Project 14158 issues
ipkh
Post by ipkh »
Any ideas on this error. Core 21 exception - unsupported version number. I got 3 units in a row that immediately failed as BAD_WU
03:15:00:WU02:FS02:Started FahCore on PID 20628
03:15:00:WU02:FS02:Core PID:18028
03:15:00:WU02:FS02:FahCore 0x21 started
03:15:00:WU02:FS02:0x21:*********************** Log Started 2019-07-10T03:15:00Z ***********************
03:15:00:WU02:FS02:0x21:Project: 14158 (Run 3, Clone 14, Gen 0)
03:15:00:WU02:FS02:0x21:Unit: 0x000000040002894c5d2551ed2d7f396d
03:15:00:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
03:15:00:WU02:FS02:0x21:Machine: 2
03:15:00:WU02:FS02:0x21:Reading tar file core.xml
03:15:00:WU02:FS02:0x21:Reading tar file integrator.xml
03:15:00:WU02:FS02:0x21:Reading tar file state.xml
03:15:00:WU02:FS02:0x21:Reading tar file system.xml
03:15:00:WU02:FS02:0x21:Digital signatures verified
03:15:00:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
03:15:00:WU02:FS02:0x21:Version 0.0.20
03:15:00:WU02:FS02:0x21:ERROR:exception: Unsupported version number
03:15:00:WU02:FS02:0x21:Saving result file logfile_01.txt
03:15:00:WU02:FS02:0x21:Saving result file log.txt
03:15:00:WU02:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:15:01:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:15:01:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:14158 run:3 clone:14 gen:0 core:0x21 unit:0x000000040002894c5d2551ed2d7f396d
03:15:01:WU02:FS02:Uploading 2.17KiB to 155.247.166.220
03:15:01:WU02:FS02:Connecting to 155.247.166.220:8080
03:15:01:WU02:FS02:Upload complete
03:15:01:WU02:FS02:Server responded WORK_ACK (400)
Re: Project 14158 issues
I need more information to answer that question.
Somewhere earlier in your log ... or maybe in a previous log (which is stored in the "logs" history file) there is probably information about a failed attempt to download a new copy of FAHCore_21. Find that segment of your history and post it.
I'm also checking with the project owner to see if something is set wrong in that particular project.
yunhui
Scientist
Post by yunhui »
Hi all,
This is my project and I’m sorry for this error. I used newer OpenMM version for new runs in this project and forgot it’s not supported yet on f@h. I just deleted the old files and replace the new ones with right version number. There shouldn’t be any version errors now.
Yunhui
ipkh
Post by ipkh »
Thanks, glad you got it figured out quickly.
I just received a p14158 and it's using FAHCore_21. While it's technically still available, most projects are now running FAHCore_22 instead of FAHCore_21, I suppose because it has a number of new features. There's really nothing wrong with running either one of them.
braiam
Post by braiam »
I got this project and is failing on my GPU, with rocm opencl drivers.
The rocm drivers are hit or miss from reports here on the forum. Some have got them to work, but it may depend on exact versions used. The AMD proprietary drivers and OpenCL support are still the recommended packages to use.
braiam
Post by braiam »
Joe_H wrote:The rocm drivers are hit or miss from reports here on the forum. Some have got them to work, but it may depend on exact versions used. The AMD proprietary drivers and OpenCL support are still the recommended packages to use.
In my case, I'm only using the OpenCL libraries. I've successfully folded other projects as seen in another post viewtopic.php?f=19&t=34970
HaloJones
Post by HaloJones »
I got one of these (3, 8249, 6) on a 1070 on Linux
No problems so far (98%) and right on the money for ppd compared to usual Core22 and IRCC faster than older Core21 units.
single 1070
