62k PPD only on 1060 GTX 6 GB
fraklo
Post by fraklo »
Hi,
I reinstalled my Win10 to have OpenCL and now I'm able to crunch on my 1060 GTX.
But, with the client Advanced Control, I'm stuck at 62k PPD only.
On 3DMARK, I have 4050 points (to compare).
My CPU is a i5 7500.
What can I do?
Here the log:
*********************** Log Started 2018-11-29T21:55:27Z ***********************
21:55:40:FS01:Unpaused
21:55:40:WU01:FS01:Starting
21:55:40:WU01:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Program Files (x86)\FAHClient\Data\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 11496 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:55:40:WU01:FS01:Started FahCore on PID 3248
21:55:41:WU01:FS01:Core PID:12848
21:55:41:WU01:FS01:FahCore 0x21 started
21:55:41:WU01:FS01:0x21:*********************** Log Started 2018-11-29T21:55:41Z ***********************
21:55:41:WU01:FS01:0x21:Project: 11718 (Run 0, Clone 1333, Gen 154)
21:55:41:WU01:FS01:0x21:Unit: 0x000000d18ca304e75b898ffc1319aabb
21:55:41:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:55:41:WU01:FS01:0x21:Machine: 1
21:55:41:WU01:FS01:0x21:Digital signatures verified
21:55:41:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:55:41:WU01:FS01:0x21:Version 0.0.18
21:55:41:WU01:FS01:0x21:  Found a checkpoint file
21:55:42:WARNING:FS01:Size of positions 5845 does not match topology 5844
21:55:47:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
21:55:47:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:59:14:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
22:02:42:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
Thanks!
Re: 62k PPD only on 1060 GTX 6 GB
That is not the interesting bit, the first 100 lines show your configuration.
But lets not let a lack of data stop me from guessing wildly that you are not using a passkey. If not, add one.
bollix47
Post by bollix47 »
In case you don't have a passkey:
https://apps.foldingathome.org/getpasskey
Add the e-mailed passkey to your configuration, then you will have to complete 10 work units with an 80% success rate before you start to receive the bonus.
fraklo
Post by fraklo »
Yes guys, you're right :)
I'm now at 320k PPD!
Thanks!
Glad to help, glad you let me know my guess was right.
kiore
Post by kiore »
You will need to complete 10 successful units with the passkey before the predicted points you are seeing translate to actual results.
