Are there issues with user certificates?
physicalphill
Post by physicalphill »
Hi there :)
I was just wondering if there was any problems when trying to download the certificates you can get from your user profile page? There's normally two options one for points and one for work units, both of these links get me 502 gateway errors and I was just curious if anyone else or everyone else is having this issue?
It was a minor issue as I just try to get downloads anytime I hit a bit of a personal milestone :)
Thanks in advance for the help :)
Re: Are there issues with user certificates?
Welcome to the folding forum.
I was unaware of any problem until you posted, but checking my own stats I got the 502 error as well. I will bring the problem to the attention of the site maintainer.
This should be fixed now. Clicking on your point or WU totals will now download the certificate as a .jpg.
physicalphill
I believe it's all back up and running now :) Thank you for the help :)
ricardom17
Post by ricardom17 »
Joe_H wrote:This should be fixed now. Clicking on your point or WU totals will now download the certificate as a .jpg.
Is it possible to get a certificate with only the stats from your donor + passkey combo when there are several users with the same username as you??
