could you help me?
please add NVIDIA TITAN V
necropowerLamas
I am using folding with my nivida titan V, but it is not ever surpassing 10% of usage
could you help me?
could you help me?
Re: please add NVIDIA TITAN V
You would not be able to fold if the Titan V had not already been added over a year ago.
As for utilization, how are you checking that? There are many posts here where persons are either using the wrong tool or using one incorrectly to see how their GPU is being used.
P.S. I have removed the unnecessary images from your post.
By the way, if you're "using the wrong tool" and you'd like to see your CPU busier, allocate some threads to a CPU slot. It's very likely that only 10% of your CPU is being used - with 90% idle.
Windows 10 Taskmanager does not show the right GPU usage for FAH as it is not doing any 3D but only compute on GPU. MSI Afterburner e.g. does show the right GPU usage (also for non MSI GPUs)
As reported here, all Volta GPUs are supported : viewtopic.php?p=303507#p303507
necropowerLamas
thank you, using gpu-z i saw the gpu being with 80% cargo-loaded
sorry for the post then ;(
