99.99% WU
Be_eLSeven
99.99% WU
i fold using latest version on my AMD GPUs (WIN10) but can't reach 100%, stucked at 99.99% ETA 1-4 seconds.
i've uninstalled and resinstalled, but still face that issue.
any ideas how to fix it?
thanks
thanks
Re: 99.99% WU
As I'm sure you already know, something has gone wrong.
Please post the beginning couple of pages from your log (see below) and the last segment.
Unfortunately, the current WU is NOT at 99.99% done. It stopped some time earlier but that was not detected by the code that estimates the time to completion. (It keeps estimating progress, even when that isn't happening.)
You can also help by selecting the "log" tab in FAHControl and selecting the Warning and Errors filter and read the last message(s) reported.
Then PAUSE the WU, wait a few seconds, and select FOLD. Go back to viewing the Warnings and Errors and see if anything changed.
Be_eLSeven
Re: 99.99% WU
*********************** Log Started 2019-05-02T14:34:08Z ***********************
14:34:09:************************* Folding@home Client *************************
14:34:09: Website: https://foldingathome.org/
14:34:09: Copyright: (c) 2009-2018 foldingathome.org
14:34:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:34:09: Args: --open-web-control
14:34:09: Config: <none>
14:34:09:******************************** Build ********************************
14:34:09: Version: 7.5.1
14:34:09: Date: May 11 2018
14:34:09: Time: 13:06:32
14:34:09: Repository: Git
14:34:09: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:34:09: Branch: master
14:34:09: Compiler: Visual C++ 2008
14:34:09: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:34:09: Platform: win32 10
14:34:09: Bits: 32
14:34:09: Mode: Release
14:34:09:******************************* System ********************************
14:34:09: CPU: Intel(R) Pentium(R) CPU G4400 @ 3.30GHz
14:34:09: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
14:34:09: CPUs: 2
14:34:09: Memory: 7.89GiB
14:34:09: Free Memory: 4.99GiB
14:34:09: Threads: WINDOWS_THREADS
14:34:09: OS Version: 6.2
14:34:09: Has Battery: false
14:34:09: On Battery: false
14:34:09: UTC Offset: 7
14:34:09: PID: 8516
14:34:09: CWD: C:\Users\Be_eLSeven\AppData\Roaming\FAHClient
14:34:09: OS: Windows 10 Pro
14:34:09: OS Arch: AMD64
14:34:09: GPUs: 0
14:34:09: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:34:09: specified module could not be found.
14:34:09:
14:34:09:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
14:34:09:OpenCL Device 2: Platform:1 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:2580.6
14:34:09:OpenCL Device 3: Platform:1 Device:1 Bus:5 Slot:0 Compute:1.2 Driver:2580.6
14:34:09:OpenCL Device 4: Platform:1 Device:2 Bus:13 Slot:0 Compute:1.2 Driver:2580.6
14:34:09:OpenCL Device 5: Platform:1 Device:3 Bus:4 Slot:0 Compute:1.2 Driver:2580.6
14:34:09:OpenCL Device 6: Platform:1 Device:4 Bus:1 Slot:0 Compute:1.2 Driver:2580.6
14:34:09:OpenCL Device 7: Platform:1 Device:5 Bus:12 Slot:0 Compute:1.2 Driver:2580.6
14:34:09: Win32 Service: false
14:34:09:***********************************************************************
14:34:09:<config>
14:34:09: <!-- Folding Slots -->
14:34:09:</config>
14:34:09:Connecting to assign1.foldingathome.org:8080
14:34:10:Updated GPUs.txt
14:34:10:Read GPUs.txt
14:34:10:Trying to access database...
14:34:10:Successfully acquired database lock
14:34:10:Enabled folding slot 00: PAUSED cpu:1 (not configured)
14:34:10:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:10:Enabled folding slot 02: PAUSED gpu:1:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:10:Enabled folding slot 03: PAUSED gpu:2:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:10:Enabled folding slot 04: PAUSED gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:10:Enabled folding slot 05: PAUSED gpu:4:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:10:Enabled folding slot 06: PAUSED gpu:5:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
14:34:15:10:127.0.0.1:New Web connection
14:35:11:Saving configuration to config.xml
14:35:11:<config>
14:35:11: <!-- Folding Slots -->
14:35:11: <slot id='0' type='CPU'/>
14:35:11: <slot id='1' type='GPU'/>
14:35:11: <slot id='2' type='GPU'/>
14:35:11: <slot id='3' type='GPU'/>
14:35:11: <slot id='4' type='GPU'/>
14:35:11: <slot id='5' type='GPU'/>
14:35:11: <slot id='6' type='GPU'/>
14:35:11:</config>
14:35:11:Set client configured
14:35:11:WU00:FS00:Connecting to 65.254.110.245:8080
14:35:11:WU01:FS01:Connecting to 65.254.110.245:8080
14:35:11:WU02:FS02:Connecting to 65.254.110.245:8080
14:35:12:WU03:FS03:Connecting to 65.254.110.245:8080
14:35:12:WU00:FS00:Connecting to 65.254.110.245:8080
14:35:12:WU04:FS04:Connecting to 65.254.110.245:8080
14:35:12:WU01:FS01:Connecting to 65.254.110.245:8080
14:35:12:WU05:FS05:Connecting to 65.254.110.245:8080
14:35:12:WU02:FS02:Connecting to 65.254.110.245:8080
14:35:13:WU03:FS03:Connecting to 65.254.110.245:8080
14:35:13:WU01:FS01:Assigned to work server 155.247.166.220
14:35:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
14:35:13:WU04:FS04:Assigned to work server 155.247.166.220
14:35:13:WU01:FS01:Connecting to 155.247.166.220:8080
14:35:13:WU04:FS04:Requesting new work unit for slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
14:35:13:WU04:FS04:Connecting to 155.247.166.220:8080
14:35:13:WU00:FS00:Assigned to work server 128.252.203.9
14:35:13:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 128.252.203.9
14:35:13:WU00:FS00:Connecting to 128.252.203.9:8080
14:35:13:WU05:FS05:Assigned to work server 140.163.4.231
14:35:13:WU05:FS05:Requesting new work unit for slot 05: READY gpu:4:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
14:35:13:WU05:FS05:Connecting to 140.163.4.231:8080
14:35:13:WU02:FS02:Assigned to work server 155.247.166.220
14:35:13:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
14:35:13:WU02:FS02:Connecting to 155.247.166.220:8080
14:35:14:WU03:FS03:Assigned to work server 140.163.4.231
14:35:14:WU03:FS03:Requesting new work unit for slot 03: READY gpu:2:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
14:35:14:WU03:FS03:Connecting to 140.163.4.231:8080
14:35:14:WU00:FS00:Downloading 8.14MiB
14:35:14:WU05:FS05:Downloading 19.84MiB
14:35:15:WU03:FS03:Downloading 20.07MiB
14:35:15:WU04:FS04:Downloading 1.12MiB
14:35:15:WU01:FS01:Downloading 1.12MiB
14:35:15:WU02:FS02:Downloading 884.06KiB
14:35:20:WU05:FS05:Download 4.10%
14:35:20:WU00:FS00:Download 46.05%
14:35:21:WU04:FS04:Download 11.14%
14:35:21:WU03:FS03:Download 2.80%
14:35:21:WU01:FS01:Download 16.70%
14:35:21:WU02:FS02:Download 21.72%
14:35:24:WU00:FS00:Download complete
14:35:24:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13825 run:292 clone:1 gen:10 core:0xa7 unit:0x0000000a80fccb095c9565bc99ddf322
14:35:24:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a7.fah
14:35:24:WU00:FS00:Connecting to cores.foldingathome.org:80
14:35:25:WU00:FS00:FahCore a7: Downloading 6.64MiB
14:35:26:WU05:FS05:Download 18.27%
14:35:27:WU04:FS04:Download 55.72%
14:35:27:WU03:FS03:Download 9.34%
14:35:27:WU01:FS01:Download 50.10%
14:35:28:WU02:FS02:Download 50.68%
14:35:32:WU05:FS05:Download 45.69%
14:35:33:WU04:FS04:Download 100.00%
14:35:33:WU04:FS04:Download complete
14:35:33:WU04:FS04:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:14179 run:32 clone:13 gen:7 core:0x21 unit:0x0000000d0002894c5cb387427e561a11
14:35:33:WU04:FS04:Downloading core from http://cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah
14:35:33:WU04:FS04:Connecting to cores.foldingathome.org:80
14:35:33:WU01:FS01:Download 83.50%
14:35:33:WU03:FS03:Download 18.68%
14:35:33:WU04:FS04:FahCore 21: Downloading 3.48MiB
14:35:34:WU02:FS02:Download 86.87%
14:35:37:WU01:FS01:Download complete
14:35:37:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14179 run:19 clone:4 gen:6 core:0x21 unit:0x0000000b0002894c5cb38732aa09168d
14:35:37:WU06:FS06:Connecting to 65.254.110.245:8080
14:35:38:WU05:FS05:Download 94.21%
14:35:38:WU02:FS02:Download complete
14:35:38:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14127 run:16 clone:2 gen:191 core:0x21 unit:0x000000ee0002894c5c06fbd3ad67a1b8
14:35:38:WU05:FS05:Download complete
14:35:38:WU05:FS05:Received Unit: id:05 state:DOWNLOAD error:NO_ERROR project:11726 run:0 clone:1136 gen:312 core:0x21 unit:0x000001a48ca304e75b95ba15d00cfff2
14:35:39:WU04:FS04:FahCore 21: 5.39%
14:35:40:WU00:FS00:FahCore a7: 5.65%
14:35:40:WU03:FS03:Download 22.73%
14:35:41:WU06:FS06:Assigned to work server 140.163.4.231
14:35:41:WU06:FS06:Requesting new work unit for slot 06: READY gpu:5:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
14:35:41:WU06:FS06:Connecting to 140.163.4.231:8080
14:35:42:WU06:FS06:Downloading 14.57MiB
14:35:45:WU04:FS04:FahCore 21: 32.36%
14:35:46:WU03:FS03:Download 51.37%
14:35:46:WU00:FS00:FahCore a7: 21.65%
14:35:48:WU06:FS06:Download 6.86%
14:35:51:WU04:FS04:FahCore 21: 48.54%
14:35:52:WU03:FS03:Download 65.39%
14:35:52:WU00:FS00:FahCore a7: 32.00%
14:35:54:WU06:FS06:Download 28.32%
14:35:57:WU04:FS04:FahCore 21: 95.28%
14:35:57:WU04:FS04:FahCore 21: Download complete
14:35:57:WU04:FS04:Valid core signature
14:35:57:WU04:FS04:Unpacked 11.81MiB to cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe
14:35:57:WU04:FS04:Starting
14:35:57:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 04 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 4 -gpu 4
14:35:57:WU04:FS04:Started FahCore on PID 8432
14:35:58:WU00:FS00:FahCore a7: 55.53%
14:35:58:WU03:FS03:Download 81.26%
14:35:59:WU04:FS04:Core PID:7176
14:35:59:WU04:FS04:FahCore 0x21 started
14:36:00:WU05:FS05:Starting
14:36:00:WU05:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 05 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 5 -gpu 5
14:36:00:WU05:FS05:Started FahCore on PID 7516
14:36:00:WU05:FS05:Core PID:1872
14:36:00:WU05:FS05:FahCore 0x21 started
14:36:00:WU01:FS01:Starting
14:36:00:WU04:FS04:0x21:*********************** Log Started 2019-05-02T14:36:00Z ***********************
14:36:00:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 3 -gpu 3
14:36:00:WU04:FS04:0x21:Project: 14179 (Run 32, Clone 13, Gen 7)
14:36:00:WU04:FS04:0x21:Unit: 0x0000000d0002894c5cb387427e561a11
14:36:00:WU01:FS01:Started FahCore on PID 6724
14:36:00:WU04:FS04:0x21:CPU: 0x00000000000000000000000000000000
14:36:00:WU04:FS04:0x21:Machine: 4
14:36:00:WU04:FS04:0x21:Reading tar file core.xml
14:36:00:WU04:FS04:0x21:Reading tar file integrator.xml
14:36:00:WU04:FS04:0x21:Reading tar file state.xml
14:36:00:WU04:FS04:0x21:Reading tar file system.xml
14:36:00:WU05:FS05:0x21:*********************** Log Started 2019-05-02T14:36:00Z ***********************
14:36:00:WU05:FS05:0x21:Project: 11726 (Run 0, Clone 1136, Gen 312)
14:36:00:WU05:FS05:0x21:Unit: 0x000001a48ca304e75b95ba15d00cfff2
14:36:00:WU05:FS05:0x21:CPU: 0x00000000000000000000000000000000
14:36:00:WU05:FS05:0x21:Machine: 5
14:36:00:WU05:FS05:0x21:Reading tar file core.xml
14:36:00:WU05:FS05:0x21:Reading tar file integrator.xml
14:36:00:WU05:FS05:0x21:Reading tar file state.xml
14:36:00:WU05:FS05:0x21:Reading tar file system.xml
14:36:00:WU05:FS05:0x21:Digital signatures verified
14:36:00:WU05:FS05:0x21:Folding@home GPU Core21 Folding@home Core
14:36:00:WU05:FS05:0x21:Version 0.0.18
14:36:00:WU06:FS06:Download 33.47%
14:36:01:WU01:FS01:Core PID:7568
14:36:01:WU01:FS01:FahCore 0x21 started
14:36:01:WU04:FS04:0x21:Digital signatures verified
14:36:01:WU04:FS04:0x21:Folding@home GPU Core21 Folding@home Core
14:36:01:WU04:FS04:0x21:Version 0.0.18
14:36:01:WU02:FS02:Starting
14:36:01:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 2 -gpu 2
14:36:01:WU02:FS02:Started FahCore on PID 5212
14:36:01:WU02:FS02:Core PID:2372
14:36:01:WU02:FS02:FahCore 0x21 started
14:36:01:WU01:FS01:0x21:*********************** Log Started 2019-05-02T14:36:01Z ***********************
14:36:01:WU01:FS01:0x21:Project: 14179 (Run 19, Clone 4, Gen 6)
14:36:01:WU01:FS01:0x21:Unit: 0x0000000b0002894c5cb38732aa09168d
14:36:01:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:36:01:WU01:FS01:0x21:Machine: 1
14:36:01:WU01:FS01:0x21:Reading tar file core.xml
14:36:01:WU01:FS01:0x21:Reading tar file integrator.xml
14:36:01:WU01:FS01:0x21:Reading tar file state.xml
14:36:01:WU01:FS01:0x21:Reading tar file system.xml
14:36:01:WU01:FS01:0x21:Digital signatures verified
14:36:02:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:36:02:WU01:FS01:0x21:Version 0.0.18
14:36:02:WU02:FS02:0x21:*********************** Log Started 2019-05-02T14:36:01Z ***********************
14:36:02:WU02:FS02:0x21:Project: 14127 (Run 16, Clone 2, Gen 191)
14:36:02:WU02:FS02:0x21:Unit: 0x000000ee0002894c5c06fbd3ad67a1b8
14:36:02:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
14:36:02:WU02:FS02:0x21:Machine: 2
14:36:02:WU02:FS02:0x21:Reading tar file core.xml
14:36:02:WU02:FS02:0x21:Reading tar file integrator.xml
14:36:02:WU02:FS02:0x21:Reading tar file state.xml
14:36:02:WU02:FS02:0x21:Reading tar file system.xml
14:36:02:WU02:FS02:0x21:Digital signatures verified
14:36:03:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
14:36:03:WU02:FS02:0x21:Version 0.0.18
14:36:04:WU00:FS00:FahCore a7: 73.41%
14:36:04:WU03:FS03:Download 83.44%
14:36:06:WU06:FS06:Download 44.19%
14:36:10:WU03:FS03:Download 91.54%
14:36:10:WU00:FS00:FahCore a7: 96.94%
14:36:11:WU00:FS00:FahCore a7: Download complete
14:36:12:WU00:FS00:Valid core signature
14:36:12:WU00:FS00:Unpacked 18.40MiB to cores/cores.foldingathome.org/Win32/AMD64/Core_a7.fah/FahCore_a7.exe
14:36:12:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/Win32/AMD64/Core_a7.fah/libfftw3f-3.dll
14:36:12:WU06:FS06:Download 59.21%
14:36:12:WU03:FS03:Download complete
14:36:12:WU00:FS00:Starting
14:36:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -np 1
14:36:12:WU00:FS00:Started FahCore on PID 6796
14:36:14:WU00:FS00:Core PID:7484
14:36:14:WU00:FS00:FahCore 0xa7 started
14:36:15:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:142 gen:368 core:0x21 unit:0x000001e08ca304e75b78c2e95d1b74ee
14:36:15:WU03:FS03:Starting
14:36:15:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
14:36:15:WU03:FS03:Started FahCore on PID 2836
14:36:16:WU03:FS03:Core PID:7912
14:36:16:WU03:FS03:FahCore 0x21 started
14:36:16:WU00:FS00:0xa7:*********************** Log Started 2019-05-02T14:36:15Z ***********************
14:36:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:36:16:WU00:FS00:0xa7: Type: 0xa7
14:36:16:WU00:FS00:0xa7: Core: Gromacs
14:36:16:WU00:FS00:0xa7: Website: https://foldingathome.org/
14:36:16:WU00:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
14:36:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:36:16:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6796 -checkpoint 15 -np 1
14:36:16:WU00:FS00:0xa7: Config: <none>
14:36:16:WU00:FS00:0xa7:************************************ Build *************************************
14:36:16:WU00:FS00:0xa7: Version: 0.0.17
14:36:16:WU00:FS00:0xa7: Date: Apr 27 2018
14:36:16:WU00:FS00:0xa7: Time: 16:19:35
14:36:16:WU00:FS00:0xa7: Repository: Git
14:36:16:WU00:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
14:36:16:WU00:FS00:0xa7: Branch: master
14:36:16:WU00:FS00:0xa7: Compiler: Visual C++ 2008
14:36:16:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:36:16:WU00:FS00:0xa7: Platform: win32 10
14:36:16:WU00:FS00:0xa7: Bits: 64
14:36:16:WU00:FS00:0xa7: Mode: Release
14:36:16:WU00:FS00:0xa7: SIMD: sse2
14:36:16:WU00:FS00:0xa7:************************************ System ************************************
14:36:16:WU00:FS00:0xa7: CPU: Unknown
14:36:16:WU00:FS00:0xa7: CPU ID:
14:36:16:WU00:FS00:0xa7: CPUs: 2
14:36:16:WU00:FS00:0xa7: Memory: 7.89GiB
14:36:16:WU00:FS00:0xa7:Free Memory: 4.49GiB
14:36:16:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
14:36:16:WU00:FS00:0xa7: OS Version: 6.2
14:36:16:WU00:FS00:0xa7:Has Battery: false
14:36:16:WU00:FS00:0xa7: On Battery: false
14:36:16:WU00:FS00:0xa7: UTC Offset: 7
14:36:16:WU00:FS00:0xa7: PID: 7484
14:36:16:WU00:FS00:0xa7: CWD: C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\work
14:36:16:WU00:FS00:0xa7: OS: Windows 10 Pro
14:36:16:WU00:FS00:0xa7: OS Arch: AMD64
14:36:16:WU00:FS00:0xa7:********************************************************************************
14:36:16:WU00:FS00:0xa7:Project: 13825 (Run 292, Clone 1, Gen 10)
14:36:16:WU00:FS00:0xa7:Unit: 0x0000000a80fccb095c9565bc99ddf322
14:36:16:WU00:FS00:0xa7:Reading tar file core.xml
14:36:16:WU00:FS00:0xa7:Reading tar file frame10.tpr
14:36:16:WU00:FS00:0xa7:Digital signatures verified
14:36:16:WU00:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -x frame10.xtc -cpt 15 -nt 1
14:36:16:WU00:FS00:0xa7:Steps: first=1250000 total=125000
14:36:16:WU03:FS03:0x21:*********************** Log Started 2019-05-02T14:36:16Z ***********************
14:36:16:WU03:FS03:0x21:Project: 11719 (Run 0, Clone 142, Gen 368)
14:36:16:WU03:FS03:0x21:Unit: 0x000001e08ca304e75b78c2e95d1b74ee
14:36:16:WU03:FS03:0x21:CPU: 0x00000000000000000000000000000000
14:36:16:WU03:FS03:0x21:Machine: 3
14:36:16:WU03:FS03:0x21:Reading tar file core.xml
14:36:16:WU03:FS03:0x21:Reading tar file integrator.xml
14:36:16:WU03:FS03:0x21:Reading tar file state.xml
14:36:16:WU03:FS03:0x21:Reading tar file system.xml
14:36:16:WU03:FS03:0x21:Digital signatures verified
14:36:16:WU03:FS03:0x21:Folding@home GPU Core21 Folding@home Core
14:36:16:WU03:FS03:0x21:Version 0.0.18
14:36:19:WU06:FS06:Download 83.66%
14:36:22:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
14:36:23:WU06:FS06:Download complete
14:36:23:WU06:FS06:Received Unit: id:06 state:DOWNLOAD error:NO_ERROR project:11728 run:0 clone:240 gen:486 core:0x21 unit:0x000002918ca304e75b95bb388b572bf3
14:36:23:WU06:FS06:Starting
14:36:23:WU06:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 06 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -gpu 1
14:36:23:WU06:FS06:Started FahCore on PID 5316
14:36:24:WU06:FS06:Core PID:4696
14:36:24:WU06:FS06:FahCore 0x21 started
14:36:24:WU06:FS06:0x21:*********************** Log Started 2019-05-02T14:36:24Z ***********************
14:36:24:WU06:FS06:0x21:Project: 11728 (Run 0, Clone 240, Gen 486)
14:36:24:WU06:FS06:0x21:Unit: 0x000002918ca304e75b95bb388b572bf3
14:36:24:WU06:FS06:0x21:CPU: 0x00000000000000000000000000000000
14:36:24:WU06:FS06:0x21:Machine: 6
14:36:24:WU06:FS06:0x21:Reading tar file core.xml
14:36:24:WU06:FS06:0x21:Reading tar file integrator.xml
14:36:24:WU06:FS06:0x21:Reading tar file state.xml
14:36:24:WU06:FS06:0x21:Reading tar file system.xml
14:36:24:WU06:FS06:0x21:Digital signatures verified
14:36:24:WU06:FS06:0x21:Folding@home GPU Core21 Folding@home Core
14:36:24:WU06:FS06:0x21:Version 0.0.18
14:37:03:WU02:FS02:0x21:Completed 0 out of 25000000 steps (0%)
14:37:04:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:05:WU01:FS01:0x21:Completed 0 out of 25000000 steps (0%)
14:37:05:WU04:FS04:0x21:Completed 0 out of 25000000 steps (0%)
14:37:05:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:05:WU04:FS04:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:07:WU06:FS06:0x21:Completed 0 out of 5000000 steps (0%)
14:37:08:WU03:FS03:0x21:Completed 0 out of 5000000 steps (0%)
14:37:08:WU06:FS06:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:08:WU05:FS05:0x21:Completed 0 out of 5000000 steps (0%)
14:37:08:WU03:FS03:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:08:WU05:FS05:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:37:09:WU04:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:37:11:WU04:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:37:12:WU04:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:37:12:WU04:FS04:0x21:ERROR:114: Max Retries Reached
14:37:12:WU04:FS04:0x21:Saving result file logfile_01.txt
14:37:12:WU04:FS04:0x21:Saving result file badstate-0.xml
14:37:13:WU04:FS04:0x21:Saving result file badstate-1.xml
14:37:15:WU04:FS04:0x21:Saving result file badstate-2.xml
14:37:15:WU04:FS04:0x21:Saving result file log.txt
14:37:16:WU04:FS04:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
14:37:17:WARNING:WU04:FS04:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:37:17:WU04:FS04:Sending unit results: id:04 state:SEND error:FAULTY project:14179 run:32 clone:13 gen:7 core:0x21 unit:0x0000000d0002894c5cb387427e561a11
14:37:17:WU04:FS04:Uploading 5.14KiB to 155.247.166.220
14:37:17:WU04:FS04:Connecting to 155.247.166.220:8080
14:37:19:WU07:FS04:Connecting to 65.254.110.245:8080
14:37:20:WU04:FS04:Upload complete
14:37:21:WU04:FS04:Server responded WORK_ACK (400)
14:37:21:WU04:FS04:Cleaning up
14:37:26:WU07:FS04:Assigned to work server 128.252.203.4
14:37:26:WU07:FS04:Requesting new work unit for slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.4
14:37:26:WU07:FS04:Connecting to 128.252.203.4:8080
14:37:41:ERROR:WU07:FS04:Exception: Server did not assign work unit
14:37:42:WU07:FS04:Connecting to 65.254.110.245:8080
14:38:14:Saving configuration to config.xml
14:38:14:<config>
14:38:14: <!-- User Information -->
14:38:14: <passkey v='********************************'/>
14:38:14: <team v='234980'/>
14:38:14: <user v='grlbeikp37ri'/>
14:38:14:
14:38:14: <!-- Folding Slots -->
14:38:14: <slot id='0' type='CPU'/>
14:38:14: <slot id='1' type='GPU'/>
14:38:14: <slot id='2' type='GPU'/>
14:38:14: <slot id='3' type='GPU'/>
14:38:14: <slot id='4' type='GPU'/>
14:38:14: <slot id='5' type='GPU'/>
14:38:14: <slot id='6' type='GPU'/>
14:38:14:</config>
14:38:38:WARNING:WU07:FS04:Failed to get assignment from '65.254.110.245:8080': 10002: Received short response, expected 272 bytes, got 0
14:38:38:WU07:FS04:Connecting to 18.218.241.186:80
14:38:59:WARNING:WU07:FS04:Failed to get assignment from '18.218.241.186:80': Failed to connect to 18.218.241.186:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:38:59:ERROR:WU07:FS04:Exception: Could not get an assignment
14:38:59:ERROR:WU07:FS04:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
14:38:59:WU07:FS04:Connecting to 65.254.110.245:8080
14:39:20:WARNING:WU07:FS04:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:39:20:ERROR:WU07:FS04:Exception: Could not get an assignment
14:40:23:Saving configuration to config.xml
14:40:23:<config>
14:40:23: <!-- Network -->
14:40:23: <proxy v=':8080'/>
14:40:23:
14:40:23: <!-- User Information -->
14:40:23: <passkey v='********************************'/>
14:40:23: <team v='234980'/>
14:40:23: <user v='grlbeikp37ri'/>
14:40:23:
14:40:23: <!-- Folding Slots -->
14:40:23: <slot id='1' type='GPU'/>
14:40:23: <slot id='2' type='GPU'/>
14:40:23: <slot id='3' type='GPU'/>
14:40:23: <slot id='4' type='GPU'/>
14:40:23: <slot id='5' type='GPU'/>
14:40:23: <slot id='6' type='GPU'/>
14:40:23:</config>
14:40:23:FS00:Shutting core down
14:40:23:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7484
14:40:23:WU00:FS00:0xa7:Exiting, please wait. . .
14:40:28:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:40:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:40:28:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
14:40:28:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:13825 run:292 clone:1 gen:10 core:0xa7 unit:0x0000000a80fccb095c9565bc99ddf322
14:40:28:WU00:Connecting to 128.252.203.9:8080
14:40:44:WU06:FS06:0x21:Completed 50000 out of 5000000 steps (1%)
14:40:48:ERROR:WU07:FS04:Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.
