Base credit
WorksForMe
Base credit
Post by WorksForMe »
I'm now getting the Base Credit for each WU instead of the Estimated Credit. I've got the Estimated Credit for years. Am I doing something wrong?
Re: Base credit
No, you are probably not doing anything wrong.
There are several older topics where this was reported, the issue is that some of the Work Servers have been updated with a newer version of the server code. One side effect has been WU's from projects on those servers have been getting just base credits over the last couple months. PG is aware of the issue, at some point in the future a manual crediting of the bonus points will happen.
WorksForMe
Re: Base credit
Joe_H wrote:No, you are probably not doing anything wrong.
Thanks for the reply Joe. I'm glad to hear it's a known issue. I was getting pretty frustrated.
Re: Base credit
You left out important information. Either I need to know which project(s) your having trouble with or which server(s) were involved.
including segments of your log (per the instructions below is generally a good idea, too.
WorksForMe
Re: Base credit
bruce wrote:You left out important information. Either I need to know which project(s) your having trouble with or which server(s) were involved.
Here is part of my log. I'm currently working on project #13826, but I don't know the project number for my previous WUs. If there's anything else you need, please let me know. Thanks in advance for the help.
22:41:19:WU01:FS00:0xa4:Completed 2475000 out of 2500000 steps  (99%)
22:41:19:WU00:FS00:Connecting to 65.254.110.245:8080
22:41:19:WU00:FS00:Assigned to work server 128.252.203.9
22:41:19:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
22:41:19:WU00:FS00:Connecting to 128.252.203.9:8080
22:41:20:WU00:FS00:Downloading 7.05MiB
22:41:22:WU00:FS00:Download complete
22:41:22:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13819 run:0 clone:786 gen:39 core:0xa7 unit:0x0000002c80fccb095c70611a70cfbd2f
22:44:45:WU01:FS00:0xa4:Completed 2500000 out of 2500000 steps  (100%)
22:44:46:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:44:56:WU01:FS00:0xa4:
22:44:56:WU01:FS00:0xa4:Finished Work Unit:
22:44:56:WU01:FS00:0xa4:- Reading up to 743328 from "01/wudata_01.trr": Read 743328
22:44:56:WU01:FS00:0xa4:trr file hash check passed.
22:44:56:WU01:FS00:0xa4:- Reading up to 39348 from "01/wudata_01.xtc": Read 39348
22:44:56:WU01:FS00:0xa4:xtc file hash check passed.
22:44:56:WU01:FS00:0xa4:edr file hash check passed.
22:44:56:WU01:FS00:0xa4:logfile size: 53137
22:44:56:WU01:FS00:0xa4:Leaving Run
22:44:57:WU01:FS00:0xa4:- Writing 872881 bytes of core data to disk...
22:44:57:WU01:FS00:0xa4:Done: 872369 -> 737853 (compressed to 84.5 percent)
22:44:57:WU01:FS00:0xa4:  ... Done.
22:44:58:WU01:FS00:0xa4:- Shutting down core
22:44:58:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:44:58:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:44:58:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8690 run:0 clone:260 gen:45 core:0xa4 unit:0x000000330002894c5d24f8dfb7bbc740
22:44:58:WU01:FS00:Uploading 721.06KiB to 155.247.166.220
22:44:58:WU01:FS00:Connecting to 155.247.166.220:8080
22:44:58:WU00:FS00:Starting
22:44:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
22:44:58:WU00:FS00:Started FahCore on PID 6664
22:44:59:WU01:FS00:Upload complete
22:45:00:WU00:FS00:Core PID:11616
22:45:00:WU00:FS00:FahCore 0xa7 started
22:45:01:WU00:FS00:0xa7:*********************** Log Started 2019-08-01T22:45:01Z ***********************
22:45:01:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:45:01:WU01:FS00:Server responded WORK_ACK (400)
22:45:01:WU00:FS00:0xa7:       Type: 0xa7
22:45:01:WU01:FS00:Final credit estimate, 1069.00 points
22:45:01:WU00:FS00:0xa7:       Core: Gromacs
22:45:01:WU00:FS00:0xa7:    Website: https://foldingathome.org/
22:45:01:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
22:45:01:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:45:01:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 6664 -checkpoint 30 -np 4
22:45:01:WU00:FS00:0xa7:     Config: <none>
22:45:01:WU00:FS00:0xa7:************************************ Build *************************************
22:45:01:WU00:FS00:0xa7:    Version: 0.0.17
22:45:01:WU00:FS00:0xa7:       Date: Apr 25 2018
22:45:01:WU00:FS00:0xa7:       Time: 11:02:26
22:45:01:WU00:FS00:0xa7: Repository: Git
22:45:01:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
22:45:01:WU00:FS00:0xa7:     Branch: master
22:45:01:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:45:01:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:45:01:WU00:FS00:0xa7:   Platform: win32 10
22:45:01:WU00:FS00:0xa7:       Bits: 32
22:45:01:WU00:FS00:0xa7:       Mode: Release
22:45:01:WU00:FS00:0xa7:       SIMD: sse2
22:45:01:WU01:FS00:Cleaning up
22:45:01:WU00:FS00:0xa7:************************************ System ************************************
22:45:01:WU00:FS00:0xa7:        CPU: Unknown
22:45:01:WU00:FS00:0xa7:     CPU ID:
22:45:01:WU00:FS00:0xa7:       CPUs: 4
22:45:01:WU00:FS00:0xa7:     Memory: 3.89GiB
22:45:01:WU00:FS00:0xa7:Free Memory: 1.40GiB
22:45:01:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:45:01:WU00:FS00:0xa7: OS Version: 6.2
22:45:01:WU00:FS00:0xa7:Has Battery: true
22:45:01:WU00:FS00:0xa7: On Battery: false
22:45:01:WU00:FS00:0xa7: UTC Offset: -4
22:45:01:WU00:FS00:0xa7:        PID: 11616
22:45:01:WU00:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
22:45:01:WU00:FS00:0xa7:         OS: Windows 10 Home
22:45:01:WU00:FS00:0xa7:    OS Arch: AMD64
22:45:01:WU00:FS00:0xa7:********************************************************************************
22:45:01:WU00:FS00:0xa7:Project: 13819 (Run 0, Clone 786, Gen 39)
22:45:01:WU00:FS00:0xa7:Unit: 0x0000002c80fccb095c70611a70cfbd2f
22:45:01:WU00:FS00:0xa7:Reading tar file core.xml
22:45:01:WU00:FS00:0xa7:Reading tar file frame39.tpr
22:45:01:WU00:FS00:0xa7:Digital signatures verified
22:45:01:WU00:FS00:0xa7:Calling: mdrun -s frame39.tpr -o frame39.trr -x frame39.xtc -cpt 30 -nt 4
22:45:02:WU00:FS00:0xa7:Steps: first=4875000 total=125000
22:45:09:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
22:53:14:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
[u](steps removed to save space)[/u]
12:45:55:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
12:45:56:WU01:FS00:Connecting to 65.254.110.245:8080
12:45:57:WU01:FS00:Assigned to work server 155.247.166.220
12:45:57:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.220
12:45:57:WU01:FS00:Connecting to 155.247.166.220:8080
12:46:00:WU01:FS00:Downloading 340.00KiB
12:46:00:WU01:FS00:Download complete
12:46:01:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14142 run:1 clone:57 gen:263 core:0xa7 unit:0x000001400002894c5bffef11bac95d2d
12:54:39:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
12:54:56:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
12:54:56:WU00:FS00:0xa7:Saving result file frame39.trr
12:54:56:WU00:FS00:0xa7:Saving result file frame39.xtc
12:54:56:WU00:FS00:0xa7:Saving result file md.log
12:54:56:WU00:FS00:0xa7:Saving result file science.log
12:54:57:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:54:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:54:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13819 run:0 clone:786 gen:39 core:0xa7 unit:0x0000002c80fccb095c70611a70cfbd2f
12:54:58:WU00:FS00:Uploading 9.53MiB to 128.252.203.9
12:54:58:WU01:FS00:Starting
12:54:58:WU00:FS00:Connecting to 128.252.203.9:8080
12:54:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
12:55:01:WU01:FS00:Started FahCore on PID 1612
12:55:03:WU01:FS00:Core PID:7284
12:55:03:WU01:FS00:FahCore 0xa7 started
12:55:04:WU00:FS00:Upload 87.25%
12:55:04:WU01:FS00:0xa7:*********************** Log Started 2019-08-02T12:55:04Z ***********************
12:55:04:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:55:04:WU01:FS00:0xa7:       Type: 0xa7
12:55:04:WU01:FS00:0xa7:       Core: Gromacs
12:55:04:WU01:FS00:0xa7:    Website: https://foldingathome.org/
12:55:04:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:55:04:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:55:04:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 1612 -checkpoint 30 -np 4
12:55:04:WU01:FS00:0xa7:     Config: <none>
12:55:04:WU01:FS00:0xa7:************************************ Build *************************************
12:55:04:WU01:FS00:0xa7:    Version: 0.0.17
12:55:04:WU01:FS00:0xa7:       Date: Apr 25 2018
12:55:04:WU01:FS00:0xa7:       Time: 11:02:26
12:55:04:WU01:FS00:0xa7: Repository: Git
12:55:04:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
12:55:04:WU01:FS00:0xa7:     Branch: master
12:55:04:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:55:04:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:55:04:WU01:FS00:0xa7:   Platform: win32 10
12:55:04:WU01:FS00:0xa7:       Bits: 32
12:55:05:WU01:FS00:0xa7:       Mode: Release
12:55:05:WU01:FS00:0xa7:       SIMD: sse2
12:55:05:WU01:FS00:0xa7:************************************ System ************************************
12:55:05:WU01:FS00:0xa7:        CPU: Unknown
12:55:05:WU01:FS00:0xa7:     CPU ID:
12:55:05:WU01:FS00:0xa7:       CPUs: 4
12:55:05:WU01:FS00:0xa7:     Memory: 3.89GiB
12:55:05:WU01:FS00:0xa7:Free Memory: 1.72GiB
12:55:05:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
12:55:05:WU01:FS00:0xa7: OS Version: 6.2
12:55:05:WU01:FS00:0xa7:Has Battery: true
12:55:05:WU01:FS00:0xa7: On Battery: false
12:55:05:WU01:FS00:0xa7: UTC Offset: -4
12:55:05:WU01:FS00:0xa7:        PID: 7284
12:55:05:WU01:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
12:55:05:WU01:FS00:0xa7:         OS: Windows 10 Home
12:55:05:WU01:FS00:0xa7:    OS Arch: AMD64
12:55:05:WU01:FS00:0xa7:********************************************************************************
12:55:05:WU01:FS00:0xa7:Project: 14142 (Run 1, Clone 57, Gen 263)
12:55:05:WU01:FS00:0xa7:Unit: 0x000001400002894c5bffef11bac95d2d
12:55:05:WU01:FS00:0xa7:Reading tar file core.xml
12:55:05:WU01:FS00:0xa7:Reading tar file frame263.tpr
12:55:05:WU01:FS00:0xa7:Digital signatures verified
12:55:05:WU01:FS00:0xa7:Calling: mdrun -s frame263.tpr -o frame263.trr -cpt 30 -nt 4
12:55:05:WU01:FS00:0xa7:Steps: first=657500000 total=2500000
12:55:05:WU00:FS00:Upload complete
12:55:05:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
12:55:06:WU00:FS00:Server responded WORK_ACK (400)
12:55:06:WU00:FS00:Final credit estimate, 700.00 points
12:55:06:WU00:FS00:Cleaning up
13:05:55:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
07:04:56:WU01:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
07:04:57:WU00:FS00:Connecting to 65.254.110.245:8080
07:04:58:WU00:FS00:Assigned to work server 128.252.203.9
