No advanced control,web control and more
jason str
Hardware configuration: One AMD & one Intel system running 24/7
Post by jason str »
Just downloaded V7.5.1 for Windows (Vista 64 HP) and advanced control is showing an error listed below.
cx_Freeze:Python error in main script.
Traceback (most recent call last):
File "C;\build\mingw32\lib\python2.7\site-packages/cx_freeze\initscripts\Console.py",line 27,in <module>
File "FAHControl', line 25 in <module>
File :fah/_init_.py", line 22 in <module>
File "fah/util/_init_.py" line 22, in <module>
File "C:\build\mingw32\lib\python2.7\site-packages\gtk-2.0/gtk/_init_.py",line 40, in <module>
File "ExtensionLoader_gtk_gtk.py",line 22 in <module>
File "ExtensionLoader_gtk_gtk.py",line 14, in _bootstrap_
ImportError :DLL load failed: The specified procedure could not be found.
jason str
Re: Advanced control issue
Post by jason str »
Tried uninstalling and reinstalling V7.5.1 and still have the exact same problem. Is this no longer used ? i still see the option on the toolbar that pops up.
bollix47
Post by bollix47 »
There is/was a known problem with advanced control (aka FAHControl) that involved the default theme ... it didn't always work properly ... solution ... if you can get into preferences change the theme and restart FAHControl.
jason str
Post by jason str »
Cannot get into advanced control to change anything or even see my log, just what pops up as shown in my previous post.
Any other way to get to that ?
bollix47
Post by bollix47 »
I'm not sure how well Vista is supported as I have not used it in many years but have a look at the Requiements:
https://foldingathome.org/support/faq/i ... uirements/
You may see some prerequisite that you're missing.
e.g. "... Microsoft .NET Framework is required by V7 FAHControl in Windows ..."
jason str
Post by jason str »
Been folding for years with this machine, all i did was update to the newer version 7.5.1.
Just updated my nvidia driver today, no change.
jason str
Post by jason str »
Looks like this Python is some kind of program, i don't know where it came from or who installed it ( maybe the kids ?) but there is no program installed by that name as far as i can see. Will continue my search. Must be some kind of incompatibility with the new download version i guess.
Python is a scripting language that is used by FAHClient. (https://www.python.org/) In the past I've seen some issues with the version of Python installed on your OS but apparently you didn't change that, so I'm not sure what the problem might be.
jason str
Post by jason str »
Trying to get my machine up and running again and still can't figure this out.
Any updates available.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Can you try fully uninstalling F@h and then doing a clean re-install?
jason str
Post by jason str »
Yes i have.
HesletQuillan
Post by HesletQuillan »
I had this issue - a reboot fixed it.
jason str
Post by jason str »
System has been rebooted many times in the past years including yesterday after frustration.
More information.
FahCore_a7 is running in task manager, the Web control, advanced control, protein viewer window pops up and adjusts correctly but that's it. Web control times out, advanced control shows the same window posted in the first thread but i am able to adjust full, medium & light options.
Thats all I'm getting at this point.
jason str
Post by jason str »
Updated Nvidia driver to latest version with clean install.
Uninstalled F@H and went through looking for anything related and deleted witch seemed to be old download version of F@h.
Reinstalled latest F@H download and still same thing.
jason str
Re: No advanced control,web control and more
Post by jason str »
Updated some components for efficiency and new windows 10, so far so good.
Back to functioning
