Fresh install of Ubuntu 18.04, FAHClient service not working
Fresh install of Ubuntu 18.04, fresh download (with wget) and install (dpkg -i) of 7.5.1 client.
Installation went fine and client started. I edited the config file to allow remote control (headless dedicated server) and rebooted the system to take change into account.
Now I'm unable to start the FAHClient service. Here's what I get :
systemctl status FAHClient.service
● FAHClient.service - LSB: Folding@home Client
Loaded: loaded (/etc/init.d/FAHClient; generated)
Active: failed (Result: exit-code) since Thu 2019-05-30 17:37:50 UTC; 4min 33s ago
Docs: man:systemd-sysv-generator(8)
Process: 2828 ExecStart=/etc/init.d/FAHClient start (code=exited, status=1/FAILURE)
mai 30 17:37:50 ns338286 systemd[1]: Starting LSB: Folding@home Client...
mai 30 17:37:50 ns338286 FAHClient[2828]: Starting fahclient ... FAIL
mai 30 17:37:50 ns338286 systemd[1]: FAHClient.service: Control process exited, code=exited status=1
mai 30 17:37:50 ns338286 systemd[1]: FAHClient.service: Failed with result 'exit-code'.
mai 30 17:37:50 ns338286 systemd[1]: Failed to start LSB: Folding@home Client.
Nothing is written to the FAHClient log.
This machine was working fine before, but FAHClient had been installed on Ubuntu 16.04 and then migrated to 18.04.
Any ideas ?
Re: Fresh install of Ubuntu 18.04, FAHClient service not wor
Is the userid 'fahclient" defined on that new install?
You are starting it with 'su' Right?
The only way I solved a different... but perhaps similar problem was to un-hide the output of init.d/FAHClient and see where it was failing.
bruce wrote:Is the userid 'fahclient" defined on that new install?
I don't know ... if it's not, there's a bug in the installer ...
bruce wrote:You are starting it with 'su' Right?
Sure, I only have root account on this system ... :roll:
bruce wrote:The only way I solved a different... but perhaps similar problem was to un-hide the output of init.d/FAHClient and see where it was failing.
If I try to start with the old /etc/init.d/FAHClient start method, I only get "Starting fahclient ... FAIL" :(
Is there a way to start the client manually, without the service commands ?
Edit a copy of /etc/init.d/FAHClient and proceed step by step assuming the parameter value "start" until something fails.
If you cannot 'su fahclient' then installation DID fail. Install it correctly.
su fahclient
This account is currently not available.
This is expected because the shell for this account is set to "/usr/sbin/nologin" ...
I tried to rerun the install process, but it doesn't change anything :
 dpkg -i --force-depends fahclient_7.5.1_amd64.deb
(Lecture de la base de données... 66795 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de fahclient_7.5.1_amd64.deb ...
usermod: no changes
Dépaquetage de fahclient (7.5.1) sur (7.5.1) ...
Paramétrage de fahclient (7.5.1) ...
Job for FAHClient.service failed because the control process exited with error code.
See "systemctl status FAHClient.service" and "journalctl -xe" for details.
invoke-rc.d: initscript FAHClient, action "start" failed.
   Active: failed (Result: exit-code) since Thu 2019-05-30 23:11:29 UTC; 7ms ago
  Process: 6056 ExecStart=/etc/init.d/FAHClient start (code=exited, status=1/FAILURE)
mai 30 23:11:29 ns338286 systemd[1]: Starting LSB: Folding@home Client...
mai 30 23:11:29 ns338286 FAHClient[6056]: Starting fahclient ... FAIL
mai 30 23:11:29 ns338286 systemd[1]: FAHClient.service: Control process exited, code=exited status=1
mai 30 23:11:29 ns338286 systemd[1]: FAHClient.service: Failed with result 'exit-code'.
mai 30 23:11:29 ns338286 systemd[1]: Failed to start LSB: Folding@home Client.
The Folding@home client is now installed
You can access the Web interface by going to:
  https://client.foldingathome.org/
in a browser on this computer.
For information about configuring the Folding@home client for
remote access please see the comments in:
  /etc/fahclient/config.xml
Traitement des actions différées (« triggers ») pour ureadahead (0.100.0-21) ...
Traitement des actions différées (« triggers ») pour systemd (237-3ubuntu10.21) ...
Traitement des actions différées (« triggers ») pour mime-support (3.60ubuntu1) ...
There's definitely something in /etc/init.d/FAHClient script that it doesn't like, but I don't know what yet ... :(
Try editing the script ... after every executable command, echo the returncode.
If that doesn't help, change /usr/bin/nologin and then type (Copy/Paste) each executable line into a terminal. There's got to be a way to debug it manually.
MeeLee
Post by MeeLee »
1- Dependencies installed?
2- Do you have access to a GUI for the installation procedure?
3- Are you folding on CPU?
I've never installed FAH via WGET.
I always download the .deb file from the main site, and install that one in GUI with a program.
I always fear of getting the commands wrong (force dependencies).
Also, are you running a minimal installation of Ubuntu? If so, some necessary dependencies might be missing.
MeeLee wrote:Also, are you running a minimal installation of Ubuntu? If so, some necessary dependencies might be missing.
I think you mean is the version designated as a "server" edition or a "desktop" edition. The server edition typically lacks many dependencies which are essential to starting the GUI desktop -- some of which are used by FAH. You don't really need to unitize that code since you don't need the GUI code to be running, but your second question is important: Do you have access to a GUI for the installation procedure?
Never mind, I found out what was wrong ! 8-)
A fucking missing / in config.xml file ... :evil:
Error messages could have been more explicit ... :(
edit : There is only one manual step in my process : editing the config.xml file to allow remote control. This is were I failed miserably ... :roll:
Katie Boundary
Post by Katie Boundary »
where does the missing / go? I'm getting the same problem.
fragmuffin
Post by fragmuffin »
The solution for me was in `/etc/init.d/FAHClient`. I needed to change the `wait_for_log_change` function to:
wait_for_log_change() {
    if [ "$2" != "" ]; then
        pid=$2
    else
        pid=$(get_pid)
    fi
    while ! is_running ; do
        sleep 0.1
    done
    while [ "$(log_status)" == "$1" ]; do
        if is_running ; then
            sleep 1
        else
            return 1
        fi
    done
    return 0
Before the change, the line
ps -hp $pid 2>/dev/null >/dev/null
was returning non-zero when called so soon after starting the FAHClient binary. A simple `sleep 1` before the original while loop also worked.
