And this happens within 2 minutes or so
I have whitelisted all the FAH processes in Windows Defender
Can you guys please help me sort it out! Much appreciated
*********************** Log Started 2018-12-21T06:53:25Z ***********************
06:53:25:************************* Folding@home Client *************************
06:53:25: Website: https://foldingathome.org/
06:53:25: Copyright: (c) 2009-2018 foldingathome.org
06:53:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:53:25: Args: --open-web-control
06:53:25: Config: C:\Users\SR\AppData\Roaming\FAHClient\config.xml
06:53:25:******************************** Build ********************************
06:53:25: Version: 7.5.1
06:53:25: Date: May 11 2018
06:53:25: Time: 13:06:32
06:53:25: Repository: Git
06:53:25: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
06:53:25: Branch: master
06:53:25: Compiler: Visual C++ 2008
06:53:25: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:53:25: Platform: win32 10
06:53:25: Bits: 32
06:53:25: Mode: Release
06:53:25:******************************* System ********************************
06:53:25: CPU: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
06:53:25: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
06:53:25: CPUs: 4
06:53:25: Memory: 11.88GiB
06:53:25: Free Memory: 7.84GiB
06:53:25: Threads: WINDOWS_THREADS
06:53:25: OS Version: 6.2
06:53:25: Has Battery: false
06:53:25: On Battery: false
06:53:25: UTC Offset: 5
06:53:25: PID: 10104
06:53:25: CWD: C:\Users\SR\AppData\Roaming\FAHClient
06:53:25: OS: Windows 8 Pro
06:53:25: OS Arch: AMD64
06:53:25: GPUs: 0
06:53:25: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:53:25: specified module could not be found.
06:53:25:
06:53:25:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:22.20
06:53:25: Win32 Service: false
06:53:25:***********************************************************************
06:53:25:<config>
06:53:25: <!-- Folding Slot Configuration -->
06:53:25: <cause v='CANCER'/>
06:53:25:
06:53:25: <!-- Slot Control -->
06:53:25: <power v='LIGHT'/>
06:53:25:
06:53:25: <!-- Folding Slots -->
06:53:25: <slot id='0' type='CPU'/>
06:53:25:</config>
06:53:25:Trying to access database...
06:53:25:Successfully acquired database lock
06:53:25:Enabled folding slot 00: READY cpu:1
06:53:25:WU00:FS00:Starting
06:53:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\SR\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 10104 -checkpoint 15 -np 1
06:53:25:WU00:FS00:Started FahCore on PID 10504
06:53:25:WU00:FS00:Core PID:5308
06:53:25:WU00:FS00:FahCore 0xa4 started
06:53:25:WU00:FS00:0xa4:
06:53:25:WU00:FS00:0xa4:*------------------------------*
06:53:25:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
06:53:25:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:53:25:WU00:FS00:0xa4:Preparing to commence simulation
06:53:25:WU00:FS00:0xa4:- Looking at optimizations...
06:53:25:WU00:FS00:0xa4:- Files status OK
06:53:25:WU00:FS00:0xa4:- Expanded 825187 -> 1397768 (decompressed 169.3 percent)
06:53:25:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825187 data_size=1397768, decompressed_data_size=1397768 diff=0
06:53:25:WU00:FS00:0xa4:- Digital signature verified
06:53:25:WU00:FS00:0xa4:Project: 9031 (Run 175, Clone 4, Gen 266)
06:53:25:WU00:FS00:0xa4:Assembly optimizations on if available.
06:53:25:WU00:FS00:0xa4:Entering M.D.
06:53:29:20:127.0.0.1:New Web connection
06:53:31:WU00:FS00:0xa4:Mapping NT from 1 to 1
06:53:32:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
06:54:26:Saving configuration to config.xml
06:54:26:<config>
06:54:26: <!-- Folding Slot Configuration -->
06:54:26: <cause v='CANCER'/>
06:54:26:
