Geforce GTX 1060M with MAX-Q
tetragonal
Post by tetragonal »
Hey, I tried to run Folding@Home but my GPU tasks failed. After getting the info for my GPU and checking the whitelist, it appears there is a revision of the 1060M card that is not added to the list. Here is the info from fahclient:
0x8086:0xa36f:0:20:2:Intel Corporation:PCI standard RAM Controller
0x8086:0xa324:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - A324
0x8086:0xa32c:0:27:0:Intel Corporation:Intel(R) PCI Express Root Port #21 - A32C
0x1969:0xe0a1:59:0:0:Qualcomm Atheros:Killer E2400 Gigabit Ethernet Controller
0x8086:0x3ec4:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 3EC4
0x8086:0xa360:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x282a:0:23:0:Intel Corporation:Intel(R) Chipset SATA/PCIe RST Premium Controller
0x8086:0xa368:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A368
0x8086:0xa379:0:18:0:Intel Corporation:Intel(R) Thermal Subsystem - A379
0x8086:0xa30d:0:31:0:Intel Corporation:Intel(R) 300 Series Chipset Family LPC Controller (HM370) - A30D
0x8086:0xa370:0:20:3:Intel Corporation:Intel(R) Wireless-AC 9560 160MHz
0x8086:0xa348:0:31:3:Intel Corporation:Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
0x8086:0xa323:0:31:4:Intel Corporation:Intel(R) SMBus - A323
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) PCIe Controller (x16) - 1901
0x10de:0x1c20:1:0:0:NVIDIA Corporation:NVIDIA GeForce GTX 1060 with Max-Q Design
0x8086:0xa335:0:29:0:Intel Corporation:Intel(R) PCI Express Root Port #14 - A335
0x8086:0x3e9b:0:2:0:Intel Corporation:Intel(R) UHD Graphics 630
0x8086:0x1911:0:8:0:Intel Corporation:Intel(R) Gaussian Mixture Model - 1911
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Platform and Thermal Framework Processor Participant
0x8086:0xa36d:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0xa369:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A369
Here's the info from GPU-Z as well:
https://i.imgur.com/HxXuYpl.png
Thank you!
Re: Geforce GTX 1060M with MAX-Q
This GPU has been in the list of supported devices for ages ...
If you post the beginning of the log we may be able to see your configuration and offer advice. (perhaps even good advice)
From GPUs.txt, you'll see
0x10de:0x1c20:2:5:GP106M [GeForce GTX 1060 Mobile]
The text in [brackets] is a man-readable comment but the critical information is to the left of that, delineated by :colons:
