Sync web.client and stats.foldingathome.org/donor
xystophyte
Hardware configuration: Ryzen 5 1600 (3400 MHz) - MSI x370 SLI Plus - Win 10 Pro x64
Cryorig H5 Ultimate
Patriot Viper 16GB DDR5 (2800 Mhz)
2x Radeon RX 580 Graphics (Sapphire)
167GB Corsair Force 3 SSD (SSD) & 2TB Seagate Firecuda HDD
Post by xystophyte »
I have this ongoing thing where the web client and the donor stats report different points which have been out of sync for 2 months now.
eg, web client is showing 121,672,506 points
donor stats shows 123,406,273 points
I uninstalled F@H and data, then reinstalled F@H. No luck. Also, there was a DNS clear/reset thingy that I thought may be related but still did not resolve the problem. I'm clearly missing something obvious.
Can you help? :e?:
xystophyte
Cryorig H5 Ultimate
Re: Sync web.client and stats.foldingathome.org/donor
Apologies, meant to add this debris ......
*********************** Log Started 2018-11-18T19:01:17Z ***********************
19:01:17:************************* Folding@home Client *************************
19:01:17:        Website: https://foldingathome.org/
19:01:17:      Copyright: (c) 2009-2018 foldingathome.org
19:01:17:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:01:17:           Args:
19:01:17:         Config: C:\Users\xysto\AppData\Roaming\FAHClient\config.xml
19:01:17:******************************** Build ********************************
19:01:17:        Version: 7.5.1
19:01:17:           Date: May 11 2018
19:01:17:           Time: 13:06:32
19:01:17:     Repository: Git
19:01:17:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:01:17:         Branch: master
19:01:17:       Compiler: Visual C++ 2008
19:01:17:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:01:17:       Platform: win32 10
19:01:17:           Bits: 32
19:01:17:           Mode: Release
19:01:17:******************************* System ********************************
19:01:17:            CPU: AMD Ryzen 5 1600 Six-Core Processor
19:01:17:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
19:01:17:           CPUs: 12
19:01:17:         Memory: 15.95GiB
19:01:17:    Free Memory: 13.48GiB
19:01:17:        Threads: WINDOWS_THREADS
19:01:17:     OS Version: 6.2
19:01:17:    Has Battery: false
19:01:17:     On Battery: false
19:01:17:     UTC Offset: -8
19:01:17:            PID: 10580
19:01:17:            CWD: C:\Users\xysto\AppData\Roaming\FAHClient
19:01:17:             OS: Windows 10 Enterprise
19:01:17:        OS Arch: AMD64
19:01:17:           GPUs: 2
19:01:17:          GPU 0: Bus:38 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
19:01:17:                 470/480/570/580]
19:01:17:          GPU 1: Bus:39 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
19:01:17:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:01:17:                 specified module could not be found.
19:01:17:
19:01:17:OpenCL Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:1.2 Driver:2686.5
19:01:17:OpenCL Device 1: Platform:0 Device:1 Bus:39 Slot:0 Compute:1.2 Driver:2686.5
19:01:17:  Win32 Service: false
19:01:17:***********************************************************************
19:01:17:<config>
19:01:17:  <!-- Folding Core -->
19:01:17:  <core-priority v='low'/>
19:01:17:
19:01:17:  <!-- Network -->
19:01:17:  <proxy v=':8080'/>
19:01:17:
19:01:17:  <!-- Slot Control -->
19:01:17:  <power v='FULL'/>
19:01:17:
19:01:17:  <!-- User Information -->
19:01:17:  <passkey v='********************************'/>
19:01:17:  <team v='37412'/>
19:01:17:  <user v='xystophyte'/>
19:01:17:
19:01:17:  <!-- Folding Slots -->
19:01:17:  <slot id='0' type='CPU'>
19:01:17:    <paused v='true'/>
19:01:17:  </slot>
19:01:17:  <slot id='1' type='GPU'>
19:01:17:  </slot>
19:01:17:  <slot id='2' type='GPU'>
19:01:17:  </slot>
19:01:17:</config>
19:01:17:Trying to access database...
19:01:17:Successfully acquired database lock
19:01:17:Enabled folding slot 00: PAUSED cpu:10 (by user)
19:01:17:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (by user)
19:01:17:Enabled folding slot 02: PAUSED gpu:1:Ellesmere XT [Radeon RX 470/480/570/580] (by user)
19:03:26:FS00:Unpaused
19:03:26:FS01:Unpaused
19:03:26:FS02:Unpaused
19:03:26:WU02:FS01:Starting
19:03:26:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:03:26:WU02:FS01:Started FahCore on PID 11412
19:03:27:WU02:FS01:Core PID:11984
19:03:27:WU02:FS01:FahCore 0x21 started
19:03:27:WU00:FS02:Starting
19:03:27:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
19:03:27:WU00:FS02:Started FahCore on PID 11980
19:03:27:WU00:FS02:Core PID:12268
19:03:27:WU00:FS02:FahCore 0x21 started
19:03:27:WU03:FS00:Starting
19:03:27:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -np 10
19:03:27:WU03:FS00:Started FahCore on PID 8652
19:03:27:WU03:FS00:Core PID:2220
19:03:27:WU03:FS00:FahCore 0xa7 started
19:03:27:WU00:FS02:0x21:*********************** Log Started 2018-11-18T19:03:27Z ***********************
19:03:27:WU00:FS02:0x21:Project: 11720 (Run 0, Clone 894, Gen 199)
19:03:27:WU00:FS02:0x21:Unit: 0x000000f78ca304e75b89a0c2cec771fd
19:03:27:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
19:03:27:WU00:FS02:0x21:Machine: 2
19:03:27:WU00:FS02:0x21:Digital signatures verified
19:03:27:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
19:03:27:WU00:FS02:0x21:Version 0.0.18
19:03:27:WU00:FS02:0x21:  Found a checkpoint file
19:03:27:WU02:FS01:0x21:*********************** Log Started 2018-11-18T19:03:27Z ***********************
19:03:27:WU02:FS01:0x21:Project: 11730 (Run 4, Clone 692, Gen 115)
19:03:27:WU02:FS01:0x21:Unit: 0x0000008a8ca304e75bcd3742b615537f
19:03:27:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:03:27:WU02:FS01:0x21:Machine: 1
19:03:27:WU02:FS01:0x21:Digital signatures verified
19:03:27:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:03:27:WU02:FS01:0x21:Version 0.0.18
19:03:27:WU02:FS01:0x21:  Found a checkpoint file
19:03:28:WU03:FS00:0xa7:*********************** Log Started 2018-11-18T19:03:27Z ***********************
19:03:28:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:03:28:WU03:FS00:0xa7:       Type: 0xa7
19:03:28:WU03:FS00:0xa7:       Core: Gromacs
19:03:28:WU03:FS00:0xa7:    Website: https://foldingathome.org/
19:03:28:WU03:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
19:03:28:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:03:28:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 8652 -checkpoint 15 -np
19:03:28:WU03:FS00:0xa7:             10
19:03:28:WU03:FS00:0xa7:     Config: <none>
19:03:28:WU03:FS00:0xa7:************************************ Build *************************************
19:03:28:WU03:FS00:0xa7:    Version: 0.0.17
19:03:28:WU03:FS00:0xa7:       Date: Apr 27 2018
19:03:28:WU03:FS00:0xa7:       Time: 16:19:36
19:03:28:WU03:FS00:0xa7: Repository: Git
19:03:28:WU03:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
19:03:28:WU03:FS00:0xa7:     Branch: master
19:03:28:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
19:03:28:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:03:28:WU03:FS00:0xa7:   Platform: win32 10
19:03:28:WU03:FS00:0xa7:       Bits: 64
19:03:28:WU03:FS00:0xa7:       Mode: Release
19:03:28:WU03:FS00:0xa7:       SIMD: avx_256
19:03:28:WU03:FS00:0xa7:************************************ System ************************************
19:03:28:WU03:FS00:0xa7:        CPU: Unknown
19:03:28:WU03:FS00:0xa7:     CPU ID:
19:03:28:WU03:FS00:0xa7:       CPUs: 12
19:03:28:WU03:FS00:0xa7:     Memory: 15.95GiB
19:03:28:WU03:FS00:0xa7:Free Memory: 12.73GiB
19:03:28:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
19:03:28:WU03:FS00:0xa7: OS Version: 6.2
19:03:28:WU03:FS00:0xa7:Has Battery: false
19:03:28:WU03:FS00:0xa7: On Battery: false
19:03:28:WU03:FS00:0xa7: UTC Offset: -8
19:03:28:WU03:FS00:0xa7:        PID: 2220
19:03:28:WU03:FS00:0xa7:        CWD: C:\Users\xysto\AppData\Roaming\FAHClient\work
19:03:28:WU03:FS00:0xa7:         OS: Windows 10 Pro
19:03:28:WU03:FS00:0xa7:    OS Arch: AMD64
19:03:28:WU03:FS00:0xa7:********************************************************************************
19:03:28:WU03:FS00:0xa7:Project: 13812 (Run 0, Clone 323, Gen 296)
19:03:28:WU03:FS00:0xa7:Unit: 0x0000016780fccb025a981926cbe3012a
19:03:28:WU03:FS00:0xa7:Digital signatures verified
19:03:28:WU03:FS00:0xa7:Calling: mdrun -s frame296.tpr -o frame296.trr -x frame296.xtc -cpi state.cpt -cpt 15 -nt 10
19:03:29:WU03:FS00:0xa7:Steps: first=74000000 total=250000
19:03:30:WU03:FS00:0xa7:Completed 58441 out of 250000 steps (23%)
19:03:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:03:38:WU00:FS02:0x21:Completed 1000000 out of 5000000 steps (20%)
19:03:38:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:03:47:WU02:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
19:03:47:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:04:20:Removing old file 'configs/config-20181102-020420.xml'
19:04:20:Saving configuration to config.xml
19:04:20:<config>
19:04:20:  <!-- Folding Core -->
19:04:20:  <core-priority v='low'/>
19:04:20:
19:04:20:  <!-- Network -->
19:04:20:  <proxy v=':8080'/>
19:04:20:
19:04:20:  <!-- Slot Control -->
19:04:20:  <power v='FULL'/>
19:04:20:
19:04:20:  <!-- User Information -->
19:04:20:  <passkey v='********************************'/>
19:04:20:  <team v='37412'/>
19:04:20:  <user v='xystophyte'/>
19:04:20:
19:04:20:  <!-- Folding Slots -->
19:04:20:  <slot id='0' type='CPU'/>
19:04:20:  <slot id='1' type='GPU'/>
19:04:20:  <slot id='2' type='GPU'/>
19:04:20:</config>
19:05:15:WU00:FS02:0x21:Completed 1050000 out of 5000000 steps (21%)
19:05:24:WU03:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
19:06:06:WU02:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
19:06:51:WU00:FS02:0x21:Completed 1100000 out of 5000000 steps (22%)
19:08:23:WU03:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
19:08:24:WU02:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
19:08:24:WU00:FS02:0x21:Completed 1150000 out of 5000000 steps (23%)
19:09:58:WU00:FS02:0x21:Completed 1200000 out of 5000000 steps (24%)
19:10:40:WU02:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
19:11:21:WU03:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
19:11:33:WU00:FS02:0x21:Completed 1250000 out of 5000000 steps (25%)
19:12:56:WU02:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
19:13:08:WU00:FS02:0x21:Completed 1300000 out of 5000000 steps (26%)
19:14:20:WU03:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
19:14:43:WU00:FS02:0x21:Completed 1350000 out of 5000000 steps (27%)
19:15:14:WU02:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
19:16:21:WU00:FS02:0x21:Completed 1400000 out of 5000000 steps (28%)
19:17:27:WU03:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
19:17:32:WU02:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
19:17:59:WU00:FS02:0x21:Completed 1450000 out of 5000000 steps (29%)
19:19:37:WU00:FS02:0x21:Completed 1500000 out of 5000000 steps (30%)
19:19:50:WU02:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
19:20:35:WU03:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
19:21:17:WU00:FS02:0x21:Completed 1550000 out of 5000000 steps (31%)
19:22:08:WU02:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
19:22:55:WU00:FS02:0x21:Completed 1600000 out of 5000000 steps (32%)
19:23:43:WU03:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
19:24:26:WU02:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
19:24:33:WU00:FS02:0x21:Completed 1650000 out of 5000000 steps (33%)
19:26:12:WU00:FS02:0x21:Completed 1700000 out of 5000000 steps (34%)
19:26:45:WU02:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
19:26:50:WU03:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
19:27:50:WU00:FS02:0x21:Completed 1750000 out of 5000000 steps (35%)
19:29:07:WU02:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
19:29:29:WU00:FS02:0x21:Completed 1800000 out of 5000000 steps (36%)
19:29:56:WU03:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
19:31:04:WU00:FS02:0x21:Completed 1850000 out of 5000000 steps (37%)
19:31:26:WU02:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
19:32:38:WU00:FS02:0x21:Completed 1900000 out of 5000000 steps (38%)
19:32:55:WU03:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
19:33:42:WU02:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
19:34:11:WU00:FS02:0x21:Completed 1950000 out of 5000000 steps (39%)
19:35:45:WU00:FS02:0x21:Completed 2000000 out of 5000000 steps (40%)
19:35:55:WU03:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
19:35:58:WU02:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
19:37:19:WU00:FS02:0x21:Completed 2050000 out of 5000000 steps (41%)
19:38:13:WU02:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
19:38:52:WU00:FS02:0x21:Completed 2100000 out of 5000000 steps (42%)
19:38:53:WU03:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
19:40:27:WU00:FS02:0x21:Completed 2150000 out of 5000000 steps (43%)
19:40:30:WU02:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
19:41:54:WU03:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
19:42:04:WU00:FS02:0x21:Completed 2200000 out of 5000000 steps (44%)
19:42:47:WU02:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
19:43:41:WU00:FS02:0x21:Completed 2250000 out of 5000000 steps (45%)
19:44:58:WU03:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
19:45:05:WU02:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
19:45:20:WU00:FS02:0x21:Completed 2300000 out of 5000000 steps (46%)
19:46:57:WU00:FS02:0x21:Completed 2350000 out of 5000000 steps (47%)
19:47:22:WU02:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
19:48:02:WU03:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
19:48:34:WU00:FS02:0x21:Completed 2400000 out of 5000000 steps (48%)
19:49:39:WU02:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
