GPU Status Failed
Koolje
GPU Status Failed
Post by Koolje »
When I open the FAH Client, my GPU seems to be failing quite frequently, 3 days ago it was working perfect but since 3 days it has been failing to compute.
Image: Image
How do I fix this issue?
(From Bruce)
I've asked before and gotten no reply. I'm opening a ticket on it.
Configuring GPU SPECIES > N is an option for all project owners but the info doesn't always get shared with newbies.
Re: GPU Status Failed
This Link viewtopic.php?f=24&t=26036
should include how to post a Log file in whatever OS you have.
With a log of the configuration, we would know quite a bit more about how your hardware is configured.
Did you recently install a major Update from WindowUpdate?
If so, go to https://www.geforce.com/drivers and install the drivers per their instructions.
THIS IS ONLY A GUESS .... AND YOU STILL NEED TO POST YOUR LOG PER THOSE INSTRUCTIONS.
Koolje
Post by Koolje »
JimboPalmer wrote:This Link viewtopic.php?f=24&t=26036
Here is the log file:
*********************** Log Started 2019-08-12T12:53:08Z ***********************
12:53:08:************************* Folding@home Client *************************
12:53:08:        Website: https://foldingathome.org/
12:53:08:      Copyright: (c) 2009-2018 foldingathome.org
12:53:08:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:53:08:           Args:
12:53:08:         Config: C:\Users\pc\AppData\Roaming\FAHClient\config.xml
12:53:08:******************************** Build ********************************
12:53:08:        Version: 7.5.1
12:53:08:           Date: May 11 2018
12:53:08:           Time: 13:06:32
12:53:08:     Repository: Git
12:53:08:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:53:08:         Branch: master
12:53:08:       Compiler: Visual C++ 2008
12:53:08:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:53:08:       Platform: win32 10
12:53:08:           Bits: 32
12:53:08:           Mode: Release
12:53:08:******************************* System ********************************
12:53:08:            CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
12:53:08:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:53:08:           CPUs: 8
12:53:08:         Memory: 7.88GiB
12:53:08:    Free Memory: 6.23GiB
12:53:08:        Threads: WINDOWS_THREADS
12:53:08:     OS Version: 6.2
12:53:08:    Has Battery: true
12:53:08:     On Battery: false
12:53:08:     UTC Offset: -4
12:53:08:            PID: 3024
12:53:08:            CWD: C:\Users\pc\AppData\Roaming\FAHClient
12:53:08:             OS: Windows 10 Enterprise
12:53:08:        OS Arch: AMD64
12:53:08:           GPUs: 1
12:53:08:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF108 [Quadro NVS 4200M]
12:53:08:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:8.0
12:53:08:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:369.9
12:53:08:  Win32 Service: false
12:53:08:***********************************************************************
12:53:08:<config>
12:53:08:  <!-- Slot Control -->
12:53:08:  <power v='FULL'/>
12:53:08:
12:53:08:  <!-- User Information -->
12:53:08:  <passkey v='********************************'/>
12:53:08:  <team v='234980'/>
12:53:08:  <user v='qg927umi4cw1'/>
12:53:08:
12:53:08:  <!-- Folding Slots -->
12:53:08:  <slot id='0' type='CPU'/>
12:53:08:  <slot id='1' type='GPU'/>
12:53:08:</config>
12:53:08:Trying to access database...
12:53:08:Successfully acquired database lock
12:53:08:Enabled folding slot 00: READY cpu:7
12:53:08:Enabled folding slot 01: READY gpu:0:GF108 [Quadro NVS 4200M]
12:53:08:WU01:FS00:Starting
12:53:08:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -np 7
12:53:08:WU01:FS00:Started FahCore on PID 4788
12:53:10:WU01:FS00:Core PID:492
12:53:10:WU01:FS00:FahCore 0xa7 started
12:53:10:WU00:FS01:Connecting to 65.254.110.245:8080
12:53:11:WU01:FS00:0xa7:*********************** Log Started 2019-08-12T12:53:10Z ***********************
12:53:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:53:11:WU01:FS00:0xa7:       Type: 0xa7
12:53:11:WU01:FS00:0xa7:       Core: Gromacs
12:53:11:WU01:FS00:0xa7:    Website: https://foldingathome.org/
12:53:11:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:53:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:53:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4788 -checkpoint 15 -np 7
12:53:11:WU01:FS00:0xa7:     Config: <none>
12:53:11:WU01:FS00:0xa7:************************************ Build *************************************
12:53:11:WU01:FS00:0xa7:    Version: 0.0.17
12:53:11:WU01:FS00:0xa7:       Date: Apr 25 2018
12:53:11:WU01:FS00:0xa7:       Time: 11:02:26
12:53:11:WU01:FS00:0xa7: Repository: Git
12:53:11:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
12:53:11:WU01:FS00:0xa7:     Branch: master
12:53:11:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:53:11:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:53:11:WU01:FS00:0xa7:   Platform: win32 10
12:53:11:WU01:FS00:0xa7:       Bits: 32
12:53:11:WU01:FS00:0xa7:       Mode: Release
12:53:11:WU01:FS00:0xa7:       SIMD: sse2
12:53:11:WU01:FS00:0xa7:************************************ System ************************************
12:53:11:WU01:FS00:0xa7:        CPU: Unknown
12:53:11:WU01:FS00:0xa7:     CPU ID:
12:53:11:WU01:FS00:0xa7:       CPUs: 8
12:53:11:WU01:FS00:0xa7:     Memory: 7.88GiB
12:53:11:WU01:FS00:0xa7:Free Memory: 6.15GiB
12:53:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
12:53:11:WU01:FS00:0xa7: OS Version: 6.2
12:53:11:WU01:FS00:0xa7:Has Battery: true
12:53:11:WU01:FS00:0xa7: On Battery: false
12:53:11:WU01:FS00:0xa7: UTC Offset: -4
12:53:11:WU01:FS00:0xa7:        PID: 492
12:53:11:WU01:FS00:0xa7:        CWD: C:\Users\pc\AppData\Roaming\FAHClient\work
12:53:11:WU01:FS00:0xa7:         OS: Windows 10 Enterprise
12:53:11:WU01:FS00:0xa7:    OS Arch: AMD64
12:53:11:WU01:FS00:0xa7:********************************************************************************
12:53:11:WU01:FS00:0xa7:Project: 14153 (Run 13, Clone 235, Gen 102)
12:53:11:WU01:FS00:0xa7:Unit: 0x0000007a0002894b5c6e03b8010bdb88
12:53:11:WU01:FS00:0xa7:Digital signatures verified
12:53:11:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
12:53:11:WU01:FS00:0xa7:Calling: mdrun -s frame102.tpr -o frame102.trr -cpi state.cpt -cpt 15 -nt 6
12:53:12:WU01:FS00:0xa7:Steps: first=510000000 total=5000000
12:53:13:WU01:FS00:0xa7:Completed 3113261 out of 5000000 steps (62%)
12:53:14:WU00:FS01:Assigned to work server 128.252.203.4
12:53:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:53:14:WU00:FS01:Connecting to 128.252.203.4:8080
12:53:17:WU00:FS01:Downloading 1.79MiB
12:53:19:WU00:FS01:Download complete
12:53:19:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:1562 gen:219 core:0x21 unit:0x0000012680fccb045b3a656bb59cdacd
12:53:19:WU00:FS01:Starting
12:53:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:53:19:WU00:FS01:Started FahCore on PID 1928
12:53:19:WU00:FS01:Core PID:1892
12:53:19:WU00:FS01:FahCore 0x21 started
12:53:20:WU00:FS01:0x21:*********************** Log Started 2019-08-12T12:53:20Z ***********************
12:53:20:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 1562, Gen 219)
12:53:20:WU00:FS01:0x21:Unit: 0x0000012680fccb045b3a656bb59cdacd
12:53:20:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:53:20:WU00:FS01:0x21:Machine: 1
12:53:20:WU00:FS01:0x21:Reading tar file core.xml
12:53:20:WU00:FS01:0x21:Reading tar file integrator.xml
12:53:20:WU00:FS01:0x21:Reading tar file state.xml
12:53:20:WU00:FS01:0x21:Reading tar file system.xml
12:53:21:WU00:FS01:0x21:Digital signatures verified
12:53:21:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:53:21:WU00:FS01:0x21:Version 0.0.20
12:53:27:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:53:27:WU00:FS01:0x21:Saving result file logfile_01.txt
12:53:27:WU00:FS01:0x21:Saving result file log.txt
12:53:27:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:53:28:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:53:28:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:1562 gen:219 core:0x21 unit:0x0000012680fccb045b3a656bb59cdacd
12:53:29:WU00:FS01:Uploading 2.29KiB to 128.252.203.4
12:53:29:WU00:FS01:Connecting to 128.252.203.4:8080
12:53:29:WU00:FS01:Upload complete
12:53:29:WU02:FS01:Connecting to 65.254.110.245:8080
12:53:29:WU00:FS01:Server responded WORK_ACK (400)
12:53:29:WU00:FS01:Cleaning up
12:53:30:WU02:FS01:Assigned to work server 155.247.166.220
12:53:30:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 155.247.166.220
12:53:30:WU02:FS01:Connecting to 155.247.166.220:8080
12:53:33:WU02:FS01:Downloading 2.47MiB
12:53:37:WU02:FS01:Download complete
12:53:37:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:6 clone:362 gen:6 core:0x21 unit:0x0000000a0002894c5d3b5533a7959ecf
12:53:37:WU02:FS01:Starting
12:53:37:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:53:37:WU02:FS01:Started FahCore on PID 3548
12:53:37:WU02:FS01:Core PID:3756
12:53:37:WU02:FS01:FahCore 0x21 started
12:53:38:WU02:FS01:0x21:*********************** Log Started 2019-08-12T12:53:37Z ***********************
12:53:38:WU02:FS01:0x21:Project: 14180 (Run 6, Clone 362, Gen 6)
12:53:38:WU02:FS01:0x21:Unit: 0x0000000a0002894c5d3b5533a7959ecf
12:53:38:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:53:38:WU02:FS01:0x21:Machine: 1
12:53:38:WU02:FS01:0x21:Reading tar file core.xml
12:53:38:WU02:FS01:0x21:Reading tar file integrator.xml
12:53:38:WU02:FS01:0x21:Reading tar file state.xml
12:53:38:WU02:FS01:0x21:Reading tar file system.xml
12:53:38:WU02:FS01:0x21:Digital signatures verified
12:53:38:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:53:38:WU02:FS01:0x21:Version 0.0.20
12:53:47:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:53:47:WU02:FS01:0x21:Saving result file logfile_01.txt
12:53:47:WU02:FS01:0x21:Saving result file log.txt
12:53:47:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:53:48:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:53:48:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:6 clone:362 gen:6 core:0x21 unit:0x0000000a0002894c5d3b5533a7959ecf
12:53:49:WU02:FS01:Uploading 2.28KiB to 155.247.166.220
12:53:49:WU02:FS01:Connecting to 155.247.166.220:8080
12:53:49:WU02:FS01:Upload complete
12:53:49:WU00:FS01:Connecting to 65.254.110.245:8080
12:53:49:WU02:FS01:Server responded WORK_ACK (400)
12:53:49:WU02:FS01:Cleaning up
12:53:50:WU00:FS01:Assigned to work server 128.252.203.4
12:53:50:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:53:50:WU00:FS01:Connecting to 128.252.203.4:8080
12:53:59:WU00:FS01:Downloading 1.79MiB
12:54:00:WU00:FS01:Download complete
12:54:00:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:560 gen:215 core:0x21 unit:0x0000013180fccb045b36d01cb5319930
12:54:01:WU00:FS01:Starting
12:54:01:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:54:01:WU00:FS01:Started FahCore on PID 4080
12:54:01:WU00:FS01:Core PID:7424
12:54:01:WU00:FS01:FahCore 0x21 started
12:54:01:WU00:FS01:0x21:*********************** Log Started 2019-08-12T12:54:01Z ***********************
12:54:01:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 560, Gen 215)
12:54:01:WU00:FS01:0x21:Unit: 0x0000013180fccb045b36d01cb5319930
12:54:01:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:54:01:WU00:FS01:0x21:Machine: 1
12:54:01:WU00:FS01:0x21:Reading tar file core.xml
12:54:01:WU00:FS01:0x21:Reading tar file integrator.xml
12:54:01:WU00:FS01:0x21:Reading tar file state.xml
12:54:01:WU00:FS01:0x21:Reading tar file system.xml
12:54:01:WU00:FS01:0x21:Digital signatures verified
12:54:01:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:54:01:WU00:FS01:0x21:Version 0.0.20
12:54:07:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:54:07:WU00:FS01:0x21:Saving result file logfile_01.txt
12:54:07:WU00:FS01:0x21:Saving result file log.txt
12:54:07:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:54:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:54:08:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:560 gen:215 core:0x21 unit:0x0000013180fccb045b36d01cb5319930
12:54:08:WU00:FS01:Uploading 2.28KiB to 128.252.203.4
12:54:08:WU00:FS01:Connecting to 128.252.203.4:8080
12:54:08:WU00:FS01:Upload complete
12:54:08:WU00:FS01:Server responded WORK_ACK (400)
12:54:08:WU00:FS01:Cleaning up
12:54:09:WU02:FS01:Connecting to 65.254.110.245:8080
12:54:09:WU02:FS01:Assigned to work server 128.252.203.4
12:54:09:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:54:09:WU02:FS01:Connecting to 128.252.203.4:8080
12:54:12:WU02:FS01:Downloading 1.79MiB
12:54:13:WU02:FS01:Download complete
12:54:13:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2569 gen:219 core:0x21 unit:0x0000012680fccb045b3f7911e6109b38
12:54:13:WU02:FS01:Starting
12:54:13:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:54:13:WU02:FS01:Started FahCore on PID 6284
12:54:13:WU02:FS01:Core PID:5364
12:54:13:WU02:FS01:FahCore 0x21 started
12:54:14:WU02:FS01:0x21:*********************** Log Started 2019-08-12T12:54:13Z ***********************
12:54:14:WU02:FS01:0x21:Project: 13816 (Run 0, Clone 2569, Gen 219)
12:54:14:WU02:FS01:0x21:Unit: 0x0000012680fccb045b3f7911e6109b38
12:54:14:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:54:14:WU02:FS01:0x21:Machine: 1
12:54:14:WU02:FS01:0x21:Reading tar file core.xml
12:54:14:WU02:FS01:0x21:Reading tar file integrator.xml
12:54:14:WU02:FS01:0x21:Reading tar file state.xml
12:54:14:WU02:FS01:0x21:Reading tar file system.xml
12:54:14:WU02:FS01:0x21:Digital signatures verified
12:54:14:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:54:14:WU02:FS01:0x21:Version 0.0.20
12:54:19:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:54:19:WU02:FS01:0x21:Saving result file logfile_01.txt
12:54:19:WU02:FS01:0x21:Saving result file log.txt
12:54:19:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:54:20:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:54:21:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13816 run:0 clone:2569 gen:219 core:0x21 unit:0x0000012680fccb045b3f7911e6109b38
12:54:21:WU02:FS01:Uploading 2.29KiB to 128.252.203.4
12:54:21:WU02:FS01:Connecting to 128.252.203.4:8080
12:54:21:WU02:FS01:Upload complete
12:54:21:WU02:FS01:Server responded WORK_ACK (400)
12:54:21:WU02:FS01:Cleaning up
12:54:21:WU00:FS01:Connecting to 65.254.110.245:8080
12:54:22:WU00:FS01:Assigned to work server 128.252.203.4
12:54:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:54:22:WU00:FS01:Connecting to 128.252.203.4:8080
12:54:24:WU00:FS01:Downloading 1.79MiB
12:54:25:WU00:FS01:Download complete
12:54:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2748 gen:215 core:0x21 unit:0x0000012a80fccb045b3f79135a0ff468
12:54:26:WU00:FS01:Starting
12:54:26:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:54:26:WU00:FS01:Started FahCore on PID 6944
12:54:26:WU00:FS01:Core PID:1700
12:54:26:WU00:FS01:FahCore 0x21 started
12:54:26:WU00:FS01:0x21:*********************** Log Started 2019-08-12T12:54:26Z ***********************
12:54:26:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 2748, Gen 215)
12:54:26:WU00:FS01:0x21:Unit: 0x0000012a80fccb045b3f79135a0ff468
12:54:26:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:54:26:WU00:FS01:0x21:Machine: 1
12:54:26:WU00:FS01:0x21:Reading tar file core.xml
12:54:26:WU00:FS01:0x21:Reading tar file integrator.xml
12:54:26:WU00:FS01:0x21:Reading tar file state.xml
12:54:26:WU00:FS01:0x21:Reading tar file system.xml
12:54:26:WU00:FS01:0x21:Digital signatures verified
12:54:26:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:54:26:WU00:FS01:0x21:Version 0.0.20
12:54:32:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:54:32:WU00:FS01:0x21:Saving result file logfile_01.txt
12:54:32:WU00:FS01:0x21:Saving result file log.txt
12:54:32:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:54:33:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:54:33:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:2748 gen:215 core:0x21 unit:0x0000012a80fccb045b3f79135a0ff468
12:54:33:WU00:FS01:Uploading 2.29KiB to 128.252.203.4
12:54:33:WU00:FS01:Connecting to 128.252.203.4:8080
12:54:33:WU00:FS01:Upload complete
12:54:33:WU00:FS01:Server responded WORK_ACK (400)
12:54:34:WU00:FS01:Cleaning up
12:54:34:WU02:FS01:Connecting to 65.254.110.245:8080
12:54:34:WU02:FS01:Assigned to work server 128.252.203.4
12:54:34:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:54:34:WU02:FS01:Connecting to 128.252.203.4:8080
12:54:39:WU02:FS01:Downloading 1.79MiB
12:54:41:WU02:FS01:Download complete
12:54:41:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2274 gen:214 core:0x21 unit:0x0000011b80fccb045b3f790fd5988432
12:54:41:WU02:FS01:Starting
12:54:41:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:54:41:WU02:FS01:Started FahCore on PID 5196
12:54:41:WU02:FS01:Core PID:7180
12:54:41:WU02:FS01:FahCore 0x21 started
12:54:42:WU02:FS01:0x21:*********************** Log Started 2019-08-12T12:54:41Z ***********************
12:54:42:WU02:FS01:0x21:Project: 13816 (Run 0, Clone 2274, Gen 214)
12:54:42:WU02:FS01:0x21:Unit: 0x0000011b80fccb045b3f790fd5988432
12:54:42:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:54:42:WU02:FS01:0x21:Machine: 1
12:54:42:WU02:FS01:0x21:Reading tar file core.xml
12:54:42:WU02:FS01:0x21:Reading tar file integrator.xml
12:54:42:WU02:FS01:0x21:Reading tar file state.xml
12:54:42:WU02:FS01:0x21:Reading tar file system.xml
12:54:42:WU02:FS01:0x21:Digital signatures verified
12:54:42:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:54:42:WU02:FS01:0x21:Version 0.0.20
12:54:47:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:54:47:WU02:FS01:0x21:Saving result file logfile_01.txt
12:54:47:WU02:FS01:0x21:Saving result file log.txt
12:54:47:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:54:48:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:54:49:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13816 run:0 clone:2274 gen:214 core:0x21 unit:0x0000011b80fccb045b3f790fd5988432
12:54:49:WU02:FS01:Uploading 2.28KiB to 128.252.203.4
12:54:49:WU02:FS01:Connecting to 128.252.203.4:8080
12:54:49:WU02:FS01:Upload complete
12:54:49:WU02:FS01:Server responded WORK_ACK (400)
12:54:49:WU02:FS01:Cleaning up
12:54:49:WU00:FS01:Connecting to 65.254.110.245:8080
12:54:49:WU00:FS01:Assigned to work server 128.252.203.4
12:54:49:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:54:49:WU00:FS01:Connecting to 128.252.203.4:8080
12:54:52:WU00:FS01:Downloading 1.79MiB
12:54:53:WU00:FS01:Download complete
12:54:53:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2454 gen:227 core:0x21 unit:0x0000012f80fccb045b3f791007fc2834
12:54:53:WU00:FS01:Starting
12:54:53:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:54:53:WU00:FS01:Started FahCore on PID 7104
12:54:53:WU00:FS01:Core PID:7568
12:54:53:WU00:FS01:FahCore 0x21 started
12:54:54:WU00:FS01:0x21:*********************** Log Started 2019-08-12T12:54:54Z ***********************
12:54:54:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 2454, Gen 227)
12:54:54:WU00:FS01:0x21:Unit: 0x0000012f80fccb045b3f791007fc2834
12:54:54:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:54:54:WU00:FS01:0x21:Machine: 1
12:54:54:WU00:FS01:0x21:Reading tar file core.xml
12:54:54:WU00:FS01:0x21:Reading tar file integrator.xml
12:54:54:WU00:FS01:0x21:Reading tar file state.xml
12:54:54:WU00:FS01:0x21:Reading tar file system.xml
12:54:54:WU00:FS01:0x21:Digital signatures verified
12:54:54:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:54:54:WU00:FS01:0x21:Version 0.0.20
12:55:00:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:55:00:WU00:FS01:0x21:Saving result file logfile_01.txt
12:55:00:WU00:FS01:0x21:Saving result file log.txt
12:55:00:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:55:01:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:55:01:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:2454 gen:227 core:0x21 unit:0x0000012f80fccb045b3f791007fc2834
12:55:01:WU00:FS01:Uploading 2.28KiB to 128.252.203.4
12:55:01:WU00:FS01:Connecting to 128.252.203.4:8080
12:55:01:WU00:FS01:Upload complete
12:55:01:WU00:FS01:Server responded WORK_ACK (400)
12:55:01:WU00:FS01:Cleaning up
12:55:02:WU02:FS01:Connecting to 65.254.110.245:8080
12:55:02:WU02:FS01:Assigned to work server 128.252.203.4
12:55:02:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:55:02:WU02:FS01:Connecting to 128.252.203.4:8080
12:55:04:WU02:FS01:Downloading 1.79MiB
12:55:06:WU02:FS01:Download complete
12:55:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2482 gen:214 core:0x21 unit:0x0000011c80fccb045b3f79118af6eba1
12:55:06:WU02:FS01:Starting
12:55:06:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:55:06:WU02:FS01:Started FahCore on PID 588
12:55:06:WU02:FS01:Core PID:5896
12:55:06:WU02:FS01:FahCore 0x21 started
12:55:06:WU02:FS01:0x21:*********************** Log Started 2019-08-12T12:55:06Z ***********************
12:55:06:WU02:FS01:0x21:Project: 13816 (Run 0, Clone 2482, Gen 214)
12:55:06:WU02:FS01:0x21:Unit: 0x0000011c80fccb045b3f79118af6eba1
12:55:06:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:55:06:WU02:FS01:0x21:Machine: 1
12:55:06:WU02:FS01:0x21:Reading tar file core.xml
12:55:06:WU02:FS01:0x21:Reading tar file integrator.xml
12:55:06:WU02:FS01:0x21:Reading tar file state.xml
12:55:07:WU02:FS01:0x21:Reading tar file system.xml
12:55:07:WU02:FS01:0x21:Digital signatures verified
12:55:07:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:55:07:WU02:FS01:0x21:Version 0.0.20
12:55:12:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:55:12:WU02:FS01:0x21:Saving result file logfile_01.txt
12:55:12:WU02:FS01:0x21:Saving result file log.txt
12:55:12:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:55:13:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:55:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13816 run:0 clone:2482 gen:214 core:0x21 unit:0x0000011c80fccb045b3f79118af6eba1
12:55:13:WU02:FS01:Uploading 2.29KiB to 128.252.203.4
12:55:13:WU02:FS01:Connecting to 128.252.203.4:8080
12:55:14:WU02:FS01:Upload complete
12:55:14:WU02:FS01:Server responded WORK_ACK (400)
12:55:14:WU02:FS01:Cleaning up
12:55:14:WU00:FS01:Connecting to 65.254.110.245:8080
12:55:14:WU00:FS01:Assigned to work server 128.252.203.4
12:55:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 128.252.203.4
12:55:14:WU00:FS01:Connecting to 128.252.203.4:8080
12:55:17:WU00:FS01:Downloading 1.79MiB
12:55:18:WU00:FS01:Download complete
12:55:19:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:522 gen:213 core:0x21 unit:0x0000012980fccb045b36d01bcd468a0f
12:55:19:WU00:FS01:Starting
12:55:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:55:19:WU00:FS01:Started FahCore on PID 7672
12:55:19:WU00:FS01:Core PID:5400
12:55:19:WU00:FS01:FahCore 0x21 started
12:55:19:WU00:FS01:0x21:*********************** Log Started 2019-08-12T12:55:19Z ***********************
12:55:19:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 522, Gen 213)
12:55:19:WU00:FS01:0x21:Unit: 0x0000012980fccb045b36d01bcd468a0f
12:55:19:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:55:19:WU00:FS01:0x21:Machine: 1
12:55:19:WU00:FS01:0x21:Reading tar file core.xml
12:55:19:WU00:FS01:0x21:Reading tar file integrator.xml
12:55:19:WU00:FS01:0x21:Reading tar file state.xml
12:55:19:WU00:FS01:0x21:Reading tar file system.xml
12:55:20:WU00:FS01:0x21:Digital signatures verified
12:55:20:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:55:20:WU00:FS01:0x21:Version 0.0.20