14:40:48:WU07:FS04:Connecting to 65.254.110.245:8080
14:40:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:40:49:WARNING:WU00:WorkServer connection failed on port 8080 trying 80
14:40:49:WU00:Connecting to 128.252.203.9:80
14:41:09:WARNING:WU07:FS04:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:41:09:ERROR:WU07:FS04:Exception: Could not get an assignment
14:41:11:WARNING:WU00:Exception: Failed to send results to work server: Failed to connect to 128.252.203.9:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:41:11:WU00:Trying to send results to collection server
14:41:11:WU00:Connecting to 155.247.166.219:8080
14:41:17:Saving configuration to config.xml
14:41:17:<config>
14:41:17: <!-- Network -->
14:41:17: <proxy v=':8080'/>
14:41:17:
14:41:17: <!-- User Information -->
14:41:17: <passkey v='********************************'/>
14:41:17: <team v='234980'/>
14:41:17: <user v='grlbeikp37ri'/>
14:41:17:
14:41:17: <!-- Folding Slots -->
14:41:17: <slot id='1' type='GPU'/>
14:41:17: <slot id='2' type='GPU'/>
14:41:17: <slot id='3' type='GPU'/>
14:41:17: <slot id='4' type='GPU'/>
14:41:17: <slot id='5' type='GPU'/>
14:41:17: <slot id='6' type='GPU'/>
14:41:17:</config>
14:41:31:WU03:FS03:0x21:Completed 50000 out of 5000000 steps (1%)
14:41:32:WARNING:WU00:WorkServer connection failed on port 8080 trying 80
14:41:32:WU00:Connecting to 155.247.166.219:80
14:41:34:WU05:FS05:0x21:Completed 50000 out of 5000000 steps (1%)
14:41:54:ERROR:WU00:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:41:54:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:13825 run:292 clone:1 gen:10 core:0xa7 unit:0x0000000a80fccb095c9565bc99ddf322
14:41:54:WU00:Connecting to 128.252.203.9:8080
14:42:15:WARNING:WU00:WorkServer connection failed on port 8080 trying 80
14:42:15:WU00:Connecting to 128.252.203.9:80
14:42:37:WARNING:WU00:Exception: Failed to send results to work server: Failed to connect to 128.252.203.9:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:42:37:WU00:Trying to send results to collection server
14:42:37:WU00:Connecting to 155.247.166.219:8080
14:42:58:WARNING:WU00:WorkServer connection failed on port 8080 trying 80
14:42:58:WU00:Connecting to 155.247.166.219:80
14:42:59:WU00:Server responded WORK_ACK (400)
14:42:59:WU00:Cleaning up
14:43:18:WU06:FS06:0x21:Completed 100000 out of 5000000 steps (2%)
14:43:26:WU07:FS04:Connecting to 65.254.110.245:8080
14:43:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:43:28:WU07:FS04:Assigned to work server 128.252.203.4
14:43:28:WU07:FS04:Requesting new work unit for slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.4
14:43:28:WU07:FS04:Connecting to 128.252.203.4:8080
14:43:32:ERROR:WU07:FS04:Exception: Server did not assign work unit
14:44:55:WU01:FS01:0x21:Completed 250000 out of 25000000 steps (1%)
14:45:01:WARNING:FS01:Size of positions 288 does not match topology 18
14:45:17:WU03:FS03:0x21:Completed 100000 out of 5000000 steps (2%)
14:45:17:WU02:FS02:0x21:Completed 250000 out of 25000000 steps (1%)
14:45:22:WARNING:FS02:Size of positions 286 does not match topology 11
14:45:25:WU05:FS05:0x21:Completed 100000 out of 5000000 steps (2%)
14:46:31:WU06:FS06:0x21:Completed 150000 out of 5000000 steps (3%)
14:47:28:WU07:FS04:Connecting to 65.254.110.245:8080
14:47:33:WU07:FS04:Assigned to work server 128.252.203.4
14:47:33:WU07:FS04:Requesting new work unit for slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.4
14:47:33:WU07:FS04:Connecting to 128.252.203.4:8080
14:47:43:WU07:FS04:Downloading 11.66MiB
14:47:49:WU07:FS04:Download 8.04%
14:47:55:WU07:FS04:Download 13.94%
14:48:01:WU07:FS04:Download 24.66%
14:48:07:WU07:FS04:Download 38.07%
14:48:13:WU07:FS04:Download 54.15%
14:48:19:WU07:FS04:Download 82.57%
14:48:20:WU07:FS04:Download complete
14:48:20:WU07:FS04:Received Unit: id:07 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:1610 gen:158 core:0x21 unit:0x000000d280fccb045b3a656b92c636dd
14:48:20:WU07:FS04:Starting
14:48:20:WU07:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 07 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 4 -gpu 4
14:48:20:WU07:FS04:Started FahCore on PID 7044
14:48:20:WU07:FS04:Core PID:1404
14:48:20:WU07:FS04:FahCore 0x21 started
14:48:21:WU07:FS04:0x21:*********************** Log Started 2019-05-02T14:48:20Z ***********************
14:48:21:WU07:FS04:0x21:Project: 13816 (Run 0, Clone 1610, Gen 158)
14:48:21:WU07:FS04:0x21:Unit: 0x000000d280fccb045b3a656b92c636dd
14:48:21:WU07:FS04:0x21:CPU: 0x00000000000000000000000000000000
14:48:21:WU07:FS04:0x21:Machine: 4-
Be_eLSeven
Re: 99.99% WU
14:48:21:WU07:FS04:0x21:Reading tar file core.xml
14:48:21:WU07:FS04:0x21:Reading tar file integrator.xml
14:48:21:WU07:FS04:0x21:Reading tar file state.xml
14:48:21:WU07:FS04:0x21:Reading tar file system.xml
14:48:21:WU07:FS04:0x21:Digital signatures verified
14:48:21:WU07:FS04:0x21:Folding@home GPU Core21 Folding@home Core
14:48:21:WU07:FS04:0x21:Version 0.0.18
14:48:33:WU07:FS04:0x21:Completed 0 out of 5000000 steps (0%)
14:48:34:WU07:FS04:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:48:53:WU07:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:49:42:WU07:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:49:51:WU03:FS03:0x21:Completed 150000 out of 5000000 steps (3%)
14:49:54:WU07:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:49:54:WU07:FS04:0x21:ERROR:114: Max Retries Reached
14:49:54:WU07:FS04:0x21:Saving result file logfile_01.txt
14:49:54:WU07:FS04:0x21:Saving result file badstate-0.xml
14:49:54:WU07:FS04:0x21:Saving result file badstate-1.xml
14:49:54:WU07:FS04:0x21:Saving result file badstate-2.xml
14:49:54:WU07:FS04:0x21:Saving result file log.txt
14:49:54:WU07:FS04:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
14:49:56:WARNING:WU07:FS04:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:49:56:WU07:FS04:Sending unit results: id:07 state:SEND error:FAULTY project:13816 run:0 clone:1610 gen:158 core:0x21 unit:0x000000d280fccb045b3a656b92c636dd
14:49:56:WU07:FS04:Uploading 8.04MiB to 128.252.203.4
14:49:56:WU07:FS04:Connecting to 128.252.203.4:8080
14:49:56:WU00:FS04:Connecting to 65.254.110.245:8080
14:49:57:WU00:FS04:Assigned to work server 155.247.166.220
14:49:57:WU00:FS04:Requesting new work unit for slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
14:49:57:WU00:FS04:Connecting to 155.247.166.220:8080
14:49:58:WU05:FS05:0x21:Completed 150000 out of 5000000 steps (3%)
14:50:00:WU00:FS04:Downloading 994.52KiB
14:50:01:WU06:FS06:0x21:Completed 200000 out of 5000000 steps (4%)
14:50:02:WU07:FS04:Upload 25.67%
14:50:04:WU00:FS04:Download complete
14:50:04:WU00:FS04:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14177 run:19 clone:5 gen:16 core:0x21 unit:0x000000140002894c5cae6aab093a0c13
14:50:04:WU00:FS04:Starting
14:50:04:WU00:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 8516 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 4 -gpu 4
14:50:04:WU00:FS04:Started FahCore on PID 2764
14:50:04:WU00:FS04:Core PID:4460
14:50:04:WU00:FS04:FahCore 0x21 started
14:50:05:WU00:FS04:0x21:*********************** Log Started 2019-05-02T14:50:04Z ***********************
14:50:05:WU00:FS04:0x21:Project: 14177 (Run 19, Clone 5, Gen 16)
14:50:05:WU00:FS04:0x21:Unit: 0x000000140002894c5cae6aab093a0c13
14:50:05:WU00:FS04:0x21:CPU: 0x00000000000000000000000000000000
14:50:05:WU00:FS04:0x21:Machine: 4
14:50:05:WU00:FS04:0x21:Reading tar file core.xml
14:50:05:WU00:FS04:0x21:Reading tar file integrator.xml
14:50:05:WU00:FS04:0x21:Reading tar file state.xml
14:50:05:WU00:FS04:0x21:Reading tar file system.xml
14:50:05:WU00:FS04:0x21:Digital signatures verified
14:50:05:WU00:FS04:0x21:Folding@home GPU Core21 Folding@home Core
14:50:05:WU00:FS04:0x21:Version 0.0.18
14:50:08:WU07:FS04:Upload 42.00%
14:50:14:WU07:FS04:Upload 67.67%
14:50:15:WU00:FS04:0x21:Completed 0 out of 25000000 steps (0%)
14:50:15:WU00:FS04:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:50:16:WU00:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:50:21:WU07:FS04:Upload complete
14:50:22:WU07:FS04:Server responded WORK_ACK (400)
14:50:22:WU07:FS04:Cleaning up
14:52:51:WU01:FS01:0x21:Completed 500000 out of 25000000 steps (2%)
14:52:57:WARNING:FS01:Size of positions 288 does not match topology 18
14:53:20:WU06:FS06:0x21:Completed 250000 out of 5000000 steps (5%)
14:53:28:WU02:FS02:0x21:Completed 500000 out of 25000000 steps (2%)
14:53:33:WARNING:FS02:Size of positions 286 does not match topology 11
14:54:19:WU03:FS03:0x21:Completed 200000 out of 5000000 steps (4%)
14:54:22:WU05:FS05:0x21:Completed 200000 out of 5000000 steps (4%)
14:56:33:WU06:FS06:0x21:Completed 300000 out of 5000000 steps (6%)
14:58:36:WU03:FS03:0x21:Completed 250000 out of 5000000 steps (5%)
14:58:40:WU05:FS05:0x21:Completed 250000 out of 5000000 steps (5%)
14:58:43:WARNING:FS03:Size of positions 2073 does not match topology 2067
14:59:50:WU06:FS06:0x21:Completed 350000 out of 5000000 steps (7%)
15:00:34:WU01:FS01:0x21:Completed 750000 out of 25000000 steps (3%)
15:00:40:WARNING:FS01:Size of positions 288 does not match topology 18
15:01:26:WU02:FS02:0x21:Completed 750000 out of 25000000 steps (3%)
15:01:31:WARNING:FS02:Size of positions 286 does not match topology 11
15:02:57:WU03:FS03:0x21:Completed 300000 out of 5000000 steps (6%)
15:02:59:WU05:FS05:0x21:Completed 300000 out of 5000000 steps (6%)
15:03:02:WU06:FS06:0x21:Completed 400000 out of 5000000 steps (8%)
15:06:08:WU06:FS06:0x21:Completed 450000 out of 5000000 steps (9%)
15:07:06:WU03:FS03:0x21:Completed 350000 out of 5000000 steps (7%)
15:07:08:WU05:FS05:0x21:Completed 350000 out of 5000000 steps (7%)
15:08:07:WU01:FS01:0x21:Completed 1000000 out of 25000000 steps (4%)
15:08:13:WARNING:FS01:Size of positions 288 does not match topology 18
15:09:17:WU02:FS02:0x21:Completed 1000000 out of 25000000 steps (4%)
15:09:20:WU06:FS06:0x21:Completed 500000 out of 5000000 steps (10%)
15:09:22:WARNING:FS02:Size of positions 286 does not match topology 11
15:11:24:WU03:FS03:0x21:Completed 400000 out of 5000000 steps (8%)
15:11:26:WU05:FS05:0x21:Completed 400000 out of 5000000 steps (8%)
15:12:34:WU06:FS06:0x21:Completed 550000 out of 5000000 steps (11%)
15:15:36:WU03:FS03:0x21:Completed 450000 out of 5000000 steps (9%)
15:15:39:WU05:FS05:0x21:Completed 450000 out of 5000000 steps (9%)
15:15:42:WU06:FS06:0x21:Completed 600000 out of 5000000 steps (12%)
15:15:45:WU01:FS01:0x21:Completed 1250000 out of 25000000 steps (5%)
15:15:50:WARNING:FS01:Size of positions 288 does not match topology 18
15:17:10:WU02:FS02:0x21:Completed 1250000 out of 25000000 steps (5%)
15:17:15:WARNING:FS02:Size of positions 286 does not match topology 11
15:18:55:WU06:FS06:0x21:Completed 650000 out of 5000000 steps (13%)
15:19:54:WU03:FS03:0x21:Completed 500000 out of 5000000 steps (10%)
15:19:57:WU05:FS05:0x21:Completed 500000 out of 5000000 steps (10%)
15:20:01:WARNING:FS03:Size of positions 2073 does not match topology 2067
15:22:09:WU06:FS06:0x21:Completed 700000 out of 5000000 steps (14%)
15:23:24:WU01:FS01:0x21:Completed 1500000 out of 25000000 steps (6%)
15:23:30:WARNING:FS01:Size of positions 288 does not match topology 18
15:24:15:WU05:FS05:0x21:Completed 550000 out of 5000000 steps (11%)
15:24:15:WU03:FS03:0x21:Completed 550000 out of 5000000 steps (11%)
15:25:07:WU02:FS02:0x21:Completed 1500000 out of 25000000 steps (6%)
15:25:12:WARNING:FS02:Size of positions 286 does not match topology 11
15:25:22:WU06:FS06:0x21:Completed 750000 out of 5000000 steps (15%)
15:28:33:WU05:FS05:0x21:Completed 600000 out of 5000000 steps (12%)
15:28:33:WU03:FS03:0x21:Completed 600000 out of 5000000 steps (12%)
15:28:36:WU06:FS06:0x21:Completed 800000 out of 5000000 steps (16%)
15:31:04:WU01:FS01:0x21:Completed 1750000 out of 25000000 steps (7%)
15:31:10:WARNING:FS01:Size of positions 288 does not match topology 18
15:31:51:WU06:FS06:0x21:Completed 850000 out of 5000000 steps (17%)
15:32:50:WU05:FS05:0x21:Completed 650000 out of 5000000 steps (13%)
15:32:52:WU03:FS03:0x21:Completed 650000 out of 5000000 steps (13%)
15:33:05:WU02:FS02:0x21:Completed 1750000 out of 25000000 steps (7%)
15:33:11:WARNING:FS02:Size of positions 286 does not match topology 11
15:34:10:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:37:06:WU05:FS05:0x21:Completed 700000 out of 5000000 steps (14%)
15:37:08:WU03:FS03:0x21:Completed 700000 out of 5000000 steps (14%)
15:37:21:WU06:FS06:0x21:Completed 800000 out of 5000000 steps (16%)
15:38:41:WU01:FS01:0x21:Completed 2000000 out of 25000000 steps (8%)
15:38:46:WARNING:FS01:Size of positions 288 does not match topology 18
15:40:35:WU06:FS06:0x21:Completed 850000 out of 5000000 steps (17%)
15:41:00:WU02:FS02:0x21:Completed 2000000 out of 25000000 steps (8%)
15:41:06:WARNING:FS02:Size of positions 286 does not match topology 11
15:41:23:WU05:FS05:0x21:Completed 750000 out of 5000000 steps (15%)
15:41:28:WU03:FS03:0x21:Completed 750000 out of 5000000 steps (15%)
15:41:35:WARNING:FS03:Size of positions 2073 does not match topology 2067
15:43:50:WU06:FS06:0x21:Completed 900000 out of 5000000 steps (18%)
15:45:43:WU05:FS05:0x21:Completed 800000 out of 5000000 steps (16%)
15:45:47:WU03:FS03:0x21:Completed 800000 out of 5000000 steps (16%)
15:46:22:WU01:FS01:0x21:Completed 2250000 out of 25000000 steps (9%)
15:46:28:WARNING:FS01:Size of positions 288 does not match topology 18
15:47:03:WU06:FS06:0x21:Completed 950000 out of 5000000 steps (19%)
15:48:58:WU02:FS02:0x21:Completed 2250000 out of 25000000 steps (9%)
15:49:03:WARNING:FS02:Size of positions 286 does not match topology 11
15:49:59:WU05:FS05:0x21:Completed 850000 out of 5000000 steps (17%)
15:50:03:WU03:FS03:0x21:Completed 850000 out of 5000000 steps (17%)
15:50:15:WU06:FS06:0x21:Completed 1000000 out of 5000000 steps (20%)
15:53:28:WU06:FS06:0x21:Completed 1050000 out of 5000000 steps (21%)
15:54:00:WU01:FS01:0x21:Completed 2500000 out of 25000000 steps (10%)
15:54:06:WARNING:FS01:Size of positions 288 does not match topology 18
15:54:16:WU05:FS05:0x21:Completed 900000 out of 5000000 steps (18%)
15:54:22:WU03:FS03:0x21:Completed 900000 out of 5000000 steps (18%)
15:56:41:WU06:FS06:0x21:Completed 1100000 out of 5000000 steps (22%)
15:56:52:WU02:FS02:0x21:Completed 2500000 out of 25000000 steps (10%)
15:56:58:WARNING:FS02:Size of positions 286 does not match topology 11
15:58:31:WU05:FS05:0x21:Completed 950000 out of 5000000 steps (19%)
15:58:38:WU03:FS03:0x21:Completed 950000 out of 5000000 steps (19%)
15:59:53:WU06:FS06:0x21:Completed 1150000 out of 5000000 steps (23%)
16:01:36:WU01:FS01:0x21:Completed 2750000 out of 25000000 steps (11%)
16:01:41:WARNING:FS01:Size of positions 288 does not match topology 18
16:02:47:WU05:FS05:0x21:Completed 1000000 out of 5000000 steps (20%)
16:02:57:WU03:FS03:0x21:Completed 1000000 out of 5000000 steps (20%)
16:03:04:WARNING:FS03:Size of positions 2073 does not match topology 2067
16:03:08:WU06:FS06:0x21:Completed 1200000 out of 5000000 steps (24%)
16:04:51:WU02:FS02:0x21:Completed 2750000 out of 25000000 steps (11%)
16:04:56:WARNING:FS02:Size of positions 286 does not match topology 11
16:06:21:WU06:FS06:0x21:Completed 1250000 out of 5000000 steps (25%)
16:07:08:WU05:FS05:0x21:Completed 1050000 out of 5000000 steps (21%)
16:07:17:WU03:FS03:0x21:Completed 1050000 out of 5000000 steps (21%)
16:09:17:WU01:FS01:0x21:Completed 3000000 out of 25000000 steps (12%)
16:09:22:WARNING:FS01:Size of positions 288 does not match topology 18
16:09:35:WU06:FS06:0x21:Completed 1300000 out of 5000000 steps (26%)
16:09:47:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
16:11:24:WU05:FS05:0x21:Completed 1100000 out of 5000000 steps (22%)
16:11:36:WU03:FS03:0x21:Completed 1100000 out of 5000000 steps (22%)
16:12:48:WU02:FS02:0x21:Completed 3000000 out of 25000000 steps (12%)
16:12:53:WARNING:FS02:Size of positions 286 does not match topology 11
16:15:40:WU05:FS05:0x21:Completed 1150000 out of 5000000 steps (23%)
16:15:53:WU03:FS03:0x21:Completed 1150000 out of 5000000 steps (23%)
16:16:10:WU06:FS06:0x21:Completed 1350000 out of 5000000 steps (27%)
16:16:54:WU01:FS01:0x21:Completed 3250000 out of 25000000 steps (13%)
16:17:00:WARNING:FS01:Size of positions 288 does not match topology 18
16:19:23:WU06:FS06:0x21:Completed 1400000 out of 5000000 steps (28%)
16:19:56:WU05:FS05:0x21:Completed 1200000 out of 5000000 steps (24%)
16:20:10:WU03:FS03:0x21:Completed 1200000 out of 5000000 steps (24%)
16:20:44:WU02:FS02:0x21:Completed 3250000 out of 25000000 steps (13%)
16:20:50:WARNING:FS02:Size of positions 286 does not match topology 11
16:22:34:WU06:FS06:0x21:Completed 1450000 out of 5000000 steps (29%)
16:24:11:WU05:FS05:0x21:Completed 1250000 out of 5000000 steps (25%)
16:24:29:WU03:FS03:0x21:Completed 1250000 out of 5000000 steps (25%)
16:24:33:WU01:FS01:0x21:Completed 3500000 out of 25000000 steps (14%)
16:24:36:WARNING:FS03:Size of positions 2073 does not match topology 2067
16:24:39:WARNING:FS01:Size of positions 288 does not match topology 18
16:25:49:WU06:FS06:0x21:Completed 1500000 out of 5000000 steps (30%)
16:28:31:WU05:FS05:0x21:Completed 1300000 out of 5000000 steps (26%)
16:28:46:WU02:FS02:0x21:Completed 3500000 out of 25000000 steps (14%)
16:28:48:WU03:FS03:0x21:Completed 1300000 out of 5000000 steps (26%)
16:28:51:WARNING:FS02:Size of positions 286 does not match topology 11
16:29:03:WU06:FS06:0x21:Completed 1550000 out of 5000000 steps (31%)
16:32:11:WU01:FS01:0x21:Completed 3750000 out of 25000000 steps (15%)
16:32:14:WU06:FS06:0x21:Completed 1600000 out of 5000000 steps (32%)
16:32:17:WARNING:FS01:Size of positions 288 does not match topology 18
16:32:47:WU05:FS05:0x21:Completed 1350000 out of 5000000 steps (27%)
16:33:05:WU03:FS03:0x21:Completed 1350000 out of 5000000 steps (27%)
16:35:26:WU06:FS06:0x21:Completed 1650000 out of 5000000 steps (33%)
16:36:43:WU02:FS02:0x21:Completed 3750000 out of 25000000 steps (15%)
16:36:49:WARNING:FS02:Size of positions 286 does not match topology 11
16:37:03:WU05:FS05:0x21:Completed 1400000 out of 5000000 steps (28%)
16:37:04:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
16:37:04:WU06:FS06:0x21:ERROR:114: Max Retries Reached
16:37:04:WU06:FS06:0x21:Saving result file logfile_01.txt
16:37:04:WU06:FS06:0x21:Saving result file badstate-0.xml
16:37:04:WU06:FS06:0x21:Saving result file badstate-1.xml
16:37:04:WU06:FS06:0x21:Saving result file badstate-2.xml
16:37:04:WU06:FS06:0x21:Saving result file log.txt
16:37:04:WU06:FS06:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:37:20:WU03:FS03:0x21:Completed 1400000 out of 5000000 steps (28%)
16:39:42:WU01:FS01:0x21:Completed 4000000 out of 25000000 steps (16%)
16:39:47:WARNING:FS01:Size of positions 288 does not match topology 18
16:40:58:WU05:FS05:0x21:Completed 1450000 out of 5000000 steps (29%)
16:41:12:WU03:FS03:0x21:Completed 1450000 out of 5000000 steps (29%)
16:44:21:WU02:FS02:0x21:Completed 4000000 out of 25000000 steps (16%)
16:44:27:WARNING:FS02:Size of positions 286 does not match topology 11
16:44:53:WU05:FS05:0x21:Completed 1500000 out of 5000000 steps (30%)
16:45:06:WU03:FS03:0x21:Completed 1500000 out of 5000000 steps (30%)
16:45:13:WARNING:FS03:Size of positions 2073 does not match topology 2067
16:47:00:WU01:FS01:0x21:Completed 4250000 out of 25000000 steps (17%)
16:47:06:WARNING:FS01:Size of positions 288 does not match topology 18
16:48:51:WU05:FS05:0x21:Completed 1550000 out of 5000000 steps (31%)
16:49:00:WU03:FS03:0x21:Completed 1550000 out of 5000000 steps (31%)
16:52:01:WU02:FS02:0x21:Completed 4250000 out of 25000000 steps (17%)
16:52:07:WARNING:FS02:Size of positions 286 does not match topology 11
16:52:46:WU05:FS05:0x21:Completed 1600000 out of 5000000 steps (32%)
16:52:52:WU03:FS03:0x21:Completed 1600000 out of 5000000 steps (32%)
16:54:17:WU01:FS01:0x21:Completed 4500000 out of 25000000 steps (18%)
16:54:22:WARNING:FS01:Size of positions 288 does not match topology 18
16:56:40:WU05:FS05:0x21:Completed 1650000 out of 5000000 steps (33%)
16:56:44:WU03:FS03:0x21:Completed 1650000 out of 5000000 steps (33%)
16:59:38:WU02:FS02:0x21:Completed 4500000 out of 25000000 steps (18%)
16:59:43:WARNING:FS02:Size of positions 286 does not match topology 11
17:00:34:WU05:FS05:0x21:Completed 1700000 out of 5000000 steps (34%)
17:00:37:WU03:FS03:0x21:Completed 1700000 out of 5000000 steps (34%)
17:01:32:WU01:FS01:0x21:Completed 4750000 out of 25000000 steps (19%)
17:01:38:WARNING:FS01:Size of positions 288 does not match topology 18
17:04:28:WU05:FS05:0x21:Completed 1750000 out of 5000000 steps (35%)
17:04:31:WU03:FS03:0x21:Completed 1750000 out of 5000000 steps (35%)
17:04:38:WARNING:FS03:Size of positions 2073 does not match topology 2067
17:07:17:WU02:FS02:0x21:Completed 4750000 out of 25000000 steps (19%)
17:07:22:WARNING:FS02:Size of positions 286 does not match topology 11
17:08:25:WU03:FS03:0x21:Completed 1800000 out of 5000000 steps (36%)
17:08:25:WU05:FS05:0x21:Completed 1800000 out of 5000000 steps (36%)
17:08:50:WU01:FS01:0x21:Completed 5000000 out of 25000000 steps (20%)
17:08:56:WARNING:FS01:Size of positions 288 does not match topology 18
17:12:17:WU03:FS03:0x21:Completed 1850000 out of 5000000 steps (37%)
17:12:19:WU05:FS05:0x21:Completed 1850000 out of 5000000 steps (37%)
17:14:53:WU02:FS02:0x21:Completed 5000000 out of 25000000 steps (20%)
17:14:58:WARNING:FS02:Size of positions 286 does not match topology 11
17:16:06:WU01:FS01:0x21:Completed 5250000 out of 25000000 steps (21%)
17:16:10:WU03:FS03:0x21:Completed 1900000 out of 5000000 steps (38%)
17:16:11:WARNING:FS01:Size of positions 288 does not match topology 18
17:16:13:WU05:FS05:0x21:Completed 1900000 out of 5000000 steps (38%)
17:20:03:WU03:FS03:0x21:Completed 1950000 out of 5000000 steps (39%)
17:20:08:WU05:FS05:0x21:Completed 1950000 out of 5000000 steps (39%)
17:22:29:WU02:FS02:0x21:Completed 5250000 out of 25000000 steps (21%)
17:22:34:WARNING:FS02:Size of positions 286 does not match topology 11
17:23:22:WU01:FS01:0x21:Completed 5500000 out of 25000000 steps (22%)
17:23:28:WARNING:FS01:Size of positions 288 does not match topology 18
17:23:56:WU03:FS03:0x21:Completed 2000000 out of 5000000 steps (40%)
17:24:03:WARNING:FS03:Size of positions 2073 does not match topology 2067
17:24:06:WU05:FS05:0x21:Completed 2000000 out of 5000000 steps (40%)
17:27:50:WU03:FS03:0x21:Completed 2050000 out of 5000000 steps (41%)
17:28:01:WU05:FS05:0x21:Completed 2050000 out of 5000000 steps (41%)
17:30:09:WU02:FS02:0x21:Completed 5500000 out of 25000000 steps (22%)
17:30:15:WARNING:FS02:Size of positions 286 does not match topology 11
17:30:40:WU01:FS01:0x21:Completed 5750000 out of 25000000 steps (23%)
17:30:46:WARNING:FS01:Size of positions 288 does not match topology 18
17:31:42:WU03:FS03:0x21:Completed 2100000 out of 5000000 steps (42%)
17:31:56:WU05:FS05:0x21:Completed 2100000 out of 5000000 steps (42%)
17:35:33:WU03:FS03:0x21:Completed 2150000 out of 5000000 steps (43%)
17:35:50:WU05:FS05:0x21:Completed 2150000 out of 5000000 steps (43%)
17:37:47:WU02:FS02:0x21:Completed 5750000 out of 25000000 steps (23%)
17:37:53:WARNING:FS02:Size of positions 286 does not match topology 11
17:37:56:WU01:FS01:0x21:Completed 6000000 out of 25000000 steps (24%)
17:38:01:WARNING:FS01:Size of positions 288 does not match topology 18
17:39:27:WU03:FS03:0x21:Completed 2200000 out of 5000000 steps (44%)
17:39:46:WU05:FS05:0x21:Completed 2200000 out of 5000000 steps (44%)
17:43:18:WU03:FS03:0x21:Completed 2250000 out of 5000000 steps (45%)
17:43:26:WARNING:FS03:Size of positions 2073 does not match topology 2067
17:43:42:WU05:FS05:0x21:Completed 2250000 out of 5000000 steps (45%)
17:45:15:WU01:FS01:0x21:Completed 6250000 out of 25000000 steps (25%)
17:45:21:WARNING:FS01:Size of positions 288 does not match topology 18
17:45:29:WU02:FS02:0x21:Completed 6000000 out of 25000000 steps (24%)
17:45:35:WARNING:FS02:Size of positions 286 does not match topology 11
17:47:17:WU03:FS03:0x21:Completed 2300000 out of 5000000 steps (46%)
17:47:38:WU05:FS05:0x21:Completed 2300000 out of 5000000 steps (46%)
17:51:11:WU03:FS03:0x21:Completed 2350000 out of 5000000 steps (47%)
17:51:34:WU05:FS05:0x21:Completed 2350000 out of 5000000 steps (47%)
17:52:31:WU01:FS01:0x21:Completed 6500000 out of 25000000 steps (26%)
17:52:37:WARNING:FS01:Size of positions 288 does not match topology 18
17:53:07:WU02:FS02:0x21:Completed 6250000 out of 25000000 steps (25%)
17:53:12:WARNING:FS02:Size of positions 286 does not match topology 11
17:55:04:WU03:FS03:0x21:Completed 2400000 out of 5000000 steps (48%)
17:55:28:WU05:FS05:0x21:Completed 2400000 out of 5000000 steps (48%)
17:58:55:WU03:FS03:0x21:Completed 2450000 out of 5000000 steps (49%)
17:59:21:WU05:FS05:0x21:Completed 2450000 out of 5000000 steps (49%)
17:59:46:WU01:FS01:0x21:Completed 6750000 out of 25000000 steps (27%)
17:59:52:WARNING:FS01:Size of positions 288 does not match topology 18
18:00:44:WU02:FS02:0x21:Completed 6500000 out of 25000000 steps (26%)
18:00:50:WARNING:FS02:Size of positions 286 does not match topology 11
18:02:43:WU03:FS03:0x21:Completed 2500000 out of 5000000 steps (50%)
18:02:51:WARNING:FS03:Size of positions 2073 does not match topology 2067
18:03:16:WU05:FS05:0x21:Completed 2500000 out of 5000000 steps (50%)
18:06:45:WU03:FS03:0x21:Completed 2550000 out of 5000000 steps (51%)
18:07:09:WU01:FS01:0x21:Completed 7000000 out of 25000000 steps (28%)
18:07:15:WARNING:FS01:Size of positions 288 does not match topology 18
18:07:16:WU05:FS05:0x21:Completed 2550000 out of 5000000 steps (51%)
18:08:31:WU02:FS02:0x21:Completed 6750000 out of 25000000 steps (27%)
18:08:36:WARNING:FS02:Size of positions 286 does not match topology 11
18:10:45:WU03:FS03:0x21:Completed 2600000 out of 5000000 steps (52%)
18:11:17:WU05:FS05:0x21:Completed 2600000 out of 5000000 steps (52%)
18:14:30:WU01:FS01:0x21:Completed 7250000 out of 25000000 steps (29%)
18:14:36:WARNING:FS01:Size of positions 288 does not match topology 18
18:14:39:WU03:FS03:0x21:Completed 2650000 out of 5000000 steps (53%)
18:15:08:WU05:FS05:0x21:Completed 2650000 out of 5000000 steps (53%)
18:16:10:WU02:FS02:0x21:Completed 7000000 out of 25000000 steps (28%)
18:16:16:WARNING:FS02:Size of positions 286 does not match topology 11
18:18:25:WU03:FS03:0x21:Completed 2700000 out of 5000000 steps (54%)
18:19:02:WU05:FS05:0x21:Completed 2700000 out of 5000000 steps (54%)
18:21:44:WU01:FS01:0x21:Completed 7500000 out of 25000000 steps (30%)
18:21:49:WARNING:FS01:Size of positions 288 does not match topology 18
18:22:18:WU03:FS03:0x21:Completed 2750000 out of 5000000 steps (55%)
18:22:25:WARNING:FS03:Size of positions 2073 does not match topology 2067
18:22:59:WU05:FS05:0x21:Completed 2750000 out of 5000000 steps (55%)
18:23:50:WU02:FS02:0x21:Completed 7250000 out of 25000000 steps (29%)
18:23:55:WARNING:FS02:Size of positions 286 does not match topology 11
18:26:14:WU03:FS03:0x21:Completed 2800000 out of 5000000 steps (56%)
18:26:55:WU05:FS05:0x21:Completed 2800000 out of 5000000 steps (56%)
18:29:02:WU01:FS01:0x21:Completed 7750000 out of 25000000 steps (31%)
18:29:08:WARNING:FS01:Size of positions 288 does not match topology 18
18:30:06:WU03:FS03:0x21:Completed 2850000 out of 5000000 steps (57%)
18:30:50:WU05:FS05:0x21:Completed 2850000 out of 5000000 steps (57%)
18:31:28:WU02:FS02:0x21:Completed 7500000 out of 25000000 steps (30%)
18:31:34:WARNING:FS02:Size of positions 286 does not match topology 11
18:33:58:WU03:FS03:0x21:Completed 2900000 out of 5000000 steps (58%)
18:34:44:WU05:FS05:0x21:Completed 2900000 out of 5000000 steps (58%)
18:36:17:WU01:FS01:0x21:Completed 8000000 out of 25000000 steps (32%)
18:36:22:WARNING:FS01:Size of positions 288 does not match topology 18
18:37:49:WU03:FS03:0x21:Completed 2950000 out of 5000000 steps (59%)
18:38:37:WU05:FS05:0x21:Completed 2950000 out of 5000000 steps (59%)
18:39:08:WU02:FS02:0x21:Completed 7750000 out of 25000000 steps (31%)
18:39:14:WARNING:FS02:Size of positions 286 does not match topology 11
18:41:41:WU03:FS03:0x21:Completed 3000000 out of 5000000 steps (60%)
18:41:49:WARNING:FS03:Size of positions 2073 does not match topology 2067
18:42:33:WU05:FS05:0x21:Completed 3000000 out of 5000000 steps (60%)
18:43:36:WU01:FS01:0x21:Completed 8250000 out of 25000000 steps (33%)
18:43:41:WARNING:FS01:Size of positions 288 does not match topology 18
18:45:37:WU03:FS03:0x21:Completed 3050000 out of 5000000 steps (61%)
18:46:29:WU05:FS05:0x21:Completed 3050000 out of 5000000 steps (61%)
18:46:55:WU02:FS02:0x21:Completed 8000000 out of 25000000 steps (32%)
18:47:00:WARNING:FS02:Size of positions 286 does not match topology 11
18:49:30:WU03:FS03:0x21:Completed 3100000 out of 5000000 steps (62%)
18:50:23:WU05:FS05:0x21:Completed 3100000 out of 5000000 steps (62%)
18:50:51:WU01:FS01:0x21:Completed 8500000 out of 25000000 steps (34%)
18:50:57:WARNING:FS01:Size of positions 288 does not match topology 18
18:53:21:WU03:FS03:0x21:Completed 3150000 out of 5000000 steps (63%)
18:54:17:WU05:FS05:0x21:Completed 3150000 out of 5000000 steps (63%)
18:54:34:WU02:FS02:0x21:Completed 8250000 out of 25000000 steps (33%)
18:54:39:WARNING:FS02:Size of positions 286 does not match topology 11
18:57:13:WU03:FS03:0x21:Completed 3200000 out of 5000000 steps (64%)
18:58:06:WU01:FS01:0x21:Completed 8750000 out of 25000000 steps (35%)
18:58:11:WARNING:FS01:Size of positions 288 does not match topology 18
18:58:11:WU05:FS05:0x21:Completed 3200000 out of 5000000 steps (64%)
19:01:05:WU03:FS03:0x21:Completed 3250000 out of 5000000 steps (65%)
19:01:12:WARNING:FS03:Size of positions 2073 does not match topology 2067
19:02:07:WU05:FS05:0x21:Completed 3250000 out of 5000000 steps (65%)
19:02:19:WU02:FS02:0x21:Completed 8500000 out of 25000000 steps (34%)
19:02:24:WARNING:FS02:Size of positions 286 does not match topology 11
19:04:59:WU03:FS03:0x21:Completed 3300000 out of 5000000 steps (66%)
19:05:24:WU01:FS01:0x21:Completed 9000000 out of 25000000 steps (36%)
19:05:29:WARNING:FS01:Size of positions 288 does not match topology 18
19:06:03:WU05:FS05:0x21:Completed 3300000 out of 5000000 steps (66%)
19:08:50:WU03:FS03:0x21:Completed 3350000 out of 5000000 steps (67%)
19:09:57:WU05:FS05:0x21:Completed 3350000 out of 5000000 steps (67%)
19:10:01:WU02:FS02:0x21:Completed 8750000 out of 25000000 steps (35%)
19:10:07:WARNING:FS02:Size of positions 286 does not match topology 11
19:12:39:WU01:FS01:0x21:Completed 9250000 out of 25000000 steps (37%)
19:12:45:WARNING:FS01:Size of positions 288 does not match topology 18
19:12:45:WU03:FS03:0x21:Completed 3400000 out of 5000000 steps (68%)
19:13:52:WU05:FS05:0x21:Completed 3400000 out of 5000000 steps (68%)
19:16:36:WU03:FS03:0x21:Completed 3450000 out of 5000000 steps (69%)
19:17:42:WU02:FS02:0x21:Completed 9000000 out of 25000000 steps (36%)
19:17:45:WU05:FS05:0x21:Completed 3450000 out of 5000000 steps (69%)
19:17:47:WARNING:FS02:Size of positions 286 does not match topology 11
19:19:54:WU01:FS01:0x21:Completed 9500000 out of 25000000 steps (38%)
19:20:00:WARNING:FS01:Size of positions 288 does not match topology 18
19:20:29:WU03:FS03:0x21:Completed 3500000 out of 5000000 steps (70%)
19:20:36:WARNING:FS03:Size of positions 2073 does not match topology 2067
19:21:40:WU05:FS05:0x21:Completed 3500000 out of 5000000 steps (70%)
19:24:26:WU03:FS03:0x21:Completed 3550000 out of 5000000 steps (71%)
19:25:25:WU02:FS02:0x21:Completed 9250000 out of 25000000 steps (37%)
19:25:30:WARNING:FS02:Size of positions 286 does not match topology 11
19:25:37:WU05:FS05:0x21:Completed 3550000 out of 5000000 steps (71%)
19:27:13:WU01:FS01:0x21:Completed 9750000 out of 25000000 steps (39%)
19:27:19:WARNING:FS01:Size of positions 288 does not match topology 18
19:28:17:WU03:FS03:0x21:Completed 3600000 out of 5000000 steps (72%)
19:29:31:WU05:FS05:0x21:Completed 3600000 out of 5000000 steps (72%)
19:32:09:WU03:FS03:0x21:Completed 3650000 out of 5000000 steps (73%)
19:33:06:WU02:FS02:0x21:Completed 9500000 out of 25000000 steps (38%)
19:33:12:WARNING:FS02:Size of positions 286 does not match topology 11
19:33:24:WU05:FS05:0x21:Completed 3650000 out of 5000000 steps (73%)
19:34:28:WU01:FS01:0x21:Completed 10000000 out of 25000000 steps (40%)
19:34:33:WARNING:FS01:Size of positions 288 does not match topology 18
19:36:01:WU03:FS03:0x21:Completed 3700000 out of 5000000 steps (74%)
19:37:17:WU05:FS05:0x21:Completed 3700000 out of 5000000 steps (74%)
19:39:54:WU03:FS03:0x21:Completed 3750000 out of 5000000 steps (75%)
19:40:01:WARNING:FS03:Size of positions 2073 does not match topology 2067
19:40:50:WU02:FS02:0x21:Completed 9750000 out of 25000000 steps (39%)
19:40:56:WARNING:FS02:Size of positions 286 does not match topology 11
19:41:15:WU05:FS05:0x21:Completed 3750000 out of 5000000 steps (75%)
19:41:47:WU01:FS01:0x21:Completed 10250000 out of 25000000 steps (41%)
19:41:52:WARNING:FS01:Size of positions 288 does not match topology 18
19:43:49:WU03:FS03:0x21:Completed 3800000 out of 5000000 steps (76%)
19:45:12:WU05:FS05:0x21:Completed 3800000 out of 5000000 steps (76%)
19:47:42:WU03:FS03:0x21:Completed 3850000 out of 5000000 steps (77%)
19:48:33:WU02:FS02:0x21:Completed 10000000 out of 25000000 steps (40%)
19:48:38:WARNING:FS02:Size of positions 286 does not match topology 11
19:49:04:WU01:FS01:0x21:Completed 10500000 out of 25000000 steps (42%)
19:49:09:WARNING:FS01:Size of positions 288 does not match topology 18
19:49:10:WU05:FS05:0x21:Completed 3850000 out of 5000000 steps (77%)
19:51:35:WU03:FS03:0x21:Completed 3900000 out of 5000000 steps (78%)
19:53:02:WU05:FS05:0x21:Completed 3900000 out of 5000000 steps (78%)
19:55:27:WU03:FS03:0x21:Completed 3950000 out of 5000000 steps (79%)
19:56:12:WU02:FS02:0x21:Completed 10250000 out of 25000000 steps (41%)
19:56:17:WARNING:FS02:Size of positions 286 does not match topology 11
19:56:20:WU01:FS01:0x21:Completed 10750000 out of 25000000 steps (43%)
19:56:25:WARNING:FS01:Size of positions 288 does not match topology 18
19:56:57:WU05:FS05:0x21:Completed 3950000 out of 5000000 steps (79%)
19:59:20:WU03:FS03:0x21:Completed 4000000 out of 5000000 steps (80%)
19:59:27:WARNING:FS03:Size of positions 2073 does not match topology 2067
20:00:54:WU05:FS05:0x21:Completed 4000000 out of 5000000 steps (80%)
20:03:17:WU03:FS03:0x21:Completed 4050000 out of 5000000 steps (81%)
20:03:38:WU01:FS01:0x21:Completed 11000000 out of 25000000 steps (44%)
20:03:44:WARNING:FS01:Size of positions 288 does not match topology 18
20:03:55:WU02:FS02:0x21:Completed 10500000 out of 25000000 steps (42%)
20:04:01:WARNING:FS02:Size of positions 286 does not match topology 11
20:04:51:WU05:FS05:0x21:Completed 4050000 out of 5000000 steps (81%)
20:07:10:WU03:FS03:0x21:Completed 4100000 out of 5000000 steps (82%)
20:08:43:WU05:FS05:0x21:Completed 4100000 out of 5000000 steps (82%)
20:10:54:WU01:FS01:0x21:Completed 11250000 out of 25000000 steps (45%)
20:10:59:WARNING:FS01:Size of positions 288 does not match topology 18
20:11:02:WU03:FS03:0x21:Completed 4150000 out of 5000000 steps (83%)
20:11:34:WU02:FS02:0x21:Completed 10750000 out of 25000000 steps (43%)
20:11:39:WARNING:FS02:Size of positions 286 does not match topology 11
20:12:38:WU05:FS05:0x21:Completed 4150000 out of 5000000 steps (83%)
20:14:54:WU03:FS03:0x21:Completed 4200000 out of 5000000 steps (84%)
20:16:32:WU05:FS05:0x21:Completed 4200000 out of 5000000 steps (84%)
20:18:10:WU01:FS01:0x21:Completed 11500000 out of 25000000 steps (46%)
20:18:16:WARNING:FS01:Size of positions 288 does not match topology 18
20:18:48:WU03:FS03:0x21:Completed 4250000 out of 5000000 steps (85%)
20:18:55:WARNING:FS03:Size of positions 2073 does not match topology 2067
20:19:15:WU02:FS02:0x21:Completed 11000000 out of 25000000 steps (44%)
20:19:21:WARNING:FS02:Size of positions 286 does not match topology 11
20:20:31:WU05:FS05:0x21:Completed 4250000 out of 5000000 steps (85%)
20:22:44:WU03:FS03:0x21:Completed 4300000 out of 5000000 steps (86%)
20:24:26:WU05:FS05:0x21:Completed 4300000 out of 5000000 steps (86%)
20:25:28:WU01:FS01:0x21:Completed 11750000 out of 25000000 steps (47%)
20:25:34:WARNING:FS01:Size of positions 288 does not match topology 18
20:26:35:WU03:FS03:0x21:Completed 4350000 out of 5000000 steps (87%)
20:26:54:WU02:FS02:0x21:Completed 11250000 out of 25000000 steps (45%)
20:27:00:WARNING:FS02:Size of positions 286 does not match topology 11
20:28:21:WU05:FS05:0x21:Completed 4350000 out of 5000000 steps (87%)
20:30:28:WU03:FS03:0x21:Completed 4400000 out of 5000000 steps (88%)
20:32:16:WU05:FS05:0x21:Completed 4400000 out of 5000000 steps (88%)
20:32:45:WU01:FS01:0x21:Completed 12000000 out of 25000000 steps (48%)
20:32:50:WARNING:FS01:Size of positions 288 does not match topology 18
******************************* Date: 2019-05-02 *******************************
20:34:20:WU03:FS03:0x21:Completed 4450000 out of 5000000 steps (89%)
20:34:33:WU02:FS02:0x21:Completed 11500000 out of 25000000 steps (46%)
20:34:39:WARNING:FS02:Size of positions 286 does not match topology 11
20:36:11:WU05:FS05:0x21:Completed 4450000 out of 5000000 steps (89%)
20:38:13:WU03:FS03:0x21:Completed 4500000 out of 5000000 steps (90%)
20:38:20:WARNING:FS03:Size of positions 2073 does not match topology 2067
20:40:02:WU01:FS01:0x21:Completed 12250000 out of 25000000 steps (49%)
20:40:08:WARNING:FS01:Size of positions 288 does not match topology 18
20:40:08:WU05:FS05:0x21:Completed 4500000 out of 5000000 steps (90%)
20:42:10:WU03:FS03:0x21:Completed 4550000 out of 5000000 steps (91%)
20:42:16:WU02:FS02:0x21:Completed 11750000 out of 25000000 steps (47%)
20:42:21:WARNING:FS02:Size of positions 286 does not match topology 11
20:44:05:WU05:FS05:0x21:Completed 4550000 out of 5000000 steps (91%)
20:46:02:WU03:FS03:0x21:Completed 4600000 out of 5000000 steps (92%)
20:47:20:WU01:FS01:0x21:Completed 12500000 out of 25000000 steps (50%)
20:47:26:WARNING:FS01:Size of positions 288 does not match topology 18
20:47:59:WU05:FS05:0x21:Completed 4600000 out of 5000000 steps (92%)
20:49:53:WU03:FS03:0x21:Completed 4650000 out of 5000000 steps (93%)
20:49:58:WU02:FS02:0x21:Completed 12000000 out of 25000000 steps (48%)
20:50:03:WARNING:FS02:Size of positions 286 does not match topology 11
20:51:54:WU05:FS05:0x21:Completed 4650000 out of 5000000 steps (93%)
20:53:04:WU03:FS03:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
20:54:38:WU01:FS01:0x21:Completed 12750000 out of 25000000 steps (51%)
20:54:44:WARNING:FS01:Size of positions 288 does not match topology 18
20:55:51:WU05:FS05:0x21:Completed 4700000 out of 5000000 steps (94%)
20:57:00:WU03:FS03:0x21:Completed 4550000 out of 5000000 steps (91%)
20:57:45:WU02:FS02:0x21:Completed 12250000 out of 25000000 steps (49%)
20:57:50:WARNING:FS02:Size of positions 286 does not match topology 11
20:59:51:WU05:FS05:0x21:Completed 4750000 out of 5000000 steps (95%)
21:00:58:WU03:FS03:0x21:Completed 4600000 out of 5000000 steps (92%)
21:02:01:WU01:FS01:0x21:Completed 13000000 out of 25000000 steps (52%)
21:02:06:WARNING:FS01:Size of positions 288 does not match topology 18
21:03:50:WU05:FS05:0x21:Completed 4800000 out of 5000000 steps (96%)
21:03:52:FS01:Paused
21:03:52:FS02:Paused
21:03:52:FS03:Paused
21:03:52:FS04:Paused
21:03:52:FS05:Paused
21:03:52:FS06:Paused
21:03:52:FS01:Shutting core down
21:03:52:FS02:Shutting core down
21:03:52:FS03:Shutting core down
21:03:52:FS04:Shutting core down
21:03:52:FS05:Shutting core down
21:03:52:FS06:Shutting core down
21:03:52:WU05:FS05:0x21:WARNING:Console control signal 1 on PID 1872
21:03:52:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 7568
21:03:52:WU03:FS03:0x21:WARNING:Console control signal 1 on PID 7912
21:03:52:WU02:FS02:0x21:WARNING:Console control signal 1 on PID 2372
21:03:52:WU05:FS05:0x21:Exiting, please wait. . .
