MX250
RegularFolder
MX250
Post by RegularFolder »
Just got an new laptop with the Nvidia MX250, i see the GPU list has the MX150 however, it's not recognizing my card and giving the "On client "local" 127.0.0.1:36330: No available GPUs" error message even when i manually try to add a GPU slot.
Do you think this is the reason it's not working?
Windows 10, clean install of new drivers and FAH. Seems to only accept the DHC version of the GeForce drivers not the regular ones.
Re: MX250
If you post your log per the instructions below, we can give you a definitive answer. Without it, we can only guess.
Most likely you do not have OpenCL support on your system. Install the drivers from nvidia.com which include OpenCL.
Another possiblity: Your laptop may have Optimus dual GPU configuration. FAH does not support the iGPU if it happens to be active.
RegularFolder
Re: MX250
*********************** Log Started 2019-09-06T17:21:40Z ***********************
17:21:40:************************* Folding@home Client *************************
17:21:40:        Website: https://foldingathome.org/
17:21:40:      Copyright: (c) 2009-2018 foldingathome.org
17:21:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:21:40:           Args: --open-web-control
17:21:40:         Config: C:\Users\****\AppData\Roaming\FAHClient\config.xml
17:21:40:******************************** Build ********************************
17:21:40:        Version: 7.5.1
17:21:40:           Date: May 11 2018
17:21:40:           Time: 13:06:32
17:21:40:     Repository: Git
17:21:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:21:40:         Branch: master
17:21:40:       Compiler: Visual C++ 2008
17:21:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:21:40:       Platform: win32 10
17:21:40:           Bits: 32
17:21:40:           Mode: Release
17:21:40:******************************* System ********************************
17:21:40:            CPU: Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz
17:21:40:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
17:21:40:           CPUs: 8
17:21:40:         Memory: 15.83GiB
17:21:40:    Free Memory: 12.20GiB
17:21:40:        Threads: WINDOWS_THREADS
17:21:40:     OS Version: 6.2
17:21:40:    Has Battery: true
17:21:40:     On Battery: true
17:21:40:     UTC Offset: -5
17:21:40:            PID: 8300
17:21:40:            CWD: C:\Users\****\AppData\Roaming\FAHClient
17:21:40:             OS: Windows 10 Home
17:21:40:        OS Arch: AMD64
17:21:40:           GPUs: 0
17:21:40:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
17:21:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:436.15
17:21:40:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
17:21:40:  Win32 Service: false
17:21:40:***********************************************************************
17:21:40:<config>
17:21:40:  <service-description v='Folding@home Client'/>
17:21:40:  <service-restart v='true'/>
17:21:40:  <service-restart-delay v='5000'/>
17:21:40:
17:21:40:  <!-- Client Control -->
17:21:40:  <client-threads v='6'/>
17:21:40:  <cycle-rate v='4'/>
17:21:40:  <cycles v='-1'/>
17:21:40:  <data-directory v='.'/>
17:21:40:  <disable-sleep-when-active v='true'/>
17:21:40:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
17:21:40:  <exit-when-done v='false'/>
17:21:40:  <fold-anon v='false'/>
17:21:40:  <open-web-control v='true'/>
17:21:40:
17:21:40:  <!-- Configuration -->
17:21:40:  <config-rotate v='true'/>
17:21:40:  <config-rotate-dir v='configs'/>
17:21:40:  <config-rotate-max v='16'/>
17:21:40:
17:21:40:  <!-- Debugging -->
17:21:40:  <assignment-servers>
17:21:40:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
17:21:40:  </assignment-servers>
17:21:40:  <auth-as v='true'/>
17:21:40:  <capture-directory v='capture'/>
17:21:40:  <capture-on-error v='false'/>
17:21:40:  <capture-packets v='false'/>
17:21:40:  <capture-requests v='false'/>
17:21:40:  <capture-responses v='false'/>
17:21:40:  <capture-sockets v='false'/>
17:21:40:  <core-exec v='FahCore_$type'/>
17:21:40:  <core-wrapper-exec v='FAHCoreWrapper'/>
17:21:40:  <debug-sockets v='false'/>
