AMD processor FX-8350
Forcinghavok
Post by Forcinghavok »
Hey just wondering if anybody else is having problems when running on the exact model of processor I'm using? I just installed a fresh windows 10 version, legit, and I am using AMD FX 8350 (8 core) processor at 4 ghz.
Are you using the same processor and running fine? Or do you have issues? Every time I try to run the CPU I get a windows error. When I run just the GPU everything is fine. I am also on "full" power.
Thanks,
Erik
Re: AMD processor FX 8350
Post the first few pages of your log and a segment showing the error.
It looks like the FX 8350 supports AVX 1.1 and not AVX 2 -- though I'm not sure if that matters.
Does your OS have support for AVX?
Or something is wrong with the hardware (cooling, PSU, ...) ...
Forcinghavok
toTOW wrote:Or something is wrong with the hardware (cooling, PSU, ...) ...
Well I am pretty sure there is nothing wrong with the hardware because I have ran all the cpu burn apps and gpu apps that test the limits of the hardware and none of those apps ever came back with anything at all!!!
Forcinghavok
bruce wrote:Post the first few pages of your log and a segment showing the error.
Bruce, I am not sure if Windows 10 supports that? How would I find out?
{no part of this post is definitive, every sentence could start "It is my understanding," }
the FX8350 belongs to a AMD micro architecture called Piledriver Piledriver features AVX1.1 but not AVX2. Somewhere I had the feeling that Core_a7 needed either AVX2, or SSE2. (although others do NOT recall it that way)
If I am right, and Core_a7 tries to use AVX2 instead of SSE2, it will fail. That would be a Cauldron Development bug. They could look for a Family 15h CPU and only use SSE2.
If, on the other hand, Windows 10 does NOT recognize Piledriver as an AVX CPU, it will not save the AVX registers when task switching. This would corrupt all AVX code on the FX8350. That would be a Windows bug. (Windows XP and early Windows 7 did not save the AVX registers on a task switch, that cause a great deal of beta testing to fail. Cauldron Development eventually added OS checks to make sure XP and 7 only used SSE2 code. While this would really be a Microsoft bug, Cauldron Development could hide it, again by selecting the SSE2 code whenever they saw a Family 15h CPU.
One way to test to see if other AVX code works well on your rig, is to run Prime95. https://www.tomshardware.com/reviews/st ... 461-2.html
https://en.wikipedia.org/wiki/Piledrive ... chitecture)
https://en.wikipedia.org/wiki/Advanced_ ... Extensions
https://docs.microsoft.com/en-us/sysint ... s/coreinfo
Post by foldy »
AVX2 is not used by FAH only AVX or SSE2.
If you say so ...
But without the logs requested by bruce previously, we can't help you ...
Forcinghavok
Hey JimboPalmer, I will check in to the links. In the mean time here is a non crash log with weird stuff happening. Is it possible to fix the connection issue? I am using no firewalls or anything. Just windows 10 and standard modem and router.
*********************** Log Started 2019-06-05T23:14:09Z ***********************
23:14:09:************************* Folding@home Client *************************
23:14:09:        Website: https://foldingathome.org/
23:14:09:      Copyright: (c) 2009-2018 foldingathome.org
23:14:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:14:09:           Args:
23:14:09:         Config: C:\Users\erikb\AppData\Roaming\FAHClient\config.xml
23:14:09:******************************** Build ********************************
23:14:09:        Version: 7.5.1
23:14:09:           Date: May 11 2018
23:14:09:           Time: 13:06:32
23:14:09:     Repository: Git
23:14:09:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:14:09:         Branch: master
23:14:09:       Compiler: Visual C++ 2008
23:14:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:14:09:       Platform: win32 10
23:14:09:           Bits: 32
23:14:09:           Mode: Release
23:14:09:******************************* System ********************************
23:14:09:            CPU: AMD FX(tm)-8350 Eight-Core Processor
23:14:09:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
23:14:09:           CPUs: 8
23:14:09:         Memory: 15.90GiB
23:14:09:    Free Memory: 13.90GiB
23:14:09:        Threads: WINDOWS_THREADS
23:14:09:     OS Version: 6.2
23:14:09:    Has Battery: false
23:14:09:     On Battery: false
23:14:09:     UTC Offset: -4
23:14:09:            PID: 236
23:14:09:            CWD: C:\Users\erikb\AppData\Roaming\FAHClient
23:14:09:             OS: Windows 10 Home
23:14:09:        OS Arch: AMD64
23:14:09:           GPUs: 1
23:14:09:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:14:09:                 470/480/570/580]
23:14:09:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:14:09:                 specified module could not be found.
