Another Noobie here
IronBredin
Another Noobie here
Post by IronBredin »
Windows 7 Professional, can't get GPU to work.
0x10de:0x0e08:1:0:1:NVIDIA Corporation:High Definition Audio Controller
0x10de:0x1056:1:0:0:NVIDIA Corporation:NVIDIA NVS 4200M
0x1217:0x13f7:11:0:0:O2 Micro, Inc.:1394 OHCI Compliant Host Controller
0x1217:0x8321:11:0:1:O2 Micro, Inc.:O2Micro Integrated MMC/SD controller
0x1217:0x8331:11:0:2:O2 Micro, Inc.:O2Micro Integrated MS/MSPRO controller
0x8086:0x0082:3:0:0:Intel Corporation:Intel(R) Centrino(R) Advanced-N 6205
0x8086:0x0101:0:1:0:Intel Corporation:2nd generation Intel(R) Core(TM) processor family PCI Express Controller - 0101
0x8086:0x0104:0:0:0:Intel Corporation:2nd generation Intel(R) Core(TM) processor family DRAM Controller - 0104
0x8086:0x1502:0:25:0:Intel Corporation:Intel(R) 82579LM Gigabit Network Connection
0x8086:0x1c10:0:28:0:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 1 - 1C10
0x8086:0x1c12:0:28:1:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 2 - 1C12
0x8086:0x1c14:0:28:2:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 3 - 1C14
0x8086:0x1c16:0:28:3:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 4 - 1C16
0x8086:0x1c1a:0:28:5:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family PCI Express Root Port 6 - 1C1A
0x8086:0x1c20:0:27:0:Intel Corporation:High Definition Audio Controller
0x8086:0x1c22:0:31:3:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
0x8086:0x1c26:0:29:0:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
0x8086:0x1c2d:0:26:0:Intel Corporation:Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
0x8086:0x1c3a:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x1c4f:0:31:0:Intel Corporation:Intel(R) QM67 Express Chipset Family LPCInterface Controller - 1C4F
0x8086:0x282a:0:31:2:Intel Corporation:Intel(R) Mobile Express Chipset SATA RAID Controller
Re: Another Noobie here
Your NVS 4200M is based on a GT 520M. While it uses a Fermi GPU, it is at the very minimum level to potentially process WU's. However the current GPU projects have moved on to requiring mixed precision calculations, and I do not see any support for double precision listed for an NVS 4200M. So that may be the reason you are not getting any work.
You may also have an Optimus driver, which uses a frugal Intel GPU normally and only uses the more power hungry Nvidia when needed. This work poorly with F@H as at startup it sees the Intel.
You may find a setting to always use the Nvidia, which may still not be powerful enough to complete a Work Unit.
It only appears to support OpenCL 1.1, and lacks double Precision Math, either of which could prevent even starting.
IronBredin
Is this a folding-at-home setting?
No it is in the Optimus control panel. You may or may not have one.
Helio_Centra
Post by Helio_Centra »
In the nVidia Control Panel you can either set it to favor optimus on specific apps (like on the FAH client) or just always.