19:50:12:WU00:FS02:0x21:Completed 2450000 out of 5000000 steps (49%)
19:51:06:WU03:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
19:51:49:WU00:FS02:0x21:Completed 2500000 out of 5000000 steps (50%)
19:52:00:WU02:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
19:53:28:WU00:FS02:0x21:Completed 2550000 out of 5000000 steps (51%)
19:54:09:WU03:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
19:54:18:WU02:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
19:55:01:WU00:FS02:0x21:Completed 2600000 out of 5000000 steps (52%)
19:56:34:WU02:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
19:56:34:WU00:FS02:0x21:Completed 2650000 out of 5000000 steps (53%)
19:57:07:WU03:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
19:58:07:WU00:FS02:0x21:Completed 2700000 out of 5000000 steps (54%)
19:58:49:WU02:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
19:59:40:WU00:FS02:0x21:Completed 2750000 out of 5000000 steps (55%)
20:00:04:WU03:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
20:01:05:WU02:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
20:01:14:WU00:FS02:0x21:Completed 2800000 out of 5000000 steps (56%)
20:02:47:WU00:FS02:0x21:Completed 2850000 out of 5000000 steps (57%)
20:03:02:WU03:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
20:03:20:WU02:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
20:04:21:WU00:FS02:0x21:Completed 2900000 out of 5000000 steps (58%)
20:05:01:20:127.0.0.1:New Web connection
20:05:38:WU02:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
20:05:56:WU00:FS02:0x21:Completed 2950000 out of 5000000 steps (59%)
20:06:02:WU03:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
20:07:30:WU00:FS02:0x21:Completed 3000000 out of 5000000 steps (60%)
20:07:55:WU02:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
20:09:01:WU03:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
20:09:06:WU00:FS02:0x21:Completed 3050000 out of 5000000 steps (61%)
20:10:12:WU02:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
20:10:40:WU00:FS02:0x21:Completed 3100000 out of 5000000 steps (62%)
20:12:01:WU03:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
20:12:15:WU00:FS02:0x21:Completed 3150000 out of 5000000 steps (63%)
20:12:29:WU02:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
20:13:48:WU00:FS02:0x21:Completed 3200000 out of 5000000 steps (64%)
20:14:48:WU02:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
20:14:59:WU03:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
20:15:24:WU00:FS02:0x21:Completed 3250000 out of 5000000 steps (65%)
20:16:58:WU00:FS02:0x21:Completed 3300000 out of 5000000 steps (66%)
20:17:04:WU02:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
20:17:58:WU03:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
20:18:31:WU00:FS02:0x21:Completed 3350000 out of 5000000 steps (67%)
20:19:20:WU02:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
20:20:04:WU00:FS02:0x21:Completed 3400000 out of 5000000 steps (68%)
20:20:56:WU03:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
20:21:36:WU02:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
20:21:37:WU00:FS02:0x21:Completed 3450000 out of 5000000 steps (69%)
20:23:10:WU00:FS02:0x21:Completed 3500000 out of 5000000 steps (70%)
20:23:53:WU02:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
20:23:53:WU03:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
20:24:44:WU00:FS02:0x21:Completed 3550000 out of 5000000 steps (71%)
20:26:09:WU02:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
20:26:18:WU00:FS02:0x21:Completed 3600000 out of 5000000 steps (72%)
20:26:50:WU03:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
20:27:51:WU00:FS02:0x21:Completed 3650000 out of 5000000 steps (73%)
20:28:26:WU02:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
20:29:25:WU00:FS02:0x21:Completed 3700000 out of 5000000 steps (74%)
20:29:49:WU03:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
20:30:42:WU02:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
20:30:59:WU00:FS02:0x21:Completed 3750000 out of 5000000 steps (75%)
20:32:33:WU00:FS02:0x21:Completed 3800000 out of 5000000 steps (76%)
20:32:47:WU03:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
20:32:58:WU02:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
20:34:06:WU00:FS02:0x21:Completed 3850000 out of 5000000 steps (77%)
20:35:14:WU02:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
20:35:40:WU00:FS02:0x21:Completed 3900000 out of 5000000 steps (78%)
20:35:45:WU03:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
20:37:13:WU00:FS02:0x21:Completed 3950000 out of 5000000 steps (79%)
20:37:33:WU02:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
20:38:43:WU03:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
20:38:47:WU00:FS02:0x21:Completed 4000000 out of 5000000 steps (80%)
20:39:49:WU02:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
20:40:22:WU00:FS02:0x21:Completed 4050000 out of 5000000 steps (81%)
20:41:41:WU03:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
20:41:54:WU00:FS02:0x21:Completed 4100000 out of 5000000 steps (82%)
20:42:05:WU02:FS01:0x21:Completed 1575000 out of 2500000 steps (63%)
20:43:28:WU00:FS02:0x21:Completed 4150000 out of 5000000 steps (83%)
20:44:21:WU02:FS01:0x21:Completed 1600000 out of 2500000 steps (64%)
20:44:38:WU03:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
20:45:02:WU00:FS02:0x21:Completed 4200000 out of 5000000 steps (84%)
20:46:35:WU00:FS02:0x21:Completed 4250000 out of 5000000 steps (85%)
20:46:38:WU02:FS01:0x21:Completed 1625000 out of 2500000 steps (65%)
20:47:36:WU03:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
20:48:09:WU00:FS02:0x21:Completed 4300000 out of 5000000 steps (86%)
20:48:54:WU02:FS01:0x21:Completed 1650000 out of 2500000 steps (66%)
20:49:43:WU00:FS02:0x21:Completed 4350000 out of 5000000 steps (87%)
20:50:34:WU03:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
20:51:10:WU02:FS01:0x21:Completed 1675000 out of 2500000 steps (67%)
20:51:16:WU00:FS02:0x21:Completed 4400000 out of 5000000 steps (88%)
20:52:49:WU00:FS02:0x21:Completed 4450000 out of 5000000 steps (89%)
20:53:25:WU02:FS01:0x21:Completed 1700000 out of 2500000 steps (68%)
20:53:31:WU03:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
20:54:22:WU00:FS02:0x21:Completed 4500000 out of 5000000 steps (90%)
20:55:41:WU02:FS01:0x21:Completed 1725000 out of 2500000 steps (69%)
20:55:58:WU00:FS02:0x21:Completed 4550000 out of 5000000 steps (91%)
20:56:29:WU03:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
20:57:32:WU00:FS02:0x21:Completed 4600000 out of 5000000 steps (92%)
20:57:57:WU02:FS01:0x21:Completed 1750000 out of 2500000 steps (70%)
20:59:06:WU00:FS02:0x21:Completed 4650000 out of 5000000 steps (93%)
20:59:28:WU03:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
21:00:17:WU02:FS01:0x21:Completed 1775000 out of 2500000 steps (71%)
21:00:41:WU00:FS02:0x21:Completed 4700000 out of 5000000 steps (94%)
21:02:14:WU00:FS02:0x21:Completed 4750000 out of 5000000 steps (95%)
21:02:27:WU03:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
21:02:33:WU02:FS01:0x21:Completed 1800000 out of 2500000 steps (72%)
21:03:49:WU00:FS02:0x21:Completed 4800000 out of 5000000 steps (96%)
21:04:49:WU02:FS01:0x21:Completed 1825000 out of 2500000 steps (73%)
21:05:22:WU00:FS02:0x21:Completed 4850000 out of 5000000 steps (97%)
21:05:25:WU03:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
21:06:55:WU00:FS02:0x21:Completed 4900000 out of 5000000 steps (98%)
21:07:05:WU02:FS01:0x21:Completed 1850000 out of 2500000 steps (74%)
21:08:23:WU03:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
21:08:28:WU00:FS02:0x21:Completed 4950000 out of 5000000 steps (99%)
21:08:29:WU01:FS02:Connecting to 65.254.110.245:8080
21:08:30:WU01:FS02:Assigned to work server 140.163.4.231
21:08:30:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
21:08:30:WU01:FS02:Connecting to 140.163.4.231:8080
21:08:30:WU01:FS02:Downloading 25.27MiB
21:08:36:WU01:FS02:Download 90.76%
21:08:36:WU01:FS02:Download complete
21:08:36:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11718 run:0 clone:1568 gen:181 core:0x21 unit:0x000000e98ca304e75b89900abdd7b2c8
21:09:21:WU02:FS01:0x21:Completed 1875000 out of 2500000 steps (75%)
21:10:02:WU00:FS02:0x21:Completed 5000000 out of 5000000 steps (100%)
21:10:03:WU00:FS02:0x21:Saving result file logfile_01.txt
21:10:03:WU00:FS02:0x21:Saving result file checkpointState.xml
21:10:03:WU00:FS02:0x21:Saving result file checkpt.crc
21:10:03:WU00:FS02:0x21:Saving result file log.txt
21:10:03:WU00:FS02:0x21:Saving result file positions.xtc
21:10:03:WU00:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
21:10:04:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:10:04:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:11720 run:0 clone:894 gen:199 core:0x21 unit:0x000000f78ca304e75b89a0c2cec771fd
21:10:04:WU00:FS02:Uploading 7.02MiB to 140.163.4.231
21:10:04:WU00:FS02:Connecting to 140.163.4.231:8080
21:10:04:WU01:FS02:Starting
21:10:04:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
21:10:04:WU01:FS02:Started FahCore on PID 13092
21:10:04:WU01:FS02:Core PID:5144
21:10:04:WU01:FS02:FahCore 0x21 started
21:10:04:WU01:FS02:0x21:*********************** Log Started 2018-11-18T21:10:04Z ***********************
21:10:04:WU01:FS02:0x21:Project: 11718 (Run 0, Clone 1568, Gen 181)
21:10:04:WU01:FS02:0x21:Unit: 0x000000e98ca304e75b89900abdd7b2c8
21:10:04:WU01:FS02:0x21:CPU: 0x00000000000000000000000000000000
21:10:04:WU01:FS02:0x21:Machine: 2
21:10:04:WU01:FS02:0x21:Reading tar file core.xml
21:10:04:WU01:FS02:0x21:Reading tar file integrator.xml
21:10:04:WU01:FS02:0x21:Reading tar file state.xml
21:10:04:WU01:FS02:0x21:Reading tar file system.xml
21:10:04:WU01:FS02:0x21:Digital signatures verified
21:10:04:WU01:FS02:0x21:Folding@home GPU Core21 Folding@home Core
21:10:04:WU01:FS02:0x21:Version 0.0.18
21:10:15:WU00:FS02:Upload 13.35%
21:10:18:WU01:FS02:0x21:Completed 0 out of 5000000 steps (0%)
21:10:18:WU01:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:10:21:WU00:FS02:Upload 52.51%
21:10:27:WU00:FS02:Upload 89.90%
21:10:30:WU00:FS02:Upload complete
21:10:30:WU00:FS02:Server responded WORK_ACK (400)
21:10:30:WU00:FS02:Final credit estimate, 38791.00 points
21:10:30:WU00:FS02:Cleaning up
21:11:20:WU03:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
21:11:36:WU02:FS01:0x21:Completed 1900000 out of 2500000 steps (76%)
21:13:44:WU01:FS02:0x21:Completed 50000 out of 5000000 steps (1%)
21:13:51:WU02:FS01:0x21:Completed 1925000 out of 2500000 steps (77%)
21:14:18:WU03:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
21:16:07:WU02:FS01:0x21:Completed 1950000 out of 2500000 steps (78%)
21:17:11:WU01:FS02:0x21:Completed 100000 out of 5000000 steps (2%)
21:17:16:WU03:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
21:18:23:WU02:FS01:0x21:Completed 1975000 out of 2500000 steps (79%)
21:20:15:WU03:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
21:20:36:WU01:FS02:0x21:Completed 150000 out of 5000000 steps (3%)
21:20:38:WU02:FS01:0x21:Completed 2000000 out of 2500000 steps (80%)
21:22:57:WU02:FS01:0x21:Completed 2025000 out of 2500000 steps (81%)
21:23:12:WU03:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
21:24:02:WU01:FS02:0x21:Completed 200000 out of 5000000 steps (4%)
21:25:13:WU02:FS01:0x21:Completed 2050000 out of 2500000 steps (82%)
21:26:10:WU03:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
21:27:27:WU01:FS02:0x21:Completed 250000 out of 5000000 steps (5%)
21:27:30:WU02:FS01:0x21:Completed 2075000 out of 2500000 steps (83%)
21:27:35:WARNING:FS02:Size of positions 5845 does not match topology 5844
21:29:07:WU03:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
21:29:47:WU02:FS01:0x21:Completed 2100000 out of 2500000 steps (84%)
21:30:56:WU01:FS02:0x21:Completed 300000 out of 5000000 steps (6%)
21:32:02:WU02:FS01:0x21:Completed 2125000 out of 2500000 steps (85%)
21:32:07:WU03:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
21:34:17:WU02:FS01:0x21:Completed 2150000 out of 2500000 steps (86%)
21:34:22:WU01:FS02:0x21:Completed 350000 out of 5000000 steps (7%)
21:35:05:WU03:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
21:36:32:WU02:FS01:0x21:Completed 2175000 out of 2500000 steps (87%)
21:37:47:WU01:FS02:0x21:Completed 400000 out of 5000000 steps (8%)
21:38:02:WU03:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
21:38:47:WU02:FS01:0x21:Completed 2200000 out of 2500000 steps (88%)
21:41:00:WU03:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
21:41:02:WU02:FS01:0x21:Completed 2225000 out of 2500000 steps (89%)
21:41:13:WU01:FS02:0x21:Completed 450000 out of 5000000 steps (9%)
21:43:18:WU02:FS01:0x21:Completed 2250000 out of 2500000 steps (90%)
21:43:57:WU03:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
21:44:39:WU01:FS02:0x21:Completed 500000 out of 5000000 steps (10%)
21:44:46:WARNING:FS02:Size of positions 5845 does not match topology 5844
21:45:34:50:127.0.0.1:New Web connection
21:45:38:WU02:FS01:0x21:Completed 2275000 out of 2500000 steps (91%)
21:46:56:WU03:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
21:47:55:WU02:FS01:0x21:Completed 2300000 out of 2500000 steps (92%)
21:48:08:WU01:FS02:0x21:Completed 550000 out of 5000000 steps (11%)
21:49:54:WU03:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
21:50:12:WU02:FS01:0x21:Completed 2325000 out of 2500000 steps (93%)
21:51:34:WU01:FS02:0x21:Completed 600000 out of 5000000 steps (12%)
21:52:29:WU02:FS01:0x21:Completed 2350000 out of 2500000 steps (94%)
21:52:51:WU03:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
21:54:47:WU02:FS01:0x21:Completed 2375000 out of 2500000 steps (95%)
21:55:00:WU01:FS02:0x21:Completed 650000 out of 5000000 steps (13%)
21:55:47:WU03:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
21:57:05:WU02:FS01:0x21:Completed 2400000 out of 2500000 steps (96%)
21:58:27:WU01:FS02:0x21:Completed 700000 out of 5000000 steps (14%)
21:58:44:WU03:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
21:59:22:WU02:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
22:01:39:WU02:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
22:01:40:WU03:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
22:01:53:WU01:FS02:0x21:Completed 750000 out of 5000000 steps (15%)
22:02:00:WARNING:FS02:Size of positions 5845 does not match topology 5844
22:03:57:WU02:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
22:03:58:WU00:FS01:Connecting to 65.254.110.245:8080
22:03:59:WU00:FS01:Assigned to work server 140.163.4.231
22:03:59:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
22:03:59:WU00:FS01:Connecting to 140.163.4.231:8080
22:04:00:WU00:FS01:Downloading 11.29MiB
22:04:06:WU00:FS01:Download 38.20%
22:04:12:WU00:FS01:Download 86.91%
22:04:17:WU00:FS01:Download complete
22:04:17:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11720 run:0 clone:930 gen:376 core:0x21 unit:0x000001c38ca304e75b89a0c3623159d0
22:04:37:WU03:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
22:05:23:WU01:FS02:0x21:Completed 800000 out of 5000000 steps (16%)
22:06:15:WU02:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
22:06:18:WU02:FS01:0x21:Saving result file logfile_01.txt
22:06:18:WU02:FS01:0x21:Saving result file checkpointState.xml
22:06:19:WU02:FS01:0x21:Saving result file checkpt.crc
22:06:19:WU02:FS01:0x21:Saving result file log.txt
22:06:19:WU02:FS01:0x21:Saving result file positions.xtc
22:06:19:WU02:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
22:06:20:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:06:20:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11730 run:4 clone:692 gen:115 core:0x21 unit:0x0000008a8ca304e75bcd3742b615537f
22:06:20:WU02:FS01:Uploading 18.29MiB to 140.163.4.231
22:06:20:WU00:FS01:Starting
22:06:20:WU02:FS01:Connecting to 140.163.4.231:8080
22:06:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
22:06:20:WU00:FS01:Started FahCore on PID 4692
22:06:20:WU00:FS01:Core PID:3856
22:06:20:WU00:FS01:FahCore 0x21 started
22:06:20:WU00:FS01:0x21:*********************** Log Started 2018-11-18T22:06:20Z ***********************
22:06:20:WU00:FS01:0x21:Project: 11720 (Run 0, Clone 930, Gen 376)
22:06:20:WU00:FS01:0x21:Unit: 0x000001c38ca304e75b89a0c3623159d0
22:06:20:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
22:06:20:WU00:FS01:0x21:Machine: 1
22:06:20:WU00:FS01:0x21:Reading tar file core.xml
22:06:20:WU00:FS01:0x21:Reading tar file integrator.xml
22:06:20:WU00:FS01:0x21:Reading tar file state.xml
22:06:20:WU00:FS01:0x21:Reading tar file system.xml
22:06:20:WU00:FS01:0x21:Digital signatures verified
22:06:20:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
22:06:20:WU00:FS01:0x21:Version 0.0.18
22:06:26:WU02:FS01:Upload 17.09%
22:06:29:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
22:06:29:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:06:32:WU02:FS01:Upload 41.01%
22:06:38:WU02:FS01:Upload 55.36%
22:06:44:WU02:FS01:Upload 62.53%
22:06:50:WU02:FS01:Upload 77.57%
22:06:56:WU02:FS01:Upload 91.24%
22:07:02:WU02:FS01:Upload 99.44%
22:07:04:WU02:FS01:Upload complete
22:07:04:WU02:FS01:Server responded WORK_ACK (400)
22:07:04:WU02:FS01:Final credit estimate, 55448.00 points
22:07:04:WU02:FS01:Cleaning up
22:07:34:WU03:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
22:08:03:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
22:08:51:WU01:FS02:0x21:Completed 850000 out of 5000000 steps (17%)
22:09:36:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
22:10:31:WU03:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
22:10:42:95:127.0.0.1:New Web connection
22:11:10:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
22:12:18:WU01:FS02:0x21:Completed 900000 out of 5000000 steps (18%)
22:12:43:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
22:13:29:WU03:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
22:14:16:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
22:15:44:WU01:FS02:0x21:Completed 950000 out of 5000000 steps (19%)
22:15:51:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
22:16:26:WU03:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
22:17:24:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
22:18:58:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
22:19:10:WU01:FS02:0x21:Completed 1000000 out of 5000000 steps (20%)
22:19:18:WARNING:FS02:Size of positions 5845 does not match topology 5844
22:19:24:WU03:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
22:20:31:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
22:22:04:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
22:22:22:WU03:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
22:22:40:WU01:FS02:0x21:Completed 1050000 out of 5000000 steps (21%)
22:23:38:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
22:25:11:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
22:25:21:WU03:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
22:26:05:WU01:FS02:0x21:Completed 1100000 out of 5000000 steps (22%)
22:26:43:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
22:28:16:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
22:28:19:WU03:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
22:29:31:WU01:FS02:0x21:Completed 1150000 out of 5000000 steps (23%)
22:29:48:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
22:31:18:WU03:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
22:31:22:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
22:32:54:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
22:32:57:WU01:FS02:0x21:Completed 1200000 out of 5000000 steps (24%)
22:34:16:WU03:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
22:34:28:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
22:36:00:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
22:36:24:WU01:FS02:0x21:Completed 1250000 out of 5000000 steps (25%)
22:36:31:WARNING:FS02:Size of positions 5845 does not match topology 5844
22:37:16:WU03:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
22:37:33:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
22:39:07:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
22:39:52:WU01:FS02:0x21:Completed 1300000 out of 5000000 steps (26%)
22:40:14:WU03:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
22:40:40:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
22:42:12:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
22:43:13:WU03:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
22:43:19:WU01:FS02:0x21:Completed 1350000 out of 5000000 steps (27%)
22:43:45:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
22:45:17:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
22:46:11:WU03:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
