FAH isnt working
carljones
FAH isnt working
Post by carljones »
Hello, im new to the forum but have tired folding in the past with success. my knowledge of these things is fairly limited so excuse my lack of knowledge however Folding@home does not work. I've looked at posts that appear to have the same problem as me but restarting, re-installing (something ive tried multiple times) and manually deleting anything to do with folding@home hasn't solved the issue so i thought id turn to you for some help. when i've completed the install the Folding@home icon appears on my desktop but when clicked it does nothing, FAHclient appears in my task manager but other than that nothing much happens.
Also ive now just noticed it says GPU 0 but ive got a GTX1070 so presumably ive got like....at least one right?
i read somewhere that the log is helpful for solving issues so ill paste it below. thanks in advance i just want to get folding!
*********************** Log Started 2019-03-24T08:39:02Z ***********************
08:39:02:************************* Folding@home Client *************************
08:39:02:      Website: https://foldingathome.org/
08:39:02:    Copyright: (c) 2009-2018 foldingathome.org
08:39:02:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:39:02:         Args:
08:39:02:       Config: <none>
08:39:02:******************************** Build ********************************
08:39:02:      Version: 7.5.1
08:39:02:         Date: May 11 2018
08:39:02:         Time: 13:06:32
08:39:02:   Repository: Git
08:39:02:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:39:02:       Branch: master
08:39:02:     Compiler: Visual C++ 2008
08:39:02:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:39:02:     Platform: win32 10
08:39:02:         Bits: 32
08:39:02:         Mode: Release
08:39:02:******************************* System ********************************
08:39:02:          CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
08:39:02:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:39:02:         CPUs: 4
08:39:02:       Memory: 15.93GiB
08:39:02:  Free Memory: 11.90GiB
08:39:02:      Threads: WINDOWS_THREADS
08:39:02:   OS Version: 6.2
08:39:02:  Has Battery: false
08:39:02:   On Battery: false
08:39:02:   UTC Offset: 0
08:39:02:          PID: 15316
08:39:02:          CWD: C:\Program Files (x86)\FAHClient
08:39:02:           OS: Windows 10 Home
08:39:02:      OS Arch: AMD64
08:39:02:         GPUs: 0
08:39:02:CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:10.1
08:39:02:       OpenCL: Not detected
08:39:02:Win32 Service: false
08:39:02:***********************************************************************
08:39:02:<config>
08:39:02:  <!-- Folding Slots -->
08:39:02:</config>
08:39:02:Connecting to assign1.foldingathome.org:8080
08:39:03:Updated GPUs.txt
08:39:03:Read GPUs.txt
08:39:03:Trying to access database...
08:39:03:Successfully acquired database lock
08:39:03:Enabled folding slot 00: PAUSED cpu:2 (not configured)
08:39:37:WARNING:Console control signal 2 on PID 15316
08:39:37:Exiting, please wait. . .
Re: FAH isnt working
1) Go to NVidia.com and install the drivers for your GTX 1070
2) I'm not sure if you'll need to reinstall FAH or just reboot.
3) Are you installing FAH when logged on as your "normal" user or are you installing with one windows user and then trying to run it as another user? You should use the same one.
carljones
Post by carljones »
Hiya, when installing I use my normal account. I’m the only one with an account on my PC. The drivers are already installed for my 1070.
If you have drivers installed after being downloaded from MS through Windows Update, you will need to follow step 1 that Bruce posted, get them from nVidia. The drivers MS distributes usually lack the OpenCL support needed for F@h, that is the likely cause of this message in your log - "08:39:02: OpenCL: Not detected". The full driver download from nVidia includes that OpenCL support.
carljones
Post by carljones »
Okay cheers, ill give it a go and let you know what happens.
carljones
Post by carljones »
okay so ive checked and i have the latest drivers for my card.
https://www.geforce.com/drivers/results/144363
Download it, honest.
If your only use of graphics is Folding@ Home, then all you need is the Graphics Driver. If you use the PC for other tasks, I would install the entire download.
I am not sure how, but you also have no CPU slot defined. I would enable one generic CPU slot.
In Advanced Control, Configure, Slots, Add, and click the radio button for CPUs.
carljones
Post by carljones »
i installed the drivers via your link and re-installed Folding@home a nd also restarted my PC but i cant open anything apart from the FAHclient still
Rats, Show us the first 100 lines of the log again, and lets see what it shows now.
carljones
Post by carljones »
appreciate all the help so far :)
*********************** Log Started 2019-03-24T19:01:21Z ***********************
19:01:21:************************* Folding@home Client *************************
19:01:21: Website: https://foldingathome.org/
19:01:21: Copyright: (c) 2009-2018 foldingathome.org
19:01:21: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:01:21: Args: --open-web-control
19:01:21: Config: <none>
19:01:21:******************************** Build ********************************
19:01:21: Version: 7.5.1
19:01:21: Date: May 11 2018
19:01:21: Time: 13:06:32
19:01:21: Repository: Git
19:01:21: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:01:21: Branch: master
19:01:21: Compiler: Visual C++ 2008
19:01:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:01:21: Platform: win32 10
19:01:21: Bits: 32
19:01:21: Mode: Release
19:01:21:******************************* System ********************************
19:01:21: CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
19:01:21: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:01:21: CPUs: 4
19:01:21: Memory: 15.93GiB
19:01:21: Free Memory: 11.69GiB
19:01:21: Threads: WINDOWS_THREADS
19:01:21: OS Version: 6.2
19:01:21: Has Battery: false
19:01:21: On Battery: false
19:01:21: UTC Offset: 0
19:01:21: PID: 2516
19:01:21: CWD: C:\Users\carlj\AppData\Roaming\FAHClient
19:01:21: OS: Windows 10 Home
19:01:21: OS Arch: AMD64
19:01:21: GPUs: 0
19:01:21:CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:10.1
19:01:21: OpenCL: Not detected
19:01:21:Win32 Service: false
19:01:21:***********************************************************************
19:01:21:<config>
19:01:21: <!-- Folding Slots -->
19:01:21:</config>
19:01:21:Connecting to assign1.foldingathome.org:8080
19:01:22:Updated GPUs.txt
19:01:22:Read GPUs.txt
19:01:22:Trying to access database...
19:01:22:Successfully acquired database lock
19:01:22:Enabled folding slot 00: PAUSED cpu:2 (not configured)
It still say "19:01:21: OpenCL: Not detected"
Ordinarily, nVidia will run a small java application to detect the characteristics of your system and choose the best version of the drivers. Then you'll be asked a few questions:
Did you choose the "Game ready drivers" or the "Creator ready drivers"?
As JimboPalmer said above, if you choose the "custom" screen, you can un-check everything except the graphics driver ... or you can accept the default to install everything.
I linked him right to the latest Game Ready Driver
GPU-Z is a program that checks out your Graphics Card, along the bottom of the screen it shows check boxes for OpenCL, CUDA, PhysX, and DirectCompute.
Knowing if GPU-Z saw OpenCL would leave us with a F@H problem, not a driver problem. (if you re-install F@H, be sure to delete Data, so it has to look at your hardware again)
https://www.techpowerup.com/download/techpowerup-gpu-z/
carljones
Post by carljones »
hello was sleeping then working, where does FAH put the data on a normal or express install? just want to double check im getting rid of it
bollix47
Post by bollix47 »
FAH Cannot work if you open the executable file in "Program Files" Microsoft prevents you from downloading data files where program files are supposed to reside.
If you use the shortcuts provided, you'll see
and FAH will be able to write it's working files where there's supposed to be.
