AMD Ryzen Laptop Vega 8 "No WU's available for this Config"
Green
Post by Green »
Well the title says it all. When I first got the laptop start of spring, I didnt give the vega 8 the chance to get through even one work unit, at least it got them. It is the same speed as a 750gtx, i have that a r9 380 thats not hooked up and a rx 580 that is. Im hoping to get a sli/crossfire board and add one of the new amd cards that goes 10,000 gflops. I love this thing :twisted:
Very Respectfully
Ben D.C. Bruner
Green
"No WU's available for this Configuration"
Post by Green »
ive got units before, like start of spring when i got the 2500u with vega 8, same as a 750gtx. why waste it.
Very Respectfully
Ben D.C. Bruner
Re: AMD Ryzen Laptop Vega 8 "No WU's available for this Conf
I have not been able to determine if the iGPU in your system supports Double Precision or not. This is a requirement for all new projects ... and many old ones.
Please post the segments of your log (see below) showing the first couple of pages plus a segment showing the error, itself.
I also need the codes associated with that GPU ... which can be obtained by running GPU-Z or by running FAHClient --lspci
Green
Post by Green »
*********************** Log Started 2019-08-05T16:31:12Z ***********************
16:31:12:************************* Folding@home Client *************************
16:31:12:        Website: https://foldingathome.org/
16:31:12:      Copyright: (c) 2009-2018 foldingathome.org
16:31:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:31:12:           Args:
16:31:12:         Config: C:\Users\bendc\AppData\Roaming\FAHClient\config.xml
16:31:12:******************************** Build ********************************
16:31:12:        Version: 7.5.1
16:31:12:           Date: May 11 2018
16:31:12:           Time: 13:06:32
16:31:12:     Repository: Git
16:31:12:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:31:12:         Branch: master
16:31:12:       Compiler: Visual C++ 2008
16:31:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:31:12:       Platform: win32 10
16:31:12:           Bits: 32
16:31:12:           Mode: Release
16:31:12:******************************* System ********************************
16:31:12:            CPU: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
16:31:12:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
16:31:12:           CPUs: 8
16:31:12:         Memory: 7.55GiB
16:31:12:    Free Memory: 5.10GiB
16:31:12:        Threads: WINDOWS_THREADS
16:31:12:     OS Version: 6.2
16:31:12:    Has Battery: true
16:31:12:     On Battery: false
16:31:12:     UTC Offset: -4
16:31:12:            PID: 12424
16:31:12:            CWD: C:\Users\bendc\AppData\Roaming\FAHClient
16:31:12:             OS: Windows 10 Home
16:31:12:        OS Arch: AMD64
16:31:12:           GPUs: 1
16:31:12:          GPU 0: Bus:3 Slot:0 Func:0 AMD:4 [Ryzen vega 8 moble]
16:31:12:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
16:31:12:                 specified module could not be found.
16:31:12:
16:31:12:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:2906.10
16:31:12:  Win32 Service: false
16:31:12:***********************************************************************
16:31:12:<config>
16:31:12:  <!-- Folding Core -->
16:31:12:  <core-priority v='low'/>
16:31:12:
16:31:12:  <!-- Folding Slot Configuration -->
16:31:12:  <cause v='ALZHEIMERS'/>
16:31:12:
16:31:12:  <!-- Network -->
16:31:12:  <proxy v=':8080'/>
16:31:12:
16:31:12:  <!-- Slot Control -->
16:31:12:  <power v='full'/>
16:31:12:
16:31:12:  <!-- User Information -->
16:31:12:  <passkey v='********************************'/>
16:31:12:  <team v='45435'/>
16:31:12:  <user v='P.Henry'/>
16:31:12:
16:31:12:  <!-- Folding Slots -->
16:31:12:  <slot id='0' type='CPU'/>
16:31:12:  <slot id='1' type='GPU'/>
16:31:12:</config>
16:31:12:Trying to access database...