17:21:40:  <exception-locations v='true'/>
17:21:40:  <stack-traces v='false'/>
17:21:40:
17:21:40:  <!-- Error Handling -->
17:21:40:  <max-slot-errors v='10'/>
17:21:40:  <max-unit-errors v='5'/>
17:21:40:
17:21:40:  <!-- Folding Core -->
17:21:40:  <checkpoint v='15'/>
17:21:40:  <core-dir v='cores'/>
17:21:40:  <core-priority v='idle'/>
17:21:40:  <cpu-affinity v='false'/>
17:21:40:  <cpu-usage v='100'/>
17:21:40:  <gpu-usage v='100'/>
17:21:40:  <no-assembly v='false'/>
17:21:40:
17:21:40:  <!-- Folding Slot Configuration -->
17:21:40:  <cause v='ANY'/>
17:21:40:  <client-subtype v='STDCLI'/>
17:21:40:  <client-type v='normal'/>
17:21:40:  <cpu-species v='X86_PENTIUM_II'/>
17:21:40:  <cpu-type v='AMD64'/>
17:21:40:  <cpus v='-1'/>
17:21:40:  <disable-viz v='false'/>
17:21:40:  <gpu v='true'/>
17:21:40:  <max-packet-size v='normal'/>
17:21:40:  <os-species v='WIN_8'/>
17:21:40:  <os-type v='WIN32'/>
17:21:40:  <project-key v='0'/>
17:21:40:  <smp v='true'/>
17:21:40:
17:21:40:  <!-- GUI -->
17:21:40:  <gui-enabled v='true'/>
17:21:40:
17:21:40:  <!-- HTTP Server -->
17:21:40:  <allow v='127.0.0.1'/>
17:21:40:  <connection-timeout v='60'/>
17:21:40:  <deny v='0/0'/>
17:21:40:  <http-addresses v='0:7396'/>
17:21:40:  <https-addresses v=''/>
17:21:40:  <max-connect-time v='900'/>
17:21:40:  <max-connections v='800'/>
17:21:40:  <max-request-length v='52428800'/>
17:21:40:  <min-connect-time v='300'/>
17:21:40:
17:21:40:  <!-- Logging -->
17:21:40:  <log v='log.txt'/>
17:21:40:  <log-color v='false'/>
17:21:40:  <log-crlf v='true'/>
17:21:40:  <log-date v='false'/>
17:21:40:  <log-date-periodically v='21600'/>
17:21:40:  <log-domain v='false'/>
17:21:40:  <log-header v='true'/>
17:21:40:  <log-level v='true'/>
17:21:40:  <log-no-info-header v='true'/>
17:21:40:  <log-redirect v='false'/>
17:21:40:  <log-rotate v='true'/>
17:21:40:  <log-rotate-dir v='logs'/>
17:21:40:  <log-rotate-max v='16'/>
17:21:40:  <log-short-level v='false'/>
17:21:40:  <log-simple-domains v='true'/>
17:21:40:  <log-thread-id v='false'/>
17:21:40:  <log-thread-prefix v='true'/>
17:21:40:  <log-time v='true'/>
17:21:40:  <log-to-screen v='true'/>
17:21:40:  <log-truncate v='false'/>
17:21:40:  <verbosity v='5'/>
17:21:40:
17:21:40:  <!-- Network -->
17:21:40:  <proxy v=':8080'/>
17:21:40:  <proxy-enable v='false'/>
17:21:40:  <proxy-pass v=''/>
17:21:40:  <proxy-user v=''/>
17:21:40:
17:21:40:  <!-- Process Control -->
17:21:40:  <child v='false'/>
17:21:40:  <daemon v='false'/>
17:21:40:  <pid v='false'/>
17:21:40:  <pid-file v='Folding@home Client.pid'/>
17:21:40:  <respawn v='false'/>
17:21:40:  <service v='false'/>
17:21:40:
17:21:40:  <!-- Remote Command Server -->
17:21:40:  <command-address v='0.0.0.0'/>
17:21:40:  <command-allow-no-pass v='127.0.0.1'/>
17:21:40:  <command-deny-no-pass v='0/0'/>
17:21:40:  <command-enable v='true'/>
17:21:40:  <command-port v='36330'/>
17:21:40:
17:21:40:  <!-- Slot Control -->
17:21:40:  <idle v='false'/>
17:21:40:  <max-shutdown-wait v='60'/>
17:21:40:  <pause-on-battery v='false'/>
17:21:40:  <pause-on-start v='false'/>
17:21:40:  <paused v='false'/>
17:21:40:  <power v='light'/>
17:21:40:
17:21:40:  <!-- User Information -->
17:21:40:  <machine-id v='0'/>
17:21:40:  <passkey v='********************************'/>
17:21:40:  <team v='******'/>
17:21:40:  <user v='************'/>
17:21:40:
17:21:40:  <!-- Web Server -->
17:21:40:  <web-allow v='127.0.0.1'/>
17:21:40:  <web-deny v='0/0'/>
17:21:40:  <web-enable v='true'/>
17:21:40:
17:21:40:  <!-- Web Server Sessions -->
17:21:40:  <session-cookie v='sid'/>
17:21:40:  <session-lifetime v='86400'/>
17:21:40:  <session-timeout v='3600'/>
17:21:40:
17:21:40:  <!-- Work Unit Control -->
17:21:40:  <dump-after-deadline v='true'/>
17:21:40:  <max-queue v='16'/>
17:21:40:  <max-units v='0'/>
17:21:40:  <next-unit-percentage v='99'/>
17:21:40:  <stall-detection-enabled v='false'/>
17:21:40:  <stall-percent v='5'/>
17:21:40:  <stall-timeout v='1800'/>
17:21:40:
17:21:40:  <!-- Folding Slots -->
17:21:40:  <slot id='0' type='CPU'/>
17:21:40:</config>
17:21:40:Trying to access database...