12:55:25:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:55:25:WU00:FS01:0x21:Saving result file logfile_01.txt
12:55:25:WU00:FS01:0x21:Saving result file log.txt
12:55:25:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:55:26:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:55:26:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13816 run:0 clone:522 gen:213 core:0x21 unit:0x0000012980fccb045b36d01bcd468a0f
12:55:26:WU00:FS01:Uploading 2.28KiB to 128.252.203.4
12:55:26:WU00:FS01:Connecting to 128.252.203.4:8080
12:55:26:WU00:FS01:Upload complete
12:55:27:WU00:FS01:Server responded WORK_ACK (400)
12:55:27:WU00:FS01:Cleaning up
12:55:27:WU02:FS01:Connecting to 65.254.110.245:8080
12:55:27:WU02:FS01:Assigned to work server 155.247.166.220
12:55:27:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [Quadro NVS 4200M] from 155.247.166.220
12:55:27:WU02:FS01:Connecting to 155.247.166.220:8080
12:55:31:WU02:FS01:Downloading 2.47MiB
12:55:34:WU02:FS01:Download complete
12:55:34:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:2 clone:134 gen:22 core:0x21 unit:0x000000230002894c5d3b547291d4f83b
12:55:34:WU02:FS01:Starting
12:55:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:55:34:WU02:FS01:Started FahCore on PID 1640
12:55:34:WU02:FS01:Core PID:5216
12:55:34:WU02:FS01:FahCore 0x21 started
12:55:35:WU02:FS01:0x21:*********************** Log Started 2019-08-12T12:55:35Z ***********************
12:55:35:WU02:FS01:0x21:Project: 14180 (Run 2, Clone 134, Gen 22)
12:55:35:WU02:FS01:0x21:Unit: 0x000000230002894c5d3b547291d4f83b
12:55:35:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:55:35:WU02:FS01:0x21:Machine: 1
12:55:35:WU02:FS01:0x21:Reading tar file core.xml
12:55:35:WU02:FS01:0x21:Reading tar file integrator.xml
12:55:35:WU02:FS01:0x21:Reading tar file state.xml
12:55:35:WU02:FS01:0x21:Reading tar file system.xml
12:55:36:WU02:FS01:0x21:Digital signatures verified
12:55:36:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:55:36:WU02:FS01:0x21:Version 0.0.20
12:55:43:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
12:55:43:WU02:FS01:0x21:Saving result file logfile_01.txt
12:55:43:WU02:FS01:0x21:Saving result file log.txt
12:55:43:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
12:55:44:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:55:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:2 clone:134 gen:22 core:0x21 unit:0x000000230002894c5d3b547291d4f83b
12:55:44:WU02:FS01:Uploading 2.29KiB to 155.247.166.220
12:55:44:WU02:FS01:Connecting to 155.247.166.220:8080
12:55:45:WU02:FS01:Upload complete
12:55:45:WU02:FS01:Server responded WORK_ACK (400)
12:55:45:WU02:FS01:Cleaning up
12:59:43:WU01:FS00:0xa7:Completed 3150000 out of 5000000 steps (63%)
13:08:39:WU01:FS00:0xa7:Completed 3200000 out of 5000000 steps (64%)
13:17:28:WU01:FS00:0xa7:Completed 3250000 out of 5000000 steps (65%)
13:26:17:WU01:FS00:0xa7:Completed 3300000 out of 5000000 steps (66%)
13:35:06:WU01:FS00:0xa7:Completed 3350000 out of 5000000 steps (67%)
13:43:56:WU01:FS00:0xa7:Completed 3400000 out of 5000000 steps (68%)
13:52:47:WU01:FS00:0xa7:Completed 3450000 out of 5000000 steps (69%)
14:01:37:WU01:FS00:0xa7:Completed 3500000 out of 5000000 steps (70%)
14:10:27:WU01:FS00:0xa7:Completed 3550000 out of 5000000 steps (71%)
14:19:17:WU01:FS00:0xa7:Completed 3600000 out of 5000000 steps (72%)
14:28:08:WU01:FS00:0xa7:Completed 3650000 out of 5000000 steps (73%)
14:36:57:WU01:FS00:0xa7:Completed 3700000 out of 5000000 steps (74%)
14:45:47:WU01:FS00:0xa7:Completed 3750000 out of 5000000 steps (75%)
14:54:36:WU01:FS00:0xa7:Completed 3800000 out of 5000000 steps (76%)
15:03:24:WU01:FS00:0xa7:Completed 3850000 out of 5000000 steps (77%)
15:12:14:WU01:FS00:0xa7:Completed 3900000 out of 5000000 steps (78%)
15:21:01:WU01:FS00:0xa7:Completed 3950000 out of 5000000 steps (79%)
15:29:49:WU01:FS00:0xa7:Completed 4000000 out of 5000000 steps (80%)
15:38:37:WU01:FS00:0xa7:Completed 4050000 out of 5000000 steps (81%)
15:47:26:WU01:FS00:0xa7:Completed 4100000 out of 5000000 steps (82%)
15:56:15:WU01:FS00:0xa7:Completed 4150000 out of 5000000 steps (83%)
16:05:04:WU01:FS00:0xa7:Completed 4200000 out of 5000000 steps (84%)
16:13:53:WU01:FS00:0xa7:Completed 4250000 out of 5000000 steps (85%)
16:22:42:WU01:FS00:0xa7:Completed 4300000 out of 5000000 steps (86%)
16:31:32:WU01:FS00:0xa7:Completed 4350000 out of 5000000 steps (87%)
16:40:22:WU01:FS00:0xa7:Completed 4400000 out of 5000000 steps (88%)
16:49:10:WU01:FS00:0xa7:Completed 4450000 out of 5000000 steps (89%)
16:57:59:WU01:FS00:0xa7:Completed 4500000 out of 5000000 steps (90%)
17:06:46:WU01:FS00:0xa7:Completed 4550000 out of 5000000 steps (91%)
17:15:34:WU01:FS00:0xa7:Completed 4600000 out of 5000000 steps (92%)
17:24:22:WU01:FS00:0xa7:Completed 4650000 out of 5000000 steps (93%)
17:33:11:WU01:FS00:0xa7:Completed 4700000 out of 5000000 steps (94%)
17:42:00:WU01:FS00:0xa7:Completed 4750000 out of 5000000 steps (95%)
17:50:49:WU01:FS00:0xa7:Completed 4800000 out of 5000000 steps (96%)
17:59:39:WU01:FS00:0xa7:Completed 4850000 out of 5000000 steps (97%)
18:08:28:WU01:FS00:0xa7:Completed 4900000 out of 5000000 steps (98%)
18:17:17:WU01:FS00:0xa7:Completed 4950000 out of 5000000 steps (99%)
18:17:18:WU00:FS00:Connecting to 65.254.110.245:8080
18:17:18:WU00:FS00:Assigned to work server 128.252.203.9
18:17:18:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.252.203.9
18:17:18:WU00:FS00:Connecting to 128.252.203.9:8080
18:17:19:WU00:FS00:Downloading 8.14MiB
18:17:20:WU00:FS00:Download complete
18:17:20:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13824 run:909 clone:1 gen:63 core:0xa7 unit:0x0000004a80fccb095c9247c25798200a
18:26:07:WU01:FS00:0xa7:Completed 5000000 out of 5000000 steps (100%)
18:26:08:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
18:26:08:WU01:FS00:0xa7:Saving result file ener.edr
18:26:08:WU01:FS00:0xa7:Saving result file frame102.trr
18:26:08:WU01:FS00:0xa7:Saving result file md.log
18:26:09:WU01:FS00:0xa7:Saving result file science.log
18:26:09:WU01:FS00:0xa7:Saving result file traj_comp.xtc
18:26:09:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:26:09:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:26:09:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14153 run:13 clone:235 gen:102 core:0xa7 unit:0x0000007a0002894b5c6e03b8010bdb88
18:26:09:WU01:FS00:Uploading 4.17MiB to 155.247.166.219
18:26:09:WU01:FS00:Connecting to 155.247.166.219:8080
18:26:09:WU00:FS00:Starting
18:26:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3024 -checkpoint 15 -np 7
18:26:09:WU00:FS00:Started FahCore on PID 692
18:26:09:WU00:FS00:Core PID:7524
18:26:09:WU00:FS00:FahCore 0xa7 started
18:26:10:WU00:FS00:0xa7:*********************** Log Started 2019-08-12T18:26:09Z ***********************
18:26:10:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:26:10:WU00:FS00:0xa7:       Type: 0xa7
18:26:10:WU00:FS00:0xa7:       Core: Gromacs
18:26:10:WU00:FS00:0xa7:    Website: https://foldingathome.org/
18:26:10:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
18:26:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:26:10:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 692 -checkpoint 15 -np 7
18:26:10:WU00:FS00:0xa7:     Config: <none>
18:26:10:WU00:FS00:0xa7:************************************ Build *************************************
18:26:10:WU00:FS00:0xa7:    Version: 0.0.17
18:26:10:WU00:FS00:0xa7:       Date: Apr 25 2018
18:26:10:WU00:FS00:0xa7:       Time: 11:02:26
18:26:10:WU00:FS00:0xa7: Repository: Git
18:26:10:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
18:26:10:WU00:FS00:0xa7:     Branch: master
18:26:10:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:26:10:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:26:10:WU00:FS00:0xa7:   Platform: win32 10
18:26:10:WU00:FS00:0xa7:       Bits: 32
18:26:10:WU00:FS00:0xa7:       Mode: Release
18:26:10:WU00:FS00:0xa7:       SIMD: sse2
18:26:10:WU00:FS00:0xa7:************************************ System ************************************
18:26:10:WU00:FS00:0xa7:        CPU: Unknown
18:26:10:WU00:FS00:0xa7:     CPU ID:
18:26:10:WU00:FS00:0xa7:       CPUs: 8
18:26:10:WU00:FS00:0xa7:     Memory: 7.88GiB
18:26:10:WU00:FS00:0xa7:Free Memory: 6.26GiB
18:26:10:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:26:10:WU00:FS00:0xa7: OS Version: 6.2
18:26:10:WU00:FS00:0xa7:Has Battery: true
18:26:10:WU00:FS00:0xa7: On Battery: false
18:26:10:WU00:FS00:0xa7: UTC Offset: -4
18:26:10:WU00:FS00:0xa7:        PID: 7524
18:26:10:WU00:FS00:0xa7:        CWD: C:\Users\pc\AppData\Roaming\FAHClient\work
18:26:10:WU00:FS00:0xa7:         OS: Windows 10 Enterprise
18:26:10:WU00:FS00:0xa7:    OS Arch: AMD64
18:26:10:WU00:FS00:0xa7:********************************************************************************
18:26:10:WU00:FS00:0xa7:Project: 13824 (Run 909, Clone 1, Gen 63)
18:26:10:WU00:FS00:0xa7:Unit: 0x0000004a80fccb095c9247c25798200a
18:26:10:WU00:FS00:0xa7:Reading tar file core.xml
18:26:10:WU00:FS00:0xa7:Reading tar file frame63.tpr
18:26:10:WU00:FS00:0xa7:Digital signatures verified
18:26:10:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
18:26:10:WU00:FS00:0xa7:Calling: mdrun -s frame63.tpr -o frame63.trr -x frame63.xtc -cpt 15 -nt 6
18:26:10:WU00:FS00:0xa7:Steps: first=7875000 total=125000
18:26:13:WU01:FS00:Upload complete
18:26:13:WU01:FS00:Server responded WORK_ACK (400)
18:26:13:WU01:FS00:Final credit estimate, 3847.00 points
18:26:13:WU01:FS00:Cleaning up
18:26:16:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
18:30:40:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
18:35:04:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
18:39:28:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
18:43:58:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
18:48:32:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
18:53:02:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
******************************* Date: 2019-08-12 *******************************
18:53:12:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:57:48:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
19:02:25:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
19:06:55:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
19:11:28:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
19:15:56:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
19:20:19:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
19:24:42:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
19:29:10:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
19:33:33:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
19:37:56:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
19:42:23:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
19:46:46:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
19:51:09:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
19:55:32:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
19:59:59:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
20:04:21:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
20:08:44:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
20:13:10:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
20:17:33:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
20:21:55:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
20:26:21:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
20:30:44:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
20:35:06:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
20:39:29:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
20:43:55:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
20:48:18:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
Four items:
OpenCL 1.1 is not supported by F@H, the minimum seems to be 1.2.
