No points credited when GPU completes WU
felixbunny
Post by felixbunny »
Hi, I have complete a number of WU using my GPU but I do not see any points credited. All points are from my CPU.
Can anyone help me? Thanks!
In the logs below, I completed a job using my GPU but I do not see any points being credited.
*********************** Log Started 2019-05-15T00:35:36Z ***********************
00:35:36:************************* Folding@home Client *************************
00:35:36:        Website: https://foldingathome.org/
00:35:36:      Copyright: (c) 2009-2018 foldingathome.org
00:35:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:35:36:           Args:
00:35:36:         Config: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\config.xml
00:35:36:******************************** Build ********************************
00:35:36:        Version: 7.5.1
00:35:36:           Date: May 11 2018
00:35:36:           Time: 13:06:32
00:35:36:     Repository: Git
00:35:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:35:36:         Branch: master
00:35:36:       Compiler: Visual C++ 2008
00:35:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:35:36:       Platform: win32 10
00:35:36:           Bits: 32
00:35:36:           Mode: Release
00:35:36:******************************* System ********************************
00:35:36:            CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:35:36:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:35:36:           CPUs: 8
00:35:36:         Memory: 31.94GiB
00:35:36:    Free Memory: 23.28GiB
00:35:36:        Threads: WINDOWS_THREADS
00:35:36:     OS Version: 6.2
00:35:36:    Has Battery: false
00:35:36:     On Battery: false
00:35:36:     UTC Offset: 8
00:35:36:            PID: 44656
00:35:36:            CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient
00:35:36:             OS: Windows 10 Enterprise
00:35:36:        OS Arch: AMD64
00:35:36:           GPUs: 1
00:35:36:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
00:35:36:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.1
00:35:36:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:388.13
00:35:36:  Win32 Service: false
00:35:36:***********************************************************************
00:35:36:<config>
00:35:36:  <!-- Folding Slot Configuration -->
00:35:36:  <cause v='CANCER'/>
00:35:36:
00:35:36:  <!-- Slot Control -->
00:35:36:  <power v='MEDIUM'/>
00:35:36:
00:35:36:  <!-- User Information -->
00:35:36:  <passkey v='********************************'/>
00:35:36:  <team v='234980'/>
00:35:36:  <user v='dy047awasyss'/>
00:35:36:
00:35:36:  <!-- Folding Slots -->
00:35:36:  <slot id='0' type='CPU'/>
00:35:36:  <slot id='1' type='GPU'/>
00:35:36:</config>
00:35:36:Trying to access database...
00:35:36:Successfully acquired database lock
00:35:36:Enabled folding slot 00: READY cpu:6
00:35:36:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308
00:35:36:WU00:FS01:Starting
00:35:36:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 44656 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:35:36:WU00:FS01:Started FahCore on PID 44920
00:35:36:WU00:FS01:Core PID:44932
00:35:36:WU00:FS01:FahCore 0x21 started
00:35:37:WU01:FS00:Starting
00:35:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 44656 -checkpoint 15 -np 6
00:35:37:WU01:FS00:Started FahCore on PID 44940
00:35:37:WU01:FS00:Core PID:44956
00:35:37:WU01:FS00:FahCore 0xa7 started
00:35:37:WARNING:FS01:Size of positions 5845 does not match topology 5844
00:35:37:WU01:FS00:0xa7:*********************** Log Started 2019-05-15T00:35:37Z ***********************
00:35:37:WU00:FS01:0x21:*********************** Log Started 2019-05-15T00:35:37Z ***********************
00:35:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:35:37:WU00:FS01:0x21:Project: 11718 (Run 0, Clone 791, Gen 344)
00:35:37:WU01:FS00:0xa7:       Type: 0xa7
00:35:37:WU00:FS01:0x21:Unit: 0x000001d18ca304e75b846ad6e023c163
00:35:37:WU01:FS00:0xa7:       Core: Gromacs
00:35:37:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:35:37:WU01:FS00:0xa7:    Website: https://foldingathome.org/
00:35:37:WU00:FS01:0x21:Machine: 1
00:35:37:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:35:37:WU00:FS01:0x21:Digital signatures verified
00:35:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:35:37:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:35:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 44940 -checkpoint 15 -np
00:35:37:WU00:FS01:0x21:Version 0.0.18
00:35:37:WU01:FS00:0xa7:             6
00:35:37:WU00:FS01:0x21:  Found a checkpoint file
00:35:37:WU01:FS00:0xa7:     Config: <none>
00:35:37:WU01:FS00:0xa7:************************************ Build *************************************
00:35:37:WU01:FS00:0xa7:    Version: 0.0.17
00:35:37:WU01:FS00:0xa7:       Date: Apr 27 2018
00:35:37:WU01:FS00:0xa7:       Time: 16:19:36
00:35:37:WU01:FS00:0xa7: Repository: Git
00:35:37:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:35:37:WU01:FS00:0xa7:     Branch: master
00:35:37:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:35:37:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:35:37:WU01:FS00:0xa7:   Platform: win32 10
00:35:37:WU01:FS00:0xa7:       Bits: 64
00:35:37:WU01:FS00:0xa7:       Mode: Release
00:35:37:WU01:FS00:0xa7:       SIMD: avx_256
00:35:37:WU01:FS00:0xa7:************************************ System ************************************
00:35:37:WU01:FS00:0xa7:        CPU: Unknown
00:35:37:WU01:FS00:0xa7:     CPU ID:
00:35:37:WU01:FS00:0xa7:       CPUs: 8
00:35:37:WU01:FS00:0xa7:     Memory: 31.94GiB
00:35:37:WU01:FS00:0xa7:Free Memory: 23.07GiB
00:35:37:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:35:37:WU01:FS00:0xa7: OS Version: 6.2
00:35:37:WU01:FS00:0xa7:Has Battery: false
00:35:37:WU01:FS00:0xa7: On Battery: false
00:35:37:WU01:FS00:0xa7: UTC Offset: 8
00:35:37:WU01:FS00:0xa7:        PID: 44956
00:35:37:WU01:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
00:35:37:WU01:FS00:0xa7:         OS: Windows 10 Pro
00:35:37:WU01:FS00:0xa7:    OS Arch: AMD64
00:35:37:WU01:FS00:0xa7:********************************************************************************
00:35:37:WU01:FS00:0xa7:Project: 14153 (Run 1, Clone 68, Gen 61)
00:35:37:WU01:FS00:0xa7:Unit: 0x000000430002894b5c546d1607da4b2b
00:35:37:WU01:FS00:0xa7:Digital signatures verified
00:35:37:WU01:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 6
00:35:37:WU01:FS00:0xa7:Steps: first=305000000 total=5000000
00:35:38:WARNING:FS01:Size of positions 5845 does not match topology 5844
00:35:38:WU01:FS00:0xa7:Completed 274161 out of 5000000 steps (5%)
00:35:51:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
00:35:52:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:41:27:WU01:FS00:0xa7:Completed 300000 out of 5000000 steps (6%)
00:42:12:WU00:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
00:42:41:6:127.0.0.1:New Web connection
00:42:42:20:127.0.0.1:New Web connection
00:48:15:WU01:FS00:0xa7:Completed 350000 out of 5000000 steps (7%)
00:48:21:WU00:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
00:53:32:WU01:FS00:0xa7:Completed 400000 out of 5000000 steps (8%)
00:54:28:WU00:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
00:58:36:WU01:FS00:0xa7:Completed 450000 out of 5000000 steps (9%)
01:00:35:WU00:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
01:03:51:WU01:FS00:0xa7:Completed 500000 out of 5000000 steps (10%)
01:06:40:WU00:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
01:06:48:WARNING:FS01:Size of positions 5845 does not match topology 5844
01:09:12:WU01:FS00:0xa7:Completed 550000 out of 5000000 steps (11%)
01:12:54:WU00:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
01:14:27:WU01:FS00:0xa7:Completed 600000 out of 5000000 steps (12%)
01:19:01:WU00:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
01:20:21:WU01:FS00:0xa7:Completed 650000 out of 5000000 steps (13%)
01:22:24:46:127.0.0.1:New Web connection
01:25:09:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
01:26:57:WU01:FS00:0xa7:Completed 700000 out of 5000000 steps (14%)
01:31:17:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
01:31:18:WU02:FS01:Connecting to 65.254.110.245:8080
01:31:19:WU02:FS01:Assigned to work server 140.163.4.231
01:31:19:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
01:31:19:WU02:FS01:Connecting to 140.163.4.231:8080
01:31:20:WU02:FS01:Downloading 20.07MiB
01:31:26:WU02:FS01:Download 67.57%
01:31:27:WU02:FS01:Download complete
01:31:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:845 gen:288 core:0x21 unit:0x0000019c8ca304e75b846b4eefb36e48
01:32:59:WU01:FS00:0xa7:Completed 750000 out of 5000000 steps (15%)
01:37:26:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
01:37:29:WU00:FS01:0x21:Saving result file logfile_01.txt
01:37:29:WU00:FS01:0x21:Saving result file checkpointState.xml
01:37:29:WU00:FS01:0x21:Saving result file checkpt.crc
01:37:29:WU00:FS01:0x21:Saving result file log.txt
01:37:29:WU00:FS01:0x21:Saving result file positions.xtc
01:37:29:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
01:37:30:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:37:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11718 run:0 clone:791 gen:344 core:0x21 unit:0x000001d18ca304e75b846ad6e023c163
01:37:30:WU00:FS01:Uploading 15.09MiB to 140.163.4.231
01:37:30:WU00:FS01:Connecting to 140.163.4.231:8080
01:37:30:WU02:FS01:Starting
01:37:30:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 02 -suffix 01 -version 705 -lifeline 44656 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:37:31:WU02:FS01:Started FahCore on PID 24432
01:37:32:WU02:FS01:Core PID:25384
01:37:32:WU02:FS01:FahCore 0x21 started
01:37:32:WU02:FS01:0x21:*********************** Log Started 2019-05-15T01:37:32Z ***********************
01:37:32:WU02:FS01:0x21:Project: 11719 (Run 0, Clone 845, Gen 288)
01:37:32:WU02:FS01:0x21:Unit: 0x0000019c8ca304e75b846b4eefb36e48
01:37:32:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:37:32:WU02:FS01:0x21:Machine: 1
01:37:32:WU02:FS01:0x21:Reading tar file core.xml
01:37:32:WU02:FS01:0x21:Reading tar file integrator.xml
01:37:32:WU02:FS01:0x21:Reading tar file state.xml
01:37:32:WU02:FS01:0x21:Reading tar file system.xml
01:37:32:WU02:FS01:0x21:Digital signatures verified
01:37:32:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:37:32:WU02:FS01:0x21:Version 0.0.18
01:37:41:WU00:FS01:Upload 19.88%
01:37:41:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
01:37:41:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:37:48:WU00:FS01:Upload 21.54%
01:37:58:WU00:FS01:Upload 22.37%
01:38:05:WU00:FS01:Upload 23.61%
01:38:12:WU00:FS01:Upload 26.92%
01:38:20:WU00:FS01:Upload 28.58%
01:38:26:WU00:FS01:Upload 29.41%
01:38:32:WU00:FS01:Upload 31.48%
01:38:33:WU01:FS00:0xa7:Completed 800000 out of 5000000 steps (16%)
01:38:38:WU00:FS01:Upload 33.14%
01:38:47:WU00:FS01:Upload 36.04%
01:38:53:WU00:FS01:Upload 38.11%
01:39:04:WU00:FS01:Upload 39.76%
01:39:10:WU00:FS01:Upload 43.08%
01:39:18:WU00:FS01:Upload 45.98%
01:39:24:WU00:FS01:Upload 46.81%
01:39:30:WU00:FS01:Upload 49.29%
01:39:37:WU00:FS01:Upload 53.85%
01:39:44:WU00:FS01:Upload 57.16%
01:39:53:WU00:FS01:Upload 60.89%
01:40:02:WU00:FS01:Upload 64.20%
01:40:08:WU00:FS01:Upload 67.10%
01:40:15:WU00:FS01:Upload 70.83%
01:40:22:WU00:FS01:Upload 73.73%
01:40:28:WU00:FS01:Upload 77.87%
01:40:34:WU00:FS01:Upload 82.43%
01:40:42:WU00:FS01:Upload 85.74%
01:40:51:WU00:FS01:Upload 88.23%
01:40:58:WU00:FS01:Upload 90.30%
01:41:04:WU00:FS01:Upload 91.96%
01:41:11:WU00:FS01:Upload 95.68%
01:41:39:WU00:FS01:Upload complete
01:41:40:WU00:FS01:Server responded WORK_ACK (400)
01:41:40:WU00:FS01:Final credit estimate, 31888.00 points
01:41:40:WU00:FS01:Cleaning up
01:42:45:WU02:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
01:43:56:WU01:FS00:0xa7:Completed 850000 out of 5000000 steps (17%)
01:47:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:47:49:WU02:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
01:49:04:WU01:FS00:0xa7:Completed 900000 out of 5000000 steps (18%)
01:52:51:WU02:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
01:54:19:WU01:FS00:0xa7:Completed 950000 out of 5000000 steps (19%)
01:57:52:WU02:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
01:59:17:WU01:FS00:0xa7:Completed 1000000 out of 5000000 steps (20%)
Re: No points credited when GPU completes WU
this WU appears to have taken just over 1 hour to complete, but according to the information associated with that WU, it took 1.88 days to complete. Apparently it was downloaded long before it was actually started. By itself, this doesn't explain what happened, but it certainly is strange. Can you find any additional information regarding that WU in the earlier logs? (FAH keeps a history of the last 16 logs on your disk.)
felixbunny
Hi Bruce,
Thanks for your reply.
iirc, I started the GPU WU since yesterday but I turned off my system when it was 90+%. I only continued this morning and when it completed, I do not see any point credited.
Regarding the earlier logs, can you direct me to where to obtain them? thanks!
**Edit**
Found it. This is the log yesterday.
*********************** Log Started 2019-05-14T00:42:10Z ***********************
00:42:10:************************* Folding@home Client *************************
00:42:10:        Website: https://foldingathome.org/
00:42:10:      Copyright: (c) 2009-2018 foldingathome.org
00:42:10:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:42:10:           Args:
00:42:10:         Config: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\config.xml
00:42:10:******************************** Build ********************************
00:42:10:        Version: 7.5.1
00:42:10:           Date: May 11 2018
00:42:10:           Time: 13:06:32
00:42:10:     Repository: Git
00:42:10:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:42:10:         Branch: master
00:42:10:       Compiler: Visual C++ 2008
00:42:10:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:42:10:       Platform: win32 10
00:42:10:           Bits: 32
00:42:10:           Mode: Release
00:42:10:******************************* System ********************************
00:42:10:            CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:42:10:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:42:10:           CPUs: 8
00:42:10:         Memory: 31.94GiB
00:42:10:    Free Memory: 24.02GiB
00:42:10:        Threads: WINDOWS_THREADS
00:42:10:     OS Version: 6.2
00:42:10:    Has Battery: false
00:42:10:     On Battery: false
00:42:10:     UTC Offset: 8
00:42:10:            PID: 28304
00:42:10:            CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient
00:42:10:             OS: Windows 10 Enterprise
00:42:10:        OS Arch: AMD64
00:42:10:           GPUs: 1
00:42:10:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
00:42:10:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.1
00:42:10:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:388.13
00:42:10:  Win32 Service: false
00:42:10:***********************************************************************
00:42:10:<config>
00:42:10:  <!-- Folding Slot Configuration -->
00:42:10:  <cause v='CANCER'/>
00:42:10:
00:42:10:  <!-- Slot Control -->
00:42:10:  <power v='MEDIUM'/>
00:42:10:
00:42:10:  <!-- User Information -->
00:42:10:  <passkey v='********************************'/>
00:42:10:  <team v='234980'/>
00:42:10:  <user v='dy047awasyss'/>
00:42:10:
00:42:10:  <!-- Folding Slots -->
00:42:10:  <slot id='0' type='CPU'/>
00:42:10:  <slot id='1' type='GPU'/>
00:42:10:</config>
00:42:10:Trying to access database...
00:42:10:Successfully acquired database lock
00:42:10:Enabled folding slot 00: READY cpu:6
00:42:10:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308
00:42:10:WU01:FS00:Starting
00:42:10:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 28304 -checkpoint 15 -np 6
00:42:10:WU01:FS00:Started FahCore on PID 40332
00:42:10:WU01:FS00:Core PID:19428
00:42:10:WU01:FS00:FahCore 0xa7 started
00:42:10:WU00:FS01:Starting
00:42:10:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 28304 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:42:10:WU00:FS01:Started FahCore on PID 25556
00:42:10:WU00:FS01:Core PID:15428
00:42:10:WU00:FS01:FahCore 0x21 started
00:42:11:WU01:FS00:0xa7:*********************** Log Started 2019-05-14T00:42:11Z ***********************
00:42:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:42:11:WU01:FS00:0xa7:       Type: 0xa7
00:42:11:WU01:FS00:0xa7:       Core: Gromacs
00:42:11:WU01:FS00:0xa7:    Website: https://foldingathome.org/
00:42:11:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:42:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:42:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 40332 -checkpoint 15 -np
00:42:12:WU01:FS00:0xa7:             6
00:42:12:WU01:FS00:0xa7:     Config: <none>
00:42:12:WU01:FS00:0xa7:************************************ Build *************************************
00:42:12:WU01:FS00:0xa7:    Version: 0.0.17
00:42:12:WU01:FS00:0xa7:       Date: Apr 27 2018
00:42:12:WU01:FS00:0xa7:       Time: 16:19:36
00:42:12:WU01:FS00:0xa7: Repository: Git
00:42:12:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:42:12:WU01:FS00:0xa7:     Branch: master
00:42:12:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:42:12:WU00:FS01:0x21:*********************** Log Started 2019-05-14T00:42:11Z ***********************
00:42:12:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:42:12:WU00:FS01:0x21:Project: 11718 (Run 0, Clone 791, Gen 344)
00:42:12:WU01:FS00:0xa7:   Platform: win32 10
00:42:12:WU00:FS01:0x21:Unit: 0x000001d18ca304e75b846ad6e023c163
00:42:12:WU01:FS00:0xa7:       Bits: 64
00:42:12:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:42:12:WU01:FS00:0xa7:       Mode: Release
00:42:12:WU00:FS01:0x21:Machine: 1
00:42:12:WU01:FS00:0xa7:       SIMD: avx_256
00:42:12:WU00:FS01:0x21:Digital signatures verified
00:42:12:WU01:FS00:0xa7:************************************ System ************************************
00:42:12:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:42:12:WU01:FS00:0xa7:        CPU: Unknown
00:42:12:WU00:FS01:0x21:Version 0.0.18
00:42:12:WU01:FS00:0xa7:     CPU ID:
00:42:12:WU01:FS00:0xa7:       CPUs: 8
00:42:12:WU01:FS00:0xa7:     Memory: 31.94GiB
00:42:12:WU01:FS00:0xa7:Free Memory: 23.92GiB
00:42:12:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:42:12:WU01:FS00:0xa7: OS Version: 6.2
00:42:12:WU01:FS00:0xa7:Has Battery: false
00:42:12:WU01:FS00:0xa7: On Battery: false
00:42:12:WU01:FS00:0xa7: UTC Offset: 8
00:42:12:WU01:FS00:0xa7:        PID: 19428
00:42:12:WU01:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
00:42:12:WU01:FS00:0xa7:         OS: Windows 10 Pro
00:42:12:WU01:FS00:0xa7:    OS Arch: AMD64
00:42:12:WU01:FS00:0xa7:********************************************************************************
00:42:12:WU01:FS00:0xa7:Project: 14143 (Run 3, Clone 80, Gen 57)
00:42:12:WU01:FS00:0xa7:Unit: 0x000000420002894c5ca3a7264105bfa5
00:42:12:WU01:FS00:0xa7:Digital signatures verified
00:42:12:WU01:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -cpi state.cpt -cpt 15 -nt 6
00:42:12:WU01:FS00:0xa7:Steps: first=142500000 total=2500000
00:42:13:WU01:FS00:0xa7:Completed 731841 out of 2500000 steps (29%)
00:42:30:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:42:30:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:43:07:15:127.0.0.1:New Web connection
00:47:54:WU01:FS00:0xa7:Completed 750000 out of 2500000 steps (30%)
00:49:01:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
00:52:17:WU01:FS00:0xa7:Completed 775000 out of 2500000 steps (31%)
00:55:11:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
00:55:52:WU01:FS00:0xa7:Completed 800000 out of 2500000 steps (32%)
00:58:57:WU01:FS00:0xa7:Completed 825000 out of 2500000 steps (33%)
01:01:19:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
01:02:10:WU01:FS00:0xa7:Completed 850000 out of 2500000 steps (34%)
01:05:22:WU01:FS00:0xa7:Completed 875000 out of 2500000 steps (35%)
01:07:28:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
01:08:33:WU01:FS00:0xa7:Completed 900000 out of 2500000 steps (36%)
01:11:42:WU01:FS00:0xa7:Completed 925000 out of 2500000 steps (37%)
01:13:36:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
01:13:44:WARNING:FS01:Size of positions 5845 does not match topology 5844
01:14:53:WU01:FS00:0xa7:Completed 950000 out of 2500000 steps (38%)
01:15:03:40:127.0.0.1:New Web connection
01:18:01:WU01:FS00:0xa7:Completed 975000 out of 2500000 steps (39%)
01:19:48:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
01:21:01:WU01:FS00:0xa7:Completed 1000000 out of 2500000 steps (40%)
01:24:16:WU01:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
01:25:56:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
01:27:27:WU01:FS00:0xa7:Completed 1050000 out of 2500000 steps (42%)
01:30:36:WU01:FS00:0xa7:Completed 1075000 out of 2500000 steps (43%)
01:32:06:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
01:33:44:WU01:FS00:0xa7:Completed 1100000 out of 2500000 steps (44%)
01:36:53:WU01:FS00:0xa7:Completed 1125000 out of 2500000 steps (45%)
01:38:14:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
01:39:56:WU01:FS00:0xa7:Completed 1150000 out of 2500000 steps (46%)
01:43:09:WU01:FS00:0xa7:Completed 1175000 out of 2500000 steps (47%)
01:44:23:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
01:44:30:WARNING:FS01:Size of positions 5845 does not match topology 5844
01:46:22:WU01:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
01:49:19:WU01:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
01:50:35:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
01:52:24:WU01:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
01:55:30:WU01:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
01:56:41:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
01:58:17:WU01:FS00:0xa7:Completed 1300000 out of 2500000 steps (52%)
02:01:23:WU01:FS00:0xa7:Completed 1325000 out of 2500000 steps (53%)
02:02:47:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
02:04:30:WU01:FS00:0xa7:Completed 1350000 out of 2500000 steps (54%)
02:07:32:WU01:FS00:0xa7:Completed 1375000 out of 2500000 steps (55%)
02:08:56:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
02:10:35:WU01:FS00:0xa7:Completed 1400000 out of 2500000 steps (56%)
02:13:45:WU01:FS00:0xa7:Completed 1425000 out of 2500000 steps (57%)
02:15:04:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
02:15:11:WARNING:FS01:Size of positions 5845 does not match topology 5844
02:16:57:WU01:FS00:0xa7:Completed 1450000 out of 2500000 steps (58%)
02:19:54:WU01:FS00:0xa7:Completed 1475000 out of 2500000 steps (59%)
02:21:15:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
02:23:20:WU01:FS00:0xa7:Completed 1500000 out of 2500000 steps (60%)
02:26:20:WU01:FS00:0xa7:Completed 1525000 out of 2500000 steps (61%)
02:27:23:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
02:29:33:WU01:FS00:0xa7:Completed 1550000 out of 2500000 steps (62%)
02:32:27:WU01:FS00:0xa7:Completed 1575000 out of 2500000 steps (63%)
02:33:30:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
02:35:37:WU01:FS00:0xa7:Completed 1600000 out of 2500000 steps (64%)
02:38:50:WU01:FS00:0xa7:Completed 1625000 out of 2500000 steps (65%)
02:39:36:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
02:41:49:WU01:FS00:0xa7:Completed 1650000 out of 2500000 steps (66%)
02:44:53:WU01:FS00:0xa7:Completed 1675000 out of 2500000 steps (67%)
02:45:43:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
02:45:53:WARNING:FS01:Size of positions 5845 does not match topology 5844
02:47:59:WU01:FS00:0xa7:Completed 1700000 out of 2500000 steps (68%)
02:51:06:WU01:FS00:0xa7:Completed 1725000 out of 2500000 steps (69%)
02:51:56:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
02:53:57:WU01:FS00:0xa7:Completed 1750000 out of 2500000 steps (70%)
02:57:01:WU01:FS00:0xa7:Completed 1775000 out of 2500000 steps (71%)
02:58:04:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
03:00:12:WU01:FS00:0xa7:Completed 1800000 out of 2500000 steps (72%)
03:03:21:WU01:FS00:0xa7:Completed 1825000 out of 2500000 steps (73%)
03:04:16:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
03:06:34:WU01:FS00:0xa7:Completed 1850000 out of 2500000 steps (74%)
03:09:35:WU01:FS00:0xa7:Completed 1875000 out of 2500000 steps (75%)
03:10:24:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
03:12:36:WU01:FS00:0xa7:Completed 1900000 out of 2500000 steps (76%)
03:15:49:WU01:FS00:0xa7:Completed 1925000 out of 2500000 steps (77%)
03:16:34:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
03:16:42:WARNING:FS01:Size of positions 5845 does not match topology 5844
03:18:58:WU01:FS00:0xa7:Completed 1950000 out of 2500000 steps (78%)
03:21:56:WU01:FS00:0xa7:Completed 1975000 out of 2500000 steps (79%)
03:22:46:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
03:25:03:WU01:FS00:0xa7:Completed 2000000 out of 2500000 steps (80%)
03:28:25:WU01:FS00:0xa7:Completed 2025000 out of 2500000 steps (81%)
03:28:56:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