22:46:44:WU01:FS02:0x21:Completed 1400000 out of 5000000 steps (28%)
22:46:51:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
22:48:23:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
22:49:10:WU03:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
22:49:11:WU02:FS00:Connecting to 65.254.110.245:8080
22:49:12:WU02:FS00:Assigned to work server 128.252.203.2
22:49:12:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 128.252.203.2
22:49:12:WU02:FS00:Connecting to 128.252.203.2:8080
22:49:12:WU02:FS00:Downloading 4.55MiB
22:49:14:WU02:FS00:Download complete
22:49:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13814 run:0 clone:1637 gen:115 core:0xa7 unit:0x0000009580fccb025ae08f6af721993b
22:49:57:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
22:50:10:WU01:FS02:0x21:Completed 1450000 out of 5000000 steps (29%)
22:51:29:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
22:52:10:WU03:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
22:52:13:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
22:52:13:WU03:FS00:0xa7:Saving result file frame296.trr
22:52:13:WU03:FS00:0xa7:Saving result file frame296.xtc
22:52:13:WU03:FS00:0xa7:Saving result file md.log
22:52:13:WU03:FS00:0xa7:Saving result file science.log
22:52:13:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
22:52:13:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:52:13:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:13812 run:0 clone:323 gen:296 core:0xa7 unit:0x0000016780fccb025a981926cbe3012a
22:52:13:WU03:FS00:Uploading 10.40MiB to 128.252.203.2
22:52:13:WU03:FS00:Connecting to 128.252.203.2:8080
22:52:13:WU02:FS00:Starting
22:52:13:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -np 10
22:52:13:WU02:FS00:Started FahCore on PID 12156
22:52:13:WU02:FS00:Core PID:7252
22:52:13:WU02:FS00:FahCore 0xa7 started
22:52:14:WU02:FS00:0xa7:*********************** Log Started 2018-11-18T22:52:14Z ***********************
22:52:14:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:52:14:WU02:FS00:0xa7:       Type: 0xa7
22:52:14:WU02:FS00:0xa7:       Core: Gromacs
22:52:14:WU02:FS00:0xa7:    Website: https://foldingathome.org/
22:52:14:WU02:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
22:52:14:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:52:14:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 12156 -checkpoint 15 -np
22:52:14:WU02:FS00:0xa7:             10
22:52:14:WU02:FS00:0xa7:     Config: <none>
22:52:14:WU02:FS00:0xa7:************************************ Build *************************************
22:52:14:WU02:FS00:0xa7:    Version: 0.0.17
22:52:14:WU02:FS00:0xa7:       Date: Apr 27 2018
22:52:14:WU02:FS00:0xa7:       Time: 16:19:36
22:52:14:WU02:FS00:0xa7: Repository: Git
22:52:14:WU02:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
22:52:14:WU02:FS00:0xa7:     Branch: master
22:52:14:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
22:52:14:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:52:14:WU02:FS00:0xa7:   Platform: win32 10
22:52:14:WU02:FS00:0xa7:       Bits: 64
22:52:14:WU02:FS00:0xa7:       Mode: Release
22:52:14:WU02:FS00:0xa7:       SIMD: avx_256
22:52:14:WU02:FS00:0xa7:************************************ System ************************************
22:52:14:WU02:FS00:0xa7:        CPU: Unknown
22:52:14:WU02:FS00:0xa7:     CPU ID:
22:52:14:WU02:FS00:0xa7:       CPUs: 12
22:52:14:WU02:FS00:0xa7:     Memory: 15.95GiB
22:52:14:WU02:FS00:0xa7:Free Memory: 12.10GiB
22:52:14:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
22:52:14:WU02:FS00:0xa7: OS Version: 6.2
22:52:14:WU02:FS00:0xa7:Has Battery: false
22:52:14:WU02:FS00:0xa7: On Battery: false
22:52:14:WU02:FS00:0xa7: UTC Offset: -8
22:52:14:WU02:FS00:0xa7:        PID: 7252
22:52:14:WU02:FS00:0xa7:        CWD: C:\Users\xysto\AppData\Roaming\FAHClient\work
22:52:14:WU02:FS00:0xa7:         OS: Windows 10 Pro
22:52:14:WU02:FS00:0xa7:    OS Arch: AMD64
22:52:14:WU02:FS00:0xa7:********************************************************************************
22:52:14:WU02:FS00:0xa7:Project: 13814 (Run 0, Clone 1637, Gen 115)
22:52:14:WU02:FS00:0xa7:Unit: 0x0000009580fccb025ae08f6af721993b
22:52:14:WU02:FS00:0xa7:Reading tar file core.xml
22:52:14:WU02:FS00:0xa7:Reading tar file frame115.tpr
22:52:14:WU02:FS00:0xa7:Digital signatures verified
22:52:14:WU02:FS00:0xa7:Calling: mdrun -s frame115.tpr -o frame115.trr -x frame115.xtc -cpt 15 -nt 10
22:52:14:WU02:FS00:0xa7:Steps: first=28750000 total=250000
22:52:15:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
22:52:19:WU03:FS00:Upload 19.22%
22:52:25:WU03:FS00:Upload 44.45%
22:52:31:WU03:FS00:Upload 55.86%
22:52:37:WU03:FS00:Upload 66.68%
22:52:43:WU03:FS00:Upload 90.10%
22:52:47:WU03:FS00:Upload complete
22:52:47:WU03:FS00:Server responded WORK_ACK (400)
22:52:47:WU03:FS00:Final credit estimate, 8624.00 points
22:52:47:WU03:FS00:Cleaning up
22:53:02:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
22:53:36:WU01:FS02:0x21:Completed 1500000 out of 5000000 steps (30%)
22:53:43:WARNING:FS02:Size of positions 5845 does not match topology 5844
22:54:35:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
22:55:23:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
22:56:08:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
22:57:04:WU01:FS02:0x21:Completed 1550000 out of 5000000 steps (31%)
22:57:41:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
22:58:30:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
22:59:14:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
23:00:31:WU01:FS02:0x21:Completed 1600000 out of 5000000 steps (32%)
23:00:47:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
23:01:36:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
23:02:20:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
23:03:53:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
23:03:56:WU01:FS02:0x21:Completed 1650000 out of 5000000 steps (33%)
23:04:43:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
23:05:26:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
23:06:59:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
23:07:22:WU01:FS02:0x21:Completed 1700000 out of 5000000 steps (34%)
23:07:50:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
23:08:32:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
23:10:05:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
23:10:47:WU01:FS02:0x21:Completed 1750000 out of 5000000 steps (35%)
23:10:55:WARNING:FS02:Size of positions 5845 does not match topology 5844
23:10:57:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
23:11:39:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
23:13:11:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
23:14:03:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
23:14:15:WU01:FS02:0x21:Completed 1800000 out of 5000000 steps (36%)
23:14:44:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
