[SOLVED] Not being awarded bonus points
SoulReaper
Post by SoulReaper »
Hello
I had recently issued a passkey for my username
The Windows Client shows correctly the amount of bonus I will get after processing a WU
The log shows the estimate score that I should be awarded for a WU
But the stats page does not reflect the bonus and just awards me the base score.
I have tried this on an Ubuntu Client as well and the same thing happens, I get just the base score against my username.
What could be wrong here?
I have searched the forum for this issue, but everyone has a different problem which causes this to happen.
Please suggest me a starting point for troubleshooting
18:50:33:FS02:Unpaused
18:50:33:WU00:FS02:Starting
18:50:33:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\SR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 4948 -checkpoint 15 -np 3
18:50:33:WU00:FS02:Started FahCore on PID 19980
18:50:33:WU00:FS02:Core PID:20648
18:50:33:WU00:FS02:FahCore 0xa7 started
18:50:34:WU00:FS02:0xa7:*********************** Log Started 2019-01-27T18:50:33Z ***********************
18:50:34:WU00:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
18:50:34:WU00:FS02:0xa7:       Type: 0xa7
18:50:34:WU00:FS02:0xa7:       Core: Gromacs
18:50:34:WU00:FS02:0xa7:    Website: https://foldingathome.org/
18:50:34:WU00:FS02:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
18:50:34:WU00:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:34:WU00:FS02:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 19980 -checkpoint 15 -np
18:50:34:WU00:FS02:0xa7:             3
18:50:34:WU00:FS02:0xa7:     Config: <none>
18:50:34:WU00:FS02:0xa7:************************************ Build *************************************
18:50:34:WU00:FS02:0xa7:    Version: 0.0.17
18:50:34:WU00:FS02:0xa7:       Date: Apr 27 2018
18:50:34:WU00:FS02:0xa7:       Time: 16:19:36
18:50:34:WU00:FS02:0xa7: Repository: Git
18:50:34:WU00:FS02:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
18:50:34:WU00:FS02:0xa7:     Branch: master
18:50:34:WU00:FS02:0xa7:   Compiler: Visual C++ 2008
18:50:34:WU00:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:50:34:WU00:FS02:0xa7:   Platform: win32 10
18:50:34:WU00:FS02:0xa7:       Bits: 64
18:50:34:WU00:FS02:0xa7:       Mode: Release
18:50:34:WU00:FS02:0xa7:       SIMD: avx_256
18:50:34:WU00:FS02:0xa7:************************************ System ************************************
18:50:34:WU00:FS02:0xa7:        CPU: Unknown
18:50:34:WU00:FS02:0xa7:     CPU ID:
18:50:34:WU00:FS02:0xa7:       CPUs: 4
18:50:34:WU00:FS02:0xa7:     Memory: 11.88GiB
18:50:34:WU00:FS02:0xa7:Free Memory: 8.60GiB
18:50:34:WU00:FS02:0xa7:    Threads: WINDOWS_THREADS
18:50:34:WU00:FS02:0xa7: OS Version: 6.1
18:50:34:WU00:FS02:0xa7:Has Battery: false
18:50:34:WU00:FS02:0xa7: On Battery: false
18:50:34:WU00:FS02:0xa7: UTC Offset: 5
18:50:34:WU00:FS02:0xa7:        PID: 20648
18:50:34:WU00:FS02:0xa7:        CWD: C:\Users\SR\AppData\Roaming\FAHClient\work
18:50:34:WU00:FS02:0xa7:         OS: Windows 7 Ultimate
18:50:34:WU00:FS02:0xa7:    OS Arch: AMD64
18:50:34:WU00:FS02:0xa7:********************************************************************************
18:50:34:WU00:FS02:0xa7:Project: 13813 (Run 0, Clone 1378, Gen 166)
18:50:34:WU00:FS02:0xa7:Unit: 0x000000de80fccb025ae0902bc0a01bea
18:50:34:WU00:FS02:0xa7:Digital signatures verified
18:50:34:WU00:FS02:0xa7:Calling: mdrun -s frame166.tpr -o frame166.trr -x frame166.xtc -cpi state.cpt -cpt 15 -nt 3
