FAH CPU Slot - Everything saying status: Unknown
Koolje
Post by Koolje »
Hi, I am running this on my main laptop and this error keeps coming up saying the connection is online but inactive when it was perfectly working yesterday.
Here is the screenshot of the errors:
Also here is the log information:
*********************** Log Started 2019-08-14T20:37:22Z ***********************
20:37:22:************************* Folding@home Client *************************
20:37:22:        Website: https://foldingathome.org/
20:37:22:      Copyright: (c) 2009-2018 foldingathome.org
20:37:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:37:22:           Args: --open-web-control
20:37:22:         Config: C:\Users\jmck3\AppData\Roaming\FAHClient\config.xml
20:37:22:******************************** Build ********************************
20:37:22:        Version: 7.5.1
20:37:22:           Date: May 11 2018
20:37:22:           Time: 13:06:32
20:37:22:     Repository: Git
20:37:22:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:37:22:         Branch: master
20:37:22:       Compiler: Visual C++ 2008
20:37:22:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:37:22:       Platform: win32 10
20:37:22:           Bits: 32
20:37:22:           Mode: Release
20:37:22:******************************* System ********************************
20:37:22:            CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
20:37:22:         CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
20:37:22:           CPUs: 4
20:37:22:         Memory: 7.91GiB
20:37:22:    Free Memory: 2.12GiB
20:37:22:        Threads: WINDOWS_THREADS
20:37:22:     OS Version: 6.2
20:37:22:    Has Battery: true
20:37:22:     On Battery: false
20:37:22:     UTC Offset: -4
20:37:22:            PID: 12620
20:37:22:            CWD: C:\Users\jmck3\AppData\Roaming\FAHClient
20:37:22:             OS: Windows 10 Enterprise
20:37:22:        OS Arch: AMD64
20:37:22:           GPUs: 0
20:37:22:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:37:22:                 specified module could not be found.
20:37:22:
20:37:22:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
20:37:22:  Win32 Service: false
20:37:22:***********************************************************************
20:37:22:<config>
20:37:22:  <!-- Folding Slot Configuration -->
20:37:22:  <cause v='ALZHEIMERS'/>
20:37:22:
20:37:22:  <!-- Slot Control -->
20:37:22:  <power v='medium'/>
20:37:22:
20:37:22:  <!-- User Information -->
20:37:22:  <passkey v='********************************'/>
20:37:22:  <team v='234980'/>
20:37:22:  <user v='qg927umi4cw1'/>
20:37:22:
20:37:22:  <!-- Folding Slots -->
20:37:22:  <slot id='0' type='CPU'/>
20:37:22:</config>
20:37:22:Trying to access database...
20:37:22:Successfully acquired database lock
20:37:22:Enabled folding slot 00: READY cpu:3
20:37:22:WU00:FS00:Connecting to 65.254.110.245:8080
20:37:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:37:23:WU00:FS00:Connecting to 18.218.241.186:80
20:37:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:37:23:ERROR:WU00:FS00:Exception: Could not get an assignment
20:37:24:WU00:FS00:Connecting to 65.254.110.245:8080
20:37:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:37:24:WU00:FS00:Connecting to 18.218.241.186:80
20:37:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:37:24:ERROR:WU00:FS00:Exception: Could not get an assignment
20:37:44:Saving configuration to config.xml
20:37:44:<config>
20:37:44:  <!-- Folding Slot Configuration -->
20:37:44:  <cause v='ALZHEIMERS'/>
20:37:44:
20:37:44:  <!-- Network -->
20:37:44:  <proxy v=':8080'/>
20:37:44:
20:37:44:  <!-- Slot Control -->
20:37:44:  <power v='medium'/>
20:37:44:
20:37:44:  <!-- User Information -->
20:37:44:  <passkey v='********************************'/>
20:37:44:  <team v='234980'/>
20:37:44:  <user v='qg927umi4cw1'/>
20:37:44:
20:37:44:  <!-- Folding Slots -->
20:37:44:  <slot id='0' type='CPU'/>
20:37:44:</config>
20:38:23:Saving configuration to config.xml
20:38:23:<config>
20:38:23:  <!-- Folding Slot Configuration -->
20:38:23:  <cause v='ALZHEIMERS'/>
20:38:23:
20:38:23:  <!-- Network -->
20:38:23:  <proxy v=':8080'/>
20:38:23:
20:38:23:  <!-- Slot Control -->
20:38:23:  <power v='medium'/>
20:38:23:
20:38:23:  <!-- User Information -->
20:38:23:  <passkey v='********************************'/>
20:38:23:  <team v='234980'/>
20:38:23:  <user v='qg927umi4cw1'/>
20:38:23:
20:38:23:  <!-- Folding Slots -->
20:38:23:  <slot id='0' type='CPU'/>
20:38:23:</config>
20:38:24:WU00:FS00:Connecting to 65.254.110.245:8080
20:38:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:38:24:WU00:FS00:Connecting to 18.218.241.186:80
20:38:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:38:24:ERROR:WU00:FS00:Exception: Could not get an assignment
20:40:01:WU00:FS00:Connecting to 65.254.110.245:8080
20:40:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:40:01:WU00:FS00:Connecting to 18.218.241.186:80
20:40:01:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:40:01:ERROR:WU00:FS00:Exception: Could not get an assignment
20:42:38:WU00:FS00:Connecting to 65.254.110.245:8080
20:42:38:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:42:38:WU00:FS00:Connecting to 18.218.241.186:80
20:42:38:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:42:38:ERROR:WU00:FS00:Exception: Could not get an assignment
Any solutions?