23:16:18:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
23:17:09:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
23:17:41:WU01:FS02:0x21:Completed 1850000 out of 5000000 steps (37%)
23:17:51:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
23:19:24:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
23:20:16:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
23:20:57:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
23:21:07:WU01:FS02:0x21:Completed 1900000 out of 5000000 steps (38%)
23:22:30:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
23:23:23:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
23:24:02:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
23:24:33:WU01:FS02:0x21:Completed 1950000 out of 5000000 steps (39%)
23:25:36:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
23:26:29:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
23:27:09:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
23:27:58:WU01:FS02:0x21:Completed 2000000 out of 5000000 steps (40%)
23:28:05:WARNING:FS02:Size of positions 5845 does not match topology 5844
23:28:42:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
23:29:36:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
23:30:15:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
23:31:27:WU01:FS02:0x21:Completed 2050000 out of 5000000 steps (41%)
23:31:48:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
23:32:42:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
23:33:21:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
23:34:53:WU01:FS02:0x21:Completed 2100000 out of 5000000 steps (42%)
23:34:55:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
23:35:49:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
23:36:27:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
23:38:00:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
23:38:19:WU01:FS02:0x21:Completed 2150000 out of 5000000 steps (43%)
23:38:56:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
23:39:33:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
23:41:07:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
23:41:44:WU01:FS02:0x21:Completed 2200000 out of 5000000 steps (44%)
23:42:03:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
23:42:39:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
23:44:12:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
23:45:09:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
23:45:10:WU01:FS02:0x21:Completed 2250000 out of 5000000 steps (45%)
23:45:17:WARNING:FS02:Size of positions 5845 does not match topology 5844
23:45:45:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
23:47:18:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
23:48:15:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
23:48:38:WU01:FS02:0x21:Completed 2300000 out of 5000000 steps (46%)
23:48:51:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
23:50:25:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
23:51:23:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
23:51:57:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
23:52:04:WU01:FS02:0x21:Completed 2350000 out of 5000000 steps (47%)
23:53:29:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
23:54:29:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:55:02:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
23:55:30:WU01:FS02:0x21:Completed 2400000 out of 5000000 steps (48%)
23:56:36:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
23:57:35:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:58:09:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
23:58:56:WU01:FS02:0x21:Completed 2450000 out of 5000000 steps (49%)
23:59:41:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
00:00:42:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
00:01:14:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
00:02:21:WU01:FS02:0x21:Completed 2500000 out of 5000000 steps (50%)
00:02:29:WARNING:FS02:Size of positions 5845 does not match topology 5844
00:02:47:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
00:03:49:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
00:04:21:WU00:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
00:05:50:WU01:FS02:0x21:Completed 2550000 out of 5000000 steps (51%)
00:05:54:WU00:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
00:06:56:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
00:07:27:WU00:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
00:09:00:WU00:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
00:09:16:WU01:FS02:0x21:Completed 2600000 out of 5000000 steps (52%)
00:10:03:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
00:10:33:WU00:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
00:12:07:WU00:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
00:12:41:WU01:FS02:0x21:Completed 2650000 out of 5000000 steps (53%)
00:13:09:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
00:13:39:WU00:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
00:15:12:WU00:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
00:16:07:WU01:FS02:0x21:Completed 2700000 out of 5000000 steps (54%)
00:16:15:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
00:16:45:WU00:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
00:18:18:WU00:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
00:19:22:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
00:19:34:WU01:FS02:0x21:Completed 2750000 out of 5000000 steps (55%)
00:19:41:WARNING:FS02:Size of positions 5845 does not match topology 5844
00:19:51:WU00:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
00:21:25:WU00:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
00:22:30:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
00:22:58:WU00:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
00:23:02:WU01:FS02:0x21:Completed 2800000 out of 5000000 steps (56%)
00:24:30:WU00:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
00:25:36:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
00:26:03:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
00:26:28:WU01:FS02:0x21:Completed 2850000 out of 5000000 steps (57%)
00:27:37:WU00:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
00:28:42:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
00:29:10:WU00:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
00:29:54:WU01:FS02:0x21:Completed 2900000 out of 5000000 steps (58%)
00:30:43:WU00:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
00:31:48:WU02:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
00:32:15:WU00:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
00:33:19:WU01:FS02:0x21:Completed 2950000 out of 5000000 steps (59%)
00:33:48:WU00:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
00:34:55:WU02:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
00:35:22:WU00:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
