Just started folding again; brought (5) ten year old dual Xeon LGA 1366 beasts back on line with GPU ranging from Fermi to Pascal, supposedly all compatible with core 21...
The EVGA Classified SR2 was running (4) GTX 590 which were working great (hot nostalgia), and a GTX 580 which does not seem to work at all and was removed from the slot config. Everytime Windows Update would want me to restart after installing updates, the GTX 580 would show up in slot (0), and one of the GTX 590 would be gone!?
I HAVE GIVEN UP ON THAT CONFIG, ANY WAY TO KNOW HOW MANY WU I WILL NEED TO GET THE QRB AGAIN? (Losing (4) GTX 590 each time is a killer)
Can I make up the WU with my old 24 core CPU running core a7 @ 3.7Ghz; or, can you please reset my restarts to 80+% again?
Do I need to make up the WU with GPU only?
Thank you!!!
archiblender
guru3D 69411
Am I below the proverbial 80% Threshold..?
archiblender
Re: Am I below the proverbial 80% Threshold..?
Assuming you are folding under the name archiblender, both passkeys shown in relation to that username are okay and eligible for the QRB.
If you have noticed that you were just getting the base points, that is due to a problem connected with updates to the server software over the last 6-8 weeks. There are several topics that discuss that issue. PG is aware of the problem and the fixes should be going into place. Sometime in the future they will manually credit the bonus points for WU's that did not receive them.
About the base point issue, see this post : viewtopic.php?f=106&t=31758
archiblender
Perfect, got it!
