FEATURE REQUEST
FEATURE REQUEST
sustainance of finished state upon exiting and re entering client. now when i set status to finished from running and then exit client, finished status does not persist. make it persist.
Re: FEATURE REQUEST
This enhancement request has been pending for a long, long time.
https://github.com/FoldingAtHome/fah-issues/issues/783
SteveWillis
- Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: FEATURE REQUEST
FAMAS, it is annoying that this feature hasn't been implemented. LOL maybe if requests could be voted on to increase their visibility. I know, not in this universe but I did hear something about a squeaky wheel.
You probably know this already but if the WU has finished set the FS to paused before you exit the client. Paused status will persist and a new WU will not start. Another thing you can do is in the expert tab or for individual slots in the slots tab add pause-on-start true and it will start up with that slot or all slots paused.
Re: FEATURE REQUEST
Another option is to set "pause-on-start" to "true"
Then FAH will always start Paused and you'll have to manually start it every time.
Re: FEATURE REQUEST
I think there's such an option : paused = true/false in slot options.
Re: FEATURE REQUEST
If you use pause-on-start = true, it is a permanent setting. If you use pause = true/false, it gets stored every time you push the "pause"/"fold" button so it won't be there when you want it.
