I ran the FAHClient.exe by hand because after the setup, nothing happen.
Here is the log file:
*********************** Log Started 2018-11-24T20:33:38Z ***********************
20:33:38:************************* Folding@home Client *************************
20:33:38: Website: https://foldingathome.org/
20:33:38: Copyright: (c) 2009-2018 foldingathome.org
20:33:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:33:38: Args: --open-web-control
20:33:38: Config: <none>
20:33:38:******************************** Build ********************************
20:33:38: Version: 7.5.1
20:33:38: Date: May 11 2018
20:33:38: Time: 13:06:32
20:33:38: Repository: Git
20:33:38: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:33:38: Branch: master
20:33:38: Compiler: Visual C++ 2008
20:33:38: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:33:38: Platform: win32 10
20:33:38: Bits: 32
20:33:38: Mode: Release
20:33:38:******************************* System ********************************
20:33:38: CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
20:33:38: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:33:38: CPUs: 4
20:33:38: Memory: 15.96GiB
20:33:38: Free Memory: 8.30GiB
20:33:38: Threads: WINDOWS_THREADS
20:33:38: OS Version: 6.2
20:33:38: Has Battery: false
20:33:38: On Battery: false
20:33:38: UTC Offset: 1
20:33:38: PID: 5908
20:33:38: CWD: C:\Users\Me\AppData\Roaming\FAHClient
20:33:38: OS: Windows 10 Enterprise
20:33:38: OS Arch: AMD64
20:33:38: GPUs: 0
20:33:38:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.0
20:33:38: OpenCL: Not detected
20:33:38:Win32 Service: false
20:33:38:***********************************************************************
20:33:38:<config>
20:33:38: <!-- Folding Slots -->
20:33:38:</config>
20:33:38:Connecting to assign1.foldingathome.org:8080
20:33:38:Updated GPUs.txt
20:33:38:Read GPUs.txt
20:33:38:Trying to access database...
20:33:38:Successfully acquired database lock
20:33:38:Enabled folding slot 00: PAUSED cpu:2 (not configured)
I choosed express method without changing anything. I tried a second time with a new directory (like D:\Folding) but same result.
What can I do?
I reinstall the nvidia drivers, remove/seup folding 10 times.
Thanks!
