GTX1080 not working
mrindian1947
GTX1080 not working
Post by mrindian1947 »
Hello,
I've been folding for the past year on this computer with a GTX1080 and have been avg 650-750k ppd.
I had to reset my system and reinstall the OS win10
Now the same setup is getting 8,000 ppd and taking 11min per fold.
Something is not right and I can't figure it out.
20:34:03:Saving configuration to config.xml
20:34:03:<config>
20:34:03: <!-- Network -->
20:34:03: <proxy v=':8080'/>
20:34:03:
20:34:03: <!-- User Information -->
20:34:03: <passkey v='********************************'/>
20:34:03: <team v='40051'/>
20:34:03: <user v='MRIndian1947'/>
20:34:03:
20:34:03: <!-- Folding Slots -->
20:34:03: <slot id='0' type='CPU'>
20:34:03: <paused v='true'/>
20:34:03: </slot>
20:34:03: <slot id='1' type='GPU'/>
20:34:03:</config>
20:34:15:WU01:FS01:0x21:Completed 0 out of 25000000 steps (0%)
20:34:15:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:45:05:WU01:FS01:0x21:Completed 250000 out of 25000000 steps (1%)
Re: GTX1080 not working
Post by foldy »
Guess you need to download and reinstall the nvidia drivers from nvidia.com. You need to post the missing beginning of the logfile.
mrindian1947
I've reinstalled the latest nvidia drivers and no luck and went back to drivers from december and still get the same results
As of now it's at 11min / fold and 100k ppd far from where it should be performing.
Thanks for any help
*********************** Log Started 2019-04-10T20:32:01Z ***********************
20:32:01:************************* Folding@home Client *************************
20:32:01: Website: https://foldingathome.org/
20:32:01: Copyright: (c) 2009-2018 foldingathome.org
20:32:01: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:32:01: Args: --open-web-control
20:32:01: Config: <none>
20:32:01:******************************** Build ********************************
20:32:01: Version: 7.5.1
20:32:01: Date: May 11 2018
20:32:01: Time: 13:06:32
20:32:01: Repository: Git
20:32:01: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:32:01: Branch: master
20:32:01: Compiler: Visual C++ 2008
20:32:01: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:32:01: Platform: win32 10
20:32:01: Bits: 32
20:32:01: Mode: Release
20:32:01:******************************* System ********************************
20:32:01: CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
20:32:01: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
20:32:01: CPUs: 8
20:32:01: Memory: 5.99GiB
20:32:01: Free Memory: 3.07GiB
20:32:01: Threads: WINDOWS_THREADS
20:32:01: OS Version: 6.2
20:32:01: Has Battery: false
20:32:01: On Battery: false
20:32:01: UTC Offset: -7
20:32:01: PID: 3508
20:32:01: CWD: C:\Users\New Pc Repair\AppData\Roaming\FAHClient
20:32:01: OS: Windows 8 Pro
20:32:01: OS Arch: AMD64
20:32:01: GPUs: 0
20:32:01: CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:10.1
20:32:01:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:419.67
20:32:01: Win32 Service: false
20:32:01:***********************************************************************
20:32:01:<config>
20:32:01: <!-- Folding Slots -->
20:32:01:</config>
20:32:01:Connecting to assign1.foldingathome.org:8080
20:32:01:Updated GPUs.txt
20:32:01:Read GPUs.txt
20:32:01:Trying to access database...
20:32:01:Successfully acquired database lock
20:32:01:Enabled folding slot 00: PAUSED cpu:6 (not configured)
20:32:01:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1080] 8873 (not configured)
I think your config.xml file describes a system you no longer have.
If you uninstall F@H including removing the Data, it should build a new config.xml from scratch. That sadly forgets your valid info, but more importantly, the info that is wrong.
My Win 10 box has config.xml at C:\Users\JimboPalmer\AppData\Roaming\FAHClient You may be able to print out the old one, delete it, and restart (or reinstall) F@H.
mrindian1947
Per the previous comment - new install of FAH with deleting data and still slow performance:
*********************** Log Started 2019-04-10T22:12:37Z ***********************
22:12:37:************************* Folding@home Client *************************
22:12:37:        Website: https://foldingathome.org/
22:12:37:      Copyright: (c) 2009-2018 foldingathome.org
22:12:37:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:12:37:           Args:
22:12:37:         Config: C:\Users\New Pc Repair\AppData\Roaming\FAHClient\config.xml
22:12:37:******************************** Build ********************************
22:12:37:        Version: 7.5.1
22:12:37:           Date: May 11 2018
22:12:37:           Time: 13:06:32
22:12:37:     Repository: Git
22:12:37:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:12:37:         Branch: master
22:12:37:       Compiler: Visual C++ 2008
22:12:37:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:12:37:       Platform: win32 10
22:12:37:           Bits: 32
22:12:37:           Mode: Release
22:12:37:******************************* System ********************************
22:12:37:            CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
22:12:37:         CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
22:12:37:           CPUs: 8
22:12:37:         Memory: 5.99GiB
22:12:37:    Free Memory: 4.26GiB
22:12:37:        Threads: WINDOWS_THREADS
22:12:37:     OS Version: 6.2
22:12:37:    Has Battery: false
22:12:37:     On Battery: false
22:12:37:     UTC Offset: -7
22:12:37:            PID: 9612
22:12:37:            CWD: C:\Users\New Pc Repair\AppData\Roaming\FAHClient
22:12:37:             OS: Windows 8 Pro
22:12:37:        OS Arch: AMD64
22:12:37:           GPUs: 1
22:12:37:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1080] 8873
22:12:37:  CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:10.1
22:12:37:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:419.67
22:12:37:  Win32 Service: false
22:12:37:***********************************************************************
22:12:37:<config>
22:12:37:  <!-- Network -->
22:12:37:  <proxy v=':8080'/>
22:12:37:
22:12:37:  <!-- User Information -->
22:12:37:  <passkey v='********************************'/>
22:12:37:  <team v='40051'/>
22:12:37:  <user v='MRIndian1947'/>
22:12:37:
22:12:37:  <!-- Folding Slots -->
22:12:37:  <slot id='0' type='CPU'>
22:12:37:    <paused v='true'/>
22:12:37:  </slot>
22:12:37:  <slot id='1' type='GPU'/>
22:12:37:</config>
22:12:37:Trying to access database...
22:12:37:Successfully acquired database lock
22:12:37:Enabled folding slot 00: PAUSED cpu:6 (by user)
22:12:37:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873
22:12:37:WU01:FS01:Starting
22:12:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\New Pc Repair\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 9612 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:12:37:WU01:FS01:Started FahCore on PID 8664
22:12:37:WU01:FS01:Core PID:9344
22:12:37:WU01:FS01:FahCore 0x21 started
22:12:39:WU01:FS01:0x21:*********************** Log Started 2019-04-10T22:12:38Z ***********************
22:12:39:WU01:FS01:0x21:Project: 14124 (Run 36, Clone 41, Gen 27)
22:12:39:WU01:FS01:0x21:Unit: 0x000000250002894c5c61660d2cd0e40f
22:12:39:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
22:12:39:WU01:FS01:0x21:Machine: 1
22:12:39:WU01:FS01:0x21:Digital signatures verified
22:12:39:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
22:12:39:WU01:FS01:0x21:Version 0.0.18
22:12:39:WU01:FS01:0x21:  Found a checkpoint file
22:13:13:WU01:FS01:0x21:Completed 2250000 out of 25000000 steps (9%)
22:13:13:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
bollix47
Post by bollix47 »
I too have a 1080 and the TPFs for all projects are under 4 minutes so you definitely have a hardware or setting problem somewhere as opposed to just a Passkey mistype although when you were getting 8000 PPD a wrong Passkey may have had something to do with such a low number.
As for hardware ensure the power connector that goes to the top of the GPU is firmly seated so that it's getting all the power it needs. If you didn't open up the computer during your "reset" then that's probably not applicable.
One of the settings to check would be in the Power under Control Panel ... ensure it's set to High Performance.
If neither of those solve your problem come back and update us on any changes the above might have caused.
This worries me, if you deleted all the data, I am not sure how it found a checkpoint file. However, even an old checkpoint file should only apply to the current WU, perhaps it will be faster next WU.
bollix47
Post by bollix47 »
Have you checked Task Manager to see if another process is using a lot of CPU resources? The folding process does run at a pretty low priority so if something else is using a lot of CPU that can cause a folding slowdown for your GPU as the CPU is used to 'feed' the GPU.
bollix47 wrote:The folding process does run at a pretty low priority so if something else is using a lot of CPU that can cause a folding slowdown for your GPU as the CPU is used to 'feed' the GPU.
One way to test this is to PAUSE the GPU slot(s) and compare the CPU utilization. If you have K CPU threads, the total CPU utilization should free up 1/K of your CPU utilization (i.e.- it should go down by about 1/K) meaning the suspended FAHCore had at least one free thread it could use.