16:31:12:Successfully acquired database lock
16:31:12:Enabled folding slot 00: READY cpu:7
16:31:12:Enabled folding slot 01: READY gpu:0:[Ryzen vega 8 moble]
16:31:12:WU00:FS00:Starting
16:31:12:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
16:31:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bendc\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/x86/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12424 -checkpoint 15 -np 3
16:31:12:WU00:FS00:Started FahCore on PID 13780
16:31:12:WU00:FS00:Core PID:13848
16:31:12:WU00:FS00:FahCore 0xa7 started
16:31:13:WU00:FS00:0xa7:*********************** Log Started 2019-08-05T16:31:13Z ***********************
16:31:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:31:13:WU00:FS00:0xa7:       Type: 0xa7
16:31:13:WU00:FS00:0xa7:       Core: Gromacs
16:31:13:WU00:FS00:0xa7:    Website: https://foldingathome.org/
16:31:13:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
16:31:13:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:31:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 13780 -checkpoint 15 -np
16:31:13:WU00:FS00:0xa7:             3
16:31:13:WU00:FS00:0xa7:     Config: <none>
16:31:13:WU00:FS00:0xa7:************************************ Build *************************************
16:31:13:WU00:FS00:0xa7:    Version: 0.0.17
16:31:13:WU00:FS00:0xa7:       Date: Apr 25 2018
16:31:13:WU00:FS00:0xa7:       Time: 11:02:26
16:31:13:WU00:FS00:0xa7: Repository: Git
16:31:13:WU00:FS00:0xa7:   Revision: fd11abfb405c921e66db1226933e9dd2d18d2acc
16:31:13:WU00:FS00:0xa7:     Branch: master
16:31:13:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:31:13:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:31:13:WU00:FS00:0xa7:   Platform: win32 10
16:31:13:WU00:FS00:0xa7:       Bits: 32
16:31:13:WU00:FS00:0xa7:       Mode: Release
16:31:13:WU00:FS00:0xa7:       SIMD: sse2
16:31:13:WU00:FS00:0xa7:************************************ System ************************************
16:31:13:WU00:FS00:0xa7:        CPU: Unknown
16:31:13:WU00:FS00:0xa7:     CPU ID:
16:31:13:WU00:FS00:0xa7:       CPUs: 8
16:31:13:WU00:FS00:0xa7:     Memory: 7.55GiB
16:31:13:WU00:FS00:0xa7:Free Memory: 4.74GiB
16:31:13:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:31:13:WU00:FS00:0xa7: OS Version: 6.2
16:31:13:WU00:FS00:0xa7:Has Battery: true
16:31:13:WU00:FS00:0xa7: On Battery: false
16:31:13:WU00:FS00:0xa7: UTC Offset: -4
16:31:13:WU00:FS00:0xa7:        PID: 13848
16:31:13:WU00:FS00:0xa7:        CWD: C:\Users\bendc\AppData\Roaming\FAHClient\work
16:31:13:WU00:FS00:0xa7:         OS: Windows 10 Home
16:31:13:WU00:FS00:0xa7:    OS Arch: AMD64
16:31:13:WU00:FS00:0xa7:********************************************************************************
16:31:13:WU00:FS00:0xa7:Project: 13822 (Run 619, Clone 2, Gen 57)
16:31:13:WU00:FS00:0xa7:Unit: 0x0000003f80fccb095c895dc4fd5c95c4
16:31:13:WU00:FS00:0xa7:Digital signatures verified
16:31:13:WU00:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -x frame57.xtc -cpi state.cpt -cpt 15 -nt 3
16:31:16:WU00:FS00:0xa7:Steps: first=7125000 total=125000
16:31:19:WU01:FS01:Connecting to 65.254.110.245:8080
16:31:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:31:20:WU01:FS01:Connecting to 18.218.241.186:80
16:31:21:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:31:21:ERROR:WU01:FS01:Exception: Could not get an assignment
16:31:21:WU01:FS01:Connecting to 65.254.110.245:8080
16:31:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:31:22:WU01:FS01:Connecting to 18.218.241.186:80
16:31:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:31:22:ERROR:WU01:FS01:Exception: Could not get an assignment
16:31:27:WU00:FS00:0xa7:Completed 32711 out of 125000 steps (26%)
16:32:21:WU01:FS01:Connecting to 65.254.110.245:8080
16:32:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:32:21:WU01:FS01:Connecting to 18.218.241.186:80
16:32:21:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:32:21:ERROR:WU01:FS01:Exception: Could not get an assignment
16:33:58:WU01:FS01:Connecting to 65.254.110.245:8080
16:33:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:33:58:WU01:FS01:Connecting to 18.218.241.186:80
16:33:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:33:59:ERROR:WU01:FS01:Exception: Could not get an assignment
16:36:36:WU01:FS01:Connecting to 65.254.110.245:8080
16:36:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:36:36:WU01:FS01:Connecting to 18.218.241.186:80
16:36:36:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:36:36:ERROR:WU01:FS01:Exception: Could not get an assignment
16:39:40:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
16:40:50:WU01:FS01:Connecting to 65.254.110.245:8080
16:40:50:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:40:50:WU01:FS01:Connecting to 18.218.241.186:80
16:40:50:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:40:50:ERROR:WU01:FS01:Exception: Could not get an assignment
16:47:41:WU01:FS01:Connecting to 65.254.110.245:8080
16:47:42:WARNING:WU01:FS01:Failed to get assignment f
Mod edit: added Code tags to log file
Very Respectfully
Ben D.C. Bruner
Green
Post by Green »
https://imgur.com/a/IywotuB this is a screen capture of gpu z, i have opencl
Very Respectfully
Ben D.C. Bruner
The Vega 8 is listed as supporting GCN v5, and does Double Precision.
https://www.techpowerup.com/gpu-specs/r ... ga-8.c3042
AMD Vega 8 is already listed in GPUs.txt. Please post the first couple of pages of FAH's log so we can confirm which OpenCL driver is in use.
Beginning of log wa posted, driver listed is here:
bollix47
Post by bollix47 »
Try changing your cause to "ANY" and restarting the client (reboot) just to see if it makes a difference.
Does the problem occur occasionally or do you always get the "No WUs avail..." message?
Green
Post by Green »
I didn't do anything to it, left it on, and it started doing work I noticed last night or this morning. Ive had a really long day or I would have said something. Thanks guys
Very Respectfully
Ben D.C. Bruner
Green
Post by Green »
Its now only utilizing 199MHz instead of 1100MHz
Very Respectfully
Ben D.C. Bruner
What WU was assigned?
Green
Post by Green »
Project and apparently work unit are the same on the web view, Project '13823'
Very Respectfully
Ben D.C. Bruner