03:31:37:WU01:FS00:0xa7:Completed 2050000 out of 2500000 steps (82%)
03:34:52:WU01:FS00:0xa7:Completed 2075000 out of 2500000 steps (83%)
03:35:07:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
03:37:56:WU01:FS00:0xa7:Completed 2100000 out of 2500000 steps (84%)
03:40:52:WU01:FS00:0xa7:Completed 2125000 out of 2500000 steps (85%)
03:41:20:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
03:43:38:WU01:FS00:0xa7:Completed 2150000 out of 2500000 steps (86%)
03:46:56:WU01:FS00:0xa7:Completed 2175000 out of 2500000 steps (87%)
03:47:22:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
03:47:30:WARNING:FS01:Size of positions 5845 does not match topology 5844
03:49:55:WU01:FS00:0xa7:Completed 2200000 out of 2500000 steps (88%)
03:52:54:WU01:FS00:0xa7:Completed 2225000 out of 2500000 steps (89%)
03:53:32:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
03:55:43:WU01:FS00:0xa7:Completed 2250000 out of 2500000 steps (90%)
03:58:31:WU01:FS00:0xa7:Completed 2275000 out of 2500000 steps (91%)
03:59:36:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
04:01:33:WU01:FS00:0xa7:Completed 2300000 out of 2500000 steps (92%)
04:04:31:WU01:FS00:0xa7:Completed 2325000 out of 2500000 steps (93%)
04:05:42:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
04:07:28:WU01:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
04:10:24:WU01:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
04:11:48:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
04:13:35:WU01:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
04:16:36:WU01:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
04:17:54:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
04:18:02:WARNING:FS01:Size of positions 5845 does not match topology 5844
04:19:32:WU01:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
04:22:29:WU01:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
04:22:29:WU02:FS00:Connecting to 65.254.110.245:8080
04:22:30:WU02:FS00:Assigned to work server 155.247.166.219
04:22:30:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
04:22:30:WU02:FS00:Connecting to 155.247.166.219:8080
04:22:30:ERROR:WU02:FS00:Exception: Server did not assign work unit
04:22:31:WU02:FS00:Connecting to 65.254.110.245:8080
04:22:31:WU02:FS00:Assigned to work server 128.252.203.9
04:22:31:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 128.252.203.9
04:22:31:WU02:FS00:Connecting to 128.252.203.9:8080
04:22:32:WU02:FS00:Downloading 3.89MiB
04:22:34:WU02:FS00:Download complete
04:22:34:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13818 run:175 clone:2 gen:18 core:0xa7 unit:0x0000001280fccb095c70622a8da8d4c0
04:24:03:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
04:25:29:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
04:25:29:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
04:25:29:WU01:FS00:0xa7:Saving result file frame57.trr
04:25:30:WU01:FS00:0xa7:Saving result file md.log
04:25:30:WU01:FS00:0xa7:Saving result file science.log
04:25:30:WU01:FS00:0xa7:Saving result file traj_comp.xtc
04:25:30:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:25:30:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:25:30:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14143 run:3 clone:80 gen:57 core:0xa7 unit:0x000000420002894c5ca3a7264105bfa5
04:25:30:WU01:FS00:Uploading 3.87MiB to 155.247.166.220
04:25:30:WU01:FS00:Connecting to 155.247.166.220:8080
04:25:30:WU02:FS00:Starting
04:25:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 28304 -checkpoint 15 -np 6
04:25:30:WU02:FS00:Started FahCore on PID 29124
04:25:30:WU02:FS00:Core PID:38040
04:25:30:WU02:FS00:FahCore 0xa7 started
04:25:31:WU02:FS00:0xa7:*********************** Log Started 2019-05-14T04:25:30Z ***********************
04:25:31:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:25:31:WU02:FS00:0xa7:       Type: 0xa7
04:25:31:WU02:FS00:0xa7:       Core: Gromacs
04:25:31:WU02:FS00:0xa7:    Website: https://foldingathome.org/
04:25:31:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
04:25:31:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:25:31:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 29124 -checkpoint 15 -np
04:25:31:WU02:FS00:0xa7:             6
04:25:31:WU02:FS00:0xa7:     Config: <none>
04:25:31:WU02:FS00:0xa7:************************************ Build *************************************
04:25:31:WU02:FS00:0xa7:    Version: 0.0.17
04:25:31:WU02:FS00:0xa7:       Date: Apr 27 2018
04:25:31:WU02:FS00:0xa7:       Time: 16:19:36
04:25:31:WU02:FS00:0xa7: Repository: Git
04:25:31:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
04:25:31:WU02:FS00:0xa7:     Branch: master
04:25:31:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
04:25:31:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:25:31:WU02:FS00:0xa7:   Platform: win32 10
04:25:31:WU02:FS00:0xa7:       Bits: 64
04:25:31:WU02:FS00:0xa7:       Mode: Release
04:25:31:WU02:FS00:0xa7:       SIMD: avx_256
04:25:31:WU02:FS00:0xa7:************************************ System ************************************
04:25:31:WU02:FS00:0xa7:        CPU: Unknown
04:25:31:WU02:FS00:0xa7:     CPU ID:
04:25:31:WU02:FS00:0xa7:       CPUs: 8
04:25:31:WU02:FS00:0xa7:     Memory: 31.94GiB
04:25:31:WU02:FS00:0xa7:Free Memory: 18.10GiB
04:25:31:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
04:25:31:WU02:FS00:0xa7: OS Version: 6.2
04:25:31:WU02:FS00:0xa7:Has Battery: false
04:25:31:WU02:FS00:0xa7: On Battery: false
04:25:31:WU02:FS00:0xa7: UTC Offset: 8
04:25:31:WU02:FS00:0xa7:        PID: 38040
04:25:31:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
04:25:31:WU02:FS00:0xa7:         OS: Windows 10 Pro
04:25:31:WU02:FS00:0xa7:    OS Arch: AMD64
04:25:31:WU02:FS00:0xa7:********************************************************************************
04:25:31:WU02:FS00:0xa7:Project: 13818 (Run 175, Clone 2, Gen 18)
04:25:31:WU02:FS00:0xa7:Unit: 0x0000001280fccb095c70622a8da8d4c0
04:25:31:WU02:FS00:0xa7:Reading tar file core.xml
04:25:31:WU02:FS00:0xa7:Reading tar file frame18.tpr
04:25:31:WU02:FS00:0xa7:Digital signatures verified
04:25:31:WU02:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpt 15 -nt 6
04:25:31:WU02:FS00:0xa7:Steps: first=4500000 total=250000
04:25:32:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
04:25:36:WU01:FS00:Upload 77.49%
04:25:43:WU01:FS00:Upload complete
04:25:43:WU01:FS00:Server responded WORK_ACK (400)
04:25:43:WU01:FS00:Final credit estimate, 2191.00 points
04:25:43:WU01:FS00:Cleaning up
04:28:35:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
04:30:10:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
04:31:35:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
04:34:18:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
04:36:15:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
04:36:58:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
04:39:40:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
04:42:18:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
04:42:23:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
04:45:16:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
04:48:25:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
04:48:28:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
04:48:35:WARNING:FS01:Size of positions 5845 does not match topology 5844
04:51:21:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
04:54:22:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
04:54:41:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
04:57:14:92:127.0.0.1:New Web connection
04:57:24:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
05:00:31:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
05:00:52:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
05:03:39:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
05:06:31:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
05:07:02:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
05:09:28:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
05:12:27:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
05:13:10:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
05:15:33:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
05:18:24:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
05:19:16:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
05:19:23:WARNING:FS01:Size of positions 5845 does not match topology 5844
05:21:06:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
05:23:50:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
05:25:22:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
05:26:35:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
05:29:39:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
05:31:34:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
05:33:13:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
05:36:54:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
05:37:59:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
05:40:49:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
05:44:19:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
05:44:25:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
05:47:36:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
05:50:39:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
05:50:39:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
05:50:47:WARNING:FS01:Size of positions 5845 does not match topology 5844
05:53:29:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
05:56:22:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
05:56:49:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
05:59:20:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
06:02:24:WU02:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
06:02:57:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
06:05:21:WU02:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
06:08:22:WU02:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
06:09:07:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
06:11:21:WU02:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
06:14:19:WU02:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
06:15:16:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
06:17:15:WU02:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
06:20:19:WU02:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
06:21:24:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
06:21:32:WARNING:FS01:Size of positions 5845 does not match topology 5844
06:23:13:WU02:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
06:26:22:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
06:27:35:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
06:29:18:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
06:32:14:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
06:33:45:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
06:35:20:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
06:38:15:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
06:39:53:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
06:41:13:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
******************************* Date: 2019-05-14 *******************************
06:44:12:WU02:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
06:46:00:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
06:47:06:WU02:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
06:49:55:WU02:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
06:52:06:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
06:52:14:WARNING:FS01:Size of positions 5845 does not match topology 5844
06:52:39:WU02:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
06:55:27:WU02:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
06:58:16:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
06:58:33:WU02:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
07:01:31:WU02:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
07:04:24:WU02:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
07:04:26:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
07:07:16:WU02:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
07:10:23:WU02:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
07:10:37:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
07:13:31:WU02:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
07:16:24:WU02:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
07:16:47:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
07:19:17:WU02:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
07:22:38:WU02:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
07:22:59:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
07:23:06:WARNING:FS01:Size of positions 5845 does not match topology 5844
07:25:44:WU02:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
07:28:44:WU02:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
07:29:12:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
07:31:34:WU02:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
07:34:38:WU02:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
07:35:20:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
07:35:36:128:127.0.0.1:New Web connection
07:37:42:WU02:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
07:40:37:WU02:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
07:41:30:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
07:43:40:WU02:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
07:47:04:WU02:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
07:47:41:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
07:50:02:WU02:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
07:52:52:WU02:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
07:53:48:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
07:53:56:WARNING:FS01:Size of positions 5845 does not match topology 5844
07:55:44:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
07:58:48:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
08:00:00:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
08:01:46:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
08:04:38:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
08:06:07:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
08:07:21:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
08:10:04:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
08:12:10:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
08:12:53:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
08:15:46:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
08:18:20:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
08:18:53:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
08:21:56:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
08:24:31:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
08:24:38:WARNING:FS01:Size of positions 5845 does not match topology 5844
08:24:53:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
08:27:50:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
08:30:41:WU00:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
08:30:44:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
08:33:36:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
08:36:33:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
08:36:48:WU00:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
08:39:28:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
08:42:20:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
08:42:55:WU00:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
08:45:29:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
08:48:23:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
08:49:03:WU00:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
08:51:21:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
08:54:15:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
08:55:10:WU00:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
08:55:18:WARNING:FS01:Size of positions 5845 does not match topology 5844
08:57:04:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
09:00:07:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
09:01:22:WU00:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
09:03:25:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
09:06:34:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
09:07:33:WU00:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
09:09:31:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
09:12:29:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
09:13:40:WU00:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
09:15:18:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
09:18:17:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
09:19:49:WU00:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
09:21:05:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
09:21:06:WU01:FS00:Connecting to 65.254.110.245:8080
09:21:07:WU01:FS00:Assigned to work server 155.247.166.219
09:21:07:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
09:21:07:WU01:FS00:Connecting to 155.247.166.219:8080
09:21:08:WU01:FS00:Downloading 294.00KiB
09:21:09:WU01:FS00:Download complete
09:21:09:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14153 run:1 clone:68 gen:61 core:0xa7 unit:0x000000430002894b5c546d1607da4b2b
09:24:06:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
09:24:10:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
09:24:10:WU02:FS00:0xa7:Saving result file frame18.trr
09:24:10:WU02:FS00:0xa7:Saving result file frame18.xtc
09:24:10:WU02:FS00:0xa7:Saving result file md.log
09:24:10:WU02:FS00:0xa7:Saving result file science.log
09:24:10:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
09:24:10:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:24:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13818 run:175 clone:2 gen:18 core:0xa7 unit:0x0000001280fccb095c70622a8da8d4c0
09:24:10:WU02:FS00:Uploading 4.56MiB to 128.252.203.9
09:24:10:WU02:FS00:Connecting to 128.252.203.9:8080
09:24:10:WU01:FS00:Starting
09:24:10:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 28304 -checkpoint 15 -np 6
09:24:10:WU01:FS00:Started FahCore on PID 3952
09:24:10:WU01:FS00:Core PID:41188
09:24:10:WU01:FS00:FahCore 0xa7 started
09:24:11:WU01:FS00:0xa7:*********************** Log Started 2019-05-14T09:24:10Z ***********************
09:24:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:24:11:WU01:FS00:0xa7:       Type: 0xa7
09:24:11:WU01:FS00:0xa7:       Core: Gromacs
09:24:11:WU01:FS00:0xa7:    Website: https://foldingathome.org/
09:24:11:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
09:24:11:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:24:11:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3952 -checkpoint 15 -np 6
09:24:11:WU01:FS00:0xa7:     Config: <none>
09:24:11:WU01:FS00:0xa7:************************************ Build *************************************
09:24:11:WU01:FS00:0xa7:    Version: 0.0.17
09:24:11:WU01:FS00:0xa7:       Date: Apr 27 2018
09:24:11:WU01:FS00:0xa7:       Time: 16:19:36
09:24:11:WU01:FS00:0xa7: Repository: Git
09:24:11:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
09:24:11:WU01:FS00:0xa7:     Branch: master
09:24:11:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:24:11:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:24:11:WU01:FS00:0xa7:   Platform: win32 10
09:24:11:WU01:FS00:0xa7:       Bits: 64
09:24:11:WU01:FS00:0xa7:       Mode: Release
09:24:11:WU01:FS00:0xa7:       SIMD: avx_256
09:24:11:WU01:FS00:0xa7:************************************ System ************************************
09:24:11:WU01:FS00:0xa7:        CPU: Unknown
09:24:11:WU01:FS00:0xa7:     CPU ID:
09:24:11:WU01:FS00:0xa7:       CPUs: 8
09:24:11:WU01:FS00:0xa7:     Memory: 31.94GiB
09:24:11:WU01:FS00:0xa7:Free Memory: 18.02GiB
09:24:11:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:24:11:WU01:FS00:0xa7: OS Version: 6.2
09:24:11:WU01:FS00:0xa7:Has Battery: false
09:24:11:WU01:FS00:0xa7: On Battery: false
09:24:11:WU01:FS00:0xa7: UTC Offset: 8
09:24:11:WU01:FS00:0xa7:        PID: 41188
09:24:11:WU01:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
09:24:11:WU01:FS00:0xa7:         OS: Windows 10 Pro
09:24:11:WU01:FS00:0xa7:    OS Arch: AMD64
09:24:11:WU01:FS00:0xa7:********************************************************************************
09:24:11:WU01:FS00:0xa7:Project: 14153 (Run 1, Clone 68, Gen 61)
09:24:11:WU01:FS00:0xa7:Unit: 0x000000430002894b5c546d1607da4b2b
09:24:11:WU01:FS00:0xa7:Reading tar file core.xml
09:24:11:WU01:FS00:0xa7:Reading tar file frame61.tpr
09:24:11:WU01:FS00:0xa7:Digital signatures verified
09:24:11:WU01:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpt 15 -nt 6
09:24:11:WU01:FS00:0xa7:Steps: first=305000000 total=5000000
09:24:11:WU01:FS00:0xa7:Completed 1 out of 5000000 steps (0%)
09:24:13:WU02:FS00:Upload complete
09:24:14:WU02:FS00:Server responded WORK_ACK (400)
09:24:14:WU02:FS00:Final credit estimate, 6507.00 points
09:24:14:WU02:FS00:Cleaning up
09:25:57:WU00:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
09:26:05:WARNING:FS01:Size of positions 5845 does not match topology 5844
09:29:25:WU01:FS00:0xa7:Completed 50000 out of 5000000 steps (1%)
09:32:06:WU00:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
09:34:25:WU01:FS00:0xa7:Completed 100000 out of 5000000 steps (2%)
09:38:13:WU00:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
09:39:58:WU01:FS00:0xa7:Completed 150000 out of 5000000 steps (3%)
09:44:19:WU00:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
09:44:39:174:127.0.0.1:New Web connection
09:45:21:WU01:FS00:0xa7:Completed 200000 out of 5000000 steps (4%)
09:50:39:WU00:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
09:51:20:WU01:FS00:0xa7:Completed 250000 out of 5000000 steps (5%)
09:56:59:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
09:57:08:WARNING:FS01:Size of positions 5845 does not match topology 5844
09:57:16:WU01:FS00:0xa7:Completed 300000 out of 5000000 steps (6%)
10:02:39:WU01:FS00:0xa7:Completed 350000 out of 5000000 steps (7%)
felixbunny
And this is the log from the day before where I also completed a work unit using my GPU but no points is credited.
09:43:18:WU03:FS01:Upload complete
09:43:19:WU03:FS01:Server responded WORK_ACK (400)
09:43:19:WU03:FS01:Final credit estimate, 56814.00 points
Deleted some progress lines to make it fit
*********************** Log Started 2019-05-13T00:46:58Z ***********************
00:46:58:************************* Folding@home Client *************************
00:46:58:        Website: https://foldingathome.org/
00:46:58:      Copyright: (c) 2009-2018 foldingathome.org
00:46:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:46:58:           Args:
00:46:58:         Config: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\config.xml
00:46:58:******************************** Build ********************************
00:46:58:        Version: 7.5.1
00:46:58:           Date: May 11 2018
00:46:58:           Time: 13:06:32
00:46:58:     Repository: Git
00:46:58:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:46:58:         Branch: master
00:46:58:       Compiler: Visual C++ 2008
00:46:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:46:58:       Platform: win32 10
00:46:58:           Bits: 32
00:46:58:           Mode: Release
00:46:58:******************************* System ********************************
00:46:58:            CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
00:46:58:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:46:58:           CPUs: 8
00:46:58:         Memory: 31.94GiB
00:46:58:    Free Memory: 23.45GiB
00:46:58:        Threads: WINDOWS_THREADS
00:46:58:     OS Version: 6.2
00:46:58:    Has Battery: false
00:46:58:     On Battery: false
00:46:58:     UTC Offset: 8
00:46:58:            PID: 25792
00:46:58:            CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient
00:46:58:             OS: Windows 10 Enterprise
00:46:58:        OS Arch: AMD64
00:46:58:           GPUs: 1
00:46:58:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
00:46:58:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.1
00:46:58:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:388.13
00:46:58:  Win32 Service: false
00:46:58:***********************************************************************
00:47:00:<config>
00:47:00:  <!-- Folding Slot Configuration -->
00:47:00:  <cause v='CANCER'/>
00:47:00:
00:47:00:  <!-- User Information -->
00:47:00:  <passkey v='********************************'/>
00:47:00:  <team v='234980'/>
00:47:00:  <user v='dy047awasyss'/>
00:47:00:
00:47:00:  <!-- Folding Slots -->
00:47:00:  <slot id='0' type='CPU'/>
00:47:00:  <slot id='1' type='GPU'/>
00:47:00:</config>
00:47:00:Trying to access database...
00:47:00:Successfully acquired database lock
00:47:00:Enabled folding slot 00: READY cpu:6
00:47:00:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308
00:47:00:WU00:FS00:Starting
00:47:00:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
00:47:00:WU00:FS00:Started FahCore on PID 31004
00:47:03:WU00:FS00:Core PID:23224
00:47:03:WU00:FS00:FahCore 0xa7 started
00:47:03:WU01:FS01:Starting
00:47:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:47:03:WU01:FS01:Started FahCore on PID 33228
00:47:04:WU01:FS01:Core PID:32156
00:47:04:WU01:FS01:FahCore 0x21 started
00:47:04:WU00:FS00:0xa7:*********************** Log Started 2019-05-13T00:47:04Z ***********************
00:47:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:47:04:WU00:FS00:0xa7:       Type: 0xa7
00:47:04:WU00:FS00:0xa7:       Core: Gromacs
00:47:04:WU00:FS00:0xa7:    Website: https://foldingathome.org/
00:47:04:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
00:47:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:47:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 31004 -checkpoint 15 -np
00:47:04:WU00:FS00:0xa7:             6
00:47:04:WU00:FS00:0xa7:     Config: <none>
00:47:04:WU00:FS00:0xa7:************************************ Build *************************************
00:47:04:WU00:FS00:0xa7:    Version: 0.0.17
00:47:04:WU00:FS00:0xa7:       Date: Apr 27 2018
00:47:04:WU00:FS00:0xa7:       Time: 16:19:36
00:47:04:WU00:FS00:0xa7: Repository: Git
00:47:04:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
00:47:04:WU00:FS00:0xa7:     Branch: master
00:47:04:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
00:47:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:47:04:WU00:FS00:0xa7:   Platform: win32 10
00:47:04:WU00:FS00:0xa7:       Bits: 64
00:47:04:WU00:FS00:0xa7:       Mode: Release
00:47:04:WU00:FS00:0xa7:       SIMD: avx_256
00:47:04:WU00:FS00:0xa7:************************************ System ************************************
00:47:04:WU00:FS00:0xa7:        CPU: Unknown
00:47:04:WU00:FS00:0xa7:     CPU ID:
00:47:04:WU00:FS00:0xa7:       CPUs: 8
00:47:04:WU00:FS00:0xa7:     Memory: 31.94GiB
00:47:04:WU00:FS00:0xa7:Free Memory: 22.81GiB
00:47:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
00:47:04:WU00:FS00:0xa7: OS Version: 6.2
00:47:04:WU00:FS00:0xa7:Has Battery: false
00:47:04:WU00:FS00:0xa7: On Battery: false
00:47:05:WU00:FS00:0xa7: UTC Offset: 8
00:47:05:WU00:FS00:0xa7:        PID: 23224
00:47:05:WU00:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
00:47:05:WU00:FS00:0xa7:         OS: Windows 10 Pro
00:47:05:WU00:FS00:0xa7:    OS Arch: AMD64
00:47:05:WU00:FS00:0xa7:********************************************************************************
00:47:05:WU00:FS00:0xa7:Project: 13822 (Run 587, Clone 1, Gen 18)
00:47:05:WU00:FS00:0xa7:Unit: 0x0000001580fccb095c895dd85bfc10e3
00:47:05:WU00:FS00:0xa7:Digital signatures verified
00:47:05:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpi state.cpt -cpt 15 -nt 6
00:47:05:WU01:FS01:0x21:*********************** Log Started 2019-05-13T00:47:05Z ***********************
00:47:05:WU01:FS01:0x21:Project: 11720 (Run 0, Clone 2194, Gen 137)
00:47:05:WU01:FS01:0x21:Unit: 0x000000c98ca304e75bbce9a9a8853ab0
00:47:05:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:47:05:WU01:FS01:0x21:Machine: 1
00:47:05:WU01:FS01:0x21:Digital signatures verified
00:47:05:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:47:05:WU01:FS01:0x21:Version 0.0.18
00:47:05:WU01:FS01:0x21:  Found a checkpoint file
00:47:19:WU00:FS00:0xa7:Steps: first=2250000 total=125000
00:47:34:WU00:FS00:0xa7:Completed 115291 out of 125000 steps (92%)
00:47:37:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
00:47:37:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:50:35:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
01:06:27:WU01:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
01:06:28:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
01:09:00:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
01:09:01:WU02:FS00:Connecting to 65.254.110.245:8080
01:09:02:WU02:FS00:Assigned to work server 128.252.203.9
01:09:02:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 128.252.203.9
01:09:02:WU02:FS00:Connecting to 128.252.203.9:8080
01:09:03:WU02:FS00:Downloading 8.14MiB
01:09:05:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
01:09:06:WU02:FS00:Download complete
01:09:06:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13824 run:160 clone:1 gen:16 core:0xa7 unit:0x0000001080fccb095c9249b60bec481e
01:11:33:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
01:11:40:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
01:11:40:WU00:FS00:0xa7:Saving result file frame18.trr
01:11:40:WU00:FS00:0xa7:Saving result file frame18.xtc
01:11:40:WU00:FS00:0xa7:Saving result file md.log
01:11:40:WU00:FS00:0xa7:Saving result file science.log
01:11:40:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:11:40:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:11:40:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13822 run:587 clone:1 gen:18 core:0xa7 unit:0x0000001580fccb095c895dd85bfc10e3
01:11:40:WU00:FS00:Uploading 11.37MiB to 128.252.203.9
01:11:40:WU00:FS00:Connecting to 128.252.203.9:8080
01:11:40:WU02:FS00:Starting
01:11:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
01:11:41:WU02:FS00:Started FahCore on PID 27848
01:11:41:WU02:FS00:Core PID:16412
01:11:41:WU02:FS00:FahCore 0xa7 started
01:11:41:WU02:FS00:0xa7:*********************** Log Started 2019-05-13T01:11:41Z ***********************
01:11:41:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:11:41:WU02:FS00:0xa7:       Type: 0xa7
01:11:41:WU02:FS00:0xa7:       Core: Gromacs
01:11:41:WU02:FS00:0xa7:    Website: https://foldingathome.org/
01:11:41:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
01:11:41:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:11:41:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 27848 -checkpoint 15 -np
01:11:41:WU02:FS00:0xa7:             6
01:11:41:WU02:FS00:0xa7:     Config: <none>
01:11:41:WU02:FS00:0xa7:************************************ Build *************************************
01:11:41:WU02:FS00:0xa7:    Version: 0.0.17
01:11:41:WU02:FS00:0xa7:       Date: Apr 27 2018
01:11:41:WU02:FS00:0xa7:       Time: 16:19:36
01:11:41:WU02:FS00:0xa7: Repository: Git
01:11:41:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
01:11:41:WU02:FS00:0xa7:     Branch: master
01:11:41:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
01:11:41:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:11:41:WU02:FS00:0xa7:   Platform: win32 10
01:11:41:WU02:FS00:0xa7:       Bits: 64
01:11:41:WU02:FS00:0xa7:       Mode: Release
01:11:41:WU02:FS00:0xa7:       SIMD: avx_256
01:11:41:WU02:FS00:0xa7:************************************ System ************************************
01:11:41:WU02:FS00:0xa7:        CPU: Unknown
01:11:41:WU02:FS00:0xa7:     CPU ID:
01:11:41:WU02:FS00:0xa7:       CPUs: 8
01:11:41:WU02:FS00:0xa7:     Memory: 31.94GiB
01:11:41:WU02:FS00:0xa7:Free Memory: 20.31GiB
01:11:41:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
01:11:41:WU02:FS00:0xa7: OS Version: 6.2
01:11:41:WU02:FS00:0xa7:Has Battery: false
01:11:41:WU02:FS00:0xa7: On Battery: false
01:11:41:WU02:FS00:0xa7: UTC Offset: 8
01:11:41:WU02:FS00:0xa7:        PID: 16412
01:11:41:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
01:11:41:WU02:FS00:0xa7:         OS: Windows 10 Pro
01:11:41:WU02:FS00:0xa7:    OS Arch: AMD64
01:11:41:WU02:FS00:0xa7:********************************************************************************
01:11:41:WU02:FS00:0xa7:Project: 13824 (Run 160, Clone 1, Gen 16)
01:11:41:WU02:FS00:0xa7:Unit: 0x0000001080fccb095c9249b60bec481e
01:11:41:WU02:FS00:0xa7:Reading tar file core.xml
01:11:41:WU02:FS00:0xa7:Reading tar file frame16.tpr
01:11:41:WU02:FS00:0xa7:Digital signatures verified
01:11:41:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpt 15 -nt 6
01:11:41:WU02:FS00:0xa7:Steps: first=2000000 total=125000
01:11:42:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
01:11:42:WU03:FS01:Connecting to 65.254.110.245:8080
01:11:43:WU03:FS01:Assigned to work server 140.163.4.231
01:11:43:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
01:11:43:WU03:FS01:Connecting to 140.163.4.231:8080
01:11:43:WU03:FS01:Downloading 20.07MiB
01:11:45:WU00:FS00:Upload complete
01:11:45:WU00:FS00:Server responded WORK_ACK (400)
01:11:45:WU00:FS00:Final credit estimate, 1231.00 points
01:11:45:WU00:FS00:Cleaning up
01:11:46:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
01:11:49:WU03:FS01:Download 75.66%
01:11:50:WU03:FS01:Download complete
01:11:50:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:1437 gen:403 core:0x21 unit:0x000002158ca304e75b8990ac2137b64e
01:12:34:101:127.0.0.1:New Web connection
01:14:24:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
01:14:25:WU01:FS01:0x21:Saving result file logfile_01.txt
01:14:26:WU01:FS01:0x21:Saving result file checkpointState.xml
01:14:26:WU01:FS01:0x21:Saving result file checkpt.crc
01:14:26:WU01:FS01:0x21:Saving result file log.txt
01:14:26:WU01:FS01:0x21:Saving result file positions.xtc
01:14:26:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
01:14:26:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:14:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11720 run:0 clone:2194 gen:137 core:0x21 unit:0x000000c98ca304e75bbce9a9a8853ab0
01:14:26:WU01:FS01:Uploading 7.02MiB to 140.163.4.231
01:14:26:WU01:FS01:Connecting to 140.163.4.231:8080
01:14:26:WU03:FS01:Starting
01:14:26:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 03 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:14:26:WU03:FS01:Started FahCore on PID 8364
01:14:26:WU03:FS01:Core PID:18228
01:14:26:WU03:FS01:FahCore 0x21 started
01:14:27:WU03:FS01:0x21:*********************** Log Started 2019-05-13T01:14:26Z ***********************
01:14:27:WU03:FS01:0x21:Project: 11719 (Run 0, Clone 1437, Gen 403)
01:14:27:WU03:FS01:0x21:Unit: 0x000002158ca304e75b8990ac2137b64e
01:14:27:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:14:27:WU03:FS01:0x21:Machine: 1
01:14:27:WU03:FS01:0x21:Reading tar file core.xml
01:14:27:WU03:FS01:0x21:Reading tar file integrator.xml
01:14:27:WU03:FS01:0x21:Reading tar file state.xml
01:14:27:WU03:FS01:0x21:Reading tar file system.xml
01:14:27:WU03:FS01:0x21:Digital signatures verified
01:14:27:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:14:27:WU03:FS01:0x21:Version 0.0.18
01:14:34:WU01:FS01:Upload 42.72%
01:14:40:WU03:FS01:0x21:Completed 0 out of 5000000 steps (0%)
01:14:40:WU03:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:14:41:WU01:FS01:Upload 54.29%
01:14:47:WU01:FS01:Upload 57.85%
01:14:53:WU01:FS01:Upload 72.09%
01:15:05:WU01:FS01:Upload complete
01:15:05:WU01:FS01:Server responded WORK_ACK (400)
01:15:05:WU01:FS01:Final credit estimate, 7979.00 points
01:15:05:WU01:FS01:Cleaning up
01:15:07:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
01:17:55:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
01:19:45:WU03:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
01:20:36:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
01:23:19:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
01:35:02:WU03:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
01:37:01:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
01:37:19:FS00:Shutting core down
01:37:19:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 16412
01:37:19:WU02:FS00:0xa7:Exiting, please wait. . .
01:37:25:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
01:37:25:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:37:25:WU02:FS00:Starting
01:37:25:WARNING:WU02:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
01:37:25:WARNING:WU02:FS00:AS lowered CPUs from 7 to 6
01:37:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
01:37:25:WU02:FS00:Started FahCore on PID 25188
01:37:25:WU02:FS00:Core PID:34940
01:37:25:WU02:FS00:FahCore 0xa7 started
01:37:26:WU02:FS00:0xa7:*********************** Log Started 2019-05-13T01:37:25Z ***********************
01:37:26:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:37:26:WU02:FS00:0xa7:       Type: 0xa7
01:37:26:WU02:FS00:0xa7:       Core: Gromacs
01:37:26:WU02:FS00:0xa7:    Website: https://foldingathome.org/
01:37:26:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
01:37:26:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:37:26:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 25188 -checkpoint 15 -np
01:37:26:WU02:FS00:0xa7:             6
01:37:26:WU02:FS00:0xa7:     Config: <none>
01:37:26:WU02:FS00:0xa7:************************************ Build *************************************
01:37:26:WU02:FS00:0xa7:    Version: 0.0.17
01:37:26:WU02:FS00:0xa7:       Date: Apr 27 2018
01:37:26:WU02:FS00:0xa7:       Time: 16:19:36
01:37:26:WU02:FS00:0xa7: Repository: Git
01:37:26:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
01:37:26:WU02:FS00:0xa7:     Branch: master
01:37:26:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
01:37:26:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:37:26:WU02:FS00:0xa7:   Platform: win32 10
01:37:26:WU02:FS00:0xa7:       Bits: 64
01:37:26:WU02:FS00:0xa7:       Mode: Release
01:37:26:WU02:FS00:0xa7:       SIMD: avx_256
01:37:26:WU02:FS00:0xa7:************************************ System ************************************
01:37:26:WU02:FS00:0xa7:        CPU: Unknown
01:37:26:WU02:FS00:0xa7:     CPU ID:
01:37:26:WU02:FS00:0xa7:       CPUs: 8
01:37:26:WU02:FS00:0xa7:     Memory: 31.94GiB
01:37:26:WU02:FS00:0xa7:Free Memory: 18.74GiB
01:37:26:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
01:37:26:WU02:FS00:0xa7: OS Version: 6.2
01:37:26:WU02:FS00:0xa7:Has Battery: false
01:37:26:WU02:FS00:0xa7: On Battery: false
01:37:26:WU02:FS00:0xa7: UTC Offset: 8
01:37:26:WU02:FS00:0xa7:        PID: 34940
01:37:26:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
01:37:26:WU02:FS00:0xa7:         OS: Windows 10 Pro
01:37:26:WU02:FS00:0xa7:    OS Arch: AMD64
01:37:26:WU02:FS00:0xa7:********************************************************************************
01:37:26:WU02:FS00:0xa7:Project: 13824 (Run 160, Clone 1, Gen 16)
01:37:26:WU02:FS00:0xa7:Unit: 0x0000001080fccb095c9249b60bec481e
01:37:26:WU02:FS00:0xa7:Digital signatures verified
01:37:26:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpi state.cpt -cpt 15 -nt 6
01:37:26:WU02:FS00:0xa7:Steps: first=2000000 total=125000
01:37:29:WU02:FS00:0xa7:Completed 11392 out of 125000 steps (9%)
01:37:50:Saving configuration to config.xml
01:37:50:<config>
01:37:50:  <!-- Folding Slot Configuration -->
01:37:50:  <cause v='CANCER'/>
01:37:50:
01:37:50:  <!-- Slot Control -->
01:37:50:  <power v='FULL'/>
01:37:50:
01:37:50:  <!-- User Information -->
01:37:50:  <passkey v='********************************'/>
01:37:50:  <team v='234980'/>
01:37:50:  <user v='dy047awasyss'/>
01:37:50:
01:37:50:  <!-- Folding Slots -->
01:37:50:  <slot id='0' type='CPU'/>
01:37:50:  <slot id='1' type='GPU'/>
01:37:50:</config>
01:39:52:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
01:40:12:WU03:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
01:40:20:WARNING:FS01:Size of positions 2073 does not match topology 2067
01:42:20:FS00:Shutting core down
01:42:20:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 34940
01:42:20:WU02:FS00:0xa7:Exiting, please wait. . .
01:42:25:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
01:42:25:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:42:25:WU02:FS00:Starting
01:42:25:WARNING:WU02:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
01:42:25:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
01:42:25:WU02:FS00:Started FahCore on PID 29120
01:42:26:WU02:FS00:Core PID:12892
01:42:26:WU02:FS00:FahCore 0xa7 started
01:42:26:WU02:FS00:0xa7:*********************** Log Started 2019-05-13T01:42:26Z ***********************
01:42:26:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:42:26:WU02:FS00:0xa7:       Type: 0xa7
01:42:26:WU02:FS00:0xa7:       Core: Gromacs
01:42:26:WU02:FS00:0xa7:    Website: https://foldingathome.org/
01:42:26:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
01:42:26:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:42:26:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 29120 -checkpoint 15 -np
01:42:26:WU02:FS00:0xa7:             6
01:42:26:WU02:FS00:0xa7:     Config: <none>
01:42:26:WU02:FS00:0xa7:************************************ Build *************************************
01:42:26:WU02:FS00:0xa7:    Version: 0.0.17
01:42:26:WU02:FS00:0xa7:       Date: Apr 27 2018
01:42:26:WU02:FS00:0xa7:       Time: 16:19:36
01:42:26:WU02:FS00:0xa7: Repository: Git
01:42:26:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
01:42:26:WU02:FS00:0xa7:     Branch: master
01:42:26:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
01:42:26:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:42:26:WU02:FS00:0xa7:   Platform: win32 10
01:42:26:WU02:FS00:0xa7:       Bits: 64
01:42:26:WU02:FS00:0xa7:       Mode: Release
01:42:26:WU02:FS00:0xa7:       SIMD: avx_256
01:42:26:WU02:FS00:0xa7:************************************ System ************************************
01:42:26:WU02:FS00:0xa7:        CPU: Unknown
01:42:26:WU02:FS00:0xa7:     CPU ID:
01:42:26:WU02:FS00:0xa7:       CPUs: 8
01:42:26:WU02:FS00:0xa7:     Memory: 31.94GiB
01:42:26:WU02:FS00:0xa7:Free Memory: 19.09GiB
01:42:26:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
01:42:26:WU02:FS00:0xa7: OS Version: 6.2
01:42:26:WU02:FS00:0xa7:Has Battery: false
01:42:26:WU02:FS00:0xa7: On Battery: false
01:42:26:WU02:FS00:0xa7: UTC Offset: 8
01:42:26:WU02:FS00:0xa7:        PID: 12892
01:42:26:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
01:42:26:WU02:FS00:0xa7:         OS: Windows 10 Pro
01:42:26:WU02:FS00:0xa7:    OS Arch: AMD64
01:42:26:WU02:FS00:0xa7:********************************************************************************
01:42:26:WU02:FS00:0xa7:Project: 13824 (Run 160, Clone 1, Gen 16)
01:42:26:WU02:FS00:0xa7:Unit: 0x0000001080fccb095c9249b60bec481e
01:42:26:WU02:FS00:0xa7:Digital signatures verified
01:42:26:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpi state.cpt -cpt 15 -nt 6
01:42:26:WU02:FS00:0xa7:Steps: first=2000000 total=125000
01:42:29:WU02:FS00:0xa7:Completed 13592 out of 125000 steps (10%)
01:42:49:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
01:42:55:Saving configuration to config.xml
01:42:55:<config>
01:42:55:  <!-- Folding Slot Configuration -->
01:42:55:  <cause v='CANCER'/>
01:42:55:
01:42:55:  <!-- Slot Control -->
01:42:55:  <power v='MEDIUM'/>
01:42:55:
01:42:55:  <!-- User Information -->
01:42:55:  <passkey v='********************************'/>
01:42:55:  <team v='234980'/>
01:42:55:  <user v='dy047awasyss'/>
01:42:55:
01:42:55:  <!-- Folding Slots -->
01:42:55:  <slot id='0' type='CPU'/>
01:42:55:  <slot id='1' type='GPU'/>
01:42:55:</config>
01:45:22:WU03:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
01:45:29:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
01:48:02:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
01:50:28:WU03:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
01:50:43:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
01:53:14:FS00:Shutting core down
01:53:14:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 12892
01:53:14:WU02:FS00:0xa7:Exiting, please wait. . .
01:53:19:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
01:53:19:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:53:19:WU02:FS00:Starting
01:53:19:WARNING:WU02:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
01:53:19:WARNING:WU02:FS00:AS lowered CPUs from 7 to 6
01:53:19:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
01:53:19:WU02:FS00:Started FahCore on PID 34804
01:53:19:WU02:FS00:Core PID:10804
01:53:19:WU02:FS00:FahCore 0xa7 started
01:53:20:WU02:FS00:0xa7:*********************** Log Started 2019-05-13T01:53:19Z ***********************
01:53:20:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:53:20:WU02:FS00:0xa7:       Type: 0xa7
01:53:20:WU02:FS00:0xa7:       Core: Gromacs
01:53:20:WU02:FS00:0xa7:    Website: https://foldingathome.org/
01:53:20:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
01:53:20:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:53:20:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 34804 -checkpoint 15 -np
01:53:20:WU02:FS00:0xa7:             6
01:53:20:WU02:FS00:0xa7:     Config: <none>
01:53:20:WU02:FS00:0xa7:************************************ Build *************************************
01:53:20:WU02:FS00:0xa7:    Version: 0.0.17
01:53:20:WU02:FS00:0xa7:       Date: Apr 27 2018
01:53:20:WU02:FS00:0xa7:       Time: 16:19:36
01:53:20:WU02:FS00:0xa7: Repository: Git
01:53:20:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
01:53:20:WU02:FS00:0xa7:     Branch: master
01:53:20:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
01:53:20:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:53:20:WU02:FS00:0xa7:   Platform: win32 10
01:53:20:WU02:FS00:0xa7:       Bits: 64
01:53:20:WU02:FS00:0xa7:       Mode: Release
01:53:20:WU02:FS00:0xa7:       SIMD: avx_256
01:53:20:WU02:FS00:0xa7:************************************ System ************************************
01:53:20:WU02:FS00:0xa7:        CPU: Unknown
01:53:20:WU02:FS00:0xa7:     CPU ID:
01:53:20:WU02:FS00:0xa7:       CPUs: 8
01:53:20:WU02:FS00:0xa7:     Memory: 31.94GiB
01:53:20:WU02:FS00:0xa7:Free Memory: 18.82GiB
01:53:20:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
01:53:20:WU02:FS00:0xa7: OS Version: 6.2
01:53:20:WU02:FS00:0xa7:Has Battery: false
01:53:20:WU02:FS00:0xa7: On Battery: false
01:53:20:WU02:FS00:0xa7: UTC Offset: 8
01:53:20:WU02:FS00:0xa7:        PID: 10804
01:53:20:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
01:53:20:WU02:FS00:0xa7:         OS: Windows 10 Pro
01:53:20:WU02:FS00:0xa7:    OS Arch: AMD64
01:53:20:WU02:FS00:0xa7:********************************************************************************
01:53:20:WU02:FS00:0xa7:Project: 13824 (Run 160, Clone 1, Gen 16)
01:53:20:WU02:FS00:0xa7:Unit: 0x0000001080fccb095c9249b60bec481e
01:53:20:WU02:FS00:0xa7:Digital signatures verified
01:53:20:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpi state.cpt -cpt 15 -nt 6
01:53:20:WU02:FS00:0xa7:Steps: first=2000000 total=125000
01:53:23:WU02:FS00:0xa7:Completed 18662 out of 125000 steps (14%)
01:53:34:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
01:54:06:Saving configuration to config.xml
01:54:06:<config>
01:54:06:  <!-- Folding Slot Configuration -->
01:54:06:  <cause v='CANCER'/>
01:54:06:
01:54:06:  <!-- Slot Control -->
01:54:06:  <power v='FULL'/>
01:54:06:
01:54:06:  <!-- User Information -->
01:54:06:  <passkey v='********************************'/>
01:54:06:  <team v='234980'/>
01:54:06:  <user v='dy047awasyss'/>
01:54:06:
01:54:06:  <!-- Folding Slots -->
01:54:06:  <slot id='0' type='CPU'/>
01:54:06:  <slot id='1' type='GPU'/>
01:54:06:</config>
01:55:34:WU03:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
01:56:07:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
01:58:43:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
02:05:31:WARNING:FS01:Size of positions 2073 does not match topology 2067
02:06:04:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
02:08:39:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
02:10:29:WU03:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
02:11:11:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
02:13:56:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
02:15:36:WU03:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
02:16:40:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
02:19:16:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
02:20:40:WU03:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
02:21:48:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
02:24:32:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
02:25:47:WU03:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
02:27:06:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
02:29:41:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
02:30:53:WU03:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
02:31:01:WARNING:FS01:Size of positions 2073 does not match topology 2067
02:32:19:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
02:34:56:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
02:36:03:WU03:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
02:37:37:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
02:40:31:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
02:41:10:WU03:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
02:43:04:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
02:45:48:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
02:46:18:WU03:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
02:48:26:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
02:50:33:FS00:Shutting core down
02:50:33:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 10804
02:50:33:WU02:FS00:0xa7:Exiting, please wait. . .
02:50:38:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:50:39:WU02:FS00:Starting
02:50:39:WARNING:WU02:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
02:50:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
02:50:39:WU02:FS00:Started FahCore on PID 36676
02:50:39:WU02:FS00:Core PID:35348
02:50:39:WU02:FS00:FahCore 0xa7 started
02:50:39:WU02:FS00:0xa7:*********************** Log Started 2019-05-13T02:50:39Z ***********************
02:50:39:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:50:39:WU02:FS00:0xa7:       Type: 0xa7
02:50:39:WU02:FS00:0xa7:       Core: Gromacs
02:50:39:WU02:FS00:0xa7:    Website: https://foldingathome.org/
02:50:39:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
02:50:39:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:50:39:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 36676 -checkpoint 15 -np
02:50:39:WU02:FS00:0xa7:             6
02:50:39:WU02:FS00:0xa7:     Config: <none>
02:50:39:WU02:FS00:0xa7:************************************ Build *************************************
02:50:39:WU02:FS00:0xa7:    Version: 0.0.17
02:50:39:WU02:FS00:0xa7:       Date: Apr 27 2018
02:50:39:WU02:FS00:0xa7:       Time: 16:19:36
02:50:39:WU02:FS00:0xa7: Repository: Git
02:50:39:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
02:50:39:WU02:FS00:0xa7:     Branch: master
02:50:39:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
02:50:39:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:50:39:WU02:FS00:0xa7:   Platform: win32 10
02:50:39:WU02:FS00:0xa7:       Bits: 64
02:50:39:WU02:FS00:0xa7:       Mode: Release
02:50:39:WU02:FS00:0xa7:       SIMD: avx_256
02:50:39:WU02:FS00:0xa7:************************************ System ************************************
02:50:39:WU02:FS00:0xa7:        CPU: Unknown
02:50:39:WU02:FS00:0xa7:     CPU ID:
02:50:39:WU02:FS00:0xa7:       CPUs: 8
02:50:39:WU02:FS00:0xa7:     Memory: 31.94GiB
02:50:39:WU02:FS00:0xa7:Free Memory: 18.56GiB
02:50:39:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
02:50:39:WU02:FS00:0xa7: OS Version: 6.2
02:50:39:WU02:FS00:0xa7:Has Battery: false
02:50:39:WU02:FS00:0xa7: On Battery: false
02:50:39:WU02:FS00:0xa7: UTC Offset: 8
02:50:39:WU02:FS00:0xa7:        PID: 35348
02:50:39:WU02:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
02:50:39:WU02:FS00:0xa7:         OS: Windows 10 Pro
02:50:39:WU02:FS00:0xa7:    OS Arch: AMD64
02:50:39:WU02:FS00:0xa7:********************************************************************************
02:50:39:WU02:FS00:0xa7:Project: 13824 (Run 160, Clone 1, Gen 16)
02:50:39:WU02:FS00:0xa7:Unit: 0x0000001080fccb095c9249b60bec481e
02:50:39:WU02:FS00:0xa7:Digital signatures verified
02:50:39:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -x frame16.xtc -cpi state.cpt -cpt 15 -nt 6
02:50:39:WU02:FS00:0xa7:Steps: first=2000000 total=125000
02:50:42:WU02:FS00:0xa7:Completed 45982 out of 125000 steps (36%)
02:51:02:Saving configuration to config.xml
02:51:02:<config>
02:51:02:  <!-- Folding Slot Configuration -->
02:51:02:  <cause v='CANCER'/>
02:51:02:
02:51:02:  <!-- Slot Control -->
02:51:02:  <power v='MEDIUM'/>
02:51:02:
02:51:02:  <!-- User Information -->
02:51:02:  <passkey v='********************************'/>
02:51:02:  <team v='234980'/>
02:51:02:  <user v='dy047awasyss'/>
02:51:02:
02:51:02:  <!-- Folding Slots -->
02:51:02:  <slot id='0' type='CPU'/>
02:51:02:  <slot id='1' type='GPU'/>
02:51:02:</config>
02:56:36:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
02:56:40:WARNING:FS01:Size of positions 2073 does not match topology 2067
02:59:13:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
03:22:10:WU03:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
03:22:18:WARNING:FS01:Size of positions 2073 does not match topology 2067
03:47:44:WARNING:FS01:Size of positions 2073 does not match topology 2067
04:13:00:WARNING:FS01:Size of positions 2073 does not match topology 2067
04:38:16:WARNING:FS01:Size of positions 2073 does not match topology 2067
05:03:48:WARNING:FS01:Size of positions 2073 does not match topology 2067
05:24:09:WU03:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
05:25:19:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
05:27:57:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
05:29:16:WU03:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
05:29:23:WARNING:FS01:Size of positions 2073 does not match topology 2067
05:30:35:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
05:30:36:WU00:FS00:Connecting to 65.254.110.245:8080
05:30:37:WU00:FS00:Assigned to work server 171.67.108.158
05:30:37:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.67.108.158
05:30:37:WU00:FS00:Connecting to 171.67.108.158:8080
05:30:38:WU00:FS00:Downloading 808.21KiB
05:30:40:WU00:FS00:Download complete
05:30:40:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9038 run:792 clone:1 gen:2279 core:0xa4 unit:0x000009caab436c9e569829146ff9ecba
05:30:40:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
05:30:40:WU00:FS00:Connecting to cores.foldingathome.org:80
05:30:40:WU00:FS00:FahCore a4: Downloading 2.89MiB
05:30:43:WU00:FS00:FahCore a4: Download complete
05:30:43:WU00:FS00:Valid core signature
05:30:43:WU00:FS00:Unpacked 9.59MiB to cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
05:33:08:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
05:33:16:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
05:33:16:WU02:FS00:0xa7:Saving result file frame16.trr
05:33:16:WU02:FS00:0xa7:Saving result file frame16.xtc
05:33:16:WU02:FS00:0xa7:Saving result file md.log
05:33:16:WU02:FS00:0xa7:Saving result file science.log
05:33:16:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
05:33:16:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:33:16:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13824 run:160 clone:1 gen:16 core:0xa7 unit:0x0000001080fccb095c9249b60bec481e
05:33:16:WU02:FS00:Uploading 29.13MiB to 128.252.203.9
05:33:16:WU02:FS00:Connecting to 128.252.203.9:8080
05:33:16:WU00:FS00:Starting
05:33:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
05:33:17:WU00:FS00:Started FahCore on PID 22636
05:33:18:WU00:FS00:Core PID:37296
05:33:18:WU00:FS00:FahCore 0xa4 started
05:33:18:WU00:FS00:0xa4:
05:33:18:WU00:FS00:0xa4:*------------------------------*
05:33:18:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:33:18:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:33:18:WU00:FS00:0xa4:Preparing to commence simulation
05:33:18:WU00:FS00:0xa4:- Looking at optimizations...
05:33:18:WU00:FS00:0xa4:- Created dyn
05:33:18:WU00:FS00:0xa4:- Files status OK
05:33:18:WU00:FS00:0xa4:- Expanded 827097 -> 1402860 (decompressed 169.6 percent)
05:33:18:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=827097 data_size=1402860, decompressed_data_size=1402860 diff=0
05:33:18:WU00:FS00:0xa4:- Digital signature verified
05:33:18:WU00:FS00:0xa4:Project: 9038 (Run 792, Clone 1, Gen 2279)
05:33:18:WU00:FS00:0xa4:Assembly optimizations on if available.
05:33:18:WU00:FS00:0xa4:Entering M.D.
05:33:22:WU02:FS00:Upload 45.06%
05:33:24:WU00:FS00:0xa4:Mapping NT from 6 to 6
05:33:24:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
05:33:26:WU02:FS00:Upload complete
05:33:26:WU02:FS00:Server responded WORK_ACK (400)
05:33:26:WU02:FS00:Final credit estimate, 4810.00 points
05:33:26:WU02:FS00:Cleaning up
05:34:25:WU03:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
05:35:09:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
05:36:46:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
05:38:27:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
05:39:28:WU03:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
05:40:10:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
05:41:55:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
05:43:36:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
05:44:32:WU03:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
05:45:17:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
05:47:10:WU00:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
05:49:03:WU00:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
05:49:36:WU03:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
05:50:57:WU00:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
05:52:52:WU00:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
05:54:38:WU00:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
05:54:40:WU03:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
05:54:47:WARNING:FS01:Size of positions 2073 does not match topology 2067
05:56:18:WU00:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
05:57:56:WU00:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
05:59:32:WU00:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
05:59:45:WU03:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
06:01:17:WU00:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
06:02:56:WU00:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
06:04:38:WU00:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
06:04:49:WU03:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
06:06:20:WU00:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
06:07:56:WU00:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
06:09:29:WU00:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
06:09:49:WU03:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
06:11:07:WU00:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
06:12:54:WU00:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
06:14:44:WU00:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
06:14:52:WU03:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
06:16:33:WU00:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
06:18:14:WU00:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
06:19:56:WU03:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
06:19:58:WU00:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
06:20:03:WARNING:FS01:Size of positions 2073 does not match topology 2067
06:21:37:WU00:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
06:23:31:WU00:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
06:25:03:WU03:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
06:25:12:WU00:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
06:26:48:WU00:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
06:28:27:WU00:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
06:30:06:WU03:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
06:30:14:WU00:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
06:31:55:WU00:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
06:33:38:WU00:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
06:35:10:WU03:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
06:35:20:WU00:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
06:36:58:WU00:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
06:38:46:WU00:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
06:40:14:WU03:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
06:40:26:WU00:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
06:42:08:WU00:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
06:43:51:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
06:45:19:WU03:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
06:45:26:WARNING:FS01:Size of positions 2073 does not match topology 2067
06:45:40:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
******************************* Date: 2019-05-13 *******************************
06:47:30:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
06:49:12:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
06:50:25:WU03:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
06:51:00:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
06:52:54:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
06:54:44:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
06:55:29:WU03:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
06:56:23:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
06:58:00:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
06:59:37:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
07:00:31:WU03:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
07:01:29:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
07:03:04:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
07:04:38:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
07:05:34:WU03:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
07:06:20:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
07:07:56:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
07:09:32:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
07:10:37:WU03:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
07:10:44:WARNING:FS01:Size of positions 2073 does not match topology 2067
07:11:07:WU00:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
07:12:42:WU00:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
07:14:16:WU00:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
07:15:42:WU03:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
07:15:53:WU00:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
07:17:41:WU00:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
07:19:23:WU00:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
07:20:47:WU03:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
07:21:05:WU00:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
07:22:45:WU00:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
07:24:20:WU00:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
07:25:51:WU03:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
07:25:56:WU00:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
07:27:47:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
07:29:28:WU00:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
07:30:55:WU03:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
07:31:08:WU00:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
07:32:46:WU00:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
07:34:22:WU00:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
07:35:58:WU03:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
07:36:05:WARNING:FS01:Size of positions 2073 does not match topology 2067
07:36:08:WU00:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
07:37:52:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
07:59:37:WU00:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
08:01:03:WU03:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
08:01:10:WARNING:FS01:Size of positions 2073 does not match topology 2067
08:01:25:WU00:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
08:20:10:WU00:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
08:21:05:WU03:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
08:21:54:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
08:21:55:WU01:FS00:Connecting to 65.254.110.245:8080
08:21:56:WU01:FS00:Assigned to work server 155.247.166.220
08:21:56:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.220
08:21:56:WU01:FS00:Connecting to 155.247.166.220:8080
08:21:56:WU01:FS00:Downloading 356.03KiB
08:21:58:WU01:FS00:Download complete
08:21:58:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14143 run:3 clone:80 gen:57 core:0xa7 unit:0x000000420002894c5ca3a7264105bfa5
08:23:35:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
08:23:36:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
08:23:46:WU00:FS00:0xa4:
08:23:46:WU00:FS00:0xa4:Finished Work Unit:
08:23:46:WU00:FS00:0xa4:- Reading up to 811536 from "00/wudata_01.trr": Read 811536
08:23:46:WU00:FS00:0xa4:trr file hash check passed.
08:23:46:WU00:FS00:0xa4:- Reading up to 746224 from "00/wudata_01.xtc": Read 746224
08:23:46:WU00:FS00:0xa4:xtc file hash check passed.
08:23:46:WU00:FS00:0xa4:edr file hash check passed.
08:23:46:WU00:FS00:0xa4:logfile size: 23172
08:23:46:WU00:FS00:0xa4:Leaving Run
08:23:50:WU00:FS00:0xa4:- Writing 1583420 bytes of core data to disk...
08:23:50:WU00:FS00:0xa4:Done: 1582908 -> 1538204 (compressed to 97.1 percent)
08:23:50:WU00:FS00:0xa4:  ... Done.
08:23:50:WU00:FS00:0xa4:- Shutting down core
08:23:50:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
08:23:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:23:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9038 run:792 clone:1 gen:2279 core:0xa4 unit:0x000009caab436c9e569829146ff9ecba
08:23:51:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
08:23:51:WU00:FS00:Connecting to 171.67.108.158:8080
08:23:51:WU01:FS00:Starting
08:23:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
08:23:51:WU01:FS00:Started FahCore on PID 37916
08:23:51:WU01:FS00:Core PID:39684
08:23:51:WU01:FS00:FahCore 0xa7 started
08:23:51:WU01:FS00:0xa7:*********************** Log Started 2019-05-13T08:23:51Z ***********************
08:23:51:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:23:51:WU01:FS00:0xa7:       Type: 0xa7
08:23:51:WU01:FS00:0xa7:       Core: Gromacs
08:23:51:WU01:FS00:0xa7:    Website: https://foldingathome.org/
08:23:51:WU01:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
08:23:51:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:23:51:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 37916 -checkpoint 15 -np
08:23:51:WU01:FS00:0xa7:             6
08:23:51:WU01:FS00:0xa7:     Config: <none>
08:23:51:WU01:FS00:0xa7:************************************ Build *************************************
08:23:51:WU01:FS00:0xa7:    Version: 0.0.17
08:23:51:WU01:FS00:0xa7:       Date: Apr 27 2018
08:23:51:WU01:FS00:0xa7:       Time: 16:19:36
08:23:51:WU01:FS00:0xa7: Repository: Git
08:23:51:WU01:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
08:23:51:WU01:FS00:0xa7:     Branch: master
08:23:51:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:23:51:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:23:51:WU01:FS00:0xa7:   Platform: win32 10
08:23:51:WU01:FS00:0xa7:       Bits: 64
08:23:51:WU01:FS00:0xa7:       Mode: Release
08:23:51:WU01:FS00:0xa7:       SIMD: avx_256
08:23:51:WU01:FS00:0xa7:************************************ System ************************************
08:23:51:WU01:FS00:0xa7:        CPU: Unknown
08:23:51:WU01:FS00:0xa7:     CPU ID:
08:23:51:WU01:FS00:0xa7:       CPUs: 8
08:23:51:WU01:FS00:0xa7:     Memory: 31.94GiB
08:23:51:WU01:FS00:0xa7:Free Memory: 18.45GiB
08:23:51:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:23:51:WU01:FS00:0xa7: OS Version: 6.2
08:23:51:WU01:FS00:0xa7:Has Battery: false
08:23:51:WU01:FS00:0xa7: On Battery: false
08:23:51:WU01:FS00:0xa7: UTC Offset: 8
08:23:51:WU01:FS00:0xa7:        PID: 39684
08:23:51:WU01:FS00:0xa7:        CWD: C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\work
08:23:51:WU01:FS00:0xa7:         OS: Windows 10 Pro
08:23:51:WU01:FS00:0xa7:    OS Arch: AMD64
08:23:51:WU01:FS00:0xa7:********************************************************************************
08:23:51:WU01:FS00:0xa7:Project: 14143 (Run 3, Clone 80, Gen 57)
08:23:51:WU01:FS00:0xa7:Unit: 0x000000420002894c5ca3a7264105bfa5
08:23:51:WU01:FS00:0xa7:Reading tar file core.xml
08:23:51:WU01:FS00:0xa7:Reading tar file frame57.tpr
08:23:51:WU01:FS00:0xa7:Digital signatures verified
08:23:51:WU01:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -cpt 15 -nt 6
08:23:51:WU01:FS00:0xa7:Steps: first=142500000 total=2500000
08:23:52:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
08:23:53:WU00:FS00:Upload complete
08:23:53:WU00:FS00:Server responded WORK_ACK (400)
08:23:53:WU00:FS00:Final credit estimate, 1490.00 points
08:23:53:WU00:FS00:Cleaning up
08:26:08:WU03:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
08:26:16:WARNING:FS01:Size of positions 2073 does not match topology 2067
08:26:57:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
08:29:54:WU01:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
08:51:30:WU03:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
08:51:37:WARNING:FS01:Size of positions 2073 does not match topology 2067
09:16:47:WU03:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
09:16:54:WARNING:FS01:Size of positions 2073 does not match topology 2067
09:18:59:WU01:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
09:21:51:WU03:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
09:21:56:WU01:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
09:24:44:WU01:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
09:26:54:WU03:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
09:28:27:WU01:FS00:0xa7:Completed 525000 out of 2500000 steps (21%)
09:31:32:WU01:FS00:0xa7:Completed 550000 out of 2500000 steps (22%)
09:31:57:WU03:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
09:34:30:WU01:FS00:0xa7:Completed 575000 out of 2500000 steps (23%)
09:36:58:WU03:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
09:36:59:WU00:FS01:Connecting to 65.254.110.245:8080
09:37:00:WU00:FS01:Assigned to work server 140.163.4.231
09:37:00:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
09:37:00:WU00:FS01:Connecting to 140.163.4.231:8080
09:37:00:WU00:FS01:Downloading 25.28MiB
09:37:06:WU00:FS01:Download 58.60%
09:37:10:WU00:FS01:Download complete
09:37:10:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11718 run:0 clone:791 gen:344 core:0x21 unit:0x000001d18ca304e75b846ad6e023c163
09:37:31:WU01:FS00:0xa7:Completed 600000 out of 2500000 steps (24%)
09:40:47:WU01:FS00:0xa7:Completed 625000 out of 2500000 steps (25%)
09:42:05:WU03:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
09:42:07:WU03:FS01:0x21:Saving result file logfile_01.txt
09:42:07:WU03:FS01:0x21:Saving result file checkpointState.xml
09:42:07:WU03:FS01:0x21:Saving result file checkpt.crc
09:42:07:WU03:FS01:0x21:Saving result file log.txt
09:42:07:WU03:FS01:0x21:Saving result file positions.xtc
09:42:08:WU03:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
09:42:08:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:42:08:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:11719 run:0 clone:1437 gen:403 core:0x21 unit:0x000002158ca304e75b8990ac2137b64e
09:42:08:WU03:FS01:Uploading 13.41MiB to 140.163.4.231
09:42:08:WU03:FS01:Connecting to 140.163.4.231:8080
09:42:08:WU00:FS01:Starting
09:42:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:42:08:WU00:FS01:Started FahCore on PID 40860
09:42:08:WU00:FS01:Core PID:37028
09:42:08:WU00:FS01:FahCore 0x21 started
09:42:09:WU00:FS01:0x21:*********************** Log Started 2019-05-13T09:42:08Z ***********************
09:42:09:WU00:FS01:0x21:Project: 11718 (Run 0, Clone 791, Gen 344)
09:42:09:WU00:FS01:0x21:Unit: 0x000001d18ca304e75b846ad6e023c163
09:42:09:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:42:09:WU00:FS01:0x21:Machine: 1
09:42:09:WU00:FS01:0x21:Reading tar file core.xml
09:42:09:WU00:FS01:0x21:Reading tar file integrator.xml
09:42:09:WU00:FS01:0x21:Reading tar file state.xml
09:42:09:WU00:FS01:0x21:Reading tar file system.xml
09:42:09:WU00:FS01:0x21:Digital signatures verified
09:42:09:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:42:09:WU00:FS01:0x21:Version 0.0.18
09:42:19:WU03:FS01:Upload 22.37%
09:42:22:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
09:42:22:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:43:12:WU03:FS01:Upload 97.40%
09:43:19:WU03:FS01:Cleaning up
09:43:57:WU01:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
09:47:08:WU01:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
09:48:32:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
10:00:22:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
10:00:22:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
10:00:22:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
10:00:22:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
10:00:22:WU01:FS00:Starting
10:00:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -np 6
10:00:22:WU01:FS00:Started FahCore on PID 39500
10:00:22:WU01:FS00:FahCore 0xa7 started
10:00:22:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:00:22:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
10:00:22:WU00:FS01:Starting
10:00:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\FELIX CHIA\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 25792 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:00:22:WU00:FS01:Started FahCore on PID 40948
10:00:22:WU00:FS01:FahCore 0x21 started
10:00:23:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
10:00:23:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
Re: No points credited when GPU completes WU
I checked the logs, the GPU WU's shown as being completed have all been credited:
Hi dy047awasyss (team 234980), Your WU (P11718 R0 C791 G344) was added to the stats database on Wed, 15 May 2019 05:26:02 GMT for 15047 points of credit.
Hi dy047awasyss (team 234980), Your WU (P11719 R0 C845 G288) was added to the stats database on Wed, 15 May 2019 05:26:02 GMT for 1236.8 points of credit.
Hi dy047awasyss (team 234980), Your WU (P11720 R0 C2194 G137) was added to the stats database on Wed, 15 May 2019 05:26:02 GMT for 4879 points of credit.
Hi dy047awasyss (team 234980), Your WU (P11719 R0 C1437 G403) was added to the stats database on Wed, 15 May 2019 05:26:02 GMT for 12368 points of credit.
All received the base credit as you have not yet completed and returned 10 WU's yet. There was a few hours delay from the time each WU was recorded as returned until entered into the database, not sure of the cause for that. Once you have returned 10 WU's, then your username and passkey will be qualified to receive the Quick Return Bonus (QRB).
felixbunny
Post by felixbunny »
Joe_H wrote:I checked the logs, the GPU WU's shown as being completed have all been credited:
Thanks for checking!
Is there a reason why the amount credited is so different from the estimate? The total for the 4 Work Units is lesser than the estimate of 1 Work Unit. Also, the estimated for the work units for the GPU as seen from the client that I see is about 40k - 60k per work unit or is this not accurate.
Your software does not know you have not yet returned 10 Work Units*, so it is estimating a Quick Return Bonus you will only be eligible for once you have returned 10 WUs.
*You might have more than one PC, so it can't just count WUs on this PC for the QRB.
felixbunny
JimboPalmer wrote:Your software does not know you have not yet returned 10 Work Units*, so it is estimating a Quick Return Bonus you will only be eligible for once you have returned 10 WUs.
Hi, thanks for your reply.
Is the Quick return bonus that substantial? From your experience, what is the % difference between the base rate vs the base rate + quick return bonus?
Thanks!
Yes, the QRB can be that substantial. The formula is nonlinear, the faster a WU is returned the greater the bonus.
felixbunny
Joe_H wrote:Yes, the QRB can be that substantial. The formula is nonlinear, the faster a WU is returned the greater the bonus.
Hi Joe, thanks for your reply.
Will keep track and see if the points improve. Thanks!
After you exceed your first 10 passkey-enabled WUs, you will NOT want to suspend processing for an extra day. That extra day of wasted time will reduce the QRB quite significantly because the server tracks the actual download time and upload time. Holding a WU for 1.88 days will earn a MUCH smaller QuickReturnBonus than if you actually return it to the server one hour after you download it.
After a WU has been returned, you can check on its results here: https://apps.foldingathome.org/wu (though as Joe said, not necessarily immediately).
felixbunny
bruce wrote:After you exceed your first 10 passkey-enabled WUs, you will NOT want to suspend processing for an extra day. That extra day of wasted time will reduce the QRB quite significantly because the server tracks the actual download time and upload time. Holding a WU for 1.88 days will earn a MUCH smaller QuickReturnBonus than if you actually return it to the server one hour after you download it.
Thanks for the tip, Bruce.
Will take note of this. Thanks!
Is the Quick Return Bonus that substantial? From your experience, what is the % difference between the base rate vs the base rate + quick return bonus?
That will vary with the speed of your Graphics card. My GTX 1060 gets 3 times the points my GTX 1050ti does, while being less than twice as powerful.
F@H really likes quick returns!
Your GTX 960 may be withing 10% of my GTX 1050ti, about 140,000 Points Per Day.
MeeLee
Post by MeeLee »
The bonus is basically how people make higher scores. With modern cards, the bonus is higher than the actual base points of the WU.
