Fedora 30 NVIDIA: 7 GP107 [GeForce GTX 1050 ti]
wdanwatts
Post by wdanwatts »
I have an AMD Phenom II X2 545 CPU running Fedora 30 which until I had an unfortunate power loss that killed my OS was running the GTX 1050 with CUDA 10.1 and getting ~ 4.5 million points per month. Since rebuilding (from scratch) the system, I now get:
22:20:25:WU00:FS02:Connecting to 65.254.110.245:8080
22:20:26:WU00:FS02:Assigned to work server 128.252.203.4
22:20:26:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GP107 [GeForce GTX 1050 Ti] 2138 from 128.252.203.4
22:20:26:WU00:FS02:Connecting to 128.252.203.4:8080
22:20:28:WU00:FS02:Downloading 1.79MiB
22:20:28:WU00:FS02:Download complete
22:20:28:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2753 gen:247 core:0x21 unit:0x0000015980fccb045b3f7913c01b5b8a
22:20:28:WU00:FS02:Starting
22:20:28:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 705 -lifeline 1232 -checkpoint 30 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
22:20:28:WU00:FS02:Started FahCore on PID 6248
22:20:28:WU00:FS02:Core PID:6252
22:20:28:WU00:FS02:FahCore 0x21 started
22:20:29:WU00:FS02:0x21:*********************** Log Started 2019-09-07T22:20:28Z ***********************
22:20:29:WU00:FS02:0x21:Project: 13816 (Run 0, Clone 2753, Gen 247)
22:20:29:WU00:FS02:0x21:Unit: 0x0000015980fccb045b3f7913c01b5b8a
22:20:29:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
22:20:29:WU00:FS02:0x21:Machine: 2
22:20:29:WU00:FS02:0x21:Reading tar file core.xml
22:20:29:WU00:FS02:0x21:Reading tar file integrator.xml
22:20:29:WU00:FS02:0x21:Reading tar file state.xml
22:20:29:WU00:FS02:0x21:Reading tar file system.xml
22:20:29:WU00:FS02:0x21:Digital signatures verified
22:20:29:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
22:20:29:WU00:FS02:0x21:Version 0.0.20
22:20:29:WU00:FS02:0x21:ERROR:126: Bad platformId size.
22:20:29:WU00:FS02:0x21:Saving result file logfile_01.txt
22:20:29:WU00:FS02:0x21:Saving result file log.txt
22:20:29:WU00:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
22:20:29:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:20:30:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:2753 gen:247 core:0x21 unit:0x0000015980fccb045b3f7913c01b5b8a
What should I do? Where should I look?
Re: Fedora 30 NVIDIA: 7 GP107 [GeForce GTX 1050 ti]
You should post the first 200 lines of your log, which shows the configuration. This will give us many hints, I suspect you have not installed OpenCL off the Nvidia Driver but I could be all wet without the log for hints.
wdanwatts
Post by wdanwatts »
It looks like your insight was correct. Do you have any idea where I can find the OpenCL and where F@H looks for it (to ensure that it is properly ensconced on the system)?
I found that ocl-icd-devel should have libOpenCL.so so I installed it. I get the same results.
Where does FAHClient look for the library?
*********************** Log Started 2019-09-08T10:16:49Z ***********************
10:16:49:************************* Folding@home Client *************************
10:16:49:      Website: https://foldingathome.org/
10:16:49:    Copyright: (c) 2009-2018 foldingathome.org
10:16:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:16:49:         Args: --child --lifeline 1240 /etc/fahclient/config.xml --run-as
10:16:49:               fahclient --pid-file=/var/run/fahclient.pid --daemon
10:16:49:       Config: /etc/fahclient/config.xml
10:16:49:******************************** Build ********************************
10:16:49:      Version: 7.5.1
10:16:49:         Date: May 12 2018
10:16:49:         Time: 22:51:07
10:16:49:   Repository: Git
10:16:49:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:16:49:       Branch: master
10:16:49:     Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
10:16:49:      Options: -std=gnu++98 -O3 -funroll-loops
10:16:49:     Platform: linux2 4.14.0-3-amd64
10:16:49:         Bits: 64
10:16:49:         Mode: Release
10:16:49:******************************* System ********************************
10:16:49:          CPU: AMD Phenom(tm) II X2 545 Processor
10:16:49:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
10:16:49:         CPUs: 2
10:16:49:       Memory: 3.85GiB
10:16:49:  Free Memory: 3.22GiB
10:16:49:      Threads: POSIX_THREADS
10:16:49:   OS Version: 5.2
10:16:49:  Has Battery: false
10:16:49:   On Battery: false
10:16:49:   UTC Offset: -5
10:16:49:          PID: 1242
10:16:49:          CWD: /var/lib/fahclient
10:16:49:           OS: Linux 5.2.11-200.fc30.x86_64 x86_64
10:16:49:      OS Arch: AMD64
10:16:49:         GPUs: 1
10:16:49:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
10:16:49:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
10:16:49:       OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
10:16:49:               libOpenCL.so: cannot open shared object file: No such file or
10:16:49:               directory
10:16:49:***********************************************************************
10:16:49:<config>
10:16:49:  <!-- Folding Core -->
10:16:49:  <checkpoint v='30'/>
10:16:49:
10:16:49:  <!-- Folding Slot Configuration -->
10:16:49:  <gpu v='false'/>
10:16:49:
10:16:49:  <!-- Network -->
10:16:49:  <proxy v=':8080'/>
10:16:49:
10:16:49:  <!-- Slot Control -->
10:16:49:  <power v='full'/>
10:16:49:
10:16:49:  <!-- User Information -->
10:16:49:  <passkey v='********************************'/>
10:16:49:  <team v='59478'/>
10:16:49:  <user v='wdw'/>
10:16:49:
10:16:49:  <!-- Folding Slots -->
10:16:49:  <slot id='0' type='CPU'>
10:16:49:    <paused v='true'/>
10:16:49:  </slot>
10:16:49:  <slot id='2' type='GPU'>
10:16:49:    <opencl-index v='0'/>
10:16:49:  </slot>
10:16:49:</config>
10:16:49:Switching to user fahclient
10:16:49:Trying to access database...
10:16:49:Successfully acquired database lock
10:16:49:Enabled folding slot 00: PAUSED cpu:1 (by user)
10:16:49:Enabled folding slot 02: PAUSED gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 (by user)
10:18:27:FS00:Unpaused
10:18:27:FS02:Unpaused
10:18:27:WU01:FS00:Starting
10:18:27:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1242 -checkpoint 30 -np 1
10:18:27:WU01:FS00:Started FahCore on PID 1976
10:18:27:WU01:FS00:Core PID:1980
10:18:27:WU01:FS00:FahCore 0xa7 started
10:18:27:WU02:FS02:Starting
10:18:27:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 705 -lifeline 1242 -checkpoint 30 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
10:18:27:WU02:FS02:Started FahCore on PID 1981
10:18:27:WU02:FS02:Core PID:1985
10:18:27:WU02:FS02:FahCore 0x21 started
10:18:28:WU01:FS00:0xa7:*********************** Log Started 2019-09-08T10:18:28Z ***********************
10:18:28:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:18:28:WU01:FS00:0xa7:       Type: 0xa7
10:18:28:WU01:FS00:0xa7:       Core: Gromacs
10:18:28:WU01:FS00:0xa7:    Website: https://foldingathome.org/
10:18:28:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
10:18:28:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:18:28:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 1976 -checkpoint 30 -np 1
10:18:28:WU01:FS00:0xa7:     Config: <none>
10:18:28:WU01:FS00:0xa7:************************************ Build *************************************
10:18:28:WU01:FS00:0xa7:    Version: 0.0.17