Re: FAH Client - Everything saying status: Unknown
I guess there's no work for a 3 threads configuration ... try to set Folding Power slider to Full to request work for a 4 threads configuration.
Koolje
Post by Koolje »
toTOW wrote:I guess there's no work for a 3 threads configuration ... try to set Folding Power slider to Full to request work for a 4 threads configuration.
dont work
If you go in Configure > Slot configuration, and set the slot to 4 or 2 instead of -1, does it help ?
absolutefunk
Post by absolutefunk »
Most of my CPU folders were stuck with this issue today (various number of threads per slot - 3 to 24). This happens occasionally, and the problem can usually be 'fixed' by deleting the slot and recreating it. Note that you may end up with an extra entry in the work queue from the slot you delete. Restarting the client usually purges that.
One key work server has been taken off-line temporarily. It has been making a large percentage of CPU assignments and the other servers with CPU projects are struggling to keep up. Temporarily there is a shortage of CPU assignments but there's nothing you can do about it but wait it out.
New projects are coming on-line on a regular basis ... moving from Beta to Advanced to full FAH does take some time. Severs are gradually being updated to new versions of the WS code and in most cases that takes many, many days because the server must be drained and then rebuilt. (If you happen to be the last person with a WU from the old server, you'll be thankful that they're waiting for you to return that WU for credit -- even though the rest of us are getting increasingly frustrated.)
suprleg
Post by suprleg »
My CPU slot is also stuck at, 'ready', however for some reason this situation is making my i7-4790 run hot and slow my machine to a crawl. Ubuntu 16.04.3. , client 7.3.6
Yes It's and old client version, but it's a long client reporting issue and I don't think pertinent to my current problem
Ideas?
Which WUs are active and which tasks are keeping your system busy?
suprleg
Re: FAH CPU Slot - Everything saying status: Unknown
Post by suprleg »
Here's cpu usage with and without fah running.:
suprleg@f1b4:~$ mpstat
Linux 4.4.0-91-generic (f1b4)   08/15/2019  _x86_64_    (8 CPU)
06:57:03 PM  CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest  %gnice   %idle
06:57:03 PM  all    4.67    1.97    1.13    3.25    0.00    0.00    0.00    0.00    0.00   88.97
suprleg@f1b4:~$ sar -u 5
06:57:22 PM     CPU     %user     %nice   %system   %iowait    %steal     %idle
06:57:27 PM     all     13.49      9.41      3.20      0.00      0.00     73.90
06:57:32 PM     all     13.59      9.51      3.05      0.00      0.00     73.85
06:57:37 PM     all     13.70      9.40      3.20      0.17      0.00     73.53
06:57:42 PM     all     13.44      9.61      3.05      0.00      0.00     73.91
06:57:47 PM     all     13.56      9.31      3.28      0.10      0.00     73.76
06:57:52 PM     all      3.28      9.58      3.05      0.08      0.00     84.01
06:57:57 PM     all      9.42      9.49      3.22      0.00      0.00     77.87
06:58:02 PM     all     13.50      9.40      3.18      0.03      0.00     73.89
06:58:07 PM     all     13.59      9.21      3.43      0.28      0.00     73.50
^C
CPU temps go from 30-35 at idle to 55-61 with fah running.
Again, the GPU slot is running and the CPU slot indicates...READY, but not folding.
Post your log file for the time period you see the client stuck at ready. Bruce's first post on this page has a link to directions to do that in his sig. Also useful is the first 100 or so lines of the log that show the system info and folding configuration.
Also, the output of top or another utility showing which processes are consuming CPU would more useful than the sar and mpstat info you have provided.
autogrog
Post by autogrog »
I have 2 systems that started failing/stalling folding after years of stable running (all aother applications continue to function). This is a sample folding log. Any help would be appreciated.
