Fermi Core 22 for RX Vega?
Locked
Mustung
Hardware configuration: Asus Z170p
Intel 6700k
AMD Rx Vega 56
8GB DDR4
Intel 760P 256G
Post by Mustung »
Hi,
I am running an RX Vega56 in Win10. Suddenly I notice that the gpu has been assigned with Nvidia core 22 these days. Is this normal? I believe there has been an AMD gpu core 22.
*********************** Log Started 2019-07-11T00:14:07Z ***********************
00:14:07:************************* Folding@home Client *************************
00:14:07:        Website: https://foldingathome.org/
00:14:07:      Copyright: (c) 2009-2018 foldingathome.org
00:14:07:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:14:07:           Args: --open-web-control
00:14:07:         Config: C:\Users\Dan\AppData\Roaming\FAHClient\config.xml
00:14:07:******************************** Build ********************************
00:14:07:        Version: 7.5.1
00:14:07:           Date: May 11 2018
00:14:07:           Time: 13:06:32
00:14:07:     Repository: Git
00:14:07:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:14:07:         Branch: master
00:14:07:       Compiler: Visual C++ 2008
00:14:07:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:14:07:       Platform: win32 10
00:14:07:           Bits: 32
00:14:07:           Mode: Release
00:14:07:******************************* System ********************************
00:14:07:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
00:14:07:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:14:07:           CPUs: 8
00:14:07:         Memory: 3.94GiB
00:14:07:    Free Memory: 762.28MiB
00:14:07:        Threads: WINDOWS_THREADS
00:14:07:     OS Version: 6.2
00:14:07:    Has Battery: false
00:14:07:     On Battery: false
00:14:07:     UTC Offset: 0
00:14:07:            PID: 20280
00:14:07:            CWD: C:\Users\Dan\AppData\Roaming\FAHClient
00:14:07:             OS: Windows 10 Enterprise
00:14:07:        OS Arch: AMD64
00:14:07:           GPUs: 1
00:14:07:          GPU 0: Bus:3 Slot:0 Func:0 AMD:5 [Radeon Rx vega]
00:14:07:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
00:14:07:                 specified module could not be found.
00:14:07:
00:14:07:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:2766.5
00:14:07:  Win32 Service: false
00:14:07:***********************************************************************
00:14:07:<config>
00:14:07:  <!-- Folding Slot Configuration -->
00:14:07:  <client-type v='beta'/>
00:14:07:
00:14:07:  <!-- Network -->
00:14:07:  <proxy v=':8080'/>
00:14:07:
00:14:07:  <!-- Slot Control -->
00:14:07:  <power v='full'/>
00:14:07:
00:14:07:  <!-- User Information -->
00:14:07:  <passkey v='********************************'/>
00:14:07:  <team v='3123'/>
00:14:07:  <user v='mustung'/>
00:14:07:
00:14:07:  <!-- Folding Slots -->
00:14:07:  <slot id='0' type='GPU'/>
00:14:07:</config>
00:14:07:Trying to access database...
00:14:07:Successfully acquired database lock
00:14:07:Enabled folding slot 00: READY gpu:0:[Radeon Rx vega]
00:14:07:WU00:FS00:Connecting to 65.254.110.245:8080
00:14:09:WU00:FS00:Assigned to work server 140.163.4.241
00:14:09:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:[Radeon Rx vega] from 140.163.4.241
00:14:09:WU00:FS00:Connecting to 140.163.4.241:8080
00:14:10:WU00:FS00:Downloading 11.66MiB
00:14:16:WU00:FS00:Download 23.58%
00:14:23:WU00:FS00:Download 51.44%
00:14:29:WU00:FS00:Download 75.02%
00:14:34:WU00:FS00:Download complete
00:14:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11733 run:0 clone:1333 gen:270 core:0x22 unit:0x0000012d8ca304f15c8acee25ea8f6cf
00:14:34:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_22.fah
00:14:34:WU00:FS00:Connecting to cores.foldingathome.org:80
00:14:34:WU00:FS00:FahCore 22: Downloading 3.97MiB
00:14:40:WU00:FS00:FahCore 22: 67.74%
00:14:41:WU00:FS00:FahCore 22: Download complete
00:14:41:WU00:FS00:Valid core signature
00:14:42:WU00:FS00:Unpacked 13.22MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_22.fah/FahCore_22.exe
00:14:42:WU00:FS00:Starting
00:14:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 20280 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:14:42:WU00:FS00:Started FahCore on PID 20140
00:14:42:WU00:FS00:Core PID:18936
00:14:42:WU00:FS00:FahCore 0x22 started
00:14:42:WU00:FS00:0x22:*********************** Log Started 2019-07-11T00:14:42Z ***********************
00:14:42:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
00:14:42:WU00:FS00:0x22:       Type: 0x22
00:14:42:WU00:FS00:0x22:       Core: Core22
00:14:42:WU00:FS00:0x22:    Website: https://foldingathome.org/
00:14:42:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:14:42:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:14:42:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
00:14:42:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 20140 -checkpoint 15
00:14:42:WU00:FS00:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:14:42:WU00:FS00:0x22:     Config: <none>
00:14:42:WU00:FS00:0x22:************************************ Build *************************************
00:14:42:WU00:FS00:0x22:    Version: 0.0.1
00:14:42:WU00:FS00:0x22:       Date: Feb 25 2019
00:14:42:WU00:FS00:0x22:       Time: 19:14:08
00:14:42:WU00:FS00:0x22: Repository: Git
00:14:42:WU00:FS00:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:14:42:WU00:FS00:0x22:     Branch: HEAD
00:14:42:WU00:FS00:0x22:   Compiler: Visual C++ 2008
00:14:42:WU00:FS00:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:14:42:WU00:FS00:0x22:   Platform: win32 10
00:14:42:WU00:FS00:0x22:       Bits: 64
00:14:42:WU00:FS00:0x22:       Mode: Release
00:14:42:WU00:FS00:0x22:************************************ System ************************************
00:14:42:WU00:FS00:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
00:14:42:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:14:42:WU00:FS00:0x22:       CPUs: 8
00:14:42:WU00:FS00:0x22:     Memory: 3.94GiB
00:14:42:WU00:FS00:0x22:Free Memory: 799.97MiB
00:14:42:WU00:FS00:0x22:    Threads: WINDOWS_THREADS
00:14:42:WU00:FS00:0x22: OS Version: 6.2
00:14:42:WU00:FS00:0x22:Has Battery: false
00:14:42:WU00:FS00:0x22: On Battery: false
00:14:42:WU00:FS00:0x22: UTC Offset: 0
00:14:42:WU00:FS00:0x22:        PID: 18936
00:14:42:WU00:FS00:0x22:        CWD: C:\Users\Dan\AppData\Roaming\FAHClient\work
00:14:42:WU00:FS00:0x22:         OS: Windows 10 Pro
00:14:42:WU00:FS00:0x22:    OS Arch: AMD64
00:14:42:WU00:FS00:0x22:********************************************************************************
00:14:42:WU00:FS00:0x22:Project: 11733 (Run 0, Clone 1333, Gen 270)
00:14:42:WU00:FS00:0x22:Unit: 0x0000012d8ca304f15c8acee25ea8f6cf
00:14:42:WU00:FS00:0x22:Reading tar file core.xml
00:14:42:WU00:FS00:0x22:Reading tar file integrator.xml
00:14:42:WU00:FS00:0x22:Reading tar file state.xml
00:14:42:WU00:FS00:0x22:Reading tar file system.xml
00:14:42:WU00:FS00:0x22:Digital signatures verified
00:14:42:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
00:14:42:WU00:FS00:0x22:Version 0.0.1
00:14:47:WU00:FS00:0x22:Completed 0 out of 5000000 steps (0%)
00:14:47:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
AMD 5800x Gigabyte 3090 LC
RTX2060(s) x 6
Re: Fermi Core 22 for RX Vega?
Core_22 is in beta test. It contains known bugs and is NOT ready for release, although some WUs are being completed successfully.
Please note: Subject: Ready For Hard Work? Join The Beta Team
Oh, and your original question isn't quite right. Cores 21 and 22 both work with the exact same GPUs. Having an RX Vega or something else that happens to be supported has no bearing on which FAHCores work or do not work.
The core 22 beta test thread is here, please continue core 22 talks there : viewtopic.php?f=66&t=31445
Locked