10:18:28:WU01:FS00:0xa7:       Date: Apr 27 2018
10:18:28:WU01:FS00:0xa7:       Time: 19:09:25
10:18:28:WU01:FS00:0xa7: Repository: Git
10:18:28:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
10:18:28:WU01:FS00:0xa7:     Branch: master
10:18:28:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
10:18:28:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
10:18:28:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
10:18:28:WU01:FS00:0xa7:       Bits: 64
10:18:28:WU01:FS00:0xa7:       Mode: Release
10:18:28:WU01:FS00:0xa7:       SIMD: sse2
10:18:28:WU01:FS00:0xa7:************************************ System ************************************
10:18:28:WU01:FS00:0xa7:        CPU: AMD Phenom(tm) II X2 545 Processor
10:18:28:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
10:18:28:WU01:FS00:0xa7:       CPUs: 2
10:18:28:WU01:FS00:0xa7:     Memory: 3.85GiB
10:18:28:WU01:FS00:0xa7:Free Memory: 2.15GiB
10:18:28:WU01:FS00:0xa7:    Threads: POSIX_THREADS
10:18:28:WU01:FS00:0xa7: OS Version: 5.2
10:18:28:WU01:FS00:0xa7:Has Battery: false
10:18:28:WU01:FS00:0xa7: On Battery: false
10:18:28:WU01:FS00:0xa7: UTC Offset: -5
10:18:28:WU01:FS00:0xa7:        PID: 1980
10:18:28:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
10:18:28:WU01:FS00:0xa7:         OS: Linux 5.2.11-200.fc30.x86_64 x86_64
10:18:28:WU01:FS00:0xa7:    OS Arch: AMD64
10:18:28:WU01:FS00:0xa7:********************************************************************************
10:18:28:WU01:FS00:0xa7:Project: 14189 (Run 5, Clone 143, Gen 0)
10:18:28:WU01:FS00:0xa7:Unit: 0x000000010002894b5d543dc151190fe5
10:18:28:WU01:FS00:0xa7:Digital signatures verified
10:18:28:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 30 -nt 1
10:18:30:WU02:FS02:0x21:*********************** Log Started 2019-09-08T10:18:30Z ***********************
10:18:30:WU02:FS02:0x21:Project: 14229 (Run 339, Clone 0, Gen 5)
10:18:30:WU02:FS02:0x21:Unit: 0x0000000580fccb0a5d6553d932a6f243
10:18:30:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
10:18:30:WU02:FS02:0x21:Machine: 2
10:18:30:WU02:FS02:0x21:Reading tar file core.xml
10:18:30:WU02:FS02:0x21:Reading tar file integrator.xml
10:18:30:WU02:FS02:0x21:Reading tar file state.xml
10:18:31:WU01:FS00:0xa7:Steps: first=0 total=1250000
10:18:32:WU02:FS02:0x21:Reading tar file system.xml
10:18:32:WU02:FS02:0x21:Digital signatures verified
10:18:32:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
10:18:32:WU02:FS02:0x21:Version 0.0.20
10:18:33:WU01:FS00:0xa7:Completed 242082 out of 1250000 steps (19%)
10:18:35:WU02:FS02:0x21:ERROR:126: Bad platformId size.
10:18:35:WU02:FS02:0x21:Saving result file logfile_01.txt
10:18:35:WU02:FS02:0x21:Saving result file log.txt
10:18:35:WU02:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
10:18:35:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
10:18:36:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:14229 run:339 clone:0 gen:5 core:0x21 unit:0x0000000580fccb0a5d6553d932a6f243
10:18:36:WU02:FS02:Uploading 6.50KiB to 128.252.203.10
10:18:36:WU02:FS02:Connecting to 128.252.203.10:8080
10:18:36:WU02:FS02:Upload complete
Not being a Linux user, I am in over my head, but there are hints that the OpenCL driver is part of the CUDA Toolkit.
https://www.if-not-true-then-false.com/ ... on-fedora/
This is for an older version, version numbers will change.
Hopefully a linux user will drop by
On my Ubuntu systems, I've successfully installed the proprietary drivers in the form of a downloaded .deb file and they include the required elements of CUDA and OpenCL. I have found .deb versions of only a few versions of those drivers for my distro, but they are straightforward and they do work.
I have also corrupted my Linux by trying to use the .run file downloaded directly from nVidia.com. Apparently they work on the server version of Linux but not the version with the GUI. There are documented procedures on how to temporarily shut down LightDM (or whatever X display manager that you're running) before using the .run file. I have not used that method.
wdanwatts
Post by wdanwatts »
Thanks for the hints.
What steams me is the system that go toasted, never stated that it had OpenCL, just CUDA, and it worked fine. Grr!
Oh, well, on to THIS challenge.
I'll post again if/when I make progress or have my fill of frustration.
While I fiddle, can/will someone let me know where FAHClient looks for the OpenCL library?