07:04:58:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
07:04:58:WU00:FS00:Connecting to 128.252.203.9:8080
07:04:58:WU00:FS00:Downloading 7.05MiB
07:05:00:WU00:FS00:Download complete
07:05:00:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13819 run:0 clone:1132 gen:323 core:0xa7 unit:0x0000016380fccb095c7060f5f8050a70
07:15:24:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
07:15:26:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
07:15:26:WU01:FS00:0xa7:Saving result file frame263.trr
07:15:28:WU01:FS00:0xa7:Saving result file md.log
07:15:28:WU01:FS00:0xa7:Saving result file science.log
07:15:28:WU01:FS00:0xa7:Saving result file traj_comp.xtc
07:15:28:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
07:15:29:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:15:29:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14142 run:1 clone:57 gen:263 core:0xa7 unit:0x000001400002894c5bffef11bac95d2d
07:15:29:WU01:FS00:Uploading 3.37MiB to 155.247.166.220
07:15:29:WU00:FS00:Starting
07:15:29:WU01:FS00:Connecting to 155.247.166.220:8080
07:15:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
07:15:33:WU00:FS00:Started FahCore on PID 10376
07:15:35:WU01:FS00:Upload 68.68%
07:15:36:WU00:FS00:Core PID:1268
07:15:36:WU00:FS00:FahCore 0xa7 started
07:15:36:WU01:FS00:Upload complete
07:15:37:WU00:FS00:0xa7:*********************** Log Started 2019-08-03T07:15:37Z ***********************
07:15:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:15:37:WU00:FS00:0xa7:       Type: 0xa7
07:15:37:WU00:FS00:0xa7:       Core: Gromacs
07:15:37:WU00:FS00:0xa7:    Website: https://foldingathome.org/
07:15:37:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
07:15:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:15:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 10376 -checkpoint 30 -np
07:15:37:WU00:FS00:0xa7:             4
07:15:37:WU00:FS00:0xa7:     Config: <none>
07:15:37:WU00:FS00:0xa7:************************************ Build *************************************
07:15:37:WU00:FS00:0xa7:    Version: 0.0.17
07:15:37:WU00:FS00:0xa7:       Date: Apr 25 2018
07:15:37:WU00:FS00:0xa7:       Time: 11:02:26
07:15:37:WU00:FS00:0xa7: Repository: Git
07:15:37:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
07:15:37:WU00:FS00:0xa7:     Branch: master
07:15:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:15:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:15:37:WU00:FS00:0xa7:   Platform: win32 10
07:15:37:WU00:FS00:0xa7:       Bits: 32
07:15:37:WU00:FS00:0xa7:       Mode: Release
07:15:37:WU00:FS00:0xa7:       SIMD: sse2
07:15:38:WU00:FS00:0xa7:************************************ System ************************************
07:15:38:WU00:FS00:0xa7:        CPU: Unknown
07:15:38:WU00:FS00:0xa7:     CPU ID:
07:15:38:WU00:FS00:0xa7:       CPUs: 4
07:15:38:WU00:FS00:0xa7:     Memory: 3.89GiB
07:15:38:WU00:FS00:0xa7:Free Memory: 1.10GiB
07:15:38:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:15:38:WU00:FS00:0xa7: OS Version: 6.2
07:15:38:WU00:FS00:0xa7:Has Battery: true
07:15:38:WU00:FS00:0xa7: On Battery: false
07:15:38:WU00:FS00:0xa7: UTC Offset: -4
07:15:38:WU00:FS00:0xa7:        PID: 1268
07:15:38:WU00:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
07:15:38:WU00:FS00:0xa7:         OS: Windows 10 Home
07:15:38:WU00:FS00:0xa7:    OS Arch: AMD64
07:15:38:WU00:FS00:0xa7:********************************************************************************
07:15:38:WU01:FS00:Server responded WORK_ACK (400)
07:15:38:WU00:FS00:0xa7:Project: 13819 (Run 0, Clone 1132, Gen 323)
07:15:38:WU01:FS00:Final credit estimate, 2282.00 points
07:15:38:WU00:FS00:0xa7:Unit: 0x0000016380fccb095c7060f5f8050a70
07:15:38:WU00:FS00:0xa7:Reading tar file core.xml
07:15:38:WU00:FS00:0xa7:Reading tar file frame323.tpr
07:15:38:WU00:FS00:0xa7:Digital signatures verified
07:15:38:WU00:FS00:0xa7:Calling: mdrun -s frame323.tpr -o frame323.trr -x frame323.xtc -cpt 30 -nt 4
07:15:38:WU01:FS00:Cleaning up
07:15:38:WU00:FS00:0xa7:Steps: first=40375000 total=125000
07:15:46:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
07:24:01:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
20:58:22:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
20:58:23:WU01:FS00:Connecting to 65.254.110.245:8080
20:58:24:WU01:FS00:Assigned to work server 128.252.203.9
20:58:24:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
20:58:24:WU01:FS00:Connecting to 128.252.203.9:8080
20:58:25:WU01:FS00:Downloading 8.14MiB
20:58:27:WU01:FS00:Download complete
20:58:27:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13821 run:456 clone:2 gen:61 core:0xa7 unit:0x0000004480fccb095c88390a21b4614b
21:06:27:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
21:06:43:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:06:44:WU00:FS00:0xa7:Saving result file frame323.trr
21:06:44:WU00:FS00:0xa7:Saving result file frame323.xtc
21:06:44:WU00:FS00:0xa7:Saving result file md.log
21:06:44:WU00:FS00:0xa7:Saving result file science.log
21:06:45:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:06:45:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:06:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13819 run:0 clone:1132 gen:323 core:0xa7 unit:0x0000016380fccb095c7060f5f8050a70
21:06:45:WU00:FS00:Uploading 9.52MiB to 128.252.203.9
21:06:45:WU01:FS00:Starting
21:06:45:WU00:FS00:Connecting to 128.252.203.9:8080
21:06:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
21:06:48:WU01:FS00:Started FahCore on PID 9732
21:06:50:WU01:FS00:Core PID:3680
21:06:50:WU01:FS00:FahCore 0xa7 started
21:06:51:WU00:FS00:Upload 78.09%
21:06:52:WU01:FS00:0xa7:*********************** Log Started 2019-08-03T21:06:51Z ***********************
21:06:52:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:06:52:WU01:FS00:0xa7:       Type: 0xa7
21:06:52:WU01:FS00:0xa7:       Core: Gromacs
21:06:52:WU01:FS00:0xa7:    Website: https://foldingathome.org/
21:06:52:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
21:06:52:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:06:52:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 9732 -checkpoint 30 -np 4
21:06:52:WU01:FS00:0xa7:     Config: <none>
21:06:52:WU01:FS00:0xa7:************************************ Build *************************************
21:06:52:WU01:FS00:0xa7:    Version: 0.0.17
21:06:52:WU01:FS00:0xa7:       Date: Apr 25 2018
21:06:52:WU01:FS00:0xa7:       Time: 11:02:26
21:06:52:WU01:FS00:0xa7: Repository: Git
21:06:52:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
21:06:52:WU01:FS00:0xa7:     Branch: master
21:06:52:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:06:52:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:06:52:WU01:FS00:0xa7:   Platform: win32 10
21:06:52:WU01:FS00:0xa7:       Bits: 32
21:06:52:WU01:FS00:0xa7:       Mode: Release
21:06:52:WU01:FS00:0xa7:       SIMD: sse2
21:06:52:WU01:FS00:0xa7:************************************ System ************************************
21:06:52:WU01:FS00:0xa7:        CPU: Unknown
21:06:52:WU01:FS00:0xa7:     CPU ID:
21:06:52:WU01:FS00:0xa7:       CPUs: 4
21:06:52:WU01:FS00:0xa7:     Memory: 3.89GiB
21:06:52:WU01:FS00:0xa7:Free Memory: 1.65GiB
21:06:52:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:06:52:WU01:FS00:0xa7: OS Version: 6.2
21:06:52:WU01:FS00:0xa7:Has Battery: true
21:06:52:WU01:FS00:0xa7: On Battery: false
21:06:52:WU01:FS00:0xa7: UTC Offset: -4
21:06:52:WU01:FS00:0xa7:        PID: 3680
21:06:52:WU01:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
21:06:52:WU01:FS00:0xa7:         OS: Windows 10 Home
21:06:52:WU01:FS00:0xa7:    OS Arch: AMD64
21:06:52:WU01:FS00:0xa7:********************************************************************************
21:06:52:WU01:FS00:0xa7:Project: 13821 (Run 456, Clone 2, Gen 61)
21:06:52:WU01:FS00:0xa7:Unit: 0x0000004480fccb095c88390a21b4614b
21:06:52:WU01:FS00:0xa7:Reading tar file core.xml
21:06:52:WU01:FS00:0xa7:Reading tar file frame61.tpr
21:06:52:WU01:FS00:0xa7:Digital signatures verified
21:06:52:WU01:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -x frame61.xtc -cpt 30 -nt 4
21:06:53:WU01:FS00:0xa7:Steps: first=7625000 total=125000
21:06:53:WU00:FS00:Upload complete
21:06:54:WU00:FS00:Server responded WORK_ACK (400)
21:06:54:WU00:FS00:Final credit estimate, 700.00 points
21:06:54:WU00:FS00:Cleaning up
21:07:04:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
21:17:00:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
13:58:32:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
13:58:33:WU00:FS00:Connecting to 65.254.110.245:8080
13:58:34:WU00:FS00:Assigned to work server 155.247.166.219
13:58:34:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
13:58:34:WU00:FS00:Connecting to 155.247.166.219:8080
13:58:34:WU00:FS00:Downloading 293.29KiB
13:58:34:WU00:FS00:Download complete
13:58:35:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14153 run:5 clone:138 gen:180 core:0xa7 unit:0x000000cd0002894b5c546d2b6ea7f6d5
14:08:32:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
14:08:52:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
14:08:52:WU01:FS00:0xa7:Saving result file frame61.trr
14:08:52:WU01:FS00:0xa7:Saving result file frame61.xtc
14:08:53:WU01:FS00:0xa7:Saving result file md.log
14:08:53:WU01:FS00:0xa7:Saving result file science.log
14:08:53:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:08:53:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:08:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13821 run:456 clone:2 gen:61 core:0xa7 unit:0x0000004480fccb095c88390a21b4614b
14:08:53:WU01:FS00:Uploading 11.27MiB to 128.252.203.9
14:08:53:WU01:FS00:Connecting to 128.252.203.9:8080
14:08:53:WU00:FS00:Starting
14:08:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
14:08:55:WU00:FS00:Started FahCore on PID 2372
14:08:56:WU00:FS00:Core PID:10896
14:08:56:WU00:FS00:FahCore 0xa7 started
14:08:57:WU00:FS00:0xa7:*********************** Log Started 2019-08-04T14:08:57Z ***********************
14:08:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:08:57:WU00:FS00:0xa7:       Type: 0xa7
14:08:57:WU00:FS00:0xa7:       Core: Gromacs
14:08:57:WU00:FS00:0xa7:    Website: https://foldingathome.org/
14:08:57:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
14:08:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:08:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 2372 -checkpoint 30 -np 4
14:08:57:WU00:FS00:0xa7:     Config: <none>
14:08:57:WU00:FS00:0xa7:************************************ Build *************************************
14:08:57:WU00:FS00:0xa7:    Version: 0.0.17
14:08:57:WU00:FS00:0xa7:       Date: Apr 25 2018
14:08:57:WU00:FS00:0xa7:       Time: 11:02:26
14:08:57:WU00:FS00:0xa7: Repository: Git
14:08:57:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
14:08:57:WU00:FS00:0xa7:     Branch: master
14:08:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:08:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:08:57:WU00:FS00:0xa7:   Platform: win32 10
14:08:57:WU00:FS00:0xa7:       Bits: 32
14:08:57:WU00:FS00:0xa7:       Mode: Release
14:08:57:WU00:FS00:0xa7:       SIMD: sse2
14:08:57:WU00:FS00:0xa7:************************************ System ************************************
14:08:57:WU00:FS00:0xa7:        CPU: Unknown
14:08:57:WU00:FS00:0xa7:     CPU ID:
14:08:57:WU00:FS00:0xa7:       CPUs: 4
14:08:57:WU00:FS00:0xa7:     Memory: 3.89GiB
14:08:57:WU00:FS00:0xa7:Free Memory: 1.53GiB
14:08:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:08:57:WU00:FS00:0xa7: OS Version: 6.2
14:08:57:WU00:FS00:0xa7:Has Battery: true
14:08:57:WU00:FS00:0xa7: On Battery: false
14:08:57:WU00:FS00:0xa7: UTC Offset: -4
14:08:57:WU00:FS00:0xa7:        PID: 10896
14:08:57:WU00:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
14:08:57:WU00:FS00:0xa7:         OS: Windows 10 Home
14:08:57:WU00:FS00:0xa7:    OS Arch: AMD64
14:08:57:WU00:FS00:0xa7:********************************************************************************
14:08:57:WU00:FS00:0xa7:Project: 14153 (Run 5, Clone 138, Gen 180)
14:08:57:WU00:FS00:0xa7:Unit: 0x000000cd0002894b5c546d2b6ea7f6d5
14:08:57:WU00:FS00:0xa7:Reading tar file core.xml
14:08:57:WU00:FS00:0xa7:Reading tar file frame180.tpr
14:08:57:WU00:FS00:0xa7:Digital signatures verified
14:08:57:WU00:FS00:0xa7:Calling: mdrun -s frame180.tpr -o frame180.trr -cpt 30 -nt 4
14:08:57:WU00:FS00:0xa7:Steps: first=900000000 total=5000000
14:08:58:WU00:FS00:0xa7:Completed 1 out of 5000000 steps (0%)
14:08:59:WU01:FS00:Upload 63.79%
14:09:02:WU01:FS00:Upload complete
14:09:02:WU01:FS00:Server responded WORK_ACK (400)
14:09:02:WU01:FS00:Final credit estimate, 900.00 points
14:09:02:WU01:FS00:Cleaning up
14:28:28:WU00:FS00:0xa7:Completed 50000 out of 5000000 steps (1%)
00:24:16:WU00:FS00:0xa7:Completed 4950000 out of 5000000 steps (99%)
00:24:17:WU01:FS00:Connecting to 65.254.110.245:8080
00:24:18:WU01:FS00:Assigned to work server 128.252.203.9
00:24:18:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
00:24:18:WU01:FS00:Connecting to 128.252.203.9:8080
00:24:18:WU01:FS00:Downloading 8.14MiB
00:24:22:WU01:FS00:Download complete
00:24:22:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13821 run:68 clone:2 gen:62 core:0xa7 unit:0x0000004880fccb095c8839faf9ae260c
00:52:45:WU00:FS00:0xa7:Completed 5000000 out of 5000000 steps (100%)
00:52:48:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
00:52:48:WU00:FS00:0xa7:Saving result file ener.edr
00:52:48:WU00:FS00:0xa7:Saving result file frame180.trr
00:52:49:WU00:FS00:0xa7:Saving result file md.log
00:52:49:WU00:FS00:0xa7:Saving result file science.log
00:52:49:WU00:FS00:0xa7:Saving result file traj_comp.xtc
00:52:49:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
00:52:50:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:52:50:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14153 run:5 clone:138 gen:180 core:0xa7 unit:0x000000cd0002894b5c546d2b6ea7f6d5
00:52:50:WU00:FS00:Uploading 3.11MiB to 155.247.166.219
00:52:50:WU01:FS00:Starting
00:52:50:WU00:FS00:Connecting to 155.247.166.219:8080
00:52:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
00:52:56:WU00:FS00:Upload complete
00:52:58:WU01:FS00:Started FahCore on PID 7284
00:53:02:WU01:FS00:Core PID:11388
00:53:02:WU01:FS00:FahCore 0xa7 started
00:53:03:WU00:FS00:Server responded WORK_ACK (400)
00:53:03:WU00:FS00:Final credit estimate, 4341.00 points
00:53:03:WU00:FS00:Cleaning up
00:53:04:WU01:FS00:0xa7:*********************** Log Started 2019-08-06T00:53:04Z ***********************
00:53:04:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:53:04:WU01:FS00:0xa7:       Type: 0xa7
00:53:04:WU01:FS00:0xa7:       Core: Gromacs
00:53:05:WU01:FS00:0xa7:    Website: https://foldingathome.org/
00:53:05:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:53:05:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:53:05:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 7284 -checkpoint 30 -np 4
00:53:05:WU01:FS00:0xa7:     Config: <none>
00:53:05:WU01:FS00:0xa7:************************************ Build *************************************
00:53:05:WU01:FS00:0xa7:    Version: 0.0.17
00:53:05:WU01:FS00:0xa7:       Date: Apr 25 2018
00:53:05:WU01:FS00:0xa7:       Time: 11:02:26
00:53:05:WU01:FS00:0xa7: Repository: Git
00:53:05:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
00:53:05:WU01:FS00:0xa7:     Branch: master
00:53:05:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:53:05:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:53:05:WU01:FS00:0xa7:   Platform: win32 10
00:53:05:WU01:FS00:0xa7:       Bits: 32
00:53:05:WU01:FS00:0xa7:       Mode: Release
00:53:05:WU01:FS00:0xa7:       SIMD: sse2
00:53:05:WU01:FS00:0xa7:************************************ System ************************************
00:53:05:WU01:FS00:0xa7:        CPU: Unknown
00:53:05:WU01:FS00:0xa7:     CPU ID:
00:53:05:WU01:FS00:0xa7:       CPUs: 4
00:53:05:WU01:FS00:0xa7:     Memory: 3.89GiB
00:53:05:WU01:FS00:0xa7:Free Memory: 712.83MiB
00:53:05:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:53:05:WU01:FS00:0xa7: OS Version: 6.2
00:53:05:WU01:FS00:0xa7:Has Battery: true
00:53:05:WU01:FS00:0xa7: On Battery: false
00:53:05:WU01:FS00:0xa7: UTC Offset: -4
00:53:05:WU01:FS00:0xa7:        PID: 11388
00:53:05:WU01:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
00:53:05:WU01:FS00:0xa7:         OS: Windows 10 Home
00:53:05:WU01:FS00:0xa7:    OS Arch: AMD64
00:53:05:WU01:FS00:0xa7:********************************************************************************
00:53:05:WU01:FS00:0xa7:Project: 13821 (Run 68, Clone 2, Gen 62)
00:53:05:WU01:FS00:0xa7:Unit: 0x0000004880fccb095c8839faf9ae260c
00:53:05:WU01:FS00:0xa7:Reading tar file core.xml
00:53:05:WU01:FS00:0xa7:Reading tar file frame62.tpr
00:53:06:WU01:FS00:0xa7:Digital signatures verified
00:53:06:WU01:FS00:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -x frame62.xtc -cpt 30 -nt 4
00:53:08:WU01:FS00:0xa7:Steps: first=7750000 total=125000
00:53:26:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
01:06:30:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
18:34:00:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
18:34:01:WU00:FS00:Connecting to 65.254.110.245:8080
18:34:02:WU00:FS00:Assigned to work server 128.252.203.9
18:34:02:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
18:34:02:WU00:FS00:Connecting to 128.252.203.9:8080
18:34:02:WU00:FS00:Downloading 8.14MiB
18:34:05:WU00:FS00:Download complete
18:34:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13821 run:757 clone:2 gen:62 core:0xa7 unit:0x0000004980fccb095c88384f547fa9d7
******************************* Date: 2019-08-06 *******************************
18:44:04:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
18:44:24:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
18:44:24:WU01:FS00:0xa7:Saving result file frame62.trr
18:44:24:WU01:FS00:0xa7:Saving result file frame62.xtc
18:44:25:WU01:FS00:0xa7:Saving result file md.log
18:44:25:WU01:FS00:0xa7:Saving result file science.log
18:44:25:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:44:26:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:44:26:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13821 run:68 clone:2 gen:62 core:0xa7 unit:0x0000004880fccb095c8839faf9ae260c
18:44:26:WU01:FS00:Uploading 11.27MiB to 128.252.203.9
18:44:26:WU00:FS00:Starting
18:44:26:WU01:FS00:Connecting to 128.252.203.9:8080
18:44:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
18:44:27:WU00:FS00:Started FahCore on PID 9376
18:44:29:WU00:FS00:Core PID:3576
18:44:29:WU00:FS00:FahCore 0xa7 started
18:44:30:WU00:FS00:0xa7:*********************** Log Started 2019-08-06T18:44:30Z ***********************
18:44:30:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:44:30:WU00:FS00:0xa7:       Type: 0xa7
18:44:30:WU00:FS00:0xa7:       Core: Gromacs
18:44:30:WU00:FS00:0xa7:    Website: https://foldingathome.org/
18:44:30:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
18:44:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:44:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 9376 -checkpoint 30 -np 4
18:44:30:WU00:FS00:0xa7:     Config: <none>
18:44:30:WU00:FS00:0xa7:************************************ Build *************************************
18:44:30:WU00:FS00:0xa7:    Version: 0.0.17
18:44:30:WU00:FS00:0xa7:       Date: Apr 25 2018
18:44:30:WU00:FS00:0xa7:       Time: 11:02:26
18:44:30:WU00:FS00:0xa7: Repository: Git
18:44:30:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
18:44:30:WU00:FS00:0xa7:     Branch: master
18:44:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:44:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:44:30:WU00:FS00:0xa7:   Platform: win32 10
18:44:30:WU00:FS00:0xa7:       Bits: 32
18:44:30:WU00:FS00:0xa7:       Mode: Release
18:44:30:WU00:FS00:0xa7:       SIMD: sse2
18:44:30:WU00:FS00:0xa7:************************************ System ************************************
18:44:30:WU00:FS00:0xa7:        CPU: Unknown
18:44:30:WU00:FS00:0xa7:     CPU ID:
18:44:30:WU00:FS00:0xa7:       CPUs: 4
18:44:30:WU00:FS00:0xa7:     Memory: 3.89GiB
18:44:30:WU00:FS00:0xa7:Free Memory: 1.60GiB
18:44:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:44:30:WU00:FS00:0xa7: OS Version: 6.2
18:44:30:WU00:FS00:0xa7:Has Battery: true
18:44:30:WU00:FS00:0xa7: On Battery: false
18:44:30:WU00:FS00:0xa7: UTC Offset: -4
18:44:30:WU00:FS00:0xa7:        PID: 3576
18:44:30:WU00:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
18:44:30:WU00:FS00:0xa7:         OS: Windows 10 Home
18:44:30:WU00:FS00:0xa7:    OS Arch: AMD64
18:44:30:WU00:FS00:0xa7:********************************************************************************
18:44:30:WU00:FS00:0xa7:Project: 13821 (Run 757, Clone 2, Gen 62)
18:44:30:WU00:FS00:0xa7:Unit: 0x0000004980fccb095c88384f547fa9d7
18:44:30:WU00:FS00:0xa7:Reading tar file core.xml
18:44:30:WU00:FS00:0xa7:Reading tar file frame62.tpr
18:44:30:WU00:FS00:0xa7:Digital signatures verified
18:44:30:WU00:FS00:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -x frame62.xtc -cpt 30 -nt 4
18:44:31:WU00:FS00:0xa7:Steps: first=7750000 total=125000
18:44:32:WU01:FS00:Upload 72.10%
18:44:35:WU01:FS00:Upload complete
18:44:35:WU01:FS00:Server responded WORK_ACK (400)
18:44:35:WU01:FS00:Final credit estimate, 900.00 points
18:44:35:WU01:FS00:Cleaning up
18:44:42:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
18:54:55:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
12:00:32:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
12:00:33:WU01:FS00:Connecting to 65.254.110.245:8080
12:00:34:WU01:FS00:Assigned to work server 128.252.203.9
12:00:34:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
12:00:34:WU01:FS00:Connecting to 128.252.203.9:8080
12:00:34:WU01:FS00:Downloading 8.14MiB
12:00:37:WU01:FS00:Download complete
12:00:38:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13826 run:281 clone:1 gen:61 core:0xa7 unit:0x0000004880fccb095c979b918a094946
12:10:21:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
12:10:41:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
12:10:41:WU00:FS00:0xa7:Saving result file frame62.trr
12:10:42:WU00:FS00:0xa7:Saving result file frame62.xtc
12:10:42:WU00:FS00:0xa7:Saving result file md.log
12:10:42:WU00:FS00:0xa7:Saving result file science.log
12:10:42:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:10:43:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:10:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13821 run:757 clone:2 gen:62 core:0xa7 unit:0x0000004980fccb095c88384f547fa9d7
12:10:43:WU00:FS00:Uploading 11.29MiB to 128.252.203.9
12:10:43:WU01:FS00:Starting
12:10:43:WU00:FS00:Connecting to 128.252.203.9:8080
12:10:43:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/JR/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 10000 -checkpoint 30 -np 4
12:10:44:WU01:FS00:Started FahCore on PID 12252
12:10:46:WU01:FS00:Core PID:9640
12:10:46:WU01:FS00:FahCore 0xa7 started
12:10:47:WU01:FS00:0xa7:*********************** Log Started 2019-08-07T12:10:47Z ***********************
12:10:47:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:10:47:WU01:FS00:0xa7:       Type: 0xa7
12:10:47:WU01:FS00:0xa7:       Core: Gromacs
12:10:47:WU01:FS00:0xa7:    Website: https://foldingathome.org/
12:10:47:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:10:47:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:10:47:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 12252 -checkpoint 30 -np
12:10:47:WU01:FS00:0xa7:             4
12:10:47:WU01:FS00:0xa7:     Config: <none>
12:10:47:WU01:FS00:0xa7:************************************ Build *************************************
12:10:47:WU01:FS00:0xa7:    Version: 0.0.17
12:10:47:WU01:FS00:0xa7:       Date: Apr 25 2018
12:10:47:WU01:FS00:0xa7:       Time: 11:02:26
12:10:47:WU01:FS00:0xa7: Repository: Git
12:10:47:WU01:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
12:10:47:WU01:FS00:0xa7:     Branch: master
12:10:47:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
12:10:47:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:10:47:WU01:FS00:0xa7:   Platform: win32 10
12:10:47:WU01:FS00:0xa7:       Bits: 32
12:10:47:WU01:FS00:0xa7:       Mode: Release
12:10:47:WU01:FS00:0xa7:       SIMD: sse2
12:10:47:WU01:FS00:0xa7:************************************ System ************************************
12:10:47:WU01:FS00:0xa7:        CPU: Unknown
12:10:47:WU01:FS00:0xa7:     CPU ID:
12:10:47:WU01:FS00:0xa7:       CPUs: 4
12:10:47:WU01:FS00:0xa7:     Memory: 3.89GiB
12:10:47:WU01:FS00:0xa7:Free Memory: 1.64GiB
12:10:47:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
12:10:47:WU01:FS00:0xa7: OS Version: 6.2
12:10:47:WU01:FS00:0xa7:Has Battery: true
12:10:47:WU01:FS00:0xa7: On Battery: false
12:10:47:WU01:FS00:0xa7: UTC Offset: -4
12:10:47:WU01:FS00:0xa7:        PID: 9640
12:10:47:WU01:FS00:0xa7:        CWD: C:\Users\JR\AppData\Roaming\FAHClient\work
12:10:47:WU01:FS00:0xa7:         OS: Windows 10 Home
12:10:47:WU01:FS00:0xa7:    OS Arch: AMD64
12:10:47:WU01:FS00:0xa7:********************************************************************************
12:10:47:WU01:FS00:0xa7:Project: 13826 (Run 281, Clone 1, Gen 61)
12:10:47:WU01:FS00:0xa7:Unit: 0x0000004880fccb095c979b918a094946
12:10:47:WU01:FS00:0xa7:Reading tar file core.xml
12:10:47:WU01:FS00:0xa7:Reading tar file frame61.tpr
12:10:47:WU01:FS00:0xa7:Digital signatures verified
12:10:47:WU01:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -x frame61.xtc -cpt 30 -nt 4
12:10:48:WU01:FS00:0xa7:Steps: first=7625000 total=125000
12:10:49:WU00:FS00:Upload 43.75%
12:10:55:WU00:FS00:Upload 70.33%
12:10:59:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
12:11:01:WU00:FS00:Upload 88.60%
12:11:05:WU00:FS00:Upload complete
12:11:06:WU00:FS00:Server responded WORK_ACK (400)
12:11:06:WU00:FS00:Final credit estimate, 900.00 points
12:11:06:WU00:FS00:Cleaning up
12:20:51:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
20:09:21:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
Reason: Added Code tags.
Re: Base credit
For project 138xx, it could be related to this issue : viewtopic.php?f=16&t=31757
Re: Base credit
I understand the first step to fixing this problem has been completed.
WUs from projects project 138xx which are assigned in the future will probably receive the correct bonus.
Retroactive corrections will take a while.
Dasha Koshechkina
Re: Base credit
Post by Dasha Koshechkina »
For my gtx-1080
Re: Base credit
See viewtopic.php?f=106&t=31758
When was PRCG 14180 (11,457,14)'s result uploaded?
Please post a segment of FAH's log showing when it was uploaded ... or a segment showing recent progress so we can extrapolate when it might be finished.
I contend that the points credited were (or will be) most likely awarded with the proper bonus.
Mstenholm
Hardware configuration: 4 x GTX 970. Win 7.
