GPUs: 0
swillden
GPUs: 0
Post by swillden »
I have a ridiculously powerful machine (needed for work, which involves compiling a very large codebase) and cheap electricity, at least part of each day, so I decided I may as well contribute a little. But, fahclient doesn't think I have a GPU. I have a Quadro M2000, with the nVidia drivers and libOpenCL installed on a Debian-based distro. Oddly, nvidia-libopencl1 didn't put libOpenCL.so in /usr/lib, which caused fahclient not to be able to find it. I symlinked it in place and now I see that fahclient sees the library, but still thinks I have no GPU.
Any ideas? Since my GPU is running my displays, do I need to install a second GPU for use by FAH?
Here's a log:
*********************** Log Started 2018-12-04T13:48:08Z ***********************
13:48:08:************************* Folding@home Client *************************
13:48:08:        Website: https://foldingathome.org/
13:48:08:      Copyright: (c) 2009-2018 foldingathome.org
13:48:08:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:48:08:           Args: --child --lifeline 24632 /etc/fahclient/config.xml --run-as
13:48:08:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
13:48:08:         Config: /etc/fahclient/config.xml
13:48:08:******************************** Build ********************************
13:48:08:        Version: 7.5.1
13:48:08:           Date: May 11 2018
13:48:08:           Time: 19:59:04
13:48:08:     Repository: Git
13:48:08:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:48:08:         Branch: master
13:48:08:       Compiler: GNU 6.3.0 20170516
13:48:08:        Options: -std=gnu++98 -O3 -funroll-loops
13:48:08:       Platform: linux2 4.14.0-3-amd64
13:48:08:           Bits: 64
13:48:08:           Mode: Release
13:48:08:******************************* System ********************************
13:48:08:            CPU: Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
13:48:08:         CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
13:48:08:           CPUs: 56
13:48:08:         Memory: 125.89GiB
13:48:08:    Free Memory: 111.15GiB
13:48:08:        Threads: POSIX_THREADS
13:48:08:     OS Version: 4.18
13:48:08:    Has Battery: false
13:48:08:     On Battery: false
13:48:08:     UTC Offset: -7
13:48:08:            PID: 24634
13:48:08:            CWD: /var/lib/fahclient
13:48:08:             OS: Linux 4.18.10-1rodete2-amd64 x86_64
13:48:08:        OS Arch: AMD64
13:48:08:           GPUs: 0
13:48:08:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:5.2 Driver:9.1
13:48:08:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:390.87
13:48:08:***********************************************************************
13:48:08:<config>
13:48:08:  <!-- Client Control -->
13:48:08:  <fold-anon v='true'/>
13:48:08:
13:48:08:  <!-- Folding Slot Configuration -->
13:48:08:  <gpu v='false'/>
13:48:08:
13:48:08:  <!-- Network -->
13:48:08:  <proxy v=':8080'/>
13:48:08:
13:48:08:  <!-- Slot Control -->
13:48:08:  <power v='full'/>
13:48:08:
13:48:08:  <!-- User Information -->
13:48:08:  <passkey v='********************************'/>
13:48:08:  <user v='swillden'/>
13:48:08:
13:48:08:  <!-- Folding Slots -->
13:48:08:  <slot id='0' type='CPU'/>
13:48:08:</config>
13:48:08:Switching to user fahclient
13:48:08:Trying to access database...
13:48:08:Successfully acquired database lock
13:48:08:Enabled folding slot 00: READY cpu:56
13:48:08:WU00:FS00:Starting
13:48:08:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 24634 -checkpoint 15 -np 56
13:48:08:WU00:FS00:Started FahCore on PID 24644
13:48:08:WU00:FS00:Core PID:24648
13:48:08:WU00:FS00:FahCore 0xa7 started
13:48:09:WU00:FS00:0xa7:*********************** Log Started 2018-12-04T13:48:08Z ***********************
13:48:09:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:48:09:WU00:FS00:0xa7:       Type: 0xa7
13:48:09:WU00:FS00:0xa7:       Core: Gromacs
13:48:09:WU00:FS00:0xa7:    Website: https://foldingathome.org/
13:48:09:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
13:48:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:48:09:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 24644 -checkpoint 15 -np
13:48:09:WU00:FS00:0xa7:             56
13:48:09:WU00:FS00:0xa7:     Config: <none>
13:48:09:WU00:FS00:0xa7:************************************ Build *************************************
13:48:09:WU00:FS00:0xa7:    Version: 0.0.17
13:48:09:WU00:FS00:0xa7:       Date: Apr 27 2018
13:48:09:WU00:FS00:0xa7:       Time: 19:09:21
13:48:09:WU00:FS00:0xa7: Repository: Git
13:48:09:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
13:48:09:WU00:FS00:0xa7:     Branch: master
13:48:09:WU00:FS00:0xa7:   Compiler: GNU 6.3.0 20170516
13:48:09:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
13:48:09:WU00:FS00:0xa7:   Platform: linux2 4.14.0-3-amd64
13:48:09:WU00:FS00:0xa7:       Bits: 64
13:48:09:WU00:FS00:0xa7:       Mode: Release
13:48:09:WU00:FS00:0xa7:       SIMD: avx_256
13:48:09:WU00:FS00:0xa7:************************************ System ************************************
13:48:09:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
13:48:09:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
13:48:09:WU00:FS00:0xa7:       CPUs: 56
13:48:09:WU00:FS00:0xa7:     Memory: 125.89GiB
13:48:09:WU00:FS00:0xa7:Free Memory: 111.14GiB
13:48:09:WU00:FS00:0xa7:    Threads: POSIX_THREADS
13:48:09:WU00:FS00:0xa7: OS Version: 4.18
13:48:09:WU00:FS00:0xa7:Has Battery: false
13:48:09:WU00:FS00:0xa7: On Battery: false
13:48:09:WU00:FS00:0xa7: UTC Offset: -7
13:48:09:WU00:FS00:0xa7:        PID: 24648
13:48:09:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
13:48:09:WU00:FS00:0xa7:         OS: Linux 4.18.10-1rodete2-amd64 x86_64
13:48:09:WU00:FS00:0xa7:    OS Arch: AMD64
13:48:09:WU00:FS00:0xa7:********************************************************************************
13:48:09:WU00:FS00:0xa7:Project: 14118 (Run 11, Clone 14, Gen 16)
13:48:09:WU00:FS00:0xa7:Unit: 0x000000160002894c5b840063be667e59
13:48:09:WU00:FS00:0xa7:Digital signatures verified
13:48:09:WU00:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpi state.cpt -cpt 15 -nt 56
13:48:09:WU00:FS00:0xa7:Steps: first=40000000 total=2500000
13:48:10:WU00:FS00:0xa7:Completed 269952 out of 2500000 steps (10%)
13:48:40:WU00:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
13:51:58:WU00:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
13:54:30:WU00:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
13:57:23:WU00:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
14:00:14:WU00:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
Re: GPUs: 0
Since the folding client was installed with the OpenCL libraries not being seen, it set the value for gpu to false:
13:48:08:
Change that to true in FAHControl and save it. Then restart the FAHClient process that runs in the background. If all of the OpenCL libraries are in place and the nVidia driver installed, then the GPU should be seen and be configurable for folding.
To answer your other question, no you do not need to install a second GPU for use by FAH. Depending on what you are displaying through the GPU you might experience some lag with folding running, the M2000 appears to be equivalent to the GTX 950. If that is the case you may want to have the GPU slot set to fold when idle.
