[93m06:32:51:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Network is unreachable[0m
06:32:51:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14120 run:2 clone:15 gen:47 core:0xa7 unit:0x000000380002894c5b840015dd153bd4
06:32:51:WU01:FS00:Uploading 10.18MiB to 155.247.166.220
06:32:51:WU01:FS00:Connecting to 155.247.166.220:8080
[93m06:33:23:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
06:33:23:WU01:FS00:Connecting to 155.247.166.220:80
06:35:01:WU01:FS00:Upload 0.61%
[93m06:35:01:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed[0m
06:35:01:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14120 run:2 clone:15 gen:47 core:0xa7 unit:0x000000380002894c5b840015dd153bd4
06:35:02:WU01:FS00:Uploading 10.18MiB to 155.247.166.220
06:35:02:WU01:FS00:Connecting to 155.247.166.220:8080
155.247.166.220 down?
seems the server are down
Re: 155.247.166.220 down?
Yes, that server is down and the team running it are aware of it.
I also have problems today since 10:09 clock too to send my results.
If the IP of the collection server is 0.0.0.0, there is no alternative.
I've been watching for quite a while that pretty much all cpu WUs do not have a collection server.
If the new WUs run for 8 to 9 hours on an i7-6700K with 4/8 cores full load, then I would like to take this opportunity to motivate everyone involved to take the CPU folders seriously.
Thank you.
Thank you.
Many CPU projects do have collection servers, I can go by the CPU WU's that my systems process and state that with confidence. But older projects might not, often due to issues at the time configuring for a CS at a different university and related firewall issues. As I understand it, adding a CS to an already running project is either very difficult or not possible.
The Work Server attempts to establish a connection to members of a list of potential Collection Servers. This happens with the WS is initially started. It must happen periodically after that but I don't know how frequently or when. At the time a WU is downloaded, this information is stored in the WU so the client can make intelligent decisions about what the choices are when the WU is finished. You can learn that information from https://apps.foldingathome.org/serverstats under the heading Has CS.
I agree with Joe_H: adding a CS to an already running project is either very difficult or not possible.
No one mentioned it, but the server is back online.
I have a GPU WU waiting to be sent to 155.247.166.220 for about an hour and a half
22:02:49:WU00:FS01:0x21:Completed 1237500 out of 1250000 steps (99%)
22:10:00:WU00:FS01:0x21:Completed 1250000 out of 1250000 steps (100%)
22:10:10:WU00:FS01:0x21:Saving result file logfile_01.txt
22:10:10:WU00:FS01:0x21:Saving result file checkpointState.xml
22:10:16:WU00:FS01:0x21:Saving result file checkpt.crc
22:10:16:WU00:FS01:0x21:Saving result file log.txt
22:10:16:WU00:FS01:0x21:Saving result file positions.xtc
22:10:20:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
22:10:20:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:10:20:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14167 run:15 clone:7 gen:25 core:0x21 unit:0x000000190002894c5c3d11f03e6f8bb0
22:10:20:WU00:FS01:Uploading 24.91MiB to 155.247.166.220
22:10:20:WU00:FS01:Connecting to 155.247.166.220:8080
They are aware that 155.247.166.220 is down and are looking into the problem.
It didn't last long (maybe a couple of hours) and the server is working again.
It's down again. Connection is being actively refused.
They just moved several projects to Advanced - viewtopic.php?f=24&t=31406, may have needed to restart the server. It is currently showing as up and assigning.Prettz wrote:It's down again. Connection is being actively refused.