FAHClient looks for video drivers -- which once included OpenCL. Installing the drivers from either AMD or nVidia used to always include OpenCL. Apparently AMD no longer does. As far as I know, nVidia still does unless you (optionally) exclude it. When WindowsUpdate installs a new version of the nVidia drivers, they do NOT include OpenCL
It seems that support for OpenCL across the entire industry is gradually decaying. FAH probably should be redesigned to either use some alternative or to insure that there's a working version of OpenCL on each system that includes a supported GPU.
wdanwatts
Post by wdanwatts »
Where (what path or set of paths) does a Linux box version of FAHClient look for the OpenCL driver?
The one I got is in /usr/lib64/libOpenCL.so but it doesn't appear to be seen/used/helpful by the F@H software.
Is there someone who can/will let me know how to get clGetDeviceIDs() to NOT return -1 :?:
goodyca
Post by goodyca »
I'm running Fedora 30. What I do is install the Nvidia driver and CUDA from RPMFusion. I have tried in the past to just install OpenCL, but was never able to get F@H to find it.
wdanwatts
Post by wdanwatts »
Thanks for the RPMFusion approach. I will try it and report on the upshot of that tack (I may have questions on specific packages). If it DOES work (which is likely how I folded before my system loss) then it means that FAHClient DOESN'T need OpenCL and can use a CUDA-ONLY path.
Actually it doesn't mean that. nVidia has packaged its OpenCL support with it CUDA support. How that gets broken up depends on which linux distro you are dealing with, some separate the two and others leave them together.
When FAH design a FAHCore to analyze the WUs of a project, it can compile it to interface with OpenCL or with CUDA (and potentially other APIs). In general FAH always compiles their FAHCores to work with OpenCL -- especially since OpenCL is supported by both nVidia and AMD. If it's compiled against the CUDA API, the FAHCore would not be able to be used with AMD GPUs. (CUDA is proprietary for nVidia only.)
Either the OpenCL api or the CUDA api can be installed on your system. OpenCL is available from several sources. if you obtain it from nVidia, it is always packaged with CUDA. (and they'd probably be happy if FAH excluded competition from AMD, but we don't want to do that.) It is reasonable to assume that the nVidia version of OpenCL sits on top of their functional CUDA support package rather than operating independently. (The OpenCL version that you could have installed from khronos.org would have been self-contained.)
wdanwatts
Post by wdanwatts »
Well! The RPMFusion approach suggested by goodyca worked!
After I
1) removed other software repositories for Nvidia drivers,
2) enabled the RPMFusion software repository,
3) followed the steps delineated at https://rpmfusion.org/Howto/NVIDIA#Curr ... ro.2FTesla
3a) removed any conflicting updates I had tried
4) rebooted
the system recognized the GPU and started running on it!
*********************** Log Started 2019-09-10T09:22:12Z ***********************
09:22:12:************************* Folding@home Client *************************
09:22:12:      Website: https://foldingathome.org/
09:22:12:    Copyright: (c) 2009-2018 foldingathome.org
09:22:12:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:22:12:         Args: --child --lifeline 1287 /etc/fahclient/config.xml --run-as
09:22:12:               fahclient --pid-file=/var/run/fahclient.pid --daemon
09:22:12:       Config: /etc/fahclient/config.xml
09:22:12:******************************** Build ********************************
09:22:12:      Version: 7.5.1
09:22:12:         Date: May 12 2018
09:22:12:         Time: 22:51:07
09:22:12:   Repository: Git
09:22:12:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:22:12:       Branch: master
09:22:12:     Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
09:22:12:      Options: -std=gnu++98 -O3 -funroll-loops
