I understand that the CPUId is assigned when a new machine
first contacts the work/assignment servers and is unique to each user/machine
CPUId = UserID+MachineID
Is there any way to determine what the CPUId number is?
running Linux command line: FAHClient --info
does not reveal the machine CPUId
Howto Reveal CPUId ?
Re: Howto Reveal CPUId ?
By the way, that app presents the CPUid in byte-reversed ascii, making it difficult to interpret the formula CPUId = UserID+MachineID since the MachineID is added to the left-most byte.
MachineID = slot number
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
Yes, that does reveal the CUId for the last results turned in by each machine running for the user -
I was looking for a way to identify the specific machine, hopefully by discovering some type of query
on the host running FAH
39F79F5BBAAB8619 xxx.xxx.xxx.45 4 x86 Windows 13,608 1 2019-09-10 02:15:27 13779 85 3 0
C47E575DA0F8EF75 xxx.xxx.xxx.44 4 NVidia GPU Linux 27,279 1 2019-09-10 09:30:31 14184 6 78 32
8FDB605B8A17FB19 xxx.xxx.xxx.103 4 x86 Linux 7,729.81 1 2019-09-10 12:00:26 13794 15 125 9
BD41705D10D28859 xxx.xxx.xxx.231 4 x86 Linux 12,269.9 1 2019-09-10 12:00:33 13794 3 47 1
C37E575DA0F8EF75 xxx.xxx.xxx.44 4 x86 Linux 12,682.8 1 2019-09-10 13:45:22 13779 4 10 0
5FD3605B8A984975 xxx.xxx.xxx.103 4 x86 Linux 10,924.4 1 2019-09-10 13:45:28 13794 16 31 3
3C3A705D7E1FDF95 xxx.xxx.xxx.231 4 x86 Linux 17,173.2 1 2019-09-10 14:30:29 13779 23 2 2
3AF79F5BBAAB8619 xxx.xxx.xxx.45 4 NVidia GPU Windows 116,204 1 2019-09-10 15:15:32 14178 68 0 176
B33E705D38DAE38C xxx.xxx.xxx.231 4 x86 Linux 11,772.1 1 2019-09-10 15:30:24 13794 12 33 3
C969555BC6C53247 xxx.xxx.xxx.175 4 x86 Linux 11,863 1 2019-09-10 15:30:27 13779 19 0 1
778B325D2A9896A6 xxx.xxx.xxx.175 4 x86 Linux 11,387 1 2019-09-10 16:45:34 13779 8 2 2
4521045C04B2323E xxx.xxx.xxx.138 4 x86 Linux 8,221.5 1 2019-09-10 17:00:30 14181 9 9 52
The first two digits = the GPU slot number.
The next 14 digits = your PC number.
I'm not sure if you reinstall FAH if any numbers remain the same. You'll probably get a completely new machine ID.
You do have access to the logs on each machine. Each line on that table shows the PRCG of a recent WU.
When you reinstall, a new CPUID is assigned. When a machine is overwritten, it doesn't notify the server that no more WUs will be assignee/completed by the old CPUID. That's why the stats say WUs withing the last NN days. Eventually the old CPUID times out.
All of the bits are part of the PC number (CPUID) for slot 0. For slot 1, add 1 to the first two digits. For slot 2, add 2 to that left-most byte. For slot 3, add three....
Not exactly.The first two digits = the GPU slot number.
