Project 14191 only base points
Mustung
Hardware configuration: Asus Z170p
Intel 6700k
AMD Rx Vega 56
8GB DDR4
Intel 760P 256G
Post by Mustung »
After 5hrs hard work, only 38k base point, no bonus. Yes, passkey loaded (13 WUs before)
Both https://stats.foldingathome.org and FAHControl shows 38k points, so it is not just the display. Only log.txt reads 180k.
*********************** Log Started 2019-09-06T04:58:13Z ***********************
04:58:13:************************* Folding@home Client *************************
04:58:13:        Website: https://foldingathome.org/
04:58:13:      Copyright: (c) 2009-2018 foldingathome.org
04:58:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:58:13:           Args:
04:58:13:
04:58:13:         Config: C:\FAH\config.xml
04:58:13:******************************** Build ********************************
04:58:13:        Version: 7.5.1
04:58:13:           Date: May 11 2018
04:58:13:           Time: 13:06:32
04:58:13:     Repository: Git
04:58:13:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:58:13:         Branch: master
04:58:13:       Compiler: Visual C++ 2008
04:58:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:13:       Platform: win32 10
04:58:13:           Bits: 32
04:58:13:           Mode: Release
04:58:13:******************************* System ********************************
04:58:13:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
04:58:13:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
04:58:13:           CPUs: 8
04:58:13:         Memory: 15.94GiB
04:58:13:    Free Memory: 12.06GiB
04:58:13:        Threads: WINDOWS_THREADS
04:58:13:     OS Version: 6.2
04:58:13:    Has Battery: false
04:58:13:     On Battery: false
04:58:13:     UTC Offset: 0
04:58:13:            PID: 7332
04:58:13:            CWD: C:\FAH0
04:58:13:             OS: Windows 10 Enterprise
04:58:13:        OS Arch: AMD64
04:58:13:           GPUs: 1
04:58:13:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
04:58:13:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
04:58:13:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:436.15
04:58:13:  Win32 Service: false
04:58:13:***********************************************************************
04:58:13:<config>
04:58:13:  <!-- Folding Core -->
04:58:13:  <checkpoint v='30'/>
04:58:13:
04:58:13:  <!-- Folding Slot Configuration -->
04:58:13:  <client-type v='advanced'/>
04:58:13:
04:58:13:  <!-- Network -->
04:58:13:  <proxy v=':8080'/>
04:58:13:
04:58:13:
04:58:13:  <!-- Slot Control -->
04:58:13:  <power v='full'/>
04:58:13:
04:58:13:  <!-- User Information -->
04:58:13:  <passkey v='********************************'/>
04:58:13:  <team v='1111'/>
04:58:13:  <user v='Mustung'/>
04:58:13:Trying to access database...
