Please add Toshiba Nvidia Geforce 310M 10DE 0A75 - 1179 FF00
Cluthe
Post by Cluthe »
Title says it all, Toshiba Satelite A500 with Nvidia Geforce 310M, device ID - 10DE 0A75 - 1179 FF00 (from GPU-Z). Also for some reason the i3-330m cpu is showing up as unknown.
Thanks!
*********************** Log Started 2018-11-07T12:58:59Z ***********************
12:58:59:************************* Folding@home Client *************************
12:58:59:        Website: https://foldingathome.org/
12:58:59:      Copyright: (c) 2009-2018 foldingathome.org
12:58:59:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:58:59:           Args:
12:58:59:         Config: C:\Users\Phlebas\AppData\Roaming\FAHClient\config.xml
12:58:59:******************************** Build ********************************
12:58:59:        Version: 7.5.1
12:58:59:           Date: May 11 2018
12:58:59:           Time: 13:06:32
12:58:59:     Repository: Git
12:58:59:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:58:59:         Branch: master
12:58:59:       Compiler: Visual C++ 2008
12:58:59:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:58:59:       Platform: win32 10
12:58:59:           Bits: 32
12:58:59:           Mode: Release
12:58:59:******************************* System ********************************
12:58:59:            CPU: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
12:58:59:         CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
12:58:59:           CPUs: 4
12:58:59:         Memory: 5.86GiB
12:58:59:    Free Memory: 4.86GiB
12:58:59:        Threads: WINDOWS_THREADS
12:58:59:     OS Version: 6.1
12:58:59:    Has Battery: true
12:58:59:     On Battery: false
12:58:59:     UTC Offset: -5
12:58:59:            PID: 2648
12:58:59:            CWD: C:\Users\Phlebas\AppData\Roaming\FAHClient
12:58:59:             OS: Windows 7 Ultimate
12:58:59:        OS Arch: AMD64
12:58:59:           GPUs: 0
12:58:59:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:6.5
12:58:59:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.0 Driver:342.1
12:58:59:  Win32 Service: false
12:58:59:***********************************************************************
12:58:59:<config>
12:58:59:  <!-- Folding Slot Configuration -->
12:58:59:  <cause v='CANCER'/>
12:58:59:
12:58:59:  <!-- Network -->
12:58:59:  <proxy v=':8080'/>
12:58:59:
12:58:59:  <!-- Slot Control -->
12:58:59:  <power v='full'/>
12:58:59:
12:58:59:  <!-- User Information -->
12:58:59:  <passkey v='********************************'/>
12:58:59:  <user v='Tiggerific'/>
12:58:59:
12:58:59:  <!-- Folding Slots -->
12:58:59:  <slot id='0' type='CPU'/>
12:58:59:</config>
12:58:59:Trying to access database...
12:59:00:Successfully acquired database lock
12:59:00:Enabled folding slot 00: READY cpu:4
12:59:33:WU00:FS00:Starting
12:59:33:WARNING:WU00:FS00:AS lowered CPUs from 4 to 3
12:59:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phlebas\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 2648 -checkpoint 15 -np 3
12:59:33:WU00:FS00:Started FahCore on PID 3440
12:59:33:WU00:FS00:Core PID:3460
12:59:33:WU00:FS00:FahCore 0xa7 started
12:59:38:WU00:FS00:0xa7:*********************** Log Started 2018-11-07T12:59:38Z ***********************
12:59:38:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:59:38:WU00:FS00:0xa7:       Type: 0xa7
12:59:38:WU00:FS00:0xa7:       Core: Gromacs
12:59:38:WU00:FS00:0xa7:    Website: https://foldingathome.org/
12:59:38:WU00:FS00:0xa7:  Copyright: (c) 2009-2018 foldingathome.org
12:59:38:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:59:38:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3440 -checkpoint 15 -np 3
12:59:38:WU00:FS00:0xa7:     Config: <none>
12:59:38:WU00:FS00:0xa7:************************************ Build *************************************
12:59:38:WU00:FS00:0xa7:    Version: 0.0.17
12:59:38:WU00:FS00:0xa7:       Date: Apr 27 2018
12:59:38:WU00:FS00:0xa7:       Time: 16:19:35
12:59:38:WU00:FS00:0xa7: Repository: Git
12:59:38:WU00:FS00:0xa7:   Revision: 21359963583d09ec2063ef946399441c4df4ccd7
12:59:38:WU00:FS00:0xa7:     Branch: master
12:59:38:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:59:38:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:59:38:WU00:FS00:0xa7:   Platform: win32 10
12:59:38:WU00:FS00:0xa7:       Bits: 64
12:59:38:WU00:FS00:0xa7:       Mode: Release
12:59:38:WU00:FS00:0xa7:       SIMD: sse2
12:59:38:WU00:FS00:0xa7:************************************ System ************************************
12:59:38:WU00:FS00:0xa7:        CPU: Unknown
12:59:38:WU00:FS00:0xa7:     CPU ID:
12:59:38:WU00:FS00:0xa7:       CPUs: 4
12:59:38:WU00:FS00:0xa7:     Memory: 5.86GiB
12:59:38:WU00:FS00:0xa7:Free Memory: 4.63GiB
12:59:38:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:59:38:WU00:FS00:0xa7: OS Version: 6.1
12:59:38:WU00:FS00:0xa7:Has Battery: true
12:59:38:WU00:FS00:0xa7: On Battery: false
12:59:38:WU00:FS00:0xa7: UTC Offset: -5
12:59:38:WU00:FS00:0xa7:        PID: 3460
12:59:38:WU00:FS00:0xa7:        CWD: C:\Users\Phlebas\AppData\Roaming\FAHClient\work
12:59:38:WU00:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
12:59:38:WU00:FS00:0xa7:    OS Arch: AMD64
12:59:38:WU00:FS00:0xa7:********************************************************************************
12:59:38:WU00:FS00:0xa7:Project: 14096 (Run 30, Clone 8, Gen 0)
12:59:38:WU00:FS00:0xa7:Unit: 0x000000010002894b5b7da5a009debd11
12:59:38:WU00:FS00:0xa7:Digital signatures verified
12:59:38:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 3
12:59:41:WU00:FS00:0xa7:Steps: first=0 total=500000
12:59:46:WU00:FS00:0xa7:Completed 183462 out of 500000 steps (36%)
13:06:15:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
Re: Please add Toshiba Nvidia Geforce 310M 10DE 0A75 - 1179
The Geforce 310M is already in the GPUs.txt file as an unsupported GPU. It is based on the Tesla architecture released over 8 years ago which is no longer usable for folding. Current GPU folding requirements for nVidia is a GPU based on the Fermi architecture or later.
0x10de:0x0a70:::GT218 [GeForce 310M]
0x10de:0x0a72:::GT218 [GeForce 310M]
0x10de:0x0a75:::GT218 [GeForce 310M]