17:21:40:Successfully acquired database lock
17:21:40:Enabled folding slot 00: PAUSED cpu:3 (on battery)
17:21:40:Started thread 6 on PID 8300
17:21:40:Started thread 5 on PID 8300
17:21:40:Started thread 7 on PID 8300
17:21:40:Started thread 9 on PID 8300
17:21:40:Started thread 4 on PID 8300
17:21:40:Started thread 8 on PID 8300
17:21:41:1:127.0.0.1 GET /ping?_=1567790501573&callback=jQuery19005984341561301074_1567790501572
17:21:42:2:127.0.0.1 GET /?nocache=0.0005240469309915063
17:21:42:3:127.0.0.1 GET /css/normalize.css
17:21:42:4:127.0.0.1 GET /css/main.css
17:21:42:5:127.0.0.1 GET /js/jquery-1.10.2.min.js
17:21:42:6:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
17:21:42:7:127.0.0.1 GET /js/intercom.min.js
17:21:42:8:127.0.0.1 GET /js/main.js
17:21:42:8:127.0.0.1:New Web connection
17:21:43:9:127.0.0.1 GET /images/mail.png
17:21:43:10:127.0.0.1 GET /images/facebook.png
17:21:43:11:127.0.0.1 GET /images/twitter.png
17:21:43:12:127.0.0.1 GET /images/report-bug.png
17:21:43:13:127.0.0.1 GET /images/template/bg.jpg
17:21:43:14:127.0.0.1 GET /images/template/logo_folding_home.png
17:21:49:Started thread 10 on PID 8300
Re: MX250
NVidia doesn' list any information about a MX250 on their website. Maybe you have something else.
Who is the laptop's manufacturer? What happens if you open the NVidia Control Panel? Have you run GPU-Z?
RegularFolder
Re: MX250
Here it is: https://www.geforce.com/hardware/notebo ... orce-mx250
HP Envy 13
RegularFolder
Re: MX250
GPU-Z detects the card and displays the info for it. Card works fine when playing games.
Re: MX250
I'm afraid the problem may be your 32-bit Windows. NVidia has dropped driver support unless you're running a 64-bit version of your OS.
What are the binary codes that identify the device? As it's a Pascal, I can add support for it, but it won't help you unless you can install the drivers from NVidia.com
Re: MX250
(Codes are displayed by GPU-Z or by "fahclient --lspci" and possibly by nVidia's control panel.)
RegularFolder
Re: MX250
It’s a 64 bit windows install.
Re: MX250
Do you have a
1d13 GP108M [GeForce MX250]
or a
1d52 GP108BM [GeForce MX250]
Re: MX250
Without a response from you, I've added the 1d13 but you'll have to confirm that your GPU works or that you have a 1d52
RegularFolder
Re: MX250
bruce wrote:Without a response from you, I've added the 1d13 but you'll have to confirm that your GPU works or that you have a 1d52
The info im getting directly from GPU-Z is: GP108, REV A1, Device ID 10DE 1D52 - 103C 85E3
RegularFolder
Re: MX250
I do need to delete/reinstall FAH or anything?
Re: MX250
No, someone has whitelist a new ID. Bruce mentioned two it might be, then blindly guessed wrong when you did not reply in 15 minutes.
RegularFolder
Re: MX250
JimboPalmer wrote:No, someone has whitelist a new ID. Bruce mentioned two it might be, then blindly guessed wrong when you did not reply in 15 minutes.
Oh ok, it's still not showing the GPU slot and says "On client "local" 127.0.0.1:36330: No available GPUs" when trying to add a slot.
So deleted the GPU text file, restarted, still not finding it.
