And spent the better part of the past 2 weeks working on getting it to work.
In short, those ExpressCard to PCIE 16x slot, with a transfer cable using HDMI, don't work for FAH.
They claim to improve the performance of the IGP, but in reality, the drivers are incompatible.
So not only do they provide ~1/2 PCIE 1x speed, but with incompatible graphics cards drivers, you can really only do 2D work (like 10x slower than the IGP).
A waste of money.
Linux, Debian, was able to recognize the card over ExpressCard slot, but the Nvidia drivers would freeze and crash when installing.
When interrupting the freeze, the drivers would be halfway installed, and the egpu would not be seen by FAH (though lspci did see it).
The egpu box works fine as a regular terminal, in case your IGP is broken.
But the GUI did not support the card, so 3D, mining, or folding is out of the question; and the laptop screen could not be enabled when starting the laptop with the card plugged in, meaning, unplugging the card, and you'd not be able to see anything anymore, even after replugging the card.
Linux allowed it to boot, but no gui.
Windows was more success. It found the graphics card, and the Nvidia drivers install (though take their time, nearly 10 minutes to install).
FAH finds the GPU even, and downloads a WU for it, but for some reason the card enters a 'ready' state.
When I set OpenCL Index to 0, the card appears to be starting a WU, but every few seconds errors until after a few errors it stops.
I wanted to look at those 'pass thru' drivers everyone is talking about (to pass Core I IGPs to an external video card), but the hardware requirements are very narrow.
I just don't own that hardware.
In other words, if you see these (relatively cheap) egpu connectors, they're mostly NOT compatible with Windows, nor Linux, for a full experience.
Sure, they can help you out in a pinch, but not for gaming.
The (Nvidia) drivers don't install correctly on these.
I thought it would be good for everyone to know.
No new life for my old laptop,
Our current only solution would be an overtly expensive thunderbolt connector box for folding on the go, or fold on desktops with graphics cards, or the $200+ expensive LattePanda Alpha with mini pcie port.