18:50:34:WU00:FS02:0xa7:Steps: first=41500000 total=250000
18:50:38:WU00:FS02:0xa7:Completed 112601 out of 250000 steps (45%)
18:51:20:Removing old file 'configs/config-20190114-183118.xml'
18:51:20:Saving configuration to config.xml
18:51:20:<config>
18:51:20:  <!-- Folding Slot Configuration -->
18:51:20:  <cause v='CANCER'/>
18:51:20:
18:51:20:  <!-- Network -->
18:51:20:  <proxy v=':8080'/>
18:51:20:
18:51:20:  <!-- Slot Control -->
18:51:20:  <power v='light'/>
18:51:20:
18:51:20:  <!-- User Information -->
18:51:20:  <passkey v='********************************'/>
18:51:20:  <team v='xxxx'/>
18:51:20:  <user v='xxxx'/>
18:51:20:
18:51:20:  <!-- Folding Slots -->
18:51:20:  <slot id='2' type='CPU'>
18:51:20:    <cpus v='3'/>
18:51:20:  </slot>
18:51:20:</config>
19:04:05:WU00:FS02:0xa7:Completed 115000 out of 250000 steps (46%)
19:18:05:WU00:FS02:0xa7:Completed 117500 out of 250000 steps (47%)
19:32:05:WU00:FS02:0xa7:Completed 120000 out of 250000 steps (48%)
19:46:05:WU00:FS02:0xa7:Completed 122500 out of 250000 steps (49%)
20:00:03:WU00:FS02:0xa7:Completed 125000 out of 250000 steps (50%)
20:14:03:WU00:FS02:0xa7:Completed 127500 out of 250000 steps (51%)
20:28:03:WU00:FS02:0xa7:Completed 130000 out of 250000 steps (52%)
20:42:00:WU00:FS02:0xa7:Completed 132500 out of 250000 steps (53%)
20:55:58:WU00:FS02:0xa7:Completed 135000 out of 250000 steps (54%)
21:09:55:WU00:FS02:0xa7:Completed 137500 out of 250000 steps (55%)
21:23:53:WU00:FS02:0xa7:Completed 140000 out of 250000 steps (56%)
21:37:51:WU00:FS02:0xa7:Completed 142500 out of 250000 steps (57%)
21:51:50:WU00:FS02:0xa7:Completed 145000 out of 250000 steps (58%)
22:05:50:WU00:FS02:0xa7:Completed 147500 out of 250000 steps (59%)
22:19:50:WU00:FS02:0xa7:Completed 150000 out of 250000 steps (60%)
22:33:52:WU00:FS02:0xa7:Completed 152500 out of 250000 steps (61%)
22:47:51:WU00:FS02:0xa7:Completed 155000 out of 250000 steps (62%)
23:01:51:WU00:FS02:0xa7:Completed 157500 out of 250000 steps (63%)
23:15:58:WU00:FS02:0xa7:Completed 160000 out of 250000 steps (64%)
23:29:57:WU00:FS02:0xa7:Completed 162500 out of 250000 steps (65%)
23:43:57:WU00:FS02:0xa7:Completed 165000 out of 250000 steps (66%)
23:57:56:WU00:FS02:0xa7:Completed 167500 out of 250000 steps (67%)
00:11:54:WU00:FS02:0xa7:Completed 170000 out of 250000 steps (68%)
00:25:55:WU00:FS02:0xa7:Completed 172500 out of 250000 steps (69%)
00:40:00:WU00:FS02:0xa7:Completed 175000 out of 250000 steps (70%)
******************************* Date: 2019-01-28 *******************************
00:53:59:WU00:FS02:0xa7:Completed 177500 out of 250000 steps (71%)
01:07:57:WU00:FS02:0xa7:Completed 180000 out of 250000 steps (72%)
01:21:56:WU00:FS02:0xa7:Completed 182500 out of 250000 steps (73%)
01:35:56:WU00:FS02:0xa7:Completed 185000 out of 250000 steps (74%)
01:49:52:WU00:FS02:0xa7:Completed 187500 out of 250000 steps (75%)
02:03:50:WU00:FS02:0xa7:Completed 190000 out of 250000 steps (76%)
02:17:50:WU00:FS02:0xa7:Completed 192500 out of 250000 steps (77%)
02:31:51:WU00:FS02:0xa7:Completed 195000 out of 250000 steps (78%)
02:45:49:WU00:FS02:0xa7:Completed 197500 out of 250000 steps (79%)
02:59:48:WU00:FS02:0xa7:Completed 200000 out of 250000 steps (80%)
03:13:48:WU00:FS02:0xa7:Completed 202500 out of 250000 steps (81%)
03:27:48:WU00:FS02:0xa7:Completed 205000 out of 250000 steps (82%)
03:41:49:WU00:FS02:0xa7:Completed 207500 out of 250000 steps (83%)
03:55:47:WU00:FS02:0xa7:Completed 210000 out of 250000 steps (84%)
04:09:45:WU00:FS02:0xa7:Completed 212500 out of 250000 steps (85%)
04:23:45:WU00:FS02:0xa7:Completed 215000 out of 250000 steps (86%)
04:37:53:WU00:FS02:0xa7:Completed 217500 out of 250000 steps (87%)
04:51:57:WU00:FS02:0xa7:Completed 220000 out of 250000 steps (88%)
05:05:56:WU00:FS02:0xa7:Completed 222500 out of 250000 steps (89%)
05:19:54:WU00:FS02:0xa7:Completed 225000 out of 250000 steps (90%)
05:34:27:WU00:FS02:0xa7:Completed 227500 out of 250000 steps (91%)
05:48:40:WU00:FS02:0xa7:Completed 230000 out of 250000 steps (92%)
06:04:45:WU00:FS02:0xa7:Completed 232500 out of 250000 steps (93%)
06:19:34:WU00:FS02:0xa7:Completed 235000 out of 250000 steps (94%)
06:33:43:WU00:FS02:0xa7:Completed 237500 out of 250000 steps (95%)
06:47:46:WU00:FS02:0xa7:Completed 240000 out of 250000 steps (96%)
07:03:53:WU00:FS02:0xa7:Completed 242500 out of 250000 steps (97%)
07:20:22:WU00:FS02:0xa7:Completed 245000 out of 250000 steps (98%)
07:34:48:WU00:FS02:0xa7:Completed 247500 out of 250000 steps (99%)
07:34:50:WU01:FS02:Connecting to 65.254.110.245:8080
07:34:52:WU01:FS02:Assigned to work server 155.247.166.219
07:34:52:WU01:FS02:Requesting new work unit for slot 02: RUNNING cpu:3 from 155.247.166.219
07:34:52:WU01:FS02:Connecting to 155.247.166.219:8080
07:34:54:WU01:FS02:Downloading 1.45MiB
07:34:59:WU01:FS02:Download complete
07:34:59:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14137 run:18 clone:153 gen:18 core:0xa7 unit:0x000000140002894b5c00470d04208e90
07:48:57:WU00:FS02:0xa7:Completed 250000 out of 250000 steps (100%)
07:49:10:WU00:FS02:0xa7:Saving result file ..\logfile_01.txt
07:49:10:WU00:FS02:0xa7:Saving result file frame166.trr
07:49:10:WU00:FS02:0xa7:Saving result file frame166.xtc
07:49:10:WU00:FS02:0xa7:Saving result file md.log
07:49:10:WU00:FS02:0xa7:Saving result file science.log
07:49:10:WU00:FS02:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
07:49:11:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:49:11:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:13813 run:0 clone:1378 gen:166 core:0xa7 unit:0x000000de80fccb025ae0902bc0a01bea
07:49:11:WU00:FS02:Uploading 10.50MiB to 128.252.203.2
07:49:11:WU00:FS02:Connecting to 128.252.203.2:8080
07:49:11:WU01:FS02:Starting
07:49:11:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\SR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4948 -checkpoint 15 -np 3
07:49:11:WU01:FS02:Started FahCore on PID 14636
07:49:11:WU01:FS02:Core PID:25652
07:49:11:WU01:FS02:FahCore 0xa7 started
07:49:12:WU01:FS02:0xa7:*********************** Log Started 2019-01-28T07:49:12Z ***********************
07:49:12:WU01:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
07:49:12:WU01:FS02:0xa7:       Type: 0xa7
07:49:12:WU01:FS02:0xa7:       Core: Gromacs
07:49:12:WU01:FS02:0xa7:    Website: https://foldingathome.org/
07:49:12:WU01:FS02:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
07:49:12:WU01:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:49:12:WU01:FS02:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 14636 -checkpoint 15 -np
07:49:12:WU01:FS02:0xa7:             3
07:49:12:WU01:FS02:0xa7:     Config: <none>
07:49:12:WU01:FS02:0xa7:************************************ Build *************************************
07:49:12:WU01:FS02:0xa7:    Version: 0.0.17
07:49:12:WU01:FS02:0xa7:       Date: Apr 27 2018
07:49:12:WU01:FS02:0xa7:       Time: 16:19:36
07:49:12:WU01:FS02:0xa7: Repository: Git
07:49:12:WU01:FS02:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
07:49:12:WU01:FS02:0xa7:     Branch: master
07:49:12:WU01:FS02:0xa7:   Compiler: Visual C++ 2008
07:49:12:WU01:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:49:12:WU01:FS02:0xa7:   Platform: win32 10
07:49:12:WU01:FS02:0xa7:       Bits: 64
07:49:12:WU01:FS02:0xa7:       Mode: Release
07:49:12:WU01:FS02:0xa7:       SIMD: avx_256
07:49:12:WU01:FS02:0xa7:************************************ System ************************************
07:49:12:WU01:FS02:0xa7:        CPU: Unknown
07:49:12:WU01:FS02:0xa7:     CPU ID:
07:49:12:WU01:FS02:0xa7:       CPUs: 4
07:49:12:WU01:FS02:0xa7:     Memory: 11.88GiB
07:49:12:WU01:FS02:0xa7:Free Memory: 7.78GiB
07:49:12:WU01:FS02:0xa7:    Threads: WINDOWS_THREADS
07:49:12:WU01:FS02:0xa7: OS Version: 6.1
07:49:12:WU01:FS02:0xa7:Has Battery: false
07:49:12:WU01:FS02:0xa7: On Battery: false
07:49:12:WU01:FS02:0xa7: UTC Offset: 5
07:49:12:WU01:FS02:0xa7:        PID: 25652
07:49:12:WU01:FS02:0xa7:        CWD: C:\Users\SR\AppData\Roaming\FAHClient\work
07:49:12:WU01:FS02:0xa7:         OS: Windows 7 Ultimate
07:49:12:WU01:FS02:0xa7:    OS Arch: AMD64
07:49:12:WU01:FS02:0xa7:********************************************************************************
07:49:12:WU01:FS02:0xa7:Project: 14137 (Run 18, Clone 153, Gen 18)
07:49:12:WU01:FS02:0xa7:Unit: 0x000000140002894b5c00470d04208e90
07:49:12:WU01:FS02:0xa7:Reading tar file core.xml
07:49:12:WU01:FS02:0xa7:Reading tar file frame18.tpr
07:49:12:WU01:FS02:0xa7:Digital signatures verified
07:49:12:WU01:FS02:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -cpt 15 -nt 3
07:49:13:WU01:FS02:0xa7:Steps: first=45000000 total=2500000
07:49:17:WU00:FS02:Upload 34.51%
07:49:19:WU01:FS02:0xa7:Completed 1 out of 2500000 steps (0%)
07:49:23:WU00:FS02:Upload 83.90%
07:49:25:WU00:FS02:Upload complete
07:49:26:WU00:FS02:Server responded WORK_ACK (400)
07:49:26:WU00:FS02:Final credit estimate, 3342.00 points
07:49:26:WU00:FS02:Cleaning up
Re: Not being awarded bonus points
I looked up the first WU in your log, from that I got a username. Since you unnecessarily blanked out the username shown in your configuration info I can not verify if that was you. Based on that username, a lookup shows a total of 5 WU's processed, and 2 different passkeys. Neither passkey is eligible for bonus points.
From the Points FAQ - https://foldingathome.org/support/faq/points/:
What are the qualifications for the QRB?
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, have successfully returned 80% or more of assigned WUs, and returned the unit before its Timeout (formerly Preferred Deadline). Bonus points do not apply to partial returns.
You need to complete more WU's, and if this is you, it is recommended that just one passkey be used. Then you will get bonus points.
SoulReaper
Thank you so much for responding. I apologize if it caused you trouble but I had a little concern for privacy, hence I removed the username.
I have sent you a PM for confirmation
Are you using the same passkey and the same Donor name on Windows and OSX? That's recommended.
If not, you'll have to complete 10 WUs use each Name+Passkey pair.
SoulReaper
Hi Bruce,
Yes I'm using the same passkey as I had only issued once on my email ID
In windows I copy pasted from the email while for the other one I typed it out. Maybe that might have caused the issue, but the entries do match on my second client so it's not very likely I made the same mistake while typing twice haha
I'm currently on my 6th WU after adding passkey so let's see if I get the BONUS or not! (after 10 WUs) :)