Wikipedia hints there is no Double Precision hardware, current WUs need at least some Double Precision. So all WUs will eventually fail.
No newer driver is available, all Fermi GPUs are unsupported now (The F is GF108 is Fermi)
Lastly, Wikipedia thinks the GF108 is a Quadro NVS 5400M, so GPU.txt may have a naming problem.
If it was me, I would delete the GPU Slot, and use all 8 CPU cores.
Koolje
Post by Koolje »
JimboPalmer wrote:Four items:
Ok, so there is no fix for the problem?
No, a Quadro NVS 5400M would normally be in a laptop, so you can't upgrade the GPU.
The GF108 was introduced in January 2011.
If it is a desktop, you would want a newer GPU.
With this laptop, I would delete the GPU Slot, and use all 8 CPU cores.
Koolje
Post by Koolje »
JimboPalmer wrote:No, a Quadro NVS 5400M would normally be in a laptop, so you can't upgrade the GPU.
Ok Thanks
12:53:08: CPUs: 8
So F@H knows you have 8 CPUs, but it holds one in reserve to aid the GPU, and uses 7 to do Core_a7 WUs
If you tab into Configure, and then Slots, you can delete the GPU Slot. All 8 CPUs will be used in the next WU.
Burialsheer
Post by Burialsheer »
I just started folding and my GPU is failed. I've added the log file (not all of it because of the character limit). Can someone help me?
*********************** Log Started 2019-08-17T09:29:50Z ***********************
09:29:50:************************* Folding@home Client *************************
09:29:50:        Website: https://foldingathome.org/
09:29:50:      Copyright: (c) 2009-2018 foldingathome.org
09:29:50:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:29:50:           Args: --open-web-control
09:29:50:         Config: <none>
09:29:50:******************************** Build ********************************
09:29:50:        Version: 7.5.1
09:29:50:           Date: May 11 2018
09:29:50:           Time: 13:06:32
09:29:50:     Repository: Git
09:29:50:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:29:50:         Branch: master
09:29:50:       Compiler: Visual C++ 2008
09:29:50:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:29:50:       Platform: win32 10
09:29:50:           Bits: 32
09:29:50:           Mode: Release
09:29:50:******************************* System ********************************
09:29:50:            CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
09:29:50:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:29:50:           CPUs: 4
09:29:50:         Memory: 7.88GiB
09:29:50:    Free Memory: 3.74GiB
09:29:50:        Threads: WINDOWS_THREADS
09:29:50:     OS Version: 6.2
09:29:50:    Has Battery: true
09:29:50:     On Battery: false
09:29:50:     UTC Offset: 3
09:29:50:            PID: 2812
09:29:50:            CWD: C:\Users\Laura\AppData\Roaming\FAHClient
09:29:50:             OS: Windows 10 Home
09:29:50:        OS Arch: AMD64
09:29:50:           GPUs: 0
09:29:50:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
09:29:50:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:431.60
09:29:50:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:22.20
09:29:50:  Win32 Service: false
09:29:50:***********************************************************************
09:29:50:<config>
09:29:50:  <!-- Folding Slots -->
09:29:50:</config>
09:29:50:Connecting to assign1.foldingathome.org:8080
09:29:51:Updated GPUs.txt
09:29:51:Read GPUs.txt
09:29:51:Trying to access database...
09:29:51:Successfully acquired database lock
09:29:51:Enabled folding slot 00: PAUSED cpu:1 (not configured)
09:29:51:Enabled folding slot 01: PAUSED gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] (not configured)
09:29:56:8:127.0.0.1:New Web connection
09:30:52:Saving configuration to config.xml
09:30:52:<config>
09:30:52:  <!-- Folding Slots -->
09:30:52:  <slot id='0' type='CPU'/>
09:30:52:  <slot id='1' type='GPU'/>
09:30:52:</config>
09:30:52:Set client configured
09:30:52:WU00:FS00:Connecting to 65.254.110.245:8080
09:30:53:WU00:FS00:Assigned to work server 155.247.166.219
09:30:53:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 155.247.166.219
09:30:53:WU00:FS00:Connecting to 155.247.166.219:8080
09:30:54:WU00:FS00:Downloading 1.45MiB
09:30:58:WU00:FS00:Download complete
09:30:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14137 run:18 clone:62 gen:2 core:0xa7 unit:0x000000020002894b5d547cbc13573f33
09:30:58:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/x86/Core_a7.fah
09:30:58:WU00:FS00:Connecting to cores.foldingathome.org:80
09:30:58:WU00:FS00:FahCore a7: Downloading 5.10MiB
09:31:04:WU00:FS00:FahCore a7: 37.98%
09:31:10:WU00:FS00:FahCore a7: 83.31%
09:31:12:WU00:FS00:FahCore a7: Download complete
09:31:12:WU00:FS00:Valid core signature
09:31:12:WU00:FS00:Unpacked 15.36MiB to cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe
09:31:13:WU00:FS00:Unpacked 2.07MiB to cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/libfftw3f-3.dll
09:31:13:WU00:FS00:Unpacked 105.50KiB to cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/libgcc_s_dw2-1.dll
09:31:13:WU00:FS00:Starting
09:31:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -np 1
09:31:13:WU00:FS00:Started FahCore on PID 7580
09:31:15:WU00:FS00:Core PID:13896
09:31:15:WU00:FS00:FahCore 0xa7 started
09:31:15:WU00:FS00:0xa7:*********************** Log Started 2019-08-17T09:31:15Z ***********************
09:31:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:31:15:WU00:FS00:0xa7:       Type: 0xa7
09:31:15:WU00:FS00:0xa7:       Core: Gromacs
09:31:15:WU00:FS00:0xa7:    Website: https://foldingathome.org/
09:31:15:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:31:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:31:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7580 -checkpoint 15 -np 1
09:31:15:WU00:FS00:0xa7:     Config: <none>
09:31:15:WU00:FS00:0xa7:************************************ Build *************************************
09:31:15:WU00:FS00:0xa7:    Version: 0.0.17
09:31:15:WU00:FS00:0xa7:       Date: Apr 25 2018
09:31:15:WU00:FS00:0xa7:       Time: 11:02:26
09:31:15:WU00:FS00:0xa7: Repository: Git
09:31:15:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
09:31:15:WU00:FS00:0xa7:     Branch: master
09:31:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:31:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:31:15:WU00:FS00:0xa7:   Platform: win32 10
09:31:15:WU00:FS00:0xa7:       Bits: 32
09:31:15:WU00:FS00:0xa7:       Mode: Release
09:31:15:WU00:FS00:0xa7:       SIMD: sse2
09:31:15:WU00:FS00:0xa7:************************************ System ************************************
09:31:15:WU00:FS00:0xa7:        CPU: Unknown
09:31:15:WU00:FS00:0xa7:     CPU ID:
09:31:15:WU00:FS00:0xa7:       CPUs: 4
09:31:15:WU00:FS00:0xa7:     Memory: 7.88GiB
09:31:15:WU00:FS00:0xa7:Free Memory: 2.60GiB
09:31:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:31:15:WU00:FS00:0xa7: OS Version: 6.2
09:31:15:WU00:FS00:0xa7:Has Battery: true
09:31:15:WU00:FS00:0xa7: On Battery: false
09:31:15:WU00:FS00:0xa7: UTC Offset: 3
09:31:15:WU00:FS00:0xa7:        PID: 13896
09:31:15:WU00:FS00:0xa7:        CWD: C:\Users\Laura\AppData\Roaming\FAHClient\work
09:31:15:WU00:FS00:0xa7:         OS: Windows 10 Home
09:31:15:WU00:FS00:0xa7:    OS Arch: AMD64
09:31:15:WU00:FS00:0xa7:********************************************************************************
09:31:15:WU00:FS00:0xa7:Project: 14137 (Run 18, Clone 62, Gen 2)
09:31:15:WU00:FS00:0xa7:Unit: 0x000000020002894b5d547cbc13573f33
09:31:15:WU00:FS00:0xa7:Reading tar file core.xml
09:31:15:WU00:FS00:0xa7:Reading tar file frame2.tpr
09:31:15:WU00:FS00:0xa7:Digital signatures verified
09:31:15:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpt 15 -nt 1
09:31:16:WU00:FS00:0xa7:Steps: first=5000000 total=2500000
09:31:17:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
09:36:58:Saving configuration to config.xml
09:36:58:<config>
09:36:58:  <!-- User Information -->
09:36:58:  <passkey v='********************************'/>
09:36:58:  <team v='223518'/>
09:36:58:  <user v='Burialsheer'/>
09:36:58:
09:36:58:  <!-- Folding Slots -->
09:36:58:  <slot id='0' type='CPU'/>
09:36:58:  <slot id='1' type='GPU'/>
09:36:58:</config>
09:40:36:FS00:Shutting core down
09:40:36:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 13896
09:40:36:WU00:FS00:0xa7:Exiting, please wait. . .
09:40:36:WU01:FS01:Connecting to 65.254.110.245:8080
09:40:36:WU01:FS01:Assigned to work server 155.247.166.220
09:40:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:40:36:WU01:FS01:Connecting to 155.247.166.220:8080
09:40:37:FS00:Shutting core down
09:40:38:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:40:38:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:40:38:WU00:FS00:Starting
09:40:38:WARNING:WU00:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
09:40:38:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
09:40:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -np 1
09:40:38:WU00:FS00:Started FahCore on PID 7792
09:40:38:WU00:FS00:Core PID:14064
09:40:38:WU00:FS00:FahCore 0xa7 started
09:40:39:WU00:FS00:0xa7:*********************** Log Started 2019-08-17T09:40:39Z ***********************
09:40:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:40:39:WU00:FS00:0xa7:       Type: 0xa7
09:40:39:WU00:FS00:0xa7:       Core: Gromacs
09:40:39:WU00:FS00:0xa7:    Website: https://foldingathome.org/
09:40:39:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:40:39:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:40:39:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7792 -checkpoint 15 -np 1
09:40:39:WU00:FS00:0xa7:     Config: <none>
09:40:39:WU00:FS00:0xa7:************************************ Build *************************************
09:40:39:WU00:FS00:0xa7:    Version: 0.0.17
09:40:39:WU00:FS00:0xa7:       Date: Apr 25 2018
09:40:39:WU00:FS00:0xa7:       Time: 11:02:26
09:40:39:WU00:FS00:0xa7: Repository: Git
09:40:39:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
09:40:39:WU00:FS00:0xa7:     Branch: master
09:40:39:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:40:40:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:40:40:WU00:FS00:0xa7:   Platform: win32 10
09:40:40:WU00:FS00:0xa7:       Bits: 32
09:40:40:WU00:FS00:0xa7:       Mode: Release
09:40:40:WU00:FS00:0xa7:       SIMD: sse2
09:40:40:WU00:FS00:0xa7:************************************ System ************************************
09:40:40:WU00:FS00:0xa7:        CPU: Unknown
09:40:40:WU00:FS00:0xa7:     CPU ID:
09:40:40:WU00:FS00:0xa7:       CPUs: 4
09:40:40:WU00:FS00:0xa7:     Memory: 7.88GiB
09:40:40:WU00:FS00:0xa7:Free Memory: 2.86GiB
09:40:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:40:40:WU00:FS00:0xa7: OS Version: 6.2
09:40:40:WU00:FS00:0xa7:Has Battery: true
09:40:40:WU00:FS00:0xa7: On Battery: false
09:40:40:WU00:FS00:0xa7: UTC Offset: 3
09:40:40:WU00:FS00:0xa7:        PID: 14064
09:40:40:WU00:FS00:0xa7:        CWD: C:\Users\Laura\AppData\Roaming\FAHClient\work
09:40:40:WU00:FS00:0xa7:         OS: Windows 10 Home
09:40:40:WU00:FS00:0xa7:    OS Arch: AMD64
09:40:40:WU00:FS00:0xa7:********************************************************************************
09:40:40:WU00:FS00:0xa7:Project: 14137 (Run 18, Clone 62, Gen 2)
09:40:40:WU00:FS00:0xa7:Unit: 0x000000020002894b5d547cbc13573f33
09:40:40:WU00:FS00:0xa7:Digital signatures verified
09:40:40:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 1
09:40:40:WU00:FS00:0xa7:Steps: first=5000000 total=2500000
09:40:40:WU01:FS01:Downloading 2.47MiB
09:40:40:WU00:FS00:0xa7:Completed 5102 out of 2500000 steps (0%)
09:40:46:WU01:FS01:Download 73.32%
09:40:47:WU01:FS01:Download complete
09:40:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:3 clone:779 gen:1 core:0x21 unit:0x000000040002894c5d3b54bfd1e7823c
09:40:47:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
09:40:47:WU01:FS01:Connecting to cores.foldingathome.org:80
09:40:48:WU01:FS01:FahCore 21: Downloading 3.47MiB
09:40:54:WU01:FS01:FahCore 21: 62.99%
09:40:57:WU01:FS01:FahCore 21: Download complete
09:40:57:WU01:FS01:Valid core signature
09:40:57:WU01:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
09:40:57:WU01:FS01:Starting
09:40:57:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:40:57:WU01:FS01:Started FahCore on PID 13996
09:40:58:WU01:FS01:Core PID:1684
09:40:58:WU01:FS01:FahCore 0x21 started
09:40:58:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:40:58Z ***********************
09:40:58:WU01:FS01:0x21:Project: 14180 (Run 3, Clone 779, Gen 1)
09:40:58:WU01:FS01:0x21:Unit: 0x000000040002894c5d3b54bfd1e7823c
09:40:58:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:40:58:WU01:FS01:0x21:Machine: 1
09:40:58:WU01:FS01:0x21:Reading tar file core.xml
09:40:58:WU01:FS01:0x21:Reading tar file integrator.xml
09:40:58:WU01:FS01:0x21:Reading tar file state.xml
09:40:59:WU01:FS01:0x21:Reading tar file system.xml
09:40:59:WU01:FS01:0x21:Digital signatures verified
09:40:59:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:40:59:WU01:FS01:0x21:Version 0.0.20
09:41:02:Saving configuration to config.xml
09:41:02:<config>
09:41:02:  <!-- Slot Control -->
09:41:02:  <power v='FULL'/>
09:41:02:
09:41:02:  <!-- User Information -->
09:41:02:  <passkey v='********************************'/>
09:41:02:  <team v='223518'/>
09:41:02:  <user v='Burialsheer'/>
09:41:02:
09:41:02:  <!-- Folding Slots -->
09:41:02:  <slot id='0' type='CPU'/>
09:41:02:  <slot id='1' type='GPU'/>
09:41:02:</config>
09:41:05:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:41:05:WU01:FS01:0x21:Saving result file logfile_01.txt
09:41:05:WU01:FS01:0x21:Saving result file log.txt
09:41:05:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:41:05:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:41:05:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:3 clone:779 gen:1 core:0x21 unit:0x000000040002894c5d3b54bfd1e7823c
09:41:05:WU01:FS01:Uploading 2.37KiB to 155.247.166.220
09:41:05:WU01:FS01:Connecting to 155.247.166.220:8080
09:41:06:WU02:FS01:Connecting to 65.254.110.245:8080
09:41:06:WU02:FS01:Assigned to work server 128.252.203.10
09:41:06:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 128.252.203.10
09:41:06:WU02:FS01:Connecting to 128.252.203.10:8080
09:41:07:WU01:FS01:Upload complete
09:41:07:ERROR:WU02:FS01:Exception: Server did not assign work unit
09:41:07:WU01:FS01:Server responded WORK_ACK (400)
09:41:07:WU01:FS01:Cleaning up
09:41:07:WU02:FS01:Connecting to 65.254.110.245:8080
09:41:08:WU02:FS01:Assigned to work server 155.247.166.220
09:41:08:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:41:08:WU02:FS01:Connecting to 155.247.166.220:8080
09:41:12:WU02:FS01:Downloading 2.48MiB
09:41:18:WU02:FS01:Download 90.83%
09:41:18:WU02:FS01:Download complete
09:41:18:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:9 clone:186 gen:36 core:0x21 unit:0x000000400002894c5d3b55b7faeea7ac
09:41:18:WU02:FS01:Starting
09:41:18:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:41:18:WU02:FS01:Started FahCore on PID 9608
09:41:19:WU02:FS01:Core PID:13332
09:41:19:WU02:FS01:FahCore 0x21 started
09:41:19:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:41:19Z ***********************
09:41:19:WU02:FS01:0x21:Project: 14180 (Run 9, Clone 186, Gen 36)
09:41:19:WU02:FS01:0x21:Unit: 0x000000400002894c5d3b55b7faeea7ac
09:41:19:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:41:19:WU02:FS01:0x21:Machine: 1
09:41:19:WU02:FS01:0x21:Reading tar file core.xml
09:41:19:WU02:FS01:0x21:Reading tar file integrator.xml
09:41:19:WU02:FS01:0x21:Reading tar file state.xml
09:41:19:WU02:FS01:0x21:Reading tar file system.xml
09:41:20:WU02:FS01:0x21:Digital signatures verified
09:41:20:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:41:20:WU02:FS01:0x21:Version 0.0.20
09:41:24:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:41:24:WU02:FS01:0x21:Saving result file logfile_01.txt
09:41:24:WU02:FS01:0x21:Saving result file log.txt
09:41:24:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:41:25:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:41:25:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:9 clone:186 gen:36 core:0x21 unit:0x000000400002894c5d3b55b7faeea7ac
09:41:25:WU02:FS01:Uploading 2.37KiB to 155.247.166.220
09:41:25:WU02:FS01:Connecting to 155.247.166.220:8080
09:41:25:WU02:FS01:Upload complete
09:41:25:WU02:FS01:Server responded WORK_ACK (400)
09:41:25:WU02:FS01:Cleaning up
09:41:25:WU01:FS01:Connecting to 65.254.110.245:8080
09:41:26:WU01:FS01:Assigned to work server 155.247.166.220
09:41:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:41:26:WU01:FS01:Connecting to 155.247.166.220:8080
09:41:29:WU01:FS01:Downloading 2.47MiB
09:41:35:WU01:FS01:Download 86.12%
09:41:35:WU01:FS01:Download complete
09:41:35:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:11 clone:638 gen:4 core:0x21 unit:0x000000050002894c5d3b5636582dc403
09:41:35:WU01:FS01:Starting
09:41:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:41:35:WU01:FS01:Started FahCore on PID 8260
09:41:36:WU01:FS01:Core PID:224
09:41:36:WU01:FS01:FahCore 0x21 started
09:41:36:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:41:36Z ***********************
09:41:36:WU01:FS01:0x21:Project: 14180 (Run 11, Clone 638, Gen 4)
09:41:36:WU01:FS01:0x21:Unit: 0x000000050002894c5d3b5636582dc403
09:41:36:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:41:36:WU01:FS01:0x21:Machine: 1
09:41:36:WU01:FS01:0x21:Reading tar file core.xml
09:41:36:WU01:FS01:0x21:Reading tar file integrator.xml
09:41:36:WU01:FS01:0x21:Reading tar file state.xml
09:41:37:WU01:FS01:0x21:Reading tar file system.xml
09:41:37:WU01:FS01:0x21:Digital signatures verified
09:41:37:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:41:37:WU01:FS01:0x21:Version 0.0.20
09:41:41:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:41:41:WU01:FS01:0x21:Saving result file logfile_01.txt
09:41:41:WU01:FS01:0x21:Saving result file log.txt
09:41:41:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:41:42:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:41:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:11 clone:638 gen:4 core:0x21 unit:0x000000050002894c5d3b5636582dc403
09:41:42:WU01:FS01:Uploading 2.39KiB to 155.247.166.220
09:41:42:WU01:FS01:Connecting to 155.247.166.220:8080
09:41:42:WU01:FS01:Upload complete
09:41:42:WU01:FS01:Server responded WORK_ACK (400)
09:41:42:WU01:FS01:Cleaning up
09:41:42:WU02:FS01:Connecting to 65.254.110.245:8080
09:41:43:WU02:FS01:Assigned to work server 155.247.166.220
09:41:43:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:41:43:WU02:FS01:Connecting to 155.247.166.220:8080
09:41:47:WU02:FS01:Downloading 2.47MiB
09:41:52:WU02:FS01:Download complete
09:41:52:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:6 clone:778 gen:1 core:0x21 unit:0x000000030002894c5d3b5542e343c836
09:41:52:WU02:FS01:Starting
09:41:52:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:41:53:WU02:FS01:Started FahCore on PID 9024
09:41:53:WU02:FS01:Core PID:13500
09:41:53:WU02:FS01:FahCore 0x21 started
09:41:53:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:41:53Z ***********************
09:41:53:WU02:FS01:0x21:Project: 14180 (Run 6, Clone 778, Gen 1)
09:41:53:WU02:FS01:0x21:Unit: 0x000000030002894c5d3b5542e343c836
09:41:53:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:41:53:WU02:FS01:0x21:Machine: 1
09:41:53:WU02:FS01:0x21:Reading tar file core.xml
09:41:53:WU02:FS01:0x21:Reading tar file integrator.xml
09:41:53:WU02:FS01:0x21:Reading tar file state.xml
09:41:54:WU02:FS01:0x21:Reading tar file system.xml
09:41:54:WU02:FS01:0x21:Digital signatures verified
09:41:54:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:41:54:WU02:FS01:0x21:Version 0.0.20
09:41:58:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:41:58:WU02:FS01:0x21:Saving result file logfile_01.txt
09:41:58:WU02:FS01:0x21:Saving result file log.txt
09:41:58:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:41:59:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:41:59:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:6 clone:778 gen:1 core:0x21 unit:0x000000030002894c5d3b5542e343c836
09:41:59:WU02:FS01:Uploading 2.35KiB to 155.247.166.220
09:41:59:WU02:FS01:Connecting to 155.247.166.220:8080
09:41:59:WU02:FS01:Upload complete
09:41:59:WU02:FS01:Server responded WORK_ACK (400)