21:03:52:WU01:FS01:0x21:Exiting, please wait. . .
21:03:52:WU03:FS03:0x21:Exiting, please wait. . .
21:03:52:WU02:FS02:0x21:Exiting, please wait. . .
21:03:53:WU05:FS05:0x21:Folding@home Core Shutdown: INTERRUPTED
21:03:53:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
21:03:53:WU03:FS03:0x21:Folding@home Core Shutdown: INTERRUPTED
21:03:53:WU02:FS02:0x21:Folding@home Core Shutdown: INTERRUPTED
21:03:54:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:54:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:54:WU03:FS03:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:54:WU05:FS05:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:54:WU06:FS06:FahCore returned: INTERRUPTED (102 = 0x66)
21:03:54:WU00:FS04:FahCore returned: INTERRUPTED (102 = 0x66)
21:04:00:FS01:Unpaused
21:04:00:FS02:Unpaused
21:04:00:FS03:Unpaused
21:04:00:FS04:Unpaused
21:04:00:FS05:Unpaused
21:04:00:FS06:Unpaused
21:04:00:WU01:FS01:Starting
21:04:00:ERROR:WU01:FS01:Failed to start core: Failed to rename './work/01/logfile_01.txt' to './work/01/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:04:00:WU02:FS02:Starting
21:04:00:ERROR:WU02:FS02:Failed to start core: Failed to rename './work/02/logfile_01.txt' to './work/02/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:04:00:WU03:FS03:Starting
21:04:00:ERROR:WU03:FS03:Failed to start core: Failed to rename './work/03/logfile_01.txt' to './work/03/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:04:00:WU05:FS05:Starting
21:04:00:ERROR:WU05:FS05:Failed to start core: Failed to rename './work/05/logfile_01.txt' to './work/05/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:04:00:WU06:FS06:Starting
21:04:00:ERROR:WU06:FS06:Failed to start core: Failed to rename './work/06/logfile_01.txt' to './work/06/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:04:00:WU00:FS04:Starting
21:04:00:ERROR:WU00:FS04:Failed to start core: Failed to rename './work/00/logfile_01.txt' to './work/00/logfile_01-20190502-210400.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU01:FS01:Starting
21:05:37:ERROR:WU01:FS01:Failed to start core: Failed to rename './work/01/logfile_01.txt' to './work/01/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU02:FS02:Starting
21:05:37:ERROR:WU02:FS02:Failed to start core: Failed to rename './work/02/logfile_01.txt' to './work/02/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU03:FS03:Starting
21:05:37:ERROR:WU03:FS03:Failed to start core: Failed to rename './work/03/logfile_01.txt' to './work/03/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU05:FS05:Starting
21:05:37:ERROR:WU05:FS05:Failed to start core: Failed to rename './work/05/logfile_01.txt' to './work/05/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU06:FS06:Starting
21:05:37:ERROR:WU06:FS06:Failed to start core: Failed to rename './work/06/logfile_01.txt' to './work/06/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:05:37:WU00:FS04:Starting
21:05:37:ERROR:WU00:FS04:Failed to start core: Failed to rename './work/00/logfile_01.txt' to './work/00/logfile_01-20190502-210537.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU01:FS01:Starting
21:08:14:ERROR:WU01:FS01:Failed to start core: Failed to rename './work/01/logfile_01.txt' to './work/01/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU02:FS02:Starting
21:08:14:ERROR:WU02:FS02:Failed to start core: Failed to rename './work/02/logfile_01.txt' to './work/02/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU03:FS03:Starting
21:08:14:ERROR:WU03:FS03:Failed to start core: Failed to rename './work/03/logfile_01.txt' to './work/03/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU05:FS05:Starting
21:08:14:ERROR:WU05:FS05:Failed to start core: Failed to rename './work/05/logfile_01.txt' to './work/05/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU06:FS06:Starting
21:08:14:ERROR:WU06:FS06:Failed to start core: Failed to rename './work/06/logfile_01.txt' to './work/06/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
21:08:14:WU00:FS04:Starting
21:08:14:ERROR:WU00:FS04:Failed to start core: Failed to rename './work/00/logfile_01.txt' to './work/00/logfile_01-20190502-210814.txt': The process cannot access the file because it is being used by another process.
Re: 99.99% WU
F@H detected 0 GPUs, but you have 6 slots for GPUs.
I am assuming you really have 1 GPU.
Download the latest driver from AMD, and install it.
Uninstall F@H including data, then reinstall it.
If that doesn't work, repost the log.
Re: 99.99% WU
This is a very unusual configuration. It's going to take me some time to digest everything you log is telling me.
One obvious issue: Exception: Could not get IP address for assign2.foldingathome.org: No such host is known.[/u]
Has your internet crashed? Apparently DNS is not functioning. This is related to several other errors later in the log. Are you able to fix that problem?
One thing that's unusual is that your Intel(R) Pentium(R) CPU G4400 represents 2 CPU threads and you're attempting to run 6 GPUs. with only one of them. The general assumption is that one CPU thread is allocated for each GPU, and that's clearly not true in your case. In an attempt to get SOMETHING running, I recommend you start by doing a PAUSE of everything and then FOLD (unpause) two GPUs. Does that allow FAH to start running successfully?
Be_eLSeven
Re: 99.99% WU
i've another rig that also have 6 GPUs but running well.
The newest log file is below
Be_eLSeven
Re: 99.99% WU
*********************** Log Started 2019-05-02T23:58:22Z ***********************
23:58:22:************************* Folding@home Client *************************
23:58:22: Website: https://foldingathome.org/
23:58:22: Copyright: (c) 2009-2018 foldingathome.org
23:58:22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:58:22: Args: --open-web-control
23:58:22: Config: C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\config.xml
23:58:22:******************************** Build ********************************
23:58:22: Version: 7.5.1
23:58:22: Date: May 11 2018
23:58:22: Time: 13:06:32
23:58:22: Repository: Git
23:58:22: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:58:22: Branch: master
23:58:22: Compiler: Visual C++ 2008
23:58:22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:58:22: Platform: win32 10
23:58:22: Bits: 32
23:58:22: Mode: Release
23:58:22:******************************* System ********************************
23:58:22: CPU: Intel(R) Pentium(R) CPU G4400 @ 3.30GHz
23:58:22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:58:22: CPUs: 2
23:58:22: Memory: 7.89GiB
23:58:22: Free Memory: 5.59GiB
23:58:22: Threads: WINDOWS_THREADS
23:58:22: OS Version: 6.2
23:58:22: Has Battery: false
23:58:22: On Battery: false
23:58:22: UTC Offset: 7
23:58:22: PID: 8396
23:58:22: CWD: C:\Users\Be_eLSeven\AppData\Roaming\FAHClient
23:58:22: OS: Windows 10 Pro
23:58:22: OS Arch: AMD64
23:58:22: GPUs: 6
23:58:22: GPU 0: Bus:4 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: 470/480/570/580]
23:58:22: GPU 1: Bus:13 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: GPU 2: Bus:10 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: GPU 3: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: GPU 4: Bus:12 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: GPU 5: Bus:5 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
23:58:22: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
23:58:22: specified module could not be found.
23:58:22:
23:58:22:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
23:58:22:OpenCL Device 2: Platform:1 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:2580.6
23:58:22:OpenCL Device 3: Platform:1 Device:1 Bus:5 Slot:0 Compute:1.2 Driver:2580.6
23:58:22:OpenCL Device 4: Platform:1 Device:2 Bus:13 Slot:0 Compute:1.2 Driver:2580.6
23:58:22:OpenCL Device 5: Platform:1 Device:3 Bus:4 Slot:0 Compute:1.2 Driver:2580.6
23:58:22:OpenCL Device 6: Platform:1 Device:4 Bus:1 Slot:0 Compute:1.2 Driver:2580.6
23:58:22:OpenCL Device 7: Platform:1 Device:5 Bus:12 Slot:0 Compute:1.2 Driver:2580.6
23:58:22: Win32 Service: false
23:58:22:***********************************************************************
23:58:22:<config>
23:58:22: <!-- Network -->
23:58:22: <proxy v=':8080'/>
23:58:22:
23:58:22: <!-- User Information -->
23:58:22: <passkey v='********************************'/>
23:58:22: <team v='234980'/>
23:58:22: <user v='grlbeikp37ri'/>
23:58:22:
23:58:22: <!-- Folding Slots -->
23:58:22: <slot id='1' type='GPU'/>
23:58:22: <slot id='2' type='GPU'/>
23:58:22: <slot id='3' type='GPU'/>
23:58:22: <slot id='4' type='GPU'/>
23:58:22: <slot id='5' type='GPU'/>
23:58:22: <slot id='6' type='GPU'/>
23:58:22:</config>
23:58:22:Trying to access database...
