremeoverclocking.com/?nav=IMAGES. For mine I followed the steps for "Adding Your Stats To A Forum Signature" and used the "Without a hyperlink" option.
A followup to your followup. :wink:
Robby_Firefox wrote:A follow up...
I don't understand why the client decided to switch WU, but it's probably good that it did. Finishing the last 3% of the Project 13794 before embarking on a full WU was not in the best interest of either FAH or your points but as I said earlier, I don't understand why it did that but finishing a 25 minute job before spending another 6 hours on 14188 was a good choice.
Yes, finishing a job earlier rather than later will earn more points.
According to your log (re-quoted below) it took 7 seconds to download a new WU.
After the new WU was downloaded,we can compare two possibilities. After the error occurred, it would have been desirable for FAH to resume work on the earlier WU and spend the 25 minutes to finish it before starting the newly downloaded WU. On the other hand, if we assume that no such error occurred, the newly downloaded WU would have waited about 10m12s (to finish the first WU from 99% to 100%) which would certainly been reasonable if the download had taken a number of minutes.
Assuming you do set next-unit-percentage to 100 (per Joe_H's instructions) the 7 second download might have started (below) at 08:31:55 and still completed only a few seconds after it was needed at 08:31:57
08:31:57:WU01:FS00:FahCore 0xa7 started[/code]
Taking advantage of the information revealed by your report, I have written up an enhancement suggestion ... which is being debated at
https://github.com/FoldingAtHome/fah-issues/issues/1296
Robby_Firefox
Thanks again to bruce and Joe_H for your helpful advice. The suggestion of default setting download to 100 seems like a good call. A mention should be noted that if you are on a slow Internet connection, do not use the new default if you go that way in a future FAH release.
Am still having trouble with my signature (all I did was change my ID number) and it has not been happy. I will try to work with this more in a couple of days. Am working nights at the moment and do not have time to work with this like I want to.
Thanks,
Robby