09:41:59:WU02:FS01:Cleaning up
09:41:59:WU01:FS01:Connecting to 65.254.110.245:8080
09:42:03:WU01:FS01:Assigned to work server 128.252.203.4
09:42:03:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 128.252.203.4
09:42:03:WU01:FS01:Connecting to 128.252.203.4:8080
09:42:09:WU01:FS01:Downloading 1.79MiB
09:42:14:WU01:FS01:Download complete
09:42:14:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2670 gen:249 core:0x21 unit:0x0000015780fccb045b3f7912677b3762
09:42:14:WU01:FS01:Starting
09:42:14:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:42:14:WU01:FS01:Started FahCore on PID 10284
09:42:15:WU01:FS01:Core PID:15068
09:42:15:WU01:FS01:FahCore 0x21 started
09:42:15:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:42:15Z ***********************
09:42:15:WU01:FS01:0x21:Project: 13816 (Run 0, Clone 2670, Gen 249)
09:42:15:WU01:FS01:0x21:Unit: 0x0000015780fccb045b3f7912677b3762
09:42:15:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:42:15:WU01:FS01:0x21:Machine: 1
09:42:15:WU01:FS01:0x21:Reading tar file core.xml
09:42:15:WU01:FS01:0x21:Reading tar file integrator.xml
09:42:15:WU01:FS01:0x21:Reading tar file state.xml
09:42:15:WU01:FS01:0x21:Reading tar file system.xml
09:42:15:WU01:FS01:0x21:Digital signatures verified
09:42:15:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:42:15:WU01:FS01:0x21:Version 0.0.20
09:42:19:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:42:19:WU01:FS01:0x21:Saving result file logfile_01.txt
09:42:19:WU01:FS01:0x21:Saving result file log.txt
09:42:19:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13816 run:0 clone:2670 gen:249 core:0x21 unit:0x0000015780fccb045b3f7912677b3762
09:42:20:WU01:FS01:Uploading 2.37KiB to 128.252.203.4
09:42:20:WU01:FS01:Connecting to 128.252.203.4:8080
09:42:20:WU01:FS01:Upload complete
09:42:20:WU01:FS01:Server responded WORK_ACK (400)
09:42:20:WU01:FS01:Cleaning up
09:42:20:WU02:FS01:Connecting to 65.254.110.245:8080
09:42:20:WU02:FS01:Assigned to work server 155.247.166.220
09:42:20:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:42:20:WU02:FS01:Connecting to 155.247.166.220:8080
09:42:24:WU02:FS01:Downloading 2.47MiB
09:42:30:WU02:FS01:Download 93.64%
09:42:30:WU02:FS01:Download complete
09:42:30:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:2 clone:176 gen:32 core:0x21 unit:0x000000410002894c5d3b5473855fbc38
09:42:30:WU02:FS01:Starting
09:42:30:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:42:30:WU02:FS01:Started FahCore on PID 7392
09:42:30:WU02:FS01:Core PID:15036
09:42:30:WU02:FS01:FahCore 0x21 started
09:42:31:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:42:30Z ***********************
09:42:31:WU02:FS01:0x21:Project: 14180 (Run 2, Clone 176, Gen 32)
09:42:31:WU02:FS01:0x21:Unit: 0x000000410002894c5d3b5473855fbc38
09:42:31:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:42:31:WU02:FS01:0x21:Machine: 1
09:42:31:WU02:FS01:0x21:Reading tar file core.xml
09:42:31:WU02:FS01:0x21:Reading tar file integrator.xml
09:42:31:WU02:FS01:0x21:Reading tar file state.xml
09:42:31:WU02:FS01:0x21:Reading tar file system.xml
09:42:31:WU02:FS01:0x21:Digital signatures verified
09:42:31:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:42:31:WU02:FS01:0x21:Version 0.0.20
09:42:36:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:42:36:WU02:FS01:0x21:Saving result file logfile_01.txt
09:42:36:WU02:FS01:0x21:Saving result file log.txt
09:42:36:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:37:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:37:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:2 clone:176 gen:32 core:0x21 unit:0x000000410002894c5d3b5473855fbc38
09:42:37:WU02:FS01:Uploading 2.37KiB to 155.247.166.220
09:42:37:WU02:FS01:Connecting to 155.247.166.220:8080
09:42:37:WU02:FS01:Upload complete
09:42:37:WU02:FS01:Server responded WORK_ACK (400)
09:42:37:WU02:FS01:Cleaning up
09:42:37:WU01:FS01:Connecting to 65.254.110.245:8080
09:42:37:WU01:FS01:Assigned to work server 128.252.203.4
09:42:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 128.252.203.4
09:42:37:WU01:FS01:Connecting to 128.252.203.4:8080
09:42:41:WU01:FS01:Downloading 1.79MiB
09:42:46:WU01:FS01:Download complete
09:42:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:1332 gen:221 core:0x21 unit:0x0000012d80fccb045b3a656aa2e3c0b6
09:42:46:WU01:FS01:Starting
09:42:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:42:46:WU01:FS01:Started FahCore on PID 7088
09:42:46:WU01:FS01:Core PID:12400
09:42:46:WU01:FS01:FahCore 0x21 started
09:42:47:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:42:46Z ***********************
09:42:47:WU01:FS01:0x21:Project: 13816 (Run 0, Clone 1332, Gen 221)
09:42:47:WU01:FS01:0x21:Unit: 0x0000012d80fccb045b3a656aa2e3c0b6
09:42:47:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:42:47:WU01:FS01:0x21:Machine: 1
09:42:47:WU01:FS01:0x21:Reading tar file core.xml
09:42:47:WU01:FS01:0x21:Reading tar file integrator.xml
09:42:47:WU01:FS01:0x21:Reading tar file state.xml
09:42:47:WU01:FS01:0x21:Reading tar file system.xml
09:42:47:WU01:FS01:0x21:Digital signatures verified
09:42:47:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:42:47:WU01:FS01:0x21:Version 0.0.20
09:42:50:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:42:50:WU01:FS01:0x21:Saving result file logfile_01.txt
09:42:50:WU01:FS01:0x21:Saving result file log.txt
09:42:50:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:51:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:51:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13816 run:0 clone:1332 gen:221 core:0x21 unit:0x0000012d80fccb045b3a656aa2e3c0b6
09:42:51:WU01:FS01:Uploading 2.39KiB to 128.252.203.4
09:42:51:WU01:FS01:Connecting to 128.252.203.4:8080
09:42:52:WU02:FS01:Connecting to 65.254.110.245:8080
09:42:52:WU02:FS01:Assigned to work server 155.247.166.220
09:42:52:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:42:52:WU02:FS01:Connecting to 155.247.166.220:8080
09:42:54:WU01:FS01:Upload complete
09:42:55:WU01:FS01:Server responded WORK_ACK (400)
09:42:55:WU01:FS01:Cleaning up
09:42:56:WU02:FS01:Downloading 2.47MiB
09:43:02:WU02:FS01:Download 100.00%
09:43:02:WU02:FS01:Download complete
09:43:02:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:8 clone:692 gen:2 core:0x21 unit:0x000000060002894c5d3b55a10f2b5e2e
09:43:02:WU02:FS01:Starting
09:43:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:43:02:WU02:FS01:Started FahCore on PID 11372
09:43:02:WU02:FS01:Core PID:3980
09:43:02:WU02:FS01:FahCore 0x21 started
09:43:02:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:43:02Z ***********************
09:43:02:WU02:FS01:0x21:Project: 14180 (Run 8, Clone 692, Gen 2)
09:43:02:WU02:FS01:0x21:Unit: 0x000000060002894c5d3b55a10f2b5e2e
09:43:02:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:43:02:WU02:FS01:0x21:Machine: 1
09:43:02:WU02:FS01:0x21:Reading tar file core.xml
09:43:02:WU02:FS01:0x21:Reading tar file integrator.xml
09:43:02:WU02:FS01:0x21:Reading tar file state.xml
09:43:03:WU02:FS01:0x21:Reading tar file system.xml
09:43:03:WU02:FS01:0x21:Digital signatures verified
09:43:03:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:43:03:WU02:FS01:0x21:Version 0.0.20
09:43:07:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:43:07:WU02:FS01:0x21:Saving result file logfile_01.txt
09:43:07:WU02:FS01:0x21:Saving result file log.txt
09:43:07:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:43:08:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:43:08:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:8 clone:692 gen:2 core:0x21 unit:0x000000060002894c5d3b55a10f2b5e2e
09:43:08:WU02:FS01:Uploading 2.38KiB to 155.247.166.220
09:43:08:WU02:FS01:Connecting to 155.247.166.220:8080
09:43:09:WU02:FS01:Upload complete
09:43:09:WU02:FS01:Server responded WORK_ACK (400)
09:43:09:WU02:FS01:Cleaning up
09:43:09:WU01:FS01:Connecting to 65.254.110.245:8080
09:43:09:WU01:FS01:Assigned to work server 155.247.166.220
09:43:09:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:43:09:WU01:FS01:Connecting to 155.247.166.220:8080
09:43:13:WU01:FS01:Downloading 2.48MiB
09:43:19:WU01:FS01:Download 90.57%
09:43:19:WU01:FS01:Download complete
09:43:19:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:10 clone:752 gen:2 core:0x21 unit:0x000000070002894c5d3b56044ba97ab1
09:43:19:WU01:FS01:Starting
09:43:19:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:43:19:WU01:FS01:Started FahCore on PID 560
09:43:19:WU01:FS01:Core PID:15224
09:43:19:WU01:FS01:FahCore 0x21 started
09:43:20:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:43:19Z ***********************
09:43:20:WU01:FS01:0x21:Project: 14180 (Run 10, Clone 752, Gen 2)
09:43:20:WU01:FS01:0x21:Unit: 0x000000070002894c5d3b56044ba97ab1
09:43:20:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:43:20:WU01:FS01:0x21:Machine: 1
09:43:20:WU01:FS01:0x21:Reading tar file core.xml
09:43:20:WU01:FS01:0x21:Reading tar file integrator.xml
09:43:20:WU01:FS01:0x21:Reading tar file state.xml
09:43:20:WU01:FS01:0x21:Reading tar file system.xml
09:43:20:WU01:FS01:0x21:Digital signatures verified
09:43:20:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:43:20:WU01:FS01:0x21:Version 0.0.20
09:43:25:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:43:25:WU01:FS01:0x21:Saving result file logfile_01.txt
09:43:25:WU01:FS01:0x21:Saving result file log.txt
09:43:25:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:43:26:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:43:26:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:10 clone:752 gen:2 core:0x21 unit:0x000000070002894c5d3b56044ba97ab1
09:43:26:WU01:FS01:Uploading 2.36KiB to 155.247.166.220
09:43:26:WU01:FS01:Connecting to 155.247.166.220:8080
09:43:26:WU01:FS01:Upload complete
09:43:26:WU01:FS01:Server responded WORK_ACK (400)
09:43:26:WU01:FS01:Cleaning up
09:43:26:WU02:FS01:Connecting to 65.254.110.245:8080
09:43:27:WU02:FS01:Assigned to work server 128.252.203.4
09:43:27:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 128.252.203.4
09:43:27:WU02:FS01:Connecting to 128.252.203.4:8080
09:43:29:WU02:FS01:Downloading 1.79MiB
09:43:34:WU02:FS01:Download complete
09:43:34:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:860 gen:238 core:0x21 unit:0x0000014780fccb045b36d01dd2215812
09:43:34:WU02:FS01:Starting
09:43:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:43:34:WU02:FS01:Started FahCore on PID 10772
09:43:34:WU02:FS01:Core PID:9660
09:43:34:WU02:FS01:FahCore 0x21 started
09:43:35:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:43:34Z ***********************
09:43:35:WU02:FS01:0x21:Project: 13816 (Run 0, Clone 860, Gen 238)
09:43:35:WU02:FS01:0x21:Unit: 0x0000014780fccb045b36d01dd2215812
09:43:35:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:43:35:WU02:FS01:0x21:Machine: 1
09:43:35:WU02:FS01:0x21:Reading tar file core.xml
09:43:35:WU02:FS01:0x21:Reading tar file integrator.xml
09:43:35:WU02:FS01:0x21:Reading tar file state.xml
09:43:35:WU02:FS01:0x21:Reading tar file system.xml
09:43:35:WU02:FS01:0x21:Digital signatures verified
09:43:35:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:43:35:WU02:FS01:0x21:Version 0.0.20
09:43:38:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:43:39:WU02:FS01:0x21:Saving result file logfile_01.txt
09:43:39:WU02:FS01:0x21:Saving result file log.txt
09:43:39:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:43:39:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:43:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13816 run:0 clone:860 gen:238 core:0x21 unit:0x0000014780fccb045b36d01dd2215812
09:43:39:WU02:FS01:Uploading 2.39KiB to 128.252.203.4
09:43:39:WU02:FS01:Connecting to 128.252.203.4:8080
09:43:40:WU02:FS01:Upload complete
09:43:40:WU02:FS01:Server responded WORK_ACK (400)
09:43:40:WU02:FS01:Cleaning up
09:46:51:FS00:Paused
09:46:51:FS01:Paused
09:46:51:FS00:Shutting core down
09:46:51:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 14064
09:46:51:WU00:FS00:0xa7:Exiting, please wait. . .
09:46:52:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:46:52:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:47:05:FS00:Unpaused
09:47:05:FS01:Unpaused
09:47:05:WU00:FS00:Starting
09:47:05:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
09:47:05:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -np 1
09:47:05:WU00:FS00:Started FahCore on PID 2844
09:47:05:WU00:FS00:Core PID:10444
09:47:05:WU00:FS00:FahCore 0xa7 started
09:47:06:WU01:FS01:Connecting to 65.254.110.245:8080
09:47:06:WU00:FS00:0xa7:*********************** Log Started 2019-08-17T09:47:06Z ***********************
09:47:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:47:06:WU00:FS00:0xa7:       Type: 0xa7
09:47:06:WU00:FS00:0xa7:       Core: Gromacs
09:47:06:WU00:FS00:0xa7:    Website: https://foldingathome.org/
09:47:06:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:47:06:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:47:06:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2844 -checkpoint 15 -np 1
09:47:06:WU00:FS00:0xa7:     Config: <none>
09:47:06:WU00:FS00:0xa7:************************************ Build *************************************
09:47:06:WU00:FS00:0xa7:    Version: 0.0.17
09:47:06:WU00:FS00:0xa7:       Date: Apr 25 2018
09:47:06:WU00:FS00:0xa7:       Time: 11:02:26
09:47:06:WU00:FS00:0xa7: Repository: Git
09:47:06:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
09:47:06:WU00:FS00:0xa7:     Branch: master
09:47:06:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
09:47:06:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:47:06:WU00:FS00:0xa7:   Platform: win32 10
09:47:06:WU00:FS00:0xa7:       Bits: 32
09:47:06:WU00:FS00:0xa7:       Mode: Release
09:47:06:WU00:FS00:0xa7:       SIMD: sse2
09:47:06:WU00:FS00:0xa7:************************************ System ************************************
09:47:06:WU00:FS00:0xa7:        CPU: Unknown
09:47:06:WU00:FS00:0xa7:     CPU ID:
09:47:06:WU00:FS00:0xa7:       CPUs: 4
09:47:06:WU00:FS00:0xa7:     Memory: 7.88GiB
09:47:06:WU00:FS00:0xa7:Free Memory: 2.81GiB
09:47:06:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
09:47:06:WU00:FS00:0xa7: OS Version: 6.2
09:47:06:WU00:FS00:0xa7:Has Battery: true
09:47:06:WU00:FS00:0xa7: On Battery: false
09:47:06:WU00:FS00:0xa7: UTC Offset: 3
09:47:06:WU00:FS00:0xa7:        PID: 10444
09:47:06:WU00:FS00:0xa7:        CWD: C:\Users\Laura\AppData\Roaming\FAHClient\work
09:47:06:WU00:FS00:0xa7:         OS: Windows 10 Home
09:47:06:WU00:FS00:0xa7:    OS Arch: AMD64
09:47:06:WU00:FS00:0xa7:********************************************************************************
09:47:06:WU00:FS00:0xa7:Project: 14137 (Run 18, Clone 62, Gen 2)
09:47:06:WU00:FS00:0xa7:Unit: 0x000000020002894b5d547cbc13573f33
09:47:06:WU00:FS00:0xa7:Digital signatures verified
09:47:06:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 1
09:47:06:WU00:FS00:0xa7:Steps: first=5000000 total=2500000
09:47:06:WU01:FS01:Assigned to work server 155.247.166.220
09:47:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:47:06:WU01:FS01:Connecting to 155.247.166.220:8080
09:47:07:WU00:FS00:0xa7:Completed 8502 out of 2500000 steps (0%)
09:47:10:WU01:FS01:Downloading 2.47MiB
09:47:16:WU01:FS01:Download 83.60%
09:47:17:WU01:FS01:Download complete
09:47:17:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:2 clone:844 gen:1 core:0x21 unit:0x000000010002894c5d3b549149c6e4ec
09:47:17:WU01:FS01:Starting
09:47:17:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:47:17:WU01:FS01:Started FahCore on PID 8616
09:47:17:WU01:FS01:Core PID:3308
09:47:17:WU01:FS01:FahCore 0x21 started
09:47:17:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:47:17Z ***********************
09:47:17:WU01:FS01:0x21:Project: 14180 (Run 2, Clone 844, Gen 1)
09:47:17:WU01:FS01:0x21:Unit: 0x000000010002894c5d3b549149c6e4ec
09:47:17:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:47:17:WU01:FS01:0x21:Machine: 1
09:47:17:WU01:FS01:0x21:Reading tar file core.xml
09:47:17:WU01:FS01:0x21:Reading tar file integrator.xml
09:47:17:WU01:FS01:0x21:Reading tar file state.xml
09:47:18:WU01:FS01:0x21:Reading tar file system.xml
09:47:18:WU01:FS01:0x21:Digital signatures verified
09:47:18:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:47:18:WU01:FS01:0x21:Version 0.0.20
09:47:23:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:47:23:WU01:FS01:0x21:Saving result file logfile_01.txt
09:47:23:WU01:FS01:0x21:Saving result file log.txt
09:47:23:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:47:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:47:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:2 clone:844 gen:1 core:0x21 unit:0x000000010002894c5d3b549149c6e4ec
09:47:24:WU01:FS01:Uploading 2.36KiB to 155.247.166.220
09:47:24:WU01:FS01:Connecting to 155.247.166.220:8080
09:47:24:WU02:FS01:Connecting to 65.254.110.245:8080
09:47:25:WU02:FS01:Assigned to work server 140.163.4.241
09:47:25:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 140.163.4.241
09:47:25:WU02:FS01:Connecting to 140.163.4.241:8080
09:47:25:WU01:FS01:Upload complete
09:47:25:WU01:FS01:Server responded WORK_ACK (400)
09:47:25:WU01:FS01:Cleaning up
09:47:25:WU02:FS01:Downloading 16.53MiB
09:47:31:WU02:FS01:Download 13.99%
09:47:37:WU02:FS01:Download 27.98%
09:47:43:WU02:FS01:Download 38.94%
09:47:49:WU02:FS01:Download 54.44%
09:47:55:WU02:FS01:Download 70.32%
09:48:01:WU02:FS01:Download 85.82%
09:48:06:WU02:FS01:Download complete
09:48:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:1368 gen:30 core:0x21 unit:0x000000298ca304f15afabde1d8c00c60
09:48:06:WU02:FS01:Starting
09:48:06:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:48:06:WU02:FS01:Started FahCore on PID 2532
09:48:07:WU02:FS01:Core PID:9328
09:48:07:WU02:FS01:FahCore 0x21 started
09:48:07:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:48:07Z ***********************
09:48:07:WU02:FS01:0x21:Project: 11714 (Run 0, Clone 1368, Gen 30)
09:48:07:WU02:FS01:0x21:Unit: 0x000000298ca304f15afabde1d8c00c60
09:48:07:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:48:07:WU02:FS01:0x21:Machine: 1
09:48:07:WU02:FS01:0x21:Reading tar file core.xml
09:48:07:WU02:FS01:0x21:Reading tar file integrator.xml
09:48:07:WU02:FS01:0x21:Reading tar file state.xml
09:48:07:WU02:FS01:0x21:Reading tar file system.xml
09:48:07:WU02:FS01:0x21:Digital signatures verified
09:48:07:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:48:07:WU02:FS01:0x21:Version 0.0.20
09:48:12:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:48:12:WU02:FS01:0x21:Saving result file logfile_01.txt
09:48:12:WU02:FS01:0x21:Saving result file log.txt
09:48:12:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:48:12:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:48:12:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11714 run:0 clone:1368 gen:30 core:0x21 unit:0x000000298ca304f15afabde1d8c00c60
09:48:12:WU02:FS01:Uploading 7.50KiB to 140.163.4.241
09:48:12:WU02:FS01:Connecting to 140.163.4.241:8080
09:48:13:WU01:FS01:Connecting to 65.254.110.245:8080
09:48:13:WU02:FS01:Upload complete
09:48:13:WU02:FS01:Server responded WORK_ACK (400)
09:48:13:WU02:FS01:Cleaning up
09:48:13:WU01:FS01:Assigned to work server 155.247.166.220
09:48:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:48:13:WU01:FS01:Connecting to 155.247.166.220:8080
09:48:17:WU01:FS01:Downloading 2.47MiB
09:48:23:WU01:FS01:Download 93.51%
09:48:23:WU01:FS01:Download complete
09:48:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:9 clone:679 gen:3 core:0x21 unit:0x000000070002894c5d3b55d1163b1b74
09:48:23:WU01:FS01:Starting
09:48:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:48:23:WU01:FS01:Started FahCore on PID 15152
09:48:23:WU01:FS01:Core PID:15040
09:48:23:WU01:FS01:FahCore 0x21 started
09:48:24:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:48:23Z ***********************
09:48:24:WU01:FS01:0x21:Project: 14180 (Run 9, Clone 679, Gen 3)
09:48:24:WU01:FS01:0x21:Unit: 0x000000070002894c5d3b55d1163b1b74
09:48:24:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:48:24:WU01:FS01:0x21:Machine: 1
09:48:24:WU01:FS01:0x21:Reading tar file core.xml
09:48:24:WU01:FS01:0x21:Reading tar file integrator.xml
09:48:24:WU01:FS01:0x21:Reading tar file state.xml
09:48:24:WU01:FS01:0x21:Reading tar file system.xml
09:48:24:WU01:FS01:0x21:Digital signatures verified
09:48:24:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:48:24:WU01:FS01:0x21:Version 0.0.20
09:48:29:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:48:29:WU01:FS01:0x21:Saving result file logfile_01.txt
09:48:29:WU01:FS01:0x21:Saving result file log.txt
09:48:29:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:48:30:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:48:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:9 clone:679 gen:3 core:0x21 unit:0x000000070002894c5d3b55d1163b1b74
09:48:30:WU01:FS01:Uploading 2.36KiB to 155.247.166.220
09:48:30:WU01:FS01:Connecting to 155.247.166.220:8080
09:48:30:WU02:FS01:Connecting to 65.254.110.245:8080
09:48:31:WU02:FS01:Assigned to work server 155.247.166.220
09:48:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:48:31:WU02:FS01:Connecting to 155.247.166.220:8080
09:48:33:WU01:FS01:Upload complete
09:48:33:WU01:FS01:Server responded WORK_ACK (400)
09:48:33:WU01:FS01:Cleaning up
09:48:37:WU02:FS01:Downloading 2.47MiB
09:48:43:WU02:FS01:Download 43.02%
09:48:46:WU02:FS01:Download complete
09:48:46:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:14 clone:716 gen:2 core:0x21 unit:0x000000040002894c5d3b56d280143c05
09:48:46:WU02:FS01:Starting
09:48:46:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:48:46:WU02:FS01:Started FahCore on PID 2968