23:58:23:Successfully acquired database lock
23:58:23:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:23:Enabled folding slot 02: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:23:Enabled folding slot 03: READY gpu:2:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:23:Enabled folding slot 04: READY gpu:3:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:23:Enabled folding slot 05: READY gpu:4:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:23:Enabled folding slot 06: READY gpu:5:Ellesmere XT [Radeon RX 470/480/570/580]
23:58:24:WU01:FS01:Starting
23:58:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 3 -gpu 3
23:58:25:WU01:FS01:Started FahCore on PID 6692
23:58:25:WU01:FS01:Core PID:5620
23:58:25:WU01:FS01:FahCore 0x21 started
23:58:26:WU02:FS02:Starting
23:58:27:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 2 -gpu 2
23:58:27:WU02:FS02:Started FahCore on PID 5788
23:58:27:WU02:FS02:Core PID:6128
23:58:27:WU02:FS02:FahCore 0x21 started
23:58:28:WU03:FS03:Starting
23:58:28:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
23:58:28:WU03:FS03:Started FahCore on PID 6624
23:58:28:WU03:FS03:Core PID:4232
23:58:28:WU03:FS03:FahCore 0x21 started
23:58:28:WU05:FS05:Starting
23:58:28:WU05:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 05 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 5 -gpu 5
23:58:28:WU05:FS05:Started FahCore on PID 7392
23:58:28:WU05:FS05:Core PID:7684
23:58:28:WU05:FS05:FahCore 0x21 started
23:58:29:WU03:FS03:0x21:*********************** Log Started 2019-05-02T23:58:28Z ***********************
23:58:29:WU03:FS03:0x21:Project: 11719 (Run 0, Clone 142, Gen 368)
23:58:29:WU03:FS03:0x21:Unit: 0x000001e08ca304e75b78c2e95d1b74ee
23:58:29:WU03:FS03:0x21:CPU: 0x00000000000000000000000000000000
23:58:29:WU03:FS03:0x21:Machine: 3
23:58:29:WU03:FS03:0x21:Digital signatures verified
23:58:29:WU03:FS03:0x21:Folding@home GPU Core21 Folding@home Core
23:58:29:WU03:FS03:0x21:Version 0.0.18
23:58:29:WU06:FS06:Starting
23:58:29:WU06:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 06 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 1 -gpu 1
23:58:29:WU06:FS06:Started FahCore on PID 7852
23:58:29:WU06:FS06:Core PID:9112
23:58:29:WU06:FS06:FahCore 0x21 started
23:58:30:WU01:FS01:0x21:*********************** Log Started 2019-05-02T23:58:29Z ***********************
23:58:30:WU01:FS01:0x21:Project: 14179 (Run 19, Clone 4, Gen 6)
23:58:30:WU01:FS01:0x21:Unit: 0x0000000b0002894c5cb38732aa09168d
23:58:30:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:58:30:WU01:FS01:0x21:Machine: 1
23:58:30:WU01:FS01:0x21:Digital signatures verified
23:58:30:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:58:30:WU01:FS01:0x21:Version 0.0.18
23:58:30:WU02:FS02:0x21:*********************** Log Started 2019-05-02T23:58:29Z ***********************
23:58:30:WU02:FS02:0x21:Project: 14127 (Run 16, Clone 2, Gen 191)
23:58:30:WU02:FS02:0x21:Unit: 0x000000ee0002894c5c06fbd3ad67a1b8
23:58:30:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
23:58:30:WU02:FS02:0x21:Machine: 2
23:58:30:WU02:FS02:0x21:Digital signatures verified
23:58:30:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
23:58:30:WU02:FS02:0x21:Version 0.0.18
23:58:30:WU06:FS06:0x21:*********************** Log Started 2019-05-02T23:58:30Z ***********************
23:58:30:WU06:FS06:0x21:Project: 11728 (Run 0, Clone 240, Gen 486)
23:58:30:WU06:FS06:0x21:Unit: 0x000002918ca304e75b95bb388b572bf3
23:58:30:WU06:FS06:0x21:CPU: 0x00000000000000000000000000000000
23:58:30:WU06:FS06:0x21:Machine: 6
23:58:30:WU05:FS05:0x21:*********************** Log Started 2019-05-02T23:58:30Z ***********************
23:58:30:WU05:FS05:0x21:Project: 11726 (Run 0, Clone 1136, Gen 312)
23:58:30:WU05:FS05:0x21:Unit: 0x000001a48ca304e75b95ba15d00cfff2
23:58:30:WU05:FS05:0x21:CPU: 0x00000000000000000000000000000000
23:58:30:WU05:FS05:0x21:Machine: 5
23:58:30:WU05:FS05:0x21:Digital signatures verified
23:58:30:WU05:FS05:0x21:Folding@home GPU Core21 Folding@home Core
23:58:30:WU05:FS05:0x21:Version 0.0.18
23:58:30:WU06:FS06:0x21:Reading tar file core.xml
23:58:30:WU06:FS06:0x21:Reading tar file integrator.xml
23:58:30:WU06:FS06:0x21:Reading tar file state.xml
23:58:30:WU00:FS04:Starting
23:58:31:WU00:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 4 -gpu 4
23:58:31:WU00:FS04:Started FahCore on PID 2484
23:58:31:WU00:FS04:Core PID:2652
23:58:31:WU00:FS04:FahCore 0x21 started
23:58:31:WU00:FS04:0x21:*********************** Log Started 2019-05-02T23:58:31Z ***********************
23:58:31:WU00:FS04:0x21:Project: 14177 (Run 19, Clone 5, Gen 16)
23:58:31:WU00:FS04:0x21:Unit: 0x000000140002894c5cae6aab093a0c13
23:58:31:WU00:FS04:0x21:CPU: 0x00000000000000000000000000000000
23:58:31:WU00:FS04:0x21:Machine: 4
23:58:32:WU00:FS04:0x21:Reading tar file core.xml
23:58:32:WU00:FS04:0x21:Reading tar file integrator.xml
23:58:32:WU00:FS04:0x21:Reading tar file state.xml
23:58:32:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:32:WU00:FS04:0x21:Reading tar file system.xml
23:58:32:WU00:FS04:0x21:Digital signatures verified
23:58:32:WU00:FS04:0x21:Folding@home GPU Core21 Folding@home Core
23:58:32:WU00:FS04:0x21:Version 0.0.18
23:58:33:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:34:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:35:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:36:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:37:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:38:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:39:WU06:FS06:0x21:Reading tar file system.xml
23:58:39:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:40:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:41:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:42:WARNING:FS01:Size of positions 288 does not match topology 18
23:58:43:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:43:WU03:FS03:0x21: Found a checkpoint file
23:58:43:WU05:FS05:0x21: Found a checkpoint file
23:58:43:WU01:FS01:0x21: Found a checkpoint file
23:58:43:WU02:FS02:0x21: Found a checkpoint file
23:58:44:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:45:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:46:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:47:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:48:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:49:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:50:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:51:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:52:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:53:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:55:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:56:WU06:FS06:0x21:Digital signatures verified
23:58:56:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:56:WU06:FS06:0x21:Folding@home GPU Core21 Folding@home Core
23:58:56:WU06:FS06:0x21:Version 0.0.18
23:58:57:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:58:WARNING:FS02:Size of positions 286 does not match topology 11
23:58:59:WARNING:FS02:Size of positions 286 does not match topology 11
23:59:00:WARNING:FS02:Size of positions 286 does not match topology 11
23:59:00:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:01:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:02:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:03:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:04:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:05:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:06:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:07:WARNING:FS03:Size of positions 2073 does not match topology 2067
23:59:34:WU02:FS02:0x21:Completed 12250000 out of 25000000 steps (49%)
23:59:34:WU00:FS04:0x21:Completed 0 out of 25000000 steps (0%)
23:59:34:WU01:FS01:0x21:Completed 13000000 out of 25000000 steps (52%)
23:59:35:WU06:FS06:0x21:Completed 0 out of 5000000 steps (0%)
23:59:35:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:35:WU00:FS04:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:35:WU05:FS05:0x21:Completed 4750000 out of 5000000 steps (95%)
23:59:35:WU06:FS06:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:35:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:35:WU03:FS03:0x21:Completed 4500000 out of 5000000 steps (90%)
23:59:35:WU05:FS05:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:35:WU03:FS03:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:36:WU00:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:02:16:WU06:FS06:0x21:Completed 50000 out of 5000000 steps (1%)
00:03:00:WU03:FS03:0x21:Completed 4550000 out of 5000000 steps (91%)
00:03:06:WU05:FS05:0x21:Completed 4800000 out of 5000000 steps (96%)
00:04:51:WU06:FS06:0x21:Completed 100000 out of 5000000 steps (2%)
00:06:19:WU03:FS03:0x21:Completed 4600000 out of 5000000 steps (92%)
00:06:24:WU01:FS01:0x21:Completed 13250000 out of 25000000 steps (53%)
00:06:29:WARNING:FS01:Size of positions 288 does not match topology 18
00:06:31:WU05:FS05:0x21:Completed 4850000 out of 5000000 steps (97%)
00:06:54:WU02:FS02:0x21:Completed 12500000 out of 25000000 steps (50%)
00:07:00:WARNING:FS02:Size of positions 286 does not match topology 11
00:07:24:WU06:FS06:0x21:Completed 150000 out of 5000000 steps (3%)
00:09:35:WU03:FS03:0x21:Completed 4650000 out of 5000000 steps (93%)
00:09:55:WU05:FS05:0x21:Completed 4900000 out of 5000000 steps (98%)
00:09:57:WU06:FS06:0x21:Completed 200000 out of 5000000 steps (4%)
00:12:29:WU06:FS06:0x21:Completed 250000 out of 5000000 steps (5%)
00:12:52:WU03:FS03:0x21:Completed 4700000 out of 5000000 steps (94%)
00:13:06:WU01:FS01:0x21:Completed 13500000 out of 25000000 steps (54%)
00:13:12:WARNING:FS01:Size of positions 288 does not match topology 18
00:13:18:WU05:FS05:0x21:Completed 4950000 out of 5000000 steps (99%)
00:13:20:WU04:FS05:Connecting to 65.254.110.245:8080
00:13:22:WU04:FS05:Assigned to work server 128.252.203.4
00:13:22:WU04:FS05:Requesting new work unit for slot 05: RUNNING gpu:4:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.4
00:13:22:WU04:FS05:Connecting to 128.252.203.4:8080
00:13:23:WU04:FS05:Downloading 11.66MiB
00:13:29:WU04:FS05:Download 14.47%
00:13:35:WU04:FS05:Download 46.63%
00:13:41:WU04:FS05:Download 78.79%
00:13:45:WU04:FS05:Download complete
00:13:45:WU04:FS05:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2779 gen:171 core:0x21 unit:0x000000e980fccb045b3f79138d20820f
00:14:05:WU02:FS02:0x21:Completed 12750000 out of 25000000 steps (51%)
00:14:10:WARNING:FS02:Size of positions 286 does not match topology 11
00:15:02:WU06:FS06:0x21:Completed 300000 out of 5000000 steps (6%)
00:16:07:WU03:FS03:0x21:Completed 4750000 out of 5000000 steps (95%)
00:16:14:WARNING:FS03:Size of positions 2073 does not match topology 2067
00:16:41:WU05:FS05:0x21:Completed 5000000 out of 5000000 steps (100%)
00:16:43:WU05:FS05:0x21:Saving result file logfile_01.txt
00:16:43:WU05:FS05:0x21:Saving result file checkpointState.xml
00:16:43:WU05:FS05:0x21:Saving result file checkpt.crc
00:16:43:WU05:FS05:0x21:Saving result file log.txt
00:16:43:WU05:FS05:0x21:Saving result file positions.xtc
00:16:43:WU05:FS05:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:17:34:WU06:FS06:0x21:Completed 350000 out of 5000000 steps (7%)
00:19:23:WU03:FS03:0x21:Completed 4800000 out of 5000000 steps (96%)
00:19:47:WU01:FS01:0x21:Completed 13750000 out of 25000000 steps (55%)
00:19:53:WARNING:FS01:Size of positions 288 does not match topology 18
00:20:04:WU06:FS06:0x21:Completed 400000 out of 5000000 steps (8%)
00:21:16:WU02:FS02:0x21:Completed 13000000 out of 25000000 steps (52%)
00:21:21:WARNING:FS02:Size of positions 286 does not match topology 11
00:22:35:WU06:FS06:0x21:Completed 450000 out of 5000000 steps (9%)
00:22:37:WU03:FS03:0x21:Completed 4850000 out of 5000000 steps (97%)
00:25:05:WU06:FS06:0x21:Completed 500000 out of 5000000 steps (10%)
00:25:51:WU03:FS03:0x21:Completed 4900000 out of 5000000 steps (98%)
00:26:27:WU01:FS01:0x21:Completed 14000000 out of 25000000 steps (56%)
00:26:32:WARNING:FS01:Size of positions 288 does not match topology 18
00:27:37:WU06:FS06:0x21:Completed 550000 out of 5000000 steps (11%)
00:28:25:WU02:FS02:0x21:Completed 13250000 out of 25000000 steps (53%)
00:28:30:WARNING:FS02:Size of positions 286 does not match topology 11
00:29:04:WU03:FS03:0x21:Completed 4950000 out of 5000000 steps (99%)
00:29:05:WU07:FS03:Connecting to 65.254.110.245:8080
00:29:06:WU07:FS03:Assigned to work server 155.247.166.220
00:29:06:WU07:FS03:Requesting new work unit for slot 03: RUNNING gpu:2:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
00:29:06:WU07:FS03:Connecting to 155.247.166.220:8080
00:29:08:WU07:FS03:Downloading 995.50KiB
00:29:14:WU07:FS03:Download 96.43%
00:29:14:WU07:FS03:Download complete
00:29:14:WU07:FS03:Received Unit: id:07 state:DOWNLOAD error:NO_ERROR project:14176 run:57 clone:1 gen:23 core:0x21 unit:0x000000210002894c5cae69f4cbdf4aee
00:30:07:WU06:FS06:0x21:Completed 600000 out of 5000000 steps (12%)
00:32:17:WU03:FS03:0x21:Completed 5000000 out of 5000000 steps (100%)
00:32:19:WU03:FS03:0x21:Saving result file logfile_01.txt
00:32:19:WU03:FS03:0x21:Saving result file checkpointState.xml
00:32:19:WU03:FS03:0x21:Saving result file checkpt.crc
00:32:19:WU03:FS03:0x21:Saving result file log.txt
00:32:19:WU03:FS03:0x21:Saving result file positions.xtc
00:32:19:WU03:FS03:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:32:24:WARNING:FS03:Size of positions 2073 does not match topology 2067
00:32:37:WU06:FS06:0x21:Completed 650000 out of 5000000 steps (13%)
00:33:06:WU01:FS01:0x21:Completed 14250000 out of 25000000 steps (57%)
00:33:11:WARNING:FS01:Size of positions 288 does not match topology 18
00:35:07:WU06:FS06:0x21:Completed 700000 out of 5000000 steps (14%)
00:35:34:WU02:FS02:0x21:Completed 13500000 out of 25000000 steps (54%)
00:35:39:WARNING:FS02:Size of positions 286 does not match topology 11
00:37:36:WU06:FS06:0x21:Completed 750000 out of 5000000 steps (15%)
00:39:25:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:39:43:WU01:FS01:0x21:Completed 14500000 out of 25000000 steps (58%)
