Please Add Radeon Pro WX 7100
Hubukai
Post by Hubukai »
0x8086:0xa36d:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0xa32c:0:27:0:Intel Corporation:Intel(R) PCI Express Root Port #21 - A32C
0x1002:0x67c4:1:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:AMD Radeon (TM) Pro WX 7100 Graphics
0x8086:0x3e30:0:0:0:Intel Corporation:PCI standard host CPU bridge
0x8086:0xa352:0:23:0:Intel Corporation:Standard SATA AHCI Controller
0x8086:0xa360:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0xa323:0:31:4:Intel Corporation:Intel(R) SMBus - A323
0x8086:0xa379:0:18:0:Intel Corporation:Intel(R) Thermal Subsystem - A379
0x8086:0xa330:0:29:0:Intel Corporation:Intel(R) PCI Express Root Port #9 - A330
0x8086:0xa36f:0:20:2:Intel Corporation:PCI standard RAM Controller
0x8086:0xa324:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - A324
0x10ec:0x8168:3:0:0:Realtek Semiconductor Co., Ltd.:Realtek Gaming GbE Family Controller
0x8086:0x1901:0:1:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xa308:0:31:0:Intel Corporation:Intel(R) 300 Series Chipset Family LPC Controller - A308
0x8086:0xa348:0:31:3:Intel Corporation:High Definition Audio Controller
0x8086:0xf1a6:2:0:0:Intel Corporation:Standard NVM Express Controller
Re: Please Add Radeon Pro WX 7100
It is a 4th gen GCN device with Double Precision from 2016, so it should fold. With 2304 shaders,it may even be fast
Given our recent experience with the driver for the 5700 XT, have you tested it with FAHBench?
Did you install OpenCL 1.1 or >=1.2? Which AMD driver are you using?
I await your replies. Meantime, I've temporarily installed it as an UNSUPPORTED device so if you try to use it with FAHClient, you'll get the same error described in the other topic so there's no point it trying to use it until you've confirmed it works in FAHBench.
We can hope that AMD's driver problems are limited to the Polaris 10 and not the Navi 10 -- if that's what is going on.
See also the 5 page discussion here: viewtopic.php?f=83&t=31710
Post by foldy »
Hi Bruce this is an older AMD Polaris GPU not related to new AMD 5700 XT. So you can enable it like the other AMD Polaris GPUs.
Done