00:36:46:WU01:FS02:0x21:Completed 3000000 out of 5000000 steps (60%)
00:36:53:WARNING:FS02:Size of positions 5845 does not match topology 5844
00:36:55:WU00:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
00:38:02:WU02:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
00:38:28:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
00:40:01:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
00:40:02:WU03:FS01:Connecting to 65.254.110.245:8080
00:40:03:WU03:FS01:Assigned to work server 140.163.4.231
00:40:03:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
00:40:03:WU03:FS01:Connecting to 140.163.4.231:8080
00:40:03:WU03:FS01:Downloading 33.32MiB
00:40:09:WU03:FS01:Download 48.21%
00:40:15:WU01:FS02:0x21:Completed 3050000 out of 5000000 steps (61%)
00:40:15:WU03:FS01:Download 94.35%
00:40:16:WU03:FS01:Download complete
00:40:16:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11730 run:3 clone:777 gen:100 core:0x21 unit:0x0000007b8ca304e75bcd370d244f08ad
00:41:09:WU02:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
00:41:34:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
00:41:36:WU00:FS01:0x21:Saving result file logfile_01.txt
00:41:36:WU00:FS01:0x21:Saving result file checkpointState.xml
00:41:36:WU00:FS01:0x21:Saving result file checkpt.crc
00:41:36:WU00:FS01:0x21:Saving result file log.txt
00:41:36:WU00:FS01:0x21:Saving result file positions.xtc
00:41:36:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:41:36:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:41:36:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11720 run:0 clone:930 gen:376 core:0x21 unit:0x000001c38ca304e75b89a0c3623159d0
00:41:36:WU00:FS01:Uploading 7.02MiB to 140.163.4.231
00:41:36:WU00:FS01:Connecting to 140.163.4.231:8080
00:41:36:WU03:FS01:Starting
00:41:36:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xysto\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 705 -lifeline 10580 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:41:36:WU03:FS01:Started FahCore on PID 11392
00:41:36:WU03:FS01:Core PID:1360
00:41:36:WU03:FS01:FahCore 0x21 started
00:41:37:WU03:FS01:0x21:*********************** Log Started 2018-11-19T00:41:36Z ***********************
00:41:37:WU03:FS01:0x21:Project: 11730 (Run 3, Clone 777, Gen 100)
00:41:37:WU03:FS01:0x21:Unit: 0x0000007b8ca304e75bcd370d244f08ad
00:41:37:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:41:37:WU03:FS01:0x21:Machine: 1
00:41:37:WU03:FS01:0x21:Reading tar file core.xml
00:41:37:WU03:FS01:0x21:Reading tar file integrator.xml
00:41:37:WU03:FS01:0x21:Reading tar file state.xml
00:41:37:WU03:FS01:0x21:Reading tar file system.xml
00:41:37:WU03:FS01:0x21:Digital signatures verified
00:41:37:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:41:37:WU03:FS01:0x21:Version 0.0.18
00:41:42:WU00:FS01:Upload 32.05%
00:41:48:WU00:FS01:Upload 58.76%
00:41:53:WU03:FS01:0x21:Completed 0 out of 2500000 steps (0%)
00:41:53:WU03:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:41:54:WU00:FS01:Upload 86.37%
00:41:59:WU00:FS01:Upload complete
00:41:59:WU00:FS01:Server responded WORK_ACK (400)
00:41:59:WU00:FS01:Final credit estimate, 40340.00 points
00:41:59:WU00:FS01:Cleaning up
00:43:41:WU01:FS02:0x21:Completed 3100000 out of 5000000 steps (62%)
00:44:08:WU03:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
00:44:16:WU02:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
00:46:23:WU03:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
00:47:07:WU01:FS02:0x21:Completed 3150000 out of 5000000 steps (63%)
00:47:22:WU02:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
00:48:38:WU03:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
00:50:29:WU02:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
00:50:33:WU01:FS02:0x21:Completed 3200000 out of 5000000 steps (64%)
00:50:53:WU03:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
00:53:08:WU03:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
00:53:35:WU02:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
00:53:58:WU01:FS02:0x21:Completed 3250000 out of 5000000 steps (65%)
00:54:06:WARNING:FS02:Size of positions 5845 does not match topology 5844
00:55:23:WU03:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
00:56:41:WU02:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
00:57:27:WU01:FS02:0x21:Completed 3300000 out of 5000000 steps (66%)
00:57:38:WU03:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
00:59:47:WU02:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
00:59:52:WU03:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
01:00:53:WU01:FS02:0x21:Completed 3350000 out of 5000000 steps (67%)
******************************* Date: 2018-11-19 *******************************
01:02:07:WU03:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
01:02:53:WU02:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
01:04:19:WU01:FS02:0x21:Completed 3400000 out of 5000000 steps (68%)
01:04:23:WU03:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
01:06:00:WU02:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
01:06:41:WU03:FS01:0x21:Completed 275000 out of 2500000 steps (11%)
01:07:46:WU01:FS02:0x21:Completed 3450000 out of 5000000 steps (69%)
01:08:56:WU03:FS01:0x21:Completed 300000 out of 2500000 steps (12%)
01:09:06:WU02:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
01:11:12:WU01:FS02:0x21:Completed 3500000 out of 5000000 steps (70%)
01:11:12:WU03:FS01:0x21:Completed 325000 out of 2500000 steps (13%)
01:11:19:WARNING:FS02:Size of positions 5845 does not match topology 5844
01:12:10:WU02:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
01:13:28:WU03:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
01:14:41:WU01:FS02:0x21:Completed 3550000 out of 5000000 steps (71%)
Mod edit: add Code tags to log
As I recall, the web client interface reports stats based on your username, team and passkey. So that number will be only for the passkey entered into the client running on that system. A lookup on the Donor Stats site will show all points earned by your username.
xystophyte
Cryorig H5 Ultimate
OK, that's a possibility I hadn't considered. I have only folded as xystophyte, on team 37412, on one passkey. It's possible that some points went to another team or to the "no-team" scoresheet. I'll check that out. I was only concerned that I had a system error. The discrepancy between the stats isn't all that important.
Thank you.
Actually the mod lookup for your name in the database shows that four different passkeys have been used in connection with your username. Two might have been from a typo or dropped digit as only 5 WU's were returned with them. A third one has 99 WU's associated with it. The bulk of the WU's have been returned with the remaining passkey.
xystophyte
Cryorig H5 Ultimate
OK, thanks for checking. I had a GPU fail in Sept and I must have reentered the wrong passkey with the reconfig / reinstall. Typos, my bad.
Thanks to all.