Thanks
*********************** Log Started 2019-08-17T06:15:55Z ***********************
06:15:55:************************* Folding@home Client *************************
06:15:55:    Website: http://folding.stanford.edu/
06:15:55:  Copyright: (c) 2009-2014 Stanford University
06:15:55:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:15:55:       Args:
06:15:55:     Config: /home/me/smpv7/config.xml
06:15:55:******************************** Build ********************************
06:15:55:    Version: 7.4.4
06:15:55:       Date: Mar 4 2014
06:15:55:       Time: 12:01:17
06:15:55:    SVN Rev: 4130
06:15:55:     Branch: fah/trunk/client
06:15:55:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
06:15:55:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
06:15:55:             -fno-unsafe-math-optimizations -msse2
06:15:55:   Platform: linux2 2.6.18-164.11.1.el5
06:15:55:       Bits: 64
06:15:55:       Mode: Release
06:15:55:******************************* System ********************************
06:15:55:        CPU: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
06:15:55:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
06:15:55:       CPUs: 12
06:15:55:     Memory: 5.82GiB
06:15:55:Free Memory: 5.45GiB
06:15:55:    Threads: POSIX_THREADS
06:15:55: OS Version: 3.6
06:15:55:Has Battery: false
06:15:55: On Battery: false
06:15:55: UTC Offset: -3
06:15:55:        PID: 1138
06:15:55:        CWD: /home/me/smpv7
06:15:55:         OS: Linux 3.6.10-4.fc18.x86_64 x86_64
06:15:55:    OS Arch: AMD64
06:15:55:       GPUs: 1
06:15:55:      GPU 0: NVIDIA:1 GT200 [GeForce GTX 280M]
06:15:55:       CUDA: Not detected
06:15:55:***********************************************************************
06:15:55:<config>
06:15:55:  <!-- Folding Slot Configuration -->
06:15:55:  <cpus v='12'/>
06:15:55:  <gpu v='false'/>
06:15:55:  <max-packet-size v='big'/>
06:15:55:
06:15:55:  <!-- User Information -->
06:15:55:  <passkey v='********************************'/>
06:15:55:  <team v='39286'/>
06:15:55:  <user v='AutoGrog'/>
06:15:55:
06:15:55:  <!-- Work Unit Control -->
06:15:55:  <next-unit-percentage v='100'/>
06:15:55:
06:15:55:  <!-- Folding Slots -->
06:15:55:  <slot id='0' type='CPU'/>
06:15:55:</config>
06:15:55:Trying to access database...
06:15:55:Successfully acquired database lock
06:15:55:FS00:Set client configured
06:15:55:Enabled folding slot 00: READY cpu:12
[91m06:15:56:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution[0m
11:16:28:WU00:FS00:Connecting to 65.254.110.245:8080
11:16:28:WU00:FS00:Assigned to work server 128.252.203.9
11:16:28:WU00:FS00:Requesting new work unit for slot 00: READY cpu:12 from 128.252.203.9
11:16:28:WU00:FS00:Connecting to 128.252.203.9:8080
11:16:29:WU00:FS00:Downloading 8.14MiB
11:16:30:WU00:FS00:Download complete
11:16:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13825 run:814 clone:2 gen:78 core:0xa7 unit:0x0000005680fccb095c9564623844912c
11:16:30:WU00:FS00:Downloading core from http://cores.foldingathome.org/Linux/AMD64/Core_a7.fah
11:16:30:WU00:FS00:Connecting to cores.foldingathome.org:80
11:16:30:WU00:FS00:FahCore a7: Downloading 7.64MiB
11:16:32:WU00:FS00:FahCore a7: Download complete
11:16:32:WU00:FS00:Valid core signature
11:16:32:WU00:FS00:Unpacked 18.42MiB to cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7
11:16:32:WU00:FS00:Starting
11:16:32:WU00:FS00:Running FahCore: /home/me/smpv7/FAHCoreWrapper /home/me/smpv7/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 704 -lifeline 1138 -checkpoint 15 -np 12
11:16:32:WU00:FS00:Started FahCore on PID 1853
11:16:32:WU00:FS00:Core PID:1857
11:16:32:WU00:FS00:FahCore 0xa7 started
[93m11:16:32:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)[0m
11:16:32:WU00:FS00:Started FahCore on PID 1858
11:16:32:WU00:FS00:Core PID:1862
[93m11:16:33:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)[0m
11:17:08:Caught signal SIGTERM(15) on PID 1138
11:17:08:Exiting, please wait. . .
11:17:09:Clean exit
Your distribution requires an update to be able to run A7 core. It's very likely a glibc incompatibility ... for instance, Ubuntu older than 16.04 won't be able to run A7 core.
If you try to run /home/me/smpv7/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 from a terminal, you'll have more details about the error.
autogrog
Post by autogrog »
I have not been able to upgrade past Fedora 18, so I'm off on a quest.
Thanks for the quick answer.
You might try to find a hack to install the proper glibc version on your system ... but it's usually easier to update the whole distribution ... :roll:
