CPU Viewer not working properly
DavF
Post by DavF »
Hi, I don't really know if this is the right subforum to create this topic in, sorry if it is not.
I'm running a CPU slot on a laptop and everything works properly, except the protein viewer. When I open it, even if I can see a protein being displayed, it doesen't display anything in the sections of the "Current Work Unit" window, and the same happens for the Donor window and the Slot section under the Status window. I tried to change the slot ID with the keys suggested by the help window but nothing seems to work.
Thanks in advance for your help.
Re: CPU Viewer not working properly
Yes, we know ... the Windows viewer is broken.
If you search on the forums, you'll find many threads discussing this issue.
edit : last thread about this issue : viewtopic.php?f=106&t=31534
DavF
Post by DavF »
Oh ok, thank you for the information. Hope it's going to get fixed soon!
DavF wrote:Hope it's going to get fixed soon!
Since it does not improve the science, I suspect it is not a high priority.
DavF
Post by DavF »
Well, that's true. But I suspect that a decent software with functioning features can increase the number of users involved in the project, which in turn can speed up the science.
DavF wrote:Well, that's true. But I suspect that a decent software with functioning features can increase the number of users involved in the project, which in turn can speed up the science.
But that is because you are showing more marketing skills than a Biochemist.
