New User - Folding Paused
mdoheny
Post by mdoheny »
Hello,
I am a new user on macOS High Sierra. I have downloaded the software, however, I cannot get off of the paused option. My status states "Paused:on battery cpu:3". At the top it says "Client: local Online Inactive". Please let me know what I can do to begin folding.
Thanks for your help!
Re: New User - Folding Paused
FAH uses power continuously which would rapidly deplete the battery. The default configuration is set to avoid running down the battery. Have you tried plugging in the power brick?
mikros
Post by mikros »
How to disable this? Option: pause-on battery = false: doesn't do anything.
I would like folding to continue even when on battery. I'm using Windows 10.