00:39:49:WARNING:FS01:Size of positions 288 does not match topology 18
00:41:54:WU06:FS06:0x21:Completed 800000 out of 5000000 steps (16%)
00:42:41:WU02:FS02:0x21:Completed 13750000 out of 25000000 steps (55%)
00:42:47:WARNING:FS02:Size of positions 286 does not match topology 11
00:44:23:WU06:FS06:0x21:Completed 850000 out of 5000000 steps (17%)
00:46:21:WU01:FS01:0x21:Completed 14750000 out of 25000000 steps (59%)
00:46:26:WARNING:FS01:Size of positions 288 does not match topology 18
00:46:53:WU06:FS06:0x21:Completed 900000 out of 5000000 steps (18%)
00:49:22:WU06:FS06:0x21:Completed 950000 out of 5000000 steps (19%)
00:49:47:WU02:FS02:0x21:Completed 14000000 out of 25000000 steps (56%)
00:49:53:WARNING:FS02:Size of positions 286 does not match topology 11
00:51:51:WU06:FS06:0x21:Completed 1000000 out of 5000000 steps (20%)
00:52:58:WU01:FS01:0x21:Completed 15000000 out of 25000000 steps (60%)
00:53:04:WARNING:FS01:Size of positions 288 does not match topology 18
00:54:22:WU06:FS06:0x21:Completed 1050000 out of 5000000 steps (21%)
00:56:51:WU06:FS06:0x21:Completed 1100000 out of 5000000 steps (22%)
00:56:53:WU02:FS02:0x21:Completed 14250000 out of 25000000 steps (57%)
00:56:58:WARNING:FS02:Size of positions 286 does not match topology 11
00:59:21:WU06:FS06:0x21:Completed 1150000 out of 5000000 steps (23%)
00:59:36:WU01:FS01:0x21:Completed 15250000 out of 25000000 steps (61%)
00:59:42:WARNING:FS01:Size of positions 288 does not match topology 18
01:01:50:WU06:FS06:0x21:Completed 1200000 out of 5000000 steps (24%)
01:03:57:WU02:FS02:0x21:Completed 14500000 out of 25000000 steps (58%)
01:04:03:WARNING:FS02:Size of positions 286 does not match topology 11
01:04:19:WU06:FS06:0x21:Completed 1250000 out of 5000000 steps (25%)
01:06:14:WU01:FS01:0x21:Completed 15500000 out of 25000000 steps (62%)
01:06:19:WARNING:FS01:Size of positions 288 does not match topology 18
01:06:49:WU06:FS06:0x21:Completed 1300000 out of 5000000 steps (26%)
01:09:19:WU06:FS06:0x21:Completed 1350000 out of 5000000 steps (27%)
01:11:03:WU02:FS02:0x21:Completed 14750000 out of 25000000 steps (59%)
01:11:08:WARNING:FS02:Size of positions 286 does not match topology 11
01:11:48:WU06:FS06:0x21:Completed 1400000 out of 5000000 steps (28%)
01:12:52:WU01:FS01:0x21:Completed 15750000 out of 25000000 steps (63%)
01:12:57:WARNING:FS01:Size of positions 288 does not match topology 18
01:14:18:WU06:FS06:0x21:Completed 1450000 out of 5000000 steps (29%)
01:16:47:WU06:FS06:0x21:Completed 1500000 out of 5000000 steps (30%)
01:18:10:WU02:FS02:0x21:Completed 15000000 out of 25000000 steps (60%)
01:18:16:WARNING:FS02:Size of positions 286 does not match topology 11
01:19:17:WU06:FS06:0x21:Completed 1550000 out of 5000000 steps (31%)
01:19:29:WU01:FS01:0x21:Completed 16000000 out of 25000000 steps (64%)
01:19:35:WARNING:FS01:Size of positions 288 does not match topology 18
01:21:46:WU06:FS06:0x21:Completed 1600000 out of 5000000 steps (32%)
01:24:16:WU06:FS06:0x21:Completed 1650000 out of 5000000 steps (33%)
01:25:17:WU02:FS02:0x21:Completed 15250000 out of 25000000 steps (61%)
01:25:22:WARNING:FS02:Size of positions 286 does not match topology 11
01:26:07:WU01:FS01:0x21:Completed 16250000 out of 25000000 steps (65%)
01:26:12:WARNING:FS01:Size of positions 288 does not match topology 18
01:26:45:WU06:FS06:0x21:Completed 1700000 out of 5000000 steps (34%)
01:29:14:WU06:FS06:0x21:Completed 1750000 out of 5000000 steps (35%)
01:31:44:WU06:FS06:0x21:Completed 1800000 out of 5000000 steps (36%)
01:32:25:WU02:FS02:0x21:Completed 15500000 out of 25000000 steps (62%)
01:32:30:WARNING:FS02:Size of positions 286 does not match topology 11
01:32:44:WU01:FS01:0x21:Completed 16500000 out of 25000000 steps (66%)
01:32:49:WARNING:FS01:Size of positions 288 does not match topology 18
01:34:14:WU06:FS06:0x21:Completed 1850000 out of 5000000 steps (37%)
01:36:43:WU06:FS06:0x21:Completed 1900000 out of 5000000 steps (38%)
01:39:12:WU06:FS06:0x21:Completed 1950000 out of 5000000 steps (39%)
01:39:22:WU01:FS01:0x21:Completed 16750000 out of 25000000 steps (67%)
01:39:27:WARNING:FS01:Size of positions 288 does not match topology 18
01:39:32:WU02:FS02:0x21:Completed 15750000 out of 25000000 steps (63%)
01:39:37:WARNING:FS02:Size of positions 286 does not match topology 11
01:41:41:WU06:FS06:0x21:Completed 2000000 out of 5000000 steps (40%)
01:44:12:WU06:FS06:0x21:Completed 2050000 out of 5000000 steps (41%)
01:45:59:WU01:FS01:0x21:Completed 17000000 out of 25000000 steps (68%)
01:46:05:WARNING:FS01:Size of positions 288 does not match topology 18
01:46:40:WU02:FS02:0x21:Completed 16000000 out of 25000000 steps (64%)
01:46:41:WU06:FS06:0x21:Completed 2100000 out of 5000000 steps (42%)
01:46:46:WARNING:FS02:Size of positions 286 does not match topology 11
01:49:11:WU06:FS06:0x21:Completed 2150000 out of 5000000 steps (43%)
01:51:40:WU06:FS06:0x21:Completed 2200000 out of 5000000 steps (44%)
01:52:38:WU01:FS01:0x21:Completed 17250000 out of 25000000 steps (69%)
01:52:43:WARNING:FS01:Size of positions 288 does not match topology 18
01:53:48:WU02:FS02:0x21:Completed 16250000 out of 25000000 steps (65%)
01:53:53:WARNING:FS02:Size of positions 286 does not match topology 11
01:54:10:WU06:FS06:0x21:Completed 2250000 out of 5000000 steps (45%)
01:56:40:WU06:FS06:0x21:Completed 2300000 out of 5000000 steps (46%)
01:59:10:WU06:FS06:0x21:Completed 2350000 out of 5000000 steps (47%)
01:59:15:WU01:FS01:0x21:Completed 17500000 out of 25000000 steps (70%)
01:59:21:WARNING:FS01:Size of positions 288 does not match topology 18
02:00:52:WU02:FS02:0x21:Completed 16500000 out of 25000000 steps (66%)
02:00:57:WARNING:FS02:Size of positions 286 does not match topology 11
02:01:39:WU06:FS06:0x21:Completed 2400000 out of 5000000 steps (48%)
02:04:08:WU06:FS06:0x21:Completed 2450000 out of 5000000 steps (49%)
02:05:53:WU01:FS01:0x21:Completed 17750000 out of 25000000 steps (71%)
02:05:58:WARNING:FS01:Size of positions 288 does not match topology 18
02:06:38:WU06:FS06:0x21:Completed 2500000 out of 5000000 steps (50%)
02:07:58:WU02:FS02:0x21:Completed 16750000 out of 25000000 steps (67%)
02:08:03:WARNING:FS02:Size of positions 286 does not match topology 11
02:09:08:WU06:FS06:0x21:Completed 2550000 out of 5000000 steps (51%)
02:11:38:WU06:FS06:0x21:Completed 2600000 out of 5000000 steps (52%)
02:12:31:WU01:FS01:0x21:Completed 18000000 out of 25000000 steps (72%)
02:12:36:WARNING:FS01:Size of positions 288 does not match topology 18
02:14:07:WU06:FS06:0x21:Completed 2650000 out of 5000000 steps (53%)
02:15:04:WU02:FS02:0x21:Completed 17000000 out of 25000000 steps (68%)
02:15:09:WARNING:FS02:Size of positions 286 does not match topology 11
02:16:36:WU06:FS06:0x21:Completed 2700000 out of 5000000 steps (54%)
02:19:06:WU06:FS06:0x21:Completed 2750000 out of 5000000 steps (55%)
02:19:09:WU01:FS01:0x21:Completed 18250000 out of 25000000 steps (73%)
02:19:14:WARNING:FS01:Size of positions 288 does not match topology 18
02:21:36:WU06:FS06:0x21:Completed 2800000 out of 5000000 steps (56%)
02:22:09:WU02:FS02:0x21:Completed 17250000 out of 25000000 steps (69%)
02:22:15:WARNING:FS02:Size of positions 286 does not match topology 11
02:24:06:WU06:FS06:0x21:Completed 2850000 out of 5000000 steps (57%)
02:25:46:WU01:FS01:0x21:Completed 18500000 out of 25000000 steps (74%)
02:25:52:WARNING:FS01:Size of positions 288 does not match topology 18
02:26:35:WU06:FS06:0x21:Completed 2900000 out of 5000000 steps (58%)
02:28:57:FS03:Paused
02:28:57:FS03:Shutting core down
02:28:57:WU03:FS03:FahCore returned: INTERRUPTED (102 = 0x66)
02:29:06:WU06:FS06:0x21:Completed 2950000 out of 5000000 steps (59%)
02:29:11:FS05:Paused
02:29:12:FS05:Shutting core down
02:29:12:WU05:FS05:FahCore returned: INTERRUPTED (102 = 0x66)
02:29:17:WU02:FS02:0x21:Completed 17500000 out of 25000000 steps (70%)
02:29:22:WARNING:FS02:Size of positions 286 does not match topology 11
02:29:26:FS03:Unpaused
02:29:26:WU03:FS03:Starting
02:29:26:ERROR:WU03:FS03:Failed to start core: Failed to rename './work/03/logfile_01.txt' to './work/03/logfile_01-20190503-022926.txt': The process cannot access the file because it is being used by another process.
02:29:38:FS05:Unpaused
02:29:38:WU05:FS05:Starting
02:29:38:ERROR:WU05:FS05:Failed to start core: Failed to rename './work/05/logfile_01.txt' to './work/05/logfile_01-20190503-022938.txt': The process cannot access the file because it is being used by another process.
02:31:03:WU03:FS03:Starting
02:31:03:ERROR:WU03:FS03:Failed to start core: Failed to rename './work/03/logfile_01.txt' to './work/03/logfile_01-20190503-023103.txt': The process cannot access the file because it is being used by another process.
02:31:15:WU05:FS05:Starting
02:31:15:ERROR:WU05:FS05:Failed to start core: Failed to rename './work/05/logfile_01.txt' to './work/05/logfile_01-20190503-023115.txt': The process cannot access the file because it is being used by another process.
02:31:36:WU06:FS06:0x21:Completed 3000000 out of 5000000 steps (60%)
02:32:25:WU01:FS01:0x21:Completed 18750000 out of 25000000 steps (75%)
02:32:31:WARNING:FS01:Size of positions 288 does not match topology 18
02:32:40:WU07:FS03:Starting
02:32:40:WU07:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 07 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
02:32:40:WU07:FS03:Started FahCore on PID 8868
02:32:40:WU07:FS03:Core PID:8168
02:32:40:WU07:FS03:FahCore 0x21 started
02:32:41:WU07:FS03:0x21:*********************** Log Started 2019-05-03T02:32:40Z ***********************
02:32:41:WU07:FS03:0x21:Project: 14176 (Run 57, Clone 1, Gen 23)
02:32:41:WU07:FS03:0x21:Unit: 0x000000210002894c5cae69f4cbdf4aee
02:32:41:WU07:FS03:0x21:CPU: 0x00000000000000000000000000000000
02:32:41:WU07:FS03:0x21:Machine: 3
02:32:41:WU07:FS03:0x21:Reading tar file core.xml
02:32:41:WU07:FS03:0x21:Reading tar file integrator.xml
02:32:41:WU07:FS03:0x21:Reading tar file state.xml
02:32:41:WU07:FS03:0x21:Reading tar file system.xml
02:32:41:WU07:FS03:0x21:Digital signatures verified
02:32:41:WU07:FS03:0x21:Folding@home GPU Core21 Folding@home Core
02:32:41:WU07:FS03:0x21:Version 0.0.18
02:32:52:WU04:FS05:Starting
02:32:52:WU04:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Be_eLSeven\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 04 -suffix 01 -version 705 -lifeline 8396 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 5 -gpu 5
02:32:52:WU04:FS05:Started FahCore on PID 6752
02:32:52:WU04:FS05:Core PID:2504
02:32:52:WU04:FS05:FahCore 0x21 started
02:32:52:WU04:FS05:0x21:*********************** Log Started 2019-05-03T02:32:52Z ***********************
02:32:52:WU04:FS05:0x21:Project: 13816 (Run 0, Clone 2779, Gen 171)
02:32:52:WU04:FS05:0x21:Unit: 0x000000e980fccb045b3f79138d20820f
02:32:52:WU04:FS05:0x21:CPU: 0x00000000000000000000000000000000
02:32:52:WU04:FS05:0x21:Machine: 5
02:32:52:WU04:FS05:0x21:Reading tar file core.xml
02:32:52:WU04:FS05:0x21:Reading tar file integrator.xml
02:32:52:WU04:FS05:0x21:Reading tar file state.xml
02:32:52:WU04:FS05:0x21:Reading tar file system.xml
02:32:52:WU04:FS05:0x21:Digital signatures verified
02:32:52:WU04:FS05:0x21:Folding@home GPU Core21 Folding@home Core
02:32:52:WU04:FS05:0x21:Version 0.0.18
02:34:07:WU06:FS06:0x21:Completed 3050000 out of 5000000 steps (61%)
02:34:15:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:36:27:WU02:FS02:0x21:Completed 17750000 out of 25000000 steps (71%)
02:36:32:WARNING:FS02:Size of positions 286 does not match topology 11
02:39:03:WU01:FS01:0x21:Completed 19000000 out of 25000000 steps (76%)
02:39:08:WARNING:FS01:Size of positions 288 does not match topology 18
02:39:14:WU06:FS06:0x21:Completed 3100000 out of 5000000 steps (62%)
02:41:43:WU06:FS06:0x21:Completed 3150000 out of 5000000 steps (63%)
02:43:37:WU02:FS02:0x21:Completed 18000000 out of 25000000 steps (72%)
02:43:42:WARNING:FS02:Size of positions 286 does not match topology 11
02:44:13:WU06:FS06:0x21:Completed 3200000 out of 5000000 steps (64%)
02:45:40:WU01:FS01:0x21:Completed 19250000 out of 25000000 steps (77%)
02:45:46:WARNING:FS01:Size of positions 288 does not match topology 18
02:46:42:WU06:FS06:0x21:Completed 3250000 out of 5000000 steps (65%)
02:49:12:WU06:FS06:0x21:Completed 3300000 out of 5000000 steps (66%)
02:50:44:WU02:FS02:0x21:Completed 18250000 out of 25000000 steps (73%)
02:50:50:WARNING:FS02:Size of positions 286 does not match topology 11
02:51:42:WU06:FS06:0x21:Completed 3350000 out of 5000000 steps (67%)
02:52:18:WU01:FS01:0x21:Completed 19500000 out of 25000000 steps (78%)
02:52:24:WARNING:FS01:Size of positions 288 does not match topology 18
02:54:11:WU06:FS06:0x21:Completed 3400000 out of 5000000 steps (68%)
02:56:40:WU06:FS06:0x21:Completed 3450000 out of 5000000 steps (69%)
02:57:52:WU02:FS02:0x21:Completed 18500000 out of 25000000 steps (74%)
02:57:57:WARNING:FS02:Size of positions 286 does not match topology 11
02:58:56:WU01:FS01:0x21:Completed 19750000 out of 25000000 steps (79%)
02:59:01:WARNING:FS01:Size of positions 288 does not match topology 18
02:59:10:WU06:FS06:0x21:Completed 3500000 out of 5000000 steps (70%)
03:01:41:WU06:FS06:0x21:Completed 3550000 out of 5000000 steps (71%)
Be_eLSeven
Re: 99.99% WU
i do what your suggestion.... pause 2 gpus and then fold ....
both are running but not fold
Re: 99.99% WU
Pause 4 GPUs and 1 CPU.
Did you fix your internet?
Restart FAH and post the new log.
Re: 99.99% WU
The latest log you posted doesn't look so bad (but pretty much unreadable with so many slots) ... I see a couple of Bad States detected, but none that failed a WU ...
You should remove the the CPU slot, it will be pretty much useless with such CPU that will be busy feeding the GPUs ...
Re: 99.99% WU
It is GPU folding slots 3 and 4 and 6 which are unstable for FAH, so reduce its overclock.
14:48:53:WU07:FS04:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:34:10:WU06:FS06:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
As already said remove the CPU slot.
Re: 99.99% WU
Which slot/which WU has reached 99.99%? Remove that slot and post that segment of the log.