04:58:13:Successfully acquired database lock
04:58:13:Enabled folding slot 01: READY gpu:0:TU106 [Geforce RTX 2060]
04:58:14:WU00:FS01:Connecting to 65.254.110.245:8080
04:58:28:WU00:FS01:Assigned to work server 155.247.166.220
04:58:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106 [Geforce RTX 2060] from 155.247.166.220
04:58:28:WU00:FS01:Connecting to 155.247.166.220:8080
04:58:30:WU00:FS01:Downloading 1.01MiB
04:58:36:WU00:FS01:Download 61.66%
04:58:42:WU00:FS01:Download 80.16%
04:58:49:WU00:FS01:Download 92.49%
04:58:55:WU00:FS01:Download 100.00%
04:58:55:WU00:FS01:Download complete
04:58:55:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14191 run:27 clone:9 gen:11 core:0x21 unit:0x000000140002894c5d5d74338a26276e
04:58:55:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
04:58:55:WU00:FS01:Connecting to cores.foldingathome.org:80
04:58:55:WU00:FS01:FahCore 21: Downloading 3.47MiB
04:59:02:WU00:FS01:FahCore 21: 7.20%
05:00:36:WU00:FS01:FahCore 21: 98.98%
05:00:36:WU00:FS01:FahCore 21: Download complete
05:00:36:WU00:FS01:Valid core signature
05:00:36:WU00:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
05:00:36:WU00:FS01:Starting
05:00:36:WU00:FS01:Started FahCore on PID 11584
05:00:36:WU00:FS01:Core PID:3984
05:00:36:WU00:FS01:FahCore 0x21 started
05:00:37:WU00:FS01:0x21:*********************** Log Started 2019-09-06T05:00:37Z ***********************
05:00:37:WU00:FS01:0x21:Project: 14191 (Run 27, Clone 9, Gen 11)
05:00:37:WU00:FS01:0x21:Unit: 0x000000140002894c5d5d74338a26276e
05:00:37:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:00:37:WU00:FS01:0x21:Machine: 1
05:00:37:WU00:FS01:0x21:Reading tar file core.xml
05:00:37:WU00:FS01:0x21:Reading tar file integrator.xml
05:00:37:WU00:FS01:0x21:Reading tar file state.xml
05:00:37:WU00:FS01:0x21:Reading tar file system.xml
05:00:37:WU00:FS01:0x21:Digital signatures verified
05:00:37:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:00:37:WU00:FS01:0x21:Version 0.0.20
05:00:41:WU00:FS01:0x21:Completed 0 out of 25000000 steps (0%)
05:00:41:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:03:01:FS01:Finishing
05:03:46:WU00:FS01:0x21:Completed 250000 out of 25000000 steps (1%)
05:06:54:WU00:FS01:0x21:Completed 500000 out of 25000000 steps (2%)
10:12:19:WU00:FS01:0x21:Completed 25000000 out of 25000000 steps (100%)
10:12:19:WU00:FS01:0x21:Saving result file logfile_01.txt
10:12:19:WU00:FS01:0x21:Saving result file checkpointState.xml
10:12:20:WU00:FS01:0x21:Saving result file checkpt.crc
10:12:20:WU00:FS01:0x21:Saving result file log.txt
10:12:20:WU00:FS01:0x21:Saving result file positions.xtc
10:12:20:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
10:12:21:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:12:21:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14191 run:27 clone:9 gen:11 core:0x21 unit:0x000000140002894c5d5d74338a26276e
10:12:21:WU00:FS01:Uploading 6.70MiB to 155.247.166.220
10:12:21:WU00:FS01:Connecting to 155.247.166.220:8080
10:12:27:WU00:FS01:Upload complete
10:12:27:WU00:FS01:Server responded WORK_ACK (400)
10:12:27:WU00:FS01:Final credit estimate, 186477.00 points
10:12:27:WU00:FS01:Cleaning up
AMD 5800x Gigabyte 3090 LC
RTX2060(s) x 6
bollix47
Re: Project 14191 only base points
Post by bollix47 »
The name Mustung does not exist in the database at this time.
The team 1111 hasn't been active since 2017.
I'm not surprised you're not getting any bonus.
Without accurate information it's going to be hard for anyone to help you.
If, as I suspect, your folding user name is 9rsqg73ci01w then the reason you are not getting bonus is the following:
WUs Finished - 14 WUs Expired - 10 % Finished - 58.33% Bonus Active - False
A 58% success rate is not even close to what you need for bonus.
Mustung
Intel 6700k
AMD Rx Vega 56
8GB DDR4
Intel 760P 256G
Post by Mustung »
thank you for your replay. I get your point anyway.
RTX2060(s) x 6
Your log shows user "Mustung" at the initial configuration. Did you change that after downloading the WU? That also will void any bonus.
The WU in question has not been recorded as returned by user "Mustung" or "mustung" as an earlier post had your system configured. If you are just trying to obfuscate your user and team ID's in the logs, just replace with asterisks and make it obvious. It doesn't matter to us, we can find that info out from completed WU's.