09:22:12:     Platform: linux2 4.14.0-3-amd64
09:22:12:         Bits: 64
09:22:12:         Mode: Release
09:22:12:******************************* System ********************************
09:22:12:          CPU: AMD Phenom(tm) II X2 545 Processor
09:22:12:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
09:22:12:         CPUs: 2
09:22:12:       Memory: 3.85GiB
09:22:12:  Free Memory: 3.09GiB
09:22:12:      Threads: POSIX_THREADS
09:22:12:   OS Version: 5.2
09:22:12:  Has Battery: false
09:22:12:   On Battery: false
09:22:12:   UTC Offset: -5
09:22:12:          PID: 1289
09:22:12:          CWD: /var/lib/fahclient
09:22:12:           OS: Linux 5.2.11-200.fc30.x86_64 x86_64
09:22:12:      OS Arch: AMD64
09:22:12:         GPUs: 1
09:22:12:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
09:22:12:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
09:22:12:       OpenCL: Not detected: clGetDeviceIDs() returned -1
09:22:12:***********************************************************************
09:22:12:<config>
09:22:12:  <!-- Folding Core -->
09:22:12:  <checkpoint v='30'/>
09:22:12:
09:22:12:  <!-- Folding Slot Configuration -->
09:22:12:  <gpu v='false'/>
09:22:12:
09:22:12:  <!-- Network -->
09:22:12:  <proxy v=':8080'/>
09:22:12:
09:22:12:  <!-- Slot Control -->
09:22:12:  <power v='full'/>
09:22:12:
09:22:12:  <!-- User Information -->
09:22:12:  <passkey v='********************************'/>
09:22:12:  <team v='59478'/>
09:22:12:  <user v='wdw'/>
09:22:12:
09:22:12:  <!-- Folding Slots -->
09:22:12:  <slot id='0' type='CPU'>
09:22:12:    <paused v='true'/>
09:22:12:  </slot>
09:22:12:  <slot id='2' type='GPU'>
09:22:12:    <opencl-index v='0'/>
09:22:12:  </slot>
09:22:12:</config>
09:22:12:Switching to user fahclient
09:22:12:Trying to access database...
09:22:12:Successfully acquired database lock
09:22:12:Enabled folding slot 00: PAUSED cpu:1 (by user)
09:22:12:Enabled folding slot 02: PAUSED gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 (by user)
09:23:05:FS00:Unpaused
09:23:05:FS02:Unpaused
09:23:05:WU01:FS00:Starting
09:23:05:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1289 -checkpoint 30 -np 1
09:23:05:WU01:FS00:Started FahCore on PID 2005
09:23:05:WU01:FS00:Core PID:2009
09:23:05:WU01:FS00:FahCore 0xa7 started
09:23:06:WU00:FS02:Connecting to 65.254.110.245:8080
09:23:07:WU00:FS02:Assigned to work server 128.252.203.10
09:23:07:WU00:FS02:Requesting new work unit for slot 02: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138 from 128.252.203.10
09:23:07:WU00:FS02:Connecting to 128.252.203.10:8080
09:23:07:WU01:FS00:0xa7:*********************** Log Started 2019-09-10T09:23:06Z ***********************
09:23:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:23:07:WU01:FS00:0xa7:       Type: 0xa7
09:23:07:WU01:FS00:0xa7:       Core: Gromacs
09:23:07:WU01:FS00:0xa7:    Website: https://foldingathome.org/
09:23:07:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:23:07:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:23:07:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2005 -checkpoint 30 -np 1
09:23:07:WU01:FS00:0xa7:     Config: <none>
09:23:07:WU01:FS00:0xa7:************************************ Build *************************************
09:23:07:WU01:FS00:0xa7:    Version: 0.0.17
09:23:07:WU01:FS00:0xa7:       Date: Apr 27 2018
09:23:07:WU01:FS00:0xa7:       Time: 19:09:25
09:23:07:WU01:FS00:0xa7: Repository: Git
09:23:07:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
09:23:07:WU01:FS00:0xa7:     Branch: master
09:23:07:WU01:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
09:23:07:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
09:23:07:WU01:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
09:23:07:WU01:FS00:0xa7:       Bits: 64
09:23:07:WU01:FS00:0xa7:       Mode: Release
09:23:07:WU01:FS00:0xa7:       SIMD: sse2
09:23:07:WU01:FS00:0xa7:************************************ System ************************************
09:23:07:WU01:FS00:0xa7:        CPU: AMD Phenom(tm) II X2 545 Processor
09:23:07:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
09:23:07:WU01:FS00:0xa7:       CPUs: 2
09:23:07:WU01:FS00:0xa7:     Memory: 3.85GiB
09:23:07:WU01:FS00:0xa7:Free Memory: 2.10GiB
09:23:07:WU01:FS00:0xa7:    Threads: POSIX_THREADS
09:23:07:WU01:FS00:0xa7: OS Version: 5.2
09:23:07:WU01:FS00:0xa7:Has Battery: false
09:23:07:WU01:FS00:0xa7: On Battery: false
09:23:07:WU01:FS00:0xa7: UTC Offset: -5
09:23:07:WU01:FS00:0xa7:        PID: 2009
09:23:07:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
09:23:07:WU01:FS00:0xa7:         OS: Linux 5.2.11-200.fc30.x86_64 x86_64
09:23:07:WU01:FS00:0xa7:    OS Arch: AMD64
09:23:07:WU01:FS00:0xa7:********************************************************************************
09:23:07:WU01:FS00:0xa7:Project: 14189 (Run 5, Clone 143, Gen 0)
09:23:07:WU01:FS00:0xa7:Unit: 0x000000010002894b5d543dc151190fe5
09:23:07:WU01:FS00:0xa7:Digital signatures verified
09:23:07:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 30 -nt 1
09:23:08:WU01:FS00:0xa7:Steps: first=0 total=1250000
09:23:10:WU00:FS02:Downloading 69.82MiB
09:23:11:WU01:FS00:0xa7:Completed 242402 out of 1250000 steps (19%)
09:23:13:Removing old file 'configs/config-20190907-144545.xml'
09:23:13:Saving configuration to /etc/fahclient/config.xml
09:23:13:<config>
09:23:13:  <!-- Folding Core -->
09:23:13:  <checkpoint v='30'/>
09:23:13:
09:23:13:  <!-- Folding Slot Configuration -->
09:23:13:  <gpu v='false'/>
09:23:13:
09:23:13:  <!-- Network -->
09:23:13:  <proxy v=':8080'/>
09:23:13:
09:23:13:  <!-- Slot Control -->
09:23:13:  <power v='full'/>
09:23:13:
09:23:13:  <!-- User Information -->
09:23:13:  <passkey v='********************************'/>
09:23:13:  <team v='59478'/>
09:23:13:  <user v='wdw'/>
09:23:13:
09:23:13:  <!-- Folding Slots -->
09:23:13:  <slot id='0' type='CPU'/>
09:23:13:  <slot id='2' type='GPU'>
09:23:13:    <opencl-index v='0'/>
09:23:13:  </slot>
09:23:13:</config>
09:23:16:WU00:FS02:Download 75.10%
09:23:17:WU00:FS02:Download complete
09:23:18:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14229 run:459 clone:0 gen:4 core:0x21 unit:0x0000000780fccb0a5d6553da6773f87b
09:23:18:WU00:FS02:Starting
09:23:18:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 705 -lifeline 1289 -checkpoint 30 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
09:23:18:WU00:FS02:Started FahCore on PID 2043
09:23:18:WU00:FS02:Core PID:2047
09:23:18:WU00:FS02:FahCore 0x21 started
09:23:18:WU00:FS02:0x21:*********************** Log Started 2019-09-10T09:23:18Z ***********************
09:23:18:WU00:FS02:0x21:Project: 14229 (Run 459, Clone 0, Gen 4)
09:23:18:WU00:FS02:0x21:Unit: 0x0000000780fccb0a5d6553da6773f87b
09:23:18:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
09:23:18:WU00:FS02:0x21:Machine: 2
09:23:18:WU00:FS02:0x21:Reading tar file core.xml
09:23:18:WU00:FS02:0x21:Reading tar file integrator.xml
09:23:18:WU00:FS02:0x21:Reading tar file state.xml
09:23:18:WU00:FS02:0x21:Reading tar file system.xml
09:23:19:WU00:FS02:0x21:Digital signatures verified
09:23:19:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
09:23:19:WU00:FS02:0x21:Version 0.0.20
09:24:22:WU00:FS02:0x21:Completed 0 out of 500000 steps (0%)
09:24:22:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
BTW the system STILL reports:
OpenCL Not Detected: clGetDeviceIDs() returned -1
while it runs the GPU. :D
[UPDATE] - I had questions about my hard drive, so I copied it to a ssd and now am running on it.
Question - After doing a system update, I had to reset the cuda index to 0 to get it to run. Is this a known behaviour?
wdanwatts
Post by wdanwatts »
According to your log:
09:22:12: GPUs: 1
... your gpu is identified as CUDA Device 0: so cuda index should be set to 0. I don't have enough information to guess why it got set to something else.
