Yet another GPU problem...[Unsuipported]
Tea_and_Biology
Post by Tea_and_Biology »
Hey all!
I'm having trouble getting the client to recognise my GPU, with the "On client "local" 127.0.0.1:36330: No available GPUs" message when attempting to save a GPU slot. It's an Intel® UHD Graphics 630 (Coffeelake 3x8 GT2), running on Ubuntu 18.04.2 LTS.
*********************** Log Started 2019-05-07T12:34:51Z ***********************
12:34:51:************************* Folding@home Client *************************
12:34:51:    Website: https://foldingathome.org/
12:34:51:  Copyright: (c) 2009-2018 foldingathome.org
12:34:51:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:34:51:       Args: --child --lifeline 1300 /etc/fahclient/config.xml --run-as
12:34:51:             fahclient --pid-file=/var/run/fahclient.pid --daemon
12:34:51:     Config: /etc/fahclient/config.xml
12:34:51:******************************** Build ********************************
12:34:51:    Version: 7.5.1
12:34:51:       Date: May 11 2018
12:34:51:       Time: 19:59:04
12:34:51: Repository: Git
12:34:51:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:34:51:     Branch: master
12:34:51:   Compiler: GNU 6.3.0 20170516
12:34:51:    Options: -std=gnu++98 -O3 -funroll-loops
12:34:51:   Platform: linux2 4.14.0-3-amd64
12:34:51:       Bits: 64
12:34:51:       Mode: Release
12:34:51:******************************* System ********************************
12:34:51:        CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
12:34:51:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:34:51:       CPUs: 12
12:34:51:     Memory: 15.46GiB
12:34:51:Free Memory: 14.75GiB
12:34:51:    Threads: POSIX_THREADS
12:34:51: OS Version: 4.15
12:34:51:Has Battery: false
12:34:51: On Battery: false
12:34:51: UTC Offset: 1
12:34:51:        PID: 1302
12:34:51:        CWD: /var/lib/fahclient
12:34:51:         OS: Linux 4.15.0-48-generic x86_64
12:34:51:    OS Arch: AMD64
12:34:51:       GPUs: 0
12:34:51:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
12:34:51:             libcuda.so: cannot open shared object file: No such file or
12:34:51:             directory
12:34:51:     OpenCL: Not detected: clGetPlatformIDs() returned -1001
12:34:51:***********************************************************************
12:34:51:<config>
12:34:51:  <!-- Client Control -->
12:34:51:  <fold-anon v='true'/>
12:34:51:
12:34:51:  <!-- Folding Slot Configuration -->
12:34:51:  <gpu v='false'/>
12:34:51:
12:34:51:  <!-- Network -->
12:34:51:  <proxy v=':8080'/>
12:34:51:
12:34:51:  <!-- User Information -->
12:34:51:  <passkey v='********************************'/>
12:34:51:  <team v='234980'/>
12:34:51:  <user v='etlkcw0yp4wg'/>
12:34:51:
12:34:51:  <!-- Folding Slots -->
12:34:51:  <slot id='0' type='CPU'/>
12:34:51:</config>
12:34:51:Switching to user fahclient
12:34:51:Trying to access database...
12:34:51:Successfully acquired database lock
12:34:51:Enabled folding slot 00: READY cpu:11
12:34:51:WU00:FS00:Starting
12:34:51:WARNING:WU00:FS00:AS lowered CPUs from 11 to 10
12:34:51:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1302 -checkpoint 15 -np 10
12:34:51:WU00:FS00:Started FahCore on PID 1318
12:34:51:WU00:FS00:Core PID:1322
12:34:51:WU00:FS00:FahCore 0xa7 started
12:34:51:WU00:FS00:0xa7:*********************** Log Started 2019-05-07T12:34:51Z ***********************
12:34:51:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:34:51:WU00:FS00:0xa7:       Type: 0xa7
12:34:51:WU00:FS00:0xa7:       Core: Gromacs
12:34:51:WU00:FS00:0xa7:    Website: https://foldingathome.org/
12:34:51:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:34:51:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:34:51:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1318 -checkpoint 15 -np
12:34:51:WU00:FS00:0xa7:             10
12:34:51:WU00:FS00:0xa7:     Config: <none>
12:34:51:WU00:FS00:0xa7:************************************ Build *************************************
12:34:51:WU00:FS00:0xa7:    Version: 0.0.17
12:34:51:WU00:FS00:0xa7:       Date: Apr 27 2018
12:34:51:WU00:FS00:0xa7:       Time: 19:09:21
12:34:51:WU00:FS00:0xa7: Repository: Git
12:34:51:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
12:34:51:WU00:FS00:0xa7:     Branch: master
12:34:51:WU00:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
12:34:51:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
12:34:51:WU00:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
12:34:51:WU00:FS00:0xa7:       Bits: 64
12:34:51:WU00:FS00:0xa7:       Mode: Release
12:34:51:WU00:FS00:0xa7:       SIMD: avx_256
12:34:51:WU00:FS00:0xa7:************************************ System ************************************
12:34:51:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
12:34:51:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:34:51:WU00:FS00:0xa7:       CPUs: 12
12:34:51:WU00:FS00:0xa7:     Memory: 15.46GiB
12:34:51:WU00:FS00:0xa7:Free Memory: 14.75GiB
12:34:51:WU00:FS00:0xa7:    Threads: POSIX_THREADS
12:34:51:WU00:FS00:0xa7: OS Version: 4.15
12:34:51:WU00:FS00:0xa7:Has Battery: false
12:34:51:WU00:FS00:0xa7: On Battery: false
12:34:51:WU00:FS00:0xa7: UTC Offset: 1
12:34:51:WU00:FS00:0xa7:        PID: 1322
12:34:51:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
12:34:51:WU00:FS00:0xa7:         OS: Linux 4.15.0-48-generic x86_64
12:34:51:WU00:FS00:0xa7:    OS Arch: AMD64
12:34:51:WU00:FS00:0xa7:********************************************************************************
12:34:51:WU00:FS00:0xa7:Project: 14153 (Run 14, Clone 302, Gen 89)
12:34:51:WU00:FS00:0xa7:Unit: 0x000000690002894b5c6e8ef5ba4a5631
12:34:51:WU00:FS00:0xa7:Digital signatures verified
12:34:51:WU00:FS00:0xa7:Calling: mdrun -s frame89.tpr -o frame89.trr -cpi state.cpt -cpt 15 -nt 10
12:34:51:WU00:FS00:0xa7:Steps: first=445000000 total=5000000
12:34:51:WU00:FS00:0xa7:Completed 94542 out of 5000000 steps (1%)
12:35:05:WU00:FS00:0xa7:Completed 100000 out of 5000000 steps (2%)
12:35:19:Saving configuration to /etc/fahclient/config.xml
12:35:19:<config>
12:35:19:  <!-- Client Control -->
12:35:19:  <fold-anon v='true'/>
12:35:19:
12:35:19:  <!-- Folding Slot Configuration -->
12:35:19:  <gpu v='false'/>
12:35:19:
12:35:19:  <!-- Network -->
12:35:19:  <proxy v=':8080'/>
12:35:19:
12:35:19:  <!-- User Information -->
12:35:19:  <passkey v='********************************'/>
12:35:19:  <team v='234980'/>
12:35:19:  <user v='etlkcw0yp4wg'/>
12:35:19:
12:35:19:  <!-- Folding Slots -->
12:35:19:  <slot id='0' type='CPU'/>
12:35:19:</config>
12:39:44:Saving configuration to /etc/fahclient/config.xml
12:39:44:<config>
12:39:44:  <!-- Client Control -->
12:39:44:  <fold-anon v='true'/>
12:39:44:
12:39:44:  <!-- Folding Slot Configuration -->
12:39:44:  <gpu v='false'/>
12:39:44:
12:39:44:  <!-- Network -->
12:39:44:  <proxy v=':8080'/>
12:39:44:
12:39:44:  <!-- User Information -->
12:39:44:  <passkey v='********************************'/>
12:39:44:  <team v='234980'/>
12:39:44:  <user v='etlkcw0yp4wg'/>
12:39:44:
12:39:44:  <!-- Folding Slots -->
12:39:44:  <slot id='0' type='CPU'/>
12:39:44:</config>
12:40:06:Saving configuration to /etc/fahclient/config.xml
12:40:06:<config>
12:40:06:  <!-- Client Control -->
12:40:06:  <fold-anon v='true'/>
12:40:06:
12:40:06:  <!-- Folding Slot Configuration -->
12:40:06:  <gpu v='false'/>
12:40:06:
12:40:06:  <!-- Network -->
12:40:06:  <proxy v=':8080'/>
12:40:06:
12:40:06:  <!-- User Information -->
12:40:06:  <passkey v='********************************'/>
12:40:06:  <team v='234980'/>
12:40:06:  <user v='etlkcw0yp4wg'/>
12:40:06:
12:40:06:  <!-- Folding Slots -->
12:40:06:  <slot id='0' type='CPU'/>
12:40:06:</config>
sudo lspci -v gives me the following, if it's of any use:
00:02.0 VGA compatible controller: Intel Corporation Device 3e92 (prog-if 00 [VGA controller])
	Subsystem: Dell Device 085a
	Flags: bus master, fast devsel, latency 0, IRQ 140
	Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
	Memory at 80000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 3000 [size=64]
	[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
	Capabilities: [40] Vendor Specific Information: Len=0c <?>
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [100] Process Address Space ID (PASID)
	Capabilities: [200] Address Translation Service (ATS)
	Capabilities: [300] Page Request Interface (PRI)
	Kernel driver in use: i915
	Kernel modules: i915
Likewise, trying to check/update/reinstall my drivers via the Intel Graphics Installer app gives me a "distribution not supported" error.
Any help, or poke in the right direction, would be immensely helpful, and very much appreciated. Thanks!
Re: Yet another GPU problem...[Unsuipported]
Intel GPU's are unsupported, and there is no plan to support them at this time. Supported GPU's are from AMD or nVidia, and currently projects require mixed precision support.