23:14:09:
23:14:09:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2348.3
23:14:09:  Win32 Service: false
23:14:09:***********************************************************************
23:14:09:<config>
23:14:09:  <!-- Folding Core -->
23:14:09:  <checkpoint v='3'/>
23:14:09:
23:14:09:  <!-- Network -->
23:14:09:  <proxy v=':8080'/>
23:14:09:
23:14:09:  <!-- Slot Control -->
23:14:09:  <pause-on-battery v='false'/>
23:14:09:  <power v='full'/>
23:14:09:
23:14:09:  <!-- User Information -->
23:14:09:  <team v='2092'/>
23:14:09:  <user v='forcinghavok'/>
23:14:09:
23:14:09:  <!-- Folding Slots -->
23:14:09:  <slot id='0' type='CPU'>
23:14:09:    <cpus v='4'/>
23:14:09:    <paused v='true'/>
23:14:09:  </slot>
23:14:09:  <slot id='1' type='GPU'>
23:14:09:  </slot>
23:14:09:</config>
23:14:09:Trying to access database...
23:14:09:Successfully acquired database lock
23:14:09:Enabled folding slot 00: PAUSED cpu:4 (by user)
23:14:09:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (by user)
23:14:35:FS00:Unpaused
23:14:35:FS01:Unpaused
23:14:35:WU01:FS01:Starting
23:14:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 236 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
23:14:36:WU01:FS01:Started FahCore on PID 7032
23:14:36:WU01:FS01:Core PID:8312
23:14:36:WU01:FS01:FahCore 0x21 started
23:14:37:WU00:FS00:Starting
23:14:37:WARNING:WU00:FS00:AS lowered CPUs from 4 to 2
23:14:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 236 -checkpoint 3 -np 2
23:14:37:WU00:FS00:Started FahCore on PID 9112
23:14:37:WU01:FS01:0x21:*********************** Log Started 2019-06-05T23:14:37Z ***********************
23:14:37:WU01:FS01:0x21:Project: 14166 (Run 5, Clone 9, Gen 167)
23:14:37:WU01:FS01:0x21:Unit: 0x000000d90002894c5c38c00cc7a55450
23:14:37:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:14:37:WU01:FS01:0x21:Machine: 1
23:14:37:WU01:FS01:0x21:Digital signatures verified
23:14:37:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:14:37:WU01:FS01:0x21:Version 0.0.18
23:14:37:WU01:FS01:0x21:  Found a checkpoint file
23:14:38:WU00:FS00:Core PID:1648
23:14:38:WU00:FS00:FahCore 0xa7 started
23:14:39:WU00:FS00:0xa7:*********************** Log Started 2019-06-05T23:14:38Z ***********************
23:14:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:14:39:WU00:FS00:0xa7:       Type: 0xa7
23:14:39:WU00:FS00:0xa7:       Core: Gromacs
23:14:39:WU00:FS00:0xa7:    Website: https://foldingathome.org/
23:14:39:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
23:14:39:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:14:39:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9112 -checkpoint 3 -np 2
23:14:39:WU00:FS00:0xa7:     Config: <none>
23:14:39:WU00:FS00:0xa7:************************************ Build *************************************
23:14:39:WU00:FS00:0xa7:    Version: 0.0.17
23:14:39:WU00:FS00:0xa7:       Date: Apr 27 2018
23:14:39:WU00:FS00:0xa7:       Time: 16:19:36
23:14:39:WU00:FS00:0xa7: Repository: Git
23:14:39:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
23:14:39:WU00:FS00:0xa7:     Branch: master
23:14:39:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:14:39:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:14:39:WU00:FS00:0xa7:   Platform: win32 10
23:14:39:WU00:FS00:0xa7:       Bits: 64
23:14:39:WU00:FS00:0xa7:       Mode: Release
23:14:39:WU00:FS00:0xa7:       SIMD: avx_256
23:14:39:WU00:FS00:0xa7:************************************ System ************************************
23:14:39:WU00:FS00:0xa7:        CPU: Unknown
23:14:39:WU00:FS00:0xa7:     CPU ID:
23:14:39:WU00:FS00:0xa7:       CPUs: 8
23:14:39:WU00:FS00:0xa7:     Memory: 15.90GiB
23:14:39:WU00:FS00:0xa7:Free Memory: 13.72GiB
23:14:39:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:14:39:WU00:FS00:0xa7: OS Version: 6.2
23:14:39:WU00:FS00:0xa7:Has Battery: false
23:14:39:WU00:FS00:0xa7: On Battery: false
23:14:39:WU00:FS00:0xa7: UTC Offset: -4
23:14:39:WU00:FS00:0xa7:        PID: 1648
23:14:39:WU00:FS00:0xa7:        CWD: C:\Users\erikb\AppData\Roaming\FAHClient\work
23:14:39:WU00:FS00:0xa7:         OS: Windows 10 Home
23:14:39:WU00:FS00:0xa7:    OS Arch: AMD64
23:14:39:WU00:FS00:0xa7:********************************************************************************
23:14:39:WU00:FS00:0xa7:Project: 13822 (Run 525, Clone 2, Gen 27)
23:14:39:WU00:FS00:0xa7:Unit: 0x0000001f80fccb095c895dff26dbd5ce
23:14:39:WU00:FS00:0xa7:Digital signatures verified
23:14:39:WU00:FS00:0xa7:Calling: mdrun -s frame27.tpr -o frame27.trr -x frame27.xtc -cpi state.cpt -cpt 3 -nt 2
23:14:42:WU00:FS00:0xa7:Steps: first=3375000 total=125000
23:14:46:WU00:FS00:0xa7:Completed 28282 out of 125000 steps (22%)
23:14:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:14:49:WU01:FS01:0x21:Completed 10500000 out of 12500000 steps (84%)
23:14:49:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:15:10:Removing old file 'configs/config-20190525-043726.xml'
23:15:10:Saving configuration to config.xml
23:15:10:<config>
23:15:10:  <!-- Folding Core -->
23:15:10:  <checkpoint v='3'/>
23:15:10:
23:15:10:  <!-- Network -->
23:15:10:  <proxy v=':8080'/>
23:15:10:
23:15:10:  <!-- Slot Control -->
23:15:10:  <pause-on-battery v='false'/>
23:15:10:  <power v='full'/>
23:15:10:
23:15:10:  <!-- User Information -->
23:15:10:  <team v='2092'/>
23:15:10:  <user v='forcinghavok'/>
23:15:10:
23:15:10:  <!-- Folding Slots -->
23:15:10:  <slot id='0' type='CPU'>
23:15:10:    <cpus v='4'/>
23:15:10:  </slot>
23:15:10:  <slot id='1' type='GPU'/>
23:15:10:</config>
23:18:00:WU01:FS01:0x21:Completed 10625000 out of 12500000 steps (85%)
23:18:51:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
23:21:11:WU01:FS01:0x21:Completed 10750000 out of 12500000 steps (86%)
23:24:22:WU01:FS01:0x21:Completed 10875000 out of 12500000 steps (87%)
23:26:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:27:33:WU01:FS01:0x21:Completed 11000000 out of 12500000 steps (88%)
23:29:45:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
23:30:44:WU01:FS01:0x21:Completed 11125000 out of 12500000 steps (89%)
23:33:55:WU01:FS01:0x21:Completed 11250000 out of 12500000 steps (90%)
23:37:12:WU01:FS01:0x21:Completed 11375000 out of 12500000 steps (91%)
23:40:23:WU01:FS01:0x21:Completed 11500000 out of 12500000 steps (92%)
23:40:40:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
23:43:34:WU01:FS01:0x21:Completed 11625000 out of 12500000 steps (93%)
23:46:44:WU01:FS01:0x21:Completed 11750000 out of 12500000 steps (94%)
23:49:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:49:56:WU01:FS01:0x21:Completed 11875000 out of 12500000 steps (95%)
23:50:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:50:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:50:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:50:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:51:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:51:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:51:32:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
23:51:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:51:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:52:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:52:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:52:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:52:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:53:07:WU01:FS01:0x21:Completed 12000000 out of 12500000 steps (96%)
23:53:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:53:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:53:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:54:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:54:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:54:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:54:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:56:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:56:18:WU01:FS01:0x21:Completed 12125000 out of 12500000 steps (97%)
23:56:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:56:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:56:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:57:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:57:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:57:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:58:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:58:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:58:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:58:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:59:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:59:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:59:29:WU01:FS01:0x21:Completed 12250000 out of 12500000 steps (98%)
23:59:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:59:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:00:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:00:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:00:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:00:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:01:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:01:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:01:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:02:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:02:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:02:22:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
00:02:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:02:40:WU01:FS01:0x21:Completed 12375000 out of 12500000 steps (99%)
00:02:41:WU02:FS01:Connecting to 65.254.110.245:8080
00:02:41:WU02:FS01:Assigned to work server 140.163.4.231
00:02:41:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
00:02:41:WU02:FS01:Connecting to 140.163.4.231:8080
00:02:42:WU02:FS01:Downloading 14.57MiB
00:02:45:WU02:FS01:Download complete
00:02:45:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11728 run:0 clone:2864 gen:124 core:0x21 unit:0x000000ba8ca304e75bbcebd5293a8fe9
00:02:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:04:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:04:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:04:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:04:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:51:WU01:FS01:0x21:Completed 12500000 out of 12500000 steps (100%)
00:05:52:WU01:FS01:0x21:Saving result file logfile_01.txt
00:05:52:WU01:FS01:0x21:Saving result file checkpointState.xml
00:05:52:WU01:FS01:0x21:Saving result file checkpt.crc
00:05:52:WU01:FS01:0x21:Saving result file log.txt
00:05:52:WU01:FS01:0x21:Saving result file positions.xtc
00:05:52:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:05:53:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:05:53:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14166 run:5 clone:9 gen:167 core:0x21 unit:0x000000d90002894c5c38c00cc7a55450
00:05:53:WU01:FS01:Uploading 3.20MiB to 155.247.166.220
00:05:53:WU02:FS01:Starting
00:05:53:WU01:FS01:Connecting to 155.247.166.220:8080
00:05:53:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\erikb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 236 -checkpoint 3 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:05:53:WU02:FS01:Started FahCore on PID 6724
00:05:53:WU02:FS01:Core PID:2812
00:05:53:WU02:FS01:FahCore 0x21 started
00:05:54:WU02:FS01:0x21:*********************** Log Started 2019-06-06T00:05:53Z ***********************
00:05:54:WU02:FS01:0x21:Project: 11728 (Run 0, Clone 2864, Gen 124)
00:05:54:WU02:FS01:0x21:Unit: 0x000000ba8ca304e75bbcebd5293a8fe9
00:05:54:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:05:54:WU02:FS01:0x21:Machine: 1
00:05:54:WU02:FS01:0x21:Reading tar file core.xml
00:05:54:WU02:FS01:0x21:Reading tar file integrator.xml
00:05:54:WU02:FS01:0x21:Reading tar file state.xml
00:05:54:WU02:FS01:0x21:Reading tar file system.xml
00:05:54:WU02:FS01:0x21:Digital signatures verified
00:05:54:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:05:54:WU02:FS01:0x21:Version 0.0.18
00:05:59:WU01:FS01:Upload 91.90%
00:06:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:06:00:WU01:FS01:Upload complete
00:06:00:WU01:FS01:Server responded WORK_ACK (400)
00:06:00:WU01:FS01:Final credit estimate, 14825.00 points
00:06:00:WU01:FS01:Cleaning up
00:06:02:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:06:02:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:06:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:06:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:06:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:07:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:07:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:07:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:07:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:24:WU02:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
00:08:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:09:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:09:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:09:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:10:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:10:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:10:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:10:47:WU02:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
00:10:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:11:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:11:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:11:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:11:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:12:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:12:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:12:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:12:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:13:11:WU02:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
00:13:11:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
00:13:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:13:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:13:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:14:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:14:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:14:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:14:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:15:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:15:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:15:33:WU02:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
00:15:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:15:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:17:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:17:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:17:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:17:56:WU02:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
00:18:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:18:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:18:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:18:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:19:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:19:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:19:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:19:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:20:WU02:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
00:20:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:21:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:21:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:21:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:22:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:22:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:22:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:22:42:WU02:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
00:22:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:56:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
00:24:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:24:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:24:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:24:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:25:04:WU02:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
00:25:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:25:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:25:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:27:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:27:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:27:26:WU02:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
00:27:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:27:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:29:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:29:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:29:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:29:49:WU02:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
00:30:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:30:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:30:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:30:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:32:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:32:12:WU02:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
00:32:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:32:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:32:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:33:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:33:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:33:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:34:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:34:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:34:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:34:34:WU02:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
00:34:42:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
00:34:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Once I get a crash log I will upload it. Thanks.
If my theories that there were issuses with FX 8350, Core_a7, and AVX were true, this would have failed almost immediately.
So I am wrong.
First it says
and then is says
: CPU: Unknown,
Are you running in a Virtual Machine? When FAH cannot detect the CPU type, that's a possible sign that something is missing. Does this work if you're running a native copy of your OS: Windows 10 Home?
The message about CUDA not being detected does not indicate there's a problem. AMD hardware doesn't use CUDA ... just OpenCL.
I often do get the message ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine when I close WebControl. I guess webcontrol is exchanging messages with FAHClient and communications isn't quiesced cleanly. Maybe your message is like mine or maybe there's another reason. Leave WebControl running and see if the message is delayed. Also, check what happens if you disable your security software (perhaps with the internet connection unplugged).
https://github.com/FoldingAtHome/fah-issues/issues/1054
Forcinghavok
Hey Bruce, I am using a legit copy of windows 10 home fresh install.
As for the webcontrol and fah client, I don't use the webcontrol! Are you saying to use the webcontrol? I do have the windows security enabled, are you suggesting that I disable it for a bit to test it? Specifically the firewall?
Forcinghavok wrote:Hey just wondering if anybody else is having problems when running on the exact model of processor I'm using? I just installed a fresh windows 10 version, legit, and I am using AMD FX 8350 (8 core) processor at 4 ghz.
I'm confused. Did you start another discussion somewhere else or have you forgotten to tell us what "problems" you're having.
If your problem is that your machine shuts itself down when folding on both the GPU and the CPU, I'm going to GUESS that you're running on a laptop and its cooling subsystem can't handle the heat being generated. If that's not your problem. please explain what it is.
There's noting wrong in the log you posted ...
I think those messages are caused by the viewer not being able to communicate with the client : ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
