Is my QRB calculation right?
tmontney
Post by tmontney »
This is for a project I'm working on.
function Get-QRB($base_points, $TimeAssigned, $TimeFinished, $Deadline){
	$k = 0.75
	$deadline_length = [Math]::Round(($TimeAssigned - $Deadline).Days, 1)
	$elapsed_time = [Math]::Round(($TimeAssigned - $TimeFinished).Hours / 24, 1)
	return $base_points * [Math]::Max(1, [Math]::Sqrt($k * $deadline_length / $elapsed_time))
I'm interfacing with the telnet client. With the recent change in QRB calculations, I want to make sure I get a constant points value, something I can store and apply calculations later to (say the K constant value changes). For instance, I'd refer to queue-info and its basecredit value, then store that for later. If I wanted to perform a QRB calculation later (or any other calculation), I could.
Is that a safe bet? Is my QRB calculation above correct? Are base points always Integer value (aka always a whole number)?
Re: Is my QRB calculation right?
Your formulas are correct : https://foldingathome.org/support/faq/p ... determined
Keep this in mind :
Deadline_length and Elapsed_time are measured in days to one decimal point.
In the old days of FAH, some projects were worth less than 1 point (0.6 for instance), but I think it has been a while that projects are using integer as base point.
tmontney
Post by tmontney »
toTOW wrote:In the old days of FAH, some projects were worth less than 1 point (0.6 for instance), but I think it has been a while that projects are using integer as base point.
Sweet, thanks.