09:48:47:WU02:FS01:Core PID:12860
09:48:47:WU02:FS01:FahCore 0x21 started
09:48:47:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:48:47Z ***********************
09:48:47:WU02:FS01:0x21:Project: 14180 (Run 14, Clone 716, Gen 2)
09:48:47:WU02:FS01:0x21:Unit: 0x000000040002894c5d3b56d280143c05
09:48:47:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:48:47:WU02:FS01:0x21:Machine: 1
09:48:47:WU02:FS01:0x21:Reading tar file core.xml
09:48:47:WU02:FS01:0x21:Reading tar file integrator.xml
09:48:47:WU02:FS01:0x21:Reading tar file state.xml
09:48:47:WU02:FS01:0x21:Reading tar file system.xml
09:48:48:WU02:FS01:0x21:Digital signatures verified
09:48:48:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:48:48:WU02:FS01:0x21:Version 0.0.20
09:48:52:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:48:52:WU02:FS01:0x21:Saving result file logfile_01.txt
09:48:52:WU02:FS01:0x21:Saving result file log.txt
09:48:52:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:48:53:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:48:53:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:14 clone:716 gen:2 core:0x21 unit:0x000000040002894c5d3b56d280143c05
09:48:53:WU02:FS01:Uploading 2.36KiB to 155.247.166.220
09:48:53:WU02:FS01:Connecting to 155.247.166.220:8080
09:48:54:WU02:FS01:Upload complete
09:48:54:WU02:FS01:Server responded WORK_ACK (400)
09:48:54:WU02:FS01:Cleaning up
09:48:54:WU01:FS01:Connecting to 65.254.110.245:8080
09:48:54:WU01:FS01:Assigned to work server 155.247.166.220
09:48:54:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:48:54:WU01:FS01:Connecting to 155.247.166.220:8080
09:48:58:WU01:FS01:Downloading 2.47MiB
09:49:04:WU01:FS01:Download 100.00%
09:49:04:WU01:FS01:Download complete
09:49:04:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:5 clone:840 gen:1 core:0x21 unit:0x000000010002894c5d3b5524efe3868d
09:49:04:WU01:FS01:Starting
09:49:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:49:04:WU01:FS01:Started FahCore on PID 12440
09:49:04:WU01:FS01:Core PID:2616
09:49:04:WU01:FS01:FahCore 0x21 started
09:49:05:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:49:05Z ***********************
09:49:05:WU01:FS01:0x21:Project: 14180 (Run 5, Clone 840, Gen 1)
09:49:05:WU01:FS01:0x21:Unit: 0x000000010002894c5d3b5524efe3868d
09:49:05:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:49:05:WU01:FS01:0x21:Machine: 1
09:49:05:WU01:FS01:0x21:Reading tar file core.xml
09:49:05:WU01:FS01:0x21:Reading tar file integrator.xml
09:49:05:WU01:FS01:0x21:Reading tar file state.xml
09:49:06:WU01:FS01:0x21:Reading tar file system.xml
09:49:06:WU01:FS01:0x21:Digital signatures verified
09:49:06:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:49:06:WU01:FS01:0x21:Version 0.0.20
09:49:11:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:49:11:WU01:FS01:0x21:Saving result file logfile_01.txt
09:49:11:WU01:FS01:0x21:Saving result file log.txt
09:49:11:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:49:11:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:49:11:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:5 clone:840 gen:1 core:0x21 unit:0x000000010002894c5d3b5524efe3868d
09:49:11:WU01:FS01:Uploading 2.35KiB to 155.247.166.220
09:49:11:WU01:FS01:Connecting to 155.247.166.220:8080
09:49:12:WU01:FS01:Upload complete
09:49:12:WU01:FS01:Server responded WORK_ACK (400)
09:49:12:WU01:FS01:Cleaning up
09:49:12:WU02:FS01:Connecting to 65.254.110.245:8080
09:49:12:WU02:FS01:Assigned to work server 155.247.166.220
09:49:12:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:49:12:WU02:FS01:Connecting to 155.247.166.220:8080
09:49:16:WU02:FS01:Downloading 2.47MiB
09:49:22:WU02:FS01:Download 96.14%
09:49:22:WU02:FS01:Download complete
09:49:22:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14180 run:14 clone:385 gen:34 core:0x21 unit:0x000000370002894c5d3b56bf04df867c
09:49:22:WU02:FS01:Starting
09:49:22:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:49:22:WU02:FS01:Started FahCore on PID 5220
09:49:22:WU02:FS01:Core PID:552
09:49:22:WU02:FS01:FahCore 0x21 started
09:49:23:WU02:FS01:0x21:*********************** Log Started 2019-08-17T09:49:22Z ***********************
09:49:23:WU02:FS01:0x21:Project: 14180 (Run 14, Clone 385, Gen 34)
09:49:23:WU02:FS01:0x21:Unit: 0x000000370002894c5d3b56bf04df867c
09:49:23:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:49:23:WU02:FS01:0x21:Machine: 1
09:49:23:WU02:FS01:0x21:Reading tar file core.xml
09:49:23:WU02:FS01:0x21:Reading tar file integrator.xml
09:49:23:WU02:FS01:0x21:Reading tar file state.xml
09:49:23:WU02:FS01:0x21:Reading tar file system.xml
09:49:23:WU02:FS01:0x21:Digital signatures verified
09:49:23:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:49:23:WU02:FS01:0x21:Version 0.0.20
09:49:28:WU02:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:49:28:WU02:FS01:0x21:Saving result file logfile_01.txt
09:49:28:WU02:FS01:0x21:Saving result file log.txt
09:49:28:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:49:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:49:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14180 run:14 clone:385 gen:34 core:0x21 unit:0x000000370002894c5d3b56bf04df867c
09:49:29:WU02:FS01:Uploading 2.37KiB to 155.247.166.220
09:49:29:WU02:FS01:Connecting to 155.247.166.220:8080
09:49:29:WU02:FS01:Upload complete
09:49:29:WU02:FS01:Server responded WORK_ACK (400)
09:49:29:WU02:FS01:Cleaning up
09:49:29:WU01:FS01:Connecting to 65.254.110.245:8080
09:49:30:WU01:FS01:Assigned to work server 155.247.166.220
09:49:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile] from 155.247.166.220
09:49:30:WU01:FS01:Connecting to 155.247.166.220:8080
09:49:34:WU01:FS01:Downloading 2.48MiB
09:49:40:WU01:FS01:Download 67.94%
09:49:41:WU01:FS01:Download complete
09:49:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:13 clone:601 gen:6 core:0x21 unit:0x0000000d0002894c5d3b56a0a9fd2169
09:49:41:WU01:FS01:Starting
09:49:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Laura\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2812 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:49:41:WU01:FS01:Started FahCore on PID 2792
09:49:42:WU01:FS01:Core PID:10524
09:49:42:WU01:FS01:FahCore 0x21 started
09:49:42:WU01:FS01:0x21:*********************** Log Started 2019-08-17T09:49:42Z ***********************
09:49:42:WU01:FS01:0x21:Project: 14180 (Run 13, Clone 601, Gen 6)
09:49:42:WU01:FS01:0x21:Unit: 0x0000000d0002894c5d3b56a0a9fd2169
09:49:42:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:49:42:WU01:FS01:0x21:Machine: 1
09:49:42:WU01:FS01:0x21:Reading tar file core.xml
09:49:42:WU01:FS01:0x21:Reading tar file integrator.xml
09:49:42:WU01:FS01:0x21:Reading tar file state.xml
09:49:42:WU01:FS01:0x21:Reading tar file system.xml
09:49:43:WU01:FS01:0x21:Digital signatures verified
09:49:43:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:49:43:WU01:FS01:0x21:Version 0.0.20
09:49:47:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
09:49:47:WU01:FS01:0x21:Saving result file logfile_01.txt
09:49:47:WU01:FS01:0x21:Saving result file log.txt
09:49:47:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:49:48:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:49:48:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14180 run:13 clone:601 gen:6 core:0x21 unit:0x0000000d0002894c5d3b56a0a9fd2169
Re: GPU Status Failed
If your laptop has power saving features that disable the NV GPU to run on the Intel one while on battery, FAH won't like that and it might explain the issue.
Are you using video drivers supplied by MS through Windows Update? If you are, download the drivers from nVidia and install those. The driver MS supplies usually does not include OpenCL support which is required for GPU folding.
Burialsheer
So far I've only been running it plugged in so the battery saver problem can't be the issue.
To the best of my knowledge I had always used Nvidia drivers but I tried reinstalling them however I'm still facing the same problem.
I actually got it to work a few hours ago. Somehow it was at a status "Ready: waiting for idle", then I unticked the "on idle" and it worked. Then I paused everything for a little while after having run it for a few hours. When I set it folding again I had lost all my GPU progress and it fails again. I've tried to recreate what I did before but I've not been successful.
Also, what it does right before failing is that it switches back and forth between "running" and "ready" (in the web control it switches between green and yellow) and then after a little bit of doing that it says it failed.
Many years ago I had a laptop that used an 'Optimus' driver. For light graphical loads it would use an Intel GPU, then once there was heavy load, it would use a NVidia GPU.
This plays havoc with F@H as most commonly it starts with light usage, meaning the unacceptable Intel GPU. If you do get to the Nvidia GPU, it runs fine.
In the version I had, I found a way to select Always use the Nvidia GPU, and my issues went away. I encourage you to try to find a setting that disables the Intel GPU (We are guessing you have one as your Log shows two OpenCL devices)
http://www.nvidia.com/object/LO_optimus ... apers.html is about a decade old.
While my experience is old, it is still in use, see https://www.nvidia.com/en-us/geforce/ga ... x-1660-ti/
Many of these laptops that switch between GPU's do that even when plugged into their power adapter. They will switch to the low power GPU when idle or working on low intensity graphics not requiring the more powerful GPU. Some have provisions for locking the selection, but moany are on full auto for choosing which GPU will be active.