Re: Base credit
Post by Mstenholm »
One more:
00:58:36:WU00:FS00:0x21:Project: 14180 (Run 6, Clone 454, Gen 12)
00:58:36:WU00:FS00:0x21:Unit: 0x000000110002894c5d3b5536557aab20
00:58:36:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
00:58:36:WU00:FS00:0x21:Machine: 0
00:58:36:WU00:FS00:0x21:Reading tar file core.xml
00:58:36:WU00:FS00:0x21:Reading tar file integrator.xml
00:58:36:WU00:FS00:0x21:Reading tar file state.xml
00:58:36:WU00:FS00:0x21:Reading tar file system.xml
00:58:36:WU00:FS00:0x21:Digital signatures verified
00:58:36:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
00:58:36:WU00:FS00:0x21:Version 0.0.20
00:58:41:WU00:FS00:0x21:Completed 0 out of 12500000 steps (0%)
snip
05:11:15:WU00:FS00:0x21:Saving result file logfile_01.txt
05:11:15:WU00:FS00:0x21:Saving result file checkpointState.xml
05:11:16:WU00:FS00:0x21:Saving result file checkpt.crc
05:11:16:WU00:FS00:0x21:Saving result file log.txt
05:11:16:WU00:FS00:0x21:Saving result file positions.xtc
05:11:17:WU00:FS00:0x21:Folding@home Core Shutdown: FINISHED_UNIT
05:11:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:11:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14180 run:6 clone:454 gen:12 core:0x21 unit:0x000000110002894c5d3b5536557aab20
05:11:18:WU00:FS00:Uploading 8.98MiB to 155.247.166.220
snip
05:31:58:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:31:58:WU00:FS00:Trying to send results to collection server
05:31:58:WU00:FS00:Uploading 8.98MiB to 128.252.203.4
05:31:58:WU00:FS00:Connecting to 128.252.203.4:8080
05:32:02:WU00:FS00:Upload complete
05:32:02:WU00:FS00:Server responded WORK_ACK (400)
05:32:02:WU00:FS00:Final credit estimate, 29000.00 points
05:32:02:WU00:FS00:Cleaning up
and one more 14180 in progress on same machine also showing only base points. I will update on that when it completes.
I can see that I'm far from being the only one with problems. I took a look at inder372 and he just had two as well, Linux.
Dasha Koshechkina
Re: Base credit
bruce wrote:See viewtopic.php?f=106&t=31758
You're right.
01:21:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14180 run:11 clone:457 gen:14 core:0x21 unit:0x000000170002894c5d3b562a4c28e5f4
01:21:28:WU01:FS01:Uploading 9.04MiB to 155.247.166.220
01:21:28:WU01:FS01:Connecting to 155.247.166.220:8080
01:21:34:WU01:FS01:Upload complete
01:21:34:WU01:FS01:Server responded WORK_ACK (400)
01:21:34:WU01:FS01:Final credit estimate, 168247.00 points
Mstenholm
Re: Base credit
Post by Mstenholm »
One more 14180. It shares two similarities with the two others that I have reported - the first upload attempt went wrong and it is a 14180
06:16:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14180 run:2 clone:351 gen:24 core:0x21 unit:0x0000001e0002894c5d3b5479711c9eff
06:16:28:WU01:FS01:Uploading 9.10MiB to 155.247.166.220
06:16:28:WU01:FS01:Connecting to 155.247.166.220:8080
06:16:47:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
06:16:47:WU00:FS01:Connecting to 155.247.166.220:80
06:16:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:16:49:WU01:FS01:Connecting to 155.247.166.220:80
06:16:50:WU01:FS01:Upload 0.69%
06:17:27:WU01:FS01:Upload 1.37%
06:17:30:WU00:FS01:Downloading 2.47MiB
06:17:33:WU01:FS01:Upload 6.18%
06:17:35:WU00:FS01:Download complete
06:17:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14180 run:2 clone:60 gen:42 core:0x21 unit:0x0000003c0002894c5cbf49e722d20e61
06:17:35:WU00:FS01:Starting
06:17:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Michael/AppData/Roaming/FAHClient/cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 912 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:17:35:WU00:FS01:Started FahCore on PID 8904
06:17:35:WU00:FS01:Core PID:9824
06:17:35:WU00:FS01:FahCore 0x21 started
06:17:36:WU00:FS01:0x21:*********************** Log Started 2019-08-11T06:17:35Z ***********************
06:17:36:WU00:FS01:0x21:Project: 14180 (Run 2, Clone 60, Gen 42)
06:17:36:WU00:FS01:0x21:Unit: 0x0000003c0002894c5cbf49e722d20e61
06:17:36:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:17:36:WU00:FS01:0x21:Machine: 1
06:17:36:WU00:FS01:0x21:Reading tar file core.xml
06:17:36:WU00:FS01:0x21:Reading tar file integrator.xml
06:17:36:WU00:FS01:0x21:Reading tar file state.xml
06:17:36:WU00:FS01:0x21:Reading tar file system.xml
06:17:36:WU00:FS01:0x21:Digital signatures verified
06:17:36:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:17:36:WU00:FS01:0x21:Version 0.0.20
06:17:39:WU01:FS01:Upload 10.99%
06:17:40:WU00:FS01:0x21:Completed 0 out of 12500000 steps (0%)
06:17:40:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:17:45:WU01:FS01:Upload 16.49%
06:17:51:WU01:FS01:Upload 21.98%
06:17:57:WU01:FS01:Upload 27.48%
06:18:03:WU01:FS01:Upload 32.29%
06:18:09:WU01:FS01:Upload 37.78%
06:18:15:WU01:FS01:Upload 42.59%
06:18:21:WU01:FS01:Upload 47.40%
06:18:27:WU01:FS01:Upload 51.52%
06:18:33:WU01:FS01:Upload 55.64%
06:18:39:WU01:FS01:Upload 59.76%
06:18:58:WU01:FS01:Upload 62.51%
06:19:04:WU01:FS01:Upload 66.63%
06:19:10:WU01:FS01:Upload 71.44%
06:19:16:WU01:FS01:Upload 76.25%
06:19:22:WU01:FS01:Upload 81.75%
06:19:28:WU01:FS01:Upload 86.55%
06:19:34:WU01:FS01:Upload 92.05%
06:19:40:WU01:FS01:Upload 97.54%
06:19:45:WU01:FS01:Upload complete
06:19:45:WU01:FS01:Server responded WORK_ACK (400)
06:19:45:WU01:FS01:Final credit estimate, 198277.00 points
