Loss of GPU config of GTX750 Ti
new08
- Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021] - Location: England
I've been folding ok on this card for a few weeks running at around 100k ppd.
I took the Slot out whilst updating driver/reboot but on return I can't reinsert the GPU for work.
This worked ok a few times before, when testing earlier, but now stalls- putting another CPU slot in instead, which is annoying as a backlog of CPU work has built up now. It doesn't offer a GPU slot to save.
The GPU is in the Whitelist and worked well till now.
I reverted the driver back to the earlier [working] one- to no effect.
Can't figure what's changed.
No log- as GPU isn't starting up
Re: Loss of GPU config of GTX750 Ti
AFTER installing the new driver, check if OpenCL is present and install it if necessary. Then reinstall FAHClient. FAH should configure the slot automatically during installation if the drivers are working.
new08
Runs F@H Ver7.6.21
I tried that but still the same. The setup log showed GPU present.
Maybe I need to completely remove FAH Client & then reinstall?
This would probably lose current work.
I ran GPU Shark shader utility and it showed 200fps & the GPU temp rose to normal working too.
10:14:16: GPUs: 1
10:14:16: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM107 [GeForce GTX 750 Ti] 1306
10:14:16: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:9.1
10:14:16:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:391.35
10:14:16: GPUs: 1
Are you running fah on Linux or Windows?
new08
Runs F@H Ver7.6.21
Win10 Seems to be stable and is up to date.
I'm thinking of just removing both CPU cores from client when current work is done- and seeing if that does the trick on re-instating along with the GPU, whicxh is otherwise fine.
Client for CPU seems to be stuck on 'Core 2' only, one running 2- and the other 1 of the 4 cores, but the logic escapes me on the config tbh!
Post the top couple of pages of the log and point out the problem.
new08
Runs F@H Ver7.6.21
The only bit about GPU is above- but I will get back with the CPU output.
Have recall how to curtail the text..
new08
Runs F@H Ver7.6.21
*********************** Log Started 2019-02-24T10:14:16Z ***********************
10:14:16:************************* Folding@home Client *************************
10:14:16: Website: https://foldingathome.org/
10:14:16: Copyright: (c) 2009-2018 foldingathome.org
10:14:16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:14:16: Args: --open-web-control
10:14:16: Config: C:\Users\Admin\AppData\Roaming\FAHClient\config.xml
10:14:16:******************************** Build ********************************
10:14:16: Version: 7.5.1
10:14:16: Date: May 11 2018
10:14:16: Time: 13:06:32
10:14:16: Repository: Git
10:14:16: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:14:16: Branch: master
10:14:16: Compiler: Visual C++ 2008
10:14:16: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:14:16: Platform: win32 10
10:14:16: Bits: 32
10:14:16: Mode: Release
10:14:16:******************************* System ********************************
10:14:16: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
10:14:16: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:14:16: CPUs: 4
10:14:16: Memory: 3.96GiB
10:14:16: Free Memory: 1.44GiB
10:14:16: Threads: WINDOWS_THREADS
10:14:16: OS Version: 6.2
10:14:16: Has Battery: false
10:14:16: On Battery: false
10:14:16: UTC Offset: 0
10:14:16: PID: 1488
10:14:16: CWD: C:\Users\Admin\AppData\Roaming\FAHClient
10:14:16: OS: Windows 10 Enterprise
10:14:16: OS Arch: AMD64
10:14:16: GPUs: 1
10:14:16: Win32 Service: false
10:14:16:***********************************************************************
10:14:16:<config>
10:14:16: <service-description v='Folding@home Client'/>
10:14:16: <service-restart v='true'/>
10:14:16: <service-restart-delay v='5000'/>
10:14:16:
10:14:16: <!-- Client Control -->
10:14:16: <client-threads v='6'/>
10:14:16: <cycle-rate v='4'/>
10:14:16: <cycles v='-1'/>
10:14:16: <data-directory v='.'/>
10:14:16: <disable-sleep-when-active v='true'/>
10:14:16: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
10:14:16: <exit-when-done v='false'/>
10:14:16: <fold-anon v='false'/>
10:14:16: <open-web-control v='true'/>
10:14:16:
10:14:16: <!-- Configuration -->
10:14:16: <config-rotate v='true'/>
10:14:16: <config-rotate-dir v='configs'/>
10:14:16: <config-rotate-max v='16'/>
10:14:16:
10:14:16: <!-- Debugging -->
10:14:16: <assignment-servers>
10:14:16: assign1.foldingathome.org:8080 assign2.foldingathome.org:80
10:14:16: </assignment-servers>
10:14:16: <auth-as v='true'/>
10:14:16: <capture-directory v='capture'/>
10:14:16: <capture-on-error v='false'/>
10:14:16: <capture-packets v='false'/>
10:14:16: <capture-requests v='false'/>
10:14:16: <capture-responses v='false'/>
10:14:16: <capture-sockets v='false'/>
10:14:16: <core-exec v='FahCore_$type'/>
10:14:16: <core-wrapper-exec v='FAHCoreWrapper'/>
10:14:16: <debug-sockets v='false'/>
10:14:16: <exception-locations v='true'/>
10:14:16: <stack-traces v='false'/>
10:14:16:
10:14:16: <!-- Error Handling -->
10:14:16: <max-slot-errors v='10'/>
10:14:16: <max-unit-errors v='5'/>
10:14:16:
10:14:16: <!-- Folding Core -->
10:14:16: <checkpoint v='20'/>
10:14:16: <core-dir v='cores'/>
10:14:16: <core-priority v='idle'/>
10:14:16: <cpu-affinity v='false'/>
10:14:16: <cpu-usage v='100'/>
10:14:16: <gpu-usage v='100'/>
10:14:16: <no-assembly v='false'/>
10:14:16:
10:14:16: <!-- Folding Slot Configuration -->
10:14:16: <cause v='ANY'/>
10:14:16: <client-subtype v='STDCLI'/>
10:14:16: <client-type v='normal'/>
10:14:16: <cpu-species v='X86_PENTIUM_II'/>
10:14:16: <cpu-type v='AMD64'/>
10:14:16: <cpus v='-1'/>
10:14:16: <disable-viz v='false'/>
10:14:16: <gpu v='true'/>
10:14:16: <max-packet-size v='normal'/>
10:14:16: <os-species v='WIN_8'/>
10:14:16: <os-type v='WIN32'/>
10:14:16: <project-key v='0'/>
10:14:16: <smp v='true'/>
10:14:16:
10:14:16: <!-- GUI -->
10:14:16: <gui-enabled v='true'/>
10:14:16:
10:14:16: <!-- HTTP Server -->
10:14:16: <allow v='127.0.0.1'/>
10:14:16: <connection-timeout v='60'/>
10:14:16: <deny v='0/0'/>
10:14:16: <http-addresses v='0:7396'/>
10:14:16: <https-addresses v=''/>
10:14:16: <max-connect-time v='900'/>
10:14:16: <max-connections v='800'/>
10:14:16: <max-request-length v='52428800'/>
10:14:16: <min-connect-time v='300'/>
10:14:16:
10:14:16: <!-- Logging -->
10:14:16: <log v='log.txt'/>
10:14:16: <log-color v='false'/>
10:14:16: <log-crlf v='true'/>
10:14:16: <log-date v='false'/>
10:14:16: <log-date-periodically v='21600'/>
10:14:16: <log-domain v='false'/>
10:14:16: <log-header v='true'/>
10:14:16: <log-level v='true'/>
10:14:16: <log-no-info-header v='true'/>
10:14:16: <log-redirect v='false'/>
10:14:16: <log-rotate v='true'/>
10:14:16: <log-rotate-dir v='logs'/>
10:14:16: <log-rotate-max v='16'/>
10:14:16: <log-short-level v='false'/>
10:14:16: <log-simple-domains v='true'/>
10:14:16: <log-thread-id v='false'/>
10:14:16: <log-thread-prefix v='true'/>
10:14:16: <log-time v='true'/>
10:14:16: <log-to-screen v='true'/>
10:14:16: <log-truncate v='false'/>
10:14:16: <verbosity v='4'/>
10:14:16:
10:14:16: <!-- Network -->
10:14:16: <proxy v=':8080'/>
10:14:16: <proxy-enable v='false'/>
10:14:16: <proxy-pass v=''/>
10:14:16: <proxy-user v=''/>
10:14:16:
10:14:16: <!-- Process Control -->
10:14:16: <child v='false'/>
10:14:16: <daemon v='false'/>
10:14:16: <pid v='false'/>
10:14:16: <pid-file v='Folding@home Client.pid'/>
10:14:16: <respawn v='false'/>
10:14:16: <service v='false'/>
10:14:16:
10:14:16: <!-- Remote Command Server -->
10:14:16: <command-address v='0.0.0.0'/>
10:14:16: <command-allow-no-pass v='127.0.0.1'/>
10:14:16: <command-deny-no-pass v='0/0'/>
10:14:16: <command-enable v='true'/>
10:14:16: <command-port v='36330'/>
10:14:16:
10:14:16: <!-- Slot Control -->
10:14:16: <idle v='false'/>
10:14:16: <max-shutdown-wait v='60'/>
10:14:16: <pause-on-battery v='false'/>
10:14:16: <pause-on-start v='false'/>
10:14:16: <paused v='false'/>
10:14:16: <power v='full'/>
10:14:16:Re: Loss of GPU config of GTX750 Ti
See Posting FAH's log:
"How to provide enough info to get helpful support." in the sig block of my first post (above). De-cluttter your post by resetting verbosity back to the default value of 3
new08
Runs F@H Ver7.6.21
I resolved the problem by clean uninstalling the 7.5.1 Client using IO Bit utility and reinstalled/configured ok and back in business.
I doubt there is much in the log to pinpoint the cause of the slot configure glitch.
The config file isn't viewable in text now, so no help there & it will have changed.
That the first report I've see of that. What does it look like in FAHControl?new08 wrote:The config file isn't viewable in text now, so no help there ...
new08
Runs F@H Ver7.6.21
That looks normal -apart from an additional new Extra Client option open-web-control =true.
This is now the ok install, though.
new08
Runs F@H Ver7.6.21
I happened to catch a post that could have helped here, explaining how the GPU isn't recognised on reboot and inserting it manually as an extra client forces the issue.
There is a known problem where the client gets started and configured before detecting the GPU and its driver.
That creates the <gpu v='false'/> entry in the configuration and the client does not download and install the GPUs.txt file.
To fix this, open FAHControl and use its Configure control. On the Expert tab add an Extra Client Option, name would be gpu with the value true. Save the changed configuration and restart your system. When restarted the client should now download an updated GPUs.txt file, at worst you might need to do that manually and place it in /var/lib/fahclient.
